Permission and usage of ACME project dir on NERSC
Hans, Can you recursively add execute permission for others on the following directory on NERSC? /project/projectdirs/acme/data/inputdata FYI, it also appears that the ACME project directory on NERSC has used up all it's disk quota. Thanks, -Gautam.
Hi Gautam - I will work with Jeff to fix this. We were trying to identify what input data files we needed for the ACME developer tests, and it's messy / a lot of files / ran out of disk space. Hans PS: Just so you know, I'll be out on vacation for two weeks. I would assume Jeff would have to address any issues at NERSC. On Tuesday, March 24, 2015, Gautam Bisht <[email protected]> wrote:
Hans,
Thanks, -Gautam.
Hi Hans, You may need to address the permissions issue yourself. For example,
ls -ld software/ACME drwxr-x--- 6 u6336 u6336 512 Feb 26 14:13 software/ACME
So this is group readable, but the group is u6336 and not acme. Also, no one but you can update this. Thanks. Pat On 3/24/15 3:12 PM, Hans Johansen wrote:
Hi Gautam -
Hans
Hans,
Thanks, -Gautam.
_______________________________________________ ACME-SE mailing list [email protected] https://lists.mcs.anl.gov/mailman/listinfo/acme-se
Yes, taking care of this now. It was an aborted attempt to establish what input files were required for the ACME developer tests. On Tuesday, March 24, 2015, Patrick Worley <[email protected]> wrote:
Thanks.
Pat
Hi Gautam -
Hans
On Tuesday, March 24, 2015, Gautam Bisht <[email protected]> <javascript:_e(%7B%7D,'cvml','[email protected]');> wrote:
Hans,
Thanks, -Gautam.
_______________________________________________ ACME-SE mailing [email protected] <javascript:_e(%7B%7D,'cvml','[email protected]');>https://lists.mcs.anl.gov/mailman/listinfo/acme-se
Aside from a few river model restart files, the tests need what is usually in the inputdata directory for running any case. Isn't there already a common directory for all the input data on NERSC? Rob On 3/24/15 2:41 PM, Hans Johansen wrote:
On Tuesday, March 24, 2015, Patrick Worley <[email protected] <mailto:[email protected]>> wrote:
Thanks.
Pat
Hi Gautam -
Hans
On Tuesday, March 24, 2015, Gautam Bisht<[email protected]> <javascript:_e(%7B%7D,'cvml','[email protected]');> wrote:
Hans,
Thanks, -Gautam.
_______________________________________________ ACME-SE mailing list [email protected] <javascript:_e(%7B%7D,'cvml','[email protected]');> https://lists.mcs.anl.gov/mailman/listinfo/acme-se
Rob, Our understanding is that the existing (“ccsm1”) directory will continue to be used for inputs that are common to ACME and existing CESM projects. It was unclear to us whether we could add inputs on the ACME side, since that would entail using non-ACME resources. But the way things work now, we’d have to choose a single place to store the files. It’s mostly a matter of how literal/stingy our charter is on sharing resources, I suppose. Jeff
Rob
Thanks.
Pat
Hi Gautam -
Hans
Hans,
Thanks, -Gautam.
Gautam - This should now be fixed, although we removed the inputdata directory since this is provided currently from: /project/projectdirs/ccsm1/inputdata For the SE team, I'd suggest we standardize on permissions based on this README Jeff and I created for Edison: https://acme-climate.atlassian.net/wiki/x/nYEzAQ Comments welcome as always - especially since I'm going on vacation :-). Hans On Tuesday, March 24, 2015, Gautam Bisht <[email protected]> wrote:
Hans,
Thanks, -Gautam.
participants (5)
Gautam Bisht -
Hans Johansen -
Jeffrey Johnson -
Patrick Worley -
Robert Jacob
