/bin/sh ./config.status --recheck running CONFIG_SHELL=/bin/sh /bin/sh ../trunk/configure --enable-debug --enable-release --enable-32bit --with-occ=/opt/OpenCascade6.3-32bit --no-create --no-recursion checking build system type... x86_64-unknown-linux-gnu checking host system type... x86_64-unknown-linux-gnu checking target system type... x86_64-unknown-linux-gnu checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... /bin/mkdir -p checking for gawk... gawk checking whether make sets $(MAKE)... yes checking for style of include used by make... GNU checking for cc... cc checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether cc accepts -g... yes checking for cc option to accept ISO C89... none needed checking dependency style of cc... gcc3 checking how to run the C preprocessor... cc -E checking for CC... no checking for aCC... no checking for cxx... no checking for xlC_r... no checking for xlC... no checking for c++... c++ checking whether we are using the GNU C++ compiler... yes checking whether c++ accepts -g... yes checking dependency style of c++... gcc3 checking how to run the C++ preprocessor... c++ -E checking for gfortran... gfortran checking whether we are using the GNU Fortran compiler... yes checking whether gfortran accepts -g... yes checking for gfortran... gfortran checking whether we are using the GNU Fortran 77 compiler... yes checking whether gfortran accepts -g... yes checking for known C compilers... GNU checking for known compiler/OS combinations... GNU:x86_64 checking for known c++ compilers... GNU checking for known compiler/OS combinations... GNU:x86_64 checking whether we are using the GNU Fortran compiler... (cached) yes checking whether gfortran accepts -g... (cached) yes checking for a sed that does not truncate output... /bin/sed checking for grep that handles long lines and -e... /bin/grep checking for egrep... /bin/grep -E checking for ld used by cc... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for /usr/bin/ld option to reload object files... -r checking for BSD-compatible nm... /usr/bin/nm -B checking whether ln -s works... yes checking how to recognize dependent libraries... pass_all checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking dlfcn.h usability... yes checking dlfcn.h presence... yes checking for dlfcn.h... yes checking how to run the C++ preprocessor... c++ -E checking the maximum length of command line arguments... 98304 checking command to parse /usr/bin/nm -B output from cc object... ok checking for objdir... .libs checking for ar... ar checking for ranlib... ranlib checking for strip... strip checking if cc supports -fno-rtti -fno-exceptions... no checking for cc option to produce PIC... -fPIC checking if cc PIC flag -fPIC works... yes checking if cc static flag -static works... yes checking if cc supports -c -o file.o... yes checking whether the cc linker (/usr/bin/ld -m elf_i386) supports shared libraries... yes checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes checking if libtool supports shared libraries... yes checking whether to build shared libraries... no checking whether to build static libraries... yes configure: creating libtool appending configuration tag "CXX" to libtool checking for ld used by c++... /usr/bin/ld -m elf_i386 checking if the linker (/usr/bin/ld -m elf_i386) is GNU ld... yes checking whether the c++ linker (/usr/bin/ld -m elf_i386) supports shared libraries... yes checking for c++ option to produce PIC... -fPIC checking if c++ PIC flag -fPIC works... yes checking if c++ static flag -static works... yes checking if c++ supports -c -o file.o... yes checking whether the c++ linker (/usr/bin/ld -m elf_i386) supports shared libraries... yes checking dynamic linker characteristics... GNU/Linux ld.so (cached) (cached) checking how to hardcode library paths into programs... immediate appending configuration tag "F77" to libtool checking if libtool supports shared libraries... yes checking whether to build shared libraries... no checking whether to build static libraries... yes checking for gfortran option to produce PIC... -fPIC checking if gfortran PIC flag -fPIC works... yes checking if gfortran static flag -static works... yes checking if gfortran supports -c -o file.o... yes checking whether the gfortran linker (/usr/bin/ld -m elf_i386) supports shared libraries... yes checking dynamic linker characteristics... GNU/Linux ld.so (cached) (cached) checking how to hardcode library paths into programs... immediate checking whether byte ordering is bigendian... no checking how to get verbose linking output from gfortran... -v checking for Fortran libraries of gfortran... -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2 -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2/../../.. -lgfortranbegin -lgfortran -lm checking for dummy main to link with Fortran libraries... none checking for Fortran name-mangling scheme... unknown configure: WARNING: unknown Fortran name-mangling scheme checking for C++-standard library in std:: namespace... yes checking for C++-standard I/O in std:: namespace... yes checking if C++ template definitions should be included... yes checking for 'include' subdir of /opt/OpenCascade6.3-32bit... inc checking for 'lib' subdir of /opt/OpenCascade6.3-32bit... lib checking if platform is 64-bit (-D_OCC64)... no checking iostream usability... yes checking iostream presence... yes checking for iostream... yes checking iostream.h usability... no checking iostream.h presence... no checking for iostream.h... no checking iomanip usability... yes checking iomanip presence... yes checking for iomanip... yes checking iomanip.h usability... no checking iomanip.h presence... no checking for iomanip.h... no checking fstream usability... yes checking fstream presence... yes checking for fstream... yes checking fstream.h usability... no checking fstream.h presence... no checking for fstream.h... no checking limits.h usability... yes checking limits.h presence... yes checking for limits.h... yes checking Standard_Version.hxx usability... yes checking Standard_Version.hxx presence... yes checking for Standard_Version.hxx... yes checking for create_mailbox in -lTKernel... no checking for create_mailbox in -lTKernel... yes CXXFLAGS = -Wall -pipe -pedantic -g -m32 configure: creating ./config.status /bin/sh ./config.status config.status: creating Makefile config.status: creating util/Makefile config.status: creating geom/Makefile config.status: creating geom/ACIS/Makefile config.status: creating geom/Cholla/Makefile config.status: creating geom/facet/Makefile config.status: creating geom/facetbool/Makefile config.status: creating geom/OCC/Makefile config.status: creating geom/parallel/Makefile config.status: creating geom/virtual/Makefile config.status: creating init/Makefile config.status: creating compat/Makefile config.status: creating cgm.make config.status: creating itaps/Makefile config.status: creating itaps/iGeom-Defs.inc config.status: creating itaps/SIDL/Makefile config.status: creating test/Makefile config.status: creating cgm_apps/Makefile config.status: creating cgm_apps/examples/Makefile config.status: creating cgm_apps/examples/driverc++/Makefile config.status: creating cgm_apps/examples/facetdriver/Makefile config.status: creating config.h config.status: config.h is unchanged config.status: creating itaps/iBase_FCDefs.h config.status: itaps/iBase_FCDefs.h is unchanged config.status: executing depfiles commands make all-recursive make[1]: Entering directory `/home/jason/cgm/test/32-occ' Making all in compat make[2]: Entering directory `/home/jason/cgm/test/32-occ/compat' make[2]: Nothing to be done for `all'. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/compat' Making all in util make[2]: Entering directory `/home/jason/cgm/test/32-occ/util' /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT AllocMemManagersList.lo -MD -MP -MF .deps/AllocMemManagersList.Tpo -c -o AllocMemManagersList.lo ../../trunk/util/AllocMemManagersList.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT AllocMemManagersList.lo -MD -MP -MF .deps/AllocMemManagersList.Tpo -c ../../trunk/util/AllocMemManagersList.cpp -o AllocMemManagersList.o mv -f .deps/AllocMemManagersList.Tpo .deps/AllocMemManagersList.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT AppUtil.lo -MD -MP -MF .deps/AppUtil.Tpo -c -o AppUtil.lo ../../trunk/util/AppUtil.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT AppUtil.lo -MD -MP -MF .deps/AppUtil.Tpo -c ../../trunk/util/AppUtil.cpp -o AppUtil.o mv -f .deps/AppUtil.Tpo .deps/AppUtil.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT ArrayBasedContainer.lo -MD -MP -MF .deps/ArrayBasedContainer.Tpo -c -o ArrayBasedContainer.lo ../../trunk/util/ArrayBasedContainer.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT ArrayBasedContainer.lo -MD -MP -MF .deps/ArrayBasedContainer.Tpo -c ../../trunk/util/ArrayBasedContainer.cpp -o ArrayBasedContainer.o ../../trunk/util/ArrayBasedContainer.cpp: In member function ‘ArrayBasedContainer& ArrayBasedContainer::operator=(const ArrayBasedContainer&)’: ../../trunk/util/ArrayBasedContainer.cpp:143: warning: suggest explicit braces to avoid ambiguous ‘else’ mv -f .deps/ArrayBasedContainer.Tpo .deps/ArrayBasedContainer.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CpuTimer.lo -MD -MP -MF .deps/CpuTimer.Tpo -c -o CpuTimer.lo ../../trunk/util/CpuTimer.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CpuTimer.lo -MD -MP -MF .deps/CpuTimer.Tpo -c ../../trunk/util/CpuTimer.cpp -o CpuTimer.o mv -f .deps/CpuTimer.Tpo .deps/CpuTimer.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT Cubit2DPoint.lo -MD -MP -MF .deps/Cubit2DPoint.Tpo -c -o Cubit2DPoint.lo ../../trunk/util/Cubit2DPoint.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT Cubit2DPoint.lo -MD -MP -MF .deps/Cubit2DPoint.Tpo -c ../../trunk/util/Cubit2DPoint.cpp -o Cubit2DPoint.o mv -f .deps/Cubit2DPoint.Tpo .deps/Cubit2DPoint.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitBox.lo -MD -MP -MF .deps/CubitBox.Tpo -c -o CubitBox.lo ../../trunk/util/CubitBox.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitBox.lo -MD -MP -MF .deps/CubitBox.Tpo -c ../../trunk/util/CubitBox.cpp -o CubitBox.o mv -f .deps/CubitBox.Tpo .deps/CubitBox.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitCollection.lo -MD -MP -MF .deps/CubitCollection.Tpo -c -o CubitCollection.lo ../../trunk/util/CubitCollection.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitCollection.lo -MD -MP -MF .deps/CubitCollection.Tpo -c ../../trunk/util/CubitCollection.cpp -o CubitCollection.o mv -f .deps/CubitCollection.Tpo .deps/CubitCollection.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitContainer.lo -MD -MP -MF .deps/CubitContainer.Tpo -c -o CubitContainer.lo ../../trunk/util/CubitContainer.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitContainer.lo -MD -MP -MF .deps/CubitContainer.Tpo -c ../../trunk/util/CubitContainer.cpp -o CubitContainer.o mv -f .deps/CubitContainer.Tpo .deps/CubitContainer.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitCoordinateSystem.lo -MD -MP -MF .deps/CubitCoordinateSystem.Tpo -c -o CubitCoordinateSystem.lo ../../trunk/util/CubitCoordinateSystem.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitCoordinateSystem.lo -MD -MP -MF .deps/CubitCoordinateSystem.Tpo -c ../../trunk/util/CubitCoordinateSystem.cpp -o CubitCoordinateSystem.o mv -f .deps/CubitCoordinateSystem.Tpo .deps/CubitCoordinateSystem.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitDynamicLoader.lo -MD -MP -MF .deps/CubitDynamicLoader.Tpo -c -o CubitDynamicLoader.lo ../../trunk/util/CubitDynamicLoader.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitDynamicLoader.lo -MD -MP -MF .deps/CubitDynamicLoader.Tpo -c ../../trunk/util/CubitDynamicLoader.cpp -o CubitDynamicLoader.o mv -f .deps/CubitDynamicLoader.Tpo .deps/CubitDynamicLoader.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitEntity.lo -MD -MP -MF .deps/CubitEntity.Tpo -c -o CubitEntity.lo ../../trunk/util/CubitEntity.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitEntity.lo -MD -MP -MF .deps/CubitEntity.Tpo -c ../../trunk/util/CubitEntity.cpp -o CubitEntity.o mv -f .deps/CubitEntity.Tpo .deps/CubitEntity.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitFile.lo -MD -MP -MF .deps/CubitFile.Tpo -c -o CubitFile.lo ../../trunk/util/CubitFile.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitFile.lo -MD -MP -MF .deps/CubitFile.Tpo -c ../../trunk/util/CubitFile.cpp -o CubitFile.o mv -f .deps/CubitFile.Tpo .deps/CubitFile.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitFileFEModel.lo -MD -MP -MF .deps/CubitFileFEModel.Tpo -c -o CubitFileFEModel.lo ../../trunk/util/CubitFileFEModel.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitFileFEModel.lo -MD -MP -MF .deps/CubitFileFEModel.Tpo -c ../../trunk/util/CubitFileFEModel.cpp -o CubitFileFEModel.o mv -f .deps/CubitFileFEModel.Tpo .deps/CubitFileFEModel.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitFileIOWrapper.lo -MD -MP -MF .deps/CubitFileIOWrapper.Tpo -c -o CubitFileIOWrapper.lo ../../trunk/util/CubitFileIOWrapper.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitFileIOWrapper.lo -MD -MP -MF .deps/CubitFileIOWrapper.Tpo -c ../../trunk/util/CubitFileIOWrapper.cpp -o CubitFileIOWrapper.o mv -f .deps/CubitFileIOWrapper.Tpo .deps/CubitFileIOWrapper.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitFileMetaData.lo -MD -MP -MF .deps/CubitFileMetaData.Tpo -c -o CubitFileMetaData.lo ../../trunk/util/CubitFileMetaData.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitFileMetaData.lo -MD -MP -MF .deps/CubitFileMetaData.Tpo -c ../../trunk/util/CubitFileMetaData.cpp -o CubitFileMetaData.o mv -f .deps/CubitFileMetaData.Tpo .deps/CubitFileMetaData.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitFileUtil.lo -MD -MP -MF .deps/CubitFileUtil.Tpo -c -o CubitFileUtil.lo ../../trunk/util/CubitFileUtil.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitFileUtil.lo -MD -MP -MF .deps/CubitFileUtil.Tpo -c ../../trunk/util/CubitFileUtil.cpp -o CubitFileUtil.o mv -f .deps/CubitFileUtil.Tpo .deps/CubitFileUtil.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitMatrix.lo -MD -MP -MF .deps/CubitMatrix.Tpo -c -o CubitMatrix.lo ../../trunk/util/CubitMatrix.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitMatrix.lo -MD -MP -MF .deps/CubitMatrix.Tpo -c ../../trunk/util/CubitMatrix.cpp -o CubitMatrix.o mv -f .deps/CubitMatrix.Tpo .deps/CubitMatrix.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitMessage.lo -MD -MP -MF .deps/CubitMessage.Tpo -c -o CubitMessage.lo ../../trunk/util/CubitMessage.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitMessage.lo -MD -MP -MF .deps/CubitMessage.Tpo -c ../../trunk/util/CubitMessage.cpp -o CubitMessage.o ../../trunk/util/CubitMessage.cpp: In static member function ‘static void CubitMessage::initialize_settings()’: ../../trunk/util/CubitMessage.cpp:795: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/util/CubitMessage.cpp:803: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/util/CubitMessage.cpp:807: warning: deprecated conversion from string constant to ‘char*’ mv -f .deps/CubitMessage.Tpo .deps/CubitMessage.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitObservable.lo -MD -MP -MF .deps/CubitObservable.Tpo -c -o CubitObservable.lo ../../trunk/util/CubitObservable.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitObservable.lo -MD -MP -MF .deps/CubitObservable.Tpo -c ../../trunk/util/CubitObservable.cpp -o CubitObservable.o mv -f .deps/CubitObservable.Tpo .deps/CubitObservable.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitObserver.lo -MD -MP -MF .deps/CubitObserver.Tpo -c -o CubitObserver.lo ../../trunk/util/CubitObserver.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitObserver.lo -MD -MP -MF .deps/CubitObserver.Tpo -c ../../trunk/util/CubitObserver.cpp -o CubitObserver.o mv -f .deps/CubitObserver.Tpo .deps/CubitObserver.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitPlane.lo -MD -MP -MF .deps/CubitPlane.Tpo -c -o CubitPlane.lo ../../trunk/util/CubitPlane.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitPlane.lo -MD -MP -MF .deps/CubitPlane.Tpo -c ../../trunk/util/CubitPlane.cpp -o CubitPlane.o mv -f .deps/CubitPlane.Tpo .deps/CubitPlane.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitStack.lo -MD -MP -MF .deps/CubitStack.Tpo -c -o CubitStack.lo ../../trunk/util/CubitStack.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitStack.lo -MD -MP -MF .deps/CubitStack.Tpo -c ../../trunk/util/CubitStack.cpp -o CubitStack.o mv -f .deps/CubitStack.Tpo .deps/CubitStack.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitString.lo -MD -MP -MF .deps/CubitString.Tpo -c -o CubitString.lo ../../trunk/util/CubitString.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitString.lo -MD -MP -MF .deps/CubitString.Tpo -c ../../trunk/util/CubitString.cpp -o CubitString.o ../../trunk/util/CubitString.cpp: In constructor ‘CubitString::CubitString()’: ../../trunk/util/CubitString.cpp:117: warning: unused variable ‘dummy’ ../../trunk/util/CubitString.cpp: In constructor ‘CubitString::CubitString(const char*)’: ../../trunk/util/CubitString.cpp:139: warning: unused variable ‘dummy’ mv -f .deps/CubitString.Tpo .deps/CubitString.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitTransformMatrix.lo -MD -MP -MF .deps/CubitTransformMatrix.Tpo -c -o CubitTransformMatrix.lo ../../trunk/util/CubitTransformMatrix.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitTransformMatrix.lo -MD -MP -MF .deps/CubitTransformMatrix.Tpo -c ../../trunk/util/CubitTransformMatrix.cpp -o CubitTransformMatrix.o mv -f .deps/CubitTransformMatrix.Tpo .deps/CubitTransformMatrix.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitUtil.lo -MD -MP -MF .deps/CubitUtil.Tpo -c -o CubitUtil.lo ../../trunk/util/CubitUtil.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitUtil.lo -MD -MP -MF .deps/CubitUtil.Tpo -c ../../trunk/util/CubitUtil.cpp -o CubitUtil.o mv -f .deps/CubitUtil.Tpo .deps/CubitUtil.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitVector.lo -MD -MP -MF .deps/CubitVector.Tpo -c -o CubitVector.lo ../../trunk/util/CubitVector.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT CubitVector.lo -MD -MP -MF .deps/CubitVector.Tpo -c ../../trunk/util/CubitVector.cpp -o CubitVector.o ../../trunk/util/CubitVector.cpp: In member function ‘CubitBoolean CubitVector::within_scaled_tolerance(const CubitVector&, double) const’: ../../trunk/util/CubitVector.cpp:350: warning: suggest parentheses around comparison in operand of == ../../trunk/util/CubitVector.cpp:351: warning: suggest parentheses around comparison in operand of == ../../trunk/util/CubitVector.cpp:352: warning: suggest parentheses around comparison in operand of == mv -f .deps/CubitVector.Tpo .deps/CubitVector.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT DIntArray.lo -MD -MP -MF .deps/DIntArray.Tpo -c -o DIntArray.lo ../../trunk/util/DIntArray.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT DIntArray.lo -MD -MP -MF .deps/DIntArray.Tpo -c ../../trunk/util/DIntArray.cpp -o DIntArray.o mv -f .deps/DIntArray.Tpo .deps/DIntArray.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT DLList.lo -MD -MP -MF .deps/DLList.Tpo -c -o DLList.lo ../../trunk/util/DLList.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT DLList.lo -MD -MP -MF .deps/DLList.Tpo -c ../../trunk/util/DLList.cpp -o DLList.o mv -f .deps/DLList.Tpo .deps/DLList.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT DynamicArray.lo -MD -MP -MF .deps/DynamicArray.Tpo -c -o DynamicArray.lo ../../trunk/util/DynamicArray.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT DynamicArray.lo -MD -MP -MF .deps/DynamicArray.Tpo -c ../../trunk/util/DynamicArray.cpp -o DynamicArray.o mv -f .deps/DynamicArray.Tpo .deps/DynamicArray.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT GMem.lo -MD -MP -MF .deps/GMem.Tpo -c -o GMem.lo ../../trunk/util/GMem.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT GMem.lo -MD -MP -MF .deps/GMem.Tpo -c ../../trunk/util/GMem.cpp -o GMem.o mv -f .deps/GMem.Tpo .deps/GMem.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT GetLongOpt.lo -MD -MP -MF .deps/GetLongOpt.Tpo -c -o GetLongOpt.lo ../../trunk/util/GetLongOpt.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT GetLongOpt.lo -MD -MP -MF .deps/GetLongOpt.Tpo -c ../../trunk/util/GetLongOpt.cpp -o GetLongOpt.o mv -f .deps/GetLongOpt.Tpo .deps/GetLongOpt.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT GfxDebug.lo -MD -MP -MF .deps/GfxDebug.Tpo -c -o GfxDebug.lo ../../trunk/util/GfxDebug.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT GfxDebug.lo -MD -MP -MF .deps/GfxDebug.Tpo -c ../../trunk/util/GfxDebug.cpp -o GfxDebug.o mv -f .deps/GfxDebug.Tpo .deps/GfxDebug.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT IntersectionTool.lo -MD -MP -MF .deps/IntersectionTool.Tpo -c -o IntersectionTool.lo ../../trunk/util/IntersectionTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT IntersectionTool.lo -MD -MP -MF .deps/IntersectionTool.Tpo -c ../../trunk/util/IntersectionTool.cpp -o IntersectionTool.o mv -f .deps/IntersectionTool.Tpo .deps/IntersectionTool.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT MemoryBlock.lo -MD -MP -MF .deps/MemoryBlock.Tpo -c -o MemoryBlock.lo ../../trunk/util/MemoryBlock.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT MemoryBlock.lo -MD -MP -MF .deps/MemoryBlock.Tpo -c ../../trunk/util/MemoryBlock.cpp -o MemoryBlock.o mv -f .deps/MemoryBlock.Tpo .deps/MemoryBlock.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT MemoryManager.lo -MD -MP -MF .deps/MemoryManager.Tpo -c -o MemoryManager.lo ../../trunk/util/MemoryManager.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT MemoryManager.lo -MD -MP -MF .deps/MemoryManager.Tpo -c ../../trunk/util/MemoryManager.cpp -o MemoryManager.o mv -f .deps/MemoryManager.Tpo .deps/MemoryManager.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT ParamCubitPlane.lo -MD -MP -MF .deps/ParamCubitPlane.Tpo -c -o ParamCubitPlane.lo ../../trunk/util/ParamCubitPlane.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT ParamCubitPlane.lo -MD -MP -MF .deps/ParamCubitPlane.Tpo -c ../../trunk/util/ParamCubitPlane.cpp -o ParamCubitPlane.o mv -f .deps/ParamCubitPlane.Tpo .deps/ParamCubitPlane.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT PlanarParamTool.lo -MD -MP -MF .deps/PlanarParamTool.Tpo -c -o PlanarParamTool.lo ../../trunk/util/PlanarParamTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT PlanarParamTool.lo -MD -MP -MF .deps/PlanarParamTool.Tpo -c ../../trunk/util/PlanarParamTool.cpp -o PlanarParamTool.o mv -f .deps/PlanarParamTool.Tpo .deps/PlanarParamTool.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT Queue.lo -MD -MP -MF .deps/Queue.Tpo -c -o Queue.lo ../../trunk/util/Queue.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT Queue.lo -MD -MP -MF .deps/Queue.Tpo -c ../../trunk/util/Queue.cpp -o Queue.o mv -f .deps/Queue.Tpo .deps/Queue.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT RandomMersenne.lo -MD -MP -MF .deps/RandomMersenne.Tpo -c -o RandomMersenne.lo ../../trunk/util/RandomMersenne.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT RandomMersenne.lo -MD -MP -MF .deps/RandomMersenne.Tpo -c ../../trunk/util/RandomMersenne.cpp -o RandomMersenne.o mv -f .deps/RandomMersenne.Tpo .deps/RandomMersenne.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT SDLList.lo -MD -MP -MF .deps/SDLList.Tpo -c -o SDLList.lo ../../trunk/util/SDLList.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT SDLList.lo -MD -MP -MF .deps/SDLList.Tpo -c ../../trunk/util/SDLList.cpp -o SDLList.o mv -f .deps/SDLList.Tpo .deps/SDLList.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT SettingHandler.lo -MD -MP -MF .deps/SettingHandler.Tpo -c -o SettingHandler.lo ../../trunk/util/SettingHandler.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT SettingHandler.lo -MD -MP -MF .deps/SettingHandler.Tpo -c ../../trunk/util/SettingHandler.cpp -o SettingHandler.o ../../trunk/util/SettingHandler.cpp: In member function ‘void SettingHandler::save_settings()’: ../../trunk/util/SettingHandler.cpp:222: warning: deprecated conversion from string constant to ‘char*’ mv -f .deps/SettingHandler.Tpo .deps/SettingHandler.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT SettingHolder.lo -MD -MP -MF .deps/SettingHolder.Tpo -c -o SettingHolder.lo ../../trunk/util/SettingHolder.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT SettingHolder.lo -MD -MP -MF .deps/SettingHolder.Tpo -c ../../trunk/util/SettingHolder.cpp -o SettingHolder.o mv -f .deps/SettingHolder.Tpo .deps/SettingHolder.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT StubProgressTool.lo -MD -MP -MF .deps/StubProgressTool.Tpo -c -o StubProgressTool.lo ../../trunk/util/StubProgressTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT StubProgressTool.lo -MD -MP -MF .deps/StubProgressTool.Tpo -c ../../trunk/util/StubProgressTool.cpp -o StubProgressTool.o mv -f .deps/StubProgressTool.Tpo .deps/StubProgressTool.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT TDUPtr.lo -MD -MP -MF .deps/TDUPtr.Tpo -c -o TDUPtr.lo ../../trunk/util/TDUPtr.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT TDUPtr.lo -MD -MP -MF .deps/TDUPtr.Tpo -c ../../trunk/util/TDUPtr.cpp -o TDUPtr.o mv -f .deps/TDUPtr.Tpo .deps/TDUPtr.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT TextProgressTool.lo -MD -MP -MF .deps/TextProgressTool.Tpo -c -o TextProgressTool.lo ../../trunk/util/TextProgressTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT TextProgressTool.lo -MD -MP -MF .deps/TextProgressTool.Tpo -c ../../trunk/util/TextProgressTool.cpp -o TextProgressTool.o mv -f .deps/TextProgressTool.Tpo .deps/TextProgressTool.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT ToolData.lo -MD -MP -MF .deps/ToolData.Tpo -c -o ToolData.lo ../../trunk/util/ToolData.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT ToolData.lo -MD -MP -MF .deps/ToolData.Tpo -c ../../trunk/util/ToolData.cpp -o ToolData.o mv -f .deps/ToolData.Tpo .deps/ToolData.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT ToolDataUser.lo -MD -MP -MF .deps/ToolDataUser.Tpo -c -o ToolDataUser.lo ../../trunk/util/ToolDataUser.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT ToolDataUser.lo -MD -MP -MF .deps/ToolDataUser.Tpo -c ../../trunk/util/ToolDataUser.cpp -o ToolDataUser.o mv -f .deps/ToolDataUser.Tpo .deps/ToolDataUser.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT Tree.lo -MD -MP -MF .deps/Tree.Tpo -c -o Tree.lo ../../trunk/util/Tree.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT Tree.lo -MD -MP -MF .deps/Tree.Tpo -c ../../trunk/util/Tree.cpp -o Tree.o mv -f .deps/Tree.Tpo .deps/Tree.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT TtyProgressTool.lo -MD -MP -MF .deps/TtyProgressTool.Tpo -c -o TtyProgressTool.lo ../../trunk/util/TtyProgressTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/util -I.. -I../itaps -Wall -pipe -pedantic -g -m32 -MT TtyProgressTool.lo -MD -MP -MF .deps/TtyProgressTool.Tpo -c ../../trunk/util/TtyProgressTool.cpp -o TtyProgressTool.o mv -f .deps/TtyProgressTool.Tpo .deps/TtyProgressTool.Plo /bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -m32 -o libcubit_util.la AllocMemManagersList.lo AppUtil.lo ArrayBasedContainer.lo CpuTimer.lo Cubit2DPoint.lo CubitBox.lo CubitCollection.lo CubitContainer.lo CubitCoordinateSystem.lo CubitDynamicLoader.lo CubitEntity.lo CubitFile.lo CubitFileFEModel.lo CubitFileIOWrapper.lo CubitFileMetaData.lo CubitFileUtil.lo CubitMatrix.lo CubitMessage.lo CubitObservable.lo CubitObserver.lo CubitPlane.lo CubitStack.lo CubitString.lo CubitTransformMatrix.lo CubitUtil.lo CubitVector.lo DIntArray.lo DLList.lo DynamicArray.lo GMem.lo GetLongOpt.lo GfxDebug.lo IntersectionTool.lo MemoryBlock.lo MemoryManager.lo ParamCubitPlane.lo PlanarParamTool.lo Queue.lo RandomMersenne.lo SDLList.lo SettingHandler.lo SettingHolder.lo StubProgressTool.lo TDUPtr.lo TextProgressTool.lo ToolData.lo ToolDataUser.lo Tree.lo TtyProgressTool.lo -lm rm -fr .libs/libcubit_util.a .libs/libcubit_util.la ar cru .libs/libcubit_util.a AllocMemManagersList.o AppUtil.o ArrayBasedContainer.o CpuTimer.o Cubit2DPoint.o CubitBox.o CubitCollection.o CubitContainer.o CubitCoordinateSystem.o CubitDynamicLoader.o CubitEntity.o CubitFile.o CubitFileFEModel.o CubitFileIOWrapper.o CubitFileMetaData.o CubitFileUtil.o CubitMatrix.o CubitMessage.o CubitObservable.o CubitObserver.o CubitPlane.o CubitStack.o CubitString.o CubitTransformMatrix.o CubitUtil.o CubitVector.o DIntArray.o DLList.o DynamicArray.o GMem.o GetLongOpt.o GfxDebug.o IntersectionTool.o MemoryBlock.o MemoryManager.o ParamCubitPlane.o PlanarParamTool.o Queue.o RandomMersenne.o SDLList.o SettingHandler.o SettingHolder.o StubProgressTool.o TDUPtr.o TextProgressTool.o ToolData.o ToolDataUser.o Tree.o TtyProgressTool.o ranlib .libs/libcubit_util.a creating libcubit_util.la (cd .libs && rm -f libcubit_util.la && ln -s ../libcubit_util.la libcubit_util.la) make[2]: Leaving directory `/home/jason/cgm/test/32-occ/util' Making all in geom make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom' Making all in . make[3]: Entering directory `/home/jason/cgm/test/32-occ/geom' /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT AllocMemManagersGeom.lo -MD -MP -MF .deps/AllocMemManagersGeom.Tpo -c -o AllocMemManagersGeom.lo ../../trunk/geom/AllocMemManagersGeom.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT AllocMemManagersGeom.lo -MD -MP -MF .deps/AllocMemManagersGeom.Tpo -c ../../trunk/geom/AllocMemManagersGeom.cpp -o AllocMemManagersGeom.o mv -f .deps/AllocMemManagersGeom.Tpo .deps/AllocMemManagersGeom.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT AnalyticGeometryTool.lo -MD -MP -MF .deps/AnalyticGeometryTool.Tpo -c -o AnalyticGeometryTool.lo ../../trunk/geom/AnalyticGeometryTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT AnalyticGeometryTool.lo -MD -MP -MF .deps/AnalyticGeometryTool.Tpo -c ../../trunk/geom/AnalyticGeometryTool.cpp -o AnalyticGeometryTool.o mv -f .deps/AnalyticGeometryTool.Tpo .deps/AnalyticGeometryTool.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT BasicTopologyEntity.lo -MD -MP -MF .deps/BasicTopologyEntity.Tpo -c -o BasicTopologyEntity.lo ../../trunk/geom/BasicTopologyEntity.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT BasicTopologyEntity.lo -MD -MP -MF .deps/BasicTopologyEntity.Tpo -c ../../trunk/geom/BasicTopologyEntity.cpp -o BasicTopologyEntity.o mv -f .deps/BasicTopologyEntity.Tpo .deps/BasicTopologyEntity.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT Body.lo -MD -MP -MF .deps/Body.Tpo -c -o Body.lo ../../trunk/geom/Body.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT Body.lo -MD -MP -MF .deps/Body.Tpo -c ../../trunk/geom/Body.cpp -o Body.o mv -f .deps/Body.Tpo .deps/Body.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT BodySM.lo -MD -MP -MF .deps/BodySM.Tpo -c -o BodySM.lo ../../trunk/geom/BodySM.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT BodySM.lo -MD -MP -MF .deps/BodySM.Tpo -c ../../trunk/geom/BodySM.cpp -o BodySM.o mv -f .deps/BodySM.Tpo .deps/BodySM.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT BoundingBoxTool.lo -MD -MP -MF .deps/BoundingBoxTool.Tpo -c -o BoundingBoxTool.lo ../../trunk/geom/BoundingBoxTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT BoundingBoxTool.lo -MD -MP -MF .deps/BoundingBoxTool.Tpo -c ../../trunk/geom/BoundingBoxTool.cpp -o BoundingBoxTool.o ../../trunk/geom/BoundingBoxTool.cpp: In static member function ‘static void BoundingBoxTool::initialize_settings()’: ../../trunk/geom/BoundingBoxTool.cpp:380: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/BoundingBoxTool.cpp:384: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/BoundingBoxTool.cpp:388: warning: deprecated conversion from string constant to ‘char*’ mv -f .deps/BoundingBoxTool.Tpo .deps/BoundingBoxTool.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT BridgeManager.lo -MD -MP -MF .deps/BridgeManager.Tpo -c -o BridgeManager.lo ../../trunk/geom/BridgeManager.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT BridgeManager.lo -MD -MP -MF .deps/BridgeManager.Tpo -c ../../trunk/geom/BridgeManager.cpp -o BridgeManager.o mv -f .deps/BridgeManager.Tpo .deps/BridgeManager.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CAActuateSet.lo -MD -MP -MF .deps/CAActuateSet.Tpo -c -o CAActuateSet.lo ../../trunk/geom/CAActuateSet.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CAActuateSet.lo -MD -MP -MF .deps/CAActuateSet.Tpo -c ../../trunk/geom/CAActuateSet.cpp -o CAActuateSet.o mv -f .deps/CAActuateSet.Tpo .deps/CAActuateSet.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CADeferredAttrib.lo -MD -MP -MF .deps/CADeferredAttrib.Tpo -c -o CADeferredAttrib.lo ../../trunk/geom/CADeferredAttrib.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CADeferredAttrib.lo -MD -MP -MF .deps/CADeferredAttrib.Tpo -c ../../trunk/geom/CADeferredAttrib.cpp -o CADeferredAttrib.o mv -f .deps/CADeferredAttrib.Tpo .deps/CADeferredAttrib.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CAEntityColor.lo -MD -MP -MF .deps/CAEntityColor.Tpo -c -o CAEntityColor.lo ../../trunk/geom/CAEntityColor.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CAEntityColor.lo -MD -MP -MF .deps/CAEntityColor.Tpo -c ../../trunk/geom/CAEntityColor.cpp -o CAEntityColor.o mv -f .deps/CAEntityColor.Tpo .deps/CAEntityColor.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CAEntityId.lo -MD -MP -MF .deps/CAEntityId.Tpo -c -o CAEntityId.lo ../../trunk/geom/CAEntityId.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CAEntityId.lo -MD -MP -MF .deps/CAEntityId.Tpo -c ../../trunk/geom/CAEntityId.cpp -o CAEntityId.o mv -f .deps/CAEntityId.Tpo .deps/CAEntityId.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CAEntityName.lo -MD -MP -MF .deps/CAEntityName.Tpo -c -o CAEntityName.lo ../../trunk/geom/CAEntityName.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CAEntityName.lo -MD -MP -MF .deps/CAEntityName.Tpo -c ../../trunk/geom/CAEntityName.cpp -o CAEntityName.o mv -f .deps/CAEntityName.Tpo .deps/CAEntityName.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CAGroup.lo -MD -MP -MF .deps/CAGroup.Tpo -c -o CAGroup.lo ../../trunk/geom/CAGroup.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CAGroup.lo -MD -MP -MF .deps/CAGroup.Tpo -c ../../trunk/geom/CAGroup.cpp -o CAGroup.o mv -f .deps/CAGroup.Tpo .deps/CAGroup.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CAMergePartner.lo -MD -MP -MF .deps/CAMergePartner.Tpo -c -o CAMergePartner.lo ../../trunk/geom/CAMergePartner.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CAMergePartner.lo -MD -MP -MF .deps/CAMergePartner.Tpo -c ../../trunk/geom/CAMergePartner.cpp -o CAMergePartner.o mv -f .deps/CAMergePartner.Tpo .deps/CAMergePartner.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CAMergeStatus.lo -MD -MP -MF .deps/CAMergeStatus.Tpo -c -o CAMergeStatus.lo ../../trunk/geom/CAMergeStatus.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CAMergeStatus.lo -MD -MP -MF .deps/CAMergeStatus.Tpo -c ../../trunk/geom/CAMergeStatus.cpp -o CAMergeStatus.o mv -f .deps/CAMergeStatus.Tpo .deps/CAMergeStatus.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CASourceFeature.lo -MD -MP -MF .deps/CASourceFeature.Tpo -c -o CASourceFeature.lo ../../trunk/geom/CASourceFeature.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CASourceFeature.lo -MD -MP -MF .deps/CASourceFeature.Tpo -c ../../trunk/geom/CASourceFeature.cpp -o CASourceFeature.o mv -f .deps/CASourceFeature.Tpo .deps/CASourceFeature.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CAUniqueId.lo -MD -MP -MF .deps/CAUniqueId.Tpo -c -o CAUniqueId.lo ../../trunk/geom/CAUniqueId.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CAUniqueId.lo -MD -MP -MF .deps/CAUniqueId.Tpo -c ../../trunk/geom/CAUniqueId.cpp -o CAUniqueId.o mv -f .deps/CAUniqueId.Tpo .deps/CAUniqueId.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CGMApp.lo -MD -MP -MF .deps/CGMApp.Tpo -c -o CGMApp.lo ../../trunk/geom/CGMApp.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CGMApp.lo -MD -MP -MF .deps/CGMApp.Tpo -c ../../trunk/geom/CGMApp.cpp -o CGMApp.o mv -f .deps/CGMApp.Tpo .deps/CGMApp.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CGMEngineDynamicLoader.lo -MD -MP -MF .deps/CGMEngineDynamicLoader.Tpo -c -o CGMEngineDynamicLoader.lo ../../trunk/geom/CGMEngineDynamicLoader.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CGMEngineDynamicLoader.lo -MD -MP -MF .deps/CGMEngineDynamicLoader.Tpo -c ../../trunk/geom/CGMEngineDynamicLoader.cpp -o CGMEngineDynamicLoader.o ../../trunk/geom/CGMEngineDynamicLoader.cpp: In member function ‘CubitBoolean CGMEngineDynamicLoader::check_engine_version()’: ../../trunk/geom/CGMEngineDynamicLoader.cpp:136: warning: ISO C++ forbids casting between pointer-to-function and pointer-to-object ../../trunk/geom/CGMEngineDynamicLoader.cpp: In member function ‘GeometryQueryEngine* CGMEngineDynamicLoader::get_gqe()’: ../../trunk/geom/CGMEngineDynamicLoader.cpp:175: warning: ISO C++ forbids casting between pointer-to-function and pointer-to-object ../../trunk/geom/CGMEngineDynamicLoader.cpp: In member function ‘GeometryModifyEngine* CGMEngineDynamicLoader::get_gme()’: ../../trunk/geom/CGMEngineDynamicLoader.cpp:210: warning: ISO C++ forbids casting between pointer-to-function and pointer-to-object mv -f .deps/CGMEngineDynamicLoader.Tpo .deps/CGMEngineDynamicLoader.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT Chain.lo -MD -MP -MF .deps/Chain.Tpo -c -o Chain.lo ../../trunk/geom/Chain.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT Chain.lo -MD -MP -MF .deps/Chain.Tpo -c ../../trunk/geom/Chain.cpp -o Chain.o mv -f .deps/Chain.Tpo .deps/Chain.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CoEdge.lo -MD -MP -MF .deps/CoEdge.Tpo -c -o CoEdge.lo ../../trunk/geom/CoEdge.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CoEdge.lo -MD -MP -MF .deps/CoEdge.Tpo -c ../../trunk/geom/CoEdge.cpp -o CoEdge.o mv -f .deps/CoEdge.Tpo .deps/CoEdge.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CoEdgeSM.lo -MD -MP -MF .deps/CoEdgeSM.Tpo -c -o CoEdgeSM.lo ../../trunk/geom/CoEdgeSM.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CoEdgeSM.lo -MD -MP -MF .deps/CoEdgeSM.Tpo -c ../../trunk/geom/CoEdgeSM.cpp -o CoEdgeSM.o mv -f .deps/CoEdgeSM.Tpo .deps/CoEdgeSM.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CoFace.lo -MD -MP -MF .deps/CoFace.Tpo -c -o CoFace.lo ../../trunk/geom/CoFace.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CoFace.lo -MD -MP -MF .deps/CoFace.Tpo -c ../../trunk/geom/CoFace.cpp -o CoFace.o mv -f .deps/CoFace.Tpo .deps/CoFace.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CollectionEntity.lo -MD -MP -MF .deps/CollectionEntity.Tpo -c -o CollectionEntity.lo ../../trunk/geom/CollectionEntity.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CollectionEntity.lo -MD -MP -MF .deps/CollectionEntity.Tpo -c ../../trunk/geom/CollectionEntity.cpp -o CollectionEntity.o mv -f .deps/CollectionEntity.Tpo .deps/CollectionEntity.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CoVertex.lo -MD -MP -MF .deps/CoVertex.Tpo -c -o CoVertex.lo ../../trunk/geom/CoVertex.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CoVertex.lo -MD -MP -MF .deps/CoVertex.Tpo -c ../../trunk/geom/CoVertex.cpp -o CoVertex.o mv -f .deps/CoVertex.Tpo .deps/CoVertex.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CoVolume.lo -MD -MP -MF .deps/CoVolume.Tpo -c -o CoVolume.lo ../../trunk/geom/CoVolume.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CoVolume.lo -MD -MP -MF .deps/CoVolume.Tpo -c ../../trunk/geom/CoVolume.cpp -o CoVolume.o mv -f .deps/CoVolume.Tpo .deps/CoVolume.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CubitAttrib.lo -MD -MP -MF .deps/CubitAttrib.Tpo -c -o CubitAttrib.lo ../../trunk/geom/CubitAttrib.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CubitAttrib.lo -MD -MP -MF .deps/CubitAttrib.Tpo -c ../../trunk/geom/CubitAttrib.cpp -o CubitAttrib.o mv -f .deps/CubitAttrib.Tpo .deps/CubitAttrib.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CubitAttribManager.lo -MD -MP -MF .deps/CubitAttribManager.Tpo -c -o CubitAttribManager.lo ../../trunk/geom/CubitAttribManager.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CubitAttribManager.lo -MD -MP -MF .deps/CubitAttribManager.Tpo -c ../../trunk/geom/CubitAttribManager.cpp -o CubitAttribManager.o mv -f .deps/CubitAttribManager.Tpo .deps/CubitAttribManager.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CubitAttribUser.lo -MD -MP -MF .deps/CubitAttribUser.Tpo -c -o CubitAttribUser.lo ../../trunk/geom/CubitAttribUser.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CubitAttribUser.lo -MD -MP -MF .deps/CubitAttribUser.Tpo -c ../../trunk/geom/CubitAttribUser.cpp -o CubitAttribUser.o ../../trunk/geom/CubitAttribUser.cpp: In member function ‘CubitStatus CubitAttribUser::remove_cubit_attrib(CubitAttrib*)’: ../../trunk/geom/CubitAttribUser.cpp:786: warning: suggest explicit braces to avoid ambiguous ‘else’ mv -f .deps/CubitAttribUser.Tpo .deps/CubitAttribUser.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CubitPolygon.lo -MD -MP -MF .deps/CubitPolygon.Tpo -c -o CubitPolygon.lo ../../trunk/geom/CubitPolygon.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CubitPolygon.lo -MD -MP -MF .deps/CubitPolygon.Tpo -c ../../trunk/geom/CubitPolygon.cpp -o CubitPolygon.o ../../trunk/geom/CubitPolygon.cpp: In member function ‘CubitPointContainment CubitPolygon::pnt_containment(Cubit2DPoint&, double)’: ../../trunk/geom/CubitPolygon.cpp:95: warning: suggest parentheses around && within || mv -f .deps/CubitPolygon.Tpo .deps/CubitPolygon.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CubitSimpleAttrib.lo -MD -MP -MF .deps/CubitSimpleAttrib.Tpo -c -o CubitSimpleAttrib.lo ../../trunk/geom/CubitSimpleAttrib.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CubitSimpleAttrib.lo -MD -MP -MF .deps/CubitSimpleAttrib.Tpo -c ../../trunk/geom/CubitSimpleAttrib.cpp -o CubitSimpleAttrib.o ../../trunk/geom/CubitSimpleAttrib.cpp: In static member function ‘static void CubitSimpleAttrib::initialize_settings()’: ../../trunk/geom/CubitSimpleAttrib.cpp:339: warning: deprecated conversion from string constant to ‘char*’ mv -f .deps/CubitSimpleAttrib.Tpo .deps/CubitSimpleAttrib.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT Curve.lo -MD -MP -MF .deps/Curve.Tpo -c -o Curve.lo ../../trunk/geom/Curve.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT Curve.lo -MD -MP -MF .deps/Curve.Tpo -c ../../trunk/geom/Curve.cpp -o Curve.o mv -f .deps/Curve.Tpo .deps/Curve.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CurveOverlapFacet.lo -MD -MP -MF .deps/CurveOverlapFacet.Tpo -c -o CurveOverlapFacet.lo ../../trunk/geom/CurveOverlapFacet.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CurveOverlapFacet.lo -MD -MP -MF .deps/CurveOverlapFacet.Tpo -c ../../trunk/geom/CurveOverlapFacet.cpp -o CurveOverlapFacet.o mv -f .deps/CurveOverlapFacet.Tpo .deps/CurveOverlapFacet.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CurveSM.lo -MD -MP -MF .deps/CurveSM.Tpo -c -o CurveSM.lo ../../trunk/geom/CurveSM.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CurveSM.lo -MD -MP -MF .deps/CurveSM.Tpo -c ../../trunk/geom/CurveSM.cpp -o CurveSM.o mv -f .deps/CurveSM.Tpo .deps/CurveSM.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CylinderEvaluator.lo -MD -MP -MF .deps/CylinderEvaluator.Tpo -c -o CylinderEvaluator.lo ../../trunk/geom/CylinderEvaluator.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT CylinderEvaluator.lo -MD -MP -MF .deps/CylinderEvaluator.Tpo -c ../../trunk/geom/CylinderEvaluator.cpp -o CylinderEvaluator.o mv -f .deps/CylinderEvaluator.Tpo .deps/CylinderEvaluator.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT DAG.lo -MD -MP -MF .deps/DAG.Tpo -c -o DAG.lo ../../trunk/geom/DAG.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT DAG.lo -MD -MP -MF .deps/DAG.Tpo -c ../../trunk/geom/DAG.cpp -o DAG.o mv -f .deps/DAG.Tpo .deps/DAG.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT DagDrawingTool.lo -MD -MP -MF .deps/DagDrawingTool.Tpo -c -o DagDrawingTool.lo ../../trunk/geom/DagDrawingTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT DagDrawingTool.lo -MD -MP -MF .deps/DagDrawingTool.Tpo -c ../../trunk/geom/DagDrawingTool.cpp -o DagDrawingTool.o mv -f .deps/DagDrawingTool.Tpo .deps/DagDrawingTool.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeomDataObserver.lo -MD -MP -MF .deps/GeomDataObserver.Tpo -c -o GeomDataObserver.lo ../../trunk/geom/GeomDataObserver.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeomDataObserver.lo -MD -MP -MF .deps/GeomDataObserver.Tpo -c ../../trunk/geom/GeomDataObserver.cpp -o GeomDataObserver.o mv -f .deps/GeomDataObserver.Tpo .deps/GeomDataObserver.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryEntity.lo -MD -MP -MF .deps/GeometryEntity.Tpo -c -o GeometryEntity.lo ../../trunk/geom/GeometryEntity.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryEntity.lo -MD -MP -MF .deps/GeometryEntity.Tpo -c ../../trunk/geom/GeometryEntity.cpp -o GeometryEntity.o mv -f .deps/GeometryEntity.Tpo .deps/GeometryEntity.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryFeatureEngine.lo -MD -MP -MF .deps/GeometryFeatureEngine.Tpo -c -o GeometryFeatureEngine.lo ../../trunk/geom/GeometryFeatureEngine.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryFeatureEngine.lo -MD -MP -MF .deps/GeometryFeatureEngine.Tpo -c ../../trunk/geom/GeometryFeatureEngine.cpp -o GeometryFeatureEngine.o mv -f .deps/GeometryFeatureEngine.Tpo .deps/GeometryFeatureEngine.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryFeatureTool.lo -MD -MP -MF .deps/GeometryFeatureTool.Tpo -c -o GeometryFeatureTool.lo ../../trunk/geom/GeometryFeatureTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryFeatureTool.lo -MD -MP -MF .deps/GeometryFeatureTool.Tpo -c ../../trunk/geom/GeometryFeatureTool.cpp -o GeometryFeatureTool.o mv -f .deps/GeometryFeatureTool.Tpo .deps/GeometryFeatureTool.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryHealerEngine.lo -MD -MP -MF .deps/GeometryHealerEngine.Tpo -c -o GeometryHealerEngine.lo ../../trunk/geom/GeometryHealerEngine.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryHealerEngine.lo -MD -MP -MF .deps/GeometryHealerEngine.Tpo -c ../../trunk/geom/GeometryHealerEngine.cpp -o GeometryHealerEngine.o mv -f .deps/GeometryHealerEngine.Tpo .deps/GeometryHealerEngine.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryHealerTool.lo -MD -MP -MF .deps/GeometryHealerTool.Tpo -c -o GeometryHealerTool.lo ../../trunk/geom/GeometryHealerTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryHealerTool.lo -MD -MP -MF .deps/GeometryHealerTool.Tpo -c ../../trunk/geom/GeometryHealerTool.cpp -o GeometryHealerTool.o mv -f .deps/GeometryHealerTool.Tpo .deps/GeometryHealerTool.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryModifyEngine.lo -MD -MP -MF .deps/GeometryModifyEngine.Tpo -c -o GeometryModifyEngine.lo ../../trunk/geom/GeometryModifyEngine.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryModifyEngine.lo -MD -MP -MF .deps/GeometryModifyEngine.Tpo -c ../../trunk/geom/GeometryModifyEngine.cpp -o GeometryModifyEngine.o mv -f .deps/GeometryModifyEngine.Tpo .deps/GeometryModifyEngine.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryModifyTool.lo -MD -MP -MF .deps/GeometryModifyTool.Tpo -c -o GeometryModifyTool.lo ../../trunk/geom/GeometryModifyTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryModifyTool.lo -MD -MP -MF .deps/GeometryModifyTool.Tpo -c ../../trunk/geom/GeometryModifyTool.cpp -o GeometryModifyTool.o ../../trunk/geom/GeometryModifyTool.cpp: In static member function ‘static void GeometryModifyTool::initialize_settings()’: ../../trunk/geom/GeometryModifyTool.cpp:3587: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/GeometryModifyTool.cpp:3591: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/GeometryModifyTool.cpp:3595: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/GeometryModifyTool.cpp:3599: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/GeometryModifyTool.cpp:3603: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/GeometryModifyTool.cpp: In member function ‘CubitStatus GeometryModifyTool::tolerant_imprint(DLIList<Body*>&, DLIList<Body*>&, bool)’: ../../trunk/geom/GeometryModifyTool.cpp:9395: warning: ISO C++ does not support the ‘%lf’ printf format mv -f .deps/GeometryModifyTool.Tpo .deps/GeometryModifyTool.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryQueryEngine.lo -MD -MP -MF .deps/GeometryQueryEngine.Tpo -c -o GeometryQueryEngine.lo ../../trunk/geom/GeometryQueryEngine.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryQueryEngine.lo -MD -MP -MF .deps/GeometryQueryEngine.Tpo -c ../../trunk/geom/GeometryQueryEngine.cpp -o GeometryQueryEngine.o mv -f .deps/GeometryQueryEngine.Tpo .deps/GeometryQueryEngine.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryQueryTool.lo -MD -MP -MF .deps/GeometryQueryTool.Tpo -c -o GeometryQueryTool.lo ../../trunk/geom/GeometryQueryTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryQueryTool.lo -MD -MP -MF .deps/GeometryQueryTool.Tpo -c ../../trunk/geom/GeometryQueryTool.cpp -o GeometryQueryTool.o ../../trunk/geom/GeometryQueryTool.cpp: In static member function ‘static void GeometryQueryTool::initialize_settings()’: ../../trunk/geom/GeometryQueryTool.cpp:2456: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/GeometryQueryTool.cpp:2460: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/GeometryQueryTool.cpp:2464: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/GeometryQueryTool.cpp:2468: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/GeometryQueryTool.cpp: In member function ‘CubitStatus GeometryQueryTool::get_intersections(RefEdge*, CubitVector&, CubitVector&, DLIList<CubitVector*>&, CubitBoolean, CubitBoolean)’: ../../trunk/geom/GeometryQueryTool.cpp:2997: warning: unused variable ‘status’ ../../trunk/geom/GeometryQueryTool.cpp: In member function ‘CubitStatus GeometryQueryTool::straightline_intersections(RefEdge*, CubitVector&, CubitVector&, DLIList<CubitVector*>&, CubitBoolean, CubitBoolean)’: ../../trunk/geom/GeometryQueryTool.cpp:3026: warning: unused variable ‘status’ mv -f .deps/GeometryQueryTool.Tpo .deps/GeometryQueryTool.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryUtil.lo -MD -MP -MF .deps/GeometryUtil.Tpo -c -o GeometryUtil.lo ../../trunk/geom/GeometryUtil.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeometryUtil.lo -MD -MP -MF .deps/GeometryUtil.Tpo -c ../../trunk/geom/GeometryUtil.cpp -o GeometryUtil.o ../../trunk/geom/GeometryUtil.cpp: In member function ‘CubitBoolean GeometryUtil::valid_shell_cofaces(Shell*, CubitBoolean)’: ../../trunk/geom/GeometryUtil.cpp:1942: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘CoEdge*’ ../../trunk/geom/GeometryUtil.cpp: In member function ‘CubitBoolean GeometryUtil::valid_sm_topology(Body*, CubitBoolean)’: ../../trunk/geom/GeometryUtil.cpp:2279: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’ ../../trunk/geom/GeometryUtil.cpp: In member function ‘CubitBoolean GeometryUtil::valid_sm_topology(RefVolume*, CubitBoolean)’: ../../trunk/geom/GeometryUtil.cpp:2381: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’ ../../trunk/geom/GeometryUtil.cpp: In member function ‘CubitBoolean GeometryUtil::valid_sm_topology(Shell*, CubitBoolean)’: ../../trunk/geom/GeometryUtil.cpp:2415: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘Shell*’ ../../trunk/geom/GeometryUtil.cpp:2432: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’ ../../trunk/geom/GeometryUtil.cpp:2432: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘Shell*’ ../../trunk/geom/GeometryUtil.cpp:2506: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’ ../../trunk/geom/GeometryUtil.cpp:2506: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘Shell*’ ../../trunk/geom/GeometryUtil.cpp: In member function ‘CubitBoolean GeometryUtil::valid_sm_topology(RefFace*, CubitBoolean)’: ../../trunk/geom/GeometryUtil.cpp:2612: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’ ../../trunk/geom/GeometryUtil.cpp: In member function ‘CubitBoolean GeometryUtil::valid_sm_topology(Loop*, CubitBoolean)’: ../../trunk/geom/GeometryUtil.cpp:2649: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘Loop*’ ../../trunk/geom/GeometryUtil.cpp:2742: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’ ../../trunk/geom/GeometryUtil.cpp:2742: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘Loop*’ ../../trunk/geom/GeometryUtil.cpp:2778: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘Loop*’ ../../trunk/geom/GeometryUtil.cpp:2778: warning: format ‘%p’ expects type ‘void*’, but argument 6 has type ‘TopologyBridge*’ ../../trunk/geom/GeometryUtil.cpp:2799: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘Loop*’ ../../trunk/geom/GeometryUtil.cpp:2799: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘TopologyBridge*’ ../../trunk/geom/GeometryUtil.cpp:2822: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘Loop*’ ../../trunk/geom/GeometryUtil.cpp:2822: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘TopologyBridge*’ ../../trunk/geom/GeometryUtil.cpp:2839: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘Loop*’ ../../trunk/geom/GeometryUtil.cpp:2839: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘TopologyBridge*’ ../../trunk/geom/GeometryUtil.cpp: In member function ‘CubitBoolean GeometryUtil::valid_sm_topology(CoEdge*, CubitBoolean)’: ../../trunk/geom/GeometryUtil.cpp:2872: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘CoEdge*’ ../../trunk/geom/GeometryUtil.cpp:2893: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘CoEdgeSM*’ ../../trunk/geom/GeometryUtil.cpp:2893: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CoEdge*’ ../../trunk/geom/GeometryUtil.cpp:2913: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’ ../../trunk/geom/GeometryUtil.cpp:2970: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘CoEdge*’ ../../trunk/geom/GeometryUtil.cpp:3014: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’ ../../trunk/geom/GeometryUtil.cpp:3014: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CoEdge*’ ../../trunk/geom/GeometryUtil.cpp: In member function ‘CubitBoolean GeometryUtil::valid_sm_topology(RefEdge*, CubitBoolean)’: ../../trunk/geom/GeometryUtil.cpp:3111: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’ ../../trunk/geom/GeometryUtil.cpp: In member function ‘CubitBoolean GeometryUtil::valid_sm_topology(RefVertex*, CubitBoolean)’: ../../trunk/geom/GeometryUtil.cpp:3156: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’ mv -f .deps/GeometryUtil.Tpo .deps/GeometryUtil.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeomMeasureTool.lo -MD -MP -MF .deps/GeomMeasureTool.Tpo -c -o GeomMeasureTool.lo ../../trunk/geom/GeomMeasureTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GeomMeasureTool.lo -MD -MP -MF .deps/GeomMeasureTool.Tpo -c ../../trunk/geom/GeomMeasureTool.cpp -o GeomMeasureTool.o ../../trunk/geom/GeomMeasureTool.cpp: In static member function ‘static void GeomMeasureTool::report_intersected_volumes(DLIList<RefVolume*>&, DLIList<RefVolume*>&)’: ../../trunk/geom/GeomMeasureTool.cpp:1182: warning: unused variable ‘curr_vol_2’ mv -f .deps/GeomMeasureTool.Tpo .deps/GeomMeasureTool.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GfxPreview.lo -MD -MP -MF .deps/GfxPreview.Tpo -c -o GfxPreview.lo ../../trunk/geom/GfxPreview.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GfxPreview.lo -MD -MP -MF .deps/GfxPreview.Tpo -c ../../trunk/geom/GfxPreview.cpp -o GfxPreview.o mv -f .deps/GfxPreview.Tpo .deps/GfxPreview.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GroupingEntity.lo -MD -MP -MF .deps/GroupingEntity.Tpo -c -o GroupingEntity.lo ../../trunk/geom/GroupingEntity.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GroupingEntity.lo -MD -MP -MF .deps/GroupingEntity.Tpo -c ../../trunk/geom/GroupingEntity.cpp -o GroupingEntity.o mv -f .deps/GroupingEntity.Tpo .deps/GroupingEntity.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GSaveOpen.lo -MD -MP -MF .deps/GSaveOpen.Tpo -c -o GSaveOpen.lo ../../trunk/geom/GSaveOpen.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT GSaveOpen.lo -MD -MP -MF .deps/GSaveOpen.Tpo -c ../../trunk/geom/GSaveOpen.cpp -o GSaveOpen.o mv -f .deps/GSaveOpen.Tpo .deps/GSaveOpen.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT Loop.lo -MD -MP -MF .deps/Loop.Tpo -c -o Loop.lo ../../trunk/geom/Loop.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT Loop.lo -MD -MP -MF .deps/Loop.Tpo -c ../../trunk/geom/Loop.cpp -o Loop.o mv -f .deps/Loop.Tpo .deps/Loop.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT LoopSM.lo -MD -MP -MF .deps/LoopSM.Tpo -c -o LoopSM.lo ../../trunk/geom/LoopSM.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT LoopSM.lo -MD -MP -MF .deps/LoopSM.Tpo -c ../../trunk/geom/LoopSM.cpp -o LoopSM.o mv -f .deps/LoopSM.Tpo .deps/LoopSM.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT Lump.lo -MD -MP -MF .deps/Lump.Tpo -c -o Lump.lo ../../trunk/geom/Lump.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT Lump.lo -MD -MP -MF .deps/Lump.Tpo -c ../../trunk/geom/Lump.cpp -o Lump.o mv -f .deps/Lump.Tpo .deps/Lump.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT LumpSM.lo -MD -MP -MF .deps/LumpSM.Tpo -c -o LumpSM.lo ../../trunk/geom/LumpSM.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT LumpSM.lo -MD -MP -MF .deps/LumpSM.Tpo -c ../../trunk/geom/LumpSM.cpp -o LumpSM.o mv -f .deps/LumpSM.Tpo .deps/LumpSM.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT MedialTool2D.lo -MD -MP -MF .deps/MedialTool2D.Tpo -c -o MedialTool2D.lo ../../trunk/geom/MedialTool2D.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT MedialTool2D.lo -MD -MP -MF .deps/MedialTool2D.Tpo -c ../../trunk/geom/MedialTool2D.cpp -o MedialTool2D.o mv -f .deps/MedialTool2D.Tpo .deps/MedialTool2D.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT MedialTool3D.lo -MD -MP -MF .deps/MedialTool3D.Tpo -c -o MedialTool3D.lo ../../trunk/geom/MedialTool3D.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT MedialTool3D.lo -MD -MP -MF .deps/MedialTool3D.Tpo -c ../../trunk/geom/MedialTool3D.cpp -o MedialTool3D.o mv -f .deps/MedialTool3D.Tpo .deps/MedialTool3D.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT MergeToolAssistant.lo -MD -MP -MF .deps/MergeToolAssistant.Tpo -c -o MergeToolAssistant.lo ../../trunk/geom/MergeToolAssistant.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT MergeToolAssistant.lo -MD -MP -MF .deps/MergeToolAssistant.Tpo -c ../../trunk/geom/MergeToolAssistant.cpp -o MergeToolAssistant.o mv -f .deps/MergeToolAssistant.Tpo .deps/MergeToolAssistant.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT MergeTool.lo -MD -MP -MF .deps/MergeTool.Tpo -c -o MergeTool.lo ../../trunk/geom/MergeTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT MergeTool.lo -MD -MP -MF .deps/MergeTool.Tpo -c ../../trunk/geom/MergeTool.cpp -o MergeTool.o ../../trunk/geom/MergeTool.cpp: In member function ‘CubitStatus MergeTool::find_mergeable_refedges(DLIList<RefEntity*>&, DLIList<DLIList<RefEdge*>*>&, bool)’: ../../trunk/geom/MergeTool.cpp:1282: warning: unused variable ‘retained_id’ ../../trunk/geom/MergeTool.cpp:1283: warning: unused variable ‘deleted_id’ ../../trunk/geom/MergeTool.cpp: In member function ‘CubitStatus MergeTool::find_mergeable_refvertices(DLIList<RefEntity*>&, DLIList<DLIList<RefVertex*>*>&, bool)’: ../../trunk/geom/MergeTool.cpp:1622: warning: unused variable ‘retained_id’ ../../trunk/geom/MergeTool.cpp:1623: warning: unused variable ‘deleted_id’ mv -f .deps/MergeTool.Tpo .deps/MergeTool.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT MidPlaneTool.lo -MD -MP -MF .deps/MidPlaneTool.Tpo -c -o MidPlaneTool.lo ../../trunk/geom/MidPlaneTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT MidPlaneTool.lo -MD -MP -MF .deps/MidPlaneTool.Tpo -c ../../trunk/geom/MidPlaneTool.cpp -o MidPlaneTool.o mv -f .deps/MidPlaneTool.Tpo .deps/MidPlaneTool.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT ModelEntity.lo -MD -MP -MF .deps/ModelEntity.Tpo -c -o ModelEntity.lo ../../trunk/geom/ModelEntity.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT ModelEntity.lo -MD -MP -MF .deps/ModelEntity.Tpo -c ../../trunk/geom/ModelEntity.cpp -o ModelEntity.o mv -f .deps/ModelEntity.Tpo .deps/ModelEntity.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT ModelQueryEngine.lo -MD -MP -MF .deps/ModelQueryEngine.Tpo -c -o ModelQueryEngine.lo ../../trunk/geom/ModelQueryEngine.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT ModelQueryEngine.lo -MD -MP -MF .deps/ModelQueryEngine.Tpo -c ../../trunk/geom/ModelQueryEngine.cpp -o ModelQueryEngine.o mv -f .deps/ModelQueryEngine.Tpo .deps/ModelQueryEngine.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT OffsetSplitTool.lo -MD -MP -MF .deps/OffsetSplitTool.Tpo -c -o OffsetSplitTool.lo ../../trunk/geom/OffsetSplitTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT OffsetSplitTool.lo -MD -MP -MF .deps/OffsetSplitTool.Tpo -c ../../trunk/geom/OffsetSplitTool.cpp -o OffsetSplitTool.o mv -f .deps/OffsetSplitTool.Tpo .deps/OffsetSplitTool.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT OldUnmergeCode.lo -MD -MP -MF .deps/OldUnmergeCode.Tpo -c -o OldUnmergeCode.lo ../../trunk/geom/OldUnmergeCode.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT OldUnmergeCode.lo -MD -MP -MF .deps/OldUnmergeCode.Tpo -c ../../trunk/geom/OldUnmergeCode.cpp -o OldUnmergeCode.o ../../trunk/geom/OldUnmergeCode.cpp: In static member function ‘static void OldUnmergeCode::initialize_settings()’: ../../trunk/geom/OldUnmergeCode.cpp:40: warning: deprecated conversion from string constant to ‘char*’ mv -f .deps/OldUnmergeCode.Tpo .deps/OldUnmergeCode.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT Point.lo -MD -MP -MF .deps/Point.Tpo -c -o Point.lo ../../trunk/geom/Point.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT Point.lo -MD -MP -MF .deps/Point.Tpo -c ../../trunk/geom/Point.cpp -o Point.o mv -f .deps/Point.Tpo .deps/Point.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT PointSM.lo -MD -MP -MF .deps/PointSM.Tpo -c -o PointSM.lo ../../trunk/geom/PointSM.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT PointSM.lo -MD -MP -MF .deps/PointSM.Tpo -c ../../trunk/geom/PointSM.cpp -o PointSM.o mv -f .deps/PointSM.Tpo .deps/PointSM.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT RefCollection.lo -MD -MP -MF .deps/RefCollection.Tpo -c -o RefCollection.lo ../../trunk/geom/RefCollection.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT RefCollection.lo -MD -MP -MF .deps/RefCollection.Tpo -c ../../trunk/geom/RefCollection.cpp -o RefCollection.o mv -f .deps/RefCollection.Tpo .deps/RefCollection.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT RefEdge.lo -MD -MP -MF .deps/RefEdge.Tpo -c -o RefEdge.lo ../../trunk/geom/RefEdge.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT RefEdge.lo -MD -MP -MF .deps/RefEdge.Tpo -c ../../trunk/geom/RefEdge.cpp -o RefEdge.o mv -f .deps/RefEdge.Tpo .deps/RefEdge.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT RefEntity.lo -MD -MP -MF .deps/RefEntity.Tpo -c -o RefEntity.lo ../../trunk/geom/RefEntity.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT RefEntity.lo -MD -MP -MF .deps/RefEntity.Tpo -c ../../trunk/geom/RefEntity.cpp -o RefEntity.o mv -f .deps/RefEntity.Tpo .deps/RefEntity.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT RefEntityFactory.lo -MD -MP -MF .deps/RefEntityFactory.Tpo -c -o RefEntityFactory.lo ../../trunk/geom/RefEntityFactory.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT RefEntityFactory.lo -MD -MP -MF .deps/RefEntityFactory.Tpo -c ../../trunk/geom/RefEntityFactory.cpp -o RefEntityFactory.o mv -f .deps/RefEntityFactory.Tpo .deps/RefEntityFactory.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT RefEntityName.lo -MD -MP -MF .deps/RefEntityName.Tpo -c -o RefEntityName.lo ../../trunk/geom/RefEntityName.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT RefEntityName.lo -MD -MP -MF .deps/RefEntityName.Tpo -c ../../trunk/geom/RefEntityName.cpp -o RefEntityName.o ../../trunk/geom/RefEntityName.cpp: In static member function ‘static void RefEntityName::initialize_settings()’: ../../trunk/geom/RefEntityName.cpp:743: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/RefEntityName.cpp:747: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/RefEntityName.cpp:751: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/RefEntityName.cpp:755: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/RefEntityName.cpp:759: warning: deprecated conversion from string constant to ‘char*’ mv -f .deps/RefEntityName.Tpo .deps/RefEntityName.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT RefFace.lo -MD -MP -MF .deps/RefFace.Tpo -c -o RefFace.lo ../../trunk/geom/RefFace.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT RefFace.lo -MD -MP -MF .deps/RefFace.Tpo -c ../../trunk/geom/RefFace.cpp -o RefFace.o mv -f .deps/RefFace.Tpo .deps/RefFace.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT RefGroup.lo -MD -MP -MF .deps/RefGroup.Tpo -c -o RefGroup.lo ../../trunk/geom/RefGroup.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT RefGroup.lo -MD -MP -MF .deps/RefGroup.Tpo -c ../../trunk/geom/RefGroup.cpp -o RefGroup.o mv -f .deps/RefGroup.Tpo .deps/RefGroup.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT RefVertex.lo -MD -MP -MF .deps/RefVertex.Tpo -c -o RefVertex.lo ../../trunk/geom/RefVertex.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT RefVertex.lo -MD -MP -MF .deps/RefVertex.Tpo -c ../../trunk/geom/RefVertex.cpp -o RefVertex.o mv -f .deps/RefVertex.Tpo .deps/RefVertex.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT RefVolume.lo -MD -MP -MF .deps/RefVolume.Tpo -c -o RefVolume.lo ../../trunk/geom/RefVolume.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT RefVolume.lo -MD -MP -MF .deps/RefVolume.Tpo -c ../../trunk/geom/RefVolume.cpp -o RefVolume.o mv -f .deps/RefVolume.Tpo .deps/RefVolume.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT SenseEntity.lo -MD -MP -MF .deps/SenseEntity.Tpo -c -o SenseEntity.lo ../../trunk/geom/SenseEntity.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT SenseEntity.lo -MD -MP -MF .deps/SenseEntity.Tpo -c ../../trunk/geom/SenseEntity.cpp -o SenseEntity.o mv -f .deps/SenseEntity.Tpo .deps/SenseEntity.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT Shell.lo -MD -MP -MF .deps/Shell.Tpo -c -o Shell.lo ../../trunk/geom/Shell.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT Shell.lo -MD -MP -MF .deps/Shell.Tpo -c ../../trunk/geom/Shell.cpp -o Shell.o mv -f .deps/Shell.Tpo .deps/Shell.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT ShellSM.lo -MD -MP -MF .deps/ShellSM.Tpo -c -o ShellSM.lo ../../trunk/geom/ShellSM.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT ShellSM.lo -MD -MP -MF .deps/ShellSM.Tpo -c ../../trunk/geom/ShellSM.cpp -o ShellSM.o mv -f .deps/ShellSM.Tpo .deps/ShellSM.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT SphereEvaluator.lo -MD -MP -MF .deps/SphereEvaluator.Tpo -c -o SphereEvaluator.lo ../../trunk/geom/SphereEvaluator.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT SphereEvaluator.lo -MD -MP -MF .deps/SphereEvaluator.Tpo -c ../../trunk/geom/SphereEvaluator.cpp -o SphereEvaluator.o mv -f .deps/SphereEvaluator.Tpo .deps/SphereEvaluator.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT SplitSurfaceTool.lo -MD -MP -MF .deps/SplitSurfaceTool.Tpo -c -o SplitSurfaceTool.lo ../../trunk/geom/SplitSurfaceTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT SplitSurfaceTool.lo -MD -MP -MF .deps/SplitSurfaceTool.Tpo -c ../../trunk/geom/SplitSurfaceTool.cpp -o SplitSurfaceTool.o ../../trunk/geom/SplitSurfaceTool.cpp: In static member function ‘static void SplitSurfaceTool::initialize_settings()’: ../../trunk/geom/SplitSurfaceTool.cpp:77: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SplitSurfaceTool.cpp:81: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SplitSurfaceTool.cpp:85: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SplitSurfaceTool.cpp:89: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SplitSurfaceTool.cpp:93: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SplitSurfaceTool.cpp: In member function ‘CubitStatus SplitSurfaceTool::adjust_for_split_direction(RefEdge*, RefEdge*, DLIList<RefVertex*>&)’: ../../trunk/geom/SplitSurfaceTool.cpp:3445: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SplitSurfaceTool.cpp:3480: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SplitSurfaceTool.cpp:3561: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SplitSurfaceTool.cpp:3593: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SplitSurfaceTool.cpp:3618: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SplitSurfaceTool.cpp: In member function ‘CubitStatus SplitSurfaceTool::check_through_vertices(char*)’: ../../trunk/geom/SplitSurfaceTool.cpp:3840: warning: too few arguments for format ../../trunk/geom/SplitSurfaceTool.cpp: In member function ‘Curve* SplitSurfaceTool::create_curve(DLIList<CubitVector*>&, Surface*, double, CubitBoolean, CubitBoolean, CubitBoolean)’: ../../trunk/geom/SplitSurfaceTool.cpp:5647: warning: suggest explicit braces to avoid ambiguous ‘else’ mv -f .deps/SplitSurfaceTool.Tpo .deps/SplitSurfaceTool.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT Surface.lo -MD -MP -MF .deps/Surface.Tpo -c -o Surface.lo ../../trunk/geom/Surface.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT Surface.lo -MD -MP -MF .deps/Surface.Tpo -c ../../trunk/geom/Surface.cpp -o Surface.o mv -f .deps/Surface.Tpo .deps/Surface.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT SurfaceOverlapFacet.lo -MD -MP -MF .deps/SurfaceOverlapFacet.Tpo -c -o SurfaceOverlapFacet.lo ../../trunk/geom/SurfaceOverlapFacet.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT SurfaceOverlapFacet.lo -MD -MP -MF .deps/SurfaceOverlapFacet.Tpo -c ../../trunk/geom/SurfaceOverlapFacet.cpp -o SurfaceOverlapFacet.o mv -f .deps/SurfaceOverlapFacet.Tpo .deps/SurfaceOverlapFacet.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT SurfaceOverlapTool.lo -MD -MP -MF .deps/SurfaceOverlapTool.Tpo -c -o SurfaceOverlapTool.lo ../../trunk/geom/SurfaceOverlapTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT SurfaceOverlapTool.lo -MD -MP -MF .deps/SurfaceOverlapTool.Tpo -c ../../trunk/geom/SurfaceOverlapTool.cpp -o SurfaceOverlapTool.o ../../trunk/geom/SurfaceOverlapTool.cpp: In member function ‘CubitBoolean SurfaceOverlapTool::check_overlap(Surface*, Surface*, std::map<Surface*, DLIList<SurfaceOverlapFacet*>*, std::less<Surface*>, std::allocator<std::pair<Surface* const, DLIList<SurfaceOverlapFacet*>*> > >*, std::map<Surface*, double, std::less<Surface*>, std::allocator<std::pair<Surface* const, double> > >*, std::map<Surface*, AbstractTree<SurfaceOverlapFacet*>*, std::less<Surface*>, std::allocator<std::pair<Surface* const, AbstractTree<SurfaceOverlapFacet*>*> > >*)’: ../../trunk/geom/SurfaceOverlapTool.cpp:816: warning: unused variable ‘num_samples’ ../../trunk/geom/SurfaceOverlapTool.cpp: In static member function ‘static void SurfaceOverlapTool::initialize_settings()’: ../../trunk/geom/SurfaceOverlapTool.cpp:1406: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SurfaceOverlapTool.cpp:1410: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SurfaceOverlapTool.cpp:1414: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SurfaceOverlapTool.cpp:1418: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SurfaceOverlapTool.cpp:1422: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SurfaceOverlapTool.cpp:1426: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SurfaceOverlapTool.cpp:1430: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SurfaceOverlapTool.cpp:1434: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SurfaceOverlapTool.cpp:1438: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SurfaceOverlapTool.cpp:1442: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SurfaceOverlapTool.cpp:1446: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SurfaceOverlapTool.cpp:1450: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SurfaceOverlapTool.cpp:1454: warning: deprecated conversion from string constant to ‘char*’ ../../trunk/geom/SurfaceOverlapTool.cpp: In member function ‘CubitStatus SurfaceOverlapTool::find_overlapping_curves(DLIList<Body*>&, std::multimap<RefEdge*, RefEdge*, std::less<RefEdge*>, std::allocator<std::pair<RefEdge* const, RefEdge*> > >&)’: ../../trunk/geom/SurfaceOverlapTool.cpp:1620: warning: unused variable ‘co_facet_list’ mv -f .deps/SurfaceOverlapTool.Tpo .deps/SurfaceOverlapTool.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT SurfParamTool.lo -MD -MP -MF .deps/SurfParamTool.Tpo -c -o SurfParamTool.lo ../../trunk/geom/SurfParamTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT SurfParamTool.lo -MD -MP -MF .deps/SurfParamTool.Tpo -c ../../trunk/geom/SurfParamTool.cpp -o SurfParamTool.o mv -f .deps/SurfParamTool.Tpo .deps/SurfParamTool.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT SurfaceSM.lo -MD -MP -MF .deps/SurfaceSM.Tpo -c -o SurfaceSM.lo ../../trunk/geom/SurfaceSM.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT SurfaceSM.lo -MD -MP -MF .deps/SurfaceSM.Tpo -c ../../trunk/geom/SurfaceSM.cpp -o SurfaceSM.o mv -f .deps/SurfaceSM.Tpo .deps/SurfaceSM.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT TDCAGE.lo -MD -MP -MF .deps/TDCAGE.Tpo -c -o TDCAGE.lo ../../trunk/geom/TDCAGE.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT TDCAGE.lo -MD -MP -MF .deps/TDCAGE.Tpo -c ../../trunk/geom/TDCAGE.cpp -o TDCAGE.o mv -f .deps/TDCAGE.Tpo .deps/TDCAGE.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT TDSourceFeature.lo -MD -MP -MF .deps/TDSourceFeature.Tpo -c -o TDSourceFeature.lo ../../trunk/geom/TDSourceFeature.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT TDSourceFeature.lo -MD -MP -MF .deps/TDSourceFeature.Tpo -c ../../trunk/geom/TDSourceFeature.cpp -o TDSourceFeature.o mv -f .deps/TDSourceFeature.Tpo .deps/TDSourceFeature.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT TDSplitSurface.lo -MD -MP -MF .deps/TDSplitSurface.Tpo -c -o TDSplitSurface.lo ../../trunk/geom/TDSplitSurface.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT TDSplitSurface.lo -MD -MP -MF .deps/TDSplitSurface.Tpo -c ../../trunk/geom/TDSplitSurface.cpp -o TDSplitSurface.o mv -f .deps/TDSplitSurface.Tpo .deps/TDSplitSurface.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT TDSurfaceOverlap.lo -MD -MP -MF .deps/TDSurfaceOverlap.Tpo -c -o TDSurfaceOverlap.lo ../../trunk/geom/TDSurfaceOverlap.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT TDSurfaceOverlap.lo -MD -MP -MF .deps/TDSurfaceOverlap.Tpo -c ../../trunk/geom/TDSurfaceOverlap.cpp -o TDSurfaceOverlap.o mv -f .deps/TDSurfaceOverlap.Tpo .deps/TDSurfaceOverlap.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT TDUniqueId.lo -MD -MP -MF .deps/TDUniqueId.Tpo -c -o TDUniqueId.lo ../../trunk/geom/TDUniqueId.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT TDUniqueId.lo -MD -MP -MF .deps/TDUniqueId.Tpo -c ../../trunk/geom/TDUniqueId.cpp -o TDUniqueId.o mv -f .deps/TDUniqueId.Tpo .deps/TDUniqueId.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT TopologyBridge.lo -MD -MP -MF .deps/TopologyBridge.Tpo -c -o TopologyBridge.lo ../../trunk/geom/TopologyBridge.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT TopologyBridge.lo -MD -MP -MF .deps/TopologyBridge.Tpo -c ../../trunk/geom/TopologyBridge.cpp -o TopologyBridge.o mv -f .deps/TopologyBridge.Tpo .deps/TopologyBridge.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT TopologyEntity.lo -MD -MP -MF .deps/TopologyEntity.Tpo -c -o TopologyEntity.lo ../../trunk/geom/TopologyEntity.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../trunk/geom -I.. -I../itaps -I../../trunk/util -I. -Wall -pipe -pedantic -g -m32 -MT TopologyEntity.lo -MD -MP -MF .deps/TopologyEntity.Tpo -c ../../trunk/geom/TopologyEntity.cpp -o TopologyEntity.o mv -f .deps/TopologyEntity.Tpo .deps/TopologyEntity.Plo /bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -m32 -o libcubit_geom.la AllocMemManagersGeom.lo AnalyticGeometryTool.lo BasicTopologyEntity.lo Body.lo BodySM.lo BoundingBoxTool.lo BridgeManager.lo CAActuateSet.lo CADeferredAttrib.lo CAEntityColor.lo CAEntityId.lo CAEntityName.lo CAGroup.lo CAMergePartner.lo CAMergeStatus.lo CASourceFeature.lo CAUniqueId.lo CGMApp.lo CGMEngineDynamicLoader.lo Chain.lo CoEdge.lo CoEdgeSM.lo CoFace.lo CollectionEntity.lo CoVertex.lo CoVolume.lo CubitAttrib.lo CubitAttribManager.lo CubitAttribUser.lo CubitPolygon.lo CubitSimpleAttrib.lo Curve.lo CurveOverlapFacet.lo CurveSM.lo CylinderEvaluator.lo DAG.lo DagDrawingTool.lo GeomDataObserver.lo GeometryEntity.lo GeometryFeatureEngine.lo GeometryFeatureTool.lo GeometryHealerEngine.lo GeometryHealerTool.lo GeometryModifyEngine.lo GeometryModifyTool.lo GeometryQueryEngine.lo GeometryQueryTool.lo GeometryUtil.lo GeomMeasureTool.lo GfxPreview.lo GroupingEntity.lo GSaveOpen.l! o Loop.lo LoopSM.lo Lump.lo LumpSM.lo MedialTool2D.lo MedialTool3D.lo MergeToolAssistant.lo MergeTool.lo MidPlaneTool.lo ModelEntity.lo ModelQueryEngine.lo OffsetSplitTool.lo OldUnmergeCode.lo Point.lo PointSM.lo RefCollection.lo RefEdge.lo RefEntity.lo RefEntityFactory.lo RefEntityName.lo RefFace.lo RefGroup.lo RefVertex.lo RefVolume.lo SenseEntity.lo Shell.lo ShellSM.lo SphereEvaluator.lo SplitSurfaceTool.lo Surface.lo SurfaceOverlapFacet.lo SurfaceOverlapTool.lo SurfParamTool.lo SurfaceSM.lo TDCAGE.lo TDSourceFeature.lo TDSplitSurface.lo TDSurfaceOverlap.lo TDUniqueId.lo TopologyBridge.lo TopologyEntity.lo -lm rm -fr .libs/libcubit_geom.a .libs/libcubit_geom.la ar cru .libs/libcubit_geom.a AllocMemManagersGeom.o AnalyticGeometryTool.o BasicTopologyEntity.o Body.o BodySM.o BoundingBoxTool.o BridgeManager.o CAActuateSet.o CADeferredAttrib.o CAEntityColor.o CAEntityId.o CAEntityName.o CAGroup.o CAMergePartner.o CAMergeStatus.o CASourceFeature.o CAUniqueId.o CGMApp.o CGMEngineDynamicLoader.o Chain.o CoEdge.o CoEdgeSM.o CoFace.o CollectionEntity.o CoVertex.o CoVolume.o CubitAttrib.o CubitAttribManager.o CubitAttribUser.o CubitPolygon.o CubitSimpleAttrib.o Curve.o CurveOverlapFacet.o CurveSM.o CylinderEvaluator.o DAG.o DagDrawingTool.o GeomDataObserver.o GeometryEntity.o GeometryFeatureEngine.o GeometryFeatureTool.o GeometryHealerEngine.o GeometryHealerTool.o GeometryModifyEngine.o GeometryModifyTool.o GeometryQueryEngine.o GeometryQueryTool.o GeometryUtil.o GeomMeasureTool.o GfxPreview.o GroupingEntity.o GSaveOpen.o Loop.o LoopSM.o Lump.o LumpSM.o MedialTool2D.o MedialTool3D.o MergeToolAssistant.o MergeTool.o MidPlaneTool.o ModelEntity! .o ModelQueryEngine.o OffsetSplitTool.o OldUnmergeCode.o Point.o PointSM.o RefCollection.o RefEdge.o RefEntity.o RefEntityFactory.o RefEntityName.o RefFace.o RefGroup.o RefVertex.o RefVolume.o SenseEntity.o Shell.o ShellSM.o SphereEvaluator.o SplitSurfaceTool.o Surface.o SurfaceOverlapFacet.o SurfaceOverlapTool.o SurfParamTool.o SurfaceSM.o TDCAGE.o TDSourceFeature.o TDSplitSurface.o TDSurfaceOverlap.o TDUniqueId.o TopologyBridge.o TopologyEntity.o ranlib .libs/libcubit_geom.a creating libcubit_geom.la (cd .libs && rm -f libcubit_geom.la && ln -s ../libcubit_geom.la libcubit_geom.la) make[3]: Leaving directory `/home/jason/cgm/test/32-occ/geom' Making all in Cholla make[3]: Entering directory `/home/jason/cgm/test/32-occ/geom/Cholla' /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT AllocMemManagersCholla.lo -MD -MP -MF .deps/AllocMemManagersCholla.Tpo -c -o AllocMemManagersCholla.lo ../../../trunk/geom/Cholla/AllocMemManagersCholla.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT AllocMemManagersCholla.lo -MD -MP -MF .deps/AllocMemManagersCholla.Tpo -c ../../../trunk/geom/Cholla/AllocMemManagersCholla.cpp -o AllocMemManagersCholla.o mv -f .deps/AllocMemManagersCholla.Tpo .deps/AllocMemManagersCholla.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT Cholla.lo -MD -MP -MF .deps/Cholla.Tpo -c -o Cholla.lo ../../../trunk/geom/Cholla/Cholla.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT Cholla.lo -MD -MP -MF .deps/Cholla.Tpo -c ../../../trunk/geom/Cholla/Cholla.cpp -o Cholla.o ../../../trunk/geom/Cholla/Cholla.cpp: In function ‘void constructQuadNormals(double, int, int, int, int*, int*, double*, double*, double*, int*)’: ../../../trunk/geom/Cholla/Cholla.cpp:437: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:437: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:437: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:438: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:438: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:438: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:439: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:439: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:439: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:440: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:440: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:440: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:441: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:441: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:441: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp: In function ‘CubitStatus build_facets(int, int, int, int, int*, int*, int*, double*, CubitPoint**, CubitFacetEdge**, CubitFacet**, CubitQuadFacet**, DLIList<FacetEntity*>&)’: ../../../trunk/geom/Cholla/Cholla.cpp:599: warning: deprecated conversion from string constant to ‘char*’ ../../../trunk/geom/Cholla/Cholla.cpp: In function ‘void evalBezierFaceFromNorms(int, int, int, int, int*, int*, double*, double*, double*, int, double*, double*, double*, double*)’: ../../../trunk/geom/Cholla/Cholla.cpp:893: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:893: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:893: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:894: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:894: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:894: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:895: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:895: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:895: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:896: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:896: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:896: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:897: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:897: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:897: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp: In function ‘void evalBezierEdgeFromTans(int, int, int*, double*, double*, int, double*, double*, double*)’: ../../../trunk/geom/Cholla/Cholla.cpp:1904: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:1904: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:1904: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:1905: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:1905: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:1905: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:1906: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:1906: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:1906: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:1907: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:1907: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:1907: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:1908: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:1908: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/Cholla.cpp:1908: warning: ISO C++ does not support the ‘%lf’ printf format mv -f .deps/Cholla.Tpo .deps/Cholla.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT ChollaCurve.lo -MD -MP -MF .deps/ChollaCurve.Tpo -c -o ChollaCurve.lo ../../../trunk/geom/Cholla/ChollaCurve.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT ChollaCurve.lo -MD -MP -MF .deps/ChollaCurve.Tpo -c ../../../trunk/geom/Cholla/ChollaCurve.cpp -o ChollaCurve.o ../../../trunk/geom/Cholla/ChollaCurve.cpp: In member function ‘CubitStatus ChollaCurve::determine_ends()’: ../../../trunk/geom/Cholla/ChollaCurve.cpp:445: warning: suggest parentheses around && within || mv -f .deps/ChollaCurve.Tpo .deps/ChollaCurve.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT ChollaEngine.lo -MD -MP -MF .deps/ChollaEngine.Tpo -c -o ChollaEngine.lo ../../../trunk/geom/Cholla/ChollaEngine.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT ChollaEngine.lo -MD -MP -MF .deps/ChollaEngine.Tpo -c ../../../trunk/geom/Cholla/ChollaEngine.cpp -o ChollaEngine.o ../../../trunk/geom/Cholla/ChollaEngine.cpp: In member function ‘CubitStatus ChollaEngine::create_geometry(CubitBoolean, double, int, CubitBoolean, CubitBoolean)’: ../../../trunk/geom/Cholla/ChollaEngine.cpp:233: warning: deprecated conversion from string constant to ‘char*’ mv -f .deps/ChollaEngine.Tpo .deps/ChollaEngine.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT ChollaEntity.lo -MD -MP -MF .deps/ChollaEntity.Tpo -c -o ChollaEntity.lo ../../../trunk/geom/Cholla/ChollaEntity.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT ChollaEntity.lo -MD -MP -MF .deps/ChollaEntity.Tpo -c ../../../trunk/geom/Cholla/ChollaEntity.cpp -o ChollaEntity.o mv -f .deps/ChollaEntity.Tpo .deps/ChollaEntity.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT ChollaPoint.lo -MD -MP -MF .deps/ChollaPoint.Tpo -c -o ChollaPoint.lo ../../../trunk/geom/Cholla/ChollaPoint.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT ChollaPoint.lo -MD -MP -MF .deps/ChollaPoint.Tpo -c ../../../trunk/geom/Cholla/ChollaPoint.cpp -o ChollaPoint.o mv -f .deps/ChollaPoint.Tpo .deps/ChollaPoint.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT ChollaSkinTool.lo -MD -MP -MF .deps/ChollaSkinTool.Tpo -c -o ChollaSkinTool.lo ../../../trunk/geom/Cholla/ChollaSkinTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT ChollaSkinTool.lo -MD -MP -MF .deps/ChollaSkinTool.Tpo -c ../../../trunk/geom/Cholla/ChollaSkinTool.cpp -o ChollaSkinTool.o mv -f .deps/ChollaSkinTool.Tpo .deps/ChollaSkinTool.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT ChollaSurface.lo -MD -MP -MF .deps/ChollaSurface.Tpo -c -o ChollaSurface.lo ../../../trunk/geom/Cholla/ChollaSurface.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT ChollaSurface.lo -MD -MP -MF .deps/ChollaSurface.Tpo -c ../../../trunk/geom/Cholla/ChollaSurface.cpp -o ChollaSurface.o mv -f .deps/ChollaSurface.Tpo .deps/ChollaSurface.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT ChordalAxis.lo -MD -MP -MF .deps/ChordalAxis.Tpo -c -o ChordalAxis.lo ../../../trunk/geom/Cholla/ChordalAxis.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT ChordalAxis.lo -MD -MP -MF .deps/ChordalAxis.Tpo -c ../../../trunk/geom/Cholla/ChordalAxis.cpp -o ChordalAxis.o mv -f .deps/ChordalAxis.Tpo .deps/ChordalAxis.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT CubitFacet.lo -MD -MP -MF .deps/CubitFacet.Tpo -c -o CubitFacet.lo ../../../trunk/geom/Cholla/CubitFacet.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT CubitFacet.lo -MD -MP -MF .deps/CubitFacet.Tpo -c ../../../trunk/geom/Cholla/CubitFacet.cpp -o CubitFacet.o ../../../trunk/geom/Cholla/CubitFacet.cpp: In member function ‘CubitFacetEdge* CubitFacet::edge_from_pts(CubitPoint*, CubitPoint*, int&)’: ../../../trunk/geom/Cholla/CubitFacet.cpp:780: warning: suggest parentheses around && within || ../../../trunk/geom/Cholla/CubitFacet.cpp:785: warning: suggest parentheses around && within || ../../../trunk/geom/Cholla/CubitFacet.cpp:790: warning: suggest parentheses around && within || mv -f .deps/CubitFacet.Tpo .deps/CubitFacet.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT CubitFacetData.lo -MD -MP -MF .deps/CubitFacetData.Tpo -c -o CubitFacetData.lo ../../../trunk/geom/Cholla/CubitFacetData.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT CubitFacetData.lo -MD -MP -MF .deps/CubitFacetData.Tpo -c ../../../trunk/geom/Cholla/CubitFacetData.cpp -o CubitFacetData.o mv -f .deps/CubitFacetData.Tpo .deps/CubitFacetData.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT CubitFacetEdge.lo -MD -MP -MF .deps/CubitFacetEdge.Tpo -c -o CubitFacetEdge.lo ../../../trunk/geom/Cholla/CubitFacetEdge.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT CubitFacetEdge.lo -MD -MP -MF .deps/CubitFacetEdge.Tpo -c ../../../trunk/geom/Cholla/CubitFacetEdge.cpp -o CubitFacetEdge.o mv -f .deps/CubitFacetEdge.Tpo .deps/CubitFacetEdge.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT CubitFacetEdgeData.lo -MD -MP -MF .deps/CubitFacetEdgeData.Tpo -c -o CubitFacetEdgeData.lo ../../../trunk/geom/Cholla/CubitFacetEdgeData.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT CubitFacetEdgeData.lo -MD -MP -MF .deps/CubitFacetEdgeData.Tpo -c ../../../trunk/geom/Cholla/CubitFacetEdgeData.cpp -o CubitFacetEdgeData.o mv -f .deps/CubitFacetEdgeData.Tpo .deps/CubitFacetEdgeData.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT CubitPoint.lo -MD -MP -MF .deps/CubitPoint.Tpo -c -o CubitPoint.lo ../../../trunk/geom/Cholla/CubitPoint.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT CubitPoint.lo -MD -MP -MF .deps/CubitPoint.Tpo -c ../../../trunk/geom/Cholla/CubitPoint.cpp -o CubitPoint.o mv -f .deps/CubitPoint.Tpo .deps/CubitPoint.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT CubitPointData.lo -MD -MP -MF .deps/CubitPointData.Tpo -c -o CubitPointData.lo ../../../trunk/geom/Cholla/CubitPointData.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT CubitPointData.lo -MD -MP -MF .deps/CubitPointData.Tpo -c ../../../trunk/geom/Cholla/CubitPointData.cpp -o CubitPointData.o mv -f .deps/CubitPointData.Tpo .deps/CubitPointData.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT CubitQuadFacet.lo -MD -MP -MF .deps/CubitQuadFacet.Tpo -c -o CubitQuadFacet.lo ../../../trunk/geom/Cholla/CubitQuadFacet.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT CubitQuadFacet.lo -MD -MP -MF .deps/CubitQuadFacet.Tpo -c ../../../trunk/geom/Cholla/CubitQuadFacet.cpp -o CubitQuadFacet.o mv -f .deps/CubitQuadFacet.Tpo .deps/CubitQuadFacet.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT CubitQuadFacetData.lo -MD -MP -MF .deps/CubitQuadFacetData.Tpo -c -o CubitQuadFacetData.lo ../../../trunk/geom/Cholla/CubitQuadFacetData.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT CubitQuadFacetData.lo -MD -MP -MF .deps/CubitQuadFacetData.Tpo -c ../../../trunk/geom/Cholla/CubitQuadFacetData.cpp -o CubitQuadFacetData.o mv -f .deps/CubitQuadFacetData.Tpo .deps/CubitQuadFacetData.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT CurveFacetEvalTool.lo -MD -MP -MF .deps/CurveFacetEvalTool.Tpo -c -o CurveFacetEvalTool.lo ../../../trunk/geom/Cholla/CurveFacetEvalTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT CurveFacetEvalTool.lo -MD -MP -MF .deps/CurveFacetEvalTool.Tpo -c ../../../trunk/geom/Cholla/CurveFacetEvalTool.cpp -o CurveFacetEvalTool.o ../../../trunk/geom/Cholla/CurveFacetEvalTool.cpp: In member function ‘void CurveFacetEvalTool::fix_point_edge_order()’: ../../../trunk/geom/Cholla/CurveFacetEvalTool.cpp:1937: warning: unused variable ‘this_pt0’ mv -f .deps/CurveFacetEvalTool.Tpo .deps/CurveFacetEvalTool.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT debug.lo -MD -MP -MF .deps/debug.Tpo -c -o debug.lo ../../../trunk/geom/Cholla/debug.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT debug.lo -MD -MP -MF .deps/debug.Tpo -c ../../../trunk/geom/Cholla/debug.cpp -o debug.o mv -f .deps/debug.Tpo .deps/debug.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FacetDataUtil.lo -MD -MP -MF .deps/FacetDataUtil.Tpo -c -o FacetDataUtil.lo ../../../trunk/geom/Cholla/FacetDataUtil.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FacetDataUtil.lo -MD -MP -MF .deps/FacetDataUtil.Tpo -c ../../../trunk/geom/Cholla/FacetDataUtil.cpp -o FacetDataUtil.o ../../../trunk/geom/Cholla/FacetDataUtil.cpp: In static member function ‘static CubitStatus FacetDataUtil::write_facets(char*, DLIList<CubitFacet*>&)’: ../../../trunk/geom/Cholla/FacetDataUtil.cpp:1274: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/FacetDataUtil.cpp:1274: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/FacetDataUtil.cpp:1274: warning: ISO C++ does not support the ‘%lf’ printf format ../../../trunk/geom/Cholla/FacetDataUtil.cpp: In static member function ‘static CubitStatus FacetDataUtil::merge_colinear_vertices(DLIList<DLIList<CubitFacet*>*>&, double, DLIList<CubitPoint*>&, int&, int&, int&)’: ../../../trunk/geom/Cholla/FacetDataUtil.cpp:1798: warning: ISO C++ does not support the ‘%lf’ printf format mv -f .deps/FacetDataUtil.Tpo .deps/FacetDataUtil.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FacetEntity.lo -MD -MP -MF .deps/FacetEntity.Tpo -c -o FacetEntity.lo ../../../trunk/geom/Cholla/FacetEntity.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FacetEntity.lo -MD -MP -MF .deps/FacetEntity.Tpo -c ../../../trunk/geom/Cholla/FacetEntity.cpp -o FacetEntity.o mv -f .deps/FacetEntity.Tpo .deps/FacetEntity.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FacetEvalTool.lo -MD -MP -MF .deps/FacetEvalTool.Tpo -c -o FacetEvalTool.lo ../../../trunk/geom/Cholla/FacetEvalTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FacetEvalTool.lo -MD -MP -MF .deps/FacetEvalTool.Tpo -c ../../../trunk/geom/Cholla/FacetEvalTool.cpp -o FacetEvalTool.o ../../../trunk/geom/Cholla/FacetEvalTool.cpp: In member function ‘CubitStatus FacetEvalTool::mark_edge_pairs(CubitPoint*)’: ../../../trunk/geom/Cholla/FacetEvalTool.cpp:532: warning: unused variable ‘status’ mv -f .deps/FacetEvalTool.Tpo .deps/FacetEvalTool.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT GeoNode.lo -MD -MP -MF .deps/GeoNode.Tpo -c -o GeoNode.lo ../../../trunk/geom/Cholla/GeoNode.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT GeoNode.lo -MD -MP -MF .deps/GeoNode.Tpo -c ../../../trunk/geom/Cholla/GeoNode.cpp -o GeoNode.o mv -f .deps/GeoNode.Tpo .deps/GeoNode.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT GeoTet.lo -MD -MP -MF .deps/GeoTet.Tpo -c -o GeoTet.lo ../../../trunk/geom/Cholla/GeoTet.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT GeoTet.lo -MD -MP -MF .deps/GeoTet.Tpo -c ../../../trunk/geom/Cholla/GeoTet.cpp -o GeoTet.o ../../../trunk/geom/Cholla/GeoTet.cpp: In member function ‘void GeoTet::opposite_edge(GeoNode*, GeoNode*, GeoNode*&, GeoNode*&)’: ../../../trunk/geom/Cholla/GeoTet.cpp:155: warning: suggest explicit braces to avoid ambiguous ‘else’ mv -f .deps/GeoTet.Tpo .deps/GeoTet.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT LoopParamTool.lo -MD -MP -MF .deps/LoopParamTool.Tpo -c -o LoopParamTool.lo ../../../trunk/geom/Cholla/LoopParamTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT LoopParamTool.lo -MD -MP -MF .deps/LoopParamTool.Tpo -c ../../../trunk/geom/Cholla/LoopParamTool.cpp -o LoopParamTool.o ../../../trunk/geom/Cholla/LoopParamTool.cpp: In member function ‘CubitStatus LoopParamTool::check_selfintersecting_coincident_edges(DLIList<DLIList<CubitPoint*>*>&)’: ../../../trunk/geom/Cholla/LoopParamTool.cpp:649: warning: suggest parentheses around && within || mv -f .deps/LoopParamTool.Tpo .deps/LoopParamTool.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT PointGridSearch.lo -MD -MP -MF .deps/PointGridSearch.Tpo -c -o PointGridSearch.lo ../../../trunk/geom/Cholla/PointGridSearch.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT PointGridSearch.lo -MD -MP -MF .deps/PointGridSearch.Tpo -c ../../../trunk/geom/Cholla/PointGridSearch.cpp -o PointGridSearch.o mv -f .deps/PointGridSearch.Tpo .deps/PointGridSearch.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT PointLoopFacetor.lo -MD -MP -MF .deps/PointLoopFacetor.Tpo -c -o PointLoopFacetor.lo ../../../trunk/geom/Cholla/PointLoopFacetor.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT PointLoopFacetor.lo -MD -MP -MF .deps/PointLoopFacetor.Tpo -c ../../../trunk/geom/Cholla/PointLoopFacetor.cpp -o PointLoopFacetor.o mv -f .deps/PointLoopFacetor.Tpo .deps/PointLoopFacetor.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT TDChordal.lo -MD -MP -MF .deps/TDChordal.Tpo -c -o TDChordal.lo ../../../trunk/geom/Cholla/TDChordal.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT TDChordal.lo -MD -MP -MF .deps/TDChordal.Tpo -c ../../../trunk/geom/Cholla/TDChordal.cpp -o TDChordal.o mv -f .deps/TDChordal.Tpo .deps/TDChordal.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT TDFacetboolData.lo -MD -MP -MF .deps/TDFacetboolData.Tpo -c -o TDFacetboolData.lo ../../../trunk/geom/Cholla/TDFacetboolData.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT TDFacetboolData.lo -MD -MP -MF .deps/TDFacetboolData.Tpo -c ../../../trunk/geom/Cholla/TDFacetboolData.cpp -o TDFacetboolData.o mv -f .deps/TDFacetboolData.Tpo .deps/TDFacetboolData.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT TDFacetBoundaryEdge.lo -MD -MP -MF .deps/TDFacetBoundaryEdge.Tpo -c -o TDFacetBoundaryEdge.lo ../../../trunk/geom/Cholla/TDFacetBoundaryEdge.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT TDFacetBoundaryEdge.lo -MD -MP -MF .deps/TDFacetBoundaryEdge.Tpo -c ../../../trunk/geom/Cholla/TDFacetBoundaryEdge.cpp -o TDFacetBoundaryEdge.o mv -f .deps/TDFacetBoundaryEdge.Tpo .deps/TDFacetBoundaryEdge.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT TDFacetBoundaryPoint.lo -MD -MP -MF .deps/TDFacetBoundaryPoint.Tpo -c -o TDFacetBoundaryPoint.lo ../../../trunk/geom/Cholla/TDFacetBoundaryPoint.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT TDFacetBoundaryPoint.lo -MD -MP -MF .deps/TDFacetBoundaryPoint.Tpo -c ../../../trunk/geom/Cholla/TDFacetBoundaryPoint.cpp -o TDFacetBoundaryPoint.o mv -f .deps/TDFacetBoundaryPoint.Tpo .deps/TDFacetBoundaryPoint.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT TDGeomFacet.lo -MD -MP -MF .deps/TDGeomFacet.Tpo -c -o TDGeomFacet.lo ../../../trunk/geom/Cholla/TDGeomFacet.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/Cholla -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT TDGeomFacet.lo -MD -MP -MF .deps/TDGeomFacet.Tpo -c ../../../trunk/geom/Cholla/TDGeomFacet.cpp -o TDGeomFacet.o mv -f .deps/TDGeomFacet.Tpo .deps/TDGeomFacet.Plo /bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -m32 -o libcholla.la AllocMemManagersCholla.lo Cholla.lo ChollaCurve.lo ChollaEngine.lo ChollaEntity.lo ChollaPoint.lo ChollaSkinTool.lo ChollaSurface.lo ChordalAxis.lo CubitFacet.lo CubitFacetData.lo CubitFacetEdge.lo CubitFacetEdgeData.lo CubitPoint.lo CubitPointData.lo CubitQuadFacet.lo CubitQuadFacetData.lo CurveFacetEvalTool.lo debug.lo FacetDataUtil.lo FacetEntity.lo FacetEvalTool.lo GeoNode.lo GeoTet.lo LoopParamTool.lo PointGridSearch.lo PointLoopFacetor.lo TDChordal.lo TDFacetboolData.lo TDFacetBoundaryEdge.lo TDFacetBoundaryPoint.lo TDGeomFacet.lo -lm rm -fr .libs/libcholla.a .libs/libcholla.la ar cru .libs/libcholla.a AllocMemManagersCholla.o Cholla.o ChollaCurve.o ChollaEngine.o ChollaEntity.o ChollaPoint.o ChollaSkinTool.o ChollaSurface.o ChordalAxis.o CubitFacet.o CubitFacetData.o CubitFacetEdge.o CubitFacetEdgeData.o CubitPoint.o CubitPointData.o CubitQuadFacet.o CubitQuadFacetData.o CurveFacetEvalTool.o debug.o FacetDataUtil.o FacetEntity.o FacetEvalTool.o GeoNode.o GeoTet.o LoopParamTool.o PointGridSearch.o PointLoopFacetor.o TDChordal.o TDFacetboolData.o TDFacetBoundaryEdge.o TDFacetBoundaryPoint.o TDGeomFacet.o ranlib .libs/libcholla.a creating libcholla.la (cd .libs && rm -f libcholla.la && ln -s ../libcholla.la libcholla.la) make[3]: Leaving directory `/home/jason/cgm/test/32-occ/geom/Cholla' Making all in facetbool make[3]: Entering directory `/home/jason/cgm/test/32-occ/geom/facetbool' /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facetbool -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FBClassify.lo -MD -MP -MF .deps/FBClassify.Tpo -c -o FBClassify.lo ../../../trunk/geom/facetbool/FBClassify.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facetbool -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FBClassify.lo -MD -MP -MF .deps/FBClassify.Tpo -c ../../../trunk/geom/facetbool/FBClassify.cpp -o FBClassify.o mv -f .deps/FBClassify.Tpo .deps/FBClassify.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facetbool -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FBDataUtil.lo -MD -MP -MF .deps/FBDataUtil.Tpo -c -o FBDataUtil.lo ../../../trunk/geom/facetbool/FBDataUtil.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facetbool -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FBDataUtil.lo -MD -MP -MF .deps/FBDataUtil.Tpo -c ../../../trunk/geom/facetbool/FBDataUtil.cpp -o FBDataUtil.o mv -f .deps/FBDataUtil.Tpo .deps/FBDataUtil.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facetbool -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FBImprint.lo -MD -MP -MF .deps/FBImprint.Tpo -c -o FBImprint.lo ../../../trunk/geom/facetbool/FBImprint.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facetbool -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FBImprint.lo -MD -MP -MF .deps/FBImprint.Tpo -c ../../../trunk/geom/facetbool/FBImprint.cpp -o FBImprint.o mv -f .deps/FBImprint.Tpo .deps/FBImprint.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facetbool -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FBIntersect.lo -MD -MP -MF .deps/FBIntersect.Tpo -c -o FBIntersect.lo ../../../trunk/geom/facetbool/FBIntersect.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facetbool -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FBIntersect.lo -MD -MP -MF .deps/FBIntersect.Tpo -c ../../../trunk/geom/facetbool/FBIntersect.cpp -o FBIntersect.o ../../../trunk/geom/facetbool/FBIntersect.cpp: In member function ‘CubitStatus FBIntersect::add_intersection_edges(FB_Triangle*, FB_Triangle*, double*, int*)’: ../../../trunk/geom/facetbool/FBIntersect.cpp:897: warning: ISO C++ does not support the ‘%le’ printf format ../../../trunk/geom/facetbool/FBIntersect.cpp:897: warning: ISO C++ does not support the ‘%le’ printf format ../../../trunk/geom/facetbool/FBIntersect.cpp:897: warning: ISO C++ does not support the ‘%le’ printf format ../../../trunk/geom/facetbool/FBIntersect.cpp:897: warning: ISO C++ does not support the ‘%le’ printf format mv -f .deps/FBIntersect.Tpo .deps/FBIntersect.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facetbool -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FBPolyhedron.lo -MD -MP -MF .deps/FBPolyhedron.Tpo -c -o FBPolyhedron.lo ../../../trunk/geom/facetbool/FBPolyhedron.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facetbool -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FBPolyhedron.lo -MD -MP -MF .deps/FBPolyhedron.Tpo -c ../../../trunk/geom/facetbool/FBPolyhedron.cpp -o FBPolyhedron.o ../../../trunk/geom/facetbool/FBPolyhedron.cpp: In member function ‘bool FBPolyhedron::edge_exists_in_tri(FB_Triangle&, int, int)’: ../../../trunk/geom/facetbool/FBPolyhedron.cpp:407: warning: suggest parentheses around && within || mv -f .deps/FBPolyhedron.Tpo .deps/FBPolyhedron.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facetbool -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FBRetriangulate.lo -MD -MP -MF .deps/FBRetriangulate.Tpo -c -o FBRetriangulate.lo ../../../trunk/geom/facetbool/FBRetriangulate.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facetbool -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FBRetriangulate.lo -MD -MP -MF .deps/FBRetriangulate.Tpo -c ../../../trunk/geom/facetbool/FBRetriangulate.cpp -o FBRetriangulate.o mv -f .deps/FBRetriangulate.Tpo .deps/FBRetriangulate.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facetbool -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FBTiler.lo -MD -MP -MF .deps/FBTiler.Tpo -c -o FBTiler.lo ../../../trunk/geom/facetbool/FBTiler.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facetbool -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT FBTiler.lo -MD -MP -MF .deps/FBTiler.Tpo -c ../../../trunk/geom/facetbool/FBTiler.cpp -o FBTiler.o mv -f .deps/FBTiler.Tpo .deps/FBTiler.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facetbool -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT IntegerHash.lo -MD -MP -MF .deps/IntegerHash.Tpo -c -o IntegerHash.lo ../../../trunk/geom/facetbool/IntegerHash.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facetbool -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT IntegerHash.lo -MD -MP -MF .deps/IntegerHash.Tpo -c ../../../trunk/geom/facetbool/IntegerHash.cpp -o IntegerHash.o mv -f .deps/IntegerHash.Tpo .deps/IntegerHash.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facetbool -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT KdTree.lo -MD -MP -MF .deps/KdTree.Tpo -c -o KdTree.lo ../../../trunk/geom/facetbool/KdTree.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facetbool -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -Wall -pipe -pedantic -g -m32 -MT KdTree.lo -MD -MP -MF .deps/KdTree.Tpo -c ../../../trunk/geom/facetbool/KdTree.cpp -o KdTree.o mv -f .deps/KdTree.Tpo .deps/KdTree.Plo /bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -m32 -o libcubit_facetbool.la FBClassify.lo FBDataUtil.lo FBImprint.lo FBIntersect.lo FBPolyhedron.lo FBRetriangulate.lo FBTiler.lo IntegerHash.lo KdTree.lo -lm rm -fr .libs/libcubit_facetbool.a .libs/libcubit_facetbool.la ar cru .libs/libcubit_facetbool.a FBClassify.o FBDataUtil.o FBImprint.o FBIntersect.o FBPolyhedron.o FBRetriangulate.o FBTiler.o IntegerHash.o KdTree.o ranlib .libs/libcubit_facetbool.a creating libcubit_facetbool.la (cd .libs && rm -f libcubit_facetbool.la && ln -s ../libcubit_facetbool.la libcubit_facetbool.la) make[3]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facetbool' Making all in facet make[3]: Entering directory `/home/jason/cgm/test/32-occ/geom/facet' /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetAttrib.lo -MD -MP -MF .deps/FacetAttrib.Tpo -c -o FacetAttrib.lo ../../../trunk/geom/facet/FacetAttrib.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetAttrib.lo -MD -MP -MF .deps/FacetAttrib.Tpo -c ../../../trunk/geom/facet/FacetAttrib.cpp -o FacetAttrib.o mv -f .deps/FacetAttrib.Tpo .deps/FacetAttrib.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetAttribSet.lo -MD -MP -MF .deps/FacetAttribSet.Tpo -c -o FacetAttribSet.lo ../../../trunk/geom/facet/FacetAttribSet.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetAttribSet.lo -MD -MP -MF .deps/FacetAttribSet.Tpo -c ../../../trunk/geom/facet/FacetAttribSet.cpp -o FacetAttribSet.o mv -f .deps/FacetAttribSet.Tpo .deps/FacetAttribSet.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetBody.lo -MD -MP -MF .deps/FacetBody.Tpo -c -o FacetBody.lo ../../../trunk/geom/facet/FacetBody.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetBody.lo -MD -MP -MF .deps/FacetBody.Tpo -c ../../../trunk/geom/facet/FacetBody.cpp -o FacetBody.o mv -f .deps/FacetBody.Tpo .deps/FacetBody.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetboolInterface.lo -MD -MP -MF .deps/FacetboolInterface.Tpo -c -o FacetboolInterface.lo ../../../trunk/geom/facet/FacetboolInterface.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetboolInterface.lo -MD -MP -MF .deps/FacetboolInterface.Tpo -c ../../../trunk/geom/facet/FacetboolInterface.cpp -o FacetboolInterface.o mv -f .deps/FacetboolInterface.Tpo .deps/FacetboolInterface.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetCoEdge.lo -MD -MP -MF .deps/FacetCoEdge.Tpo -c -o FacetCoEdge.lo ../../../trunk/geom/facet/FacetCoEdge.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetCoEdge.lo -MD -MP -MF .deps/FacetCoEdge.Tpo -c ../../../trunk/geom/facet/FacetCoEdge.cpp -o FacetCoEdge.o mv -f .deps/FacetCoEdge.Tpo .deps/FacetCoEdge.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetCurve.lo -MD -MP -MF .deps/FacetCurve.Tpo -c -o FacetCurve.lo ../../../trunk/geom/facet/FacetCurve.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetCurve.lo -MD -MP -MF .deps/FacetCurve.Tpo -c ../../../trunk/geom/facet/FacetCurve.cpp -o FacetCurve.o mv -f .deps/FacetCurve.Tpo .deps/FacetCurve.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetLoop.lo -MD -MP -MF .deps/FacetLoop.Tpo -c -o FacetLoop.lo ../../../trunk/geom/facet/FacetLoop.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetLoop.lo -MD -MP -MF .deps/FacetLoop.Tpo -c ../../../trunk/geom/facet/FacetLoop.cpp -o FacetLoop.o mv -f .deps/FacetLoop.Tpo .deps/FacetLoop.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetLump.lo -MD -MP -MF .deps/FacetLump.Tpo -c -o FacetLump.lo ../../../trunk/geom/facet/FacetLump.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetLump.lo -MD -MP -MF .deps/FacetLump.Tpo -c ../../../trunk/geom/facet/FacetLump.cpp -o FacetLump.o mv -f .deps/FacetLump.Tpo .deps/FacetLump.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetModifyEngine.lo -MD -MP -MF .deps/FacetModifyEngine.Tpo -c -o FacetModifyEngine.lo ../../../trunk/geom/facet/FacetModifyEngine.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetModifyEngine.lo -MD -MP -MF .deps/FacetModifyEngine.Tpo -c ../../../trunk/geom/facet/FacetModifyEngine.cpp -o FacetModifyEngine.o ../../../trunk/geom/facet/FacetModifyEngine.cpp: In static member function ‘static void FacetModifyEngine::initialize_settings()’: ../../../trunk/geom/facet/FacetModifyEngine.cpp:112: warning: deprecated conversion from string constant to ‘char*’ mv -f .deps/FacetModifyEngine.Tpo .deps/FacetModifyEngine.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetParamTool.lo -MD -MP -MF .deps/FacetParamTool.Tpo -c -o FacetParamTool.lo ../../../trunk/geom/facet/FacetParamTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetParamTool.lo -MD -MP -MF .deps/FacetParamTool.Tpo -c ../../../trunk/geom/facet/FacetParamTool.cpp -o FacetParamTool.o mv -f .deps/FacetParamTool.Tpo .deps/FacetParamTool.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetPoint.lo -MD -MP -MF .deps/FacetPoint.Tpo -c -o FacetPoint.lo ../../../trunk/geom/facet/FacetPoint.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetPoint.lo -MD -MP -MF .deps/FacetPoint.Tpo -c ../../../trunk/geom/facet/FacetPoint.cpp -o FacetPoint.o mv -f .deps/FacetPoint.Tpo .deps/FacetPoint.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetQueryEngine.lo -MD -MP -MF .deps/FacetQueryEngine.Tpo -c -o FacetQueryEngine.lo ../../../trunk/geom/facet/FacetQueryEngine.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetQueryEngine.lo -MD -MP -MF .deps/FacetQueryEngine.Tpo -c ../../../trunk/geom/facet/FacetQueryEngine.cpp -o FacetQueryEngine.o ../../../trunk/geom/facet/FacetQueryEngine.cpp: In static member function ‘static CubitStatus FacetQueryEngine::read_facets(const char*, int*&, int&, int&, int&, FacetFileFormat)’: ../../../trunk/geom/facet/FacetQueryEngine.cpp:3393: warning: suggest parentheses around && within || mv -f .deps/FacetQueryEngine.Tpo .deps/FacetQueryEngine.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetShell.lo -MD -MP -MF .deps/FacetShell.Tpo -c -o FacetShell.lo ../../../trunk/geom/facet/FacetShell.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetShell.lo -MD -MP -MF .deps/FacetShell.Tpo -c ../../../trunk/geom/facet/FacetShell.cpp -o FacetShell.o mv -f .deps/FacetShell.Tpo .deps/FacetShell.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetSurface.lo -MD -MP -MF .deps/FacetSurface.Tpo -c -o FacetSurface.lo ../../../trunk/geom/facet/FacetSurface.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT FacetSurface.lo -MD -MP -MF .deps/FacetSurface.Tpo -c ../../../trunk/geom/facet/FacetSurface.cpp -o FacetSurface.o mv -f .deps/FacetSurface.Tpo .deps/FacetSurface.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT GridSearchTree.lo -MD -MP -MF .deps/GridSearchTree.Tpo -c -o GridSearchTree.lo ../../../trunk/geom/facet/GridSearchTree.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/geom/facet -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -Wall -pipe -pedantic -g -m32 -MT GridSearchTree.lo -MD -MP -MF .deps/GridSearchTree.Tpo -c ../../../trunk/geom/facet/GridSearchTree.cpp -o GridSearchTree.o mv -f .deps/GridSearchTree.Tpo .deps/GridSearchTree.Plo /bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -m32 -o libcubit_facet.la FacetAttrib.lo FacetAttribSet.lo FacetBody.lo FacetboolInterface.lo FacetCoEdge.lo FacetCurve.lo FacetLoop.lo FacetLump.lo FacetModifyEngine.lo FacetParamTool.lo FacetPoint.lo FacetQueryEngine.lo FacetShell.lo FacetSurface.lo GridSearchTree.lo -lm rm -fr .libs/libcubit_facet.a .libs/libcubit_facet.la ar cru .libs/libcubit_facet.a FacetAttrib.o FacetAttribSet.o FacetBody.o FacetboolInterface.o FacetCoEdge.o FacetCurve.o FacetLoop.o FacetLump.o FacetModifyEngine.o FacetParamTool.o FacetPoint.o FacetQueryEngine.o FacetShell.o FacetSurface.o GridSearchTree.o ranlib .libs/libcubit_facet.a creating libcubit_facet.la (cd .libs && rm -f libcubit_facet.la && ln -s ../libcubit_facet.la libcubit_facet.la) make[3]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facet' Making all in virtual make[3]: Entering directory `/home/jason/cgm/test/32-occ/geom/virtual' /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT AllocMemManagersVirtual.lo -MD -MP -MF .deps/AllocMemManagersVirtual.Tpo -c -o AllocMemManagersVirtual.lo ../../../trunk/geom/virtual/AllocMemManagersVirtual.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT AllocMemManagersVirtual.lo -MD -MP -MF .deps/AllocMemManagersVirtual.Tpo -c ../../../trunk/geom/virtual/AllocMemManagersVirtual.cpp -o AllocMemManagersVirtual.o mv -f .deps/AllocMemManagersVirtual.Tpo .deps/AllocMemManagersVirtual.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CACompositeVG.lo -MD -MP -MF .deps/CACompositeVG.Tpo -c -o CACompositeVG.lo ../../../trunk/geom/virtual/CACompositeVG.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CACompositeVG.lo -MD -MP -MF .deps/CACompositeVG.Tpo -c ../../../trunk/geom/virtual/CACompositeVG.cpp -o CACompositeVG.o ../../../trunk/geom/virtual/CACompositeVG.cpp: In member function ‘virtual CubitStatus CACompositeVG::actuate()’: ../../../trunk/geom/virtual/CACompositeVG.cpp:137: warning: suggest explicit braces to avoid ambiguous ‘else’ mv -f .deps/CACompositeVG.Tpo .deps/CACompositeVG.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CAPartitionVG.lo -MD -MP -MF .deps/CAPartitionVG.Tpo -c -o CAPartitionVG.lo ../../../trunk/geom/virtual/CAPartitionVG.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CAPartitionVG.lo -MD -MP -MF .deps/CAPartitionVG.Tpo -c ../../../trunk/geom/virtual/CAPartitionVG.cpp -o CAPartitionVG.o mv -f .deps/CAPartitionVG.Tpo .deps/CAPartitionVG.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CAVirtualVG.lo -MD -MP -MF .deps/CAVirtualVG.Tpo -c -o CAVirtualVG.lo ../../../trunk/geom/virtual/CAVirtualVG.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CAVirtualVG.lo -MD -MP -MF .deps/CAVirtualVG.Tpo -c ../../../trunk/geom/virtual/CAVirtualVG.cpp -o CAVirtualVG.o mv -f .deps/CAVirtualVG.Tpo .deps/CAVirtualVG.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CollapseAngleTool.lo -MD -MP -MF .deps/CollapseAngleTool.Tpo -c -o CollapseAngleTool.lo ../../../trunk/geom/virtual/CollapseAngleTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CollapseAngleTool.lo -MD -MP -MF .deps/CollapseAngleTool.Tpo -c ../../../trunk/geom/virtual/CollapseAngleTool.cpp -o CollapseAngleTool.o mv -f .deps/CollapseAngleTool.Tpo .deps/CollapseAngleTool.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeAttrib.lo -MD -MP -MF .deps/CompositeAttrib.Tpo -c -o CompositeAttrib.lo ../../../trunk/geom/virtual/CompositeAttrib.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeAttrib.lo -MD -MP -MF .deps/CompositeAttrib.Tpo -c ../../../trunk/geom/virtual/CompositeAttrib.cpp -o CompositeAttrib.o mv -f .deps/CompositeAttrib.Tpo .deps/CompositeAttrib.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeBody.lo -MD -MP -MF .deps/CompositeBody.Tpo -c -o CompositeBody.lo ../../../trunk/geom/virtual/CompositeBody.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeBody.lo -MD -MP -MF .deps/CompositeBody.Tpo -c ../../../trunk/geom/virtual/CompositeBody.cpp -o CompositeBody.o mv -f .deps/CompositeBody.Tpo .deps/CompositeBody.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeCoEdge.lo -MD -MP -MF .deps/CompositeCoEdge.Tpo -c -o CompositeCoEdge.lo ../../../trunk/geom/virtual/CompositeCoEdge.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeCoEdge.lo -MD -MP -MF .deps/CompositeCoEdge.Tpo -c ../../../trunk/geom/virtual/CompositeCoEdge.cpp -o CompositeCoEdge.o ../../../trunk/geom/virtual/CompositeCoEdge.cpp: In member function ‘void CompositeCoEdge::print_debug_info(const char*, bool)’: ../../../trunk/geom/virtual/CompositeCoEdge.cpp:558: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CompositeCoEdge*’ ../../../trunk/geom/virtual/CompositeCoEdge.cpp:561: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CoEdgeSM*’ ../../../trunk/geom/virtual/CompositeCoEdge.cpp:571: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘CompositeCurve*’ mv -f .deps/CompositeCoEdge.Tpo .deps/CompositeCoEdge.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeCoSurf.lo -MD -MP -MF .deps/CompositeCoSurf.Tpo -c -o CompositeCoSurf.lo ../../../trunk/geom/virtual/CompositeCoSurf.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeCoSurf.lo -MD -MP -MF .deps/CompositeCoSurf.Tpo -c ../../../trunk/geom/virtual/CompositeCoSurf.cpp -o CompositeCoSurf.o ../../../trunk/geom/virtual/CompositeCoSurf.cpp: In member function ‘void CompositeCoSurf::print_debug_info(const char*, bool)’: ../../../trunk/geom/virtual/CompositeCoSurf.cpp:38: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CompositeCoSurf*’ ../../../trunk/geom/virtual/CompositeCoSurf.cpp:43: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘CompositeSurface*’ mv -f .deps/CompositeCoSurf.Tpo .deps/CompositeCoSurf.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeCurve.lo -MD -MP -MF .deps/CompositeCurve.Tpo -c -o CompositeCurve.lo ../../../trunk/geom/virtual/CompositeCurve.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeCurve.lo -MD -MP -MF .deps/CompositeCurve.Tpo -c ../../../trunk/geom/virtual/CompositeCurve.cpp -o CompositeCurve.o ../../../trunk/geom/virtual/CompositeCurve.hpp: In constructor ‘CompositeCurve::CompositeCurve(Curve*)’: ../../../trunk/geom/virtual/CompositeCurve.hpp:213: warning: ‘CompositeCurve::stitchNext’ will be initialized after ../../../trunk/geom/virtual/CompositeCurve.hpp:31: warning: ‘int CompositeCurve::HadBridgeRemoved’ ../../../trunk/geom/virtual/CompositeCurve.cpp:34: warning: when initialized here ../../../trunk/geom/virtual/CompositeCurve.hpp: In constructor ‘CompositeCurve::CompositeCurve(CompositeGeom*)’: ../../../trunk/geom/virtual/CompositeCurve.hpp:213: warning: ‘CompositeCurve::stitchNext’ will be initialized after ../../../trunk/geom/virtual/CompositeCurve.hpp:31: warning: ‘int CompositeCurve::HadBridgeRemoved’ ../../../trunk/geom/virtual/CompositeCurve.cpp:51: warning: when initialized here ../../../trunk/geom/virtual/CompositeCurve.hpp: In constructor ‘CompositeCurve::CompositeCurve(CompositePoint*)’: ../../../trunk/geom/virtual/CompositeCurve.hpp:213: warning: ‘CompositeCurve::stitchNext’ will be initialized after ../../../trunk/geom/virtual/CompositeCurve.hpp:31: warning: ‘int CompositeCurve::HadBridgeRemoved’ ../../../trunk/geom/virtual/CompositeCurve.cpp:79: warning: when initialized here ../../../trunk/geom/virtual/CompositeCurve.cpp: In member function ‘void CompositeCurve::print_debug_info(const char*, bool) const’: ../../../trunk/geom/virtual/CompositeCurve.cpp:1078: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘const CompositeCurve*’ ../../../trunk/geom/virtual/CompositeCurve.cpp:1078: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘CompositePoint*’ ../../../trunk/geom/virtual/CompositeCurve.cpp:1078: warning: format ‘%p’ expects type ‘void*’, but argument 6 has type ‘CompositePoint*’ ../../../trunk/geom/virtual/CompositeCurve.cpp:1080: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘Curve*’ ../../../trunk/geom/virtual/CompositeCurve.cpp:1094: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘const CompositeCurve*’ ../../../trunk/geom/virtual/CompositeCurve.cpp:1125: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘TopologyBridge*’ mv -f .deps/CompositeCurve.Tpo .deps/CompositeCurve.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeEngine.lo -MD -MP -MF .deps/CompositeEngine.Tpo -c -o CompositeEngine.lo ../../../trunk/geom/virtual/CompositeEngine.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeEngine.lo -MD -MP -MF .deps/CompositeEngine.Tpo -c ../../../trunk/geom/virtual/CompositeEngine.cpp -o CompositeEngine.o mv -f .deps/CompositeEngine.Tpo .deps/CompositeEngine.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeGeom.lo -MD -MP -MF .deps/CompositeGeom.Tpo -c -o CompositeGeom.lo ../../../trunk/geom/virtual/CompositeGeom.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeGeom.lo -MD -MP -MF .deps/CompositeGeom.Tpo -c ../../../trunk/geom/virtual/CompositeGeom.cpp -o CompositeGeom.o ../../../trunk/geom/virtual/CompositeGeom.cpp: In member function ‘void CompositeGeom::print_debug_info(const char*)’: ../../../trunk/geom/virtual/CompositeGeom.cpp:714: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CompositeGeom*’ mv -f .deps/CompositeGeom.Tpo .deps/CompositeGeom.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeLoop.lo -MD -MP -MF .deps/CompositeLoop.Tpo -c -o CompositeLoop.lo ../../../trunk/geom/virtual/CompositeLoop.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeLoop.lo -MD -MP -MF .deps/CompositeLoop.Tpo -c ../../../trunk/geom/virtual/CompositeLoop.cpp -o CompositeLoop.o ../../../trunk/geom/virtual/CompositeLoop.cpp: In member function ‘void CompositeLoop::print_debug_info(const char*)’: ../../../trunk/geom/virtual/CompositeLoop.cpp:274: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CompositeLoop*’ mv -f .deps/CompositeLoop.Tpo .deps/CompositeLoop.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeLump.lo -MD -MP -MF .deps/CompositeLump.Tpo -c -o CompositeLump.lo ../../../trunk/geom/virtual/CompositeLump.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeLump.lo -MD -MP -MF .deps/CompositeLump.Tpo -c ../../../trunk/geom/virtual/CompositeLump.cpp -o CompositeLump.o ../../../trunk/geom/virtual/CompositeLump.cpp: In member function ‘void CompositeLump::print_debug_info(const char*, bool)’: ../../../trunk/geom/virtual/CompositeLump.cpp:328: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CompositeLump*’ ../../../trunk/geom/virtual/CompositeLump.cpp:332: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CompositeLump*’ mv -f .deps/CompositeLump.Tpo .deps/CompositeLump.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositePoint.lo -MD -MP -MF .deps/CompositePoint.Tpo -c -o CompositePoint.lo ../../../trunk/geom/virtual/CompositePoint.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositePoint.lo -MD -MP -MF .deps/CompositePoint.Tpo -c ../../../trunk/geom/virtual/CompositePoint.cpp -o CompositePoint.o ../../../trunk/geom/virtual/CompositePoint.hpp: In constructor ‘CompositePoint::CompositePoint(Point*)’: ../../../trunk/geom/virtual/CompositePoint.hpp:80: warning: ‘CompositePoint::stitchNext’ will be initialized after ../../../trunk/geom/virtual/CompositePoint.hpp:28: warning: ‘int CompositePoint::HadBridgeRemoved’ ../../../trunk/geom/virtual/CompositePoint.cpp:17: warning: when initialized here ../../../trunk/geom/virtual/CompositePoint.cpp: In member function ‘void CompositePoint::print_debug_info(const char*, bool) const’: ../../../trunk/geom/virtual/CompositePoint.cpp:170: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘const CompositePoint*’ ../../../trunk/geom/virtual/CompositePoint.cpp:170: warning: format ‘%p’ expects type ‘void*’, but argument 6 has type ‘Point*’ mv -f .deps/CompositePoint.Tpo .deps/CompositePoint.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeShell.lo -MD -MP -MF .deps/CompositeShell.Tpo -c -o CompositeShell.lo ../../../trunk/geom/virtual/CompositeShell.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeShell.lo -MD -MP -MF .deps/CompositeShell.Tpo -c ../../../trunk/geom/virtual/CompositeShell.cpp -o CompositeShell.o ../../../trunk/geom/virtual/CompositeShell.cpp: In member function ‘void CompositeShell::print_debug_info(const char*)’: ../../../trunk/geom/virtual/CompositeShell.cpp:190: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CompositeShell*’ mv -f .deps/CompositeShell.Tpo .deps/CompositeShell.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeSurface.lo -MD -MP -MF .deps/CompositeSurface.Tpo -c -o CompositeSurface.lo ../../../trunk/geom/virtual/CompositeSurface.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeSurface.lo -MD -MP -MF .deps/CompositeSurface.Tpo -c ../../../trunk/geom/virtual/CompositeSurface.cpp -o CompositeSurface.o ../../../trunk/geom/virtual/CompositeSurface.hpp: In constructor ‘CompositeSurface::CompositeSurface(Surface*)’: ../../../trunk/geom/virtual/CompositeSurface.hpp:235: warning: ‘CompositeSurface::facetTool’ will be initialized after ../../../trunk/geom/virtual/CompositeSurface.hpp:217: warning: ‘int CompositeSurface::HadBridgeRemoved’ ../../../trunk/geom/virtual/CompositeSurface.cpp:43: warning: when initialized here ../../../trunk/geom/virtual/CompositeSurface.hpp: In constructor ‘CompositeSurface::CompositeSurface(CompositeGeom*)’: ../../../trunk/geom/virtual/CompositeSurface.hpp:235: warning: ‘CompositeSurface::facetTool’ will be initialized after ../../../trunk/geom/virtual/CompositeSurface.hpp:217: warning: ‘int CompositeSurface::HadBridgeRemoved’ ../../../trunk/geom/virtual/CompositeSurface.cpp:55: warning: when initialized here ../../../trunk/geom/virtual/CompositeSurface.cpp: In member function ‘void CompositeSurface::print_debug_info(const char*, bool)’: ../../../trunk/geom/virtual/CompositeSurface.cpp:1524: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CompositeSurface*’ mv -f .deps/CompositeSurface.Tpo .deps/CompositeSurface.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeTool.lo -MD -MP -MF .deps/CompositeTool.Tpo -c -o CompositeTool.lo ../../../trunk/geom/virtual/CompositeTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompositeTool.lo -MD -MP -MF .deps/CompositeTool.Tpo -c ../../../trunk/geom/virtual/CompositeTool.cpp -o CompositeTool.o mv -f .deps/CompositeTool.Tpo .deps/CompositeTool.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompSurfFacets.lo -MD -MP -MF .deps/CompSurfFacets.Tpo -c -o CompSurfFacets.lo ../../../trunk/geom/virtual/CompSurfFacets.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT CompSurfFacets.lo -MD -MP -MF .deps/CompSurfFacets.Tpo -c ../../../trunk/geom/virtual/CompSurfFacets.cpp -o CompSurfFacets.o ../../../trunk/geom/virtual/CompSurfFacets.cpp:254:1: warning: multi-line comment ../../../trunk/geom/virtual/CompSurfFacets.cpp:256:1: warning: multi-line comment ../../../trunk/geom/virtual/CompSurfFacets.cpp:262:1: warning: multi-line comment mv -f .deps/CompSurfFacets.Tpo .deps/CompSurfFacets.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT Faceter.lo -MD -MP -MF .deps/Faceter.Tpo -c -o Faceter.lo ../../../trunk/geom/virtual/Faceter.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT Faceter.lo -MD -MP -MF .deps/Faceter.Tpo -c ../../../trunk/geom/virtual/Faceter.cpp -o Faceter.o mv -f .deps/Faceter.Tpo .deps/Faceter.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT FaceterFacetData.lo -MD -MP -MF .deps/FaceterFacetData.Tpo -c -o FaceterFacetData.lo ../../../trunk/geom/virtual/FaceterFacetData.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT FaceterFacetData.lo -MD -MP -MF .deps/FaceterFacetData.Tpo -c ../../../trunk/geom/virtual/FaceterFacetData.cpp -o FaceterFacetData.o mv -f .deps/FaceterFacetData.Tpo .deps/FaceterFacetData.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT FaceterPointData.lo -MD -MP -MF .deps/FaceterPointData.Tpo -c -o FaceterPointData.lo ../../../trunk/geom/virtual/FaceterPointData.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT FaceterPointData.lo -MD -MP -MF .deps/FaceterPointData.Tpo -c ../../../trunk/geom/virtual/FaceterPointData.cpp -o FaceterPointData.o mv -f .deps/FaceterPointData.Tpo .deps/FaceterPointData.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT FacetProjectTool.lo -MD -MP -MF .deps/FacetProjectTool.Tpo -c -o FacetProjectTool.lo ../../../trunk/geom/virtual/FacetProjectTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT FacetProjectTool.lo -MD -MP -MF .deps/FacetProjectTool.Tpo -c ../../../trunk/geom/virtual/FacetProjectTool.cpp -o FacetProjectTool.o mv -f .deps/FacetProjectTool.Tpo .deps/FacetProjectTool.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT HiddenEntitySet.lo -MD -MP -MF .deps/HiddenEntitySet.Tpo -c -o HiddenEntitySet.lo ../../../trunk/geom/virtual/HiddenEntitySet.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT HiddenEntitySet.lo -MD -MP -MF .deps/HiddenEntitySet.Tpo -c ../../../trunk/geom/virtual/HiddenEntitySet.cpp -o HiddenEntitySet.o ../../../trunk/geom/virtual/HiddenEntitySet.cpp: In member function ‘void HiddenEntitySet::print_debug_info(const char*) const’: ../../../trunk/geom/virtual/HiddenEntitySet.cpp:173: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘const HiddenEntitySet*’ ../../../trunk/geom/virtual/HiddenEntitySet.cpp:173: warning: format ‘%p’ expects type ‘void*’, but argument 6 has type ‘TBOwner*’ ../../../trunk/geom/virtual/HiddenEntitySet.cpp:194: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘TopologyBridge*’ mv -f .deps/HiddenEntitySet.Tpo .deps/HiddenEntitySet.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT ImprintBoundaryTool.lo -MD -MP -MF .deps/ImprintBoundaryTool.Tpo -c -o ImprintBoundaryTool.lo ../../../trunk/geom/virtual/ImprintBoundaryTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT ImprintBoundaryTool.lo -MD -MP -MF .deps/ImprintBoundaryTool.Tpo -c ../../../trunk/geom/virtual/ImprintBoundaryTool.cpp -o ImprintBoundaryTool.o ../../../trunk/geom/virtual/ImprintBoundaryTool.cpp: In member function ‘CubitStatus ImprintBoundaryTool::intersect_segments(ImprintLineSegment*, ImprintLineSegment*, IntersectResult&, ImprintLineSegment**)’: ../../../trunk/geom/virtual/ImprintBoundaryTool.cpp:955: warning: suggest parentheses around && within || ../../../trunk/geom/virtual/ImprintBoundaryTool.cpp:970: warning: suggest parentheses around && within || ../../../trunk/geom/virtual/ImprintBoundaryTool.cpp:985: warning: suggest parentheses around && within || ../../../trunk/geom/virtual/ImprintBoundaryTool.cpp:1000: warning: suggest parentheses around && within || mv -f .deps/ImprintBoundaryTool.Tpo .deps/ImprintBoundaryTool.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT ImprintLineSegment.lo -MD -MP -MF .deps/ImprintLineSegment.Tpo -c -o ImprintLineSegment.lo ../../../trunk/geom/virtual/ImprintLineSegment.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT ImprintLineSegment.lo -MD -MP -MF .deps/ImprintLineSegment.Tpo -c ../../../trunk/geom/virtual/ImprintLineSegment.cpp -o ImprintLineSegment.o mv -f .deps/ImprintLineSegment.Tpo .deps/ImprintLineSegment.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT ImprintPointData.lo -MD -MP -MF .deps/ImprintPointData.Tpo -c -o ImprintPointData.lo ../../../trunk/geom/virtual/ImprintPointData.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT ImprintPointData.lo -MD -MP -MF .deps/ImprintPointData.Tpo -c ../../../trunk/geom/virtual/ImprintPointData.cpp -o ImprintPointData.o mv -f .deps/ImprintPointData.Tpo .deps/ImprintPointData.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionBody.lo -MD -MP -MF .deps/PartitionBody.Tpo -c -o PartitionBody.lo ../../../trunk/geom/virtual/PartitionBody.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionBody.lo -MD -MP -MF .deps/PartitionBody.Tpo -c ../../../trunk/geom/virtual/PartitionBody.cpp -o PartitionBody.o mv -f .deps/PartitionBody.Tpo .deps/PartitionBody.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionCoEdge.lo -MD -MP -MF .deps/PartitionCoEdge.Tpo -c -o PartitionCoEdge.lo ../../../trunk/geom/virtual/PartitionCoEdge.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionCoEdge.lo -MD -MP -MF .deps/PartitionCoEdge.Tpo -c ../../../trunk/geom/virtual/PartitionCoEdge.cpp -o PartitionCoEdge.o mv -f .deps/PartitionCoEdge.Tpo .deps/PartitionCoEdge.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionCoSurf.lo -MD -MP -MF .deps/PartitionCoSurf.Tpo -c -o PartitionCoSurf.lo ../../../trunk/geom/virtual/PartitionCoSurf.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionCoSurf.lo -MD -MP -MF .deps/PartitionCoSurf.Tpo -c ../../../trunk/geom/virtual/PartitionCoSurf.cpp -o PartitionCoSurf.o mv -f .deps/PartitionCoSurf.Tpo .deps/PartitionCoSurf.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionCurve.lo -MD -MP -MF .deps/PartitionCurve.Tpo -c -o PartitionCurve.lo ../../../trunk/geom/virtual/PartitionCurve.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionCurve.lo -MD -MP -MF .deps/PartitionCurve.Tpo -c ../../../trunk/geom/virtual/PartitionCurve.cpp -o PartitionCurve.o ../../../trunk/geom/virtual/PartitionCurve.cpp: In member function ‘virtual void PartitionCurve::print_debug_info(const char*, bool) const’: ../../../trunk/geom/virtual/PartitionCurve.cpp:298: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘const PartitionCurve*’ ../../../trunk/geom/virtual/PartitionCurve.cpp:315: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘Surface*’ ../../../trunk/geom/virtual/PartitionCurve.cpp:318: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PartitionPoint*’ ../../../trunk/geom/virtual/PartitionCurve.cpp:325: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PartitionPoint*’ mv -f .deps/PartitionCurve.Tpo .deps/PartitionCurve.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionEngine.lo -MD -MP -MF .deps/PartitionEngine.Tpo -c -o PartitionEngine.lo ../../../trunk/geom/virtual/PartitionEngine.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionEngine.lo -MD -MP -MF .deps/PartitionEngine.Tpo -c ../../../trunk/geom/virtual/PartitionEngine.cpp -o PartitionEngine.o ../../../trunk/geom/virtual/PartitionEngine.cpp: In member function ‘CubitStatus PartitionEngine::restore_from_attrib(Surface*)’: ../../../trunk/geom/virtual/PartitionEngine.cpp:4660: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘Surface*’ ../../../trunk/geom/virtual/PartitionEngine.cpp:4709: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionPoint*’ ../../../trunk/geom/virtual/PartitionEngine.cpp:4751: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartPTCurve*’ ../../../trunk/geom/virtual/PartitionEngine.cpp:4751: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘PartitionPoint*’ ../../../trunk/geom/virtual/PartitionEngine.cpp:4787: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘SegmentedCurve*’ ../../../trunk/geom/virtual/PartitionEngine.cpp:4787: warning: format ‘%p’ expects type ‘void*’, but argument 6 has type ‘PartitionPoint*’ ../../../trunk/geom/virtual/PartitionEngine.cpp:4787: warning: format ‘%p’ expects type ‘void*’, but argument 11 has type ‘PartitionPoint*’ ../../../trunk/geom/virtual/PartitionEngine.cpp:4983: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionCurve*’ mv -f .deps/PartitionEngine.Tpo .deps/PartitionEngine.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionEntity.lo -MD -MP -MF .deps/PartitionEntity.Tpo -c -o PartitionEntity.lo ../../../trunk/geom/virtual/PartitionEntity.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionEntity.lo -MD -MP -MF .deps/PartitionEntity.Tpo -c ../../../trunk/geom/virtual/PartitionEntity.cpp -o PartitionEntity.o ../../../trunk/geom/virtual/PartitionEntity.cpp: In member function ‘virtual void PartitionEntity::print_debug_info(const char*, bool) const’: ../../../trunk/geom/virtual/PartitionEntity.cpp:32: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘const PartitionEntity*’ ../../../trunk/geom/virtual/PartitionEntity.cpp: In member function ‘void PartitionEntity::print_partitioned_entity(const char*) const’: ../../../trunk/geom/virtual/PartitionEntity.cpp:46: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘TopologyBridge*’ mv -f .deps/PartitionEntity.Tpo .deps/PartitionEntity.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionLoop.lo -MD -MP -MF .deps/PartitionLoop.Tpo -c -o PartitionLoop.lo ../../../trunk/geom/virtual/PartitionLoop.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionLoop.lo -MD -MP -MF .deps/PartitionLoop.Tpo -c ../../../trunk/geom/virtual/PartitionLoop.cpp -o PartitionLoop.o mv -f .deps/PartitionLoop.Tpo .deps/PartitionLoop.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionLump.lo -MD -MP -MF .deps/PartitionLump.Tpo -c -o PartitionLump.lo ../../../trunk/geom/virtual/PartitionLump.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionLump.lo -MD -MP -MF .deps/PartitionLump.Tpo -c ../../../trunk/geom/virtual/PartitionLump.cpp -o PartitionLump.o mv -f .deps/PartitionLump.Tpo .deps/PartitionLump.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionLumpImprint.lo -MD -MP -MF .deps/PartitionLumpImprint.Tpo -c -o PartitionLumpImprint.lo ../../../trunk/geom/virtual/PartitionLumpImprint.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionLumpImprint.lo -MD -MP -MF .deps/PartitionLumpImprint.Tpo -c ../../../trunk/geom/virtual/PartitionLumpImprint.cpp -o PartitionLumpImprint.o ../../../trunk/geom/virtual/PartitionLumpImprint.cpp: In member function ‘void PartitionLumpImprint::set_point_owner(CubitPoint*, PartitionEntity*)’: ../../../trunk/geom/virtual/PartitionLumpImprint.cpp:356: warning: format ‘%p’ expects type ‘void*’, but argument 8 has type ‘PartitionEntity*’ ../../../trunk/geom/virtual/PartitionLumpImprint.cpp: In member function ‘CubitStatus PartitionLumpImprint::partitionCurve(CubitPoint*)’: ../../../trunk/geom/virtual/PartitionLumpImprint.cpp:710: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionCurve*’ ../../../trunk/geom/virtual/PartitionLumpImprint.cpp: In member function ‘CubitStatus PartitionLumpImprint::partitionSurface(int, int, PartitionSurface*)’: ../../../trunk/geom/virtual/PartitionLumpImprint.cpp:789: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionSurface*’ ../../../trunk/geom/virtual/PartitionLumpImprint.cpp: In member function ‘CubitStatus PartitionLumpImprint::makePointCurve(CubitPoint*)’: ../../../trunk/geom/virtual/PartitionLumpImprint.cpp:1000: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionSurface*’ ../../../trunk/geom/virtual/PartitionLumpImprint.cpp: In member function ‘CubitStatus PartitionLumpImprint::makeFreeCurve(int, int)’: ../../../trunk/geom/virtual/PartitionLumpImprint.cpp:1067: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionPoint*’ ../../../trunk/geom/virtual/PartitionLumpImprint.cpp:1067: warning: format ‘%p’ expects type ‘void*’, but argument 8 has type ‘PartitionPoint*’ mv -f .deps/PartitionLumpImprint.Tpo .deps/PartitionLumpImprint.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionPoint.lo -MD -MP -MF .deps/PartitionPoint.Tpo -c -o PartitionPoint.lo ../../../trunk/geom/virtual/PartitionPoint.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionPoint.lo -MD -MP -MF .deps/PartitionPoint.Tpo -c ../../../trunk/geom/virtual/PartitionPoint.cpp -o PartitionPoint.o ../../../trunk/geom/virtual/PartitionPoint.cpp: In member function ‘virtual void PartitionPoint::print_debug_info(const char*, bool) const’: ../../../trunk/geom/virtual/PartitionPoint.cpp:141: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘const PartitionPoint*’ ../../../trunk/geom/virtual/PartitionPoint.cpp:151: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CubitPointData*’ mv -f .deps/PartitionPoint.Tpo .deps/PartitionPoint.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionShell.lo -MD -MP -MF .deps/PartitionShell.Tpo -c -o PartitionShell.lo ../../../trunk/geom/virtual/PartitionShell.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionShell.lo -MD -MP -MF .deps/PartitionShell.Tpo -c ../../../trunk/geom/virtual/PartitionShell.cpp -o PartitionShell.o mv -f .deps/PartitionShell.Tpo .deps/PartitionShell.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionSurface.lo -MD -MP -MF .deps/PartitionSurface.Tpo -c -o PartitionSurface.lo ../../../trunk/geom/virtual/PartitionSurface.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionSurface.lo -MD -MP -MF .deps/PartitionSurface.Tpo -c ../../../trunk/geom/virtual/PartitionSurface.cpp -o PartitionSurface.o ../../../trunk/geom/virtual/PartitionSurface.cpp: In member function ‘virtual void PartitionSurface::print_debug_info(const char*, bool) const’: ../../../trunk/geom/virtual/PartitionSurface.cpp:96: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘const PartitionSurface*’ ../../../trunk/geom/virtual/PartitionSurface.cpp:100: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PartitionLoop*’ ../../../trunk/geom/virtual/PartitionSurface.cpp:107: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PartitionCoEdge*’ ../../../trunk/geom/virtual/PartitionSurface.cpp:107: warning: format ‘%p’ expects type ‘void*’, but argument 6 has type ‘PartitionCurve*’ ../../../trunk/geom/virtual/PartitionSurface.hpp: In constructor ‘PartitionSurface::PartitionSurface()’: ../../../trunk/geom/virtual/PartitionSurface.hpp:203: warning: ‘PartitionSurface::firstCoSurf’ will be initialized after ../../../trunk/geom/virtual/PartitionSurface.hpp:194: warning: ‘CubitSense PartitionSurface::geometry_sense’ ../../../trunk/geom/virtual/PartitionSurface.cpp:118: warning: when initialized here ../../../trunk/geom/virtual/PartitionSurface.hpp: In constructor ‘PartitionSurface::PartitionSurface(PartitionLump*)’: ../../../trunk/geom/virtual/PartitionSurface.hpp:203: warning: ‘PartitionSurface::firstCoSurf’ will be initialized after ../../../trunk/geom/virtual/PartitionSurface.hpp:194: warning: ‘CubitSense PartitionSurface::geometry_sense’ ../../../trunk/geom/virtual/PartitionSurface.cpp:122: warning: when initialized here ../../../trunk/geom/virtual/PartitionSurface.hpp: In constructor ‘PartitionSurface::PartitionSurface(PartitionSurface*)’: ../../../trunk/geom/virtual/PartitionSurface.hpp:203: warning: ‘PartitionSurface::firstCoSurf’ will be initialized after ../../../trunk/geom/virtual/PartitionSurface.hpp:194: warning: ‘CubitSense PartitionSurface::geometry_sense’ ../../../trunk/geom/virtual/PartitionSurface.cpp:893: warning: when initialized here mv -f .deps/PartitionSurface.Tpo .deps/PartitionSurface.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionTool.lo -MD -MP -MF .deps/PartitionTool.Tpo -c -o PartitionTool.lo ../../../trunk/geom/virtual/PartitionTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartitionTool.lo -MD -MP -MF .deps/PartitionTool.Tpo -c ../../../trunk/geom/virtual/PartitionTool.cpp -o PartitionTool.o ../../../trunk/geom/virtual/PartitionTool.cpp: In member function ‘CubitStatus PartitionTool::partition_face_by_curves(RefFace*, const DLIList<Curve*>&, DLIList<RefFace*>&, CubitBoolean, DLIList<RefEdge*>*, CubitBoolean)’: ../../../trunk/geom/virtual/PartitionTool.cpp:1524: warning: unused variable ‘sta’ ../../../trunk/geom/virtual/PartitionTool.cpp:1530: warning: unused variable ‘sta’ ../../../trunk/geom/virtual/PartitionTool.cpp:1544: warning: unused variable ‘sta’ ../../../trunk/geom/virtual/PartitionTool.cpp:1550: warning: unused variable ‘stat’ ../../../trunk/geom/virtual/PartitionTool.cpp: In function ‘void pt_print_bte_list(int, DLIList<BasicTopologyEntity*>&, const char*)’: ../../../trunk/geom/virtual/PartitionTool.cpp:1931: warning: suggest explicit braces to avoid ambiguous ‘else’ mv -f .deps/PartitionTool.Tpo .deps/PartitionTool.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartPTCurve.lo -MD -MP -MF .deps/PartPTCurve.Tpo -c -o PartPTCurve.lo ../../../trunk/geom/virtual/PartPTCurve.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartPTCurve.lo -MD -MP -MF .deps/PartPTCurve.Tpo -c ../../../trunk/geom/virtual/PartPTCurve.cpp -o PartPTCurve.o mv -f .deps/PartPTCurve.Tpo .deps/PartPTCurve.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartSurfFacetTool.lo -MD -MP -MF .deps/PartSurfFacetTool.Tpo -c -o PartSurfFacetTool.lo ../../../trunk/geom/virtual/PartSurfFacetTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PartSurfFacetTool.lo -MD -MP -MF .deps/PartSurfFacetTool.Tpo -c ../../../trunk/geom/virtual/PartSurfFacetTool.cpp -o PartSurfFacetTool.o ../../../trunk/geom/virtual/PartSurfFacetTool.cpp: In static member function ‘static void PartSurfFacetTool::validate_facets(PartitionSurface*)’: ../../../trunk/geom/virtual/PartSurfFacetTool.cpp:258: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionCurve*’ ../../../trunk/geom/virtual/PartSurfFacetTool.cpp:271: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionPoint*’ ../../../trunk/geom/virtual/PartSurfFacetTool.cpp:271: warning: format ‘%p’ expects type ‘void*’, but argument 8 has type ‘PartitionCurve*’ ../../../trunk/geom/virtual/PartSurfFacetTool.cpp:281: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionCurve*’ ../../../trunk/geom/virtual/PartSurfFacetTool.cpp:281: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘PartitionPoint*’ ../../../trunk/geom/virtual/PartSurfFacetTool.cpp:291: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionCurve*’ ../../../trunk/geom/virtual/PartSurfFacetTool.cpp:291: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘PartitionPoint*’ ../../../trunk/geom/virtual/PartSurfFacetTool.cpp:305: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionCurve*’ ../../../trunk/geom/virtual/PartSurfFacetTool.cpp:305: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘PartitionCurve*’ ../../../trunk/geom/virtual/PartSurfFacetTool.cpp: In function ‘void draw_edges(DLIList<CubitFacetEdge*>&, int, bool, bool, int, bool)’: ../../../trunk/geom/virtual/PartSurfFacetTool.cpp:521: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘CubitFacetEdge*’ ../../../trunk/geom/virtual/PartSurfFacetTool.cpp:541: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘CubitPoint*’ mv -f .deps/PartSurfFacetTool.Tpo .deps/PartSurfFacetTool.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PST_Data.lo -MD -MP -MF .deps/PST_Data.Tpo -c -o PST_Data.lo ../../../trunk/geom/virtual/PST_Data.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT PST_Data.lo -MD -MP -MF .deps/PST_Data.Tpo -c ../../../trunk/geom/virtual/PST_Data.cpp -o PST_Data.o ../../../trunk/geom/virtual/PST_Data.cpp: In member function ‘int PST_Point::validate(CubitBoolean)’: ../../../trunk/geom/virtual/PST_Data.cpp:996: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Point*’ ../../../trunk/geom/virtual/PST_Data.cpp:996: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_Edge*’ ../../../trunk/geom/virtual/PST_Data.cpp: In member function ‘int PST_Edge::validate(CubitBoolean)’: ../../../trunk/geom/virtual/PST_Data.cpp:1011: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’ ../../../trunk/geom/virtual/PST_Data.cpp:1026: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Point*’ ../../../trunk/geom/virtual/PST_Data.cpp:1038: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’ ../../../trunk/geom/virtual/PST_Data.cpp:1053: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Point*’ ../../../trunk/geom/virtual/PST_Data.cpp:1066: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’ ../../../trunk/geom/virtual/PST_Data.cpp:1066: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_Face*’ ../../../trunk/geom/virtual/PST_Data.cpp:1074: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’ ../../../trunk/geom/virtual/PST_Data.cpp:1074: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_Face*’ ../../../trunk/geom/virtual/PST_Data.cpp:1082: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’ ../../../trunk/geom/virtual/PST_Data.cpp:1082: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_CoEdge*’ ../../../trunk/geom/virtual/PST_Data.cpp:1090: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’ ../../../trunk/geom/virtual/PST_Data.cpp:1090: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_CoEdge*’ ../../../trunk/geom/virtual/PST_Data.cpp: In member function ‘int PST_CoEdge::validate(CubitBoolean)’: ../../../trunk/geom/virtual/PST_Data.cpp:1102: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_CoEdge*’ ../../../trunk/geom/virtual/PST_Data.cpp:1111: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’ ../../../trunk/geom/virtual/PST_Data.cpp:1111: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_CoEdge*’ ../../../trunk/geom/virtual/PST_Data.cpp: In member function ‘int PST_Face::validate(CubitBoolean)’: ../../../trunk/geom/virtual/PST_Data.cpp:1125: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Face*’ ../../../trunk/geom/virtual/PST_Data.cpp:1135: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Face*’ ../../../trunk/geom/virtual/PST_Data.cpp:1144: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Face*’ ../../../trunk/geom/virtual/PST_Data.cpp:1144: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_Face*’ ../../../trunk/geom/virtual/PST_Data.cpp:1144: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘PST_Edge*’ ../../../trunk/geom/virtual/PST_Data.cpp:1155: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_CoEdge*’ ../../../trunk/geom/virtual/PST_Data.cpp:1155: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_Face*’ ../../../trunk/geom/virtual/PST_Data.cpp:1162: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_CoEdge*’ ../../../trunk/geom/virtual/PST_Data.cpp:1162: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_Face*’ ../../../trunk/geom/virtual/PST_Data.cpp: In member function ‘void PST_Face::print()’: ../../../trunk/geom/virtual/PST_Data.cpp:1189: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Face*’ ../../../trunk/geom/virtual/PST_Data.cpp:1197: warning: format ‘%10p’ expects type ‘void*’, but argument 3 has type ‘PST_Face*’ ../../../trunk/geom/virtual/PST_Data.cpp:1197: warning: format ‘%10p’ expects type ‘void*’, but argument 4 has type ‘PST_CoEdge*’ ../../../trunk/geom/virtual/PST_Data.cpp:1197: warning: format ‘%10p’ expects type ‘void*’, but argument 5 has type ‘PST_Edge*’ ../../../trunk/geom/virtual/PST_Data.cpp:1197: warning: format ‘%10p’ expects type ‘void*’, but argument 6 has type ‘PST_Point*’ ../../../trunk/geom/virtual/PST_Data.cpp:1197: warning: format ‘%10p’ expects type ‘void*’, but argument 7 has type ‘PST_Point*’ ../../../trunk/geom/virtual/PST_Data.cpp:1202: warning: format ‘%10p’ expects type ‘void*’, but argument 3 has type ‘PST_CoEdge*’ ../../../trunk/geom/virtual/PST_Data.cpp:1202: warning: format ‘%10p’ expects type ‘void*’, but argument 4 has type ‘PST_Edge*’ ../../../trunk/geom/virtual/PST_Data.cpp:1202: warning: format ‘%10p’ expects type ‘void*’, but argument 5 has type ‘PST_Point*’ ../../../trunk/geom/virtual/PST_Data.cpp:1202: warning: format ‘%10p’ expects type ‘void*’, but argument 6 has type ‘PST_Point*’ ../../../trunk/geom/virtual/PST_Data.cpp: In member function ‘void PST_Edge::print()’: ../../../trunk/geom/virtual/PST_Data.cpp:1210: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’ ../../../trunk/geom/virtual/PST_Data.cpp:1210: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_Point*’ ../../../trunk/geom/virtual/PST_Data.cpp:1210: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘PST_Point*’ ../../../trunk/geom/virtual/PST_Data.cpp:1210: warning: format ‘%p’ expects type ‘void*’, but argument 6 has type ‘PST_Face*’ ../../../trunk/geom/virtual/PST_Data.cpp:1210: warning: format ‘%p’ expects type ‘void*’, but argument 7 has type ‘PST_Face*’ ../../../trunk/geom/virtual/PST_Data.cpp: In member function ‘void PST_Point::print()’: ../../../trunk/geom/virtual/PST_Data.cpp:1215: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Point*’ ../../../trunk/geom/virtual/PST_Data.cpp:1226: warning: format ‘%8p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’ ../../../trunk/geom/virtual/PST_Data.cpp:1230: warning: format ‘%8p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’ mv -f .deps/PST_Data.Tpo .deps/PST_Data.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT SegmentedCurve.lo -MD -MP -MF .deps/SegmentedCurve.Tpo -c -o SegmentedCurve.lo ../../../trunk/geom/virtual/SegmentedCurve.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT SegmentedCurve.lo -MD -MP -MF .deps/SegmentedCurve.Tpo -c ../../../trunk/geom/virtual/SegmentedCurve.cpp -o SegmentedCurve.o ../../../trunk/geom/virtual/SegmentedCurve.cpp: In member function ‘virtual void SegmentedCurve::print_debug_info(const char*, bool) const’: ../../../trunk/geom/virtual/SegmentedCurve.cpp:860: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘const SegmentedCurve*’ mv -f .deps/SegmentedCurve.Tpo .deps/SegmentedCurve.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT SubCurve.lo -MD -MP -MF .deps/SubCurve.Tpo -c -o SubCurve.lo ../../../trunk/geom/virtual/SubCurve.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT SubCurve.lo -MD -MP -MF .deps/SubCurve.Tpo -c ../../../trunk/geom/virtual/SubCurve.cpp -o SubCurve.o mv -f .deps/SubCurve.Tpo .deps/SubCurve.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT SubEntitySet.lo -MD -MP -MF .deps/SubEntitySet.Tpo -c -o SubEntitySet.lo ../../../trunk/geom/virtual/SubEntitySet.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT SubEntitySet.lo -MD -MP -MF .deps/SubEntitySet.Tpo -c ../../../trunk/geom/virtual/SubEntitySet.cpp -o SubEntitySet.o ../../../trunk/geom/virtual/SubEntitySet.cpp: In member function ‘void SubEntitySet::print_debug_info(const char*) const’: ../../../trunk/geom/virtual/SubEntitySet.cpp:335: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘TopologyBridge*’ ../../../trunk/geom/virtual/SubEntitySet.cpp:342: warning: format ‘%p’ expects type ‘void*’, but argument 6 has type ‘PartitionEntity*’ ../../../trunk/geom/virtual/SubEntitySet.cpp:351: warning: format ‘%p’ expects type ‘void*’, but argument 6 has type ‘PartitionEntity*’ ../../../trunk/geom/virtual/SubEntitySet.cpp:355: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PartitionBody*’ mv -f .deps/SubEntitySet.Tpo .deps/SubEntitySet.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT SubSurface.lo -MD -MP -MF .deps/SubSurface.Tpo -c -o SubSurface.lo ../../../trunk/geom/virtual/SubSurface.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT SubSurface.lo -MD -MP -MF .deps/SubSurface.Tpo -c ../../../trunk/geom/virtual/SubSurface.cpp -o SubSurface.o mv -f .deps/SubSurface.Tpo .deps/SubSurface.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT TDVGFacetOwner.lo -MD -MP -MF .deps/TDVGFacetOwner.Tpo -c -o TDVGFacetOwner.lo ../../../trunk/geom/virtual/TDVGFacetOwner.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT TDVGFacetOwner.lo -MD -MP -MF .deps/TDVGFacetOwner.Tpo -c ../../../trunk/geom/virtual/TDVGFacetOwner.cpp -o TDVGFacetOwner.o mv -f .deps/TDVGFacetOwner.Tpo .deps/TDVGFacetOwner.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT TDVGFacetSplit.lo -MD -MP -MF .deps/TDVGFacetSplit.Tpo -c -o TDVGFacetSplit.lo ../../../trunk/geom/virtual/TDVGFacetSplit.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT TDVGFacetSplit.lo -MD -MP -MF .deps/TDVGFacetSplit.Tpo -c ../../../trunk/geom/virtual/TDVGFacetSplit.cpp -o TDVGFacetSplit.o mv -f .deps/TDVGFacetSplit.Tpo .deps/TDVGFacetSplit.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT VirtualQueryEngine.lo -MD -MP -MF .deps/VirtualQueryEngine.Tpo -c -o VirtualQueryEngine.lo ../../../trunk/geom/virtual/VirtualQueryEngine.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT VirtualQueryEngine.lo -MD -MP -MF .deps/VirtualQueryEngine.Tpo -c ../../../trunk/geom/virtual/VirtualQueryEngine.cpp -o VirtualQueryEngine.o ../../../trunk/geom/virtual/VirtualQueryEngine.cpp: In member function ‘virtual CubitStatus VirtualQueryEngine::get_graphics(Surface*, int&, int&, int&, GMem*, short unsigned int, double, double) const’: ../../../trunk/geom/virtual/VirtualQueryEngine.cpp:201: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘Surface*’ ../../../trunk/geom/virtual/VirtualQueryEngine.cpp:201: warning: format ‘%p’ expects type ‘void*’, but argument 7 has type ‘GMem*’ ../../../trunk/geom/virtual/VirtualQueryEngine.cpp: In member function ‘virtual CubitStatus VirtualQueryEngine::entity_entity_distance(GeometryEntity*, GeometryEntity*, CubitVector&, CubitVector&, double&)’: ../../../trunk/geom/virtual/VirtualQueryEngine.cpp:1396: warning: unused variable ‘gqe2’ mv -f .deps/VirtualQueryEngine.Tpo .deps/VirtualQueryEngine.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT VirtualImprintTool.lo -MD -MP -MF .deps/VirtualImprintTool.Tpo -c -o VirtualImprintTool.lo ../../../trunk/geom/virtual/VirtualImprintTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../trunk/geom/virtual -I../.. -I../../itaps -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/facet -I../../../trunk/geom/Cholla -Wall -pipe -pedantic -g -m32 -MT VirtualImprintTool.lo -MD -MP -MF .deps/VirtualImprintTool.Tpo -c ../../../trunk/geom/virtual/VirtualImprintTool.cpp -o VirtualImprintTool.o mv -f .deps/VirtualImprintTool.Tpo .deps/VirtualImprintTool.Plo /bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -m32 -o libcubit_virtual.la AllocMemManagersVirtual.lo CACompositeVG.lo CAPartitionVG.lo CAVirtualVG.lo CollapseAngleTool.lo CompositeAttrib.lo CompositeBody.lo CompositeCoEdge.lo CompositeCoSurf.lo CompositeCurve.lo CompositeEngine.lo CompositeGeom.lo CompositeLoop.lo CompositeLump.lo CompositePoint.lo CompositeShell.lo CompositeSurface.lo CompositeTool.lo CompSurfFacets.lo Faceter.lo FaceterFacetData.lo FaceterPointData.lo FacetProjectTool.lo HiddenEntitySet.lo ImprintBoundaryTool.lo ImprintLineSegment.lo ImprintPointData.lo PartitionBody.lo PartitionCoEdge.lo PartitionCoSurf.lo PartitionCurve.lo PartitionEngine.lo PartitionEntity.lo PartitionLoop.lo PartitionLump.lo PartitionLumpImprint.lo PartitionPoint.lo PartitionShell.lo PartitionSurface.lo PartitionTool.lo PartPTCurve.lo PartSurfFacetTool.lo PST_Data.lo SegmentedCurve.lo SubCurve.lo SubEntitySet.lo SubSurface.lo TDVGFacetOwner.lo TDVGFacet! Split.lo VirtualQueryEngine.lo VirtualImprintTool.lo -lm rm -fr .libs/libcubit_virtual.a .libs/libcubit_virtual.la ar cru .libs/libcubit_virtual.a AllocMemManagersVirtual.o CACompositeVG.o CAPartitionVG.o CAVirtualVG.o CollapseAngleTool.o CompositeAttrib.o CompositeBody.o CompositeCoEdge.o CompositeCoSurf.o CompositeCurve.o CompositeEngine.o CompositeGeom.o CompositeLoop.o CompositeLump.o CompositePoint.o CompositeShell.o CompositeSurface.o CompositeTool.o CompSurfFacets.o Faceter.o FaceterFacetData.o FaceterPointData.o FacetProjectTool.o HiddenEntitySet.o ImprintBoundaryTool.o ImprintLineSegment.o ImprintPointData.o PartitionBody.o PartitionCoEdge.o PartitionCoSurf.o PartitionCurve.o PartitionEngine.o PartitionEntity.o PartitionLoop.o PartitionLump.o PartitionLumpImprint.o PartitionPoint.o PartitionShell.o PartitionSurface.o PartitionTool.o PartPTCurve.o PartSurfFacetTool.o PST_Data.o SegmentedCurve.o SubCurve.o SubEntitySet.o SubSurface.o TDVGFacetOwner.o TDVGFacetSplit.o VirtualQueryEngine.o VirtualImprintTool.o ranlib .libs/libcubit_virtual.a creating libcubit_virtual.la (cd .libs && rm -f libcubit_virtual.la && ln -s ../libcubit_virtual.la libcubit_virtual.la) make[3]: Leaving directory `/home/jason/cgm/test/32-occ/geom/virtual' Making all in OCC make[3]: Entering directory `/home/jason/cgm/test/32-occ/geom/OCC' /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCShapeAttributeSet.lo -MD -MP -MF .deps/OCCShapeAttributeSet.Tpo -c -o OCCShapeAttributeSet.lo ../../../trunk/geom/OCC/OCCShapeAttributeSet.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCShapeAttributeSet.lo -MD -MP -MF .deps/OCCShapeAttributeSet.Tpo -c ../../../trunk/geom/OCC/OCCShapeAttributeSet.cpp -o OCCShapeAttributeSet.o mv -f .deps/OCCShapeAttributeSet.Tpo .deps/OCCShapeAttributeSet.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCAttribSet.lo -MD -MP -MF .deps/OCCAttribSet.Tpo -c -o OCCAttribSet.lo ../../../trunk/geom/OCC/OCCAttribSet.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCAttribSet.lo -MD -MP -MF .deps/OCCAttribSet.Tpo -c ../../../trunk/geom/OCC/OCCAttribSet.cpp -o OCCAttribSet.o ../../../trunk/geom/OCC/OCCAttribSet.cpp: In static member function ‘static CubitStatus OCCAttribSet::get_attributes(TopoDS_Shape&, DLIList<CubitSimpleAttrib*>&)’: ../../../trunk/geom/OCC/OCCAttribSet.cpp:400: warning: unused variable ‘string’ mv -f .deps/OCCAttribSet.Tpo .deps/OCCAttribSet.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCBody.lo -MD -MP -MF .deps/OCCBody.Tpo -c -o OCCBody.lo ../../../trunk/geom/OCC/OCCBody.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCBody.lo -MD -MP -MF .deps/OCCBody.Tpo -c ../../../trunk/geom/OCC/OCCBody.cpp -o OCCBody.o mv -f .deps/OCCBody.Tpo .deps/OCCBody.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCCoEdge.lo -MD -MP -MF .deps/OCCCoEdge.Tpo -c -o OCCCoEdge.lo ../../../trunk/geom/OCC/OCCCoEdge.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCCoEdge.lo -MD -MP -MF .deps/OCCCoEdge.Tpo -c ../../../trunk/geom/OCC/OCCCoEdge.cpp -o OCCCoEdge.o mv -f .deps/OCCCoEdge.Tpo .deps/OCCCoEdge.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCCoFace.lo -MD -MP -MF .deps/OCCCoFace.Tpo -c -o OCCCoFace.lo ../../../trunk/geom/OCC/OCCCoFace.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCCoFace.lo -MD -MP -MF .deps/OCCCoFace.Tpo -c ../../../trunk/geom/OCC/OCCCoFace.cpp -o OCCCoFace.o mv -f .deps/OCCCoFace.Tpo .deps/OCCCoFace.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCCurve.lo -MD -MP -MF .deps/OCCCurve.Tpo -c -o OCCCurve.lo ../../../trunk/geom/OCC/OCCCurve.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCCurve.lo -MD -MP -MF .deps/OCCCurve.Tpo -c ../../../trunk/geom/OCC/OCCCurve.cpp -o OCCCurve.o mv -f .deps/OCCCurve.Tpo .deps/OCCCurve.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCLoop.lo -MD -MP -MF .deps/OCCLoop.Tpo -c -o OCCLoop.lo ../../../trunk/geom/OCC/OCCLoop.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCLoop.lo -MD -MP -MF .deps/OCCLoop.Tpo -c ../../../trunk/geom/OCC/OCCLoop.cpp -o OCCLoop.o mv -f .deps/OCCLoop.Tpo .deps/OCCLoop.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCLump.lo -MD -MP -MF .deps/OCCLump.Tpo -c -o OCCLump.lo ../../../trunk/geom/OCC/OCCLump.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCLump.lo -MD -MP -MF .deps/OCCLump.Tpo -c ../../../trunk/geom/OCC/OCCLump.cpp -o OCCLump.o mv -f .deps/OCCLump.Tpo .deps/OCCLump.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCModifyEngine.lo -MD -MP -MF .deps/OCCModifyEngine.Tpo -c -o OCCModifyEngine.lo ../../../trunk/geom/OCC/OCCModifyEngine.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCModifyEngine.lo -MD -MP -MF .deps/OCCModifyEngine.Tpo -c ../../../trunk/geom/OCC/OCCModifyEngine.cpp -o OCCModifyEngine.o ../../../trunk/geom/OCC/OCCModifyEngine.cpp: In member function ‘virtual Curve* OCCModifyEngine::create_arc_three(Curve*, Curve*, Curve*, bool)’: ../../../trunk/geom/OCC/OCCModifyEngine.cpp:4830: warning: control reaches end of non-void function mv -f .deps/OCCModifyEngine.Tpo .deps/OCCModifyEngine.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCParamTool.lo -MD -MP -MF .deps/OCCParamTool.Tpo -c -o OCCParamTool.lo ../../../trunk/geom/OCC/OCCParamTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCParamTool.lo -MD -MP -MF .deps/OCCParamTool.Tpo -c ../../../trunk/geom/OCC/OCCParamTool.cpp -o OCCParamTool.o mv -f .deps/OCCParamTool.Tpo .deps/OCCParamTool.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCPoint.lo -MD -MP -MF .deps/OCCPoint.Tpo -c -o OCCPoint.lo ../../../trunk/geom/OCC/OCCPoint.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCPoint.lo -MD -MP -MF .deps/OCCPoint.Tpo -c ../../../trunk/geom/OCC/OCCPoint.cpp -o OCCPoint.o mv -f .deps/OCCPoint.Tpo .deps/OCCPoint.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCQueryEngine.lo -MD -MP -MF .deps/OCCQueryEngine.Tpo -c -o OCCQueryEngine.lo ../../../trunk/geom/OCC/OCCQueryEngine.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCQueryEngine.lo -MD -MP -MF .deps/OCCQueryEngine.Tpo -c ../../../trunk/geom/OCC/OCCQueryEngine.cpp -o OCCQueryEngine.o mv -f .deps/OCCQueryEngine.Tpo .deps/OCCQueryEngine.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCShell.lo -MD -MP -MF .deps/OCCShell.Tpo -c -o OCCShell.lo ../../../trunk/geom/OCC/OCCShell.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCShell.lo -MD -MP -MF .deps/OCCShell.Tpo -c ../../../trunk/geom/OCC/OCCShell.cpp -o OCCShell.o mv -f .deps/OCCShell.Tpo .deps/OCCShell.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCSurface.lo -MD -MP -MF .deps/OCCSurface.Tpo -c -o OCCSurface.lo ../../../trunk/geom/OCC/OCCSurface.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCSurface.lo -MD -MP -MF .deps/OCCSurface.Tpo -c ../../../trunk/geom/OCC/OCCSurface.cpp -o OCCSurface.o mv -f .deps/OCCSurface.Tpo .deps/OCCSurface.Plo /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCDrawTool.lo -MD -MP -MF .deps/OCCDrawTool.Tpo -c -o OCCDrawTool.lo ../../../trunk/geom/OCC/OCCDrawTool.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCDrawTool.lo -MD -MP -MF .deps/OCCDrawTool.Tpo -c ../../../trunk/geom/OCC/OCCDrawTool.cpp -o OCCDrawTool.o mv -f .deps/OCCDrawTool.Tpo .deps/OCCDrawTool.Plo /bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -m32 -o libcubit_OCC.la OCCShapeAttributeSet.lo OCCAttribSet.lo OCCBody.lo OCCCoEdge.lo OCCCoFace.lo OCCCurve.lo OCCLoop.lo OCCLump.lo OCCModifyEngine.lo OCCParamTool.lo OCCPoint.lo OCCQueryEngine.lo OCCShell.lo OCCSurface.lo OCCDrawTool.lo -L/opt/OpenCascade6.3-32bit/lib -lTKMath -lTKXSBase -lTKernel -lTKShHealing -lTKBRep -lTKG3d -lTKBO -lTKFeat -lTKFillet -lTKG2d -lTKOffset -lTKBool -lTKGeomAlgo -lTKGeomBase -lTKPrim -lTKTopAlgo -lTKHLR -lTKIGES -lTKMesh -lTKPrim -lTKSTEP209 -lTKSTEPAttr -lTKSTEPBase -lTKSTEP -lTKSTL -lTKTopAlgo -lTKXSBase -lTKLCAF -ldl -lm rm -fr .libs/libcubit_OCC.a .libs/libcubit_OCC.la ar cru .libs/libcubit_OCC.a OCCShapeAttributeSet.o OCCAttribSet.o OCCBody.o OCCCoEdge.o OCCCoFace.o OCCCurve.o OCCLoop.o OCCLump.o OCCModifyEngine.o OCCParamTool.o OCCPoint.o OCCQueryEngine.o OCCShell.o OCCSurface.o OCCDrawTool.o ranlib .libs/libcubit_OCC.a creating libcubit_OCC.la (cd .libs && rm -f libcubit_OCC.la && ln -s ../libcubit_OCC.la libcubit_OCC.la) make[3]: Leaving directory `/home/jason/cgm/test/32-occ/geom/OCC' make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom' Making all in init make[2]: Entering directory `/home/jason/cgm/test/32-occ/init' /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_OCC -I. -I../../trunk/init -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/geom/ACIS -I../../trunk/geom/OCC -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/cholla -I../../trunk/init -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT InitCGMA.lo -MD -MP -MF .deps/InitCGMA.Tpo -c -o InitCGMA.lo ../../trunk/init/InitCGMA.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_OCC -I. -I../../trunk/init -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/geom/ACIS -I../../trunk/geom/OCC -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/cholla -I../../trunk/init -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT InitCGMA.lo -MD -MP -MF .deps/InitCGMA.Tpo -c ../../trunk/init/InitCGMA.cpp -o InitCGMA.o mv -f .deps/InitCGMA.Tpo .deps/InitCGMA.Plo /bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -m32 -o libcgma_init.la InitCGMA.lo -lm rm -fr .libs/libcgma_init.a .libs/libcgma_init.la ar cru .libs/libcgma_init.a InitCGMA.o ranlib .libs/libcgma_init.a creating libcgma_init.la (cd .libs && rm -f libcgma_init.la && ln -s ../libcgma_init.la libcgma_init.la) make[2]: Leaving directory `/home/jason/cgm/test/32-occ/init' Making all in . make[2]: Entering directory `/home/jason/cgm/test/32-occ' /bin/sh ./libtool --tag=CC --mode=link cc -Wall -pipe -pedantic -g -m32 -o libcgm.la -rpath /usr/local/lib init/libcgma_init.la geom/OCC/libcubit_OCC.la geom/virtual/libcubit_virtual.la geom/facet/libcubit_facet.la geom/Cholla/libcholla.la geom/facetbool/libcubit_facetbool.la geom/libcubit_geom.la util/libcubit_util.la -lTKMath -lTKXSBase -lTKernel -lTKShHealing -lTKBRep -lTKG3d -lTKBO -lTKFeat -lTKFillet -lTKG2d -lTKOffset -lTKBool -lTKGeomAlgo -lTKGeomBase -lTKPrim -lTKTopAlgo -lTKHLR -lTKIGES -lTKMesh -lTKPrim -lTKSTEP209 -lTKSTEPAttr -lTKSTEPBase -lTKSTEP -lTKSTL -lTKTopAlgo -lTKXSBase -lTKLCAF -ldl no -lm rm -fr .libs/libcgm.a .libs/libcgm.la .libs/libcgm.lai rm -fr .libs/libcgm.lax mkdir .libs/libcgm.lax rm -fr .libs/libcgm.lax/libcgma_init.a mkdir .libs/libcgm.lax/libcgma_init.a (cd .libs/libcgm.lax/libcgma_init.a && ar x /home/jason/cgm/test/32-occ/init/.libs/libcgma_init.a) rm -fr .libs/libcgm.lax/libcubit_OCC.a mkdir .libs/libcgm.lax/libcubit_OCC.a (cd .libs/libcgm.lax/libcubit_OCC.a && ar x /home/jason/cgm/test/32-occ/geom/OCC/.libs/libcubit_OCC.a) rm -fr .libs/libcgm.lax/libcubit_virtual.a mkdir .libs/libcgm.lax/libcubit_virtual.a (cd .libs/libcgm.lax/libcubit_virtual.a && ar x /home/jason/cgm/test/32-occ/geom/virtual/.libs/libcubit_virtual.a) rm -fr .libs/libcgm.lax/libcubit_facet.a mkdir .libs/libcgm.lax/libcubit_facet.a (cd .libs/libcgm.lax/libcubit_facet.a && ar x /home/jason/cgm/test/32-occ/geom/facet/.libs/libcubit_facet.a) rm -fr .libs/libcgm.lax/libcholla.a mkdir .libs/libcgm.lax/libcholla.a (cd .libs/libcgm.lax/libcholla.a && ar x /home/jason/cgm/test/32-occ/geom/Cholla/.libs/libcholla.a) rm -fr .libs/libcgm.lax/libcubit_facetbool.a mkdir .libs/libcgm.lax/libcubit_facetbool.a (cd .libs/libcgm.lax/libcubit_facetbool.a && ar x /home/jason/cgm/test/32-occ/geom/facetbool/.libs/libcubit_facetbool.a) rm -fr .libs/libcgm.lax/libcubit_geom.a mkdir .libs/libcgm.lax/libcubit_geom.a (cd .libs/libcgm.lax/libcubit_geom.a && ar x /home/jason/cgm/test/32-occ/geom/.libs/libcubit_geom.a) rm -fr .libs/libcgm.lax/libcubit_util.a mkdir .libs/libcgm.lax/libcubit_util.a (cd .libs/libcgm.lax/libcubit_util.a && ar x /home/jason/cgm/test/32-occ/util/.libs/libcubit_util.a) ar cru .libs/libcgm.a .libs/libcgm.lax/libcgma_init.a/InitCGMA.o .libs/libcgm.lax/libcubit_OCC.a/OCCBody.o .libs/libcgm.lax/libcubit_OCC.a/OCCLump.o .libs/libcgm.lax/libcubit_OCC.a/OCCCoFace.o .libs/libcgm.lax/libcubit_OCC.a/OCCCurve.o .libs/libcgm.lax/libcubit_OCC.a/OCCQueryEngine.o .libs/libcgm.lax/libcubit_OCC.a/OCCDrawTool.o .libs/libcgm.lax/libcubit_OCC.a/OCCAttribSet.o .libs/libcgm.lax/libcubit_OCC.a/OCCShell.o .libs/libcgm.lax/libcubit_OCC.a/OCCModifyEngine.o .libs/libcgm.lax/libcubit_OCC.a/OCCCoEdge.o .libs/libcgm.lax/libcubit_OCC.a/OCCParamTool.o .libs/libcgm.lax/libcubit_OCC.a/OCCPoint.o .libs/libcgm.lax/libcubit_OCC.a/OCCShapeAttributeSet.o .libs/libcgm.lax/libcubit_OCC.a/OCCSurface.o .libs/libcgm.lax/libcubit_OCC.a/OCCLoop.o .libs/libcgm.lax/libcubit_virtual.a/ImprintBoundaryTool.o .libs/libcgm.lax/libcubit_virtual.a/SegmentedCurve.o .libs/libcgm.lax/libcubit_virtual.a/CompositeLump.o .libs/libcgm.lax/libcubit_virtual.a/VirtualImprintTool.o .libs/libcgm.lax/l! ibcubit_virtual.a/CompositeCoEdge.o .libs/libcgm.lax/libcubit_virtual.a/PartitionPoint.o .libs/libcgm.lax/libcubit_virtual.a/CompositeGeom.o .libs/libcgm.lax/libcubit_virtual.a/PartitionLumpImprint.o .libs/libcgm.lax/libcubit_virtual.a/PartitionCurve.o .libs/libcgm.lax/libcubit_virtual.a/PartitionLoop.o .libs/libcgm.lax/libcubit_virtual.a/VirtualQueryEngine.o .libs/libcgm.lax/libcubit_virtual.a/CAPartitionVG.o .libs/libcgm.lax/libcubit_virtual.a/PartSurfFacetTool.o .libs/libcgm.lax/libcubit_virtual.a/TDVGFacetSplit.o .libs/libcgm.lax/libcubit_virtual.a/PartitionCoEdge.o .libs/libcgm.lax/libcubit_virtual.a/PartitionLump.o .libs/libcgm.lax/libcubit_virtual.a/PartitionBody.o .libs/libcgm.lax/libcubit_virtual.a/CompositeTool.o .libs/libcgm.lax/libcubit_virtual.a/FaceterPointData.o .libs/libcgm.lax/libcubit_virtual.a/FaceterFacetData.o .libs/libcgm.lax/libcubit_virtual.a/Faceter.o .libs/libcgm.lax/libcubit_virtual.a/CollapseAngleTool.o .libs/libcgm.lax/libcubit_virtual.a/HiddenE! ntitySet.o .libs/libcgm.lax/libcubit_virtual.a/CAVirtualVG.o .libs/lib cgm.lax/libcubit_virtual.a/SubCurve.o .libs/libcgm.lax/libcubit_virtual.a/PST_Data.o .libs/libcgm.lax/libcubit_virtual.a/PartitionTool.o .libs/libcgm.lax/libcubit_virtual.a/ImprintPointData.o .libs/libcgm.lax/libcubit_virtual.a/SubSurface.o .libs/libcgm.lax/libcubit_virtual.a/CACompositeVG.o .libs/libcgm.lax/libcubit_virtual.a/SubEntitySet.o .libs/libcgm.lax/libcubit_virtual.a/FacetProjectTool.o .libs/libcgm.lax/libcubit_virtual.a/CompositeEngine.o .libs/libcgm.lax/libcubit_virtual.a/PartPTCurve.o .libs/libcgm.lax/libcubit_virtual.a/TDVGFacetOwner.o .libs/libcgm.lax/libcubit_virtual.a/ImprintLineSegment.o .libs/libcgm.lax/libcubit_virtual.a/AllocMemManagersVirtual.o .libs/libcgm.lax/libcubit_virtual.a/CompositeAttrib.o .libs/libcgm.lax/libcubit_virtual.a/CompSurfFacets.o .libs/libcgm.lax/libcubit_virtual.a/CompositeBody.o .libs/libcgm.lax/libcubit_virtual.a/CompositeCoSurf.o .libs/libcgm.lax/libcubit_virtual.a/PartitionCoSurf.o .libs/libcgm.lax/libcubit_virtual.a/PartitionSh! ell.o .libs/libcgm.lax/libcubit_virtual.a/CompositeSurface.o .libs/libcgm.lax/libcubit_virtual.a/CompositePoint.o .libs/libcgm.lax/libcubit_virtual.a/PartitionSurface.o .libs/libcgm.lax/libcubit_virtual.a/CompositeCurve.o .libs/libcgm.lax/libcubit_virtual.a/CompositeShell.o .libs/libcgm.lax/libcubit_virtual.a/PartitionEntity.o .libs/libcgm.lax/libcubit_virtual.a/CompositeLoop.o .libs/libcgm.lax/libcubit_virtual.a/PartitionEngine.o .libs/libcgm.lax/libcubit_facet.a/FacetAttribSet.o .libs/libcgm.lax/libcubit_facet.a/GridSearchTree.o .libs/libcgm.lax/libcubit_facet.a/FacetLoop.o .libs/libcgm.lax/libcubit_facet.a/FacetLump.o .libs/libcgm.lax/libcubit_facet.a/FacetParamTool.o .libs/libcgm.lax/libcubit_facet.a/FacetCoEdge.o .libs/libcgm.lax/libcubit_facet.a/FacetSurface.o .libs/libcgm.lax/libcubit_facet.a/FacetCurve.o .libs/libcgm.lax/libcubit_facet.a/FacetShell.o .libs/libcgm.lax/libcubit_facet.a/FacetBody.o .libs/libcgm.lax/libcubit_facet.a/FacetboolInterface.o .libs/libcgm.la! x/libcubit_facet.a/FacetModifyEngine.o .libs/libcgm.lax/libcubit_facet .a/FacetPoint.o .libs/libcgm.lax/libcubit_facet.a/FacetAttrib.o .libs/libcgm.lax/libcubit_facet.a/FacetQueryEngine.o .libs/libcgm.lax/libcholla.a/TDChordal.o .libs/libcgm.lax/libcholla.a/CubitPoint.o .libs/libcgm.lax/libcholla.a/ChollaPoint.o .libs/libcgm.lax/libcholla.a/FacetEvalTool.o .libs/libcgm.lax/libcholla.a/CubitQuadFacet.o .libs/libcgm.lax/libcholla.a/PointGridSearch.o .libs/libcgm.lax/libcholla.a/FacetEntity.o .libs/libcgm.lax/libcholla.a/Cholla.o .libs/libcgm.lax/libcholla.a/GeoNode.o .libs/libcgm.lax/libcholla.a/TDFacetBoundaryEdge.o .libs/libcgm.lax/libcholla.a/ChordalAxis.o .libs/libcgm.lax/libcholla.a/PointLoopFacetor.o .libs/libcgm.lax/libcholla.a/ChollaEngine.o .libs/libcgm.lax/libcholla.a/debug.o .libs/libcgm.lax/libcholla.a/ChollaSkinTool.o .libs/libcgm.lax/libcholla.a/ChollaEntity.o .libs/libcgm.lax/libcholla.a/LoopParamTool.o .libs/libcgm.lax/libcholla.a/CubitFacetData.o .libs/libcgm.lax/libcholla.a/GeoTet.o .libs/libcgm.lax/libcholla.a/AllocMemManagers! Cholla.o .libs/libcgm.lax/libcholla.a/CubitFacetEdge.o .libs/libcgm.lax/libcholla.a/CubitFacet.o .libs/libcgm.lax/libcholla.a/CurveFacetEvalTool.o .libs/libcgm.lax/libcholla.a/FacetDataUtil.o .libs/libcgm.lax/libcholla.a/CubitFacetEdgeData.o .libs/libcgm.lax/libcholla.a/TDGeomFacet.o .libs/libcgm.lax/libcholla.a/CubitPointData.o .libs/libcgm.lax/libcholla.a/ChollaSurface.o .libs/libcgm.lax/libcholla.a/CubitQuadFacetData.o .libs/libcgm.lax/libcholla.a/TDFacetboolData.o .libs/libcgm.lax/libcholla.a/ChollaCurve.o .libs/libcgm.lax/libcholla.a/TDFacetBoundaryPoint.o .libs/libcgm.lax/libcubit_facetbool.a/FBRetriangulate.o .libs/libcgm.lax/libcubit_facetbool.a/FBDataUtil.o .libs/libcgm.lax/libcubit_facetbool.a/FBIntersect.o .libs/libcgm.lax/libcubit_facetbool.a/KdTree.o .libs/libcgm.lax/libcubit_facetbool.a/FBImprint.o .libs/libcgm.lax/libcubit_facetbool.a/FBTiler.o .libs/libcgm.lax/libcubit_facetbool.a/IntegerHash.o .libs/libcgm.lax/libcubit_facetbool.a/FBClassify.o .libs/libcgm! .lax/libcubit_facetbool.a/FBPolyhedron.o .libs/libcgm.lax/libcubit_ge om.a/CoVolume.o .libs/libcgm.lax/libcubit_geom.a/RefGroup.o .libs/libcgm.lax/libcubit_geom.a/GeometryFeatureEngine.o .libs/libcgm.lax/libcubit_geom.a/AllocMemManagersGeom.o .libs/libcgm.lax/libcubit_geom.a/OffsetSplitTool.o .libs/libcgm.lax/libcubit_geom.a/RefVertex.o .libs/libcgm.lax/libcubit_geom.a/CubitPolygon.o .libs/libcgm.lax/libcubit_geom.a/CAEntityColor.o .libs/libcgm.lax/libcubit_geom.a/TDSplitSurface.o .libs/libcgm.lax/libcubit_geom.a/GeomDataObserver.o .libs/libcgm.lax/libcubit_geom.a/SurfaceSM.o .libs/libcgm.lax/libcubit_geom.a/BridgeManager.o .libs/libcgm.lax/libcubit_geom.a/CoFace.o .libs/libcgm.lax/libcubit_geom.a/CAEntityName.o .libs/libcgm.lax/libcubit_geom.a/CAActuateSet.o .libs/libcgm.lax/libcubit_geom.a/GeometryHealerEngine.o .libs/libcgm.lax/libcubit_geom.a/GeomMeasureTool.o .libs/libcgm.lax/libcubit_geom.a/CAMergePartner.o .libs/libcgm.lax/libcubit_geom.a/GeometryUtil.o .libs/libcgm.lax/libcubit_geom.a/GeometryQueryEngine.o .libs/libcgm.lax/libcubit_geo! m.a/CGMEngineDynamicLoader.o .libs/libcgm.lax/libcubit_geom.a/PointSM.o .libs/libcgm.lax/libcubit_geom.a/CubitAttribUser.o .libs/libcgm.lax/libcubit_geom.a/RefFace.o .libs/libcgm.lax/libcubit_geom.a/CAMergeStatus.o .libs/libcgm.lax/libcubit_geom.a/TDSurfaceOverlap.o .libs/libcgm.lax/libcubit_geom.a/Lump.o .libs/libcgm.lax/libcubit_geom.a/MedialTool2D.o .libs/libcgm.lax/libcubit_geom.a/RefEntityName.o .libs/libcgm.lax/libcubit_geom.a/GSaveOpen.o .libs/libcgm.lax/libcubit_geom.a/CAUniqueId.o .libs/libcgm.lax/libcubit_geom.a/TopologyBridge.o .libs/libcgm.lax/libcubit_geom.a/CubitAttribManager.o .libs/libcgm.lax/libcubit_geom.a/TDUniqueId.o .libs/libcgm.lax/libcubit_geom.a/CurveOverlapFacet.o .libs/libcgm.lax/libcubit_geom.a/GeometryFeatureTool.o .libs/libcgm.lax/libcubit_geom.a/CADeferredAttrib.o .libs/libcgm.lax/libcubit_geom.a/CoVertex.o .libs/libcgm.lax/libcubit_geom.a/GeometryQueryTool.o .libs/libcgm.lax/libcubit_geom.a/RefEntity.o .libs/libcgm.lax/libcubit_geom.a/SphereEv! aluator.o .libs/libcgm.lax/libcubit_geom.a/Shell.o .libs/libcgm.lax/li bcubit_geom.a/LumpSM.o .libs/libcgm.lax/libcubit_geom.a/BoundingBoxTool.o .libs/libcgm.lax/libcubit_geom.a/SurfaceOverlapTool.o .libs/libcgm.lax/libcubit_geom.a/CAEntityId.o .libs/libcgm.lax/libcubit_geom.a/Curve.o .libs/libcgm.lax/libcubit_geom.a/Point.o .libs/libcgm.lax/libcubit_geom.a/SplitSurfaceTool.o .libs/libcgm.lax/libcubit_geom.a/RefVolume.o .libs/libcgm.lax/libcubit_geom.a/Loop.o .libs/libcgm.lax/libcubit_geom.a/RefEdge.o .libs/libcgm.lax/libcubit_geom.a/TDCAGE.o .libs/libcgm.lax/libcubit_geom.a/MedialTool3D.o .libs/libcgm.lax/libcubit_geom.a/TDSourceFeature.o .libs/libcgm.lax/libcubit_geom.a/CubitSimpleAttrib.o .libs/libcgm.lax/libcubit_geom.a/CAGroup.o .libs/libcgm.lax/libcubit_geom.a/MergeToolAssistant.o .libs/libcgm.lax/libcubit_geom.a/GeometryModifyEngine.o .libs/libcgm.lax/libcubit_geom.a/GeometryEntity.o .libs/libcgm.lax/libcubit_geom.a/ModelQueryEngine.o .libs/libcgm.lax/libcubit_geom.a/AnalyticGeometryTool.o .libs/libcgm.lax/libcubit_geom.a/GfxPreview.o .l! ibs/libcgm.lax/libcubit_geom.a/DAG.o .libs/libcgm.lax/libcubit_geom.a/RefCollection.o .libs/libcgm.lax/libcubit_geom.a/RefEntityFactory.o .libs/libcgm.lax/libcubit_geom.a/CASourceFeature.o .libs/libcgm.lax/libcubit_geom.a/SurfParamTool.o .libs/libcgm.lax/libcubit_geom.a/GeometryModifyTool.o .libs/libcgm.lax/libcubit_geom.a/LoopSM.o .libs/libcgm.lax/libcubit_geom.a/ModelEntity.o .libs/libcgm.lax/libcubit_geom.a/Surface.o .libs/libcgm.lax/libcubit_geom.a/SenseEntity.o .libs/libcgm.lax/libcubit_geom.a/CylinderEvaluator.o .libs/libcgm.lax/libcubit_geom.a/GroupingEntity.o .libs/libcgm.lax/libcubit_geom.a/BodySM.o .libs/libcgm.lax/libcubit_geom.a/CurveSM.o .libs/libcgm.lax/libcubit_geom.a/CoEdge.o .libs/libcgm.lax/libcubit_geom.a/MergeTool.o .libs/libcgm.lax/libcubit_geom.a/CGMApp.o .libs/libcgm.lax/libcubit_geom.a/CubitAttrib.o .libs/libcgm.lax/libcubit_geom.a/CoEdgeSM.o .libs/libcgm.lax/libcubit_geom.a/TopologyEntity.o .libs/libcgm.lax/libcubit_geom.a/MidPlaneTool.o .libs/libcg! m.lax/libcubit_geom.a/OldUnmergeCode.o .libs/libcgm.lax/libcubit_geom. a/Chain.o .libs/libcgm.lax/libcubit_geom.a/SurfaceOverlapFacet.o .libs/libcgm.lax/libcubit_geom.a/GeometryHealerTool.o .libs/libcgm.lax/libcubit_geom.a/Body.o .libs/libcgm.lax/libcubit_geom.a/DagDrawingTool.o .libs/libcgm.lax/libcubit_geom.a/BasicTopologyEntity.o .libs/libcgm.lax/libcubit_geom.a/CollectionEntity.o .libs/libcgm.lax/libcubit_geom.a/ShellSM.o .libs/libcgm.lax/libcubit_util.a/GMem.o .libs/libcgm.lax/libcubit_util.a/CubitCoordinateSystem.o .libs/libcgm.lax/libcubit_util.a/GfxDebug.o .libs/libcgm.lax/libcubit_util.a/CubitString.o .libs/libcgm.lax/libcubit_util.a/StubProgressTool.o .libs/libcgm.lax/libcubit_util.a/TextProgressTool.o .libs/libcgm.lax/libcubit_util.a/TDUPtr.o .libs/libcgm.lax/libcubit_util.a/CubitStack.o .libs/libcgm.lax/libcubit_util.a/CubitMessage.o .libs/libcgm.lax/libcubit_util.a/CubitFileIOWrapper.o .libs/libcgm.lax/libcubit_util.a/CubitFileUtil.o .libs/libcgm.lax/libcubit_util.a/CubitEntity.o .libs/libcgm.lax/libcubit_util.a/CubitVector.o .lib! s/libcgm.lax/libcubit_util.a/IntersectionTool.o .libs/libcgm.lax/libcubit_util.a/MemoryBlock.o .libs/libcgm.lax/libcubit_util.a/Queue.o .libs/libcgm.lax/libcubit_util.a/SettingHolder.o .libs/libcgm.lax/libcubit_util.a/Cubit2DPoint.o .libs/libcgm.lax/libcubit_util.a/CubitCollection.o .libs/libcgm.lax/libcubit_util.a/PlanarParamTool.o .libs/libcgm.lax/libcubit_util.a/ArrayBasedContainer.o .libs/libcgm.lax/libcubit_util.a/GetLongOpt.o .libs/libcgm.lax/libcubit_util.a/CubitFileFEModel.o .libs/libcgm.lax/libcubit_util.a/AllocMemManagersList.o .libs/libcgm.lax/libcubit_util.a/CubitPlane.o .libs/libcgm.lax/libcubit_util.a/CubitDynamicLoader.o .libs/libcgm.lax/libcubit_util.a/TtyProgressTool.o .libs/libcgm.lax/libcubit_util.a/CubitObservable.o .libs/libcgm.lax/libcubit_util.a/DIntArray.o .libs/libcgm.lax/libcubit_util.a/DynamicArray.o .libs/libcgm.lax/libcubit_util.a/ToolData.o .libs/libcgm.lax/libcubit_util.a/ToolDataUser.o .libs/libcgm.lax/libcubit_util.a/RandomMersenne.o .libs/l! ibcgm.lax/libcubit_util.a/SDLList.o .libs/libcgm.lax/libcubit_util.a/C ubitBox.o .libs/libcgm.lax/libcubit_util.a/CubitTransformMatrix.o .libs/libcgm.lax/libcubit_util.a/ParamCubitPlane.o .libs/libcgm.lax/libcubit_util.a/CubitFileMetaData.o .libs/libcgm.lax/libcubit_util.a/DLList.o .libs/libcgm.lax/libcubit_util.a/CubitFile.o .libs/libcgm.lax/libcubit_util.a/CubitMatrix.o .libs/libcgm.lax/libcubit_util.a/CubitObserver.o .libs/libcgm.lax/libcubit_util.a/CubitContainer.o .libs/libcgm.lax/libcubit_util.a/Tree.o .libs/libcgm.lax/libcubit_util.a/AppUtil.o .libs/libcgm.lax/libcubit_util.a/CpuTimer.o .libs/libcgm.lax/libcubit_util.a/MemoryManager.o .libs/libcgm.lax/libcubit_util.a/CubitUtil.o .libs/libcgm.lax/libcubit_util.a/SettingHandler.o ranlib .libs/libcgm.a rm -fr .libs/libcgm.lax creating libcgm.la (cd .libs && rm -f libcgm.la && ln -s ../libcgm.la libcgm.la) make[2]: Leaving directory `/home/jason/cgm/test/32-occ' Making all in itaps make[2]: Entering directory `/home/jason/cgm/test/32-occ/itaps' make all-recursive make[3]: Entering directory `/home/jason/cgm/test/32-occ/itaps' Making all in . make[4]: Entering directory `/home/jason/cgm/test/32-occ/itaps' /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -I. -I../../trunk/itaps -I.. -I../../trunk/util -I../../trunk/geom -I../../trunk/init -I. -Wall -pipe -pedantic -g -m32 -MT CATag.lo -MD -MP -MF .deps/CATag.Tpo -c -o CATag.lo ../../trunk/itaps/CATag.cpp c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -I. -I../../trunk/itaps -I.. -I../../trunk/util -I../../trunk/geom -I../../trunk/init -I. -Wall -pipe -pedantic -g -m32 -MT CATag.lo -MD -MP -MF .deps/CATag.Tpo -c ../../trunk/itaps/CATag.cpp -o CATag.o mv -f .deps/CATag.Tpo .deps/CATag.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -I. -I../../trunk/itaps -I.. -I../../trunk/util -I../../trunk/geom -I../../trunk/init -I. -Wall -pipe -pedantic -g -m32 -MT iGeom_CGMA.lo -MD -MP -MF .deps/iGeom_CGMA.Tpo -c -o iGeom_CGMA.lo ../../trunk/itaps/iGeom_CGMA.cc c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -I. -I../../trunk/itaps -I.. -I../../trunk/util -I../../trunk/geom -I../../trunk/init -I. -Wall -pipe -pedantic -g -m32 -MT iGeom_CGMA.lo -MD -MP -MF .deps/iGeom_CGMA.Tpo -c ../../trunk/itaps/iGeom_CGMA.cc -o iGeom_CGMA.o mv -f .deps/iGeom_CGMA.Tpo .deps/iGeom_CGMA.Plo /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -I. -I../../trunk/itaps -I.. -I../../trunk/util -I../../trunk/geom -I../../trunk/init -I. -Wall -pipe -pedantic -g -m32 -MT iGeomError.lo -MD -MP -MF .deps/iGeomError.Tpo -c -o iGeomError.lo ../../trunk/itaps/iGeomError.cc c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -I. -I../../trunk/itaps -I.. -I../../trunk/util -I../../trunk/geom -I../../trunk/init -I. -Wall -pipe -pedantic -g -m32 -MT iGeomError.lo -MD -MP -MF .deps/iGeomError.Tpo -c ../../trunk/itaps/iGeomError.cc -o iGeomError.o mv -f .deps/iGeomError.Tpo .deps/iGeomError.Plo /bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -m32 -o libiGeom.la -rpath /usr/local/lib CATag.lo iGeom_CGMA.lo iGeomError.lo ../libcgm.la -lm rm -fr .libs/libiGeom.a .libs/libiGeom.la .libs/libiGeom.lai ar cru .libs/libiGeom.a CATag.o iGeom_CGMA.o iGeomError.o ranlib .libs/libiGeom.a creating libiGeom.la (cd .libs && rm -f libiGeom.la && ln -s ../libiGeom.la libiGeom.la) make[4]: Leaving directory `/home/jason/cgm/test/32-occ/itaps' make[3]: Leaving directory `/home/jason/cgm/test/32-occ/itaps' make[2]: Leaving directory `/home/jason/cgm/test/32-occ/itaps' Making all in test make[2]: Entering directory `/home/jason/cgm/test/32-occ/test' make[2]: Nothing to be done for `all'. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/test' Making all in cgm_apps make[2]: Entering directory `/home/jason/cgm/test/32-occ/cgm_apps' Making all in examples make[3]: Entering directory `/home/jason/cgm/test/32-occ/cgm_apps/examples' Making all in facetdriver make[4]: Entering directory `/home/jason/cgm/test/32-occ/cgm_apps/examples/facetdriver' make[4]: Nothing to be done for `all'. make[4]: Leaving directory `/home/jason/cgm/test/32-occ/cgm_apps/examples/facetdriver' make[4]: Entering directory `/home/jason/cgm/test/32-occ/cgm_apps/examples' make[4]: Nothing to be done for `all-am'. make[4]: Leaving directory `/home/jason/cgm/test/32-occ/cgm_apps/examples' make[3]: Leaving directory `/home/jason/cgm/test/32-occ/cgm_apps/examples' make[3]: Entering directory `/home/jason/cgm/test/32-occ/cgm_apps' make[3]: Nothing to be done for `all-am'. make[3]: Leaving directory `/home/jason/cgm/test/32-occ/cgm_apps' make[2]: Leaving directory `/home/jason/cgm/test/32-occ/cgm_apps' make[1]: Leaving directory `/home/jason/cgm/test/32-occ' Making check in compat make[1]: Entering directory `/home/jason/cgm/test/32-occ/compat' make[1]: Nothing to be done for `check'. make[1]: Leaving directory `/home/jason/cgm/test/32-occ/compat' Making check in util make[1]: Entering directory `/home/jason/cgm/test/32-occ/util' make[1]: Nothing to be done for `check'. make[1]: Leaving directory `/home/jason/cgm/test/32-occ/util' Making check in geom make[1]: Entering directory `/home/jason/cgm/test/32-occ/geom' Making check in . make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom' make[2]: Nothing to be done for `check-am'. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom' Making check in Cholla make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/Cholla' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/Cholla' Making check in facetbool make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/facetbool' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facetbool' Making check in facet make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/facet' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facet' Making check in virtual make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/virtual' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/virtual' Making check in OCC make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/OCC' make[2]: Nothing to be done for `check'. make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/OCC' make[1]: Leaving directory `/home/jason/cgm/test/32-occ/geom' Making check in init make[1]: Entering directory `/home/jason/cgm/test/32-occ/init' make[1]: Nothing to be done for `check'. make[1]: Leaving directory `/home/jason/cgm/test/32-occ/init' Making check in . make[1]: Entering directory `/home/jason/cgm/test/32-occ' make[1]: Leaving directory `/home/jason/cgm/test/32-occ' Making check in itaps make[1]: Entering directory `/home/jason/cgm/test/32-occ/itaps' Making check in . make[2]: Entering directory `/home/jason/cgm/test/32-occ/itaps' make testgeom_occ make[3]: Entering directory `/home/jason/cgm/test/32-occ/itaps' c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -I. -I../../trunk/itaps -I.. -I../../trunk/util -I../../trunk/geom -I../../trunk/init -I. -DSRCDIR=../../trunk/itaps -DFORCE_OCC -Wall -pipe -pedantic -g -m32 -MT testgeom_occ-testgeom.o -MD -MP -MF .deps/testgeom_occ-testgeom.Tpo -c -o testgeom_occ-testgeom.o `test -f 'testgeom.cc' || echo '../../trunk/itaps/'`testgeom.cc mv -f .deps/testgeom_occ-testgeom.Tpo .deps/testgeom_occ-testgeom.Po /bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -m32 -L/opt/OpenCascade6.3-32bit/lib -o testgeom_occ testgeom_occ-testgeom.o libiGeom.la -lm c++ -Wall -pipe -pedantic -g -m32 -o testgeom_occ testgeom_occ-testgeom.o -L/opt/OpenCascade6.3-32bit/lib ./.libs/libiGeom.a /home/jason/cgm/test/32-occ/.libs/libcgm.a /opt/OpenCascade6.3-32bit/lib/libTKFeat.so /opt/OpenCascade6.3-32bit/lib/libTKHLR.so /opt/OpenCascade6.3-32bit/lib/libTKIGES.so /opt/OpenCascade6.3-32bit/lib/libTKOffset.so /opt/OpenCascade6.3-32bit/lib/libTKFillet.so /opt/OpenCascade6.3-32bit/lib/libTKBool.so /opt/OpenCascade6.3-32bit/lib/libTKBO.so /opt/OpenCascade6.3-32bit/lib/libTKPrim.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPAttr.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP209.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPBase.so /opt/OpenCascade6.3-32bit/lib/libTKSTL.so /opt/OpenCascade6.3-32bit/lib/libTKMesh.so /opt/OpenCascade6.3-32bit/lib/libTKXSBase.so /opt/OpenCascade6.3-32bit/lib/libTKShHealing.so /opt/OpenCascade6.3-32bit/lib/libTKLCAF.so /opt/OpenCascade6.3-32bit/lib/libTKCDF.so /opt/OpenCascade6.3-32bit/lib! /libTKTopAlgo.so /opt/OpenCascade6.3-32bit/lib/libTKGeomAlgo.so /opt/OpenCascade6.3-32bit/lib/libTKBRep.so /opt/OpenCascade6.3-32bit/lib/libTKGeomBase.so /opt/OpenCascade6.3-32bit/lib/libTKG3d.so /opt/OpenCascade6.3-32bit/lib/libTKG2d.so /opt/OpenCascade6.3-32bit/lib/libTKMath.so /opt/OpenCascade6.3-32bit/lib/libTKernel.so -lpthread -ldl -lm -Wl,--rpath -Wl,/opt/OpenCascade6.3-32bit/lib -Wl,--rpath -Wl,/opt/OpenCascade6.3-32bit/lib ./.libs/libiGeom.a(iGeom_CGMA.o): In function `iGeom_load_cub_geometry': /home/jason/cgm/test/32-occ/itaps/../../trunk/itaps/iGeom_CGMA.cc:5883: warning: the use of `tmpnam' is dangerous, better use `mkstemp' make[3]: Leaving directory `/home/jason/cgm/test/32-occ/itaps' make check-TESTS make[3]: Entering directory `/home/jason/cgm/test/32-occ/itaps' Using default input file: ../../trunk/itaps/../test/LeverArm.brep Geometry engine set to: OCC Geometry Engine version 6.2.0 ITAPS GEOMETRY INTERFACE TEST PROGRAM: gLoad: Model contents: vertices: 0 edges: 0 faces: 0 regions: 0 Success tags: Tags defined on model: <none> Success gentity sets: Success topology adjacencies: Success construct: Created swept volume 3 Success primitives: Success transforms: Success booleans: Updated volume(s): 10 Destroyed volume(s): 11 Updated volume(s): 12 Updated volume(s): 12 Destroyed volume(s): 13 Success shutdown: Success TSTT TEST SUMMARY: Number Tests: 9 Number Successful: 9 Number Not Implemented: 0 Number Failed: 0 PASS: testgeom_occ ================== All 1 tests passed ================== make[3]: Leaving directory `/home/jason/cgm/test/32-occ/itaps' make[2]: Leaving directory `/home/jason/cgm/test/32-occ/itaps' make[1]: Leaving directory `/home/jason/cgm/test/32-occ/itaps' Making check in test make[1]: Entering directory `/home/jason/cgm/test/32-occ/test' make sheet modify makept r_w test_occ make[2]: Entering directory `/home/jason/cgm/test/32-occ/test' c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_OCC -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/init -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_OCC -Wall -pipe -pedantic -g -m32 -MT sheet.o -MD -MP -MF .deps/sheet.Tpo -c -o sheet.o ../../trunk/test/sheet.cpp mv -f .deps/sheet.Tpo .deps/sheet.Po /bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -m32 -L/opt/OpenCascade6.3-32bit/lib -o sheet sheet.o ../libcgm.la -lm c++ -Wall -pipe -pedantic -g -m32 -o sheet sheet.o -L/opt/OpenCascade6.3-32bit/lib ../.libs/libcgm.a /opt/OpenCascade6.3-32bit/lib/libTKFeat.so /opt/OpenCascade6.3-32bit/lib/libTKHLR.so /opt/OpenCascade6.3-32bit/lib/libTKIGES.so /opt/OpenCascade6.3-32bit/lib/libTKOffset.so /opt/OpenCascade6.3-32bit/lib/libTKFillet.so /opt/OpenCascade6.3-32bit/lib/libTKBool.so /opt/OpenCascade6.3-32bit/lib/libTKBO.so /opt/OpenCascade6.3-32bit/lib/libTKPrim.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPAttr.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP209.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPBase.so /opt/OpenCascade6.3-32bit/lib/libTKSTL.so /opt/OpenCascade6.3-32bit/lib/libTKMesh.so /opt/OpenCascade6.3-32bit/lib/libTKXSBase.so /opt/OpenCascade6.3-32bit/lib/libTKShHealing.so /opt/OpenCascade6.3-32bit/lib/libTKLCAF.so /opt/OpenCascade6.3-32bit/lib/libTKCDF.so /opt/OpenCascade6.3-32bit/lib/libTKTopAlgo.so /opt/OpenCascade6.3-32bit/lib/libTKGeomAlgo.so /op! t/OpenCascade6.3-32bit/lib/libTKBRep.so /opt/OpenCascade6.3-32bit/lib/libTKGeomBase.so /opt/OpenCascade6.3-32bit/lib/libTKG3d.so /opt/OpenCascade6.3-32bit/lib/libTKG2d.so /opt/OpenCascade6.3-32bit/lib/libTKMath.so /opt/OpenCascade6.3-32bit/lib/libTKernel.so -lpthread -ldl -lm -Wl,--rpath -Wl,/opt/OpenCascade6.3-32bit/lib -Wl,--rpath -Wl,/opt/OpenCascade6.3-32bit/lib c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_OCC -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/init -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_OCC -Wall -pipe -pedantic -g -m32 -MT modify.o -MD -MP -MF .deps/modify.Tpo -c -o modify.o ../../trunk/test/modify.cpp ../../trunk/test/modify.cpp: In function ‘CubitStatus make_Point()’: ../../trunk/test/modify.cpp:878: warning: unused variable ‘vt3’ mv -f .deps/modify.Tpo .deps/modify.Po /bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -m32 -L/opt/OpenCascade6.3-32bit/lib -o modify modify.o ../libcgm.la -lm c++ -Wall -pipe -pedantic -g -m32 -o modify modify.o -L/opt/OpenCascade6.3-32bit/lib ../.libs/libcgm.a /opt/OpenCascade6.3-32bit/lib/libTKFeat.so /opt/OpenCascade6.3-32bit/lib/libTKHLR.so /opt/OpenCascade6.3-32bit/lib/libTKIGES.so /opt/OpenCascade6.3-32bit/lib/libTKOffset.so /opt/OpenCascade6.3-32bit/lib/libTKFillet.so /opt/OpenCascade6.3-32bit/lib/libTKBool.so /opt/OpenCascade6.3-32bit/lib/libTKBO.so /opt/OpenCascade6.3-32bit/lib/libTKPrim.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPAttr.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP209.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPBase.so /opt/OpenCascade6.3-32bit/lib/libTKSTL.so /opt/OpenCascade6.3-32bit/lib/libTKMesh.so /opt/OpenCascade6.3-32bit/lib/libTKXSBase.so /opt/OpenCascade6.3-32bit/lib/libTKShHealing.so /opt/OpenCascade6.3-32bit/lib/libTKLCAF.so /opt/OpenCascade6.3-32bit/lib/libTKCDF.so /opt/OpenCascade6.3-32bit/lib/libTKTopAlgo.so /opt/OpenCascade6.3-32bit/lib/libTKGeomAlgo.so /! opt/OpenCascade6.3-32bit/lib/libTKBRep.so /opt/OpenCascade6.3-32bit/lib/libTKGeomBase.so /opt/OpenCascade6.3-32bit/lib/libTKG3d.so /opt/OpenCascade6.3-32bit/lib/libTKG2d.so /opt/OpenCascade6.3-32bit/lib/libTKMath.so /opt/OpenCascade6.3-32bit/lib/libTKernel.so -lpthread -ldl -lm -Wl,--rpath -Wl,/opt/OpenCascade6.3-32bit/lib -Wl,--rpath -Wl,/opt/OpenCascade6.3-32bit/lib c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_OCC -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/init -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_OCC -Wall -pipe -pedantic -g -m32 -MT makept.o -MD -MP -MF .deps/makept.Tpo -c -o makept.o ../../trunk/test/makept.cpp ../../trunk/test/makept.cpp: In function ‘CubitStatus make_Point()’: ../../trunk/test/makept.cpp:289: warning: unused variable ‘d’ ../../trunk/test/makept.cpp:206: warning: unused variable ‘is_equal’ ../../trunk/test/makept.cpp:294: warning: unused variable ‘new_face2’ ../../trunk/test/makept.cpp:335: warning: unused variable ‘area’ ../../trunk/test/makept.cpp:374: warning: unused variable ‘pc2’ ../../trunk/test/makept.cpp:378: warning: unused variable ‘num_loops’ ../../trunk/test/makept.cpp:383: warning: unused variable ‘angle’ mv -f .deps/makept.Tpo .deps/makept.Po /bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -m32 -L/opt/OpenCascade6.3-32bit/lib -o makept makept.o ../libcgm.la -lm c++ -Wall -pipe -pedantic -g -m32 -o makept makept.o -L/opt/OpenCascade6.3-32bit/lib ../.libs/libcgm.a /opt/OpenCascade6.3-32bit/lib/libTKFeat.so /opt/OpenCascade6.3-32bit/lib/libTKHLR.so /opt/OpenCascade6.3-32bit/lib/libTKIGES.so /opt/OpenCascade6.3-32bit/lib/libTKOffset.so /opt/OpenCascade6.3-32bit/lib/libTKFillet.so /opt/OpenCascade6.3-32bit/lib/libTKBool.so /opt/OpenCascade6.3-32bit/lib/libTKBO.so /opt/OpenCascade6.3-32bit/lib/libTKPrim.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPAttr.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP209.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPBase.so /opt/OpenCascade6.3-32bit/lib/libTKSTL.so /opt/OpenCascade6.3-32bit/lib/libTKMesh.so /opt/OpenCascade6.3-32bit/lib/libTKXSBase.so /opt/OpenCascade6.3-32bit/lib/libTKShHealing.so /opt/OpenCascade6.3-32bit/lib/libTKLCAF.so /opt/OpenCascade6.3-32bit/lib/libTKCDF.so /opt/OpenCascade6.3-32bit/lib/libTKTopAlgo.so /opt/OpenCascade6.3-32bit/lib/libTKGeomAlgo.so /! opt/OpenCascade6.3-32bit/lib/libTKBRep.so /opt/OpenCascade6.3-32bit/lib/libTKGeomBase.so /opt/OpenCascade6.3-32bit/lib/libTKG3d.so /opt/OpenCascade6.3-32bit/lib/libTKG2d.so /opt/OpenCascade6.3-32bit/lib/libTKMath.so /opt/OpenCascade6.3-32bit/lib/libTKernel.so -lpthread -ldl -lm -Wl,--rpath -Wl,/opt/OpenCascade6.3-32bit/lib -Wl,--rpath -Wl,/opt/OpenCascade6.3-32bit/lib c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_OCC -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/init -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_OCC -Wall -pipe -pedantic -g -m32 -MT r_w.o -MD -MP -MF .deps/r_w.Tpo -c -o r_w.o ../../trunk/test/r_w.cpp ../../trunk/test/r_w.cpp: In function ‘CubitStatus make_Point()’: ../../trunk/test/r_w.cpp:313: warning: unused variable ‘d’ ../../trunk/test/r_w.cpp:315: warning: unused variable ‘n’ mv -f .deps/r_w.Tpo .deps/r_w.Po /bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -m32 -L/opt/OpenCascade6.3-32bit/lib -o r_w r_w.o ../libcgm.la -lm c++ -Wall -pipe -pedantic -g -m32 -o r_w r_w.o -L/opt/OpenCascade6.3-32bit/lib ../.libs/libcgm.a /opt/OpenCascade6.3-32bit/lib/libTKFeat.so /opt/OpenCascade6.3-32bit/lib/libTKHLR.so /opt/OpenCascade6.3-32bit/lib/libTKIGES.so /opt/OpenCascade6.3-32bit/lib/libTKOffset.so /opt/OpenCascade6.3-32bit/lib/libTKFillet.so /opt/OpenCascade6.3-32bit/lib/libTKBool.so /opt/OpenCascade6.3-32bit/lib/libTKBO.so /opt/OpenCascade6.3-32bit/lib/libTKPrim.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPAttr.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP209.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPBase.so /opt/OpenCascade6.3-32bit/lib/libTKSTL.so /opt/OpenCascade6.3-32bit/lib/libTKMesh.so /opt/OpenCascade6.3-32bit/lib/libTKXSBase.so /opt/OpenCascade6.3-32bit/lib/libTKShHealing.so /opt/OpenCascade6.3-32bit/lib/libTKLCAF.so /opt/OpenCascade6.3-32bit/lib/libTKCDF.so /opt/OpenCascade6.3-32bit/lib/libTKTopAlgo.so /opt/OpenCascade6.3-32bit/lib/libTKGeomAlgo.so /opt/Op! enCascade6.3-32bit/lib/libTKBRep.so /opt/OpenCascade6.3-32bit/lib/libTKGeomBase.so /opt/OpenCascade6.3-32bit/lib/libTKG3d.so /opt/OpenCascade6.3-32bit/lib/libTKG2d.so /opt/OpenCascade6.3-32bit/lib/libTKMath.so /opt/OpenCascade6.3-32bit/lib/libTKernel.so -lpthread -ldl -lm -Wl,--rpath -Wl,/opt/OpenCascade6.3-32bit/lib -Wl,--rpath -Wl,/opt/OpenCascade6.3-32bit/lib c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_OCC -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/init -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_OCC -Wall -pipe -pedantic -g -m32 -MT test_occ.o -MD -MP -MF .deps/test_occ.Tpo -c -o test_occ.o ../../trunk/test/test_occ.cpp mv -f .deps/test_occ.Tpo .deps/test_occ.Po /bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -m32 -L/opt/OpenCascade6.3-32bit/lib -o test_occ test_occ.o ../libcgm.la -lm c++ -Wall -pipe -pedantic -g -m32 -o test_occ test_occ.o -L/opt/OpenCascade6.3-32bit/lib ../.libs/libcgm.a /opt/OpenCascade6.3-32bit/lib/libTKFeat.so /opt/OpenCascade6.3-32bit/lib/libTKHLR.so /opt/OpenCascade6.3-32bit/lib/libTKIGES.so /opt/OpenCascade6.3-32bit/lib/libTKOffset.so /opt/OpenCascade6.3-32bit/lib/libTKFillet.so /opt/OpenCascade6.3-32bit/lib/libTKBool.so /opt/OpenCascade6.3-32bit/lib/libTKBO.so /opt/OpenCascade6.3-32bit/lib/libTKPrim.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPAttr.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP209.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPBase.so /opt/OpenCascade6.3-32bit/lib/libTKSTL.so /opt/OpenCascade6.3-32bit/lib/libTKMesh.so /opt/OpenCascade6.3-32bit/lib/libTKXSBase.so /opt/OpenCascade6.3-32bit/lib/libTKShHealing.so /opt/OpenCascade6.3-32bit/lib/libTKLCAF.so /opt/OpenCascade6.3-32bit/lib/libTKCDF.so /opt/OpenCascade6.3-32bit/lib/libTKTopAlgo.so /opt/OpenCascade6.3-32bit/lib/libTKGeomAlgo.! so /opt/OpenCascade6.3-32bit/lib/libTKBRep.so /opt/OpenCascade6.3-32bit/lib/libTKGeomBase.so /opt/OpenCascade6.3-32bit/lib/libTKG3d.so /opt/OpenCascade6.3-32bit/lib/libTKG2d.so /opt/OpenCascade6.3-32bit/lib/libTKMath.so /opt/OpenCascade6.3-32bit/lib/libTKernel.so -lpthread -ldl -lm -Wl,--rpath -Wl,/opt/OpenCascade6.3-32bit/lib -Wl,--rpath -Wl,/opt/OpenCascade6.3-32bit/lib make[2]: Leaving directory `/home/jason/cgm/test/32-occ/test' make check-TESTS make[2]: Entering directory `/home/jason/cgm/test/32-occ/test' PASS: sheet Modified volume Created volume(s): 9 Destroyed volume(s): 2 to 7 Exported: 1 OCC Body to stitch.occ ======================================= Constructed 1 Volume: 10 ======================================= Updated volume(s): 19 Destroyed volume(s): 20 Created volume(s): 22, 23 Destroyed volume(s): 19, 21 Total 0 cuts performed, with from_shape having 6 faces. Total 1 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 1 cuts performed, with from_shape having 7 faces. Total 1 cuts performed, with from_shape having 8 faces. Updated volume(s): 26 Total 0 cuts performed, with from_shape having 6 faces. Total 1 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Updated volume(s): 27 Updated volume(s): 27 Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 1 cuts performed, with from_shape having 7 faces. Total 1 cuts performed, with from_shape having 8 faces. Updated volume(s): 27 Total 2 cuts performed, with from_shape having 8 faces. Updated volume(s): 24 Destroyed volume(s): 25 Modified volume Total 1 cuts performed, with from_shape having 7 faces. Total 0 cuts performed, with from_shape having 2 faces. Updated volume(s): 32 Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. WARNING: Cant make a scar on existing face without splitting it. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. WARNING: Cant make a scar on existing face without splitting it. Total 0 cuts performed, with from_shape having 6 faces. Updated volume(s): 33 Created volume(s): 34 WARNING: Surfaces or Shells can't be used to cut a body. ERROR: Subtract FAILED Total 4 cuts performed, with from_shape having 10 faces. Total 3 cuts performed, with from_shape having 9 faces. Updated volume(s): 35, 36 No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. No projection on the surface. Total 1 cuts performed, with from_shape having 6 faces. Total 1 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 0 cuts performed, with from_shape having 6 faces. Total 1 cuts performed, with from_shape having 7 faces. Total 1 cuts performed, with from_shape having 8 faces. Total 0 cuts performed, with from_shape having 8 faces. Total 0 cuts performed, with from_shape having 8 faces. Total 0 cuts performed, with from_shape having 8 faces. Total 0 cuts performed, with from_shape having 8 faces. Total 0 cuts performed, with from_shape having 8 faces. Total 0 cuts performed, with from_shape having 8 faces. Removing projected curves Created volume(s): 39 Updated volume(s): 41 Destroyed volume(s): 40 Updated volume(s): 41 Destroyed volume(s): 42 The 1 body did not have common part with the tool_body. The 1 body did not have common part with the tool_body. Destroyed volume(s): 41, 43 Created volume(s): 46 Destroyed volume(s): 44 Updated volume(s): 45 Created volume(s): 49 Destroyed volume(s): 48 Updated volume(s): 47 Updated volume(s): 51 Destroyed volume(s): 50 Updated volume(s): 53 Destroyed volume(s): 52 Updated volume(s): 54 Destroyed volume(s): 55 Updated volume(s): 54 Modified volume Created swept volume 60 Modified volume Created swept volume 61 Created swept volume 62 Modified volume Created swept volume 63 ERROR: Only surfaces with no intersection point with the axis can be revolve-swept. Created swept volume 64 ERROR: Only curves with no intersection point with the axis can be revolve-swept. Created swept volume 65 Created swept volume 66 ERROR: Only curves with no intersection point with the axis can be revolve-swept. Created swept volume 67 Created swept volume 68 ERROR: Sweep along curve itself is not allowed. Created swept volume 69 Created swept volume 70 Modified volume Created swept volume 71 Created swept volume 72 ERROR: Errors found during Mergechk session. FAIL: modify ======================================= Constructed 1 Volume: 2 ======================================= ======================================= Constructed 1 Volume: 3 ======================================= ======================================= Constructed 2 Volumes: 4, 5 ======================================= Created volume(s): 6 to 10 Exported: 6 OCC Bodies to point.occ 3 OCC Points to point.occ Exported: 2 OCC Bodies to point.occ 3 OCC Points to point.occ PASS: makept ======================================= Total number of loaded entities : 109. Constructed 18 Free Curves: 1 to 18 ======================================= Exported: 18 OCC Curves to ex3.occ Exported: 18 OCC Curves to ex3export.iges ******************************************************************* ****** Statistics on Transfer (Write) ****** ******************************************************************* ****** Transfer Mode = 0 I.E. As Is ****** ****** Transferring Shape, ShapeType = 0 ****** ** WorkSession : Sending all data Step File Name : ex3export.step(578 ents) Write Done Exported: 18 OCC Curves to ex3export.step ======================================= Total number of loaded entities : 58. Constructed 7 Volumes: 1 to 7 ======================================= Exported: 7 OCC Bodies to diffuser.occ ======================================= ... Step File Reading : ../../trunk/test/proe.stp ... STEP File Read ... Elapsed time: 0 Hours 0 Minutes 0.001684 Seconds CPU user time: 0 seconds CPU system time: 0 seconds ... Step File loaded ... Elapsed time: 0 Hours 0 Minutes 0.003066 Seconds CPU user time: 0.01 seconds CPU system time: 0 seconds 1393 records (entities,sub-lists,scopes), 3595 parameters ... Parameters prepared ... Elapsed time: 0 Hours 0 Minutes 0.004771 Seconds CPU user time: 0.01 seconds CPU system time: 0 seconds ... Objets analysed ... Elapsed time: 0 Hours 0 Minutes 0.007764 Seconds CPU user time: 0.01 seconds CPU system time: 0 seconds STEP Loading done : 815 Entities Constructed 12 Volumes: 8 to 19 ======================================= Exported: 12 OCC Bodies to proe.occ Exported: 12 OCC Bodies to proeexport.iges ******************************************************************* ****** Statistics on Transfer (Write) ****** ******************************************************************* ****** Transfer Mode = 0 I.E. As Is ****** ****** Transferring Shape, ShapeType = 0 ****** ** WorkSession : Sending all data Step File Name : proeexport.step(1348 ents) Write Done Exported: 12 OCC Bodies to proeexport.step ======================================= Constructed 2 Volumes: 20, 21 ======================================= Exported: 2 OCC Bodies to beforesub.occ ======================================= Constructed 2 Volumes: 22, 23 ======================================= Exported: 2 OCC Bodies to beforesub2.occ Created volume(s): 24, 25 Destroyed volume(s): 22, 23 Exported: 2 OCC Bodies to aftersub.occ ======================================= Constructed 2 Volumes: 26, 27 ======================================= Updated volume(s): 26 Destroyed volume(s): 27 Exported: 1 OCC Body to unite2.occ ======================================= Constructed 2 Volumes: 28, 29 ======================================= Updated volume(s): 29 Destroyed volume(s): 28 Exported: 1 OCC Body to unite3.occ ======================================= Constructed 2 Volumes: 30, 31 ======================================= Updated volume(s): 30 Destroyed volume(s): 31 Exported: 1 OCC Body to unite5.occ ======================================= Constructed 2 Volumes: 32, 33 ======================================= Updated volume(s): 33 Destroyed volume(s): 32 Exported: 1 OCC Body to unite6.occ PASS: r_w Constructed 1 Volume: 1 done... PASS: test_occ =================== 1 of 5 tests failed =================== make[2]: *** [check-TESTS] Error 1 make[2]: Leaving directory `/home/jason/cgm/test/32-occ/test' make[1]: *** [check-am] Error 2 make[1]: Leaving directory `/home/jason/cgm/test/32-occ/test' make: *** [check-recursive] Error 1
participants (1)
Nightly Test
