/bin/sh ./config.status --recheck running CONFIG_SHELL=/bin/sh /bin/sh ../trunk/configure --enable-debug --enable-release --enable-32bit --with-occ=/opt/OpenCascade6.3-32bit --no-create --no-recursion checking build system type... x86_64-unknown-linux-gnu checking host system type... x86_64-unknown-linux-gnu checking target system type... x86_64-unknown-linux-gnu checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... /bin/mkdir -p checking for gawk... gawk checking whether make sets $(MAKE)... yes checking for style of include used by make... GNU checking for cc... cc checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether cc accepts -g... yes checking for cc option to accept ISO C89... none needed checking dependency style of cc... gcc3 checking how to run the C preprocessor... cc -E checking for CC... no checking for aCC... no checking for cxx... no checking for xlC_r... no checking for xlC... no checking for c++... c++ checking whether we are using the GNU C++ compiler... yes checking whether c++ accepts -g... yes checking dependency style of c++... gcc3 checking how to run the C++ preprocessor... c++ -E checking for gfortran... gfortran checking whether we are using the GNU Fortran compiler... yes checking whether gfortran accepts -g... yes checking for gfortran... gfortran checking whether we are using the GNU Fortran 77 compiler... yes checking whether gfortran accepts -g... yes checking for known C compilers... GNU checking for known compiler/OS combinations... GNU:x86_64 checking for known c++ compilers... GNU checking for known compiler/OS combinations... GNU:x86_64 checking whether we are using the GNU Fortran compiler... (cached) yes checking whether gfortran accepts -g... (cached) yes checking for a sed that does not truncate output... /bin/sed checking for grep that handles long lines and -e... /bin/grep checking for egrep... /bin/grep -E checking for ld used by cc... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for /usr/bin/ld option to reload object files... -r checking for BSD-compatible nm... /usr/bin/nm -B checking whether ln -s works... yes checking how to recognize dependent libraries... pass_all checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking dlfcn.h usability... yes checking dlfcn.h presence... yes checking for dlfcn.h... yes checking how to run the C++ preprocessor... c++ -E checking the maximum length of command line arguments... 98304 checking command to parse /usr/bin/nm -B output from cc object... ok checking for objdir... .libs checking for ar... ar checking for ranlib... ranlib checking for strip... strip checking if cc supports -fno-rtti -fno-exceptions... no checking for cc option to produce PIC... -fPIC checking if cc PIC flag -fPIC works... yes checking if cc static flag -static works... yes checking if cc supports -c -o file.o... yes checking whether the cc linker (/usr/bin/ld -m elf_i386) supports shared libraries... yes checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes checking if libtool supports shared libraries... yes checking whether to build shared libraries... no checking whether to build static libraries... yes configure: creating libtool appending configuration tag "CXX" to libtool checking for ld used by c++... /usr/bin/ld -m elf_i386 checking if the linker (/usr/bin/ld -m elf_i386) is GNU ld... yes checking whether the c++ linker (/usr/bin/ld -m elf_i386) supports shared libraries... yes checking for c++ option to produce PIC... -fPIC checking if c++ PIC flag -fPIC works... yes checking if c++ static flag -static works... yes checking if c++ supports -c -o file.o... yes checking whether the c++ linker (/usr/bin/ld -m elf_i386) supports shared libraries... yes checking dynamic linker characteristics... GNU/Linux ld.so (cached) (cached) checking how to hardcode library paths into programs... immediate appending configuration tag "F77" to libtool checking if libtool supports shared libraries... yes checking whether to build shared libraries... no checking whether to build static libraries... yes checking for gfortran option to produce PIC... -fPIC checking if gfortran PIC flag -fPIC works... yes checking if gfortran static flag -static works... yes checking if gfortran supports -c -o file.o... yes checking whether the gfortran linker (/usr/bin/ld -m elf_i386) supports shared libraries... yes checking dynamic linker characteristics... GNU/Linux ld.so (cached) (cached) checking how to hardcode library paths into programs... immediate checking whether byte ordering is bigendian... no checking how to get verbose linking output from gfortran... -v checking for Fortran libraries of gfortran... -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2 -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2/../../.. -lgfortranbegin -lgfortran -lm checking for dummy main to link with Fortran libraries... none checking for Fortran name-mangling scheme... unknown configure: WARNING: unknown Fortran name-mangling scheme checking for C++-standard library in std:: namespace... yes checking for C++-standard I/O in std:: namespace... yes checking if C++ template definitions should be included... yes checking for 'include' subdir of /opt/OpenCascade6.3-32bit... inc checking for 'lib' subdir of /opt/OpenCascade6.3-32bit... lib checking if platform is 64-bit (-D_OCC64)... no checking iostream usability... yes checking iostream presence... yes checking for iostream... yes checking iostream.h usability... no checking iostream.h presence... no checking for iostream.h... no checking iomanip usability... yes checking iomanip presence... yes checking for iomanip... yes checking iomanip.h usability... no checking iomanip.h presence... no checking for iomanip.h... no checking fstream usability... yes checking fstream presence... yes checking for fstream... yes checking fstream.h usability... no checking fstream.h presence... no checking for fstream.h... no checking limits.h usability... yes checking limits.h presence... yes checking for limits.h... yes checking Standard_Version.hxx usability... yes checking Standard_Version.hxx presence... yes checking for Standard_Version.hxx... yes checking for create_mailbox in -lTKernel... no checking for create_mailbox in -lTKernel... yes CXXFLAGS = -Wall -pipe -pedantic -g -m32 configure: creating ./config.status /bin/sh ./config.status config.status: creating Makefile config.status: creating util/Makefile config.status: creating geom/Makefile config.status: creating geom/ACIS/Makefile config.status: creating geom/Cholla/Makefile config.status: creating geom/facet/Makefile config.status: creating geom/facetbool/Makefile config.status: creating geom/OCC/Makefile config.status: creating geom/parallel/Makefile config.status: creating geom/virtual/Makefile config.status: creating init/Makefile config.status: creating compat/Makefile config.status: creating cgm.make config.status: creating itaps/Makefile config.status: creating itaps/iGeom-Defs.inc config.status: creating itaps/SIDL/Makefile config.status: creating test/Makefile config.status: creating cgm_apps/Makefile config.status: creating cgm_apps/examples/Makefile config.status: creating cgm_apps/examples/driverc++/Makefile config.status: creating cgm_apps/examples/facetdriver/Makefile config.status: creating config.h config.status: config.h is unchanged config.status: creating itaps/iBase_FCDefs.h config.status: itaps/iBase_FCDefs.h is unchanged config.status: executing depfiles commands make all-recursive make[1]: Entering directory `/home/jason/cgm/test/32-occ' Making all in compat make[2]: Entering directory `/home/jason/cgm/test/32-occ/compat' make[2]: Nothing to be done for `all'. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/compat' Making all in util make[2]: Entering directory `/home/jason/cgm/test/32-occ/util' make[2]: Nothing to be done for `all'. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/util' Making all in geom make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom' Making all in . make[3]: Entering directory `/home/jason/cgm/test/32-occ/geom' make[3]: Nothing to be done for `all-am'. make[3]: Leaving directory `/home/jason/cgm/test/32-occ/geom' Making all in Cholla make[3]: Entering directory `/home/jason/cgm/test/32-occ/geom/Cholla' make[3]: Nothing to be done for `all'. make[3]: Leaving directory `/home/jason/cgm/test/32-occ/geom/Cholla' Making all in facetbool make[3]: Entering directory `/home/jason/cgm/test/32-occ/geom/facetbool' make[3]: Nothing to be done for `all'. make[3]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facetbool' Making all in facet make[3]: Entering directory `/home/jason/cgm/test/32-occ/geom/facet' make[3]: Nothing to be done for `all'. make[3]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facet' Making all in virtual make[3]: Entering directory `/home/jason/cgm/test/32-occ/geom/virtual' make[3]: Nothing to be done for `all'. make[3]: Leaving directory `/home/jason/cgm/test/32-occ/geom/virtual' Making all in OCC make[3]: Entering directory `/home/jason/cgm/test/32-occ/geom/OCC' make[3]: Nothing to be done for `all'. make[3]: Leaving directory `/home/jason/cgm/test/32-occ/geom/OCC' make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom' Making all in init make[2]: Entering directory `/home/jason/cgm/test/32-occ/init' make[2]: Nothing to be done for `all'. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/init' Making all in . make[2]: Entering directory `/home/jason/cgm/test/32-occ' make[2]: Leaving directory `/home/jason/cgm/test/32-occ' Making all in itaps make[2]: Entering directory `/home/jason/cgm/test/32-occ/itaps' make all-recursive make[3]: Entering directory `/home/jason/cgm/test/32-occ/itaps' Making all in . make[4]: Entering directory `/home/jason/cgm/test/32-occ/itaps' make[4]: Leaving directory `/home/jason/cgm/test/32-occ/itaps' make[3]: Leaving directory `/home/jason/cgm/test/32-occ/itaps' make[2]: Leaving directory `/home/jason/cgm/test/32-occ/itaps' Making all in test make[2]: Entering directory `/home/jason/cgm/test/32-occ/test' make[2]: Nothing to be done for `all'. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/test' Making all in cgm_apps make[2]: Entering directory `/home/jason/cgm/test/32-occ/cgm_apps' Making all in examples make[3]: Entering directory `/home/jason/cgm/test/32-occ/cgm_apps/examples' Making all in facetdriver make[4]: Entering directory `/home/jason/cgm/test/32-occ/cgm_apps/examples/facetdriver' make[4]: Nothing to be done for `all'. make[4]: Leaving directory `/home/jason/cgm/test/32-occ/cgm_apps/examples/facetdriver' make[4]: Entering directory `/home/jason/cgm/test/32-occ/cgm_apps/examples' make[4]: Nothing to be done for `all-am'. make[4]: Leaving directory `/home/jason/cgm/test/32-occ/cgm_apps/examples' make[3]: Leaving directory `/home/jason/cgm/test/32-occ/cgm_apps/examples' make[3]: Entering directory `/home/jason/cgm/test/32-occ/cgm_apps' make[3]: Nothing to be done for `all-am'. make[3]: Leaving directory `/home/jason/cgm/test/32-occ/cgm_apps' make[2]: Leaving directory `/home/jason/cgm/test/32-occ/cgm_apps' make[1]: Leaving directory `/home/jason/cgm/test/32-occ' Making check in compat make[1]: Entering directory `/home/jason/cgm/test/32-occ/compat' make[1]: Nothing to be done for `check'. make[1]: Leaving directory `/home/jason/cgm/test/32-occ/compat' Making check in util make[1]: Entering directory `/home/jason/cgm/test/32-occ/util' make[1]: Nothing to be done for `check'. make[1]: Leaving directory `/home/jason/cgm/test/32-occ/util' Making check in geom make[1]: Entering directory `/home/jason/cgm/test/32-occ/geom' Making check in . make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom' make[2]: Nothing to be done for `check-am'. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom' Making check in Cholla make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/Cholla' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/Cholla' Making check in facetbool make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/facetbool' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facetbool' Making check in facet make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/facet' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facet' Making check in virtual make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/virtual' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/virtual' Making check in OCC make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/OCC' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/OCC' make[1]: Leaving directory `/home/jason/cgm/test/32-occ/geom' Making check in init make[1]: Entering directory `/home/jason/cgm/test/32-occ/init' make[1]: Nothing to be done for `check'. make[1]: Leaving directory `/home/jason/cgm/test/32-occ/init' Making check in . make[1]: Entering directory `/home/jason/cgm/test/32-occ' make[1]: Leaving directory `/home/jason/cgm/test/32-occ' Making check in itaps make[1]: Entering directory `/home/jason/cgm/test/32-occ/itaps' Making check in . make[2]: Entering directory `/home/jason/cgm/test/32-occ/itaps' make testgeom_occ make[3]: Entering directory `/home/jason/cgm/test/32-occ/itaps' make[3]: Leaving directory `/home/jason/cgm/test/32-occ/itaps' make check-TESTS make[3]: Entering directory `/home/jason/cgm/test/32-occ/itaps' Using default input file: ../../trunk/itaps/../test/LeverArm.brep Geometry engine set to: OCC Geometry Engine version 6.2.0 ITAPS GEOMETRY INTERFACE TEST PROGRAM: gLoad: Constructed 1 Volume: 1 Model contents: vertices: 99 edges: 159 faces: 63 regions: 1 Success tags: Tags defined on model: GLOBAL_ID, NAME Success gentity sets: Success topology adjacencies: Success construct: Created swept volume 4 Success primitives: Success transforms: Success booleans: Updated volume(s): 11 Destroyed volume(s): 12 Updated volume(s): 13 Updated volume(s): 13 Destroyed volume(s): 14 Success shutdown: Success TSTT TEST SUMMARY: Number Tests: 9 Number Successful: 9 Number Not Implemented: 0 Number Failed: 0 PASS: testgeom_occ ================== All 1 tests passed ================== make[3]: Leaving directory `/home/jason/cgm/test/32-occ/itaps' make[2]: Leaving directory `/home/jason/cgm/test/32-occ/itaps' make[1]: Leaving directory `/home/jason/cgm/test/32-occ/itaps' Making check in test make[1]: Entering directory `/home/jason/cgm/test/32-occ/test' make sheet modify makept r_w test_occ make[2]: Entering directory `/home/jason/cgm/test/32-occ/test' make[2]: `sheet' is up to date. make[2]: `modify' is up to date. make[2]: `makept' is up to date. make[2]: `r_w' is up to date. make[2]: `test_occ' is up to date. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/test' make check-TESTS make[2]: Entering directory `/home/jason/cgm/test/32-occ/test' PASS: sheet Modified volume Created volume(s): 9 Destroyed volume(s): 2 to 7 Exported: 1 OCC Body ======================================= Constructed 1 Volume: 10 ======================================= Updated volume(s): 19 Destroyed volume(s): 20 Created volume(s): 22, 23 Destroyed volume(s): 19, 21 Total 0 cuts performed, with from_shape having 6 faces. Total 1 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 1 cuts performed, with from_shape having 7 faces. Total 1 cuts performed, with from_shape having 8 faces. Updated volume(s): 26 Total 0 cuts performed, with from_shape having 6 faces. Total 1 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Updated volume(s): 27 Updated volume(s): 27 Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 1 cuts performed, with from_shape having 7 faces. Total 1 cuts performed, with from_shape having 8 faces. Updated volume(s): 27 Total 2 cuts performed, with from_shape having 8 faces. Updated volume(s): 24 Destroyed volume(s): 25 Modified volume Total 1 cuts performed, with from_shape having 7 faces. Total 0 cuts performed, with from_shape having 2 faces. Updated volume(s): 32 Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. WARNING: Cant make a scar on existing face without splitting it. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. WARNING: Cant make a scar on existing face without splitting it. Total 0 cuts performed, with from_shape having 6 faces. Updated volume(s): 33 Created volume(s): 34 WARNING: Surfaces or Shells can't be used to cut a body. ERROR: Subtract FAILED Total 4 cuts performed, with from_shape having 10 faces. Total 3 cuts performed, with from_shape having 9 faces. Updated volume(s): 35, 36 No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. Total 1 cuts performed, with from_shape having 6 faces. Total 1 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 1 cuts performed, with from_shape having 7 faces. Total 1 cuts performed, with from_shape having 8 faces. Total 0 cuts performed, with from_shape having 8 faces. Total 0 cuts performed, with from_shape having 8 faces. Total 0 cuts performed, with from_shape having 8 faces. Total 0 cuts performed, with from_shape having 8 faces. Total 0 cuts performed, with from_shape having 8 faces. Total 0 cuts performed, with from_shape having 8 faces. Removing projected curves Created volume(s): 39 Updated volume(s): 41 Destroyed volume(s): 40 Updated volume(s): 41 Destroyed volume(s): 42 The 1 body did not have common part with the tool_body. The 1 body did not have common part with the tool_body. Destroyed volume(s): 41, 43 Created volume(s): 46 Destroyed volume(s): 44 Updated volume(s): 45 Created volume(s): 49 Destroyed volume(s): 48 Updated volume(s): 47 Updated volume(s): 51 Destroyed volume(s): 50 Updated volume(s): 53 Destroyed volume(s): 52 Updated volume(s): 54 Destroyed volume(s): 55 Updated volume(s): 54 Modified volume Created swept volume 60 Modified volume Created swept volume 61 Created swept volume 62 Modified volume Created swept volume 63 ERROR: Only surfaces with no intersection point with the axis can be revolve-swept. Created swept volume 64 ERROR: Only curves with no intersection point with the axis can be revolve-swept. Created swept volume 65 Created swept volume 66 ERROR: Only curves with no intersection point with the axis can be revolve-swept. Created swept volume 67 Created swept volume 68 ERROR: Sweep along curve itself is not allowed. Created swept volume 69 Created swept volume 70 Modified volume Created swept volume 71 Created swept volume 72 ERROR: Errors found during Mergechk session. FAIL: modify ======================================= Constructed 1 Volume: 2 ======================================= ======================================= Constructed 1 Volume: 3 ======================================= ======================================= Constructed 2 Volumes: 4, 5 ======================================= Created volume(s): 6 to 10 Exported: 6 OCC Bodies 3 OCC Points Exported: 2 OCC Bodies 3 OCC Points PASS: makept ======================================= Constructed 2 Volumes: 1, 2 ======================================= Exported: 2 OCC Bodies ======================================= Constructed 2 Volumes: 3, 4 ======================================= Exported: 2 OCC Bodies Created volume(s): 5, 6 Destroyed volume(s): 3, 4 Exported: 2 OCC Bodies ======================================= Constructed 2 Volumes: 7, 8 ======================================= Updated volume(s): 7 Destroyed volume(s): 8 Exported: 1 OCC Body ======================================= Constructed 2 Volumes: 9, 10 ======================================= Updated volume(s): 10 Destroyed volume(s): 9 Exported: 1 OCC Body ======================================= Constructed 2 Volumes: 11, 12 ======================================= Updated volume(s): 11 Destroyed volume(s): 12 Exported: 1 OCC Body ======================================= Constructed 2 Volumes: 13, 14 ======================================= Updated volume(s): 14 Destroyed volume(s): 13 Exported: 1 OCC Body PASS: r_w Constructed 1 Volume: 1 done... PASS: test_occ =================== 1 of 5 tests failed =================== make[2]: *** [check-TESTS] Error 1 make[2]: Leaving directory `/home/jason/cgm/test/32-occ/test' make[1]: *** [check-am] Error 2 make[1]: Leaving directory `/home/jason/cgm/test/32-occ/test' make: *** [check-recursive] Error 1
participants (1)
Nightly Test
