Ok, I didn't update the testcase, now it did fail, and your change looks proper. please go ahead to add it . Thanks. Jane On Thu, Jun 9, 2011 at 10:52 AM, Hong-Jun Kim <[email protected]> wrote:
By the way, I am curious why you don't fail the test. Inside "faceting_test", when "size.sat" is imported to OCC geometry kernel, it looks it must fail. Am I wrong?
Hong-Jun
----- Original Message ----- From: "Hong-Jun Kim" <[email protected]> To: "Jane Hu" <[email protected]> Cc: [email protected] Sent: Thursday, June 9, 2011 10:45:47 AM Subject: Re: [cgma-dev] CGM/itaps/testgeom_occ
Thanks for your reply.
The test fails in "faceting_test". I think "faceting_test" also has to be inside "#if defined(HAVE_ACIS) && !defined(FORCE_OCC)" block as you mentioned, because it is loading "size.sat" by itself again. If it is ok for you all, I will change it.
Hong-Jun
From: "Jane Hu" <[email protected]> To: "Hong-Jun Kim" <[email protected]> Cc: [email protected] Sent: Thursday, June 9, 2011 9:47:12 AM Subject: Re: [cgma-dev] CGM/itaps/testgeom_occ Hi, Hong-Jun:
testgeom is using LeverArm.brep for OCC part of testing, and it passed in my machine for make check. Only with HAVE_ACIS and without FORCE_OCC defined will mesh_size_test test be performed. So it is Acis specific.
Jane
On Wed, Jun 8, 2011 at 1:25 PM, Hong-Jun Kim < [email protected] > wrote:
Hi
Currently, "CGM/itaps/testgeom_occ" fails for OCC geometry because its' input file is "size.sat" for "faceting_test". To fix this, can I ask if the test is specific to the input file, "size.sat"?
Hong-Jun
participants (1)
Jane Hu
