Re: [cgma-dev] CGMA 12.2.0b2pre bugs
On 06/24/2011 05:33 PM, Carl Ollivier-Gooch wrote:
2. GeometryQueryTool.cpp:332: error: prototype for âCubitStatus GeometryQueryTool::export_solid_model(DLIList<RefEntity*>&, const char*, const char*, int&, const CubitString&, const char*)â does not match any in class âGeometryQueryToolâ GeometryQueryTool.hpp:378: error: candidates are: CubitStatus GeometryQueryTool::export_solid_model(DLIList<RefEntity*>&, char*&, int&, bool) GeometryQueryTool.hpp:367: error: CubitStatus GeometryQueryTool::export_solid_model(DLIList<RefEntity*>&, const char*, Model_File_Type, int&, const CubitString&, const char*)
3. GeometryQueryTool.cpp:959: error: prototype for âCubitStatus GeometryQueryTool::import_solid_model(const char*, const char*, const char*, CubitBoolean, CubitBoolean, CubitBoolean, CubitBoolean, CubitBoolean, CubitBoolean, DLIList<RefEntity*>*)â does not match any in class âGeometryQueryToolâ GeometryQueryTool.hpp:432: error: candidates are: CubitStatus GeometryQueryTool::import_solid_model(DLIList<RefEntity*>*, const char*, int) GeometryQueryTool.hpp:412: error: CubitStatus GeometryQueryTool::import_solid_model(const char*, Model_File_Type, ModelImportOptions&, DLIList<RefEntity*>*)
The above two errors indicate some kind of configuration problem. What configure command did you use? Would you mind sending a copy of geom/CubitCompat.h and config.log? - jason
participants (1)
Jason Kraftcheck
