2 new commits in CGM: https://bitbucket.org/fathomteam/cgm/commits/18a1fbad59e0/ Changeset: 18a1fbad59e0 Branch: None User: iulian07 Date: 2014-03-12 19:45:44 Summary: commit 6138 didn't make it on bitbucket move partest from TESTS partest is a test that should be launched in parallel, but not by make check move it from TESTS variable to check_PROGRAMS variable it will be compiled by make check, but not run Affected #: 1 file https://bitbucket.org/fathomteam/cgm/commits/46d8245dec6e/ Changeset: 46d8245dec6e Branch: master User: iulian07 Date: 2014-03-12 19:46:40 Summary: remove cgm.make from repo this is a build specific file Affected #: 1 file Repository URL: https://bitbucket.org/fathomteam/cgm/ -- This is a commit notification from bitbucket.org. You are receiving this because you have the service enabled, addressing the recipient of this email.
participants (1)
Bitbucket
