[ADIC] #47: active type variable declaration (for temporaries) needs to be based on xaif:symbol attribute
#47: active type variable declaration (for temporaries) needs to be based on xaif:symbol attribute --------------------------+------------------------------------------------- Reporter: utke | Owner: norris Type: defect | Status: new Priority: major | Milestone: Component: XAIF parsing | Version: Keywords: | --------------------------+------------------------------------------------- currently it is based on the xaif:VariableReference attribute which is supposed to express the "usage" (e.g. an activa variable used in a passive context would have active set to false). To declare the variable properly one has to look it up in the xaif:Scope and look at the xaif:Symbol active attribute -- Ticket URL: <http://trac.mcs.anl.gov/projects/ADIC/ticket/47> ADIC <http://trac.mcs.anl.gov/projects/ADIC> ADIC: Automatic Differentiation for C and C++
#47: active type variable declaration (for temporaries) needs to be based on xaif:symbol attribute --------------------------+------------------------------------------------- Reporter: utke | Owner: snarayan Type: defect | Status: accepted Priority: major | Milestone: Component: XAIF parsing | Version: Keywords: | --------------------------+------------------------------------------------- Changes (by snarayan): * owner: norris => snarayan * status: new => accepted -- Ticket URL: <http://trac.mcs.anl.gov/projects/ADIC/ticket/47#comment:1> ADIC <http://trac.mcs.anl.gov/projects/ADIC> ADIC: Automatic Differentiation for C and C++
#47: active type variable declaration (for temporaries) needs to be based on xaif:symbol attribute ---------------------------+------------------------------------------------ Reporter: utke | Owner: snarayan Type: defect | Status: closed Priority: major | Milestone: Component: XAIF parsing | Version: Resolution: fixed | Keywords: ---------------------------+------------------------------------------------ Changes (by snarayan): * status: accepted => closed * resolution: => fixed Comment: Fixed in revision @558:1a20925561a6 However, changes will be required once activity analysis results become available. -- Ticket URL: <http://trac.mcs.anl.gov/projects/ADIC/ticket/47#comment:2> ADIC <http://trac.mcs.anl.gov/projects/ADIC> ADIC: Automatic Differentiation for C and C++
#47: active type variable declaration (for temporaries) needs to be based on xaif:symbol attribute ---------------------------+------------------------------------------------ Reporter: utke | Owner: snarayan Type: defect | Status: closed Priority: major | Milestone: Component: XAIF parsing | Version: Resolution: fixed | Keywords: ---------------------------+------------------------------------------------ Comment(by snarayan): That should be revision r557 and r558 -- Ticket URL: <http://trac.mcs.anl.gov/projects/ADIC/ticket/47#comment:3> ADIC <http://trac.mcs.anl.gov/projects/ADIC> ADIC: Automatic Differentiation for C and C++
participants (1)
ADIC
