Re: [cgma-dev] buildbot failure in cgm-shared: failed test
27 Apr
27 Apr
'11
3:26 p.m.
On Wed, 2011-04-27 at 12:39 -0500, Jason Kraftcheck wrote:
I cannot reproduce the problem below locally. I've tried CGM builds with and without CUBIT, static and shared for each. My first guess is that perhaps 'make clean' needs to be run in gnep. If that doesn't fix the problem, then does the output of these commands differ on gnep?
The builds usually run "make clean" when they start, but this time it required a "make distclean". Everything looks good now. - Jim
5622
Age (days ago)
5622
Last active (days ago)
0 comments
1 participants
participants (1)
James Porter
