[ADIC] #42: adic2 binary not located in standard spot causes odd assumptions for intrinsic file location
#42: adic2 binary not located in standard spot causes odd assumptions for intrinsic file location -----------------------------+---------------------------------------------- Reporter: utke | Owner: Type: defect | Status: new Priority: minor | Milestone: Component: OA/Sage to XAIF | Version: Keywords: | -----------------------------+---------------------------------------------- e.g. by accident running /ADIC_build/.libs/adic2 gives Fatal Error at file , line 0, char 0 Message: unable to open primary document entity '/sandbox/Argonne/Dev/RoseFE/ADIC_build/share/inlinable_intrinsics.xaif' -- Ticket URL: <http://trac.mcs.anl.gov/projects/ADIC/ticket/42> ADIC <http://trac.mcs.anl.gov/projects/ADIC> ADIC: Automatic Differentiation for C and C++
#42: adic2 binary not located in standard spot causes odd assumptions for intrinsic file location -----------------------------+---------------------------------------------- Reporter: utke | Owner: Type: defect | Status: new Priority: minor | Milestone: Component: OA/Sage to XAIF | Version: Keywords: | -----------------------------+---------------------------------------------- Comment(by norris): This is not a bug -- the ADIC build is using libtool, and must be installed with 'make install' before being used (and never used in the build location). Libtool does not support or encourage using any of the temporary build artifacts and we certainly don't want to support such nonstandard use in adic. -- Ticket URL: <http://trac.mcs.anl.gov/projects/ADIC/ticket/42#comment:1> ADIC <http://trac.mcs.anl.gov/projects/ADIC> ADIC: Automatic Differentiation for C and C++
#42: adic2 binary not located in standard spot causes odd assumptions for intrinsic file location ------------------------------+--------------------------------------------- Reporter: utke | Owner: Type: defect | Status: closed Priority: minor | Milestone: Component: OA/Sage to XAIF | Version: Resolution: wontfix | Keywords: ------------------------------+--------------------------------------------- Changes (by norris): * status: new => closed * resolution: => wontfix -- Ticket URL: <http://trac.mcs.anl.gov/projects/ADIC/ticket/42#comment:2> ADIC <http://trac.mcs.anl.gov/projects/ADIC> ADIC: Automatic Differentiation for C and C++
participants (1)
ADIC
