r4740 - cgm/branches/merge-cubit12/geom/testing
Author: janehu Date: 2011-04-14 12:14:46 -0500 (Thu, 14 Apr 2011) New Revision: 4740 Modified: cgm/branches/merge-cubit12/geom/testing/CreateGeometry.cpp Log: Changes made forsource code change in revision 4739. Modified: cgm/branches/merge-cubit12/geom/testing/CreateGeometry.cpp =================================================================== --- cgm/branches/merge-cubit12/geom/testing/CreateGeometry.cpp 2011-04-14 17:13:03 UTC (rev 4739) +++ cgm/branches/merge-cubit12/geom/testing/CreateGeometry.cpp 2011-04-14 17:14:46 UTC (rev 4740) @@ -48,17 +48,15 @@ printf("failed to make brick\n"); return 1; } - CubitBox comp_box(CubitVector(-4.035534, -0.5, 0.5), - CubitVector(1.621320, 5.156854, 7.5)); + CubitBox comp_box(CubitVector(-4.656854, -3.656854, -3.), + CubitVector(6.656854, 7.656854, 11.)); CubitBox bnd_box = brick->bounding_box(); bool identical = cubit_box_identical(bnd_box, comp_box, GEOMETRY_RESABS*2.0, true); if (identical) return 0; - //because this box is given from OCC engine, acis engine should give smaller - //box. - if( bnd_box > comp_box || bnd_box < comp_box/1.09) + if( bnd_box < comp_box || bnd_box > comp_box*1.09) { printf("boxes not identical\n"); return 1;
participants (1)
jiangtao_ma@yahoo.com
