Author: kraftche Date: 2008-12-04 10:44:16 -0600 (Thu, 04 Dec 2008) New Revision: 2466 Removed: cgm/trunk/test/unite2.occ cgm/trunk/test/unite3.occ cgm/trunk/test/unite4.occ cgm/trunk/test/unite5.occ cgm/trunk/test/unite6.occ cgm/trunk/test/webcut_with_brick.sat Modified: cgm/trunk/test/Makefile.am cgm/trunk/test/webcut.cpp Log: Clean up mess with test output files. Files created by tests should *not* be checked into SVN? or included in tarballs. Such files *must* be written to the test build directory (not the source directory if they are different) and must be cleaned up during "make clean". Modified: cgm/trunk/test/Makefile.am =================================================================== --- cgm/trunk/test/Makefile.am 2008-12-04 16:23:02 UTC (rev 2465) +++ cgm/trunk/test/Makefile.am 2008-12-04 16:44:16 UTC (rev 2466) @@ -46,6 +46,8 @@ r_w_LDFLAGS = $(LDFLAGS) $(LINK_FLAGS) test_occ_LDFLAGS = $(LDFLAGS) $(LINK_FLAGS) +# Files that are used as input to tests, and therefore +# must be included in tarball for tests to run. EXTRA_DIST = 62_shaver1.brep \ 66_shaver3.brep \ 72_shaver6.brep \ @@ -54,11 +56,6 @@ beforesub.occ_ref \ beforesub2.occ_ref \ unite1.occ\ - unite2.occ\ - unite3.occ\ - unite4.occ\ - unite5.occ\ - unite6.occ\ huge.sat \ model1.sat \ model2.sat \ @@ -68,13 +65,31 @@ model6.sat \ model7.sat \ hollow.sat \ - stitch.occ_name \ - webcut_with_brick.sat \ - webcut_with_curve_loop.sat \ - webcut_with_extended_surf.sat \ - webcut_with_sheet.sat \ - webcut_with_sweep_along_curve.sat \ - webcut_with_sweep_surfaces.sat \ - webcut_with_sweep_surfaces_along_curve.sat \ - webcut_with_sweep_surfaces_rotated.sat + stitch.occ_name +# Files that are created by tests, and that therefore +# - should be removed during 'make clean' +# - should not be included in tarball +MOSTLYCLEANFILES = \ + webcut_with_brick.sat \ + webcut_with_cylinder.sat \ + webcut_with_sheet.sat \ + webcut_with_sweep_rotational.sat \ + webcut_with_sweep_curves.sat \ + webcut_with_sweep_along_curve.sat \ + webcut_with_curve_loop.sat \ + webcut_with_extended_surf.sat \ + webcut_with_sweep_surfaces_rotated.sat \ + webcut_with_sweep_surfaces.sat \ + webcut_with_sweep_surfaces_along_curve.sat \ + webcut_with_sweep_surfaces_perp.sat \ + point.occ \ + stitch.occ \ + beforesub.occ \ + beforesub2.occ \ + aftersub.occ \ + unite2.occ \ + unite3.occ \ + unite5.occ \ + unite6.occ + Deleted: cgm/trunk/test/unite2.occ =================================================================== --- cgm/trunk/test/unite2.occ 2008-12-04 16:23:02 UTC (rev 2465) +++ cgm/trunk/test/unite2.occ 2008-12-04 16:44:16 UTC (rev 2466) @@ -1,464 +0,0 @@ -DBRep_DrawableShape - -CASCADE Topology V1, (c) Matra-Datavision -Locations 4 -1 - 1 0 0 0 - 0 1 0 0.5 - 0 0 1 0 -1 - 1 0 0 0 - 0 1 0 0.5 - 0 0 1 0 -2 1 1 2 1 0 -2 2 -1 1 -1 0 -Curve2ds 40 -1 0 0 0 1 -1 0 1 1 0 -1 0 -1 1 0 -1 0 1 1 0 -1 1 0 0 1 -1 0 1 1 0 -1 0 -1 1 0 -1 0 0 1 0 -1 0 0 0 -1 -1 0 0 0 1 -1 0 0 0 1 -1 0 0 1 0 -1 0 0 0 -1 -1 1 0 0 1 -1 0 0 1 0 -1 0 1 1 0 -1 1 0 0 -1 -1 1 0 0 1 -1 1 0 0 -1 -1 0 0 0 1 -1 1 0 0 1 -1 0 0 1 0 -1 0 0 1 0 -1 0 0 1 0 -1 0 0 0 -1 -1 0 0 0 1 -1 0 0 0 1 -1 0 0 1 0 -1 0 0 0 -1 -1 1 0 0 1 -1 0 0 1 0 -1 0 1 1 0 -1 1 0 0 -1 -1 1 0 0 1 -1 1 0 0 -1 -1 0 0 0 1 -1 1 0 0 1 -1 0 0 1 0 -1 0 0 1 0 -1 0 0 1 0 -Curves 20 -1 0 1 0 1 0 -0 -1 1 1 0 0 0 1 -1 0 1 1 1 0 -0 -1 0 1 0 0 0 1 -1 0 0 0 -0 1 0 -1 0 0 0 1 0 -0 -1 1 0 0 -0 1 0 -1 1 0 0 0 0 1 -1 1 0 1 0 1 0 -1 0 0 1 -0 1 0 -1 0 0 1 1 0 -0 -1 0 0 0 0 0 1 -1 0 0 0 -0 1 0 -1 0 0 0 1 0 -0 -1 1 0 0 -0 1 0 -1 1 0 0 0 0 1 -1 1 0 1 0 1 0 -1 0 0 1 -0 1 0 -1 0 0 1 1 0 -0 -1 0 0 0 0 0 1 -Polygon3D 0 -PolygonOnTriangulations 0 -Surfaces 11 -1 0 1 0 -0 1 0 0 0 1 1 0 -0 -1 0 0 0 0 0 1 1 0 -0 -0 1 0 -1 1 0 0 1 0 -0 0 0 1 0 -1 0 -1 0 0 1 0 0 1 1 0 -0 -0 1 0 -1 0 0 0 1 0 -0 0 0 1 0 -1 0 -1 0 0 0 -0 1 0 0 0 1 1 0 -0 -1 0 0 0 0 0 1 1 0 -0 -0 1 0 -1 0 0 0 1 0 -0 0 0 1 0 -1 0 -1 0 0 0 -0 1 0 0 0 1 1 0 -0 -1 1 0 0 1 0 -0 0 0 1 0 -1 0 -1 0 0 1 0 0 1 1 0 -0 -0 1 0 -Triangulations 0 - -TShapes 55 -Ve -1e-07 -1 1 0 -0 0 - -0101101 -* -Ve -1e-07 -0 1 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 1 0 0 1 -2 1 1 0 0 1 -2 2 2 0 0 1 -0 - -0101000 --55 0 +54 0 * -Ve -1e-07 -1 1 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 2 0 0 1 -2 3 3 0 0 1 -2 4 1 0 0 1 -0 - -0101000 --52 0 +55 0 * -Ve -1e-07 -0 1 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 3 0 0 1 -2 5 1 0 0 1 -2 6 4 0 0 1 -0 - -0101000 --52 0 +50 0 * -Ed - 1e-07 1 1 0 -1 4 0 0 1 -2 7 5 0 0 1 -2 8 1 0 0 1 -0 - -0101000 --50 0 +54 0 * -Wi - -0101000 --53 0 -51 0 +49 0 +48 0 * -Fa -0 1e-07 1 0 - -0111000 -+47 0 * -Ve -1e-07 -0 1 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 5 0 0 1 -2 9 5 0 0 1 -2 10 2 0 0 1 -0 - -0101000 -+45 4 -54 0 * -Ve -1e-07 -1 1 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 6 0 0 1 -2 11 6 0 0 1 -2 12 2 0 0 1 -0 - -0101000 -+45 4 -43 4 * -Ed - 1e-07 1 1 0 -1 7 0 0 1 -2 13 3 0 0 1 -2 14 2 0 0 1 -0 - -0101000 -+43 4 -55 0 * -Wi - -0101000 --44 3 +42 3 -53 3 +41 3 * -Fa -0 1e-07 2 3 - -0101000 -+40 0 * -Ve -1e-07 -1 1 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 8 0 0 1 -2 15 3 0 0 1 -2 16 6 0 0 1 -0 - -0101000 -+43 4 -38 4 * -Ed - 1e-07 1 1 0 -1 9 0 0 1 -2 17 3 0 0 1 -2 18 4 0 0 1 -0 - -0101000 -+38 4 -52 0 * -Wi - -0101000 --37 3 +41 3 -36 3 +51 3 * -Fa -0 1e-07 3 3 - -0101000 -+35 0 * -Ve -1e-07 -0 1 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 10 0 0 1 -2 19 5 0 0 1 -2 20 4 0 0 1 -0 - -0101000 -+33 4 -50 0 * -Ed - 1e-07 1 1 0 -1 11 0 0 1 -2 21 6 0 0 1 -2 22 4 0 0 1 -0 - -0101000 -+33 4 -38 4 * -Wi - -0101000 --32 3 +31 3 -49 3 +36 3 * -Fa -0 1e-07 4 3 - -0101000 -+30 0 * -Ed - 1e-07 1 1 0 -1 12 0 0 1 -2 23 5 0 0 1 -2 24 6 0 0 1 -0 - -0101000 -+45 4 -33 4 * -Wi - -0101000 --28 3 +44 3 -32 3 +48 3 * -Fa -0 1e-07 5 3 - -0101000 -+27 0 * -Ve -1e-07 -0 0 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 13 0 0 1 -2 25 8 0 0 1 -2 26 7 0 0 1 -0 - -0101000 -+25 0 -45 0 * -Ve -1e-07 -1 0 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 14 0 0 1 -2 27 9 0 0 1 -2 28 7 0 0 1 -0 - -0101000 --23 0 +25 0 * -Ed - 1e-07 1 1 0 -1 15 0 0 1 -2 29 10 0 0 1 -2 30 7 0 0 1 -0 - -0101000 -+23 0 -43 0 * -Wi - -0101000 --24 0 +22 0 -42 3 +21 0 * -Fa -0 1e-07 7 0 - -0101000 -+20 0 * -Ve -1e-07 -1 0 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 16 0 0 1 -2 31 10 0 0 1 -2 32 9 0 0 1 -0 - -0101000 --18 0 +23 0 * -Ed - 1e-07 1 1 0 -1 17 0 0 1 -2 33 10 0 0 1 -2 34 11 0 0 1 -0 - -0101000 -+18 0 -38 0 * -Wi - -0101000 --17 0 -16 0 +21 0 +37 3 * -Fa -0 1e-07 10 0 - -0101000 -+15 0 * -Ve -1e-07 -0 0 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 18 0 0 1 -2 35 8 0 0 1 -2 36 11 0 0 1 -0 - -0101000 -+13 0 -33 0 * -Ed - 1e-07 1 1 0 -1 19 0 0 1 -2 37 9 0 0 1 -2 38 11 0 0 1 -0 - -0101000 --18 0 +13 0 * -Wi - -0101000 --12 0 +11 0 -31 3 +16 0 * -Fa -0 1e-07 11 0 - -0101000 -+10 0 * -Ed - 1e-07 1 1 0 -1 20 0 0 1 -2 39 8 0 0 1 -2 40 9 0 0 1 -0 - -0101000 --13 0 +25 0 * -Wi - -0101000 --8 0 -12 0 +24 0 +28 3 * -Fa -0 1e-07 8 0 - -0101000 -+7 0 * -Wi - -0101000 --22 0 -17 0 +11 0 +8 0 * -Fa -0 1e-07 9 0 - -0111000 -+5 0 * -Sh - -0101000 -+46 3 -39 0 +34 0 +29 0 -26 0 -19 0 +14 0 +9 0 -6 0 -4 0 -* -So - -CGM_ATTRIB ENTITY_NAME* volumeB* * * -* -0100000 -+3 0 * -Co - -1100000 -+2 0 * - -+1 0 \ No newline at end of file Deleted: cgm/trunk/test/unite3.occ =================================================================== --- cgm/trunk/test/unite3.occ 2008-12-04 16:23:02 UTC (rev 2465) +++ cgm/trunk/test/unite3.occ 2008-12-04 16:44:16 UTC (rev 2466) @@ -1,464 +0,0 @@ -DBRep_DrawableShape - -CASCADE Topology V1, (c) Matra-Datavision -Locations 4 -1 - 1 0 0 0 - 0 1 0 0.5 - 0 0 1 0 -1 - 1 0 0 0 - 0 1 0 0.5 - 0 0 1 0 -2 1 1 2 1 0 -2 2 -1 1 -1 0 -Curve2ds 40 -1 0 0 0 1 -1 0 0 1 0 -1 0 0 1 0 -1 0 1 1 0 -1 1 0 0 1 -1 0 0 1 0 -1 0 0 1 0 -1 0 0 1 0 -1 0 0 0 -1 -1 0 0 0 1 -1 0 0 0 1 -1 0 1 1 0 -1 0 0 0 -1 -1 1 0 0 1 -1 1 0 0 -1 -1 1 0 0 1 -1 0 -1 1 0 -1 0 1 1 0 -1 1 0 0 -1 -1 0 0 0 1 -1 1 0 0 1 -1 0 1 1 0 -1 0 -1 1 0 -1 0 0 1 0 -1 0 0 0 -1 -1 0 0 0 1 -1 0 0 0 1 -1 0 1 1 0 -1 0 0 0 -1 -1 1 0 0 1 -1 1 0 0 -1 -1 1 0 0 1 -1 0 -1 1 0 -1 0 1 1 0 -1 1 0 0 -1 -1 0 0 0 1 -1 1 0 0 1 -1 0 1 1 0 -1 0 -1 1 0 -1 0 0 1 0 -Curves 20 -1 0 0 0 1 0 -0 -1 1 0 0 0 0 1 -1 0 0 1 1 0 -0 -1 0 0 0 0 0 1 -1 0 0 0 -0 1 0 -1 0 1 0 1 0 -0 -1 1 0 0 -0 1 0 -1 1 0 1 0 1 0 -1 1 1 0 0 0 1 -1 0 0 1 -0 1 0 -1 0 1 1 1 0 -0 -1 0 1 0 0 0 1 -1 0 0 0 -0 1 0 -1 0 1 0 1 0 -0 -1 1 0 0 -0 1 0 -1 1 0 1 0 1 0 -1 1 1 0 0 0 1 -1 0 0 1 -0 1 0 -1 0 1 1 1 0 -0 -1 0 1 0 0 0 1 -Polygon3D 0 -PolygonOnTriangulations 0 -Surfaces 11 -1 0 0 0 -0 1 0 0 0 1 1 0 -0 -1 0 0 0 0 0 1 1 0 -0 -0 1 0 -1 1 0 0 1 0 -0 0 0 1 0 -1 0 -1 0 0 1 0 0 1 1 0 -0 -0 1 0 -1 0 0 0 1 0 -0 0 0 1 0 -1 0 -1 0 1 0 -0 1 0 0 0 1 1 0 -0 -1 0 0 0 0 0 1 1 0 -0 -0 1 0 -1 0 0 0 1 0 -0 0 0 1 0 -1 0 -1 0 1 0 -0 1 0 0 0 1 1 0 -0 -1 1 0 0 1 0 -0 0 0 1 0 -1 0 -1 0 0 1 0 0 1 1 0 -0 -0 1 0 -Triangulations 0 - -TShapes 55 -Ve -1e-07 -1 0 0 -0 0 - -0101101 -* -Ve -1e-07 -0 0 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 1 0 0 1 -2 1 1 0 0 1 -2 2 2 0 0 1 -0 - -0101000 --55 0 +54 0 * -Ve -1e-07 -1 0 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 2 0 0 1 -2 3 3 0 0 1 -2 4 1 0 0 1 -0 - -0101000 --52 0 +55 0 * -Ve -1e-07 -0 0 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 3 0 0 1 -2 5 1 0 0 1 -2 6 4 0 0 1 -0 - -0101000 --52 0 +50 0 * -Ed - 1e-07 1 1 0 -1 4 0 0 1 -2 7 5 0 0 1 -2 8 1 0 0 1 -0 - -0101000 --50 0 +54 0 * -Wi - -0101000 --53 0 -51 0 +49 0 +48 0 * -Fa -0 1e-07 1 0 - -0111000 -+47 0 * -Ve -1e-07 -0 1 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 5 0 0 1 -2 9 5 0 0 1 -2 10 2 0 0 1 -0 - -0101000 -+54 0 -45 0 * -Ve -1e-07 -1 1 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 6 0 0 1 -2 11 6 0 0 1 -2 12 2 0 0 1 -0 - -0101000 -+45 0 -43 0 * -Ed - 1e-07 1 1 0 -1 7 0 0 1 -2 13 3 0 0 1 -2 14 2 0 0 1 -0 - -0101000 -+55 0 -43 0 * -Wi - -0101000 --44 0 +53 0 -42 0 +41 0 * -Fa -0 1e-07 2 0 - -0101000 -+40 0 * -Ve -1e-07 -1 1 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 8 0 0 1 -2 15 3 0 0 1 -2 16 4 0 0 1 -0 - -0101000 -+52 0 -38 0 * -Ed - 1e-07 1 1 0 -1 9 0 0 1 -2 17 3 0 0 1 -2 18 6 0 0 1 -0 - -0101000 -+43 0 -38 0 * -Wi - -0101000 --51 0 -37 0 +41 0 +36 0 * -Fa -0 1e-07 3 0 - -0101000 -+35 0 * -Ve -1e-07 -0 1 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 10 0 0 1 -2 19 5 0 0 1 -2 20 4 0 0 1 -0 - -0101000 -+50 0 -33 0 * -Ed - 1e-07 1 1 0 -1 11 0 0 1 -2 21 6 0 0 1 -2 22 4 0 0 1 -0 - -0101000 -+33 0 -38 0 * -Wi - -0101000 --32 0 +49 0 -31 0 +37 0 * -Fa -0 1e-07 4 0 - -0101000 -+30 0 * -Ed - 1e-07 1 1 0 -1 12 0 0 1 -2 23 5 0 0 1 -2 24 6 0 0 1 -0 - -0101000 -+45 0 -33 0 * -Wi - -0101000 --48 0 -32 0 +44 0 +28 0 * -Fa -0 1e-07 5 0 - -0101000 -+27 0 * -Ve -1e-07 -0 1 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 13 0 0 1 -2 25 8 0 0 1 -2 26 7 0 0 1 -0 - -0101000 -+45 4 -25 0 * -Ve -1e-07 -1 1 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 14 0 0 1 -2 27 9 0 0 1 -2 28 7 0 0 1 -0 - -0101000 --23 0 +25 0 * -Ed - 1e-07 1 1 0 -1 15 0 0 1 -2 29 10 0 0 1 -2 30 7 0 0 1 -0 - -0101000 -+43 4 -23 0 * -Wi - -0101000 --24 3 +42 0 -22 3 +21 3 * -Fa -0 1e-07 7 3 - -0101000 -+20 0 * -Ve -1e-07 -1 1 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 16 0 0 1 -2 31 10 0 0 1 -2 32 11 0 0 1 -0 - -0101000 -+38 4 -18 0 * -Ed - 1e-07 1 1 0 -1 17 0 0 1 -2 33 10 0 0 1 -2 34 9 0 0 1 -0 - -0101000 --18 0 +23 0 * -Wi - -0101000 --36 0 +21 3 -17 3 +16 3 * -Fa -0 1e-07 10 3 - -0101000 -+15 0 * -Ve -1e-07 -0 1 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 18 0 0 1 -2 35 8 0 0 1 -2 36 11 0 0 1 -0 - -0101000 -+33 4 -13 0 * -Ed - 1e-07 1 1 0 -1 19 0 0 1 -2 37 9 0 0 1 -2 38 11 0 0 1 -0 - -0101000 --18 0 +13 0 * -Wi - -0101000 --12 3 +31 0 -11 3 +17 3 * -Fa -0 1e-07 11 3 - -0101000 -+10 0 * -Ed - 1e-07 1 1 0 -1 20 0 0 1 -2 39 8 0 0 1 -2 40 9 0 0 1 -0 - -0101000 --13 0 +25 0 * -Wi - -0101000 --28 0 +24 3 -12 3 +8 3 * -Fa -0 1e-07 8 3 - -0101000 -+7 0 * -Wi - -0101000 --22 0 -16 0 +11 0 +8 0 * -Fa -0 1e-07 9 0 - -0111000 -+5 0 * -Sh - -0101000 --46 0 -39 0 +34 0 +29 0 -26 0 -19 0 +14 0 +9 0 -6 0 +4 3 -* -So - -CGM_ATTRIB ENTITY_NAME* volumeA* * * -* -0100000 -+3 0 * -Co - -1100000 -+2 0 * - -+1 0 \ No newline at end of file Deleted: cgm/trunk/test/unite4.occ =================================================================== --- cgm/trunk/test/unite4.occ 2008-12-04 16:23:02 UTC (rev 2465) +++ cgm/trunk/test/unite4.occ 2008-12-04 16:44:16 UTC (rev 2466) @@ -1,562 +0,0 @@ -DBRep_DrawableShape - -CASCADE Topology V1, (c) Matra-Datavision -Locations 1 -1 - 1 0 0 0 - 0 1 0 0.5 - 0 0 1 0 -Curve2ds 48 -1 0 0 1 0 -1 0 0 1 0 -1 4 0 0 -1 -1 0 0 0 1 -1 0 -4 1 0 -1 0 0 1 0 -1 0 0 0 -1 -1 0 0 0 1 -1 0 0 1 0 -1 0 4 1 0 -1 4 0 0 -1 -1 4 0 0 1 -1 0 -4 1 0 -1 0 4 1 0 -1 0 0 0 -1 -1 4 0 0 1 -1 0 0 0 1 -1 0 0 1 0 -1 4 0 0 1 -1 0 0 1 0 -1 0 0 0 1 -1 0 4 1 0 -1 4 0 0 1 -1 0 4 1 0 -1 0 0 1 0 -1 0 0 1 0 -1 1 0 0 -1 -1 0 0 0 1 -1 0 -1 1 0 -1 0 0 1 0 -1 0 0 0 -1 -1 0 0 0 1 -1 0 0 1 0 -1 0 1 1 0 -1 1 0 0 -1 -1 1 0 0 1 -1 0 -1 1 0 -1 0 1 1 0 -1 0 0 0 -1 -1 1 0 0 1 -1 0 0 0 1 -1 0 0 1 0 -1 1 0 0 1 -1 0 0 1 0 -1 0 0 0 1 -1 0 1 1 0 -1 1 0 0 1 -1 0 1 1 0 -Curves 24 -1 0 0 0 0 0 1 -1 0 0 4 -0 1 0 -1 0 4 0 0 0 1 -1 0 0 0 -0 1 0 -1 4 0 0 0 0 1 -1 4 0 4 0 1 0 -1 4 4 0 0 0 1 -1 4 0 0 -0 1 0 -1 0 0 0 1 0 -0 -1 0 0 4 1 0 -0 -1 0 4 0 1 0 -0 -1 0 4 4 1 0 -0 -1 0 0 0 0 0 1 -1 0 0 1 -0 1 0 -1 0 1 0 0 0 1 -1 0 0 0 -0 1 0 -1 1 0 0 0 0 1 -1 1 0 1 0 1 0 -1 1 1 0 0 0 1 -1 1 0 0 -0 1 0 -1 0 0 0 1 0 -0 -1 0 0 1 1 0 -0 -1 0 1 0 1 0 -0 -1 0 1 1 1 0 -0 -Polygon3D 0 -PolygonOnTriangulations 0 -Surfaces 12 -1 0 0 0 1 0 -0 0 0 1 0 -1 0 -1 0 0 0 -0 1 0 0 0 1 1 0 -0 -1 0 0 4 0 0 1 1 0 -0 -0 1 0 -1 0 4 0 -0 1 0 0 0 1 1 0 -0 -1 0 0 0 0 0 1 1 0 -0 -0 1 0 -1 4 0 0 1 0 -0 0 0 1 0 -1 0 -1 0 0 0 1 0 -0 0 0 1 0 -1 0 -1 0 0 0 -0 1 0 0 0 1 1 0 -0 -1 0 0 1 0 0 1 1 0 -0 -0 1 0 -1 0 1 0 -0 1 0 0 0 1 1 0 -0 -1 0 0 0 0 0 1 1 0 -0 -0 1 0 -1 1 0 0 1 0 -0 0 0 1 0 -1 0 -Triangulations 0 - -TShapes 69 -Ve -1e-07 -0 0 4 -0 0 - -0101101 -* -Ve -1e-07 -0 0 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 1 0 0 4 -2 1 1 0 0 4 -2 2 2 0 0 4 -0 - -0101000 --69 0 +68 0 * -Ve -1e-07 -0 4 4 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 2 0 0 4 -2 3 1 0 0 4 -2 4 3 0 0 4 -0 - -0101000 --66 0 +69 0 * -Ve -1e-07 -0 4 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 3 0 0 4 -2 5 1 0 0 4 -2 6 4 0 0 4 -0 - -0101000 --66 0 +64 0 * -Ed - 1e-07 1 1 0 -1 4 0 0 4 -2 7 1 0 0 4 -2 8 5 0 0 4 -0 - -0101000 --64 0 +68 0 * -Wi - -0101000 --67 0 -65 0 +63 0 +62 0 * -Fa -0 1e-07 1 0 - -0111000 -+61 0 * -Ve -1e-07 -4 0 4 -0 0 - -0101101 -* -Ve -1e-07 -4 0 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 5 0 0 4 -2 9 6 0 0 4 -2 10 2 0 0 4 -0 - -0101000 --59 0 +58 0 * -Ve -1e-07 -4 4 4 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 6 0 0 4 -2 11 6 0 0 4 -2 12 3 0 0 4 -0 - -0101000 --56 0 +59 0 * -Ve -1e-07 -4 4 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 7 0 0 4 -2 13 6 0 0 4 -2 14 4 0 0 4 -0 - -0101000 --56 0 +54 0 * -Ed - 1e-07 1 1 0 -1 8 0 0 4 -2 15 6 0 0 4 -2 16 5 0 0 4 -0 - -0101000 --54 0 +58 0 * -Wi - -0101000 --57 0 -55 0 +53 0 +52 0 * -Fa -0 1e-07 6 0 - -0111000 -+51 0 * -Ed - 1e-07 1 1 0 -1 9 0 0 4 -2 17 2 0 0 4 -2 18 5 0 0 4 -0 - -0101000 --58 0 +68 0 * -Ed - 1e-07 1 1 0 -1 10 0 0 4 -2 19 2 0 0 4 -2 20 3 0 0 4 -0 - -0101000 --59 0 +69 0 * -Wi - -0101000 --49 0 -57 0 +48 0 +67 0 * -Fa -0 1e-07 2 0 - -0111000 -+47 0 * -Ed - 1e-07 1 1 0 -1 11 0 0 4 -2 21 4 0 0 4 -2 22 5 0 0 4 -0 - -0101000 --54 0 +64 0 * -Ed - 1e-07 1 1 0 -1 12 0 0 4 -2 23 4 0 0 4 -2 24 3 0 0 4 -0 - -0101000 --56 0 +66 0 * -Wi - -0101000 --45 0 -53 0 +44 0 +63 0 * -Fa -0 1e-07 4 0 - -0111000 -+43 0 * -Wi - -0101000 --62 0 -45 0 +52 0 +49 0 * -Fa -0 1e-07 5 0 - -0111000 -+41 0 * -Wi - -0101000 --65 0 -44 0 +55 0 +48 0 * -Fa -0 1e-07 3 0 - -0111000 -+39 0 * -Sh - -0101100 --60 0 +50 0 -46 0 +42 0 -40 0 +38 0 * -So - -CGM_ATTRIB ENTITY_NAME* volumeA* * * -* -0100000 -+37 0 * -Ve -1e-07 -0 0 1 -0 0 - -0101101 -* -Ve -1e-07 -0 0 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 13 0 0 1 -2 25 7 0 0 1 -2 26 8 0 0 1 -0 - -0101000 --35 0 +34 0 * -Ve -1e-07 -0 1 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 14 0 0 1 -2 27 7 0 0 1 -2 28 9 0 0 1 -0 - -0101000 --32 0 +35 0 * -Ve -1e-07 -0 1 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 15 0 0 1 -2 29 7 0 0 1 -2 30 10 0 0 1 -0 - -0101000 --32 0 +30 0 * -Ed - 1e-07 1 1 0 -1 16 0 0 1 -2 31 7 0 0 1 -2 32 11 0 0 1 -0 - -0101000 --30 0 +34 0 * -Wi - -0101000 --33 0 -31 0 +29 0 +28 0 * -Fa -0 1e-07 7 0 - -0111000 -+27 0 * -Ve -1e-07 -1 0 1 -0 0 - -0101101 -* -Ve -1e-07 -1 0 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 17 0 0 1 -2 33 12 0 0 1 -2 34 8 0 0 1 -0 - -0101000 --25 0 +24 0 * -Ve -1e-07 -1 1 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 18 0 0 1 -2 35 12 0 0 1 -2 36 9 0 0 1 -0 - -0101000 --22 0 +25 0 * -Ve -1e-07 -1 1 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 19 0 0 1 -2 37 12 0 0 1 -2 38 10 0 0 1 -0 - -0101000 --22 0 +20 0 * -Ed - 1e-07 1 1 0 -1 20 0 0 1 -2 39 12 0 0 1 -2 40 11 0 0 1 -0 - -0101000 --20 0 +24 0 * -Wi - -0101000 --23 0 -21 0 +19 0 +18 0 * -Fa -0 1e-07 12 0 - -0111000 -+17 0 * -Ed - 1e-07 1 1 0 -1 21 0 0 1 -2 41 8 0 0 1 -2 42 11 0 0 1 -0 - -0101000 --24 0 +34 0 * -Ed - 1e-07 1 1 0 -1 22 0 0 1 -2 43 8 0 0 1 -2 44 9 0 0 1 -0 - -0101000 --25 0 +35 0 * -Wi - -0101000 --15 0 -23 0 +14 0 +33 0 * -Fa -0 1e-07 8 0 - -0111000 -+13 0 * -Ed - 1e-07 1 1 0 -1 23 0 0 1 -2 45 10 0 0 1 -2 46 11 0 0 1 -0 - -0101000 --20 0 +30 0 * -Ed - 1e-07 1 1 0 -1 24 0 0 1 -2 47 10 0 0 1 -2 48 9 0 0 1 -0 - -0101000 --22 0 +32 0 * -Wi - -0101000 --11 0 -19 0 +10 0 +29 0 * -Fa -0 1e-07 10 0 - -0111000 -+9 0 * -Wi - -0101000 --28 0 -11 0 +18 0 +15 0 * -Fa -0 1e-07 11 0 - -0111000 -+7 0 * -Wi - -0101000 --31 0 -10 0 +21 0 +14 0 * -Fa -0 1e-07 9 0 - -0111000 -+5 0 * -Sh - -0101100 --26 0 +16 0 -12 0 +8 0 -6 0 +4 0 * -So - -CGM_ATTRIB ENTITY_NAME* volumeB* * * -* -0100000 -+3 0 * -Co - -1100000 -+36 1 +2 0 * - -+1 0 Deleted: cgm/trunk/test/unite5.occ =================================================================== --- cgm/trunk/test/unite5.occ 2008-12-04 16:23:02 UTC (rev 2465) +++ cgm/trunk/test/unite5.occ 2008-12-04 16:44:16 UTC (rev 2466) @@ -1,626 +0,0 @@ -DBRep_DrawableShape - -CASCADE Topology V1, (c) Matra-Datavision -Locations 2 -1 - 1 0 0 0 - 0 1 0 0.5 - 0 0 1 0 -2 1 -1 0 -Curve2ds 48 -1 0 0 1 0 -1 0 4 1 0 -1 4 0 0 -1 -1 4 0 0 1 -1 0 -4 1 0 -1 0 4 1 0 -1 0 0 0 -1 -1 4 0 0 1 -8 -1 0 -1 0 1 -1 0 -8 -1 0 -1 0 -0.5 -1 -0 -1 0 0 0 1 -1 0 0 1 0 -1 4 0 0 1 -1 0 0 1 0 -1 0 0 1 0 -1 0 0 1 0 -8 0 1 -1 1 0 0 1 -8 0 1 -1 0 0.5 1 0 -1 4 0 0 -1 -1 0 0 0 1 -1 4 0 0 1 -1 0 4 1 0 -1 0 0 0 1 -1 0 4 1 0 -1 0 -4 1 0 -1 0 0 1 0 -1 0 0 0 -1 -1 0 0 0 1 -1 0 0 0 -1 -1 1 0 0 1 -1 0 0 0 1 -1 0 1 1 0 -1 0 0 1 0 -1 0 1 1 0 -1 1 0 0 -1 -1 1 0 0 1 -1 0 -1 1 0 -1 0 0 1 0 -1 1 0 0 -1 -1 0 0 0 1 -1 1 0 0 1 -1 0 0 1 0 -1 0 0 0 -1 -1 0 0 0 1 -1 0 0 0 1 -1 0 0 1 0 -1 0 0 1 0 -1 0 0 1 0 -Curves 24 -1 4 0 0 0 0 1 -1 4 0 4 0 1 0 -1 4 4 0 0 0 1 -1 4 0 0 -0 1 0 -1 1 0.5 0 -0 0 -1 -1 0 0 0 1 0 -0 -1 0 0 4 1 0 -0 -1 0 0 0 0 0 1 -1 0 0.5 1 1 0 0 -1 0 0 4 -0 1 0 -1 0 4 4 1 0 -0 -1 0 4 0 1 0 -0 -1 0 4 0 0 0 1 -1 0 0 0 -0 1 0 -1 1 0 0 -0 1 0 -1 0 1 0 1 0 -0 -1 1 0 0 0 0 1 -1 1 0 1 0 1 0 -1 0 1 0 0 0 1 -1 0 0 1 -0 1 0 -1 0 0 1 1 0 -0 -1 0 0 0 -0 1 0 -1 0 0 0 1 0 -0 -1 0 0 0 0 0 1 -Polygon3D 0 -PolygonOnTriangulations 0 -Surfaces 12 -1 4 0 0 1 0 -0 0 0 1 0 -1 0 -1 0 0 0 -0 1 0 0 0 1 1 0 -0 -1 0 0 4 0 0 1 1 0 -0 -0 1 0 -1 0 4 0 -0 1 0 0 0 1 1 0 -0 -1 0 0 0 0 0 1 1 0 -0 -0 1 0 -1 1 0 0 1 0 -0 0 0 1 0 -1 0 -1 0 0 0 1 0 -0 0 0 1 0 -1 0 -1 0 0 1 0 0 1 1 0 -0 -0 1 0 -1 0 0 0 0 0 1 1 0 -0 -0 1 0 -1 0 1 0 -0 1 0 0 0 1 1 0 -0 -1 0 0 0 -0 1 0 0 0 1 1 0 -0 -1 0 0 0 1 0 -0 0 0 1 0 -1 0 -Triangulations 0 - -TShapes 76 -Ve -1e-07 -4 0 4 -0 0 - -0101101 -* -Ve -1e-07 -4 0 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 1 0 0 4 -2 1 1 0 0 4 -2 2 2 0 0 4 -0 - -0101000 --76 0 +75 0 * -Ve -1e-07 -4 4 4 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 2 0 0 4 -2 3 1 0 0 4 -2 4 3 0 0 4 -0 - -0101000 --73 0 +76 0 * -Ve -1e-07 -4 4 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 3 0 0 4 -2 5 1 0 0 4 -2 6 4 0 0 4 -0 - -0101000 --73 0 +71 0 * -Ed - 1e-07 1 1 0 -1 4 0 0 4 -2 7 1 0 0 4 -2 8 5 0 0 4 -0 - -0101000 --71 0 +75 0 * -Wi - -0101000 --74 0 -72 0 +70 0 +69 0 * -Fa -0 1e-07 1 0 - -0111000 -+68 0 * -Ve -2.00001e-07 -1 0.5 1 -0 0 - -0101101 -* -Ve -1.24999999959086e-07 -1 0.500000025 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 5 0 -1 0 -2 9 2 1 -1 0 -2 10 6 0 -1 0 -0 - -0101000 -+66 0 -65 0 * -Ed - 1e-07 1 1 0 -1 6 0 1 4 -2 11 2 0 1 4 -2 12 5 0 1 4 -0 - -0101000 -+65 2 -75 0 * -Ve -1e-07 -0 0 4 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 7 0 0 4 -2 13 2 0 0 4 -2 14 3 0 0 4 -0 - -0101000 --76 0 +62 0 * -Ve -1.24999999959086e-07 -0 0.500000025 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 8 0 1 4 -2 15 7 0 1 4 -2 16 2 0 1 4 -0 - -0101000 -+60 2 -62 0 * -Ed - 1e-07 1 1 0 -1 9 0 0 1 -2 17 2 1 0 1 -2 18 8 0 0 1 -0 - -0101000 -+60 0 -66 0 * -Wi - -0101000 --64 0 -63 1 -74 1 +61 1 +59 1 -58 0 * -Fa -0 1e-07 2 1 - -0101000 -+57 0 * -Ve -1e-07 -0 4 4 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 10 0 0 4 -2 19 7 0 0 4 -2 20 3 0 0 4 -0 - -0101000 --55 0 +62 0 * -Ed - 1e-07 1 1 0 -1 11 0 0 4 -2 21 4 0 0 4 -2 22 3 0 0 4 -0 - -0101000 --73 0 +55 0 * -Wi - -0101000 --54 0 -53 0 +72 0 +61 0 * -Fa -0 1e-07 3 0 - -0111000 -+52 0 * -Ve -1e-07 -0 4 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 12 0 0 4 -2 23 4 0 0 4 -2 24 5 0 0 4 -0 - -0101000 --71 0 +50 0 * -Ed - 1e-07 1 1 0 -1 13 0 0 4 -2 25 7 0 0 4 -2 26 4 0 0 4 -0 - -0101000 --55 0 +50 0 * -Wi - -0101000 --49 0 -70 0 +53 0 +48 0 * -Fa -0 1e-07 4 0 - -0111000 -+47 0 * -Ve -1e-07 -0 1 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 14 0 0.5 4 -2 27 7 0 0.5 4 -2 28 5 0 0.5 4 -0 - -0101000 -+45 2 -50 0 * -Ve -1e-07 -1 1 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 15 0 0.50000005 1 -2 29 6 0 0.50000005 1 -2 30 9 0 0.50000005 1 -0 - -0101000 -+65 0 -43 0 * -Ed - 1e-07 1 1 0 -1 16 0 0 1 -2 31 10 0 0 1 -2 32 9 0 0 1 -0 - -0101000 --43 0 +45 0 * -Wi - -0101000 --44 1 -49 1 +69 1 +63 1 -42 0 +41 0 * -Fa -0 1e-07 5 1 - -0101000 -+40 0 * -Ve -1e-07 -1 0 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 15 0 0 0.50000005 -2 29 6 0 0 0.50000005 -2 30 9 0 0 0.50000005 -0 - -0101000 -+38 0 -65 0 * -Ve -1e-07 -1 0 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 17 0 0 1 -2 33 6 0 0 1 -2 34 11 0 0 1 -0 - -0101000 --36 0 +38 0 * -Ed - 1e-07 1 1 0 -1 18 0 0 0.5 -2 35 6 0 0 0.5 -2 36 8 0 0 0.5 -0 - -0101000 -+36 0 -66 0 * -Wi - -0101000 --64 0 +37 0 -35 0 -34 0 * -Fa -0 1e-07 6 0 - -0101000 -+33 0 * -Ve -1e-07 -0 1 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 19 0 0 1 -2 37 12 0 0 1 -2 38 10 0 0 1 -0 - -0101000 --31 0 +45 0 * -Ed - 1e-07 1 1 0 -1 20 0 0.50000005 1 -2 39 12 0 0.50000005 1 -2 40 8 0 0.50000005 1 -0 - -0101000 -+60 0 -31 0 * -Wi - -0101000 --59 1 -54 1 +48 1 +44 1 -30 0 +29 0 * -Fa -0 1e-07 7 1 - -0101000 -+28 0 * -Ve -1e-07 -0 0 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 21 0 0 1 -2 41 11 0 0 1 -2 42 8 0 0 1 -0 - -0101000 --36 0 +26 0 * -Ed - 1e-07 1 1 0 -1 20 0 0 0.50000005 -2 39 12 0 0 0.50000005 -2 40 8 0 0 0.50000005 -0 - -0101000 -+26 0 -60 0 * -Wi - -0101000 --58 0 +34 0 +25 0 -24 0 * -Fa -0 1e-07 8 0 - -0101000 -+23 0 * -Ve -1e-07 -0 0 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 14 0 0 0.5 -2 27 7 0 0 0.5 -2 28 5 0 0 0.5 -0 - -0101000 -+21 0 -45 2 * -Ed - 1e-07 1 1 0 -1 6 0 0 1 -2 11 2 0 0 1 -2 12 5 0 0 1 -0 - -0101000 -+21 0 -65 2 * -Wi - -0101000 --20 1 -41 0 +42 0 +19 1 * -Fa -0 1e-07 5 1 - -0111000 -+18 0 * -Ve -1e-07 -0 0 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 22 0 0 0.5 -2 43 12 0 0 0.5 -2 44 9 0 0 0.5 -0 - -0101000 -+16 0 -21 1 * -Ed - 1e-07 1 1 0 -1 23 0 0 1 -2 45 11 0 0 1 -2 46 9 0 0 1 -0 - -0101000 --38 0 +16 0 * -Wi - -0101000 --15 0 -19 1 +37 0 +14 0 * -Fa -0 1e-07 9 0 - -0101000 -+13 0 * -Ed - 1e-07 1 1 0 -1 24 0 0 1 -2 47 12 0 0 1 -2 48 11 0 0 1 -0 - -0101000 --26 0 +16 0 * -Wi - -0101000 --14 0 -35 0 +25 0 +11 0 * -Fa -0 1e-07 11 0 - -0111000 -+10 0 * -Ed - 1e-07 1 1 0 -1 8 0 0 1 -2 15 7 0 0 1 -2 16 2 0 0 1 -0 - -0101000 -+21 0 -60 2 * -Wi - -0101000 --8 1 -29 0 +30 0 +20 1 * -Fa -0 1e-07 7 1 - -0111000 -+7 0 * -Wi - -0101000 --24 0 +8 1 +15 0 -11 0 * -Fa -0 1e-07 12 0 - -0101000 -+5 0 * -Sh - -0101000 -+67 1 -56 0 +51 1 +46 1 -39 0 +32 0 -27 0 +22 0 -17 0 -12 0 --9 0 -6 0 -4 0 * -So - -CGM_ATTRIB ENTITY_NAME* volumeA* * * -* -0100000 -+3 0 * -Co - -1100000 -+2 0 * - -+1 0 \ No newline at end of file Deleted: cgm/trunk/test/unite6.occ =================================================================== --- cgm/trunk/test/unite6.occ 2008-12-04 16:23:02 UTC (rev 2465) +++ cgm/trunk/test/unite6.occ 2008-12-04 16:44:16 UTC (rev 2466) @@ -1,626 +0,0 @@ -DBRep_DrawableShape - -CASCADE Topology V1, (c) Matra-Datavision -Locations 2 -1 - 1 0 0 0 - 0 1 0 0.5 - 0 0 1 0 -2 1 -1 0 -Curve2ds 48 -1 0 0 0 1 -1 0 0 1 0 -1 0 0 1 0 -1 0 1 1 0 -1 1 0 0 1 -1 0 0 1 0 -1 0 0 1 0 -1 0 0 1 0 -1 0 0 0 -1 -1 0 0 0 1 -1 0 0 0 1 -1 0 0 1 0 -1 0 0 0 -1 -1 1 0 0 1 -1 1 0 0 -1 -1 1 0 0 1 -8 0 1 -1 0 -0.5 1 0 -8 0 1 -1 0 1 1 0 -1 1 0 0 -1 -1 0 0 0 1 -8 -1 0 -1 0 0.5 -1 0 -8 -1 0 -1 1 0 0 -1 -1 0 0 1 0 -1 0 0 1 0 -1 0 0 0 1 -1 0 1 1 0 -1 0 0 1 0 -1 0 4 1 0 -1 4 0 0 1 -1 0 0 1 0 -1 0 -1 1 0 -1 0 0 1 0 -1 0 0 0 -1 -1 0 0 0 1 -1 0 0 0 1 -1 0 4 1 0 -1 0 0 0 -1 -1 4 0 0 1 -1 4 0 0 -1 -1 4 0 0 1 -1 0 -4 1 0 -1 0 4 1 0 -1 4 0 0 -1 -1 0 0 0 1 -1 4 0 0 1 -1 0 4 1 0 -1 0 -4 1 0 -1 0 0 1 0 -Curves 24 -1 0 0 0 1 0 -0 -1 1 0 0 0 0 1 -1 0 0 1 1 0 -0 -1 0 0 0 0 0 1 -1 0 0 0 -0 1 0 -1 0 0 0 1 0 -0 -1 1 0 0 -0 1 0 -1 1 0 1 0 1 0 -1 1 0.5 0 0 -0 1 -1 0 0 1 -0 1 0 -1 0 0.5 1 -1 0 0 -1 0 0 0 0 0 1 -1 0 1 0 1 0 -0 -1 4 0 0 0 0 1 -1 0 0 4 1 0 -0 -1 0 1 0 0 0 1 -1 0 0 0 -0 1 0 -1 0 4 0 1 0 -0 -1 4 0 0 -0 1 0 -1 4 0 4 0 1 0 -1 4 4 0 0 0 1 -1 0 0 4 -0 1 0 -1 0 4 4 1 0 -0 -1 0 4 0 0 0 1 -Polygon3D 0 -PolygonOnTriangulations 0 -Surfaces 12 -1 0 0 0 -0 1 0 0 0 1 1 0 -0 -1 0 0 0 0 0 1 1 0 -0 -0 1 0 -1 1 0 0 1 0 -0 0 0 1 0 -1 0 -1 0 0 1 0 0 1 1 0 -0 -0 1 0 -1 0 0 0 1 0 -0 0 0 1 0 -1 0 -1 0 0 0 -0 1 0 0 0 1 1 0 -0 -1 0 0 0 0 0 1 1 0 -0 -0 1 0 -1 0 0 0 1 0 -0 0 0 1 0 -1 0 -1 0 1 0 -0 1 0 0 0 1 1 0 -0 -1 4 0 0 1 0 -0 0 0 1 0 -1 0 -1 0 0 4 0 0 1 1 0 -0 -0 1 0 -1 0 4 0 -0 1 0 0 0 1 1 0 -0 -Triangulations 0 - -TShapes 76 -Ve -1e-07 -1 0 0 -0 0 - -0101101 -* -Ve -1e-07 -0 0 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 1 0 0 1 -2 1 1 0 0 1 -2 2 2 0 0 1 -0 - -0101000 --76 0 +75 0 * -Ve -1e-07 -1 0 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 2 0 0 1 -2 3 3 0 0 1 -2 4 1 0 0 1 -0 - -0101000 --73 0 +76 0 * -Ve -1e-07 -0 0 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 3 0 0 1 -2 5 1 0 0 1 -2 6 4 0 0 1 -0 - -0101000 --73 0 +71 0 * -Ed - 1e-07 1 1 0 -1 4 0 0 1 -2 7 5 0 0 1 -2 8 1 0 0 1 -0 - -0101000 --71 0 +75 0 * -Wi - -0101000 --74 0 -72 0 +70 0 +69 0 * -Fa -0 1e-07 1 0 - -0111000 -+68 0 * -Ve -1e-07 -0 0 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 5 0 0 0.5 -2 9 5 0 0 0.5 -2 10 2 0 0 0.5 -0 - -0101000 -+75 0 -66 1 * -Ve -1.24999999959086e-07 -1 0.500000025 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 6 0 0 1 -2 11 6 0 0 1 -2 12 7 0 0 1 -0 - -0101000 -+66 0 -64 2 * -Ed - 1e-07 1 1 0 -1 7 0 0 0.50000005 -2 13 3 0 0 0.50000005 -2 14 2 0 0 0.50000005 -0 - -0101000 -+76 0 -64 0 * -Wi - -0101000 --65 0 -63 1 +62 0 +74 0 * -Fa -0 1e-07 2 0 - -0101000 -+61 0 * -Ve -2.00001e-07 -1 0.5 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 8 0 0 0.5 -2 15 3 0 0 0.5 -2 16 4 0 0 0.5 -0 - -0101000 -+73 0 -59 0 * -Ed - 1e-07 1 1 0 -1 9 0 0 1 -2 17 3 0 0 1 -2 18 6 1 0 1 -0 - -0101000 -+64 0 -59 0 * -Wi - -0101000 -+62 0 -72 0 -58 0 +57 0 * -Fa -0 1e-07 3 0 - -0101000 -+56 0 * -Ve -1.24999999959086e-07 -0 0.500000025 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 10 0 0 0.50000005 -2 19 5 0 0 0.50000005 -2 20 4 0 0 0.50000005 -0 - -0101000 -+71 0 -54 0 * -Ed - 1e-07 1 1 0 -1 11 0 -1 0 -2 21 4 0 -1 0 -2 22 6 1 -1 0 -0 - -0101000 -+59 0 -54 0 * -Wi - -0101000 -+58 0 +70 0 -53 0 +52 0 * -Fa -0 1e-07 4 0 - -0101000 -+51 0 * -Ed - 1e-07 1 1 0 -1 12 0 0 1 -2 23 8 0 0 1 -2 24 6 0 0 1 -0 - -0101000 -+66 0 -54 2 * -Wi - -0101000 --53 0 +49 1 +65 0 -69 0 * -Fa -0 1e-07 5 0 - -0101000 -+48 0 * -Ve -1e-07 -0 1 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 5 0 0.5 1 -2 9 5 0 0.5 1 -2 10 2 0 0.5 1 -0 - -0101000 -+66 1 -46 0 * -Ve -1e-07 -1 1 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 13 0 0 1 -2 25 9 0 0 1 -2 26 2 0 0 1 -0 - -0101000 --44 0 +46 0 * -Ed - 1e-07 1 1 0 -1 7 0 0.50000005 1 -2 13 3 0 0.50000005 1 -2 14 2 0 0.50000005 1 -0 - -0101000 -+64 0 -44 0 * -Wi - -0101000 --45 0 -43 0 +42 0 +63 1 * -Fa -0 1e-07 2 0 - -0111000 -+41 0 * -Ve -1e-07 -4 0 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 6 0 1 4 -2 11 6 0 1 4 -2 12 7 0 1 4 -0 - -0101000 -+64 2 -39 0 * -Ve -1e-07 -4 0 4 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 14 0 0 4 -2 27 10 0 0 4 -2 28 6 0 0 4 -0 - -0101000 --37 0 +39 0 * -Ve -1e-07 -0 0 4 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 15 0 0 4 -2 29 6 0 0 4 -2 30 11 0 0 4 -0 - -0101000 --37 0 +35 0 * -Ed - 1e-07 1 1 0 -1 12 0 1 4 -2 23 8 0 1 4 -2 24 6 0 1 4 -0 - -0101000 -+54 2 -35 0 * -Wi - -0101000 --38 1 -36 1 +34 1 +33 1 +52 0 +57 0 * -Fa -0 1e-07 6 1 - -0101000 -+32 0 * -Ve -1e-07 -0 1 1 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 10 0 0.50000005 1 -2 19 5 0 0.50000005 1 -2 20 4 0 0.50000005 1 -0 - -0101000 -+54 0 -30 0 * -Ed - 1e-07 1 1 0 -1 16 0 0 1 -2 31 5 0 0 1 -2 32 9 0 0 1 -0 - -0101000 --30 0 +46 0 * -Wi - -0101000 --29 0 +28 0 +45 0 -49 1 * -Fa -0 1e-07 5 0 - -0111000 -+27 0 * -Ve -1e-07 -0 4 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 17 0 0.5 4 -2 33 8 0 0.5 4 -2 34 7 0 0.5 4 -0 - -0101000 -+46 2 -25 0 * -Ve -1e-07 -4 4 0 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 18 0 0 4 -2 35 12 0 0 4 -2 36 7 0 0 4 -0 - -0101000 --23 0 +25 0 * -Ed - 1e-07 1 1 0 -1 19 0 0 4 -2 37 10 0 0 4 -2 38 7 0 0 4 -0 - -0101000 --23 0 +39 0 * -Wi - -0101000 --24 1 -22 1 +21 1 +38 1 -42 0 +43 0 * -Fa -0 1e-07 7 1 - -0101000 -+20 0 * -Ve -1e-07 -4 4 4 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 20 0 0 4 -2 39 10 0 0 4 -2 40 11 0 0 4 -0 - -0101000 --18 0 +37 0 * -Ed - 1e-07 1 1 0 -1 21 0 0 4 -2 41 10 0 0 4 -2 42 12 0 0 4 -0 - -0101000 --18 0 +23 0 * -Wi - -0101000 --36 0 -17 0 +16 0 +21 0 * -Fa -0 1e-07 10 0 - -0111000 -+15 0 * -Ve -1e-07 -0 4 4 -0 0 - -0101101 -* -Ed - 1e-07 1 1 0 -1 22 0 0 4 -2 43 8 0 0 4 -2 44 11 0 0 4 -0 - -0101000 --13 0 +35 0 * -Ed - 1e-07 1 1 0 -1 23 0 0 4 -2 45 12 0 0 4 -2 46 11 0 0 4 -0 - -0101000 --18 0 +13 0 * -Wi - -0101000 --12 0 -11 0 +17 0 +34 0 * -Fa -0 1e-07 11 0 - -0111000 -+10 0 * -Ed - 1e-07 1 1 0 -1 24 0 0 4 -2 47 8 0 0 4 -2 48 12 0 0 4 -0 - -0101000 --13 0 +25 0 * -Wi - -0101000 --33 1 -12 1 +8 1 +24 1 -28 0 +29 0 * -Fa -0 1e-07 8 1 - -0101000 -+7 0 * -Wi - -0101000 --22 0 -16 0 +11 0 +8 0 * -Fa -0 1e-07 12 0 - -0111000 -+5 0 * -Sh - -0101000 --67 0 -60 0 +55 0 +50 0 -47 0 -40 0 -31 0 -26 0 -19 0 +14 1 -+9 1 -6 0 +4 1 * -So - -CGM_ATTRIB ENTITY_NAME* volumeB* * * -* -0100000 -+3 0 * -Co - -1100000 -+2 0 * - -+1 0 \ No newline at end of file Modified: cgm/trunk/test/webcut.cpp =================================================================== --- cgm/trunk/test/webcut.cpp 2008-12-04 16:23:02 UTC (rev 2465) +++ cgm/trunk/test/webcut.cpp 2008-12-04 16:44:16 UTC (rev 2466) @@ -162,7 +162,7 @@ DLIList<RefEntity*> ref_entity_list; int num_ents_exported=0; const CubitString cubit_version="10.2"; - const char * filename = STRINGIFY(SRCDIR) "/webcut_with_brick.sat"; + const char * filename = "webcut_with_brick.sat"; const char * filetype = "ACIS_SAT"; rsl = gti->export_solid_model(ref_entity_list, filename, filetype, num_ents_exported, cubit_version); @@ -213,7 +213,7 @@ DLIList<RefEntity*> ref_entity_list; int num_ents_exported=0; const CubitString cubit_version="10.2"; - const char * filename = STRINGIFY(SRCDIR) "webcut_with_cylinder.sat"; + const char * filename = "webcut_with_cylinder.sat"; const char * filetype = "ACIS_SAT"; rsl = gti->export_solid_model(ref_entity_list, filename, filetype, num_ents_exported, cubit_version); @@ -266,7 +266,7 @@ DLIList<RefEntity*> ref_entity_list; int num_ents_exported=0; const CubitString cubit_version="10.2"; - const char * filename = STRINGIFY(SRCDIR) "/webcut_with_sheet.sat"; + const char * filename = "webcut_with_sheet.sat"; const char * filetype = "ACIS_SAT"; rsl = gti->export_solid_model(ref_entity_list, filename, filetype, num_ents_exported, cubit_version); @@ -334,7 +334,7 @@ DLIList<RefEntity*> ref_entity_list; int num_ents_exported=0; const CubitString cubit_version="10.2"; - const char * filename = STRINGIFY(SRCDIR) "webcut_with_sweep_rotational.sat"; + const char * filename = "webcut_with_sweep_rotational.sat"; const char * filetype = "ACIS_SAT"; rsl = gti->export_solid_model(ref_entity_list, filename, filetype, num_ents_exported, cubit_version); @@ -394,7 +394,7 @@ DLIList<RefEntity*> ref_entity_list; int num_ents_exported=0; const CubitString cubit_version="10.2"; - const char * filename = STRINGIFY(SRCDIR) "webcut_with_sweep_curves.sat"; + const char * filename = "webcut_with_sweep_curves.sat"; const char * filetype = "ACIS_SAT"; rsl = gti->export_solid_model(ref_entity_list, filename, filetype, num_ents_exported, cubit_version); @@ -465,7 +465,7 @@ DLIList<RefEntity*> ref_entity_list; int num_ents_exported=0; const CubitString cubit_version="10.2"; - const char * filename = STRINGIFY(SRCDIR) "/webcut_with_sweep_along_curve.sat"; + const char * filename = "webcut_with_sweep_along_curve.sat"; const char * filetype = "ACIS_SAT"; rsl = gti->export_solid_model(ref_entity_list, filename, filetype, num_ents_exported, cubit_version); @@ -522,7 +522,7 @@ DLIList<RefEntity*> ref_entity_list; int num_ents_exported=0; const CubitString cubit_version="10.2"; - const char * filename = STRINGIFY(SRCDIR) "/webcut_with_curve_loop.sat"; + const char * filename = "webcut_with_curve_loop.sat"; const char * filetype = "ACIS_SAT"; rsl = gti->export_solid_model(ref_entity_list, filename, filetype, num_ents_exported, cubit_version); @@ -575,7 +575,7 @@ DLIList<RefEntity*> ref_entity_list; int num_ents_exported=0; const CubitString cubit_version="10.2"; - const char * filename = STRINGIFY(SRCDIR) "/webcut_with_extended_surf.sat"; + const char * filename = "webcut_with_extended_surf.sat"; const char * filetype = "ACIS_SAT"; rsl = gti->export_solid_model(ref_entity_list, filename, filetype, num_ents_exported, cubit_version); @@ -626,7 +626,7 @@ DLIList<RefEntity*> ref_entity_list; int num_ents_exported=0; const CubitString cubit_version="10.2"; - const char * filename = STRINGIFY(SRCDIR) "/webcut_with_sweep_surfaces_rotated.sat"; + const char * filename = "webcut_with_sweep_surfaces_rotated.sat"; const char * filetype = "ACIS_SAT"; rsl = gti->export_solid_model(ref_entity_list, filename, filetype, num_ents_exported, cubit_version); @@ -676,7 +676,7 @@ DLIList<RefEntity*> ref_entity_list; int num_ents_exported=0; const CubitString cubit_version="10.2"; - const char * filename = STRINGIFY(SRCDIR) "/webcut_with_sweep_surfaces.sat"; + const char * filename = "webcut_with_sweep_surfaces.sat"; const char * filetype = "ACIS_SAT"; rsl = gti->export_solid_model(ref_entity_list, filename, filetype, num_ents_exported, cubit_version); @@ -736,7 +736,7 @@ DLIList<RefEntity*> ref_entity_list; int num_ents_exported=0; const CubitString cubit_version="10.2"; - const char * filename = STRINGIFY(SRCDIR) "/webcut_with_sweep_surfaces_along_curve.sat"; + const char * filename = "webcut_with_sweep_surfaces_along_curve.sat"; const char * filetype = "ACIS_SAT"; rsl = gti->export_solid_model(ref_entity_list, filename, filetype, num_ents_exported, cubit_version); Deleted: cgm/trunk/test/webcut_with_brick.sat =================================================================== --- cgm/trunk/test/webcut_with_brick.sat 2008-12-04 16:23:02 UTC (rev 2465) +++ cgm/trunk/test/webcut_with_brick.sat 2008-12-04 16:44:16 UTC (rev 2466) @@ -1,233 +0,0 @@ -1600 0 2 0 -10 Cubit 10.2 17 ACIS 16.0.7 Linux 24 Wed Nov 26 13:51:34 2008 -1 9.9999999999999995e-07 1e-10 -body $-1 -1 -1 $-1 $2 $-1 $3 T 4 4 4 14 14 14 # -body $-1 -1 -1 $-1 $4 $-1 $5 T 4 4 4 5 5 5 # -lump $-1 -1 -1 $-1 $-1 $6 $0 T 4 4 4 14 14 14 # -transform $-1 -1 1 0 0 0 1 0 0 0 1 0 0 0 1 no_rotate no_reflect no_shear # -lump $-1 -1 -1 $-1 $-1 $7 $1 T 4 4 4 5 5 5 # -transform $-1 -1 1 0 0 0 1 0 0 0 1 0 0 0 1 no_rotate no_reflect no_shear # -shell $-1 -1 -1 $-1 $-1 $-1 $8 $-1 $2 T 4 4 4 14 14 14 # -shell $-1 -1 -1 $-1 $-1 $-1 $9 $-1 $4 T 4 4 4 5 5 5 # -face $-1 -1 -1 $-1 $10 $11 $6 $-1 $12 reversed single T 4 4 5 5 5 5 F # -face $-1 -1 -1 $-1 $13 $14 $7 $-1 $15 forward single T 4 4 5 5 5 5 F # -face $-1 -1 -1 $-1 $16 $17 $6 $-1 $18 forward single T 4 5 4 5 5 5 F # -loop $-1 -1 -1 $-1 $-1 $19 $8 T 4 4 5 5 5 5 unknown # -plane-surface $-1 -1 -1 $-1 4.5 4.5 5 0 0 1 1 0 0 forward_v I I I I # -face $-1 -1 -1 $-1 $20 $21 $7 $-1 $22 reversed single T 4 5 4 5 5 5 F # -loop $-1 -1 -1 $-1 $-1 $23 $9 T 4 4 5 5 5 5 unknown # -plane-surface $-1 -1 -1 $-1 4.5 4.5 5 0 0 1 1 0 0 forward_v I I I I # -face $-1 -1 -1 $-1 $24 $25 $6 $-1 $26 forward single T 5 4 4 5 5 5 F # -loop $-1 -1 -1 $-1 $-1 $27 $10 T 4 5 4 5 5 5 unknown # -plane-surface $-1 -1 -1 $-1 4.5 5 4.5 0 -1 0 0 0 -1 forward_v I I I I # -coedge $-1 -1 -1 $-1 $28 $29 $30 $31 reversed $11 $-1 # -face $-1 -1 -1 $-1 $32 $33 $7 $-1 $34 reversed single T 5 4 4 5 5 5 F # -loop $-1 -1 -1 $-1 $-1 $35 $13 T 4 5 4 5 5 5 unknown # -plane-surface $-1 -1 -1 $-1 4.5 5 4.5 0 -1 0 0 0 -1 forward_v I I I I # -coedge $-1 -1 -1 $-1 $36 $37 $38 $39 forward $14 $-1 # -face $-1 -1 -1 $-1 $40 $41 $6 $-1 $42 reversed single T 4 4 4 14 4 14 F # -loop $-1 -1 -1 $-1 $-1 $43 $16 T 5 4 4 5 5 5 unknown # -plane-surface $-1 -1 -1 $-1 5 4.5 4.5 -1 0 0 0 0 1 forward_v I I I I # -coedge $-1 -1 -1 $-1 $44 $45 $46 $47 reversed $17 $-1 # -coedge $-1 -1 -1 $-1 $48 $19 $49 $50 reversed $11 $-1 # -coedge $-1 -1 -1 $-1 $19 $48 $44 $51 reversed $11 $-1 # -coedge $-1 -1 -1 $-1 $46 $43 $19 $31 forward $25 $-1 # -edge $-1 -1 -1 $-1 $52 -0.5 $53 0.5 $30 $54 forward @7 unknown T 5 4 5 5 5 5 # -face $-1 -1 -1 $-1 $55 $56 $7 $-1 $57 reversed single T 4 4 4 4 5 5 F # -loop $-1 -1 -1 $-1 $-1 $58 $20 T 5 4 4 5 5 5 unknown # -plane-surface $-1 -1 -1 $-1 5 4.5 4.5 -1 0 0 0 0 1 forward_v I I I I # -coedge $-1 -1 -1 $-1 $59 $60 $61 $62 forward $21 $-1 # -coedge $-1 -1 -1 $-1 $63 $23 $60 $64 forward $14 $-1 # -coedge $-1 -1 -1 $-1 $23 $63 $65 $66 forward $14 $-1 # -coedge $-1 -1 -1 $-1 $58 $61 $23 $39 reversed $33 $-1 # -edge $-1 -1 -1 $-1 $67 -0.5 $68 0.5 $38 $69 forward @7 unknown T 5 4 5 5 5 5 # -face $-1 -1 -1 $-1 $70 $71 $6 $-1 $72 forward single T 4 4 14 14 14 14 F # -loop $-1 -1 -1 $-1 $-1 $49 $24 T 4 4 4 14 4 14 unknown # -plane-surface $-1 -1 -1 $-1 9 4 9 0 1 0 0 0 1 forward_v I I I I # -coedge $-1 -1 -1 $-1 $30 $73 $74 $75 reversed $25 $-1 # -coedge $-1 -1 -1 $-1 $76 $27 $29 $51 forward $17 $-1 # -coedge $-1 -1 -1 $-1 $27 $76 $77 $78 reversed $17 $-1 # -coedge $-1 -1 -1 $-1 $73 $30 $27 $47 forward $25 $-1 # -edge $-1 -1 -1 $-1 $53 -0.5 $79 0.5 $46 $80 forward @7 unknown T 5 5 4 5 5 5 # -coedge $-1 -1 -1 $-1 $29 $28 $81 $82 reversed $11 $-1 # -coedge $-1 -1 -1 $-1 $74 $83 $28 $50 forward $41 $-1 # -edge $-1 -1 -1 $-1 $84 -2.75 $52 -1.75 $49 $85 forward @7 unknown T 4 4 5 5 4 5 # -edge $-1 -1 -1 $-1 $53 -0.5 $86 0.5 $44 $87 forward @7 unknown T 4 5 5 5 5 5 # -vertex $-1 -1 -1 $-1 $50 $88 # -vertex $-1 -1 -1 $-1 $31 $89 # -straight-curve $-1 -1 -1 $-1 5 4.5 5 0 1 0 I I # -face $-1 -1 -1 $-1 $90 $91 $7 $-1 $92 reversed single T 4 4 4 5 5 4 F # -loop $-1 -1 -1 $-1 $-1 $93 $32 T 4 4 4 4 5 5 unknown # -plane-surface $-1 -1 -1 $-1 4 9 9 1 0 0 0 0 -1 forward_v I I I I # -coedge $-1 -1 -1 $-1 $94 $38 $95 $96 forward $33 $-1 # -coedge $-1 -1 -1 $-1 $97 $35 $98 $99 forward $21 $-1 # -coedge $-1 -1 -1 $-1 $35 $97 $36 $64 reversed $21 $-1 # -coedge $-1 -1 -1 $-1 $38 $94 $35 $62 reversed $33 $-1 # -edge $-1 -1 -1 $-1 $68 -0.5 $100 0.5 $61 $101 forward @7 unknown T 5 5 4 5 5 5 # -coedge $-1 -1 -1 $-1 $37 $36 $93 $102 forward $14 $-1 # -edge $-1 -1 -1 $-1 $68 -0.5 $103 0.5 $60 $104 forward @7 unknown T 4 5 5 5 5 5 # -coedge $-1 -1 -1 $-1 $105 $95 $37 $66 reversed $106 $-1 # -edge $-1 -1 -1 $-1 $107 -2.75 $67 -1.75 $65 $108 forward @7 unknown T 4 4 5 5 4 5 # -vertex $-1 -1 -1 $-1 $66 $109 # -vertex $-1 -1 -1 $-1 $39 $110 # -straight-curve $-1 -1 -1 $-1 5 4.5 5 0 1 0 I I # -face $-1 -1 -1 $-1 $111 $112 $6 $-1 $113 reversed single T 4 4 4 14 14 4 F # -loop $-1 -1 -1 $-1 $-1 $114 $40 T 4 4 14 14 14 14 unknown # -plane-surface $-1 -1 -1 $-1 9 9 14 0 0 1 1 0 0 forward_v I I I I # -coedge $-1 -1 -1 $-1 $43 $46 $115 $116 reversed $25 $-1 # -coedge $-1 -1 -1 $-1 $117 $49 $43 $75 forward $41 $-1 # -edge $-1 -1 -1 $-1 $52 1.75 $118 2.75 $74 $119 forward @7 unknown T 5 4 4 5 4 5 # -coedge $-1 -1 -1 $-1 $45 $44 $120 $121 reversed $17 $-1 # -coedge $-1 -1 -1 $-1 $122 $115 $45 $78 forward $112 $-1 # -edge $-1 -1 -1 $-1 $79 1.75 $123 2.75 $77 $124 forward @7 unknown T 4 5 4 5 5 4 # -vertex $-1 -1 -1 $-1 $78 $125 # -straight-curve $-1 -1 -1 $-1 5 5 4.5 0 0 -1 I I # -coedge $-1 -1 -1 $-1 $126 $120 $48 $82 forward $127 $-1 # -edge $-1 -1 -1 $-1 $86 1.75 $84 2.75 $81 $128 forward @7 unknown T 4 4 5 4 5 5 # -coedge $-1 -1 -1 $-1 $49 $129 $126 $130 forward $41 $-1 # -vertex $-1 -1 -1 $-1 $50 $131 # -straight-curve $-1 -1 -1 $-1 6.75 4 5 1 0 0 I I # -vertex $-1 -1 -1 $-1 $82 $132 # -straight-curve $-1 -1 -1 $-1 4.5 5 5 -1 0 0 I I # -point $-1 -1 -1 $-1 5 4 5 # -point $-1 -1 -1 $-1 5 5 5 # -face $-1 -1 -1 $-1 $-1 $106 $7 $-1 $133 reversed single T 4 4 4 5 4 5 F # -loop $-1 -1 -1 $-1 $-1 $98 $55 T 4 4 4 5 5 4 unknown # -plane-surface $-1 -1 -1 $-1 9 9 4 0 0 1 1 0 0 forward_v I I I I # -coedge $-1 -1 -1 $-1 $134 $135 $63 $102 reversed $56 $-1 # -coedge $-1 -1 -1 $-1 $61 $58 $136 $137 forward $33 $-1 # -coedge $-1 -1 -1 $-1 $65 $138 $58 $96 reversed $106 $-1 # -edge $-1 -1 -1 $-1 $67 1.75 $139 2.75 $95 $140 forward @7 unknown T 5 4 4 5 4 5 # -coedge $-1 -1 -1 $-1 $60 $59 $134 $141 forward $21 $-1 # -coedge $-1 -1 -1 $-1 $136 $142 $59 $99 reversed $91 $-1 # -edge $-1 -1 -1 $-1 $100 1.75 $143 2.75 $98 $144 forward @7 unknown T 4 5 4 5 5 4 # -vertex $-1 -1 -1 $-1 $99 $145 # -straight-curve $-1 -1 -1 $-1 5 5 4.5 0 0 -1 I I # -edge $-1 -1 -1 $-1 $103 1.75 $107 2.75 $93 $146 forward @7 unknown T 4 4 5 4 5 5 # -vertex $-1 -1 -1 $-1 $102 $147 # -straight-curve $-1 -1 -1 $-1 4.5 5 5 -1 0 0 I I # -coedge $-1 -1 -1 $-1 $138 $65 $135 $148 forward $106 $-1 # -loop $-1 -1 -1 $-1 $-1 $65 $90 T 4 4 4 5 4 5 unknown # -vertex $-1 -1 -1 $-1 $148 $149 # -straight-curve $-1 -1 -1 $-1 6.75 4 5 1 0 0 I I # -point $-1 -1 -1 $-1 5 4 5 # -point $-1 -1 -1 $-1 5 5 5 # -face $-1 -1 -1 $-1 $150 $127 $6 $-1 $151 reversed single T 4 4 4 4 14 14 F # -loop $-1 -1 -1 $-1 $-1 $77 $70 T 4 4 4 14 14 4 unknown # -plane-surface $-1 -1 -1 $-1 9 9 4 0 0 1 1 0 0 forward_v I I I I # -coedge $-1 -1 -1 $-1 $152 $153 $154 $155 forward $71 $-1 # -coedge $-1 -1 -1 $-1 $77 $156 $73 $116 forward $112 $-1 # -edge $-1 -1 -1 $-1 $118 -2.75 $79 -1.75 $115 $157 forward @7 unknown T 5 4 4 5 5 4 # -coedge $-1 -1 -1 $-1 $158 $74 $156 $159 reversed $41 $-1 # -vertex $-1 -1 -1 $-1 $75 $160 # -straight-curve $-1 -1 -1 $-1 5 4 6.75 0 0 -1 I I # -coedge $-1 -1 -1 $-1 $81 $161 $76 $121 forward $127 $-1 # -edge $-1 -1 -1 $-1 $123 -2.75 $86 -1.75 $120 $162 forward @7 unknown T 4 5 4 4 5 5 # -coedge $-1 -1 -1 $-1 $163 $77 $161 $164 forward $112 $-1 # -vertex $-1 -1 -1 $-1 $164 $165 # -straight-curve $-1 -1 -1 $-1 6.75 5 4 -1 0 0 I I # -point $-1 -1 -1 $-1 5 5 4 # -coedge $-1 -1 -1 $-1 $166 $81 $83 $130 reversed $127 $-1 # -loop $-1 -1 -1 $-1 $-1 $81 $111 T 4 4 4 4 14 14 unknown # -straight-curve $-1 -1 -1 $-1 4 6.75 5 0 -1 0 I I # -coedge $-1 -1 -1 $-1 $83 $158 $153 $167 reversed $41 $-1 # -edge $-1 -1 -1 $-1 $168 -5 $84 4 $126 $169 forward @7 unknown T 4 4 5 4 4 14 # -point $-1 -1 -1 $-1 4 4 5 # -point $-1 -1 -1 $-1 4 5 5 # -plane-surface $-1 -1 -1 $-1 9 4 9 0 1 0 0 0 1 forward_v I I I I # -coedge $-1 -1 -1 $-1 $170 $93 $97 $141 reversed $56 $-1 # -coedge $-1 -1 -1 $-1 $93 $170 $105 $148 reversed $56 $-1 # -coedge $-1 -1 -1 $-1 $171 $98 $94 $137 reversed $91 $-1 # -edge $-1 -1 -1 $-1 $139 -2.75 $100 -1.75 $136 $172 forward @7 unknown T 5 4 4 5 5 4 # -coedge $-1 -1 -1 $-1 $95 $105 $171 $173 reversed $106 $-1 # -vertex $-1 -1 -1 $-1 $173 $174 # -straight-curve $-1 -1 -1 $-1 5 4 6.75 0 0 -1 I I # -edge $-1 -1 -1 $-1 $143 -2.75 $103 -1.75 $134 $175 forward @7 unknown T 4 5 4 4 5 5 # -coedge $-1 -1 -1 $-1 $98 $171 $170 $176 forward $91 $-1 # -vertex $-1 -1 -1 $-1 $99 $177 # -straight-curve $-1 -1 -1 $-1 6.75 5 4 -1 0 0 I I # -point $-1 -1 -1 $-1 5 5 4 # -straight-curve $-1 -1 -1 $-1 4 6.75 5 0 -1 0 I I # -point $-1 -1 -1 $-1 4 5 5 # -edge $-1 -1 -1 $-1 $107 4 $178 5 $135 $179 forward @7 unknown T 4 4 4 4 4 5 # -point $-1 -1 -1 $-1 4 4 5 # -face $-1 -1 -1 $-1 $180 $181 $6 $-1 $182 reversed single T 4 14 4 14 14 14 F # -plane-surface $-1 -1 -1 $-1 4 9 9 1 0 0 0 0 -1 forward_v I I I I # -coedge $-1 -1 -1 $-1 $183 $114 $184 $185 forward $71 $-1 # -coedge $-1 -1 -1 $-1 $114 $183 $129 $167 forward $71 $-1 # -coedge $-1 -1 -1 $-1 $186 $187 $114 $155 reversed $188 $-1 # -edge $-1 -1 -1 $-1 $189 -5 $190 5 $154 $191 forward @7 unknown T 14 4 14 14 14 14 # -coedge $-1 -1 -1 $-1 $115 $192 $117 $159 forward $112 $-1 # -straight-curve $-1 -1 -1 $-1 5 6.75 4 0 1 -0 I I # -coedge $-1 -1 -1 $-1 $129 $117 $186 $193 reversed $41 $-1 # -edge $-1 -1 -1 $-1 $194 -5 $118 4 $117 $195 forward @7 unknown T 5 4 4 14 4 4 # -point $-1 -1 -1 $-1 5 4 4 # -coedge $-1 -1 -1 $-1 $120 $196 $122 $164 reversed $127 $-1 # -straight-curve $-1 -1 -1 $-1 4 5 6.75 -0 0 1 I I # -coedge $-1 -1 -1 $-1 $192 $122 $197 $198 forward $112 $-1 # -edge $-1 -1 -1 $-1 $123 -4 $199 5 $161 $200 forward @7 unknown T 4 5 4 4 14 4 # -point $-1 -1 -1 $-1 4 5 4 # -coedge $-1 -1 -1 $-1 $196 $126 $183 $201 reversed $127 $-1 # -edge $-1 -1 -1 $-1 $168 -5 $189 5 $129 $202 forward @7 unknown T 4 4 14 14 4 14 # -vertex $-1 -1 -1 $-1 $201 $203 # -straight-curve $-1 -1 -1 $-1 4 4 9 0 0 -1 I I # -coedge $-1 -1 -1 $-1 $135 $134 $142 $176 reversed $56 $-1 # -coedge $-1 -1 -1 $-1 $142 $136 $138 $173 forward $91 $-1 # -straight-curve $-1 -1 -1 $-1 5 6.75 4 0 1 -0 I I # -edge $-1 -1 -1 $-1 $139 4 $178 5 $138 $204 forward @7 unknown T 4 4 4 5 4 4 # -point $-1 -1 -1 $-1 5 4 4 # -straight-curve $-1 -1 -1 $-1 4 5 6.75 -0 0 1 I I # -edge $-1 -1 -1 $-1 $178 -5 $143 -4 $170 $205 forward @7 unknown T 4 4 4 4 5 4 # -point $-1 -1 -1 $-1 4 5 4 # -vertex $-1 -1 -1 $-1 $176 $206 # -straight-curve $-1 -1 -1 $-1 4 4 9 0 0 -1 I I # -face $-1 -1 -1 $-1 $-1 $188 $6 $-1 $207 reversed single T 14 4 4 14 14 14 F # -loop $-1 -1 -1 $-1 $-1 $208 $150 T 4 14 4 14 14 14 unknown # -plane-surface $-1 -1 -1 $-1 9 14 9 0 -1 0 0 0 -1 forward_v I I I I # -coedge $-1 -1 -1 $-1 $153 $152 $166 $201 forward $71 $-1 # -coedge $-1 -1 -1 $-1 $208 $209 $152 $185 reversed $181 $-1 # -edge $-1 -1 -1 $-1 $190 -5 $210 5 $184 $211 forward @7 unknown T 4 14 14 14 14 14 # -coedge $-1 -1 -1 $-1 $212 $154 $158 $193 forward $188 $-1 # -coedge $-1 -1 -1 $-1 $154 $212 $208 $213 reversed $188 $-1 # -loop $-1 -1 -1 $-1 $-1 $186 $180 T 14 4 4 14 14 14 unknown # -vertex $-1 -1 -1 $-1 $155 $214 # -vertex $-1 -1 -1 $-1 $155 $215 # -straight-curve $-1 -1 -1 $-1 14 9 14 0 1 0 I I # -coedge $-1 -1 -1 $-1 $156 $163 $212 $216 forward $112 $-1 # -edge $-1 -1 -1 $-1 $189 -5 $194 5 $186 $217 forward @7 unknown T 14 4 4 14 4 14 # -vertex $-1 -1 -1 $-1 $193 $218 # -straight-curve $-1 -1 -1 $-1 9 4 4 -1 0 0 I I # -coedge $-1 -1 -1 $-1 $161 $166 $209 $219 forward $127 $-1 # -coedge $-1 -1 -1 $-1 $209 $208 $163 $198 reversed $181 $-1 # -edge $-1 -1 -1 $-1 $199 -5 $220 5 $197 $221 forward @7 unknown T 4 14 4 14 14 4 # -vertex $-1 -1 -1 $-1 $198 $222 # -straight-curve $-1 -1 -1 $-1 4 9 4 0 1 0 I I # -edge $-1 -1 -1 $-1 $210 -5 $168 5 $166 $223 forward @7 unknown T 4 4 14 4 14 14 # -straight-curve $-1 -1 -1 $-1 9 4 14 1 0 0 I I # -point $-1 -1 -1 $-1 4 4 14 # -straight-curve $-1 -1 -1 $-1 9 4 4 -1 0 0 I I # -straight-curve $-1 -1 -1 $-1 4 9 4 0 1 0 I I # -point $-1 -1 -1 $-1 4 4 4 # -plane-surface $-1 -1 -1 $-1 14 9 9 -1 0 0 0 0 1 forward_v I I I I # -coedge $-1 -1 -1 $-1 $197 $184 $187 $213 forward $181 $-1 # -coedge $-1 -1 -1 $-1 $184 $197 $196 $219 reversed $181 $-1 # -vertex $-1 -1 -1 $-1 $185 $224 # -straight-curve $-1 -1 -1 $-1 9 14 14 -1 0 0 I I # -coedge $-1 -1 -1 $-1 $187 $186 $192 $216 reversed $188 $-1 # -edge $-1 -1 -1 $-1 $190 -5 $220 5 $187 $225 forward @7 unknown T 14 14 4 14 14 14 # -point $-1 -1 -1 $-1 14 4 14 # -point $-1 -1 -1 $-1 14 14 14 # -edge $-1 -1 -1 $-1 $220 -5 $194 5 $212 $226 forward @7 unknown T 14 4 4 14 14 4 # -straight-curve $-1 -1 -1 $-1 14 4 9 0 0 -1 I I # -point $-1 -1 -1 $-1 14 4 4 # -edge $-1 -1 -1 $-1 $210 -5 $199 5 $209 $227 forward @7 unknown T 4 14 4 4 14 14 # -vertex $-1 -1 -1 $-1 $216 $228 # -straight-curve $-1 -1 -1 $-1 9 14 4 1 0 0 I I # -point $-1 -1 -1 $-1 4 14 4 # -straight-curve $-1 -1 -1 $-1 4 9 14 0 -1 0 I I # -point $-1 -1 -1 $-1 4 14 14 # -straight-curve $-1 -1 -1 $-1 14 14 9 0 0 -1 I I # -straight-curve $-1 -1 -1 $-1 14 9 4 0 -1 0 I I # -straight-curve $-1 -1 -1 $-1 4 14 9 0 0 -1 I I # -point $-1 -1 -1 $-1 14 14 4 # -End-of-ACIS-data \ No newline at end of file
participants (1)
kraftche@mcs.anl.gov
