Author: kraftche Date: 2007-07-18 13:25:05 -0500 (Wed, 18 Jul 2007) New Revision: 1211 Modified: cgm/trunk/cgm.make.in Log: more fixes to use CGM build w/out installing Modified: cgm/trunk/cgm.make.in =================================================================== --- cgm/trunk/cgm.make.in 2007-07-17 21:22:01 UTC (rev 1210) +++ cgm/trunk/cgm.make.in 2007-07-18 18:25:05 UTC (rev 1211) @@ -31,7 +31,7 @@ CGM_PARALLEL_LIB_FILE = @CGM_PARALLEL_LIB_FILE@ # These get redefined by a makefile target during *install* # by appending correct values to the end of the file. -CGM_LIBDIR = @abs_builddir@/.libs +CGM_LIBDIR = @abs_builddir@ CGM_INCLUDEDIR = @abs_srcdir@ CGM_CXX = @CXX@ @@ -41,23 +41,29 @@ CGM_CFLAGS = @CFLAGS@ CGM_LDFLAGS = @LDFLAGS@ -CGM_INCLUDES = -I$(CGM_DIR)/util -I$(CGM_DIR)/init -I$(CGM_DIR)/geom -I$(CGM_DIR)/geom/ACIS $(CGM_PARALLEL_INCLUDE) -I$(CGM_INCLUDEDIR) ${ACIS_INCLUDES} +CGM_INCLUDES = -I$(CGM_INCLUDEDIR)/util \ + -I$(CGM_INCLUDEDIR)/init \ + -I$(CGM_INCLUDEDIR)/geom \ + -I$(CGM_INCLUDEDIR)/geom/ACIS \ + $(CGM_PARALLEL_INCLUDE) \ + -I$(CGM_INCLUDEDIR) \ + ${ACIS_INCLUDES} CGM_LIBS_LINK_INTERNAL = ${LDFLAGS} \ - -L$(CGM_DIR)/geom/virtual/.libs \ - -L$(CGM_DIR)/geom/facetbool/.libs \ - -L$(CGM_DIR)/geom/facet/.libs \ - -L$(CGM_DIR)/geom/Cholla/.libs \ - -L$(CGM_DIR)/geom/ACIS/.libs \ - -L$(CGM_DIR)/geom/.libs \ - -L$(CGM_DIR)/util/.libs \ - -L$(CGM_DIR)/geom/virtual \ - -L$(CGM_DIR)/geom/facetbool \ - -L$(CGM_DIR)/geom/facet \ - -L$(CGM_DIR)/geom/Cholla \ - -L$(CGM_DIR)/geom/ACIS \ - -L$(CGM_DIR)/geom \ - -L$(CGM_DIR)/util \ + -L$(CGM_LIBDIR)/geom/virtual/.libs \ + -L$(CGM_LIBDIR)/geom/facetbool/.libs \ + -L$(CGM_LIBDIR)/geom/facet/.libs \ + -L$(CGM_LIBDIR)/geom/Cholla/.libs \ + -L$(CGM_LIBDIR)/geom/ACIS/.libs \ + -L$(CGM_LIBDIR)/geom/.libs \ + -L$(CGM_LIBDIR)/util/.libs \ + -L$(CGM_LIBDIR)/geom/virtual \ + -L$(CGM_LIBDIR)/geom/facetbool \ + -L$(CGM_LIBDIR)/geom/facet \ + -L$(CGM_LIBDIR)/geom/Cholla \ + -L$(CGM_LIBDIR)/geom/ACIS \ + -L$(CGM_LIBDIR)/geom \ + -L$(CGM_LIBDIR)/util \ -L${ACIS_LIB_DIR} \ -L$(CGM_LIBDIR) \ ${ACIS_LIBS} \ @@ -84,6 +90,6 @@ CUBIT_LIBS = @CUBIT_LIBS@ CUBIT_FILE = @CUBIT_FILE@ -CGM_LIBS_LINK = @CGM_LIBS_LINK@ -L$(CGM_DIR)/init -L$(CGM_DIR)/init/.libs -lcgma_init +CGM_LIBS_LINK = @CGM_LIBS_LINK@ -L$(CGM_LIBDIR)/init -L$(CGM_LIBDIR)/init/.libs -lcgma_init CGM_LIBS_FILES = @CGM_LIBS_FILES@ $(CGM_LIBDIR)/libcgma_init.a CGM_LIBS_LTFLAGS = @CGM_LIBS_LTFLAGS@
participants (1)
kraftche@mcs.anl.gov
