Re: [cgma-dev] error in make check
Thanks, changed my configure line to include --enable-shared. I'm doing this on a 32-bit system: ./configure --prefix=/home/rajeev/FATHOM/lib/CGM --with-cubit=/home/rajeev/cubit-32 --enable-debug --enable-shared I'm getting a seg fault now. It seems to be related to Ubuntu distribution: https://bugs.launchpad.net/ubuntu/+source/pciutils/+bug/690431 rajeev@nix:~/FATHOM/source/CGM/itaps/.libs$ ./testgeom Segmentation fault rajeev@nix:~/FATHOM/source/CGM/itaps/.libs$ gdb testgeom This GDB was configured as "i686-linux-gnu". . Reading symbols from /home/rajeev/FATHOM/source/CGM/itaps/.libs/testgeom...done. (gdb) r Starting program: /home/rajeev/FATHOM/source/CGM/itaps/.libs/testgeom [Thread debugging using libthread_db enabled] Program received signal SIGSEGV, Segmentation fault. __memcpy_ssse3 () at ../sysdeps/i386/i686/multiarch/memcpy-ssse3.S:1279 1279 ../sysdeps/i386/i686/multiarch/memcpy-ssse3.S: No such file or directory. in ../sysdeps/i386/i686/multiarch/memcpy-ssse3.S (gdb) Rajeev ________________________________ From: Steve Jackson <[email protected]> To: Rajeev Jain <[email protected]> Cc: Developer information for cgma <[email protected]> Sent: Friday, December 17, 2010 10:31:41 Subject: Re: [cgma-dev] error in make check If you're building against 32-bit CUBIT on a 64-bit machine, you probably need to add "--enable-32bit" to your CGM configure line. ~S On Dec 16, 2010, at 18:56 , Rajeev Jain wrote:
I'm trying to build a serial, static version of CGM. autoreconf, ./configure and make goes well, but, make check fails with the following error, looking for /libcubit_geom.so. I'm attaching my config.log file. My config options are:
rajeev@nix:~/FATHOM/source/CGM/itaps$ make testgeom
/bin/bash ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -g -R/home/rajeev/cubit-32/bin -L/home/rajeev/cubit-32/bin -o testgeom testgeom.o libiGeom.la -lm libtool: link: g++ -Wall -pipe -pedantic -g -o testgeom testgeom.o -L/home/rajeev/cubit-32/bin ./.libs/libiGeom.a /home/rajeev/FATHOM/source/CGM/.libs/libcgm.a -lcubiti19 -lm -Wl,-rpath -Wl,/home/rajeev/cubit-32/bin ./.libs/libiGeom.a(iGeom_CGMA.o): In function `iGeom_load_cub_geometry': /home/rajeev/FATHOM/source/CGM/itaps/iGeom_CGMA.cc:6260: warning: the use of `tmpnam' is dangerous, better use `mkstemp'
/usr/bin/ld.bfd.real: ./.libs/libiGeom.a(iGeom_CGMA.o): undefined reference to symbol 'MergeTool::merge_volumes(DLIList<RefVolume*>&, bool)' /usr/bin/ld.bfd.real: note: 'MergeTool::merge_volumes(DLIList<RefVolume*>&, bool)' is defined in DSO /home/rajeev/cubit-32/bin/libcubit_geom.so so try adding it to the linker command line /home/rajeev/cubit-32/bin/libcubit_geom.so: could not read symbols: Invalid operation collect2: ld returned 1 exit status make: *** [testgeom] Error 1
rajeev@nix:~/FATHOM/source/CGM/itaps$ ls -l .libs/
total 1420 -rw-r--r-- 1 rajeev rajeev 1444022 2010-12-16 18:10 libiGeom.a lrwxrwxrwx 1 rajeev rajeev 14 2010-12-16 18:10 libiGeom.la -> ../libiGeom.la -rw-r--r-- 1 rajeev rajeev 1020 2010-12-16 18:10 libiGeom.lai
Tried explicitly adding the linker by using "LDFLAGS=-L/home/rajeev/cubit-32/bin LIBS=-lcubit_geom" in the config line, it doesn't work.
Rajeev
Send to CGMA announce instead of dev.
participants (1)
Rajeev Jain
