copying iGeom entities in occ...
Hi all, I just ran into an interesting problem in CGM built with OCC. When an entity is copied, the original loses all user-applied tag information (or so it seems). I understand why a copy might not keep data from the original, but for the data to disappear from the original altogether seems like incorrect behaviour to me. I wrote a test as an example of this below. The test fails on the red line. Any ideas as to why? I've tracked the number of tags on the entity and they seem to disappear in line 5804 of iGeom_CGMA.cc. Any help or insight for this would be very appreciated! I'm close to finishing my updates to the iGeom interface and this seems to be the last piece of the puzzle. bool tag_copied_ent_test(iGeom_Instance geom) { int err; //create a tag iBase_TagHandle test_tag; std::string name("test_tag"); iGeom_createTag(geom, &name[0], 1, iBase_INTEGER, &test_tag, &err, name.length()); CHECK( "ERROR: could not create tag" ); //create a test entity iBase_EntityHandle cyl; iGeom_createCylinder(geom, 5.0, 5.0, 0.0, &cyl, &err); CHECK( "ERROR: could not create the cylinder" ); //set a value for this tag on the original int value = 6; iGeom_setIntData(geom, cyl, test_tag, value, &err); CHECK( "ERROR: could not set the tag data" ); //create a copy iBase_EntityHandle copy; iGeom_copyEnt(geom, cyl, ©, &err); CHECK( "ERROR: could not copy the entity" ); //check to see if the tag is accessible int bytes; iGeom_getTagSizeBytes(geom, test_tag, &bytes, &err); CHECK( "ERROR: could not get the tag size" ); if (bytes != sizeof(int)) return false; iGeom_getIntData(geom, cyl, test_tag, &check_value, &err); CHECK( "ERROR: could not get the tag data" ); if (check_value != value) return false; //cleanup iGeom_destroyTag(geom, test_tag, 1, &err); CHECK( "ERROR: could not destroy tag" ); iGeom_deleteEnt(geom, cyl, &err); CHECK( "ERROR: could not delete entity" ); iGeom_deleteEnt(geom, copy, &err); CHECK( "ERROR: could not delete entity" ); return true; } -- Patrick C. Shriwise Research Assistant University of Wisconsin - Madison Engineering Research Building - Rm. 428 1500 Engineering Drive Madison, WI 53706 (608) 446-8173
participants (1)
shriwise
