Author: hongjun Date: 2009-08-18 16:47:39 -0500 (Tue, 18 Aug 2009) New Revision: 3106 Modified: cgm/trunk/itaps/testgeom.cc Log: OCC default test file is changed from "LeverArm.brep" to "Hip_Prothesis.brep", because the old one is not working. -This line, and those below, will be ignored-- M testgeom.cc Modified: cgm/trunk/itaps/testgeom.cc =================================================================== --- cgm/trunk/itaps/testgeom.cc 2009-08-11 20:37:22 UTC (rev 3105) +++ cgm/trunk/itaps/testgeom.cc 2009-08-18 21:47:39 UTC (rev 3106) @@ -134,13 +134,13 @@ #ifndef HAVE_OCC #error "Cannot force use of OCC w/out OCC support" #endif - std::string filename = STRINGIFY(SRCDIR) "/../test/LeverArm.brep"; + std::string filename = STRINGIFY(SRCDIR) "/../test/Hip_Prothesis.brep"; std::string engine_opt = ";engine=OCC"; #elif defined(HAVE_ACIS) std::string filename = STRINGIFY(SRCDIR) "/testgeom.sat"; std::string engine_opt = ";engine=ACIS"; #elif defined(USE_OCC) - std::string filename = STRINGIFY(SRCDIR) "/../test/LeverArm.brep"; + std::string filename = STRINGIFY(SRCDIR) "/../test/Hip_Prothesis.brep"; std::string engine_opt = ";engine=OCC"; #else std::string filename = STRINGIFY(SRCDIR) "/testgeom.sat";
participants (1)
hongjun@mcs.anl.gov
