Re: [cgma-dev] Make check errors...
and these are modifications needed for lasso, in the same context (ubuntu 12, shared build) It should not affect other builds, but I am still reluctant to commit them to repository, until I understand why are they needed; and maybe there is a better solution; LPATH could be one solution, but I do not really like it. Iulian ----- Original Message ----- | ----- Original Message ----- | | On 09/26/2012 01:57 PM, Paul Wilson wrote: | | | Hi everyone, | | | Sorry if I've missed this discussed elsewhere (or forgotten the | | | answer | | | that once knew).... | | | I get the following errors when I try to "make check" on CGM built | | | against cubit 12.2: | | | | wilsonp@todlaw ~/UW/research/fathom/cgm/dagmc_bld/test > | | | | LD_LIBRARY_PATH=/opt/cubit/12.2/bin make check | | | | make init sheet webcut brick_acis merge_acis | | | | make[1]: Entering directory | | | | `/home/wilsonp/UW/research/fathom/cgm/dagmc_bld/test' | | | | make[1]: `init' is up to date. | | | | /bin/bash ../libtool --tag=CXX --mode=link g++ -Wall -pipe | | | | -pedantic | | | | -O2 -DNDEBUG -L/opt/cubit/12.2/bin -R/opt/cubit/12.2/bin -o | | | | sheet | | | | sheet.o ../libcgm.la -lm | | | | libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o | | | | .libs/sheet | | | | sheet.o -L/opt/cubit/12.2/bin ../.libs/libcgm.so -lm -Wl,-rpath | | | | -Wl,/home/wilsonp/opt/lib -Wl,-rpath -Wl,/opt/cubit/12.2/bin | | | | /usr/bin/ld: sheet.o: undefined reference to symbol | | | | 'Body::is_sheet_body()' | | | | /usr/bin/ld: note: 'Body::is_sheet_body()' is defined in DSO | | | | /opt/cubit/12.2/bin/libcubiti19.so so try adding it to the | | | | linker | | | | command line | | | | /opt/cubit/12.2/bin/libcubiti19.so: could not read symbols: | | | | Invalid | | | | operation | | | | collect2: ld returned 1 exit status | | | | make[1]: *** [sheet] Error 1 | | | | make[1]: Leaving directory | | | | `/home/wilsonp/UW/research/fathom/cgm/dagmc_bld/test' | | | | make: *** [check-am] Error 2 | | | I've configured with: --enable-optimize --disable-debug | | | --enable-shared --with-cubit=/opt/cubit/12.2 | | | --prefix=/home/wilsonp/opt | | | Should there be a -lcubit19 in the linker flags here? | | | Paul | | | -- | | | -- ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ | | | ~ | | | -- | | | Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: | | | http://bit.ly/pphw-cal | | | Associate Professor, Engineering Physics. ~ | | | http://cnerg.engr.wisc.edu | | | Chair, Energy Analysis & Policy Program ~ | | | http://nelson.wisc.edu/eap | | Hi Paul | | Try adding cubit to your LPATH as well as your LD_LIBRARY_PATH. | | Stuart | | -- | | Stuart Slattery | | Nuclear Regulatory Commission Fellow | | Computational Nuclear Engineering Research Group | | Department of Engineering Physics | | University of Wisconsin - Madison | | 434 Engineering Research Building | | 1500 Engineering Drive | | Madison, WI 53706 | | email : [email protected] cell : 608.843.5871 | | url : http://cnerg.engr.wisc.edu | hello, | This is my patch needed for cgm to pass make check on ubuntu 12 | (shared build) | I didn't try setting LPATH.
participants (1)
Iulian Grindeanu
