Re: [cgma-dev] Problem building CGM in shared mode
Yes it does. I did check that first. On May 6, 2010, at 4:27 PM, Jason Kraftcheck wrote:
Robert Smith wrote:
Is there some trick to getting CGM to build with --enable-shared? This also has Cubit turned on.
I tried running the configure as it is done on the buildbot server and I continually get an error when it tries to link libcgm.la. It says that '/bin/ld cannot find -lcubiti19'. That makes sense since there is no -L switch to point to the Cubit install directory in the link line although the libcubiti19.so file is included explicitly in the libtool line. And the output of the make is slightly different on my build than the buildbot build.
Could this be a libtool mismatch? I'm on the ANL Linux cluster running 1.5.26.
Does your LD_LIBRARY_PATH include the cubit bin directory?
- jason
participants (1)
Robert Smith
