Thoughts on partial separability implementation
Hi, During our intermittent discussions about the partial separability work, both before the submission and during the AMR proposal writing we floated the idea of eliminating a loop that was considered wasteful by you, but convenient from an implementation standpoint by me. Specifically: The statements: #pragma $adic_partiallyseparable, fquad, flin *f = area*(p5*fquad+flin); were converted originally to: #pragma $adic_partiallyseparable, fquad, flin ADIC_SPARSE_Create1DimArray(&__adic_temp_f, ad_var_max); for (__adic_temp0 = 0; __adic_temp0 < ad_var_max; __adic_temp0++) { __adic_temp_f[__adic_temp0] = (area * ((p5 * fquad[__adic_temp0]) + flin[__adic_temp0])); } ADIC_SPARSE_Summation(f,__adic_temp_f,ad_var_max); where the grad_array of f is dense and large in size. f is an object of the class SparseDerivSeparable. The grad_array of __adic_temp_f, fquad, and flin are of size p, where p is the number of colors used by ColPack to compress the sparse elemental Jacobian. These variables are objects of the class SparseDeriv. DERIV_TYPE is typedeffed to SparseDeriv SparseDerivSeparable is a child of SparseDeriv.SparseDeriv contains a static array: double grad[ADIC_GRADVEC_LENGTH]; and SparseDerivSeparable contains a dynamically allocated array: double *grad;. The only location where a SparseDeriv object is used to compute a SparseDerivSeparable object is in the ADIC_SPARSE_Summation function. In the sparsity detection mode ADIC_SPARSE_Summation registers the sparsity patterns of __adic_temp_f. In the computation mode, uses the registered patterns along with the ColPack routines to compute f from __adic_temp_f. I went ahead an implemented a version that did not require a loop that calculates each element of __adic_temp_f. The output is given below: #pragma $adic_partiallyseparable, fquad, flin DERIV_TYPE *__adic_temp_flin; DERIV_TYPE *__adic_temp_fquad; ad_var_26 = ADIC_SPARSE_max(ad_var_0,ad_var_1); ADIC_SPARSE_Summation(__adic_temp_fquad,ad_fquad,ad_var_26); ad_var_27 = ADIC_SPARSE_max(ad_var_0,ad_var_1); ADIC_SPARSE_Summation(__adic_temp_flin,ad_flin,ad_var_27); ad_TempVartmp_7 = DERIV_val(ad_p5) * DERIV_val( *__adic_temp_fquad) + DERIV_val( *__adic_temp_flin); ad_TempVarSymbol_12 = DERIV_val(ad_area) * ad_TempVartmp_7; ad_TempVarlin_30 = ad_TempVartmp_7; ad_TempVarlin_32 = DERIV_val( *__adic_temp_fquad); ad_TempVarlin_33 = DERIV_val(ad_p5); ad_TempVarlin_31 = DERIV_val(ad_area); ADIC_SetValue( *f,ad_TempVarSymbol_12); ADIC_SetDeriv (DERIV_TYPE_ref(ad_area),DERIV_TYPE_ref(ad_TempVarprop_55)); ADIC_SetDeriv(DERIV_TYPE_ref(ad_p5),DERIV_TYPE_ref(ad_TempVarprop_56)); ADIC_SetDeriv (DERIV_TYPE_ref( *__adic_temp_fquad),DERIV_TYPE_ref(ad_TempVarprop_57)); ADIC_SetDeriv (DERIV_TYPE_ref( *__adic_temp_flin),DERIV_TYPE_ref(ad_TempVarprop_58)); ADIC_Sax_3 (1 ,DERIV_TYPE_ref (ad_TempVarprop_58 ),ad_TempVarlin_32 ,DERIV_TYPE_ref (ad_TempVarprop_56 ),ad_TempVarlin_33 ,DERIV_TYPE_ref(ad_TempVarprop_57),DERIV_TYPE_ref(ad_TempVarprop_59)); ADIC_Sax_2 (ad_TempVarlin_30 ,DERIV_TYPE_ref (ad_TempVarprop_55 ),ad_TempVarlin_31 ,DERIV_TYPE_ref(ad_TempVarprop_59),DERIV_TYPE_ref( *f)); } Right now, all temporary variables are objects of SparseDeriv. There are two calls to ADIC_SPARSE_Summation that assign values to the temporary variables __adic_temp_flin and __adic_temp_fquad These variables will be defined as SparseDerivSeparable within ADIC_SPARSE_Summation. Here begins the problem, the XAIFBooster output for the statement area*(p5*fquad+flin); requires ADIC_Sax_# and SetDeriv calls which causes assignments of SparseDeriv to SparseDerivSeparable and vice-versa. Statements such as: ADIC_SetDeriv (DERIV_TYPE_ref( *__adic_temp_fquad),DERIV_TYPE_ref(ad_TempVarprop_57)); can probably be handled by intelligent declaration of temporaries. However, the statement ADIC_Sax_3 (1 ,DERIV_TYPE_ref (ad_TempVarprop_58 ),ad_TempVarlin_32 ,DERIV_TYPE_ref (ad_TempVarprop_56 ),ad_TempVarlin_33 ,DERIV_TYPE_ref(ad_TempVarprop_57),DERIV_TYPE_ref(ad_TempVarprop_59)); is trickier to handle as it requires us to define the computation between a SparseDeriv type and a SparseDerivSeparable type. ad_TempVarprop_56 is just a temporary holding the grad_arrary of ad_area which is a SparseDeriv object. What can be noted is that ad_area is a non_elemental value that is also in effect inactive. So if we integrate ActivityAnalysis, we should be able to keep ad_area inactive (double type) and so the above situation should not occur. Are there any thoughts on this? I have not yet talked about possibly using f later on in the code in this email. I am assuming that the succeeding code is all SparseDerivSeparable. We will have to work out how to have different types and variables declaration co-existing harmoniously. Thanks, Krishna
participants (1)
Sri Hari Krishna Narayanan
