Author: janehu Date: 2011-07-12 12:32:07 -0500 (Tue, 12 Jul 2011) New Revision: 5053 Modified: cgm/trunk/geom/OCC/OCCAttribSet.cpp cgm/trunk/geom/OCC/OCCAttribSet.hpp cgm/trunk/geom/OCC/OCCBody.cpp cgm/trunk/geom/OCC/OCCCurve.cpp cgm/trunk/geom/OCC/OCCDrawTool.cpp cgm/trunk/geom/OCC/OCCLoop.cpp cgm/trunk/geom/OCC/OCCLump.cpp cgm/trunk/geom/OCC/OCCModifyEngine.cpp cgm/trunk/geom/OCC/OCCPoint.hpp cgm/trunk/geom/OCC/OCCQueryEngine.cpp cgm/trunk/geom/OCC/OCCQueryEngine.hpp cgm/trunk/geom/OCC/OCCShapeAttributeSet.cpp cgm/trunk/geom/OCC/OCCShapeAttributeSet.hpp cgm/trunk/geom/OCC/OCCShell.cpp cgm/trunk/geom/OCC/OCCSurface.cpp Log: Added a map of an OCC shape and its attribute label structure to improved read and write speed, and related suporting changes. passed all testcases under cgm make check. Modified: cgm/trunk/geom/OCC/OCCAttribSet.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCAttribSet.cpp 2011-07-12 16:55:15 UTC (rev 5052) +++ cgm/trunk/geom/OCC/OCCAttribSet.cpp 2011-07-12 17:32:07 UTC (rev 5053) @@ -28,6 +28,8 @@ #include "TDataXtd_Shape.hxx" #endif +#include "TDF_Label.hxx" +#include "TopTools_DataMapOfShapeInteger.hxx" #include "TCollection_ExtendedString.hxx" #include "Handle_TDataStd_Name.hxx" #include "Handle_TDataStd_ExtStringArray.hxx" @@ -40,26 +42,23 @@ #include "TopoDS_Shape.hxx" #include "TDF_ChildIterator.hxx" #include <vector> +typedef std::map<int, TDF_Label>::value_type labType; void OCCAttribSet::FindShape(TopoDS_Shape& shape, TDF_Label& aLabel, CubitBoolean& found) { - for (TDF_ChildIterator it1(OCCQueryEngine::instance()->mainLabel, CUBIT_FALSE); - it1.More(); it1.Next()) + found = CUBIT_FALSE; + if(!OCCQueryEngine::instance()->OCCMap->IsBound(shape)) + return; + + int k = OCCQueryEngine::instance()->OCCMap->Find(shape); + std::map<int, TDF_Label>::iterator it = + OCCQueryEngine::instance()->Shape_Label_Map->find(k); + if(it != OCCQueryEngine::instance()->Shape_Label_Map->end()) { - //find the same shape attribute first - aLabel = it1.Value(); - - Handle_TDataXtd_Shape attr_shape; - TopoDS_Shape old_shape; - if(aLabel.FindAttribute(TDataXtd_Shape::GetID(), attr_shape)) - old_shape = attr_shape->Get(aLabel); - if(old_shape.IsPartner(shape)) - { - found = CUBIT_TRUE; - break; - } + aLabel = (*it).second; + found = CUBIT_TRUE; } }
participants (1)
jiangtao_ma@yahoo.com
