Re: [cgma-dev] Large OCC subtraction time
You will need "Lasso" and configure "--with-iRel". Hong-Jun ----- Original Message -----
From: "Jiangtao Hu" <[email protected]> To: "Hong-Jun Kim" <[email protected]> Cc: [email protected], "Rajeev Jain" <[email protected]> Sent: Monday, February 28, 2011 11:08:27 AM Subject: Re: [cgma-dev] Large OCC subtraction time Hi,
I just tried to build meshkit, with the following configure:
./configure --enable-debug --with-itaps=/mnt/disk2b/jhu/ddriv
it failed on compiling EdgeMesher make[3]: Entering directory `/mnt/disk2b/jhu/meshkit/algs' CXX EdgeMesher.lo In file included from EdgeMesher.cpp:1: EdgeMesher.hpp:16:18: error: iRel.h: No such file or directory In file included from EdgeMesher.cpp:1: EdgeMesher.hpp:40: error: ‘iRel_Instance’ has not been declared EdgeMesher.hpp:40: error: ‘iRel_PairHandle’ has not been declared In file included from EdgeMesher.cpp:1: EdgeMesher.hpp:57: error: ‘iRel_Instance’ does not name a type EdgeMesher.hpp:58: error: ‘iRel_PairHandle’ does not name a type EdgeMesher.cpp:5: error: ‘iRel_Instance’ has not been declared EdgeMesher.cpp:5: error: ‘iRel_PairHandle’ has not been declared EdgeMesher.cpp: In constructor ‘EdgeMesher::EdgeMesher(iGeom_Instance_Private*&, iBase_EntityHandle_Private**, iMesh_Instance_Private*&, int&, int*)’: EdgeMesher.cpp:31: error: ‘assoc’ was not declared in this scope EdgeMesher.cpp:32: error: ‘rel’ was not declared in this scope EdgeMesher.cpp: In member function ‘void EdgeMesher::EdgeMesh()’: EdgeMesher.cpp:120: warning: unused variable ‘NumEntitySet’ EdgeMesher.cpp: In member function ‘std::vector<double, std::allocator<double> > EdgeMesher::BiasMeshing()’: EdgeMesher.cpp:203: warning: unused variable ‘err’ EdgeMesher.cpp:204: warning: unused variable ‘x’ EdgeMesher.cpp:204: warning: unused variable ‘y’ EdgeMesher.cpp:204: warning: unused variable ‘z’ EdgeMesher.cpp:204: warning: unused variable ‘du’ EdgeMesher.cpp: In member function ‘std::vector<double, std::allocator<double> > EdgeMesher::DualBiasMeshing()’: EdgeMesher.cpp:250: warning: unused variable ‘err’ EdgeMesher.cpp:251: warning: unused variable ‘x’ EdgeMesher.cpp:251: warning: unused variable ‘y’ EdgeMesher.cpp:251: warning: unused variable ‘z’ EdgeMesher.cpp:251: warning: unused variable ‘ustart’ EdgeMesher.cpp:251: warning: unused variable ‘du’ EdgeMesher.cpp: In member function ‘void EdgeMesher::RapidSorting(std::vector<double, std::allocator<double>
&, std::vector<double, std::allocator<double> >&, int, int)’: EdgeMesher.cpp:433: warning: unused variable ‘x’ EdgeMesher.cpp:433: warning: unused variable ‘y’ EdgeMesher.cpp:433: warning: unused variable ‘z’ EdgeMesher.cpp: In member function ‘void EdgeMesher::get_related_entityset(iBase_EntitySetHandle_Private*&)’: EdgeMesher.cpp:591: error: ‘assoc’ was not declared in this scope EdgeMesher.cpp:591: error: ‘rel’ was not declared in this scope EdgeMesher.cpp:591: error: ‘iRel_getEntSetRelation’ was not declared in this scope EdgeMesher.cpp:607: error: ‘iRel_setEntSetRelation’ was not declared in this scope EdgeMesher.cpp: In member function ‘void EdgeMesher::ShowCoorData()’: EdgeMesher.cpp:619: error: ‘assoc’ was not declared in this scope EdgeMesher.cpp:619: error: ‘rel’ was not declared in this scope EdgeMesher.cpp:619: error: ‘iRel_getEntSetRelation’ was not declared in this scope
I've updated cgm, moab and meshkit, and built, installed cgm and moab, did I left something out?
Thanks.
Jane --- On Sat, 2/26/11, Hong-Jun Kim <[email protected]> wrote:
From: Hong-Jun Kim <[email protected]> Subject: Re: [cgma-dev] Large OCC subtraction time To: "Jiangtao Hu" <[email protected]> Cc: [email protected], "Rajeev Jain" <[email protected]> Date: Saturday, February 26, 2011, 12:22 PM
In my case of using OCC geometry, attribute updating and removing time take too long. It takes more than import/exporting time of the geometry.
Hong-Jun
From: "Jiangtao Hu" < [email protected] > To: [email protected] , "Rajeev Jain" < [email protected] > Sent: Saturday, February 26, 2011 11:08:37 AM Subject: Re: [cgma-dev] Large OCC subtraction time Hi, Rajeev:
Thank you for providing the testcase. OCC did have a reputation of getting much slower with larger models and more operations. I'll have a look on Monday to see if there's anything I can do on cgm side that can speed it up.
Have a nice weekend!
Jane
--- On Fri, 2/25/11, Rajeev Jain < [email protected] > wrote:
From: Rajeev Jain < [email protected] > Subject: [cgma-dev] Large OCC subtraction time To: [email protected] Date: Friday, February 25, 2011, 4:21 PM
When subtracting 325 pins from a block, OCC takes a lot more time than the corresponding ACIS model. I'm attaching the assygen .inp that can be run as MeshKit/rgg>assygen 7. This file is for OCC version of MeshKit. For ACIS change the geometry engine to ACIS in the .inp file and run ACIS version.
RGG o/p:
ACIS:
Normal Termination. Geometry file: 7.sat saved. Schemes file created: 7.template.jou Cubit journal file created: 7.jou Ending at : Fri Feb 25 15:10:31 2011 Elapsed wall clock time: 8 seconds or 0.133333 mins
OCC:
Exported: 327 OCC Bodies to 7.stp
Normal Termination. Geometry file: 7.stp saved. Schemes file created: 7.template.jou Cubit journal file created: 7.jou Ending at : Fri Feb 25 14:59:51 2011 Elapsed wall clock time: 3173 seconds or 52.8833 mins
The geometry files can be found at /homes/jain/MeshKit-all/trunk/rgg/test/geometry_parallel_meshing/7.stp and 7.sat
Rajeev
participants (1)
Hong-Jun Kim
