I made this test. Sorry. Let me fix it. Hongjun ----- Original Message ----- From: "Jason Kraftcheck" <[email protected]> To: "CGMA Development" <[email protected]> Sent: Tuesday, November 3, 2009 11:03:26 AM GMT -06:00 US/Canada Central Subject: [cgma-dev] broken partest "make check" currently fails for CGM builds with parallel support because 'partest' isn't a proper test. It fails with: Hello Usage: ./partest [<filename>] [<send_methond>] FAIL: partest Either this test needs to be changed such that it can be run w/out manually specifying input files (wrapper script, defaults, etc.) or the Makefile.am should be changed such that partest is included in check_PROGRAMS but *not* TESTS, so that it is not run during 'make check'. - jason
participants (1)
Hongjun Kim
