Re: [cgma-dev] Observer question?
On 07/22/2013 02:51 PM, David Thompson wrote:
... The notify_observer() method called on observers doesn't appear to provide information about the entity(-ies) replacing those being modified. Is there a way to obtain the resulting split or merged entities? If I create an attribute to hold an ID on faces or edges of interest, how fast will lookup be?
If it's anything like ACIS, you generally don't know the correspondence between an entity that gets deleted and the ones used to replace it. IIRC you don't get many notifications of split or merge type, only of delete type (and implicitly create type, which show up as not having associated CGM entities yet).
Hmm. If different engines behave differently, then I guess we shouldn't rely on it for tracking persistent geometry across operations. Would you advise adding UUIDs as attributes for that kind of tracking?
No; you'd get exactly the same results. We hang an attribute on the engine entities pointing to the CGM entities, then after the operation, see what's left, and remove the CGM entities that are no longer referenced. So in a sense, we only get "before" and "after" pictures, not "during" pictures. - tim
Thanks, David
-- ================================================================ "You will keep in perfect peace him whose mind is steadfast, because he trusts in you." Isaiah 26:3 Tim Tautges Argonne National Laboratory ([email protected]) (telecommuting from UW-Madison) phone (gvoice): (608) 354-1459 1500 Engineering Dr. fax: (608) 263-4499 Madison, WI 53706
participants (1)
Tim Tautges
