Author: janehu Date: 2008-12-11 15:18:43 -0600 (Thu, 11 Dec 2008) New Revision: 2481 Modified: cgm/trunk/geom/OCC/OCCBody.cpp cgm/trunk/geom/OCC/OCCCurve.cpp cgm/trunk/geom/OCC/OCCLoop.cpp cgm/trunk/geom/OCC/OCCLump.cpp cgm/trunk/geom/OCC/OCCPoint.cpp cgm/trunk/geom/OCC/OCCQueryEngine.cpp cgm/trunk/geom/OCC/OCCShell.cpp cgm/trunk/geom/OCC/OCCSurface.cpp Log: Partially fix for the coedge problem for subtraction, still has test case failure/crash. Modified: cgm/trunk/geom/OCC/OCCBody.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCBody.cpp 2008-12-11 00:55:42 UTC (rev 2480) +++ cgm/trunk/geom/OCC/OCCBody.cpp 2008-12-11 21:18:43 UTC (rev 2481) @@ -85,6 +85,9 @@ void OCCBody::set_TopoDS_Shape( TopoDS_CompSolid theshape) { + if(theshape.IsEqual(*myTopoDSShape)) + return; + TopoDS_CompSolid * the_comp = new TopoDS_CompSolid(theshape); if(myTopoDSShape) delete myTopoDSShape; Modified: cgm/trunk/geom/OCC/OCCCurve.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCCurve.cpp 2008-12-11 00:55:42 UTC (rev 2480) +++ cgm/trunk/geom/OCC/OCCCurve.cpp 2008-12-11 21:18:43 UTC (rev 2481) @@ -116,6 +116,9 @@ void OCCCurve::set_TopoDS_Edge(TopoDS_Edge edge) { + if(edge.IsEqual(*myTopoDSEdge)) + return; + TopoDS_Edge* the_edge = new TopoDS_Edge(edge); if(myTopoDSEdge) delete myTopoDSEdge; Modified: cgm/trunk/geom/OCC/OCCLoop.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCLoop.cpp 2008-12-11 00:55:42 UTC (rev 2480) +++ cgm/trunk/geom/OCC/OCCLoop.cpp 2008-12-11 21:18:43 UTC (rev 2481) @@ -70,15 +70,6 @@ if(loop.IsEqual(*myTopoDSWire)) return; TopoDS_Wire* the_wire = new TopoDS_Wire(loop); - DLIList<OCCCoEdge *> coedges = this->coedges(); - for(int i = 0; i < coedges.size(); i++) - { - OCCCoEdge *coedge = coedges.get_and_step(); - Curve* curve = coedge->curve(); - CAST_TO(curve, OCCCurve)->remove_loop(this); - this->remove_coedge(coedge); - delete coedge; - } if(myTopoDSWire) delete myTopoDSWire; myTopoDSWire = the_wire; Modified: cgm/trunk/geom/OCC/OCCLump.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCLump.cpp 2008-12-11 00:55:42 UTC (rev 2480) +++ cgm/trunk/geom/OCC/OCCLump.cpp 2008-12-11 21:18:43 UTC (rev 2481) @@ -82,6 +82,9 @@ void OCCLump::set_TopoDS_Solid(TopoDS_Solid solid) { + if(solid.IsEqual(*myTopoDSSolid) ) + return; + TopoDS_Solid* the_solid = new TopoDS_Solid(solid); if(myTopoDSSolid) delete myTopoDSSolid ; Modified: cgm/trunk/geom/OCC/OCCPoint.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCPoint.cpp 2008-12-11 00:55:42 UTC (rev 2480) +++ cgm/trunk/geom/OCC/OCCPoint.cpp 2008-12-11 21:18:43 UTC (rev 2481) @@ -86,6 +86,8 @@ void OCCPoint::set_TopoDS_Vertex(TopoDS_Vertex vertex) { + if(vertex.IsEqual(*myTopoDSVertex)) + return; TopoDS_Vertex* the_vertex = new TopoDS_Vertex(vertex); if(myTopoDSVertex) delete myTopoDSVertex; @@ -282,7 +284,7 @@ //update all attributes first. TopTools_ListIteratorOfListOfShape it; it.Initialize(shapes); - for(it; it.More(); it.Next()) + for(; it.More(); it.Next()) { shape = it.Value(); OCCQueryEngine::instance()->copy_attributes(*get_TopoDS_Vertex(),shape); Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-12-11 00:55:42 UTC (rev 2480) +++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-12-11 21:18:43 UTC (rev 2481) @@ -1358,6 +1358,25 @@ } if(!exist) { + DLIList<OCCShell*> shells = occ_surface->shells(); + for(int i = 0; i < shells.size() ; i++) + { + OCCShell* shell = shells.get_and_step(); + TopoDS_Shell* topo_shell = shell->get_TopoDS_Shell(); + if (!OCCMap->IsBound(*topo_shell)) + { + DLIList<OCCCoFace*> coface_list = shell->cofaces(); + for(int j = 0; j < coface_list.size(); j++) + { + OCCCoFace * test_coface = coface_list.get_and_step(); + occ_surface->remove_shell(shell); + shell->remove_coface(test_coface); + delete test_coface; + } + if(!topo_shell->IsNull()) + topo_shell->Nullify(); + } + } OCCCoFace * coface = new OCCCoFace( occ_surface, shell, sense); cofaces_new.append(coface); occ_surface->add_shell(shell); @@ -1490,20 +1509,20 @@ for(int i = 0; i < loops.size() ; i++) { OCCLoop* occ_loop = loops.get_and_step(); - if (!OCCMap->IsBound(*occ_loop->get_TopoDS_Wire())) + TopoDS_Wire* wire = occ_loop->get_TopoDS_Wire(); + if (wire->IsNull() || !OCCMap->IsBound(*wire)) { DLIList<OCCCoEdge*> coedge_list = occ_loop->coedges(); for(int j = 0; j < coedge_list.size(); j++) { OCCCoEdge * test_coedge = coedge_list.get_and_step(); - if (test_coedge->curve() == curve) - { - occ_loop->remove_coedge(test_coedge); - occ_curve->remove_loop(occ_loop); - delete test_coedge; - } + occ_loop->remove_coedge(test_coedge); + occ_curve->remove_loop(occ_loop); + delete test_coedge; } - delete occ_loop; + if(!wire->IsNull()) + wire->Nullify(); + WireList->remove(occ_loop); } } //for the cylinder side face, there are 4 coedges, 2 of them are seam @@ -1520,7 +1539,31 @@ } } - assert(occ_curve->loops().size() <2); + if(occ_curve->loops().size() == 2) + { + //there must be a loop which doesn't have this curve anymore + //this is been found in subtract cases while one solid becomes + //2 solid, and one face becomes two faces. One face uses/updates + //the old face while the other face generates face and wire from + //new. However, in order to uses the curves, the old curve is kept + //as possible, so curve's loops get kept, but since it's going to + //associate with new loop, the old loop should be removed from the + //loop list. + DLIList<OCCLoop*> old_loops = occ_curve->loops(); + for (int i = 0; i < 2; i++) + { + OCCLoop* old_loop = old_loops.get_and_step(); + DLIList<OCCCoEdge*> test_coedges = old_loop->coedges(); + int found = 0; + if(test_coedges.get()->curve() != curve) + test_coedges.step(); + else + found = 1; + if(!found) + occ_curve->remove_loop(old_loop); + } + } + assert(occ_curve->loops().size() < 2); coedge = new OCCCoEdge( curve, loop, sense); coedges_new.append(coedge); occ_curve->add_loop(loop); Modified: cgm/trunk/geom/OCC/OCCShell.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCShell.cpp 2008-12-11 00:55:42 UTC (rev 2480) +++ cgm/trunk/geom/OCC/OCCShell.cpp 2008-12-11 21:18:43 UTC (rev 2481) @@ -82,6 +82,9 @@ void OCCShell::set_TopoDS_Shell(TopoDS_Shell shell) { + if(shell.IsEqual(*myTopoDSShell)) + return; + TopoDS_Shell* the_shell = new TopoDS_Shell(shell); if (myTopoDSShell) delete myTopoDSShell; Modified: cgm/trunk/geom/OCC/OCCSurface.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCSurface.cpp 2008-12-11 00:55:42 UTC (rev 2480) +++ cgm/trunk/geom/OCC/OCCSurface.cpp 2008-12-11 21:18:43 UTC (rev 2481) @@ -99,6 +99,9 @@ void OCCSurface::set_TopoDS_Face(TopoDS_Face& face) { + if(face.IsEqual(*myTopoDSFace)) + return; + TopoDS_Face* face_ptr = new TopoDS_Face(face); if(myTopoDSFace) delete myTopoDSFace; @@ -906,7 +909,11 @@ { TopoDS_Edge edge = Ex.Current(); if(op) + { shapes.Assign(op->Modified(edge)); + if(shapes.Extent() == 0) + shapes.Assign(op->Generated(edge)); + } else if(sp) shapes.Assign(sp->DescendantShapes(edge));
participants (1)
janehu@mcs.anl.gov
