Re: [cgma-dev] CGM failing with OCC6.6.0
Hello, Even after recompiling occ660 on ubuntu 12, I got the same errors The tests to blame are in cgm/master branch: FAIL: merge_facet .. FAIL: merge_occ .. FAIL: r_w .. FAIL: groups_saved_to_OCC They fail in optimized mode, and pass in debug mode They used to work on ubuntu 10 on occ 653, on cgm master, in optimized mode. They fail in optimized mode on ubuntu 12 on occ 653 and on occ 660. We did not test before for occ 660 on master , on ubuntu 10. Iulian ________________________________________ From: [email protected] [[email protected]] on behalf of Grindeanu, Iulian R. [[email protected]] Sent: Friday, April 11, 2014 10:02 AM To: Paul Wilson; CGMA Development Subject: Re: [cgma-dev] CGM failing with OCC6.6.0 Hello, There seems to be another problem with cgm master, uncovered by last night builds On my machine, it works with occ 653, in debug mode, with mpi. If I compile without debug mode, several tests fail; it is the same error on gnep now; To add to the misery, on ubuntu 10.04, there were no errors in optimized mode. (this is previous build, before gnep was upgraded) http://gnep.mcs.anl.gov:8010/builders/cgmtr-occ-par-sta/builds/430/steps/tes... But errors pop up on my machine too, like these pointed by buildbot, last night: http://gnep.mcs.anl.gov:8010/builders/cgmtr-occ-par-sta/builds/431/steps/tes... Jane is on vacation, so I don't know who can figure these out now :( I will try to rebuild occ 653, on gnep. What kind of errors do you see with 660 on cgm master? Iulian ________________________________________ From: [email protected] [[email protected]] on behalf of Grindeanu, Iulian R. [[email protected]] Sent: Thursday, April 10, 2014 1:49 PM To: Paul Wilson; CGMA Development Subject: Re: [cgma-dev] CGM failing with OCC6.6.0 Ouch :( Buildbot was testing only cgm13.1 against occ660. If cgm master fails (I think it is 14.0), it means Jane would have to look at it. Does anybody build cgm master with occ 660? Iulian ________________________________________ From: [email protected] [[email protected]] on behalf of Paul Wilson [[email protected]] Sent: Thursday, April 10, 2014 12:23 PM To: CGMA Development Subject: [cgma-dev] CGM failing with OCC6.6.0 Hello all, I thought I had overcome these problems last month, but I seem to be having new problems. I have successfully built CGM13.1 with OCC 6.6.0, including successful testing with 'make check'. When I use the identical installation of OCC 6.6.0 to build the master CGM branch (14.1?) it fails on 'make check'. I have looked and the patch to OCC 6.6.0 didn't change between CGM13.1 and master. It certainly seems that the code did change. Any tips? Paul -- -- ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ -- Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu Faculty Director, Advanced Computing Infrastructure
participants (1)
