r5754 - cgm/branches/merge-cubit13.1/geom/OCC/patches653
Author: csverma Date: 2012-09-26 10:25:19 -0500 (Wed, 26 Sep 2012) New Revision: 5754 Added: cgm/branches/merge-cubit13.1/geom/OCC/patches653/OpenGl_FontMgr.cxx_patch cgm/branches/merge-cubit13.1/geom/OCC/patches653/README Log: Passed CGM make check with new FTGL Added: cgm/branches/merge-cubit13.1/geom/OCC/patches653/OpenGl_FontMgr.cxx_patch =================================================================== --- cgm/branches/merge-cubit13.1/geom/OCC/patches653/OpenGl_FontMgr.cxx_patch (rev 0) +++ cgm/branches/merge-cubit13.1/geom/OCC/patches653/OpenGl_FontMgr.cxx_patch 2012-09-26 15:25:19 UTC (rev 5754) @@ -0,0 +1,15 @@ +--- OpenGl_FontMgr.cxx 2012-04-13 07:39:02.000000000 -0500 ++++ ../../../rosnew/src/OpenGl/OpenGl_FontMgr.cxx 2012-09-25 13:57:29.461257744 -0500 +@@ -17,9 +17,9 @@ + + #include <OpenGl_FontMgr.hxx> + +-#include <FTGLTextureFont.h> +-#include <FTLibrary.h> +-#include <FTFace.h> ++#include <FTGL/FTGLTextureFont.h> ++#include <FTGL/FTLibrary.h> ++#include <FTGL/FTFace.h> + #include <Standard_Stream.hxx> + + #undef TRACE Added: cgm/branches/merge-cubit13.1/geom/OCC/patches653/README =================================================================== --- cgm/branches/merge-cubit13.1/geom/OCC/patches653/README (rev 0) +++ cgm/branches/merge-cubit13.1/geom/OCC/patches653/README 2012-09-26 15:25:19 UTC (rev 5754) @@ -0,0 +1,15 @@ +When you install ftgl library on Ubuntu12.04, some of the header +files are not correctly copied to the standard location. The new +FTGL expects them to be /usr/include/FTGL directory. + +Go to the source code of the new ftgl and copy all the *.h files +to the /usr/include/FTGL directory. + +Also in the source code of OCC, you need to change the header files +to FTGL/FTFont.h instead of FTFont.h and this is being done in the +given patch file. + +All the test cases of CGM passed through these changes, so assuming +that everything was fine, but no rigrous testing was carried out for +these changes. +
participants (1)
csverma@mcs.anl.gov
