Making check in compat make[1]: Entering directory `/home/jason/cgm/test/cubit/compat' make[1]: Nothing to be done for `check'. make[1]: Leaving directory `/home/jason/cgm/test/cubit/compat' Making check in util make[1]: Entering directory `/home/jason/cgm/test/cubit/util' make[1]: Nothing to be done for `check'. make[1]: Leaving directory `/home/jason/cgm/test/cubit/util' Making check in geom make[1]: Entering directory `/home/jason/cgm/test/cubit/geom' Making check in . make[2]: Entering directory `/home/jason/cgm/test/cubit/geom' make[2]: Nothing to be done for `check-am'. make[2]: Leaving directory `/home/jason/cgm/test/cubit/geom' Making check in Cholla make[2]: Entering directory `/home/jason/cgm/test/cubit/geom/Cholla' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/cubit/geom/Cholla' Making check in facetbool make[2]: Entering directory `/home/jason/cgm/test/cubit/geom/facetbool' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/cubit/geom/facetbool' Making check in facet make[2]: Entering directory `/home/jason/cgm/test/cubit/geom/facet' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/cubit/geom/facet' Making check in virtual make[2]: Entering directory `/home/jason/cgm/test/cubit/geom/virtual' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/cubit/geom/virtual' make[1]: Leaving directory `/home/jason/cgm/test/cubit/geom' Making check in init make[1]: Entering directory `/home/jason/cgm/test/cubit/init' make[1]: Nothing to be done for `check'. make[1]: Leaving directory `/home/jason/cgm/test/cubit/init' Making check in . make[1]: Entering directory `/home/jason/cgm/test/cubit' make[1]: Leaving directory `/home/jason/cgm/test/cubit' Making check in itaps make[1]: Entering directory `/home/jason/cgm/test/cubit/itaps' make check-recursive make[2]: Entering directory `/home/jason/cgm/test/cubit/itaps' Making check in . make[3]: Entering directory `/home/jason/cgm/test/cubit/itaps' make chaman testgeom make[4]: Entering directory `/home/jason/cgm/test/cubit/itaps' make[4]: `testgeom' is up to date. make[4]: Leaving directory `/home/jason/cgm/test/cubit/itaps' make check-TESTS make[4]: Entering directory `/home/jason/cgm/test/cubit/itaps' Using default input file: ../../trunk/itaps/testgeom.sat ITAPS GEOMETRY INTERFACE TEST PROGRAM: gLoad: Read 1 ACIS Entities from the input file Constructed 1 Volume: 1 Model contents: vertices: 36 edges: 60 faces: 33 regions: 1 Success tags: Tags defined on model: GLOBAL_ID, NAME Success gentity sets: Success topology adjacencies: Success construct: Created swept volume 3 Success primitives: Success transforms: Success booleans: Updated volume(s): 10 Destroyed volume(s): 11 Updated volume(s): 12 Updated volume(s): 12 Destroyed volume(s): 13 Success mesh size: Read 1 ACIS Entities from the input file ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. Constructed 1 Volume: 1 Success shutdown: Success TSTT TEST SUMMARY: Number Tests: 10 Number Successful: 10 Number Not Implemented: 0 Number Failed: 0 PASS: testgeom ================== All 1 tests passed ================== make[4]: Leaving directory `/home/jason/cgm/test/cubit/itaps' make[3]: Leaving directory `/home/jason/cgm/test/cubit/itaps' make[2]: Leaving directory `/home/jason/cgm/test/cubit/itaps' make[1]: Leaving directory `/home/jason/cgm/test/cubit/itaps' Making check in test make[1]: Entering directory `/home/jason/cgm/test/cubit/test' make sheet brick webcut make[2]: Entering directory `/home/jason/cgm/test/cubit/test' make[2]: `sheet' is up to date. c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -DCUBIT_CGM -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/init -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -DSRCDIR=../../trunk/test -DHAVE_ACIS -Wall -pipe -pedantic -g -MT brick.o -MD -MP -MF .deps/brick.Tpo -c -o brick.o ../../trunk/test/brick.cpp In file included from ../../trunk/test/brick.cpp:17: ../../trunk/geom/ACIS/AcisQueryEngine.hpp: In static member function ‘static AcisQueryEngine* AcisQueryEngine::instance()’: ../../trunk/geom/ACIS/AcisQueryEngine.hpp:157: error: cannot allocate an object of abstract type ‘AcisQueryEngine’ ../../trunk/geom/ACIS/AcisQueryEngine.hpp:117: note: because the following virtual functions are pure within ‘AcisQueryEngine’: ../../trunk/geom/GeometryQueryEngine.hpp:57: note: virtual CubitStatus GeometryQueryEngine::export_solid_model(DLIList<TopologyBridge*>&, char*&, int&, bool) ../../trunk/geom/GeometryQueryEngine.hpp:114: note: virtual CubitStatus GeometryQueryEngine::import_solid_model(DLIList<TopologyBridge*>&, const char*, int) make[2]: *** [brick.o] Error 1 make[2]: Leaving directory `/home/jason/cgm/test/cubit/test' make[1]: *** [check-am] Error 2 make[1]: Leaving directory `/home/jason/cgm/test/cubit/test' make: *** [check-recursive] Error 1
participants (1)
Nightly Test
