Re: [cgma-dev] Link error building parallel CGM with OCC
I think using the 2 --enable options together does it; when I do that in my out of source builds, I see a problem with unresolved externs too, though they're from the OCC libraries. - tim On 10/08/2010 04:22 PM, Robert Smith wrote:
Yes, this is an in source build. Also, I'm using --enable-shared and --enable-static to get both types of libraries out of the build. I'm not sure if that's a contributing factor.
--Bob On Oct 8, 2010, at 4:15 PM, Tim Tautges wrote:
I don't see this problem in parallel either. I've (double/triple/quadruple) checked I don't have any local mods. Can you try an autoreconf? Also, these are all out of source builds, is the one you're doing an in source build?
- tim
On 10/08/2010 04:09 PM, Tim Tautges wrote:
I don't see this problem, in serial at least (will try building in parallel next).
- tim
On 10/08/2010 03:43 PM, Robert Smith wrote:
You're right it isn't explicitly in the link line.
It's defined as follows in the Makefile:
libiGeom_la_LIBADD = $(top_builddir)/libcgm.la
--Bob
On Oct 8, 2010, at 3:06 PM, [email protected] wrote:
It looks your link doesn't have "libcgm" in the link library list after "libiGeom", but I don't know why. Can you tell me how your "libiGeom_la_LIBADD" in itaps directory is defined?
Hong-Jun
----- "Robert Smith" <[email protected]> wrote:
Has anyone encountered a problem building a parallel version of CGM with OCC (the patched version)? This is built on the new Ubuntu 10 release installed on the ANL compute servers (thrash specifically). It is using MPI compiled with
GCC 4.4.3.
The issue comes during make check. It first appears in the src/itaps
directory when building chaman. But it occurs in all 3 link steps taken in that directory.
The log lines for the compile and link are below.
make[3]: Entering directory `/nfs/fathom/libs/cgm/cgm-4.0.1/parallel/
src/itaps' make chaman testgeom_occ partest make[4]: Entering directory `/nfs/fathom/libs/cgm/cgm-4.0.1/parallel/
src/itaps' /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx - DHAVE_CONFIG_H -I. -I.. -I../geom/parallel - DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC - DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -DSRCDIR=. -I../util - I../geom -I../init -I../geom/parallel -DUSE_MPI -Wall -pipe - pedantic -O2 -DNDEBUG -MT chaman.o -MD -MP -MF .deps/chaman.Tpo -c -o
chaman.o chaman.cc mv -f .deps/chaman.Tpo .deps/chaman.Po /bin/sh ../libtool --tag=CXX --mode=link /home/fathom/3rdparty/ mpich2/mpich2-1.2.1/gcc/bin/mpicxx -Wall -pipe -pedantic -O2 - DNDEBUG -L/home/fathom/3rdparty/occ/OpenCASCADE6.3.0/gcc/lib -o chaman chaman.o libiGeom.la -lm libtool: link: /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/ mpicxx -Wall -pipe -pedantic -O2 -DNDEBUG -o .libs/chaman chaman.o -L/ home/fathom/3rdparty/occ/OpenCASCADE6.3.0/gcc/lib ./.libs/libiGeom.so - lm -Wl,-rpath -Wl,/home/fathom/libs/cgm/cgm-4.0.1/parallel/gcc_optocc/
lib ./.libs/libiGeom.so: undefined reference to `CGMReadParallel::CGMReadParallel(GeometryQueryTool*, CGMParallelComm*)' ./.libs/libiGeom.so: undefined reference to `CGMReadParallel::load_file(char const*, char const*, char const*, int
const*, int)' collect2: ld returned 1 exit status make[4]: *** [chaman] Error 1
I've looked at .libs/libiGeom.so. It does have undefined references to
the above routines. But it also has a dependency on the libcgm.so.0
shared library that exists in the main CGM source directory (in .libs). And that shared library has definitions for the routines.
--Bob
-- ================================================================ "You will keep in perfect peace him whose mind is steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory ([email protected]) (telecommuting from UW-Madison) phone: (608) 263-8485 1500 Engineering Dr. fax: (608) 263-4499 Madison, WI 53706
-- ================================================================ "You will keep in perfect peace him whose mind is steadfast, because he trusts in you." Isaiah 26:3 Tim Tautges Argonne National Laboratory ([email protected]) (telecommuting from UW-Madison) phone: (608) 263-8485 1500 Engineering Dr. fax: (608) 263-4499 Madison, WI 53706
participants (1)
Tim Tautges
