Re: [cgma-dev] testgeom failure with Cubit-12.2
The failure of getting intervals is due to attribute changes, so for that one the test needs to be changed. For the other one, I'm not sure what the problem is. Jane/Jason, have you seen this failure? - tim On 04/13/2011 01:39 PM, Rajeev Jain wrote:
make check fails at testgeom when I use CGM merge-12 branch and cubit-12.2, my config line is: ./configure --enable-shared --prefix=/home/rajeev/lib/cgm12 --with-cubit=/home/rajeev/Cubit-12.2 --enable-debug
There are two failures (see below, test results from running testgeom): 1. Topology adjacency 2. Save EntSet
Let me know if you need more info. ------------------------------------------------------------------------------------------------------- rajeev@jain:~/cgm12/itaps$ gdb .libs/testgeom GNU gdb (GDB) 7.1-ubuntu Copyright (C) 2010 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "i486-linux-gnu". For bug reporting instructions, please see: <http://www.gnu.org/software/gdb/bugs/>... Reading symbols from /home/rajeev/cgm12/itaps/.libs/testgeom...done. (gdb) r Starting program: /home/rajeev/cgm12/itaps/.libs/testgeom [Thread debugging using libthread_db enabled] Using default input file: ./testgeom.sat
ITAPS GEOMETRY INTERFACE TEST PROGRAM:
gLoad: Read 1 ACIS Entities from the input file
Constructed 1 Volume: 1 Model contents: vertices: 36 edges: 60 faces: 33 regions: 1 Success tags: Tags defined on model: GLOBAL_ID, NAME Success gentity sets: ERROR: Problem to add entity set. Error code: 23 Error desc: Problem adding entity to another set. At : testgeom.cc:825 Failure topology adjacencies: Success construct: Created swept volume 3 Success primitives: Success transforms: Success booleans: Updated volume(s): 10 Destroyed volume(s): 11 Updated volume(s): 12 Updated volume(s): 12 Destroyed volume(s): 13 Success mesh size: Read 1 ACIS Entities from the input file
ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized. ERROR: Attribute type -1 not recognized.
Constructed 1 Volume: 1 ERROR: Failed to get intervals for curves Error code: 15 Error desc: Tag does not exist At : testgeom.cc:1309 Failure save entset: Exported: 2 Volumes
Read 2 ACIS Entities from the input file
WARNING: Entity name 'Group 1' can't be used in commands. Additional name 'Group_1' assigned. Constructed 2 Volumes: 2, 3 Success shutdown: Success
TSTT TEST SUMMARY: Number Tests: 11 Number Successful: 9 Number Not Implemented: 0 Number Failed: 2
Program exited with code 02.
Rajeev
-- ================================================================ "You will keep in perfect peace him whose mind is steadfast, because he trusts in you." Isaiah 26:3 Tim Tautges Argonne National Laboratory ([email protected]) (telecommuting from UW-Madison) phone: (608) 263-8485 1500 Engineering Dr. fax: (608) 263-4499 Madison, WI 53706
participants (1)
Tim Tautges
