CGM make check failure help
Howdy, I'm a graduate researcher at the INL working for the Center for Space Nuclear Research. I'm trying to install the reactor geometry generation dependencies which needs meshkit which needs cgm and I'm running into some trouble I was hoping you could help me with. I'm trying to build CGM with cubit on Linux 14.04 LTS and get errors when I make check my installation: .so ../.libs/libcgm.so -lm -Wl,-rpath -Wl,/home/patevk/lib/serial/cgm/lib -Wl,-rpath -Wl,/home/patevk/opt/Cubit-14.1-Lin64/bin ./.libs/libiGeom.so: undefined reference to `GeometryQueryTool::translate(Body*, CubitVector const&, bool, bool)' ./.libs/libiGeom.so: undefined reference to `GeometryQueryTool::rotate(BasicTopologyEntity*, CubitVector const&, double, bool, bool)' ./.libs/libiGeom.so: undefined reference to `CubitMessage::print_error(char const*, ...)' ./.libs/libiGeom.so: undefined reference to `GeometryQueryTool::translate(BasicTopologyEntity*, CubitVector const&, bool, bool)' ./.libs/libiGeom.so: undefined reference to `GeometryQueryTool::reflect(DLIList<Body*>, CubitVector const&, CubitVector const&, bool)' ./.libs/libiGeom.so: undefined reference to `CubitString::operator==(char const*) const' ./.libs/libiGeom.so: undefined reference to `GeometryQueryTool::reflect(BasicTopologyEntity*, CubitVector const&, CubitVector const&, bool, bool)' ./.libs/libiGeom.so: undefined reference to `GeometryQueryTool::rotate(Body*, CubitVector const&, double, bool, bool)' It seems my cubit path is being referenced fine and it also exists in my LD_LIBRARY_PATH. I'm using the CGMA-14.1 pre package, and I've tried the nightly build as well as 13.1 with the same errors occurring. I am configuring with: ./configure --enable-shared --prefix=/home/patevk/lib/serial/cgm --with-cubit=/home/patevk/opt/Cubit-14.1-Lin64 --enable-debug I've also tried installing CGM on my OSX machine but can't get Cubit libraries to link. Any help would be wonderful. Thanks, Vishal Patel Graduate Researcher Nuclear Engineering Texas A&M University
participants (1)
Vishal Patel
