Re: [cgma-dev] How to build the CGMA on Windows 7 64bit + VS2010?
Hello, How did you configure? Even if you use cmake, at some point you need to have a configuration step. You can see what we build every night here: http://gnep.mcs.anl.gov:8010/waterfall?category=cgm Those are all built on a Linux compute node, ubuntu 10.04, 64-bit. The configuration closest to yours' is probably cgm-occ or cgm-occ-sta. These are built on merge cubit 12.2 branch, with occ version 6.5.3 http://gnep.mcs.anl.gov:8010/builders/cgm-occ or http://gnep.mcs.anl.gov:8010/builders/cgm-occ-sta If you send your config.log file (or equivalent?) , we may have some clues of what is not working. Best Regards, Iulian ----- Original Message ----- | Dear all, | I have successfully built the project 'cubit_OOC' after I used the | version 12.2 from here: | https://svn.mcs.anl.gov/repos/ITAPS/cgm/branches/Version12.2/ | However, after I built a simple example "\test\operation.cpp" and run | it, the following error displayed: | ERROR: Invalid or unsupported engine: 'OCC' | Is there anything I missed? | Thanks, | Zhanghong Tang | --- On Sun, 11/4/12, Iulian Grindeanu <[email protected]> wrote: | | From: Iulian Grindeanu <[email protected]> | | Subject: Re: [cgma-dev] How to build the CGMA on Windows 7 64bit + | | VS2010? | | To: "Zhanghong Tang" <[email protected]> | | Date: Sunday, November 4, 2012, 12:51 AM | | Hello, | | It would be good if you can make it work. | | How did you configure ? Using ccmake or autotools in cygwin? | | You should configure with-occ OR with-cubit, if you have cubit. | | It seems that you installed occ, so configure ONLY with-occ. | | I will be out of email until Monday | | Iulian | | | Dear Dr. Grindeanu, | | | Thank you very much for pointing out my problem. I thought that | | | the | | | CGMA can work without any other package. | | | Now I have installed Open CASCADE Technology 6.5.3 and rebuild the | | | CGMA project (reset the path by CMake and create the VS2010 | | | projects), | | | the following error displayed when build the cubit_OCC project: | | | 1>------ Build started: Project: ZERO_CHECK, Configuration: Debug | | | x64 | | | ------ | | | 1>Build started 2012/11/3 23:41:53. | | | 1>InitializeBuildStatus: | | | 1> Creating "x64\Debug\ZERO_CHECK\ZERO_CHECK.unsuccessfulbuild" | | | because "AlwaysCreate" was specified. | | | 1>FinalizeBuildStatus: | | | 1> Deleting file | | | "x64\Debug\ZERO_CHECK\ZERO_CHECK.unsuccessfulbuild". | | | 1> Touching "x64\Debug\ZERO_CHECK\ZERO_CHECK.lastbuildstate". | | | 1> | | | 1>Build succeeded. | | | 1> | | | 1>Time Elapsed 00:00:00.06 | | | 2>------ Build started: Project: cubit_OCC, Configuration: Debug | | | x64 | | | ------ | | | 2>Build started 2012/11/3 23:41:53. | | | 2>InitializeBuildStatus: | | | 2> Touching "cubit_OCC.dir\Debug\cubit_OCC.unsuccessfulbuild". | | | 2>CustomBuild: | | | 2> All outputs are up-to-date. | | | 2>ClCompile: | | | 2> OCCModifyEngine.cpp | | | 2>E:\cgma-12.2.0b1\util\CubitMessage.hpp(400): warning C4138: '*/' | | | found outside of comment | | | 2>E:\cgma-12.2.0b1\geom\GeometryQueryEngine.hpp(259): warning | | | C4138: | | | '*/' found outside of comment | | | 2>E:\cgma-12.2.0b1\geom\GeometryQueryEngine.hpp(260): warning | | | C4138: | | | '*/' found outside of comment | | | 2>..\..\..\geom\OCC\OCCModifyEngine.cpp(715): error C2440: | | | '<function-style-cast>' : cannot convert from | | | 'Handle_Geom_RectangularTrimmedSurface' to | | | 'BRepBuilderAPI_MakeFace' | | | 2> No constructor could take the source type, or constructor | | | overload | | | resolution was ambiguous | | | 2>..\..\..\geom\OCC\OCCModifyEngine.cpp(725): error C2440: | | | '<function-style-cast>' : cannot convert from | | | 'Handle_Geom_RectangularTrimmedSurface' to | | | 'BRepBuilderAPI_MakeFace' | | | 2> No constructor could take the source type, or constructor | | | overload | | | resolution was ambiguous | | | 2>..\..\..\geom\OCC\OCCModifyEngine.cpp(744): error C2665: | | | 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace' : none of the | | | 23 | | | overloads could convert all the argument types | | | 2> C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(104): | | | could | | | be 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Pln | | | &,const Standard_Real,const Standard_Real,const | | | Standard_Real,const | | | Standard_Real)' | | | 2> C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(106): | | | or | | | 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const | | | gp_Cylinder | | | &,const Standard_Real,const Standard_Real,const | | | Standard_Real,const | | | Standard_Real)' | | | 2> C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(108): | | | or | | | 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Cone | | | &,const Standard_Real,const Standard_Real,const | | | Standard_Real,const | | | Standard_Real)' | | | 2> C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(110): | | | or | | | 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Sphere | | | &,const Standard_Real,const Standard_Real,const | | | Standard_Real,const | | | Standard_Real)' | | | 2> C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(112): | | | or | | | 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Torus | | | &,const Standard_Real,const Standard_Real,const | | | Standard_Real,const | | | Standard_Real)' | | | 2> while trying to match the argument list | | | '(Handle_Geom_BezierSurface, double, double, double, double)' | | | 2>..\..\..\geom\OCC\OCCModifyEngine.cpp(2267): warning C4800: | | | 'Standard_Boolean' : forcing value to bool 'true' or 'false' | | | (performance warning) | | | 2>..\..\..\geom\OCC\OCCModifyEngine.cpp(7913): error C2440: | | | '<function-style-cast>' : cannot convert from | | | 'Handle_Geom_RectangularTrimmedSurface' to | | | 'BRepBuilderAPI_MakeFace' | | | 2> No constructor could take the source type, or constructor | | | overload | | | resolution was ambiguous | | | 2> | | | 2>Build FAILED. | | | 2> | | | 2>Time Elapsed 00:00:01.52 | | | 3>------ Build started: Project: ALL_BUILD, Configuration: Debug | | | x64 | | | ------ | | | 3>Build started 2012/11/3 23:41:54. | | | 3>InitializeBuildStatus: | | | 3> Creating "x64\Debug\ALL_BUILD\ALL_BUILD.unsuccessfulbuild" | | | because | | | "AlwaysCreate" was specified. | | | 3>CustomBuild: | | | 3> Build all projects | | | 3>FinalizeBuildStatus: | | | 3> Deleting file | | | "x64\Debug\ALL_BUILD\ALL_BUILD.unsuccessfulbuild". | | | 3> Touching "x64\Debug\ALL_BUILD\ALL_BUILD.lastbuildstate". | | | 3> | | | 3>Build succeeded. | | | 3> | | | 3>Time Elapsed 00:00:02.02 | | | 4>------ Skipped Build: Project: INSTALL, Configuration: Debug x64 | | | ------ | | | 4>Project not selected to build for this solution configuration | | | ========== Build: 2 succeeded, 1 failed, 7 up-to-date, 1 skipped | | | ========== | | | Could you please take a look at it for me? | | | Thanks, | | | Zhanghong Tang | | | --- On Sat, 11/3/12, Iulian Grindeanu <[email protected]> wrote: | | | | From: Iulian Grindeanu <[email protected]> | | | | Subject: Re: [cgma-dev] How to build the CGMA on Windows 7 64bit | | | | + | | | | VS2010? | | | | To: "Zhanghong Tang" <[email protected]> | | | | Cc: "CGMA Development" <[email protected]> | | | | Date: Saturday, November 3, 2012, 10:30 PM | | | | | Dear Dr. Grindeanu, | | | | | Thank you very much for your kindly reply. With the help of | | | | | CMake | | | | | I | | | | | have successfully build the libraries. There are 7 libs | | | | | generated: | | | | | cgma_init.lib | | | | | cholla.lib | | | | | cubit_facet.lib | | | | | cubit_facetboolstub.lib | | | | | cubit_geom.lib | | | | | cubit_util.lib | | | | | cubit_virtual.lib | | | | Hello, | | | | So I assume you are on the main branch. | | | | You can't use CGM without a geometry engine. Did you read my | | | | previous | | | | e-mail? | | | | You will need to configure with OCC or Cubit. | | | | Sorry, I can't be of more help. | | | | Iulian | | | | | I tried to build a simple test "brick.cpp", however, there are | | | | | some | | | | | errors when run the example: | | | | | Facet-based geometry modification is a beta capability. | | | | | ERROR: This capability is currently disabled. | | | | | To enable this capability, issue the command 'set developer | | | | | commands | | | | | on'. | | | | | ERROR: In GeometryModifyTool::brick | | | | | Problem creating a brick. | | | | | Assertion failed: brick != 0, file ..\test\brick.cpp, line 42 | | | | | I would like to do a simple test: | | | | | 1) build a box and a sphere with both center at (0,0,0) and | | | | | size | | | | | 1; | | | | | 2) do boolean operations such as intersection between the box | | | | | and | | | | | sphere; | | | | | 3) output the result to an OFF file. | | | | | Could anyone give me such a simple example? | | | | | Thanks, | | | | | Zhanghong Tang | | | | | --- On Fri, 11/2/12, Iulian Grindeanu <[email protected]> | | | | | wrote: | | | | | | From: Iulian Grindeanu <[email protected]> | | | | | | Subject: Re: [cgma-dev] How to build the CGMA on Windows 7 | | | | | | 64bit | | | | | | + | | | | | | VS2010? | | | | | | To: "Zhanghong Tang" <[email protected]> | | | | | | Cc: [email protected] | | | | | | Date: Friday, November 2, 2012, 11:21 PM | | | | | | Hello, | | | | | | I don't know if anybody tried building on Windows, maybe | | | | | | Jane | | | | | | or | | | | | | Tim | | | | | | know. | | | | | | You have to configure with a geometric engine. If you don't | | | | | | have | | | | | | Cubit | | | | | | for your platform, you will need to configure with OCC | | | | | | It seems that you use cygwin. I know that OCC can be build | | | | | | on | | | | | | Windows, | | | | | | on VS 2010. | | | | | | (http://www.opencascade.org/getocc/require/) | | | | | | You then can try configuring on cygwin with occ. And then | | | | | | look | | | | | | at | | | | | | Makefiles generated to see what would be needed for projects | | | | | | in | | | | | | VS. | | | | | | Or | | | | | | is there a cmake-based build? I think that would be easier | | | | | | to | | | | | | port | | | | | | to | | | | | | Windows. | | | | | | Iulian | | | | | | | Dear all, | | | | | | | I am trying to build the CGMA on Windows 7 64bit + VS2010. | | | | | | | I | | | | | | | have | | | | | | | attached the project. However, there are hundreds of | | | | | | | errors | | | | | | | such | | | | | | | as: | | | | | | | 2>CGMAD.lib(DAG.obj) : error LNK2019: unresolved external | | | | | | | symbol | | | | | | | "public: __cdecl DLIList<class ModelEntity | | | | | | | *>::~DLIList<class | | | | | | | ModelEntity *>(void)" | | | | | | | (??1?$DLIList@PEAVModelEntity@@@@QEAA@XZ) | | | | | | | referenced in function "public: enum CubitStatus __cdecl | | | | | | | DAG::get_children_at_level(class DLIList<class ModelEntity | | | | | | | *> | | | | | | | &,int,class DLIList<class ModelEntity *> &)" | | | | | | | (?get_children_at_level@DAG@@QEAA?AW4CubitStatus@@AEAV?$DLIList@PEAVModelEntity@@@@H0@Z) | | | | | | | 2>CGMAD.lib(CAActuateSet.obj) : error LNK2001: unresolved | | | | | | | external | | | | | | | symbol "public: __cdecl DLIList<class ModelEntity | | | | | | | *>::~DLIList<class | | | | | | | ModelEntity *>(void)" | | | | | | | (??1?$DLIList@PEAVModelEntity@@@@QEAA@XZ) | | | | | | | 2>CGMAD.lib(PartitionTool.obj) : error LNK2001: unresolved | | | | | | | external | | | | | | | symbol "public: __cdecl DLIList<class ModelEntity | | | | | | | *>::~DLIList<class | | | | | | | ModelEntity *>(void)" | | | | | | | (??1?$DLIList@PEAVModelEntity@@@@QEAA@XZ) | | | | | | | 2>CGMAD.lib(CompositeTool.obj) : error LNK2001: unresolved | | | | | | | external | | | | | | | symbol "public: __cdecl DLIList<class ModelEntity | | | | | | | *>::~DLIList<class | | | | | | | ModelEntity *>(void)" | | | | | | | (??1?$DLIList@PEAVModelEntity@@@@QEAA@XZ) | | | | | | | 2>CGMAD.lib(TopologyEntity.obj) : error LNK2001: | | | | | | | unresolved | | | | | | | external | | | | | | | symbol "public: __cdecl DLIList<class ModelEntity | | | | | | | *>::~DLIList<class | | | | | | | ModelEntity *>(void)" | | | | | | | (??1?$DLIList@PEAVModelEntity@@@@QEAA@XZ) | | | | | | | Could anyone help me to take a look at it and give me some | | | | | | | hints | | | | | | | on | | | | | | | how to setup the project or modify some code to | | | | | | | successfully | | | | | | | build | | | | | | | the | | | | | | | project? | | | | | | | Thanks, | | | | | | | Zhanghong Tang
participants (1)
Iulian Grindeanu
