Author: janehu Date: 2008-03-07 13:56:28 -0600 (Fri, 07 Mar 2008) New Revision: 1639 Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp Log: added stitch_surfs function. Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-03-07 19:12:39 UTC (rev 1638) +++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-03-07 19:56:28 UTC (rev 1639) @@ -1207,8 +1207,8 @@ // Function : pyramid // Member Type: PUBLIC // Description: create an OCC pyramid -// Author : John Fowler -// Date : 10/02 +// Author : Jane Hu +// Date : 03/08 //=============================================================================== BodySM* OCCModifyEngine::pyramid( double height, int sides, double major, double minor, double top) const @@ -1412,12 +1412,112 @@ return CAST_TO(lump, OCCLump)->body(); } +//=============================================================================== +// Function : stitch_surfs +// Member Type: PUBLIC +// Description: Unite surfs into one surface sheet body +// Author : Jane Hu +// Date : 03/08 +//=============================================================================== CubitStatus OCCModifyEngine::stitch_surfs( DLIList<BodySM*>& surf_bodies, BodySM*& stitched_body) const { - PRINT_ERROR("Option not supported for mesh based geometry.\n"); - return CUBIT_SUCCESS; + stitched_body = NULL; + if (surf_bodies.size()==0) + return CUBIT_SUCCESS; + + if (surf_bodies.size()==1) + { + stitched_body = surf_bodies.get(); + return CUBIT_SUCCESS; + } + + DLIList<TopoDS_Face*> faces_to_stitch; + for (int i = 0; i < surf_bodies.size(); i++) + { + BodySM * tool_body = surf_bodies.get(); + OCCBody* occ_body = CAST_TO(tool_body, OCCBody); + OCCSurface* surface = occ_body->my_sheet_surface(); + if (surface == NULL) + { + PRINT_ERROR("Can't stitch non-sheet bodySM's. \n"); + return CUBIT_FAILURE; + } + TopoDS_Face* topods_face = surface->get_TopoDS_Face(); + if (topods_face != NULL) + faces_to_stitch.append(topods_face); + } + + TopoDS_Face* first_face = faces_to_stitch.get(); + TopoDS_Face* second_face = NULL; + TopoDS_Face* new_face = NULL ; + CubitBoolean disconnected = CUBIT_FALSE; + DLIList<TopoDS_Face*>disconnected_faces; + TopoDS_Shape fusion; + int count = 0; + for(int i = 0; i < faces_to_stitch.size(); i++) + { + if (count > 0 && disconnected) + { + first_face = faces_to_stitch[i]; + disconnected = CUBIT_FALSE; + } + else if (count > 0 && disconnected == CUBIT_FALSE) + { + first_face = new_face; + } + for(int j = i + 1; j < faces_to_stitch.size(); j++) + { + second_face = faces_to_stitch[j]; + BRepAlgoAPI_Fuse fuse(*first_face, *second_face); + if (fuse.ErrorStatus() != 0 && fuse.ErrorStatus() != 1) + { + PRINT_ERROR("Can't operate fusion for given surfaces. \n"); + return CUBIT_FAILURE; + } + else if (fuse.ErrorStatus() == 1) + { + //The Object is created but Nothing is Done + disconnected = CUBIT_TRUE; + continue; + } + + //fused into one face + fusion = fuse.Shape1(); + if (count > 0) + delete new_face; + new_face = new TopoDS_Face(TopoDS::Face(fusion)); + faces_to_stitch.remove(second_face); + i--; + count++; + break; + } + if (disconnected) + { + //save the first_face for building the body + disconnected_faces.append(first_face); + } + } + if (disconnected) //last one + disconnected_faces.append(second_face); + + if(disconnected_faces.size() == 0) + { + Surface* surface = OCCQueryEngine::instance()-> + populate_topology_bridge(*new_face, CUBIT_TRUE); + + stitched_body = CAST_TO(surface, OCCSurface)->my_body(); + //delete all original surfaces + OCCQueryEngine::instance()->delete_solid_model_entities(surf_bodies); + return CUBIT_SUCCESS; + } + + //Can't make a body out of disconnected faces + PRINT_ERROR("Can't create one BodySM out of disconnected surfaces. \n"); + if(new_face != NULL) + delete new_face; + return CUBIT_FAILURE; } //===============================================================================
participants (1)
janehu@mcs.anl.gov
