Author: janehu Date: 2013-11-22 11:55:45 -0600 (Fri, 22 Nov 2013) New Revision: 6100 Modified: cgm/tags/13.1.1/Makefile.am cgm/tags/13.1.1/geom/GeometryQueryTool.cpp cgm/tags/13.1.1/geom/GeometryQueryTool.hpp Log: Changed the cgm version info into a separate header file, removed it from GeometryQueryTool. Passed occshared and cubitshared distcheck. Modified: cgm/tags/13.1.1/Makefile.am =================================================================== --- cgm/tags/13.1.1/Makefile.am 2013-11-22 17:01:57 UTC (rev 6099) +++ cgm/tags/13.1.1/Makefile.am 2013-11-22 17:55:45 UTC (rev 6100) @@ -11,6 +11,7 @@ lib_LTLIBRARIES = libcgm.la +libcgm_la_includedir = $(includedir) if ENABLE_igeom igeom_DIR = itaps else @@ -55,6 +56,7 @@ libcgm_la_SOURCES = +libcgm_la_include_HEADERS = cgm_version.h # By default, cmg.make will define these to $(srcdir). We # want to override that during the INSTALL of the file so # that the correct values are set (e.g. if someone does Modified: cgm/tags/13.1.1/geom/GeometryQueryTool.cpp =================================================================== --- cgm/tags/13.1.1/geom/GeometryQueryTool.cpp 2013-11-22 17:01:57 UTC (rev 6099) +++ cgm/tags/13.1.1/geom/GeometryQueryTool.cpp 2013-11-22 17:55:45 UTC (rev 6100) @@ -92,9 +92,6 @@ DLIList<int> GeometryQueryTool::uidsOfImportingEnts; int GeometryQueryTool::entitiesMergedAway = 0; -const int GeometryQueryTool::CGM_MAJOR_VERSION = 13; -const int GeometryQueryTool::CGM_MINOR_VERSION = 1; - #ifndef CAT // Keep checking bounding box and use internal surf check for Sandia CubitBoolean GeometryQueryTool::bboxMergeTest = CUBIT_TRUE; Modified: cgm/tags/13.1.1/geom/GeometryQueryTool.hpp =================================================================== --- cgm/tags/13.1.1/geom/GeometryQueryTool.hpp 2013-11-22 17:01:57 UTC (rev 6099) +++ cgm/tags/13.1.1/geom/GeometryQueryTool.hpp 2013-11-22 17:55:45 UTC (rev 6100) @@ -1114,9 +1114,6 @@ int maxPersistentRefEdgeId; int maxPersistentRefVertexId; - static const int CGM_MAJOR_VERSION; - static const int CGM_MINOR_VERSION; - CGMHistory mHistory; };
participants (1)
janehu@mcs.anl.gov
