login Nightly Backup Cron
IBM Tivoli Storage Manager Command Line Backup-Archive Client Interface Client Version 6, Release 1, Level 0.0 Client date/time: 01/31/13 04:43:45 (c) Copyright by IBM Corporation and other(s) 1990, 2009. All Rights Reserved. Node Name: LOGIN.MREN.ORG Session established with server SRI: AIX-RS/6000 Server Version 5, Release 4, Level 2.0 Server date/time: 01/31/13 04:27:24 Last access: 01/30/13 04:30:58 Incremental backup of volume '/' Incremental backup of volume '/var' Successful incremental backup of '/var' ANS1228E Sending of object '/sandbox/beacon-backup/usr/share/doc/console-tools/examples/♪♬' failed ANS4042E Object name '/sandbox/beacon-backup/usr/share/doc/console-tools/examples/♪♬' contains one or more unrecognised characters and is not valid. ANS1228E Sending of object '/sandbox/starlsd-backup/opt/kde3/share/apps/kturtle/examples/fr_FR/carr�.logo' failed ANS4042E Object name '/sandbox/starlsd-backup/opt/kde3/share/apps/kturtle/examples/fr_FR/carr�.logo' contains one or more unrecognised characters and is not valid. ANS1228E Sending of object '/sandbox/starlsd-backup/opt/kde3/share/apps/kturtle/examples/fr_FR/enroul�.logo' failed ANS4042E Object name '/sandbox/starlsd-backup/opt/kde3/share/apps/kturtle/examples/fr_FR/enroul�.logo' contains one or more unrecognised characters and is not valid. ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/c0A7qLg' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/c0A7qLg': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/c1atImL' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/c1atImL': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/c2yv9PR' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/c2yv9PR': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/c3lBuL6' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/c3lBuL6': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/c3qL6xc' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/c3qL6xc': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cBu7mYD' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cBu7mYD': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cG1it4Y' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cG1it4Y': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cGo2rz0' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cGo2rz0': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cIse62E' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cIse62E': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cKfHddq' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cKfHddq': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cN5MMt5' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cN5MMt5': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cRUJbol' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cRUJbol': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cRqMq4w' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cRqMq4w': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cWR40BY' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cWR40BY': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cXJBoFO' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cXJBoFO': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cYjiKKf' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cYjiKKf': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cYsPbHy' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cYsPbHy': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cbbtuWN' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cbbtuWN': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/ce3KNEU' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/ce3KNEU': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/ce6lZqT' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/ce6lZqT': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/ceSs4zs' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/ceSs4zs': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cefySha' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cefySha': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cgJWSHj' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cgJWSHj': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cgRBnU4' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cgRBnU4': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/ch5mNrC' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/ch5mNrC': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/chPkGFa' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/chPkGFa': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/check0m6JJY' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/check0m6JJY': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/check3qTjM3' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/check3qTjM3': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/check4BMz8Y' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/check4BMz8Y': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/check5asyzt' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/check5asyzt': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/check5s5zzu' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/check5s5zzu': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/check77KnPy' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/check77KnPy': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkBOweKk' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkBOweKk': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkE9BZvO' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkE9BZvO': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkETIHS9' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkETIHS9': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkI16xEo' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkI16xEo': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkL1TTzO' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkL1TTzO': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkM263ZD' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkM263ZD': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkSjv7we' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkSjv7we': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkTUHqw4' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkTUHqw4': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkVGTaKk' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkVGTaKk': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkWT7dEU' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkWT7dEU': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkbsgEfV' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkbsgEfV': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkdsVsvE' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkdsVsvE': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkfvFj3I' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkfvFj3I': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkjMybfe' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkjMybfe': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkm7cMOo' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkm7cMOo': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkoTPjoT' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkoTPjoT': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkowQZQK' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkowQZQK': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkq5Kuuz' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkq5Kuuz': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checkqD3xdj' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checkqD3xdj': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checku29sV8' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checku29sV8': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/checku8FgiK' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/checku8FgiK': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cjtmk5H' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cjtmk5H': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/clgyxZK' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/clgyxZK': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cn4u0JI' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cn4u0JI': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cnECBbr' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cnECBbr': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/ctJKGcd' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/ctJKGcd': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cuT2Y2w' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cuT2Y2w': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cunJ7vm' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cunJ7vm': file not found ANS1228E Sending of object '/usr/local/nagios/mren-sl/var/spool/checkresults/cw9EKSC' failed ANS4005E Error processing '/usr/local/nagios/mren-sl/var/spool/checkresults/cw9EKSC': file not found ANS1228E Sending of object '/usr/local/pnp4nagios/var/stats/22660532' failed ANS4005E Error processing '/usr/local/pnp4nagios/var/stats/22660532': file not found ANS1228E Sending of object '/usr/share/doc/kbd/utf/♪♬' failed ANS4042E Object name '/usr/share/doc/kbd/utf/♪♬' contains one or more unrecognised characters and is not valid. ANS1802E Incremental backup of '/' finished with 66 failure Total number of objects inspected: 791,707 Total number of objects backed up: 2,792 Total number of objects updated: 0 Total number of objects rebound: 0 Total number of objects deleted: 0 Total number of objects expired: 20 Total number of objects failed: 66 Total number of bytes transferred: 476.23 MB Data transfer time: 29.30 sec Network data transfer rate: 16,642.87 KB/sec Aggregate data transfer rate: 154.04 KB/sec Objects compressed by: 81% Elapsed processing time: 00:52:45
participants (1)
root@mren.org
