Author: janehu Date: 2014-03-12 10:08:11 -0500 (Wed, 12 Mar 2014) New Revision: 6143 Removed: cgm/trunk/KNOWN_ISSUES cgm/trunk/Makefile.am cgm/trunk/README.CGM cgm/trunk/README.CONFIGURE cgm/trunk/README.OCC cgm/trunk/README.OpenCascade cgm/trunk/cgm.make cgm/trunk/cgm.make.in cgm/trunk/cgm_version.h cgm/trunk/compat/ cgm/trunk/configure.ac cgm/trunk/geom/ cgm/trunk/init/ cgm/trunk/itaps/ cgm/trunk/m4/ cgm/trunk/test/ cgm/trunk/util/ Log: cgm has been moved to bitbucket, removing all source codes. Deleted: cgm/trunk/KNOWN_ISSUES =================================================================== --- cgm/trunk/KNOWN_ISSUES 2014-03-12 04:19:30 UTC (rev 6142) +++ cgm/trunk/KNOWN_ISSUES 2014-03-12 15:08:11 UTC (rev 6143) @@ -1,35 +0,0 @@ -This is a list of the known issues with CGM on OCC.For more details please see -the online ticket system at the MOAB website: - https://trac.mcs.anl.gov/projects/ITAPS/wiki - - - -ID Severity Summary/Details -=== ======== =================================================================== -175 critical imprint special cases fail with crash. - -176 minor CGM memory leak - -178 major Unite function doesn't unite smoothly connected surfaces. - -179 major mcnp2cad test suite lat1-3, lat5, lat1,norot not working, - `needs debugging. - -180 major There are lots new functions or added functions to exsisting - functions requirements to port OCC to cubit12. - -181 minor Lack of good cases for testing purpose. - -182 minor Dirty geometry/imported geometry is not tested for read/repair yet -183 minor Don't have proper tool to visualize the TopoDS_Shapes, debugging - process is long preparing for graphics to understand the issue - -185 major mcnp2cad/tests/INP-torus test case fails on imprinting 2 spline - surfaces. - -247 major Uniting of two shapes failed in Opencascade - -251 major imprint mesh bug by Boyd Tidwell - -265 major step file read crash - Deleted: cgm/trunk/Makefile.am =================================================================== --- cgm/trunk/Makefile.am 2014-03-12 04:19:30 UTC (rev 6142) +++ cgm/trunk/Makefile.am 2014-03-12 15:08:11 UTC (rev 6143) @@ -1,69 +0,0 @@ -AUTOMAKE_OPTIONS = foreign -# Don't loose the autoconf include path -ACLOCAL_AMFLAGS = -I m4 - -# Automake doesn't seem to have a directory defined for
participants (1)
janehu@mcs.anl.gov
