Re: [Ad-dev] Managed to build
Kaveh, The latest revision has been developed with a lot more features that are used to support Fortran Input that may not work for the C side right now. Can you please try revision 631 or 587 with boost_1_43_0. I can provide better guidance for this. You should be able to upgrade to the latest version in a couple of weeks. Krishna On May 23, 2012, at 6:23 AM, Kaveh Vahedipour wrote:
I had to take the newest. 631 had another problem. Which I know how to fix in tehory but didn't wanna find out how complicated it would be in the end. Something about the compiler not knowing how to make a boost::unorder_list or so to ...
But I might know where the problem was anyways. It turns out that angel just built the static library and make was happy if an error had occured down the road and you thought that you had fixed it.
I have
64bit precise pangelot gcc-4.4 rose-0.9.5a-18998 xerces-2.8.0 xaifBooster (rev 125) angel (rev 82) boost 1.46.1 openanalysis 1.0 (svn)
Cheers, Kaveh.
On 23 May 2012, at 12:46, Sri Hari Krishna Narayanan wrote:
Hi Kaveh,
Can you tell me which revision of ADIC you checked out?
Thanks, Krishna
On May 23, 2012, at 4:15 AM, Kaveh Vahedipour wrote:
Dear ADIC team,
I have done my best to get ADIC2 compiled. I have finally made it. After many hours of trouble shooting code & build files. This is on 64bit Linux, btw.
However, this is the error that I am faced with now:
<snip> kvahed@beo-38 ~/ADIC/adic_source/tests/basic/exec/ mini1_forward_array> make make: Warning: File `Makefile' has modification time 97 s in the future
==== Using ADIC to generate derivative code (forward-dense) ======mini1_dense_forward.ad.c=== /usr/local/bin/adic2 mini1.c -mforward --nary ADIC DEBUG[Command Line][0]: ../adic_source/util/ BoostCommandLine.cpp 271 ROSE command line arguments: -rose:c mini1.c ERROR: caught exception: (../adic_source/main/ADIC.cpp: 322)LogicException: preprocessTemplateFile: no template file named found make: *** [mini1_dense_forward.ad.c] Error 255 </snip>
Do you have any suggestions as to how to proceed from here?
With highest regards, Kaveh Vahedipour.
--- Kaveh Vahedipour Institute of Neuroscience and Medicine Medical Imaging Physics Forschungszentrum Juelich GmbH 52425 Juelich Germany Phone: +49-2461-611921 Fax: +49-2461-611919 E-mail: [email protected] Web: http://www.fz-juelich.de/inm/inm-4
------------------------------------------------------------------------------------------------ ------------------------------------------------------------------------------------------------ Forschungszentrum Juelich GmbH 52425 Juelich Sitz der Gesellschaft: Juelich Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498 Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher Geschaeftsfuehrung: Prof. Dr. Achim Bachem (Vorsitzender), Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt, Prof. Dr. Sebastian M. Schmidt ------------------------------------------------------------------------------------------------ ------------------------------------------------------------------------------------------------
Kennen Sie schon unseren neuen Film? http://www.fz-juelich.de/film Kennen Sie schon unsere app? http://www.fz-juelich.de/app
participants (1)
