Hi Jane/Iulian, 'make dist' in CGM doesn't work, something about not knowing how to make target mergechk_merge in cgm_apps/examples/driverc++. This needs to work, and should be the way the buildbot builds distribution tarballs. The tarfile for CGM 12.2 on the ftp site is missing CubitFileSimModel.[c,h]pp, which I'm guessing is caused by this problem (and not using make dist to build that tarball). Comments? - tim -- ================================================================ "You will keep in perfect peace him whose mind is steadfast, because he trusts in you." Isaiah 26:3 Tim Tautges Argonne National Laboratory ([email protected]) (telecommuting from UW-Madison) phone (gvoice): (608) 354-1459 1500 Engineering Dr. fax: (608) 263-4499 Madison, WI 53706
participants (1)
Tim Tautges
