Making check in compat make[1]: Entering directory `/home/jason/cgm/test/32-acis/compat' make[1]: Nothing to be done for `check'. make[1]: Leaving directory `/home/jason/cgm/test/32-acis/compat' Making check in util make[1]: Entering directory `/home/jason/cgm/test/32-acis/util' make[1]: Nothing to be done for `check'. make[1]: Leaving directory `/home/jason/cgm/test/32-acis/util' Making check in geom make[1]: Entering directory `/home/jason/cgm/test/32-acis/geom' Making check in . make[2]: Entering directory `/home/jason/cgm/test/32-acis/geom' make[2]: Nothing to be done for `check-am'. make[2]: Leaving directory `/home/jason/cgm/test/32-acis/geom' Making check in Cholla make[2]: Entering directory `/home/jason/cgm/test/32-acis/geom/Cholla' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/32-acis/geom/Cholla' Making check in facetbool make[2]: Entering directory `/home/jason/cgm/test/32-acis/geom/facetbool' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/32-acis/geom/facetbool' Making check in facet make[2]: Entering directory `/home/jason/cgm/test/32-acis/geom/facet' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/32-acis/geom/facet' Making check in virtual make[2]: Entering directory `/home/jason/cgm/test/32-acis/geom/virtual' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/32-acis/geom/virtual' Making check in ACIS make[2]: Entering directory `/home/jason/cgm/test/32-acis/geom/ACIS' /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1600 -DACIS_VERSION=1600 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1600 -I. -I../../../trunk/geom/ACIS -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/ACIS/gtcAttrib/incl -I/opt/acis16-32bit/include -I../../../trunk/compat/new -isystem /opt/acis16-32bit/include -Wall -pipe -pedantic -g -m32 -MT AcisBridge.lo -MD -MP -MF .deps/AcisBridge.Tpo -c -o AcisBridge.lo ../../../trunk/geom/ACIS/AcisBridge.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1600 -DACIS_VERSION=1600 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1600 -I. -I../../../trunk/geom/ACIS -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/ACIS/gtcAttrib/incl -I/opt/acis16-32bit/include -I../../../trunk/compat/new -isystem /opt/acis16-32bit/include -Wall -pipe -pedantic -g -m32 -MT AcisBridge.lo -MD -MP -MF .deps/AcisBridge.Tpo -c ../../../trunk/geom/ACIS/AcisBridge.cpp -o AcisBridge.o In file included from ../../../trunk/geom/ACIS/AcisBridge.cpp:26: ../../../trunk/geom/ACIS/AcisQueryEngine.hpp: In static member function ‘static AcisQueryEngine* AcisQueryEngine::instance()’: ../../../trunk/geom/ACIS/AcisQueryEngine.hpp:157: error: cannot allocate an object of abstract type ‘AcisQueryEngine’ ../../../trunk/geom/ACIS/AcisQueryEngine.hpp:117: note: because the following virtual functions are pure within ‘AcisQueryEngine’: ../../../trunk/geom/GeometryQueryEngine.hpp:57: note: virtual CubitStatus GeometryQueryEngine::export_solid_model(DLIList<TopologyBridge*>&, char*&, int&, bool) ../../../trunk/geom/GeometryQueryEngine.hpp:114: note: virtual CubitStatus GeometryQueryEngine::import_solid_model(DLIList<TopologyBridge*>&, const char*, int) make[2]: *** [AcisBridge.lo] Error 1 make[2]: Leaving directory `/home/jason/cgm/test/32-acis/geom/ACIS' make[1]: *** [check-recursive] Error 1 make[1]: Leaving directory `/home/jason/cgm/test/32-acis/geom' make: *** [check-recursive] Error 1
participants (1)
Nightly Test
