Making check in compat make[1]: Entering directory `/home/jason/cgm/test/64-occ/compat' make[1]: Nothing to be done for `check'. make[1]: Leaving directory `/home/jason/cgm/test/64-occ/compat' Making check in util make[1]: Entering directory `/home/jason/cgm/test/64-occ/util' make[1]: Nothing to be done for `check'. make[1]: Leaving directory `/home/jason/cgm/test/64-occ/util' Making check in geom make[1]: Entering directory `/home/jason/cgm/test/64-occ/geom' Making check in . make[2]: Entering directory `/home/jason/cgm/test/64-occ/geom' make[2]: Nothing to be done for `check-am'. make[2]: Leaving directory `/home/jason/cgm/test/64-occ/geom' Making check in Cholla make[2]: Entering directory `/home/jason/cgm/test/64-occ/geom/Cholla' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/64-occ/geom/Cholla' Making check in facetbool make[2]: Entering directory `/home/jason/cgm/test/64-occ/geom/facetbool' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/64-occ/geom/facetbool' Making check in facet make[2]: Entering directory `/home/jason/cgm/test/64-occ/geom/facet' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/64-occ/geom/facet' Making check in virtual make[2]: Entering directory `/home/jason/cgm/test/64-occ/geom/virtual' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/64-occ/geom/virtual' Making check in OCC make[2]: Entering directory `/home/jason/cgm/test/64-occ/geom/OCC' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/64-occ/geom/OCC' make[1]: Leaving directory `/home/jason/cgm/test/64-occ/geom' Making check in init make[1]: Entering directory `/home/jason/cgm/test/64-occ/init' make[1]: Nothing to be done for `check'. make[1]: Leaving directory `/home/jason/cgm/test/64-occ/init' Making check in . make[1]: Entering directory `/home/jason/cgm/test/64-occ' make[1]: Leaving directory `/home/jason/cgm/test/64-occ' Making check in itaps make[1]: Entering directory `/home/jason/cgm/test/64-occ/itaps' make check-recursive make[2]: Entering directory `/home/jason/cgm/test/64-occ/itaps' Making check in . make[3]: Entering directory `/home/jason/cgm/test/64-occ/itaps' make chaman testgeom_occ make[4]: Entering directory `/home/jason/cgm/test/64-occ/itaps' make[4]: `testgeom_occ' is up to date. make[4]: Leaving directory `/home/jason/cgm/test/64-occ/itaps' make check-TESTS make[4]: Entering directory `/home/jason/cgm/test/64-occ/itaps' Using default input file: ../../trunk/itaps/../test/Hip_Prothesis.brep Geometry engine set to: OCC Geometry Engine version 6.2.0 ITAPS GEOMETRY INTERFACE TEST PROGRAM: gLoad: ERROR: Cannot open geometry file: ../../trunk/itaps/../test/Hip_Prothesis.brep . ERROR: ERROR : can not load a geometry Error code: 3 Error desc: Trouble loading geometry file. At : ../../trunk/itaps/testgeom.cc:286 Failure tags: Tags defined on model: <none> Success gentity sets: Success topology adjacencies: Success construct: Created swept volume 3 Success primitives: Success transforms: Success booleans: Updated volume(s): 10 Destroyed volume(s): 11 Updated volume(s): 12 Updated volume(s): 12 Destroyed volume(s): 13 Success shutdown: ERROR: Errors found during CUBIT session. Success TSTT TEST SUMMARY: Number Tests: 9 Number Successful: 8 Number Not Implemented: 0 Number Failed: 1 FAIL: testgeom_occ =================== 1 of 1 tests failed =================== make[4]: *** [check-TESTS] Error 1 make[4]: Leaving directory `/home/jason/cgm/test/64-occ/itaps' make[3]: *** [check-am] Error 2 make[3]: Leaving directory `/home/jason/cgm/test/64-occ/itaps' make[2]: *** [check-recursive] Error 1 make[2]: Leaving directory `/home/jason/cgm/test/64-occ/itaps' make[1]: *** [check] Error 2 make[1]: Leaving directory `/home/jason/cgm/test/64-occ/itaps' make: *** [check-recursive] Error 1
participants (1)
Nightly Test
