Re: [cgma-dev] Problem building CGM in shared mode
Doesn't it also have to be in your PATH? I seem to recall that... - tim Rajeev Jain wrote:
On 05/06/2010 04:26 PM, Robert Smith wrote:
Is there some trick to getting CGM to build with --enable-shared? This also has Cubit turned on.
I tried running the configure as it is done on the buildbot server and I continually get an error when it tries to link libcgm.la. It says that '/bin/ld cannot find -lcubiti19'. That makes sense since there is no -L switch to point to the Cubit install directory in the link line although the libcubiti19.so file is included explicitly in the libtool line. And the output of the make is slightly different on my build than the buildbot build.
Could this be a libtool mismatch? I'm on the ANL Linux cluster running 1.5.26.
--Bob Adding LDFLAGS=-L/home/rajeev/cubit-32/bin LIBS=-lcubiti19 to the configure script did the trick for cubit-32 using 32 bit ubuntu-10.04, This can be found at http://trac.mcs.anl.gov/projects/ITAPS/ticket/158
-- ================================================================ "You will keep in perfect peace him whose mind is steadfast, because he trusts in you." Isaiah 26:3 Tim Tautges Argonne National Laboratory ([email protected]) (telecommuting from UW-Madison) phone: (608) 263-8485 1500 Engineering Dr. fax: (608) 263-4499 Madison, WI 53706
participants (1)
Tim Tautges
