8 new commits in CGM: https://bitbucket.org/fathomteam/cgm/commits/0fc28830accd/ Changeset: 0fc28830accd Branch: None User: dcthomp Date: 2014-05-01 22:46:13 Summary: Fix compilation using CMake on OS X. 0. Add a new toplevel CMakeLists.txt file to build the project. 1. The new (Mavericks) libc++ uses a specialization for `std::vector<bool>` that prevents `DLIList<X>` from re-using `std::vector<X>::const_reference` blindly. 2. CubitCompat.h was not being generated. 3. The init project's include directories did not cover build directories where configured headers are placed. Affected #: 3 files https://bitbucket.org/fathomteam/cgm/commits/848cb17d6b97/ Changeset: 848cb17d6b97 Branch: None User: dcthomp Date: 2014-05-01 22:46:13 Summary: Start fixing CMake install rules. Affected #: 3 files https://bitbucket.org/fathomteam/cgm/commits/588755965351/ Changeset: 588755965351 Branch: None User: dcthomp Date: 2014-05-01 22:46:13 Summary: Add a ReadMe in a format github likes. Affected #: 1 file https://bitbucket.org/fathomteam/cgm/commits/e8a3200ea8ce/ Changeset: e8a3200ea8ce Branch: None User: dcthomp Date: 2014-05-01 22:46:13 Summary: Get headers installed properly. Now, with the exception of the itaps directory, header files installed by CMake match those install by autoconf (at least on OS X 10.9 built with OCC and CGM_FACET turned on). Affected #: 10 files https://bitbucket.org/fathomteam/cgm/commits/af74c96465aa/ Changeset: af74c96465aa Branch: None User: dcthomp Date: 2014-05-01 22:46:13 Summary: Clean up CMakeLists. Affected #: 2 files https://bitbucket.org/fathomteam/cgm/commits/5587ee046f6b/ Changeset: 5587ee046f6b Branch: None User: dcthomp Date: 2014-05-01 22:47:52 Summary: Progress on building with CMake. CGM now builds against some versions of OpenCascade. It is unclear why the subdirectories are separate projects instead of a top-level CMakeLists that prepares "add_definitions" and "include_directories" values for all subdirectories. CGM also creates `cgm.make` (to mirror the autoconf version) which is usable in some cases. Affected #: 11 files https://bitbucket.org/fathomteam/cgm/commits/7a3b9069334d/ Changeset: 7a3b9069334d Branch: None User: dcthomp Date: 2014-05-01 22:48:36 Summary: Update ReadMe. Affected #: 1 file https://bitbucket.org/fathomteam/cgm/commits/af90022a1c7c/ Changeset: af90022a1c7c Branch: master User: janehu Date: 2014-05-05 19:33:15 Summary: Merged in dcthomp/cgma/cmake (pull request #3) Minimal changes to get CMake building Affected #: 12 files Repository URL: https://bitbucket.org/fathomteam/cgm/ -- This is a commit notification from bitbucket.org. You are receiving this because you have the service enabled, addressing the recipient of this email.
participants (1)
Bitbucket
