Author: janehu Date: 2012-01-20 14:42:57 -0600 (Fri, 20 Jan 2012) New Revision: 5331 Modified: cgm/trunk/geom/virtual/VirtualQueryEngine.cpp cgm/trunk/geom/virtual/VirtualQueryEngine.hpp Log: Added unit parameter for import/export functions for iges files in OCC engine cgm. Passed cgm/test make check. Modified: cgm/trunk/geom/virtual/VirtualQueryEngine.cpp =================================================================== --- cgm/trunk/geom/virtual/VirtualQueryEngine.cpp 2012-01-20 20:42:35 UTC (rev 5330) +++ cgm/trunk/geom/virtual/VirtualQueryEngine.cpp 2012-01-20 20:42:57 UTC (rev 5331) @@ -1652,6 +1652,7 @@ const char* , const char* , const CubitString &, + const char*, const char* ) { return CUBIT_FAILURE; @@ -1691,7 +1692,8 @@ CubitBoolean , CubitBoolean , CubitBoolean , - CubitBoolean ) + CubitBoolean , + const char* ) { PRINT_INFO("VirtualQueryEngine::import_solid_model\n"); Modified: cgm/trunk/geom/virtual/VirtualQueryEngine.hpp =================================================================== --- cgm/trunk/geom/virtual/VirtualQueryEngine.hpp 2012-01-20 20:42:35 UTC (rev 5330) +++ cgm/trunk/geom/virtual/VirtualQueryEngine.hpp 2012-01-20 20:42:57 UTC (rev 5331) @@ -357,6 +357,7 @@ const char* file_name, const char* file_type, const CubitString &cubit_version, + const char* unit = NULL, const char* logfile_name = NULL ); virtual CubitStatus export_solid_model( DLIList<TopologyBridge*>& bridge_list, @@ -386,7 +387,8 @@ CubitBoolean import_surfaces = CUBIT_TRUE, CubitBoolean import_curves = CUBIT_TRUE, CubitBoolean import_vertices = CUBIT_TRUE, - CubitBoolean free_surfaces = CUBIT_TRUE ); + CubitBoolean free_surfaces = CUBIT_TRUE, + const char* unit = NULL ); virtual CubitStatus import_solid_model(DLIList<TopologyBridge*> &imported_entities, const char* pBuffer,
participants (1)
jiangtao_ma@yahoo.com
