buildbot failure in Fathom on cgm-occ
The Fathomatic has detected a failed build of cgm-occ on Fathom. Full details are available at: http://gnep.mcs.anl.gov:8010/builders/cgm-occ/builds/268 Buildbot URL: http://gnep.mcs.anl.gov:8010/ Buildslave for this Build: gnep Build Reason: The Nightly scheduler named 'nightly' triggered this build Build Source Stamp: None Blamelist: BUILD FAILED: failed compile LOG EXCERPT: OCCBody.cpp: In member function 'virtual void OCCBody::append_simple_attribute_virt(CubitSimpleAttrib*)': OCCBody.cpp:193: warning: statement has no effect mv -f .deps/OCCBody.Tpo .deps/OCCBody.Plo /bin/sh ../../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCCoEdge.lo -MD -MP -MF .deps/OCCCoEdge.Tpo -c -o OCCCoEdge.lo OCCCoEdge.cpp g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCCoEdge.lo -MD -MP -MF .deps/OCCCoEdge.Tpo -c OCCCoEdge.cpp -o OCCCoEdge.o mv -f .deps/OCCCoEdge.Tpo .deps/OCCCoEdge.Plo /bin/sh ../../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCCoFace.lo -MD -MP -MF .deps/OCCCoFace.Tpo -c -o OCCCoFace.lo OCCCoFace.cpp g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCCoFace.lo -MD -MP -MF .deps/OCCCoFace.Tpo -c OCCCoFace.cpp -o OCCCoFace.o mv -f .deps/OCCCoFace.Tpo .deps/OCCCoFace.Plo /bin/sh ../../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCCurve.lo -MD -MP -MF .deps/OCCCurve.Tpo -c -o OCCCurve.lo OCCCurve.cpp g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCCurve.lo -MD -MP -MF .deps/OCCCurve.Tpo -c OCCCurve.cpp -o OCCCurve.o OCCCurve.cpp: In member function 'void OCCCurve::adjust_periodic_parameter(double&)': OCCCurve.cpp:877: warning: unused variable 'edge_range' OCCCurve.cpp: In member function 'virtual CubitStatus OCCCurve::closest_point(const CubitVector&, CubitVector&, CubitVector*, CubitVector*, double*)': OCCCurve.cpp:437: warning: 'pparam' may be used uninitialized in this function mv -f .deps/OCCCurve.Tpo .deps/OCCCurve.Plo /bin/sh ../../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCLoop.lo -MD -MP -MF .deps/OCCLoop.Tpo -c -o OCCLoop.lo OCCLoop.cpp g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCLoop.lo -MD -MP -MF .deps/OCCLoop.Tpo -c OCCLoop.cpp -o OCCLoop.o mv -f .deps/OCCLoop.Tpo .deps/OCCLoop.Plo /bin/sh ../../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCLump.lo -MD -MP -MF .deps/OCCLump.Tpo -c -o OCCLump.lo OCCLump.cpp g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCLump.lo -MD -MP -MF .deps/OCCLump.Tpo -c OCCLump.cpp -o OCCLump.o mv -f .deps/OCCLump.Tpo .deps/OCCLump.Plo /bin/sh ../../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCModifyEngine.lo -MD -MP -MF .deps/OCCModifyEngine.Tpo -c -o OCCModifyEngine.lo OCCModifyEngine.cpp g++ -DHAVE_CONFIG_H -I. -I../.. -I../../geom/parallel -I../../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util -I../../geom -I/home/sharp/3rdparty/OCC/OpenCASCADE6.3.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOSTREAM_H -DHAVE_IOMANIP -DHAVE_IOMANIP_H -DHAVE_FSTREAM -DHAVE_FSTREAM_H -DHAVE_LIMITS_H -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCModifyEngine.lo -MD -MP -MF .deps/OCCModifyEngine.Tpo -c OCCModifyEngine.cpp -o OCCModifyEngine.o OCCModifyEngine.cpp: In member function 'virtual CubitStatus OCCModifyEngine::imprint(DLIList<BodySM*>&, DLIList<BodySM*>&, bool, DLIList<TopologyBridge*>*, DLIList<TopologyBridge*>*) const': OCCModifyEngine.cpp:2970: warning: unused variable 'volume' OCCModifyEngine.cpp: In member function 'virtual CubitStatus OCCModifyEngine::intersect(BodySM*, DLIList<BodySM*>&, DLIList<BodySM*>&, bool) const': OCCModifyEngine.cpp:3656: warning: unused variable 'from_body' OCCModifyEngine.cpp: In member function 'virtual CubitStatus OCCModifyEngine::tweak_move(DLIList<Surface*>&, const CubitVector&, DLIList<BodySM*>&, CubitBoolean, CubitBoolean) const': OCCModifyEngine.cpp:7155: warning: suggest parentheses around assignment used as truth value OCCModifyEngine.cpp: In member function 'virtual CubitStatus OCCModifyEngine::tweak_move(DLIList<Curve*>&, const CubitVector&, DLIList<BodySM*>&, CubitBoolean, CubitBoolean) const': OCCModifyEngine.cpp:7270: warning: suggest parentheses around assignment used as truth value OCCModifyEngine.cpp: In member function 'CubitStatus OCCModifyEngine::sort_curves(DLIList<Curve*>, DLIList<DLIList<TopoDS_Edge*>*>&) const': OCCModifyEngine.cpp:802: warning: 'new_end' may be used uninitialized in this function OCCModifyEngine.cpp: In member function 'virtual CubitStatus OCCModifyEngine::webcut(DLIList<BodySM*>&, const BodySM*, DLIList<BodySM*>&, bool) const': OCCModifyEngine.cpp:4844: warning: 'body' is used uninitialized in this function OCCModifyEngine.cpp: In member function 'virtual CubitStatus OCCModifyEngine::sweep_along_curve(DLIList<GeometryEntity*>&, DLIList<BodySM*>&, DLIList<Curve*>&, double, int, bool, Surface*, BodySM*) const': OCCModifyEngine.cpp:4685: warning: 'type' may be used uninitialized in this function OCCModifyEngine.cpp: In member function 'virtual CubitStatus OCCModifyEngine::sweep_translational(DLIList<GeometryEntity*>&, DLIList<BodySM*>&, const CubitVector&, double, int, bool, bool, Surface*, BodySM*) const': OCCModifyEngine.cpp:4226: warning: 'Cornertype' may be used uninitialized in this function {standard input}: Assembler messages: {standard input}:40151: Warning: end of file not at end of a line; newline inserted {standard input}:40432: Error: undefined symbol `.LLSDACSE8534' in operation {standard input}:40483: Error: invalid sections for operation on `.LEHE1494' and `.LEHB1' g++: Internal error: Killed (program cc1plus) Please submit a full bug report. See <URL:http://gcc.gnu.org/bugs.html> for instructions. For Debian GNU/Linux specific bug reporting instructions, see <URL:file:///usr/share/doc/gcc-4.2/README.Bugs>. sincerely, -The Fathomatic
participants (1)
cgma-dev@lists.mcs.anl.gov
