Author: kraftche Date: 2008-01-18 14:09:56 -0600 (Fri, 18 Jan 2008) New Revision: 1544 Modified: cgm/trunk/configure.in Log: Fix strange configure stuff: OCC requires some configure defines about standard headers (HAVE_IOSTREAM, HAVE_IOSTREAM_H, etc.) Previous code defined these depending on wether or not the platform is 64-bit. That doesn't make any sense to me, so I'm adding proper checks for these headers. Modified: cgm/trunk/configure.in =================================================================== --- cgm/trunk/configure.in 2008-01-18 19:53:39 UTC (rev 1543) +++ cgm/trunk/configure.in 2008-01-18 20:09:56 UTC (rev 1544) @@ -272,9 +272,19 @@ # Check if 64-bit AC_MSG_CHECKING([if platform is 64-bit (-D_OCC64)]) AC_TRY_COMPILE([],[int array[6-(int)sizeof(void*)];],[AC_MSG_RESULT(no)], - [AC_MSG_RESULT(yes); OCC_INC_FLAG="$OCC_INC_FLAG -D_OCC64 -DHAVE_IOSTREAM_H -DHAVE_LIMITS_H"]) + [AC_MSG_RESULT(yes); OCC_INC_FLAG="$OCC_INC_FLAG -D_OCC64"]) - # Check if OCC has Stadard_Version.hxx + # OCC requires some defines + AC_LANG_PUSH(C++) + AC_CHECK_HEADER([iostream],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_IOSTREAM"]) + AC_CHECK_HEADER([iostream.h],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_IOSTREAM_H"]) + AC_CHECK_HEADER([iomanip],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_IOMANIP"]) + AC_CHECK_HEADER([iomanip.h],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_IOMANIP_H"]) + AC_CHECK_HEADER([fstream],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_FSTREAM"]) + AC_CHECK_HEADER([fstream.h],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_FSTREAM_H"]) + AC_CHECK_HEADER([limits.h],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_LIMITS_H"]) + + # Check for CCC headers Stadard_Version.hxx AC_CHECK_HEADER( [Standard_Version.hxx], [], [AC_MSG_ERROR([OpenCascade config error:Standard_Version.hxx not found])] ) @@ -283,6 +293,7 @@ AC_CHECK_LIB( [TKernel], [create_mailbox],, [AC_MSG_ERROR([OpenCascade config error: libTKernel not found ])]) LIBS="$old_LIBS" + AC_LANG_POP(C++) # Restore original values of variables CPPFLAGS="$old_CPPFLAGS"
participants (1)
kraftche@mcs.anl.gov
