r1253 - in cgm/trunk: cgm_apps/examples/driverc++ geom geom/ACIS_SRC geom/facet
Author: kraftche Date: 2007-08-24 15:43:22 -0500 (Fri, 24 Aug 2007) New Revision: 1253 Modified: cgm/trunk/cgm_apps/examples/driverc++/Makefile cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.cpp cgm/trunk/geom/GeometryModifyEngine.cpp cgm/trunk/geom/GeometryModifyEngine.hpp cgm/trunk/geom/GeometryModifyTool.cpp cgm/trunk/geom/facet/FacetModifyEngine.cpp cgm/trunk/geom/facet/FacetModifyEngine.hpp Log: o Add additional sweep termiantion options to GeometryModifyEngine::sweep* o Reduce abstract webcut methods provided by engines to a single webcut with tool-body function. o Move old webcut_* methods to common implementation for all engines in GeometryModifyEngine o Add tests for webcut functions Modified: cgm/trunk/cgm_apps/examples/driverc++/Makefile =================================================================== --- cgm/trunk/cgm_apps/examples/driverc++/Makefile 2007-08-24 20:05:52 UTC (rev 1252) +++ cgm/trunk/cgm_apps/examples/driverc++/Makefile 2007-08-24 20:43:22 UTC (rev 1253) @@ -1,10 +1,10 @@ CGM_DIR = ../../.. include ${CGM_DIR}/lib/cgm.make -all: mergechk +all: webcut -mergechk: mergechk.o ${CGM_LIBS_FILES} - $(CGM_CXX) -o mergechk $(LDFLAGS) mergechk.o $(CGM_LIBS_LINK) +webcut: webcut.o ${CGM_LIBS_FILES} + $(CGM_CXX) -o webcut $(LDFLAGS) webcut.o $(CGM_LIBS_LINK) .cpp.o: $(CGM_CXX) ${CGM_CXXFLAGS} ${CGM_INCLUDES} -c -o $@ $< Modified: cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp =================================================================== --- cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp 2007-08-24 20:05:52 UTC (rev 1252) +++ cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp 2007-08-24 20:43:22 UTC (rev 1253) @@ -1,5 +1,4 @@ -//------------------------------------------------------------------------- -// Filename : AcisModifyEngine.cpp + // // Purpose : Performs all acis-based geometry modification or creation // @@ -234,13 +233,13 @@ #ifdef ACIS_IGES_TRANSLATOR #if CUBIT_ACIS_VERSION < 1100 - #include "igeshusk/igs_api/routines.hxx" +#include "igeshusk/igs_api/routines.hxx" #else #include "acisiges_api.hxx" #endif #endif #ifdef ACIS_PROE_TRANSLATOR - #include "proe/proehusk/api/proeapi.hxx" +#include "proe/proehusk/api/proeapi.hxx" #endif #ifdef ACIS_LOCAL_OPS @@ -253,13 +252,13 @@ #ifdef ACIS_STEP_TRANSLATOR #if CUBIT_ACIS_VERSION < 1100 - #include "stephusk/include/acis_inc.hxx" - #include "stephusk/include/stpapi.hxx" - #include "stephusk/util/apiinit.hxx" - #include "stephusk/stepwrit/api/apiwrite.hxx" - #include "stephusk/stepread/api/apiread.hxx" - #include "stephusk/util/stphead.hxx" - #include "stephusk/util/stp_res.hxx" +#include "stephusk/include/acis_inc.hxx" +#include "stephusk/include/stpapi.hxx" +#include "stephusk/util/apiinit.hxx" +#include "stephusk/stepwrit/api/apiwrite.hxx" +#include "stephusk/stepread/api/apiread.hxx" +#include "stephusk/util/stphead.hxx" +#include "stephusk/util/stp_res.hxx" #else #include "acisstep_api.hxx" #endif @@ -335,51 +334,51 @@ AcisModifyEngine::~AcisModifyEngine() { - api_terminate_booleans(); - api_terminate_covering(); - api_terminate_sweeping(); - api_terminate_skinning(); - api_terminate_offsetting(); - api_terminate_shelling (); + api_terminate_booleans(); + api_terminate_covering(); + api_terminate_sweeping(); + api_terminate_skinning(); + api_terminate_offsetting(); + api_terminate_shelling (); #ifdef ACIS_LOCAL_OPS - api_terminate_face_removal(); + api_terminate_face_removal(); #endif - instance_ = 0; + instance_ = 0; } AcisModifyEngine::AcisModifyEngine() { assert( !instance_ ); - // add this modify engine to geometrymodifytool + // add this modify engine to geometrymodifytool GeometryModifyTool::instance()->add_gme(this); - API_BEGIN; - //initialize the correct modules - api_initialize_booleans(); - api_initialize_covering(); - api_initialize_sweeping(); - api_initialize_skinning(); - api_initialize_offsetting(); - api_initialize_shelling (); + API_BEGIN; + //initialize the correct modules + api_initialize_booleans(); + api_initialize_covering(); + api_initialize_sweeping(); + api_initialize_skinning(); + api_initialize_offsetting(); + api_initialize_shelling (); #ifdef ACIS_LOCAL_OPS - api_initialize_face_removal(); + api_initialize_face_removal(); #endif - API_END; + API_END; } CubitString AcisModifyEngine::identify() { - CubitString number_string = get_major_version(); - number_string += "."; - number_string += CubitString(get_minor_version()); - number_string += "."; - number_string += CubitString(get_point_version()); - CubitString version_string = "ACIS Version "; - version_string += number_string; - return version_string; + CubitString number_string = get_major_version(); + number_string += "."; + number_string += CubitString(get_minor_version()); + number_string += "."; + number_string += CubitString(get_point_version()); + CubitString version_string = "ACIS Version "; + version_string += number_string; + return version_string; } //------------------------------------------------------------------------- @@ -394,7 +393,7 @@ const type_info& AcisModifyEngine::entity_type_info() const { - return typeid(AcisModifyEngine); + return typeid(AcisModifyEngine); } //------------------------------------------------------------------------- @@ -409,20 +408,20 @@ BodySM* AcisModifyEngine::sphere(double radius) const { - BODY* BODYPtr = NULL; + BODY* BODYPtr = NULL; - // Create a BODY that represents the cuboid - outcome result = api_make_sphere ( radius, BODYPtr ); - if (!result.ok()) - { + // Create a BODY that represents the cuboid + outcome result = api_make_sphere ( radius, BODYPtr ); + if (!result.ok()) + { PRINT_ERROR("In AcisModifyEngine::sphere, Line# %d\n" " Problems creating a sphere\n", __LINE__ ); return NULL ; - } + } - // Build a Body from the BODY and return it. - BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr); - return this_bodysm; + // Build a Body from the BODY and return it. + BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr); + return this_bodysm; } //------------------------------------------------------------------------- @@ -437,31 +436,31 @@ BodySM* AcisModifyEngine::brick(double width, double depth, double height) const { - BODY* BODYPtr = NULL; + BODY* BODYPtr = NULL; - // Create a BODY that represents the cuboid - outcome result = api_make_cuboid ( width, depth, height, BODYPtr ); - if (!result.ok()) - { + // Create a BODY that represents the cuboid + outcome result = api_make_cuboid ( width, depth, height, BODYPtr ); + if (!result.ok()) + { PRINT_ERROR("In AcisModifyEngine::brick, Line# %d\n" " Problems creating a brick\n", __LINE__); return NULL ; - } + } - BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr); - return this_bodysm; + BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr); + return this_bodysm; } BodySM* AcisModifyEngine::brick( const CubitVector ¢er, const CubitVector axes[3], const CubitVector &extension ) const { - BODY* BODY_ptr; + BODY* BODY_ptr; - BODY_ptr = make_brick_BODY( center, axes, extension ); + BODY_ptr = make_brick_BODY( center, axes, extension ); - BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges( BODY_ptr ); - return this_bodysm; + BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges( BODY_ptr ); + return this_bodysm; } //------------------------------------------------------------------------- @@ -477,20 +476,20 @@ BodySM* AcisModifyEngine::prism( double height, int sides, double major, double minor) const { - BODY* BODYPtr = NULL; + BODY* BODYPtr = NULL; - // Create a BODY that represents the prism - outcome result = api_make_prism ( height, major, minor, sides, BODYPtr ); - if (!result.ok()) - { + // Create a BODY that represents the prism + outcome result = api_make_prism ( height, major, minor, sides, BODYPtr ); + if (!result.ok()) + { PRINT_ERROR("In AcisModifyEngine::prism, Line# %d\n" " Problems creating a prism\n", __LINE__); return NULL ; - } + } - // Build a Body from the BODY and return it. - BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr); - return this_bodysm; + // Build a Body from the BODY and return it. + BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr); + return this_bodysm; } //------------------------------------------------------------------------- @@ -506,19 +505,19 @@ BodySM* AcisModifyEngine::pyramid( double height, int sides, double major, double minor, double top ) const { - BODY* BODYPtr = NULL; - // Create a BODY that represents the pyramid - outcome result = api_make_pyramid ( height, major, minor, top, - sides, BODYPtr ); - if (!result.ok()) - { + BODY* BODYPtr = NULL; + // Create a BODY that represents the pyramid + outcome result = api_make_pyramid ( height, major, minor, top, + sides, BODYPtr ); + if (!result.ok()) + { PRINT_ERROR("In AcisModifyEngine::pyramid, Line# %d\n" " Problems creating a pyramid\n", __LINE__); return NULL ; - } - // Build a Body from the BODY and return it. - BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr); - return this_bodysm; + } + // Build a Body from the BODY and return it. + BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr); + return this_bodysm; } //------------------------------------------------------------------------- @@ -534,21 +533,23 @@ BodySM* AcisModifyEngine::cylinder( double hi, double r1, double r2, double r3 ) const { - BODY* BODYPtr = NULL; - // Create a BODY that represents the cylinder - outcome result = api_make_frustum ( hi, r1, r2, r3, BODYPtr ); - if (!result.ok()) - { + BODY* BODYPtr = NULL; + // Create a BODY that represents the cylinder + outcome result = api_make_frustum ( hi, r1, r2, r3, BODYPtr ); + if (!result.ok()) + { PRINT_ERROR("In AcisModifyEngine::cylinder, Line# %d\n" " Problems creating a cylinder\n", __LINE__); return NULL ; - } + } - // Build a Body from the BODY and return it. - BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr); - return this_bodysm; + // Build a Body from the BODY and return it. + + BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr); + return this_bodysm; } + //------------------------------------------------------------------------- // Purpose : Create a torus and return a pointer to the Body. // @@ -561,18 +562,18 @@ BodySM* AcisModifyEngine::torus( double r1, double r2 ) const { - BODY* BODYPtr = NULL; - // Create a BODY that represents the torus - outcome result = api_make_torus ( r1, r2, BODYPtr ); - if (!result.ok()) - { + BODY* BODYPtr = NULL; + // Create a BODY that represents the torus + outcome result = api_make_torus ( r1, r2, BODYPtr ); + if (!result.ok()) + { PRINT_ERROR("In AcisModifyEngine::torus, Line# %d\n" " Problems creating a torus\n", __LINE__); return NULL ; - } - // Build a Body from the BODY and return it. - BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr); - return this_bodysm; + } + // Build a Body from the BODY and return it. + BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr); + return this_bodysm; } //------------------------------------------------------------------------- @@ -589,13 +590,13 @@ const CubitVector& p3, const CubitVector& p4 ) const { - BODY* new_BODY = make_planar_quad_BODY( p1, p2, p3, p4 ); + BODY* new_BODY = make_planar_quad_BODY( p1, p2, p3, p4 ); - // Build a VGI Body (i.e, the entire VGI structure) from this - // ACIS BODY. - BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(new_BODY); + // Build a VGI Body (i.e, the entire VGI structure) from this + // ACIS BODY. + BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(new_BODY); - return this_bodysm; + return this_bodysm; } //------------------------------------------------------------------------- @@ -611,138 +612,138 @@ BodySM* AcisModifyEngine::copy_body ( BodySM* OSMEPtr) const { - // Make sure that we have a valid pointer - assert(OSMEPtr != NULL) ; + // Make sure that we have a valid pointer + assert(OSMEPtr != NULL) ; - BodyACIS* bodyACISPtr = CAST_TO(OSMEPtr, BodyACIS) ; + BodyACIS* bodyACISPtr = CAST_TO(OSMEPtr, BodyACIS) ; - // Make sure that we have a valid BodyACIS - assert(bodyACISPtr != NULL) ; + // Make sure that we have a valid BodyACIS + assert(bodyACISPtr != NULL) ; - // Get the ACIS BODY - BODY* BODY_ptr = bodyACISPtr->get_BODY_ptr() ; + // Get the ACIS BODY + BODY* BODY_ptr = bodyACISPtr->get_BODY_ptr() ; - // Construct a new BODY from what we have - BODY* new_BODY_ptr = this->copy_BODY(BODY_ptr) ; + // Construct a new BODY from what we have + BODY* new_BODY_ptr = this->copy_BODY(BODY_ptr) ; - // Build a VGI Body and return it. - BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(new_BODY_ptr); - return this_bodysm; + // Build a VGI Body and return it. + BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(new_BODY_ptr); + return this_bodysm; } CubitStatus AcisModifyEngine::imprint_BODYs (BODY* body1_ptr, BODY* body2_ptr) const { - CpuTimer imprint_BODYs_timer; + CpuTimer imprint_BODYs_timer; - // Imprints the 2 input ACIS BODYs. If something goes wrong, state is - // restored and CUBIT_FALSE is returned. + // Imprints the 2 input ACIS BODYs. If something goes wrong, state is + // restored and CUBIT_FALSE is returned. - CubitStatus status = CUBIT_FAILURE; + CubitStatus status = CUBIT_FAILURE; - // Use the BEGIN/END pair so that a roll-back is done by ACIS if something - // goes wrong in the api_imprint or api_check_entity operations - if ( GeometryModifyTool::get_all_edges_imprint() ) - { + // Use the BEGIN/END pair so that a roll-back is done by ACIS if something + // goes wrong in the api_imprint or api_check_entity operations + if ( GeometryModifyTool::get_all_edges_imprint() ) + { api_set_int_option("all_free_edges", TRUE ); - } + } - outcome result = api_imprint(body1_ptr, body2_ptr); + outcome result = api_imprint(body1_ptr, body2_ptr); - //Gets rid of sliver curves/surfaces that could get produced by the imprint. - AcisModifyEngine::instance()->cleanup_slivers( body1_ptr ); - AcisModifyEngine::instance()->cleanup_slivers( body2_ptr ); + //Gets rid of sliver curves/surfaces that could get produced by the imprint. + AcisModifyEngine::instance()->cleanup_slivers( body1_ptr ); + AcisModifyEngine::instance()->cleanup_slivers( body2_ptr ); - if ( GeometryModifyTool::get_all_edges_imprint() ) - { + if ( GeometryModifyTool::get_all_edges_imprint() ) + { api_set_int_option("all_free_edges", FALSE ); - } + } - if (DEBUG_FLAG(18)) - { + if (DEBUG_FLAG(18)) + { if (result.ok()) - { - status = CUBIT_SUCCESS; + { + status = CUBIT_SUCCESS; - // Now that the imprint operation has apparently succeeded (:-) - // test the resulting BODYs for correctness. The output of the - // api_check_entity procedure is sent to the file whose pointer - // is debug_file_ptr (an ACIS global file pointer). + // Now that the imprint operation has apparently succeeded (:-) + // test the resulting BODYs for correctness. The output of the + // api_check_entity procedure is sent to the file whose pointer + // is debug_file_ptr (an ACIS global file pointer). - // MJP Note: - // I do this test here because there are bugs in the imprint - // operation that result in invalid BODYs even though the api_imprint - // call may return a successful status. I've been told that the imprint - // operation will be a lot more stable in Version 2 -- and where have - // we heard this kind of stuff before?? :-) + // MJP Note: + // I do this test here because there are bugs in the imprint + // operation that result in invalid BODYs even though the api_imprint + // call may return a successful status. I've been told that the imprint + // operation will be a lot more stable in Version 2 -- and where have + // we heard this kind of stuff before?? :-) - FILE* save_dfp = NULL; + FILE* save_dfp = NULL; - // Save the original value of the ACIS Debug File Pointer - save_dfp = debug_file_ptr; + // Save the original value of the ACIS Debug File Pointer + save_dfp = debug_file_ptr; - // Check the first entity and save the results of the check in the file, - // api_check_entity_output.txt - debug_file_ptr = fopen ("api_check_entity_output.txt", "w"); - result = api_check_entity (body1_ptr, (ENTITY_LIST *)NULL); - if (debug_file_ptr) fclose (debug_file_ptr); + // Check the first entity and save the results of the check in the file, + // api_check_entity_output.txt + debug_file_ptr = fopen ("api_check_entity_output.txt", "w"); + result = api_check_entity (body1_ptr, (ENTITY_LIST *)NULL); + if (debug_file_ptr) fclose (debug_file_ptr); - if (result.ok()) - { + if (result.ok()) + { // Check the second entity and save the results of the check in the // file, api_check_entity_output.txt - debug_file_ptr = fopen("api_check_entity_output.txt", "w"); - result = api_check_entity (body2_ptr, (ENTITY_LIST *)NULL); - if (debug_file_ptr) fclose (debug_file_ptr); + debug_file_ptr = fopen("api_check_entity_output.txt", "w"); + result = api_check_entity (body2_ptr, (ENTITY_LIST *)NULL); + if (debug_file_ptr) fclose (debug_file_ptr); - if (result.ok()) - { - status = CUBIT_SUCCESS; - } + if (result.ok()) + { + status = CUBIT_SUCCESS; + } - else - { - status = CUBIT_FAILURE; - AcisQueryEngine::instance()->ACIS_API_error (result); - } - } - else - { - status = CUBIT_FAILURE; - AcisQueryEngine::instance()->ACIS_API_error (result); - } - // Restore the original value of the ACIS Debug File Pointer - debug_file_ptr = save_dfp; - } + else + { + status = CUBIT_FAILURE; + AcisQueryEngine::instance()->ACIS_API_error (result); + } + } + else + { + status = CUBIT_FAILURE; + AcisQueryEngine::instance()->ACIS_API_error (result); + } + // Restore the original value of the ACIS Debug File Pointer + debug_file_ptr = save_dfp; + } else - { - status = CUBIT_FAILURE; - AcisQueryEngine::instance()->ACIS_API_error (result); - } - } - if (result.ok()) - status = CUBIT_SUCCESS; - else - { - // mieht just be no overlap, check smaller boxes - SPAbox box1 = get_body_box(body1_ptr); - SPAbox box2 = get_body_box(body2_ptr); + { + status = CUBIT_FAILURE; + AcisQueryEngine::instance()->ACIS_API_error (result); + } + } + if (result.ok()) + status = CUBIT_SUCCESS; + else + { + // mieht just be no overlap, check smaller boxes + SPAbox box1 = get_body_box(body1_ptr); + SPAbox box2 = get_body_box(body2_ptr); - if (!body1_ptr || !body2_ptr || (box1 && box2)) - { - if (DEBUG_FLAG(95)) - { - PRINT_DEBUG_95( "Bodies were not " - "imprinted.\n"); - AcisQueryEngine::instance()->ACIS_API_error(result, "imprint Bodies"); - } - status = CUBIT_FAILURE; - } - } - PRINT_DEBUG_3( "CPU time taken to imprint two BODYs: " - "%f secs\n", imprint_BODYs_timer.cpu_secs() ) ; + if (!body1_ptr || !body2_ptr || (box1 && box2)) + { + if (DEBUG_FLAG(95)) + { + PRINT_DEBUG_95( "Bodies were not " + "imprinted.\n"); + AcisQueryEngine::instance()->ACIS_API_error(result, "imprint Bodies"); + } + status = CUBIT_FAILURE; + } + } + PRINT_DEBUG_3( "CPU time taken to imprint two BODYs: " + "%f secs\n", imprint_BODYs_timer.cpu_secs() ) ; - return status; + return status; } //------------------------------------------------------------------------- @@ -759,40 +760,40 @@ BODY* AcisModifyEngine::copy_BODY (BODY* body_ptr, bool remove_attribs ) const { - // If the input pointer is NULL, return a NULL pointer - if (body_ptr == NULL) - { + // If the input pointer is NULL, return a NULL pointer + if (body_ptr == NULL) + { PRINT_ERROR("Cannot copy ACIS BODY - input pointer is NULL.\n"); return (BODY *) NULL; - } + } - BODY* new_body_ptr = NULL; + BODY* new_body_ptr = NULL; - if( remove_attribs ) - ATTRIB_CUBIT_OWNER::set_copyable( false ); + if( remove_attribs ) + ATTRIB_CUBIT_OWNER::set_copyable( false ); - outcome result = api_copy_body(body_ptr, new_body_ptr); + outcome result = api_copy_body(body_ptr, new_body_ptr); - if (!result.ok()) - { + if (!result.ok()) + { AcisQueryEngine::instance()->ACIS_API_error (result); new_body_ptr = NULL; - } - // Before returning this new BODY, first make sure that all the CUBIT - // OWNER attributes are cleaned out of it - if( remove_attribs ) - ATTRIB_CUBIT_OWNER::set_copyable( true ); -/* - if ( remove_attribs ) - { - AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(new_body_ptr); - } -*/ - // Also make sure that any healing attributes are removed from it + } + // Before returning this new BODY, first make sure that all the CUBIT + // OWNER attributes are cleaned out of it + if( remove_attribs ) + ATTRIB_CUBIT_OWNER::set_copyable( true ); + /* + if ( remove_attribs ) + { + AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(new_body_ptr); + } + */ + // Also make sure that any healing attributes are removed from it #ifdef ACIS_HEALER - AcisHealerTool::instance()->end_BODY_for_healing( new_body_ptr ); + AcisHealerTool::instance()->end_BODY_for_healing( new_body_ptr ); #endif - return new_body_ptr; + return new_body_ptr; } CubitStatus AcisModifyEngine::surface_intersection( Surface *surface1_ptr, @@ -800,42 +801,42 @@ DLIList<Curve*> &intersect_graph, const double ) const { - //First make sure the entities are ACIS. + //First make sure the entities are ACIS. SurfaceACIS *surf_ACIS_1= CAST_TO(surface1_ptr,SurfaceACIS); SurfaceACIS *surf_ACIS_2= CAST_TO(surface2_ptr,SurfaceACIS); if ( !surf_ACIS_1 || !surf_ACIS_2 ) - { - PRINT_ERROR("In AcisModifyEngine::surface_intersection\n" - "Not all entities are from the same engine.\n"); - return CUBIT_FAILURE; - } - //Get the original bodies. + { + PRINT_ERROR("In AcisModifyEngine::surface_intersection\n" + "Not all entities are from the same engine.\n"); + return CUBIT_FAILURE; + } + //Get the original bodies. FACE* FACE1_ptr = surf_ACIS_1->get_FACE_ptr(); FACE* FACE2_ptr = surf_ACIS_2->get_FACE_ptr(); BODY* intersect_BODY = NULL; - //Now get the intersection. + //Now get the intersection. CubitBoolean intersecting = CUBIT_FALSE; CubitStatus ret = FACE_intersection(FACE1_ptr, FACE2_ptr, intersect_BODY, intersecting); if ( ret != CUBIT_SUCCESS ) return ret; if ( !intersecting ) - { + { //No intersection, we should have caught this before, but //just return with an empty edge list. - return CUBIT_SUCCESS; - } + return CUBIT_SUCCESS; + } ret = convert_WIRE( intersect_BODY, intersect_graph ); if ( ret != CUBIT_SUCCESS ) return ret; - //Okay we should have our fill of curves. - //Delete the intersection graph wire, which should - //be fine since we copied the curves. + //Okay we should have our fill of curves. + //Delete the intersection graph wire, which should + //be fine since we copied the curves. api_del_entity(intersect_BODY); - //return sucess! + //return sucess! return CUBIT_SUCCESS; } @@ -854,27 +855,27 @@ return CUBIT_FAILURE; BODY *sheet_BODY = this->create_infinite_plane_cutting_tool( - point_1, point_2, point_3, super_box, CUBIT_TRUE); + point_1, point_2, point_3, super_box, CUBIT_TRUE); BODY* BODY_to_trim_to = AcisQueryEngine::get_BODY(body_to_trim_to); bool delete_attribs = CUBIT_TRUE; BODY* BODY_copy = this->copy_BODY(BODY_to_trim_to, delete_attribs); if (BODY_copy == NULL) - { - PRINT_ERROR("Cannot make a copy of the parent ACIS BODY of volume.\n" - " mid plane creation failed.\n" ); - return CUBIT_FAILURE; - } + { + PRINT_ERROR("Cannot make a copy of the parent ACIS BODY of volume.\n" + " mid plane creation failed.\n" ); + return CUBIT_FAILURE; + } outcome result = api_intersect( BODY_copy, sheet_BODY ); if ( !result.ok() ) - { - api_del_entity(BODY_copy); - api_del_entity(sheet_BODY); - PRINT_ERROR("Problems creating midplane.\n"); - return CUBIT_FAILURE; - } + { + api_del_entity(BODY_copy); + api_del_entity(sheet_BODY); + PRINT_ERROR("Problems creating midplane.\n"); + return CUBIT_FAILURE; + } //Create a new cubit body for the imprinted body. midplane_body = AcisQueryEngine::instance()-> @@ -891,48 +892,48 @@ // Date : 03/07/06 //============================================================================= CubitStatus AcisModifyEngine::get_spheric_mid_surface( Surface *surface_ptr1, - Surface *surface_ptr2, - BodySM *body_to_trim_to, - BodySM *&midsurface_body ) const + Surface *surface_ptr2, + BodySM *body_to_trim_to, + BodySM *&midsurface_body ) const { SurfaceACIS *surf_ACIS1 = CAST_TO(surface_ptr1, SurfaceACIS ); FACE* FACE1_ptr = make_FACE( surf_ACIS1->get_FACE_ptr() ); int surface_type = (&(FACE1_ptr->geometry()->equation()))->type(); if( surface_type != sphere_type ) - { - PRINT_ERROR( "In AcisModifyEngine::get_spheric_mid_surface\n" - " The CGM sphere is not an ASIS sphere (%d %d).\n", surface_type, SPHERE_SURFACE_TYPE ); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_spheric_mid_surface\n" + " The CGM sphere is not an ASIS sphere (%d %d).\n", surface_type, SPHERE_SURFACE_TYPE ); + return CUBIT_FAILURE; + } SurfaceACIS *surf_ACIS2 = CAST_TO(surface_ptr2, SurfaceACIS ); FACE* FACE2_ptr = make_FACE( surf_ACIS2->get_FACE_ptr() ); surface_type = (&(FACE2_ptr->geometry()->equation()))->type(); if( surface_type != sphere_type ) - { - PRINT_ERROR( "In AcisModifyEngine::get_spheric_mid_surface\n" - " The CGM sphere is not an ASIS sphere (%d %d).\n", surface_type, SPHERE_SURFACE_TYPE ); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_spheric_mid_surface\n" + " The CGM sphere is not an ASIS sphere (%d %d).\n", surface_type, SPHERE_SURFACE_TYPE ); + return CUBIT_FAILURE; + } -// surface const* acis_surface1 = &(FACE1_ptr->geometry()->equation()); -// sphere const* sphere_surface1 = (sphere *)acis_surface1; + // surface const* acis_surface1 = &(FACE1_ptr->geometry()->equation()); + // sphere const* sphere_surface1 = (sphere *)acis_surface1; SURFACE const* acis_SURFACE1 = FACE1_ptr->geometry(); SPHERE const* SPHERE_SURFACE1 = (SPHERE *)acis_SURFACE1; SPAposition center1 = SPHERE_SURFACE1->centre(); -// surface const* acis_surface2 = &(FACE2_ptr->geometry()->equation()); -// sphere const* sphere_surface2 = (sphere *)acis_surface2; + // surface const* acis_surface2 = &(FACE2_ptr->geometry()->equation()); + // sphere const* sphere_surface2 = (sphere *)acis_surface2; SURFACE const* acis_SURFACE2 = FACE2_ptr->geometry(); SPHERE const* SPHERE_SURFACE2 = (SPHERE *)acis_SURFACE2; SPAposition center2 = SPHERE_SURFACE2->centre(); if ( center1 != center2 ) - { - PRINT_ERROR( "In AcisModifyEngine::get_spheric_mid_surface\n" - " Not supported yet: spheres do not have the same center.\n" ); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_spheric_mid_surface\n" + " Not supported yet: spheres do not have the same center.\n" ); + return CUBIT_FAILURE; + } CubitBox bounding_box = GeometryQueryTool::instance()->model_bounding_box(); @@ -956,52 +957,52 @@ new_FACE_ptr ); if (!result.ok() || new_FACE_ptr == NULL || new_FACE_ptr->geometry() == NULL ) - { - PRINT_ERROR( "In AcisModifyEngine::get_spheric_mid_surface\n" - " ACIS api_make_spface function failed.\n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_spheric_mid_surface\n" + " ACIS api_make_spface function failed.\n"); + AcisQueryEngine::instance()->ACIS_API_error (result); + return CUBIT_FAILURE; + } FACE *face_list[1]; face_list[0] = new_FACE_ptr; result = api_sheet_from_ff( 1, face_list, sheet_BODY ); if ( !result.ok() || sheet_BODY == NULL || sheet_BODY->lump() == NULL - || sheet_BODY->lump()->shell() == NULL || - sheet_BODY->lump()->shell()->first_face() == NULL ) - { - PRINT_ERROR( "In AcisModifyEngine::get_spheric_mid_surface\n" - " ACIS api_sheet_from_ff function failed.\n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - return CUBIT_FAILURE; - } + || sheet_BODY->lump()->shell() == NULL || + sheet_BODY->lump()->shell()->first_face() == NULL ) + { + PRINT_ERROR( "In AcisModifyEngine::get_spheric_mid_surface\n" + " ACIS api_sheet_from_ff function failed.\n"); + AcisQueryEngine::instance()->ACIS_API_error (result); + return CUBIT_FAILURE; + } result = api_body_to_2d( sheet_BODY ); if ( !result.ok() ) - { - PRINT_ERROR( "In AcisModifyEngine::get_spheric_mid_surface\n" - " ACIS api_body_to_2d function failed.\n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_spheric_mid_surface\n" + " ACIS api_body_to_2d function failed.\n"); + AcisQueryEngine::instance()->ACIS_API_error (result); + return CUBIT_FAILURE; + } BODY* BODY_to_trim_to = AcisQueryEngine::get_BODY(body_to_trim_to); bool delete_attribs = CUBIT_TRUE; BODY* BODY_copy = this->copy_BODY(BODY_to_trim_to, delete_attribs); if ( BODY_copy == NULL ) - { - PRINT_ERROR( "In AcisModifyEngine::get_spheric_mid_surface\n" - " Cannot make a copy of the parent ACIS BODY of volume.\n" ); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_spheric_mid_surface\n" + " Cannot make a copy of the parent ACIS BODY of volume.\n" ); + return CUBIT_FAILURE; + } result = api_intersect( BODY_copy, sheet_BODY ); if ( !result.ok() ) - { - api_del_entity( BODY_copy ); - api_del_entity( sheet_BODY ); - PRINT_ERROR( "In AcisModifyEngine::get_spheric_mid_surface\n" - " ACIS api_intersect function failed.\n" ); - return CUBIT_FAILURE; - } + { + api_del_entity( BODY_copy ); + api_del_entity( sheet_BODY ); + PRINT_ERROR( "In AcisModifyEngine::get_spheric_mid_surface\n" + " ACIS api_intersect function failed.\n" ); + return CUBIT_FAILURE; + } midsurface_body = AcisQueryEngine::instance()->populate_topology_bridges(sheet_BODY); @@ -1016,28 +1017,28 @@ // Date : 03/07/06 //============================================================================= CubitStatus AcisModifyEngine::get_conic_mid_surface( Surface *surface_ptr1, - Surface *surface_ptr2, - BodySM *body_to_trim_to, - BodySM *&midsurface_body ) const + Surface *surface_ptr2, + BodySM *body_to_trim_to, + BodySM *&midsurface_body ) const { SurfaceACIS *surf_ACIS1 = CAST_TO(surface_ptr1, SurfaceACIS ); FACE* FACE1_ptr = make_FACE( surf_ACIS1->get_FACE_ptr() ); int surface_type = (&(FACE1_ptr->geometry()->equation()))->type(); if( surface_type != cone_type ) - { - PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" - " The CGM cone is not an ASIS cone (%d %d).\n", surface_type, CONE_SURFACE_TYPE ); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" + " The CGM cone is not an ASIS cone (%d %d).\n", surface_type, CONE_SURFACE_TYPE ); + return CUBIT_FAILURE; + } SurfaceACIS *surf_ACIS2 = CAST_TO(surface_ptr2, SurfaceACIS ); FACE* FACE2_ptr = make_FACE( surf_ACIS2->get_FACE_ptr() ); surface_type = (&(FACE2_ptr->geometry()->equation()))->type(); if( surface_type != cone_type ) - { - PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" - " The CGM cone is not an ASIS cone (%d %d).\n", surface_type, CONE_SURFACE_TYPE ); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" + " The CGM cone is not an ASIS cone (%d %d).\n", surface_type, CONE_SURFACE_TYPE ); + return CUBIT_FAILURE; + } surface const* acis_surface1 = &(FACE1_ptr->geometry()->equation()); cone const* cone_surface1 = (cone *)acis_surface1; @@ -1052,34 +1053,34 @@ if ( ( sine_angle1 != 0.0 ) || ( fabs( cosine_angle1 ) != 1.0 ) || ( sine_angle2 != 0.0 ) || ( fabs( cosine_angle2 ) != 1.0 ) ) - { - if( ( sine_angle1 != sine_angle2 ) || ( cosine_angle1 != cosine_angle2 ) ) { - PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" - " Not supported yet: cones do not have the same major angle.\n" ); - return CUBIT_FAILURE; + if( ( sine_angle1 != sine_angle2 ) || ( cosine_angle1 != cosine_angle2 ) ) + { + PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" + " Not supported yet: cones do not have the same major angle.\n" ); + return CUBIT_FAILURE; + } } - } ellipse const* base1 = &cone_surface1->base; double ratio1 = base1->radius_ratio; ellipse const* base2 = &cone_surface2->base; double ratio2 = base2->radius_ratio; if( ratio1 != ratio2 ) - { - PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" - " Not supported yet: cones do not have the same radius ratios.\n" ); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" + " Not supported yet: cones do not have the same radius ratios.\n" ); + return CUBIT_FAILURE; + } SPAunit_vector normal1 = base1->normal; SPAunit_vector normal2 = base2->normal; if ( ( normal1 != normal2 ) && ( - normal1 != normal2 ) ) - { - PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" - " Not supported yet: cones do not have the same axis of symmetry.\n" ); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" + " Not supported yet: cones do not have the same axis of symmetry.\n" ); + return CUBIT_FAILURE; + } SPAposition const centre1 = base1->centre; SPAposition const centre2 = base2->centre; @@ -1089,72 +1090,72 @@ centre2.y() - centre1.y(), centre2.z() - centre1.z() ); if ( ! c1_to_c2.about_equal( null_vec ) ) - { - CubitVector comm_dir( normal1.x(), normal1.y(), normal1.z() ); - c1_to_c2.normalize(); - if ( ( ! c1_to_c2.about_equal( comm_dir ) ) && ( ! (-c1_to_c2).about_equal( comm_dir ) ) ) { - CubitVector const point_1( ( centre1.x() + centre2.x() ) * .5, - ( centre1.y() + centre2.y() ) * .5, - ( centre1.z() + centre2.z() ) * .5 ); - CubitVector const point_2 = point_1 + comm_dir; - CubitVector const point_3 = point_1 + ( comm_dir * c1_to_c2 ); - CubitStatus ret = this->get_mid_plane( point_1, point_2, point_3, - body_to_trim_to, midsurface_body ); + CubitVector comm_dir( normal1.x(), normal1.y(), normal1.z() ); + c1_to_c2.normalize(); + if ( ( ! c1_to_c2.about_equal( comm_dir ) ) && ( ! (-c1_to_c2).about_equal( comm_dir ) ) ) + { + CubitVector const point_1( ( centre1.x() + centre2.x() ) * .5, + ( centre1.y() + centre2.y() ) * .5, + ( centre1.z() + centre2.z() ) * .5 ); + CubitVector const point_2 = point_1 + comm_dir; + CubitVector const point_3 = point_1 + ( comm_dir * c1_to_c2 ); + CubitStatus ret = this->get_mid_plane( point_1, point_2, point_3, + body_to_trim_to, midsurface_body ); - return ret; + return ret; + } } - } CubitBox bounding_box = GeometryQueryTool::instance()->model_bounding_box(); BODY *sheet_BODY; CubitBoolean cylinder = CUBIT_FALSE; if ( ( sine_angle1 == 0.0 ) && ( fabs( cosine_angle1 ) == 1.0 ) ) - { - cylinder = CUBIT_TRUE; - } + { + cylinder = CUBIT_TRUE; + } double const st_ang = 0.; double const end_ang = 2. * CUBIT_PI; double const height = 2. * (bounding_box.diagonal()).length(); CubitVector center_vec; CubitVector temp_norm( normal1.x(), normal1.y(), normal1.z()); if ( ! cylinder ) - { - if ( sine_angle1 > 0.0 && cosine_angle1 > 0.0 ) { - sine_angle1 = - sine_angle1; - temp_norm *= - 1.0; + if ( sine_angle1 > 0.0 && cosine_angle1 > 0.0 ) + { + sine_angle1 = - sine_angle1; + temp_norm *= - 1.0; + } + else if ( sine_angle1 < 0.0 && cosine_angle1 < 0.0 ) + { + cosine_angle1 = - cosine_angle1; + temp_norm *= - 1.0; + } + //make center of surface along axis, 1/2 height of + //bounding box of entire model. + CubitVector root_vec( centre1.x(), centre1.y(), centre1.z() ); + center_vec = root_vec + ( -.5 * height) * temp_norm; } - else if ( sine_angle1 < 0.0 && cosine_angle1 < 0.0 ) + else { - cosine_angle1 = - cosine_angle1; - temp_norm *= - 1.0; + CubitVector root_vec( centre1.x(), centre1.y(), centre1.z() ); + center_vec = .5 * height * temp_norm; + center_vec = root_vec - center_vec; } - //make center of surface along axis, 1/2 height of - //bounding box of entire model. - CubitVector root_vec( centre1.x(), centre1.y(), centre1.z() ); - center_vec = root_vec + ( -.5 * height) * temp_norm; - } - else - { - CubitVector root_vec( centre1.x(), centre1.y(), centre1.z() ); - center_vec = .5 * height * temp_norm; - center_vec = root_vec - center_vec; - } SPAposition const center ( center_vec.x(), center_vec.y(), center_vec.z() ); SPAvector const major_axis1 = base1->major_axis; SPAvector const major_axis2 = base2->major_axis; SPAvector newmajor_axis; if ( cosine_angle1 * cosine_angle2 < 0. ) - { - newmajor_axis = ( major_axis1 - major_axis2 ) * .5; - } + { + newmajor_axis = ( major_axis1 - major_axis2 ) * .5; + } else - { - newmajor_axis = ( major_axis1 + major_axis2 ) * .5; - } + { + newmajor_axis = ( major_axis1 + major_axis2 ) * .5; + } FACE *new_FACE_ptr = NULL; outcome result = api_make_cnface( center, @@ -1169,52 +1170,52 @@ new_FACE_ptr ); if (!result.ok() || new_FACE_ptr == NULL || new_FACE_ptr->geometry() == NULL ) - { - PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" - " ACIS api_make_cnface function failed.\n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" + " ACIS api_make_cnface function failed.\n"); + AcisQueryEngine::instance()->ACIS_API_error (result); + return CUBIT_FAILURE; + } FACE *face_list[1]; face_list[0] = new_FACE_ptr; result = api_sheet_from_ff( 1, face_list, sheet_BODY ); if ( !result.ok() || sheet_BODY == NULL || sheet_BODY->lump() == NULL - || sheet_BODY->lump()->shell() == NULL || - sheet_BODY->lump()->shell()->first_face() == NULL ) - { - PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" - " ACIS api_sheet_from_ff function failed.\n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - return CUBIT_FAILURE; - } + || sheet_BODY->lump()->shell() == NULL || + sheet_BODY->lump()->shell()->first_face() == NULL ) + { + PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" + " ACIS api_sheet_from_ff function failed.\n"); + AcisQueryEngine::instance()->ACIS_API_error (result); + return CUBIT_FAILURE; + } result = api_body_to_2d( sheet_BODY ); if ( !result.ok() ) - { - PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" - " ACIS api_body_to_2d function failed.\n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" + " ACIS api_body_to_2d function failed.\n"); + AcisQueryEngine::instance()->ACIS_API_error (result); + return CUBIT_FAILURE; + } BODY* BODY_to_trim_to = AcisQueryEngine::get_BODY(body_to_trim_to); bool delete_attribs = CUBIT_TRUE; BODY* BODY_copy = this->copy_BODY(BODY_to_trim_to, delete_attribs); if ( BODY_copy == NULL ) - { - PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" - " Cannot make a copy of the parent ACIS BODY of volume.\n" ); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" + " Cannot make a copy of the parent ACIS BODY of volume.\n" ); + return CUBIT_FAILURE; + } result = api_intersect( BODY_copy, sheet_BODY ); if ( !result.ok() ) - { - api_del_entity( BODY_copy ); - api_del_entity( sheet_BODY ); - PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" - " ACIS api_intersect function failed.\n" ); - return CUBIT_FAILURE; - } + { + api_del_entity( BODY_copy ); + api_del_entity( sheet_BODY ); + PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" + " ACIS api_intersect function failed.\n" ); + return CUBIT_FAILURE; + } midsurface_body = AcisQueryEngine::instance()->populate_topology_bridges(sheet_BODY); @@ -1229,64 +1230,64 @@ // Date : 03/07/06 //============================================================================= CubitStatus AcisModifyEngine::get_toric_mid_surface( Surface *surface_ptr1, - Surface *surface_ptr2, - BodySM *body_to_trim_to, - BodySM *&midsurface_body ) const + Surface *surface_ptr2, + BodySM *body_to_trim_to, + BodySM *&midsurface_body ) const { SurfaceACIS *surf_ACIS1 = CAST_TO(surface_ptr1, SurfaceACIS ); FACE* FACE1_ptr = make_FACE( surf_ACIS1->get_FACE_ptr() ); int surface_type = (&(FACE1_ptr->geometry()->equation()))->type(); if( surface_type != torus_type ) - { - PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n" - " The CGM cone is not an ASIS torus (%d %d).\n", surface_type, CONE_SURFACE_TYPE ); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n" + " The CGM cone is not an ASIS torus (%d %d).\n", surface_type, CONE_SURFACE_TYPE ); + return CUBIT_FAILURE; + } SurfaceACIS *surf_ACIS2 = CAST_TO(surface_ptr2, SurfaceACIS ); FACE* FACE2_ptr = make_FACE( surf_ACIS2->get_FACE_ptr() ); surface_type = (&(FACE2_ptr->geometry()->equation()))->type(); if( surface_type != torus_type ) - { - PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n" - " The CGM cone is not an ASIS torus (%d %d).\n", surface_type, CONE_SURFACE_TYPE ); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n" + " The CGM cone is not an ASIS torus (%d %d).\n", surface_type, CONE_SURFACE_TYPE ); + return CUBIT_FAILURE; + } -// surface const* acis_surface1 = &(FACE1_ptr->geometry()->equation()); -// torus const* torus_surface1 = (torus *)acis_surface1; + // surface const* acis_surface1 = &(FACE1_ptr->geometry()->equation()); + // torus const* torus_surface1 = (torus *)acis_surface1; SURFACE const* acis_SURFACE1 = FACE1_ptr->geometry(); TORUS const* TORUS_SURFACE1 = (TORUS *)acis_SURFACE1; double major_radius1 = TORUS_SURFACE1->major_radius(); -// surface const* acis_surface2 = &(FACE2_ptr->geometry()->equation()); -// torus const* torus_surface2 = (torus *)acis_surface2; + // surface const* acis_surface2 = &(FACE2_ptr->geometry()->equation()); + // torus const* torus_surface2 = (torus *)acis_surface2; SURFACE const* acis_SURFACE2 = FACE2_ptr->geometry(); TORUS const* TORUS_SURFACE2 = (TORUS *)acis_SURFACE2; double major_radius2 = TORUS_SURFACE2->major_radius(); if ( major_radius1 != major_radius2 ) - { - PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n" - " Not supported yet: torii do not have the same radii.\n" ); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n" + " Not supported yet: torii do not have the same radii.\n" ); + return CUBIT_FAILURE; + } SPAposition center1 = TORUS_SURFACE1->centre(); SPAposition center2 = TORUS_SURFACE2->centre(); if ( center1 != center2 ) - { - PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n" - " Not supported yet: torii do not have the same center.\n" ); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n" + " Not supported yet: torii do not have the same center.\n" ); + return CUBIT_FAILURE; + } SPAunit_vector normal1 = TORUS_SURFACE1->normal(); SPAunit_vector normal2 = TORUS_SURFACE2->normal(); if ( ( normal1 != normal2 ) && ( - normal1 != normal2 ) ) - { - PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" - " Not supported yet: torii do not have the same axis of symmetry.\n" ); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_conic_mid_surface\n" + " Not supported yet: torii do not have the same axis of symmetry.\n" ); + return CUBIT_FAILURE; + } CubitBox bounding_box = GeometryQueryTool::instance()->model_bounding_box(); @@ -1310,52 +1311,52 @@ new_FACE_ptr ); if (!result.ok() || new_FACE_ptr == NULL || new_FACE_ptr->geometry() == NULL ) - { - PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n" - " ACIS api_make_trface function failed.\n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n" + " ACIS api_make_trface function failed.\n"); + AcisQueryEngine::instance()->ACIS_API_error (result); + return CUBIT_FAILURE; + } FACE *face_list[1]; face_list[0] = new_FACE_ptr; result = api_sheet_from_ff( 1, face_list, sheet_BODY ); if ( !result.ok() || sheet_BODY == NULL || sheet_BODY->lump() == NULL - || sheet_BODY->lump()->shell() == NULL || - sheet_BODY->lump()->shell()->first_face() == NULL ) - { - PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n" - " ACIS api_sheet_from_ff function failed.\n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - return CUBIT_FAILURE; - } + || sheet_BODY->lump()->shell() == NULL || + sheet_BODY->lump()->shell()->first_face() == NULL ) + { + PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n" + " ACIS api_sheet_from_ff function failed.\n"); + AcisQueryEngine::instance()->ACIS_API_error (result); + return CUBIT_FAILURE; + } result = api_body_to_2d( sheet_BODY ); if ( !result.ok() ) - { - PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n" - " ACIS api_body_to_2d function failed.\n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n" + " ACIS api_body_to_2d function failed.\n"); + AcisQueryEngine::instance()->ACIS_API_error (result); + return CUBIT_FAILURE; + } BODY* BODY_to_trim_to = AcisQueryEngine::get_BODY(body_to_trim_to); bool delete_attribs = CUBIT_TRUE; BODY* BODY_copy = this->copy_BODY(BODY_to_trim_to, delete_attribs); if ( BODY_copy == NULL ) - { - PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n" - " Cannot make a copy of the parent ACIS BODY of volume.\n" ); - return CUBIT_FAILURE; - } + { + PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n" + " Cannot make a copy of the parent ACIS BODY of volume.\n" ); + return CUBIT_FAILURE; + } result = api_intersect( BODY_copy, sheet_BODY ); if ( !result.ok() ) - { - api_del_entity( BODY_copy ); - api_del_entity( sheet_BODY ); - PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n" - " ACIS api_intersect function failed.\n" ); - return CUBIT_FAILURE; - } + { + api_del_entity( BODY_copy ); + api_del_entity( sheet_BODY ); + PRINT_ERROR( "In AcisModifyEngine::get_toric_mid_surface\n" + " ACIS api_intersect function failed.\n" ); + return CUBIT_FAILURE; + } midsurface_body = AcisQueryEngine::instance()->populate_topology_bridges(sheet_BODY); @@ -1379,8 +1380,8 @@ CubitBoolean keep_old_body, CubitBoolean preview ) const { - return AcisTweakTool::instance()->tweak_chamfer( curve_list, left_offset, - new_bodysm_list, right_offset, keep_old_body, preview ); + return AcisTweakTool::instance()->tweak_chamfer( curve_list, left_offset, + new_bodysm_list, right_offset, keep_old_body, preview ); } //============================================================================= @@ -1407,8 +1408,8 @@ CubitBoolean preview ) const { return AcisTweakTool::instance()->tweak_chamfer( ref_vertex_list, offset1, - new_bodysm_list, edge1, offset2, edge2, offset3, edge3, keep_old_body, - preview ); + new_bodysm_list, edge1, offset2, edge2, offset3, edge3, keep_old_body, + preview ); } //============================================================================= @@ -1425,8 +1426,8 @@ CubitBoolean keep_old_body, CubitBoolean preview ) const { - return AcisTweakTool::instance()->tweak_fillet( curve_list, radius, - new_bodysm_list, keep_old_body, preview ); + return AcisTweakTool::instance()->tweak_fillet( curve_list, radius, + new_bodysm_list, keep_old_body, preview ); } //============================================================================= @@ -1446,7 +1447,7 @@ CubitBoolean preview ) const { return AcisTweakTool::instance()->tweak_fillet( curve_ptr, start_radius, - end_radius, new_bodysm_ptr, keep_old_body, preview ); + end_radius, new_bodysm_ptr, keep_old_body, preview ); } //============================================================================= @@ -1465,7 +1466,7 @@ CubitBoolean preview ) const { return AcisTweakTool::instance()->tweak_fillet( ref_vertex_list, radius, - new_bodysm_list, keep_old_body, preview ); + new_bodysm_list, keep_old_body, preview ); } //============================================================================= @@ -1481,8 +1482,8 @@ CubitBoolean keep_old_body, CubitBoolean preview ) const { - return AcisTweakTool::instance()->tweak_move( surface_list, delta, - new_bodysm_list, keep_old_body, preview ); + return AcisTweakTool::instance()->tweak_move( surface_list, delta, + new_bodysm_list, keep_old_body, preview ); } //============================================================================= @@ -1499,7 +1500,7 @@ CubitBoolean preview ) const { return AcisTweakTool::instance()->tweak_move( curve_list, delta, - new_bodysm_list, keep_old_body, preview ); + new_bodysm_list, keep_old_body, preview ); } //============================================================================= @@ -1516,8 +1517,8 @@ CubitBoolean keep_old_body, CubitBoolean preview ) const { - return AcisTweakTool::instance()->tweak_offset( surface_list, - offset_distance, new_bodysm_list, keep_old_body, preview ); + return AcisTweakTool::instance()->tweak_offset( surface_list, + offset_distance, new_bodysm_list, keep_old_body, preview ); } //============================================================================= @@ -1535,7 +1536,7 @@ CubitBoolean preview ) const { return AcisTweakTool::instance()->tweak_offset( curve_list, offset_distance, - new_bodysm_list, keep_old_body, preview ); + new_bodysm_list, keep_old_body, preview ); } //============================================================================= @@ -1553,8 +1554,8 @@ CubitBoolean keep_old_body, CubitBoolean preview ) const { - return AcisTweakTool::instance()->tweak_remove( ref_face_list, - new_bodysm_list, extend_adjoining, keep_surface, keep_old_body, preview ); + return AcisTweakTool::instance()->tweak_remove( ref_face_list, + new_bodysm_list, extend_adjoining, keep_surface, keep_old_body, preview ); } //================================================================================ @@ -1569,7 +1570,7 @@ CubitBoolean preview ) const { return AcisTweakTool::instance()->tweak_remove( curve_list, new_bodysm_list, - keep_old_body, preview ); + keep_old_body, preview ); } //============================================================================= @@ -1587,8 +1588,8 @@ CubitBoolean keep_old_body, CubitBoolean preview ) const { - return AcisTweakTool::instance()->tweak_target( surface_list, target_face_list, - new_bodysm_list, reverse_flg, keep_old_body, preview ); + return AcisTweakTool::instance()->tweak_target( surface_list, target_face_list, + new_bodysm_list, reverse_flg, keep_old_body, preview ); } //============================================================================= @@ -1608,7 +1609,7 @@ CubitBoolean preview ) const { return AcisTweakTool::instance()->tweak_target( curve_list, target_surf_list, - new_body_list, reverse_flg, keep_old_bodies, preview ); + new_body_list, reverse_flg, keep_old_bodies, preview ); } //============================================================================= @@ -1630,7 +1631,7 @@ CubitBoolean preview ) const { return AcisTweakTool::instance()->tweak_target( curve_list, target_curve_list, - new_body_list, reverse_flg, keep_old_bodies, preview ); + new_body_list, reverse_flg, keep_old_bodies, preview ); } //================================================================================ @@ -1643,8 +1644,8 @@ DLIList<DLIList<CubitVector*>*> &vec_lists_v, double net_tol, CubitBoolean heal ) const { - return AcisSurfaceTool::instance()->create_net_surface( new_body, vec_lists_u, vec_lists_v, - net_tol, heal ); + return AcisSurfaceTool::instance()->create_net_surface( new_body, vec_lists_u, vec_lists_v, + net_tol, heal ); } //================================================================================ @@ -1655,7 +1656,7 @@ CubitStatus AcisModifyEngine::create_net_surface( DLIList<Curve*>& u_curves, DLIList<Curve*>& v_curves, BodySM *& new_body, double net_tol, CubitBoolean heal ) const { - return AcisSurfaceTool::instance()->create_net_surface( u_curves, v_curves, new_body, net_tol, heal ); + return AcisSurfaceTool::instance()->create_net_surface( u_curves, v_curves, new_body, net_tol, heal ); } //================================================================================ @@ -1665,7 +1666,7 @@ //================================================================================ CubitStatus AcisModifyEngine::create_offset_surface( Surface* ref_face_ptr, BodySM*& new_body, double offset_distance ) const { - return AcisSurfaceTool::instance()->create_offset_surface( ref_face_ptr, new_body, offset_distance ); + return AcisSurfaceTool::instance()->create_offset_surface( ref_face_ptr, new_body, offset_distance ); } //================================================================================ @@ -1675,7 +1676,7 @@ //================================================================================ CubitStatus AcisModifyEngine::create_offset_body( BodySM* body_ptr, BodySM*& new_body, double offset_distance ) const { - return AcisSurfaceTool::instance()->create_offset_body( body_ptr, new_body, offset_distance ); + return AcisSurfaceTool::instance()->create_offset_body( body_ptr, new_body, offset_distance ); } //================================================================================ @@ -1685,7 +1686,7 @@ //================================================================================ CubitStatus AcisModifyEngine::create_skin_surface( DLIList<Curve*>& curves, BodySM*& new_body ) const { - return AcisSurfaceTool::instance()->create_skin_surface( curves, new_body ); + return AcisSurfaceTool::instance()->create_skin_surface( curves, new_body ); } //================================================================================ @@ -1700,9 +1701,9 @@ CubitBoolean align_direction, CubitBoolean perpendicular, CubitBoolean simplify_option ) const { - return AcisSurfaceTool::instance()->loft_surfaces( face1, takeoff1, face2, takeoff2, new_body, - arc_length_option, twist_option, align_direction, - perpendicular, simplify_option ); + return AcisSurfaceTool::instance()->loft_surfaces( face1, takeoff1, face2, takeoff2, new_body, + arc_length_option, twist_option, align_direction, + perpendicular, simplify_option ); } //================================================================================ @@ -1717,9 +1718,9 @@ CubitBoolean align_direction, CubitBoolean perpendicular, CubitBoolean simplify_option ) const { - return AcisSurfaceTool::instance()->loft_surfaces_to_body( face1, takeoff1, face2, takeoff2, new_body, - arc_length_option, twist_option, align_direction, - perpendicular, simplify_option ); + return AcisSurfaceTool::instance()->loft_surfaces_to_body( face1, takeoff1, face2, takeoff2, new_body, + arc_length_option, twist_option, align_direction, + perpendicular, simplify_option ); } //================================================================================ @@ -1730,7 +1731,7 @@ CubitStatus AcisModifyEngine::create_surface( DLIList<CubitVector*>& vec_list, BodySM *&new_body, Surface *ref_face_ptr, CubitBoolean project_points ) const { - return AcisSurfaceTool::instance()->create_surface( vec_list, new_body, ref_face_ptr, project_points ); + return AcisSurfaceTool::instance()->create_surface( vec_list, new_body, ref_face_ptr, project_points ); } //================================================================================ @@ -1742,7 +1743,7 @@ Surface *ref_face1, double leg1, Surface *ref_face2, double leg2, BodySM *&new_body ) const { - return AcisSurfaceTool::instance()->create_weld_surface( root, ref_face1, leg1, ref_face2, leg2, new_body ); + return AcisSurfaceTool::instance()->create_weld_surface( root, ref_face1, leg1, ref_face2, leg2, new_body ); } //------------------------------------------------------------------------- @@ -1766,38 +1767,38 @@ BODY *&intersect_graph, CubitBoolean &interfering ) const { - // Make sure we have 2 non-NULL, valid BODYs first. + // Make sure we have 2 non-NULL, valid BODYs first. if ( FACE1_ptr == NULL || !IS_ENTITY_TYPE( FACE1_ptr, FACE ) || FACE2_ptr == NULL || !IS_ENTITY_TYPE( FACE2_ptr, FACE ) ) - { - PRINT_ERROR("BUG: In AcisModifyEngine::BODY_intersection\n" - " One or both input FACE's are NULL or invalid.\n"); - assert(0); - return CUBIT_FAILURE; - } - //make copies to make sure nothing bad happens to the FACES. + { + PRINT_ERROR("BUG: In AcisModifyEngine::BODY_intersection\n" + " One or both input FACE's are NULL or invalid.\n"); + assert(0); + return CUBIT_FAILURE; + } + //make copies to make sure nothing bad happens to the FACES. FACE* copy_1 = make_FACE(FACE1_ptr); FACE* copy_2 = make_FACE(FACE2_ptr); intersect_graph = NULL; - // Create the intersection graph between the given bodies + // Create the intersection graph between the given bodies outcome result = api_fafa_int(copy_1, copy_2, intersect_graph); if (!result.ok() || intersect_graph == NULL ) - { + { // Find out if the returned "slice" is empty - interfering = CUBIT_FALSE; - } + interfering = CUBIT_FALSE; + } else - { - interfering = CUBIT_TRUE; - } - //now delete the copies. + { + interfering = CUBIT_TRUE; + } + //now delete the copies. api_delent(copy_1); api_delent(copy_2); - //return success. + //return success. return CUBIT_SUCCESS; } @@ -1807,101 +1808,101 @@ CubitStatus AcisModifyEngine::convert_WIRE( BODY *wire_BODY, DLIList <Curve*> &curve_list ) const { - //Now get the edges from the wire body (int_graph), and create - //ref edges. - DLIList <EDGE*> EDGE_list; - WIRE *cur_WIRE = NULL; - LUMP *cur_LUMP = NULL; - // Make sure the wire is OK, and get the appropriate entity - // Get a WIRE if it's there - if ( wire_BODY->wire() == NULL || - wire_BODY->wire()->coedge() == NULL || - wire_BODY->wire()->coedge()->edge() == NULL ) + //Now get the edges from the wire body (int_graph), and create + //ref edges. + DLIList <EDGE*> EDGE_list; + WIRE *cur_WIRE = NULL; + LUMP *cur_LUMP = NULL; + // Make sure the wire is OK, and get the appropriate entity + // Get a WIRE if it's there + if ( wire_BODY->wire() == NULL || + wire_BODY->wire()->coedge() == NULL || + wire_BODY->wire()->coedge()->edge() == NULL ) { - // If there was no WIRE, see if there's a lump - if(wire_BODY->lump() != NULL && - wire_BODY->lump()->shell() != NULL && - wire_BODY->lump()->shell()->wire() != NULL && - wire_BODY->lump()->shell()->wire()->coedge() != NULL && - wire_BODY->lump()->shell()->wire()->coedge()->edge() != NULL ) + // If there was no WIRE, see if there's a lump + if(wire_BODY->lump() != NULL && + wire_BODY->lump()->shell() != NULL && + wire_BODY->lump()->shell()->wire() != NULL && + wire_BODY->lump()->shell()->wire()->coedge() != NULL && + wire_BODY->lump()->shell()->wire()->coedge()->edge() != NULL ) { - cur_LUMP = wire_BODY->lump(); + cur_LUMP = wire_BODY->lump(); } - else + else { - PRINT_ERROR("Non-existent wire body in convert_WIRE function.\n"); - return CUBIT_FAILURE; + PRINT_ERROR("Non-existent wire body in convert_WIRE function.\n"); + return CUBIT_FAILURE; } } - else + else { - cur_WIRE = wire_BODY->wire(); + cur_WIRE = wire_BODY->wire(); } - LUMP *start_LUMP = cur_LUMP; - do{ - if((wire_BODY->wire() == NULL || - wire_BODY->wire()->coedge() == NULL || - wire_BODY->wire()->coedge()->edge() == NULL ) && - wire_BODY->lump() != NULL && - wire_BODY->lump()->shell() != NULL && - wire_BODY->lump()->shell()->wire() != NULL && - wire_BODY->lump()->shell()->wire()->coedge() != NULL && - wire_BODY->lump()->shell()->wire()->coedge()->edge() != NULL ) - { - cur_WIRE = cur_LUMP->shell()->wire(); - } + LUMP *start_LUMP = cur_LUMP; + do{ + if((wire_BODY->wire() == NULL || + wire_BODY->wire()->coedge() == NULL || + wire_BODY->wire()->coedge()->edge() == NULL ) && + wire_BODY->lump() != NULL && + wire_BODY->lump()->shell() != NULL && + wire_BODY->lump()->shell()->wire() != NULL && + wire_BODY->lump()->shell()->wire()->coedge() != NULL && + wire_BODY->lump()->shell()->wire()->coedge()->edge() != NULL ) + { + cur_WIRE = cur_LUMP->shell()->wire(); + } - WIRE *start_WIRE = cur_WIRE; + WIRE *start_WIRE = cur_WIRE; - if (cur_WIRE != NULL){ - do { - COEDGE *start_COEDGE = cur_WIRE->coedge(); - COEDGE *cur_COEDGE = start_COEDGE; - do{ - EDGE *cur_EDGE = cur_COEDGE->edge(); - //Just get one of the edges. Often you have two coedges - //for the same edge. - if ( EDGE_list.move_to(cur_EDGE) ) - { - // additional check to avoid an infinite loop - if(cur_COEDGE == cur_COEDGE->next()) - break; + if (cur_WIRE != NULL){ + do { + COEDGE *start_COEDGE = cur_WIRE->coedge(); + COEDGE *cur_COEDGE = start_COEDGE; + do{ + EDGE *cur_EDGE = cur_COEDGE->edge(); + //Just get one of the edges. Often you have two coedges + //for the same edge. + if ( EDGE_list.move_to(cur_EDGE) ) + { + // additional check to avoid an infinite loop + if(cur_COEDGE == cur_COEDGE->next()) + break; - cur_COEDGE = cur_COEDGE->next(); - continue; - } - else - { - EDGE_list.append(cur_EDGE); - } - EDGE *new_EDGE_ptr = NULL; - outcome result = api_edge(cur_EDGE, new_EDGE_ptr); - if ( !result.ok() || new_EDGE_ptr == NULL ) - { - PRINT_ERROR("In AcisModifyEngine::body_intersection\n" - " Cannot copy curve in intersection graph.\n"); - return CUBIT_FAILURE; - } - // Create a new CurveACIS object - // Use the new EDGE to create a new CurveACIS - Curve *new_curve = - AcisQueryEngine::instance()->populate_topology_bridges(new_EDGE_ptr); - curve_list.append(new_curve); - cur_COEDGE = cur_COEDGE->next(); - } while (cur_COEDGE && (cur_COEDGE != start_COEDGE)); - cur_WIRE = cur_WIRE->next(); - } while (cur_WIRE && (cur_WIRE != start_WIRE)); - } + cur_COEDGE = cur_COEDGE->next(); + continue; + } + else + { + EDGE_list.append(cur_EDGE); + } + EDGE *new_EDGE_ptr = NULL; + outcome result = api_edge(cur_EDGE, new_EDGE_ptr); + if ( !result.ok() || new_EDGE_ptr == NULL ) + { + PRINT_ERROR("In AcisModifyEngine::body_intersection\n" + " Cannot copy curve in intersection graph.\n"); + return CUBIT_FAILURE; + } + // Create a new CurveACIS object + // Use the new EDGE to create a new CurveACIS + Curve *new_curve = + AcisQueryEngine::instance()->populate_topology_bridges(new_EDGE_ptr); + curve_list.append(new_curve); + cur_COEDGE = cur_COEDGE->next(); + } while (cur_COEDGE && (cur_COEDGE != start_COEDGE)); + cur_WIRE = cur_WIRE->next(); + } while (cur_WIRE && (cur_WIRE != start_WIRE)); + } - //we may not have a lump, ACIS sometimes will return a wire - //as the intersection and other times a LUMP... - if (cur_LUMP) - { - cur_LUMP = cur_LUMP->next(); - } - }while (cur_LUMP && (start_LUMP != cur_LUMP)); - //At this point we are done! - return CUBIT_SUCCESS; + //we may not have a lump, ACIS sometimes will return a wire + //as the intersection and other times a LUMP... + if (cur_LUMP) + { + cur_LUMP = cur_LUMP->next(); + } + }while (cur_LUMP && (start_LUMP != cur_LUMP)); + //At this point we are done! + return CUBIT_SUCCESS; } //------------------------------------------------------------------------- @@ -1915,62 +1916,62 @@ // //------------------------------------------------------------------------- CubitBoolean AcisModifyEngine::BODYs_interfering ( - BODY* body1_ptr, - BODY* body2_ptr) const + BODY* body1_ptr, + BODY* body2_ptr) const { - CpuTimer timer; + CpuTimer timer; - // Efficient algorithm to test interference between 2 ACIS BODYs. The - // entire intersection boolean operation is *not* performed if api_slice - // is used. + // Efficient algorithm to test interference between 2 ACIS BODYs. The + // entire intersection boolean operation is *not* performed if api_slice + // is used. - CubitBoolean interfering = CUBIT_TRUE; + CubitBoolean interfering = CUBIT_TRUE; - // Use the NOP pair to ensure that the roll-back is done by ACIS after - // the test, so that the input BODYs are unaffected by this operation. - API_NOP_BEGIN; + // Use the NOP pair to ensure that the roll-back is done by ACIS after + // the test, so that the input BODYs are unaffected by this operation. + API_NOP_BEGIN; - BODY* slice = NULL; + BODY* slice = NULL; - // Make sure we have 2 non-NULL, valid BODYs first. - if ( body1_ptr == NULL || !IS_ENTITY_TYPE( body1_ptr, BODY ) || - body2_ptr == NULL || !IS_ENTITY_TYPE( body2_ptr, BODY ) ) - { + // Make sure we have 2 non-NULL, valid BODYs first. + if ( body1_ptr == NULL || !IS_ENTITY_TYPE( body1_ptr, BODY ) || + body2_ptr == NULL || !IS_ENTITY_TYPE( body2_ptr, BODY ) ) + { PRINT_ERROR("BUG: In AcisModifyEngine::BODYs_interfering\n" " One or both input BODYs are NULL or invalid.\n"); assert(0); return CUBIT_FALSE; - } + } - // Create the intersection graph between the given bodies - outcome status = api_slice(body1_ptr, body2_ptr, - *(SPAunit_vector *)NULL_REF, slice); + // Create the intersection graph between the given bodies + outcome status = api_slice(body1_ptr, body2_ptr, + *(SPAunit_vector *)NULL_REF, slice); - if (!status.ok() || slice == NULL ) - interfering = CUBIT_FALSE; - else - interfering = CUBIT_TRUE; + if (!status.ok() || slice == NULL ) + interfering = CUBIT_FALSE; + else + interfering = CUBIT_TRUE; - // Set the result variable to true so that the API_NOP_END - // can roll back the bulletin board to ensure that the - // ENTITYs that were modified within this NOP block will be - // returned to their original state. - result = outcome(0); + // Set the result variable to true so that the API_NOP_END + // can roll back the bulletin board to ensure that the + // ENTITYs that were modified within this NOP block will be + // returned to their original state. + result = outcome(0); - API_NOP_END; + API_NOP_END; - PRINT_DEBUG_3( "CPU time taken to check if two BODYs are " - "interfering: %f secs\n", timer.cpu_secs()); + PRINT_DEBUG_3( "CPU time taken to check if two BODYs are " + "interfering: %f secs\n", timer.cpu_secs()); - // Return the interference status - return interfering; + // Return the interference status + return interfering; } CubitStatus AcisModifyEngine::stitch_FACEs( DLIList<FACE*> &faces, - FACE *&result_FACE, - BODY *&stitched_BODY ) + FACE *&result_FACE, + BODY *&stitched_BODY )const { //Make copies of each FACE ENTITY_LIST copied_FACES; @@ -1980,62 +1981,62 @@ BODY *master = NULL; for( i=faces.size(); i--;) - { - FACE *tmp_FACE = faces.get_and_step(); - ENTITY *new_FACE = NULL; - result = api_copy_entity( (ENTITY*)tmp_FACE, new_FACE ); + { + FACE *tmp_FACE = faces.get_and_step(); + ENTITY *new_FACE = NULL; + result = api_copy_entity( (ENTITY*)tmp_FACE, new_FACE ); - FACE *face_list[1]; - face_list[0] = (FACE*)new_FACE; - result = api_sheet_from_ff( 1, face_list, sheet_BODY_ptr ); - result = api_body_to_2d( sheet_BODY_ptr ); + FACE *face_list[1]; + face_list[0] = (FACE*)new_FACE; + result = api_sheet_from_ff( 1, face_list, sheet_BODY_ptr ); + result = api_body_to_2d( sheet_BODY_ptr ); - if( !result.ok() ) - { - PRINT_ERROR("Problems copying surface(s)\n"); - //delete all other surface - for(i=0; i<copied_FACES.count(); i++) - api_delent( copied_FACES[i]); - return CUBIT_FAILURE; - } - else - { - if( master == NULL ) - master = sheet_BODY_ptr; + if( !result.ok() ) + { + PRINT_ERROR("Problems copying surface(s)\n"); + //delete all other surface + for(i=0; i<copied_FACES.count(); i++) + api_delent( copied_FACES[i]); + return CUBIT_FAILURE; + } else - copied_FACES.add( sheet_BODY_ptr ); + { + if( master == NULL ) + master = sheet_BODY_ptr; + else + copied_FACES.add( sheet_BODY_ptr ); + } } - } //stitch together to form a sheet body. #if CUBIT_ACIS_VERSION < 1100 for( i=0; i<copied_FACES.count(); i++ ) - { - result = api_unite((BODY*)copied_FACES[i], master ); - if( !result.ok() ) { - PRINT_ERROR("Problems stitching surfaces\n"); - //delete all other surface - for(; i<copied_FACES.count(); i++) - api_delent( copied_FACES[i]); - return CUBIT_FAILURE; + result = api_unite((BODY*)copied_FACES[i], master ); + if( !result.ok() ) + { + PRINT_ERROR("Problems stitching surfaces\n"); + //delete all other surface + for(; i<copied_FACES.count(); i++) + api_delent( copied_FACES[i]); + return CUBIT_FAILURE; + } } - } #else exact_stitch_options stitch_opts; result = api_stitch( master, copied_FACES, &stitch_opts ); #endif if( !result.ok() ) - { - api_delent( master ); - stitched_BODY = NULL; - for(i=0; i<copied_FACES.count(); i++) - api_delent( copied_FACES[i]); - result_FACE = NULL; - return CUBIT_FAILURE; - } + { + api_delent( master ); + stitched_BODY = NULL; + for(i=0; i<copied_FACES.count(); i++) + api_delent( copied_FACES[i]); + result_FACE = NULL; + return CUBIT_FAILURE; + } copied_FACES.clear(); stitched_BODY = master; @@ -2045,693 +2046,16 @@ api_get_faces( master, copied_FACES ); if( copied_FACES.count() != 1 ) - { - result_FACE = NULL; - return CUBIT_SUCCESS; - } + { + result_FACE = NULL; + return CUBIT_SUCCESS; + } else result_FACE = (FACE*)copied_FACES[0]; return CUBIT_SUCCESS; } -CubitStatus AcisModifyEngine::webcut_with_sweep_curves_rotated( - DLIList<BodySM*> &blank_bodies, - DLIList<Curve*> &curves, - const CubitVector& point, - const CubitVector& sweep_axis, - double angle, - Surface *stop_surf, - DLIList<BodySM*> &results_list, - CubitBoolean imprint) -{ - if(curves.size() == 0 ) - return CUBIT_FAILURE; - - //see if surface-where-sweep-is-to-stop has been specified - EDGE *EDGE_to_sweep = NULL; - FACE *stop_FACE= NULL; - if( stop_surf ) - { - SurfaceACIS *surf_ACIS = CAST_TO(stop_surf, SurfaceACIS ); - stop_FACE = surf_ACIS->get_FACE_ptr(); - } - - //sweep each curve about the specified axis - int i,j; - DLIList<FACE*> FACES_for_cutting; - for(i=curves.size(); i--; ) - { - Curve *curve = curves.get_and_step(); - - CurveACIS *curve_ACIS = CAST_TO(curve, CurveACIS); - EDGE *EDGE_ptr = curve_ACIS->get_EDGE_ptr(); - - if (!EDGE_ptr) - { - PRINT_ERROR("Unable to get ACIS EDGE from Curve\n" ); - for( j=FACES_for_cutting.size(); j--; ) - api_delent( FACES_for_cutting.get_and_step() ); - return CUBIT_FAILURE; - } - - outcome result = api_edge( EDGE_ptr, EDGE_to_sweep); - if (!result.ok() || EDGE_to_sweep == NULL ) - { - AcisQueryEngine::instance()->ACIS_API_error (result); - for( j=FACES_for_cutting.size(); j--; ) - api_delent( FACES_for_cutting.get_and_step() ); - PRINT_ERROR( "Unable to copy ACIS curve\n" ); - return CUBIT_FAILURE; - } - - BODY *BODY_of_swept_EDGE = NULL; - CubitStatus status; - - status = sweep_EDGE_about_axis( EDGE_to_sweep, BODY_of_swept_EDGE, - sweep_axis, point, angle, 0, 0.0, 0, - false, false, stop_FACE ); - - if( status == CUBIT_FAILURE ) - { - api_delent( EDGE_to_sweep ); - int j; - for( j=FACES_for_cutting.size(); j--; ) - api_delent( FACES_for_cutting.get_and_step() ); - return CUBIT_FAILURE; - } - - FACE *FACE_ptr = BODY_of_swept_EDGE->lump()->shell()->first_face(); - FACES_for_cutting.append( FACE_ptr ); - } - - //stitch FACEs together into one BODY - //they may not stitch into on single FACE... a sheet-body - //with multiple FACEs will still webcut though - BODY *tool_BODY = NULL; - if( FACES_for_cutting.size() > 1 ) - { - FACE *dummy_FACE = NULL; - CubitStatus status; - status = stitch_FACEs( FACES_for_cutting, dummy_FACE, tool_BODY ); - - if( status == CUBIT_FAILURE ) - { - PRINT_ERROR("Swept curves produce surfaces that cannot be stitched together.\n"); - for( i=FACES_for_cutting.size(); i--; ) - api_delent( FACES_for_cutting.get_and_step() ); - return CUBIT_FAILURE; - } - } - else - tool_BODY = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACES_for_cutting.get() ); - - //get rid of any unnecessary edges - api_clean_entity( (ENTITY*)tool_BODY); - - //webcut each blank BODY with the tool BODY - int num_cut=0; - DLIList<BodySM*> temp_new_bodies; - - for ( i = blank_bodies.size(); i > 0; i-- ) - { - BodySM *blank_body = blank_bodies.get_and_step(); - BODY *blank_BODY = AcisQueryEngine::get_BODY(blank_body ); - //now webcut it. - BODY *new_BODY_1, *new_BODY_2; - - CubitStatus status = webcut_with_sheet( blank_BODY, - tool_BODY, - new_BODY_1, - new_BODY_2, - imprint ); - if ( status == CUBIT_SUCCESS ) - { - DLIList<BODY*> new_BODY_list; - new_BODY_list.append(new_BODY_1); - new_BODY_list.append(new_BODY_2); - temp_new_bodies.clean_out(); - - CubitStatus result = get_new_Body(blank_body, blank_BODY, - new_BODY_list, temp_new_bodies, - CUBIT_FALSE); - if ( result != CUBIT_SUCCESS ) - { - api_delent( tool_BODY ); - PRINT_ERROR("Problems with building volume.\n"); - num_cut = 0; - return CUBIT_FAILURE; - } - else - { - results_list += temp_new_bodies; - num_cut++; - } - } - } - - return num_cut > 0 ? CUBIT_SUCCESS : CUBIT_FAILURE; -} - -CubitStatus AcisModifyEngine::webcut_with_sweep_surfaces_rotated( - DLIList<BodySM*> &blank_bodies, - DLIList<Surface*> &surfaces, - const CubitVector& point, - const CubitVector& sweep_vector, - double angle, - Surface *stop_surf, - bool up_to_next, - DLIList<BodySM*> &results_list, - CubitBoolean imprint ) -{ - FACE *FACE_to_sweep = NULL; - - int i; - CubitStatus status; - DLIList<FACE*> FACES_to_sweep; - if( surfaces.size() > 1 ) - { - DLIList<FACE*> faces; - for(i=surfaces.size(); i--;) - { - SurfaceACIS *surf_ACIS = CAST_TO(surfaces.get_and_step(), SurfaceACIS ); - faces.append( surf_ACIS->get_FACE_ptr() ); - } - - //attempt to stitch FACEs together, to get a single FACE - BODY *stitched_BODY = NULL; - status = stitch_FACEs( faces, FACE_to_sweep, stitched_BODY ); - - //can't stitch surfaces together, so we'll sweep them separately - if( status == CUBIT_FAILURE ) - { - PRINT_ERROR("Input surfaces could not be stitched together to form a single surface.\n"); - PRINT_INFO(" Input surfaces must share coinsident curves to be stitchable.\n"); - return CUBIT_FAILURE; - } - else if( !FACE_to_sweep ) //couldn't stitch into one FACE....will sweep surfaces individually - { - if( stitched_BODY ) api_delent( stitched_BODY ); - for(i=surfaces.size(); i--;) - { - SurfaceACIS *surf_ACIS = CAST_TO(surfaces.get_and_step(), SurfaceACIS ); - FACE_to_sweep = make_FACE( surf_ACIS->get_FACE_ptr() ); - FACES_to_sweep.append( FACE_to_sweep ); - } - } - else - FACES_to_sweep.append( FACE_to_sweep ); - } - else - { - Surface *surface = surfaces.get(); - SurfaceACIS *surf_ACIS = CAST_TO(surface, SurfaceACIS ); - FACE_to_sweep = make_FACE( surf_ACIS->get_FACE_ptr() ); - FACES_to_sweep.append( FACE_to_sweep ); - } - - //see if surface-where-sweep-is-to-stop has been specified - FACE *stop_FACE = NULL; - if( stop_surf ) - { - SurfaceACIS *surf_ACIS = CAST_TO(stop_surf, SurfaceACIS ); - stop_FACE = surf_ACIS->get_FACE_ptr(); - } - - //sweep each surface about the specified axis - bool volume_is_negative; - DLIList<BODY*> swept_BODYs; - for( i=FACES_to_sweep.size(); i--; ) - { - FACE_to_sweep = FACES_to_sweep.get_and_step(); - - status = sweep_FACE_about_axis( FACE_to_sweep, sweep_vector, point, angle, - volume_is_negative, true, 0, 0.0, 0, false, stop_FACE ); - - if( status == CUBIT_FAILURE ) - { - api_delent( FACE_to_sweep ); - for(i=swept_BODYs.size(); i--;) - api_delent( swept_BODYs.get_and_step() ); - return CUBIT_FAILURE; - } - - BODY *swept_BODY = AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_to_sweep); - swept_BODYs.append( swept_BODY ); - } - - //if there are more than 1, unite them all - BODY *tool_BODY = swept_BODYs.get_and_step(); - if( swept_BODYs.size() > 1 ) - { - for(i=swept_BODYs.size()-1; i--;) - { - outcome result = api_unite( swept_BODYs.get_and_step(), tool_BODY ); - if( !result.ok() ) - { - api_delent( tool_BODY ); - for(; i--; ) - api_delent( swept_BODYs.get_and_step() ); - return CUBIT_FAILURE; - } - } - } - - //get rid of any unnecessary edges - api_clean_entity( (ENTITY*)tool_BODY); - - //trim tool_body if 'up_to_next_surface' option is specified - if( up_to_next) - { - //get a vertex on the original face that we're sweeping - SurfaceACIS *surf_ACIS = CAST_TO(surfaces.get(), SurfaceACIS ); - - ENTITY_LIST vertices; - api_get_vertices( surf_ACIS->get_FACE_ptr(), vertices ); - - VERTEX *surf_VERT = NULL; - if( vertices.count() ) - surf_VERT = static_cast<VERTEX*>( vertices[0] ); - - if( !trim_up_to_next_surface( tool_BODY, blank_bodies, surf_VERT ) ) - { - api_delent( tool_BODY ); - PRINT_ERROR("Cannot use 'up_to_next' option with specified geometry\n"); - PRINT_INFO("Try the 'stop surface <id>' option instead\n"); - return CUBIT_FAILURE; - } - } - - return webcut( blank_bodies, tool_BODY, results_list, imprint ); - -} - -CubitStatus AcisModifyEngine::webcut_with_sweep_curves( - DLIList<BodySM*> &blank_bodies, - DLIList<Curve*> &curves, - const CubitVector& sweep_vector, - bool through_all, - Surface *stop_surf, - Curve *curve_to_sweep_along, - DLIList<BodySM*> &results_list, - CubitBoolean imprint ) -{ - EDGE *EDGE_to_sweep = NULL; - if(curves.size() == 0 ) - return CUBIT_FAILURE; - - CubitVector tmp_sweep_vector = sweep_vector; - - //get model bbox info...will scale sweep vector by its diagonal - //so that we go far enough - FACE *stop_FACE= NULL; - if( through_all || stop_surf ) - { - CubitBox bounding_box = GeometryQueryTool::instance()->model_bounding_box(); - tmp_sweep_vector.normalize(); - tmp_sweep_vector*=(2*bounding_box.diagonal().length()); - } - - //see if surface-where-sweep-is-to-stop has been specified - if( stop_surf ) - { - SurfaceACIS *surf_ACIS = CAST_TO(stop_surf, SurfaceACIS ); - stop_FACE = surf_ACIS->get_FACE_ptr(); - } - - //see if we're sweeping along a specified curve - BODY *WIRE_ptr = NULL; - if( curve_to_sweep_along ) - { - CurveACIS *curve_ACIS = CAST_TO(curve_to_sweep_along, CurveACIS); - EDGE *EDGE_ptr = curve_ACIS->get_EDGE_ptr(); - - if (!EDGE_ptr) - { - PRINT_ERROR("Unable to get ACIS EDGE from Curve\n" ); - return CUBIT_FAILURE; - } - - EDGE *EDGE_to_sweep_along = NULL; - outcome result = api_edge( EDGE_ptr, EDGE_to_sweep_along ); - if (!result.ok() || EDGE_to_sweep_along == NULL ) - { - AcisQueryEngine::instance()->ACIS_API_error (result); - PRINT_ERROR( "Unable to copy ACIS curve\n" ); - return CUBIT_FAILURE; - } - - EDGE* EDGES[1]; - EDGES[0] = EDGE_to_sweep_along; - result = api_make_ewire( 1, EDGES, WIRE_ptr); - if (!result.ok()) - { - AcisQueryEngine::instance()->ACIS_API_error (result); - PRINT_ERROR( "Unable to make ACIS wire body from curve to sweep along\n" ); - } - } - - //sweep each curve - int i,j; - DLIList<FACE*> FACES_for_cutting; - for(i=curves.size(); i--; ) - { - Curve *curve = curves.get_and_step(); - - CurveACIS *curve_ACIS = CAST_TO(curve, CurveACIS); - EDGE *EDGE_ptr = curve_ACIS->get_EDGE_ptr(); - - if (!EDGE_ptr) - { - PRINT_ERROR("Unable to get ACIS EDGE from Curve\n" ); - return CUBIT_FAILURE; - } - - outcome result = api_edge( EDGE_ptr, EDGE_to_sweep); - if (!result.ok() || EDGE_to_sweep == NULL ) - { - AcisQueryEngine::instance()->ACIS_API_error (result); - PRINT_ERROR( "Unable to copy ACIS curve\n" ); - for( j=FACES_for_cutting.size(); j--; ) - api_delent( FACES_for_cutting.get_and_step() ); - if( WIRE_ptr ) - api_delent( WIRE_ptr ); - return CUBIT_FAILURE; - } - - BODY *BODY_of_swept_EDGE = NULL; - CubitStatus status; - - if( WIRE_ptr ) - status = sweep_EDGE_along_WIRE( EDGE_to_sweep, WIRE_ptr, BODY_of_swept_EDGE, - 0.0, 0, false, stop_FACE ); - else - status = sweep_EDGE_along_vector( EDGE_to_sweep, BODY_of_swept_EDGE, - tmp_sweep_vector, 0.0, 0, false, stop_FACE ); - - if( status == CUBIT_FAILURE ) - { - api_delent( EDGE_to_sweep ); - for( j=FACES_for_cutting.size(); j--; ) - api_delent( FACES_for_cutting.get_and_step() ); - if( WIRE_ptr ) - api_delent( WIRE_ptr ); - return CUBIT_FAILURE; - } - - FACE *FACE_ptr = BODY_of_swept_EDGE->lump()->shell()->first_face(); - FACES_for_cutting.append( FACE_ptr ); - } - - if( WIRE_ptr ) - api_delent( WIRE_ptr ); - - //stitch FACEs together into one BODY - //they may not stitch into on single FACE... a sheet-body - //with multiple FACEs will still webcut though - BODY *tool_BODY = NULL; - if( FACES_for_cutting.size() > 1 ) - { - FACE *dummy_FACE = NULL; - CubitStatus status; - status = stitch_FACEs( FACES_for_cutting, dummy_FACE, tool_BODY ); - - if( status == CUBIT_FAILURE ) - { - PRINT_ERROR("Swept curves produce surfaces that cannot be stitched together.\n"); - for( i=FACES_for_cutting.size(); i--; ) - api_delent( FACES_for_cutting.get_and_step() ); - return CUBIT_FAILURE; - } - } - else - tool_BODY = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACES_for_cutting.get() ); - - //get rid of any unnecessary edges - api_clean_entity( (ENTITY*)tool_BODY); - - //webcut each blank BODY with the tool BODY - int num_cut=0; - DLIList<BodySM*> temp_new_bodies; - for ( i = blank_bodies.size(); i > 0; i-- ) - { - BodySM *blank_body = blank_bodies.get_and_step(); - BODY *blank_BODY = AcisQueryEngine::get_BODY(blank_body ); - BODY *new_BODY_1, *new_BODY_2; - - CubitStatus status = webcut_with_sheet( blank_BODY, - tool_BODY, - new_BODY_1, - new_BODY_2, - imprint ); - if ( status == CUBIT_SUCCESS ) - { - DLIList<BODY*> new_BODY_list; - new_BODY_list.append(new_BODY_1); - new_BODY_list.append(new_BODY_2); - temp_new_bodies.clean_out(); - - CubitStatus result = get_new_Body(blank_body, blank_BODY, - new_BODY_list, temp_new_bodies, - CUBIT_FALSE); - if ( result != CUBIT_SUCCESS ) - { - PRINT_ERROR("Problems with building volume.\n"); - num_cut = 0; - return CUBIT_FAILURE; - } - else - { - results_list += temp_new_bodies; - num_cut++; - } - } - } - - return num_cut > 0 ? CUBIT_SUCCESS : CUBIT_FAILURE; -} - - -CubitStatus AcisModifyEngine::webcut_with_sweep_surfaces( - DLIList<BodySM*> &blank_bodies, - DLIList<Surface*> &surfaces, - const CubitVector& sweep_vector, - bool sweep_perp, - bool through_all, - bool outward, - bool up_to_next, - Surface *stop_surf, - Curve *curve_to_sweep_along, - DLIList<BodySM*> &results_list, - CubitBoolean imprint ) -{ - FACE *FACE_to_sweep = NULL; - SurfaceACIS *surf_ACIS = NULL; - - CubitVector tmp_sweep_vector = sweep_vector; - - int i,j; - DLIList<FACE*> FACES_to_sweep; - - //if multiple FACEs stitch, them together into one BODY, - //they may not stitch into on single FACE... a sheet-body - //with multiple FACEs will still webcut though - if( surfaces.size() > 1 ) - { - DLIList<FACE*> faces; - for(i=surfaces.size(); i--;) - { - SurfaceACIS *surf_ACIS = CAST_TO(surfaces.get_and_step(), SurfaceACIS ); - faces.append( surf_ACIS->get_FACE_ptr() ); - } - - //attempt to stitch FACEs together, to get a single FACE - BODY *dummy_BODY = NULL; - CubitStatus status; - status = stitch_FACEs( faces, FACE_to_sweep, dummy_BODY ); - - if( status == CUBIT_FAILURE ) - { - PRINT_ERROR("Input surfaces could not be stitched together.\n"); - PRINT_INFO(" Input surfaces must share coinsident curves to be stitchable.\n"); - return CUBIT_FAILURE; - } - else if( !FACE_to_sweep ) - { - //can't stitch surfaces into single FACE, so we'll sweep them separately - if( dummy_BODY ) api_delent( dummy_BODY ); - for(i=surfaces.size(); i--;) - { - surf_ACIS = CAST_TO(surfaces.get_and_step(), SurfaceACIS ); - FACE_to_sweep = make_FACE( surf_ACIS->get_FACE_ptr() ); - FACES_to_sweep.append( FACE_to_sweep ); - } - } - else - FACES_to_sweep.append( FACE_to_sweep ); - } - else //if only 1 surface - { - Surface *surface = surfaces.get(); - surf_ACIS = CAST_TO(surface, SurfaceACIS ); - FACE_to_sweep = make_FACE( surf_ACIS->get_FACE_ptr() ); - FACES_to_sweep.append( FACE_to_sweep ); - } - - FACE *stop_FACE= NULL; - if( sweep_perp == true ) - { - //if( !stop_surf ) - // tmp_sweep_vector.set( sweep_vector.x(),0,0); - if( through_all || stop_surf ) - { - CubitBox bounding_box = GeometryQueryTool::instance()->model_bounding_box(); - tmp_sweep_vector.set(1,0,0); - tmp_sweep_vector = 2*(bounding_box.diagonal()); - } - } - else if( through_all || stop_surf || up_to_next ) - { - CubitBox bounding_box = GeometryQueryTool::instance()->model_bounding_box(); - tmp_sweep_vector.normalize(); - tmp_sweep_vector*=(2*bounding_box.diagonal().length()); - } - - //see if surface-where-sweep-is-to-stop has been specified - if( stop_surf ) - { - //get the SURFACE - SurfaceACIS *surf_ACIS = CAST_TO(stop_surf, SurfaceACIS ); - stop_FACE = surf_ACIS->get_FACE_ptr(); - } - - //see if we're sweeping along a specified curve - BODY* WIRE_ptr = NULL; - if( curve_to_sweep_along ) - { - CurveACIS *curve_ACIS = CAST_TO(curve_to_sweep_along, CurveACIS); - EDGE *EDGE_ptr = curve_ACIS->get_EDGE_ptr(); - - if (!EDGE_ptr) - { - PRINT_ERROR("Unable to get ACIS EDGE from Curve\n" ); - for( j=FACES_to_sweep.size(); j--; ) - api_delent( FACES_to_sweep.get_and_step() ); - return CUBIT_FAILURE; - } - - EDGE *EDGE_to_sweep_along = NULL; - outcome result = api_edge( EDGE_ptr, EDGE_to_sweep_along ); - if (!result.ok() || EDGE_to_sweep_along == NULL ) - { - AcisQueryEngine::instance()->ACIS_API_error (result); - PRINT_ERROR( "Unable to copy ACIS curve\n" ); - for( j=FACES_to_sweep.size(); j--; ) - api_delent( FACES_to_sweep.get_and_step() ); - return CUBIT_FAILURE; - } - - EDGE* EDGES[1]; - EDGES[0] = EDGE_to_sweep_along; - result = api_make_ewire( 1, EDGES, WIRE_ptr); - if (!result.ok()) - { - AcisQueryEngine::instance()->ACIS_API_error (result); - PRINT_ERROR( "Unable to make ACIS wire body from curve to sweep along\n" ); - for( j=FACES_to_sweep.size(); j--; ) - api_delent( FACES_to_sweep.get_and_step() ); - return CUBIT_FAILURE; - } - } - - bool volume_neg; - CubitStatus status; - - //sweep each surface - DLIList<BODY*> swept_BODYs; - for( i=FACES_to_sweep.size(); i--; ) - { - FACE_to_sweep = FACES_to_sweep.get_and_step(); - - if( sweep_perp ) - status = sweep_FACE_perpendicular( FACE_to_sweep, tmp_sweep_vector.length(), volume_neg, - outward, 0.0, 0, false, stop_FACE ); - else if( WIRE_ptr ) - status = sweep_FACE_along_WIRE( FACE_to_sweep, WIRE_ptr, 0.0, 0, false, stop_FACE ); - else - status = sweep_FACE_along_vector( FACE_to_sweep, tmp_sweep_vector, volume_neg, true, 0.0, 0, - false, stop_FACE ); - - if( status == CUBIT_FAILURE ) - { - api_delent( FACE_to_sweep ); - for(i=swept_BODYs.size(); i--;) - api_delent( swept_BODYs.get_and_step() ); - if( WIRE_ptr ) - api_delent( WIRE_ptr ); - return CUBIT_FAILURE; - } - BODY *swept_BODY = AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_to_sweep); - swept_BODYs.append( swept_BODY ); - } - - //clean up - if( WIRE_ptr ) - api_delent( WIRE_ptr ); - - //if there are more than 1, unite them all - swept_BODYs.reset(); - BODY *tool_BODY = swept_BODYs.extract(); - if( swept_BODYs.size() > 0 ) - { - for(i=swept_BODYs.size(); i--;) - { - outcome result = api_unite( swept_BODYs.get(), tool_BODY ); - if( !result.ok() ) - { - PRINT_ERROR( "Problems uniting swept surfaces for webcut\n" ); - AcisQueryEngine::instance()->ACIS_API_error (result); - api_delent( tool_BODY ); - for(i=swept_BODYs.size(); i--; ) - { - if( swept_BODYs.get() ) - api_delent( swept_BODYs.get_and_step() ); - } - return CUBIT_FAILURE; - } - else - swept_BODYs.change_to(NULL); - swept_BODYs.step(); - } - } - - //remove unnecessary edges - api_clean_entity( (ENTITY*)tool_BODY); - - //trim tool_body if 'up_to_next_surface' option is specified - if( up_to_next) - { - //get a vertex on the original face that we're sweeping - ENTITY_LIST vertices; - api_get_vertices( surf_ACIS->get_FACE_ptr(), vertices ); - - VERTEX *surf_VERT = NULL; - if( vertices.count() ) - surf_VERT = static_cast<VERTEX*>( vertices[0] ); - - if( !trim_up_to_next_surface( tool_BODY, blank_bodies, surf_VERT ) ) - { - api_delent( tool_BODY ); - PRINT_ERROR("Cannot use 'up_to_next' option with specified geometry\n"); - PRINT_INFO("Try the 'stop surface <id>' option instead\n"); - return CUBIT_FAILURE; - } - } - - return webcut( blank_bodies, tool_BODY, results_list, imprint); - -} - CubitStatus AcisModifyEngine::trim_up_to_next_surface( BODY *&tool_BODY, DLIList<BodySM*> &blank_bodies, VERTEX *surf_VERT ) @@ -2744,17 +2068,17 @@ int i; for( i=blank_bodies.size()-1; i--; ) - { - blank_BODY = AcisQueryEngine::get_BODY( blank_bodies.get_and_step() ); - BODY *copy_blank_BODY = this->copy_BODY(blank_BODY, true ); - result = api_unite( copy_blank_BODY, master_blank_BODY); - - if( !result.ok() ) { - PRINT_ERROR("Problems uniting blank volumes with 'up_to_next' option.\n"); - return CUBIT_FAILURE; + blank_BODY = AcisQueryEngine::get_BODY( blank_bodies.get_and_step() ); + BODY *copy_blank_BODY = this->copy_BODY(blank_BODY, true ); + result = api_unite( copy_blank_BODY, master_blank_BODY); + + if( !result.ok() ) + { + PRINT_ERROR("Problems uniting blank volumes with 'up_to_next' option.\n"); + return CUBIT_FAILURE; + } } - } //get all the cells generic_graph *boolean_graph; @@ -2765,10 +2089,10 @@ gvertex **vertex_array = boolean_graph->get_vertices( num_verts ); ENTITY_LIST common_vertices; for(i=num_verts; i--; ) - { - if( vertex_array[i]->is_kind(0) && vertex_array[i]->is_kind(1) ) - common_vertices.add( vertex_array[i]->get_entity() ); - } + { + if( vertex_array[i]->is_kind(0) && vertex_array[i]->is_kind(1) ) + common_vertices.add( vertex_array[i]->get_entity() ); + } ENTITY *vertex_to_keep = NULL; @@ -2776,35 +2100,35 @@ if( common_vertices.count() == 1 ) vertex_to_keep = common_vertices[0]; else - { - SPAposition point_on_surf = surf_VERT->geometry()->coords(); - SPAposition dummy_pos; - double min_distance = -1, tmp_distance = 0; - for( i=common_vertices.count(); i--; ) { - if( is_CELL( common_vertices[i] ) ) - { - CELL *tmp_cell = NULL; - tmp_cell = static_cast<CELL*>( common_vertices[i] ); - BODY *tmp_body = NULL; - api_ct_copy_cell( tmp_cell, tmp_body ); + SPAposition point_on_surf = surf_VERT->geometry()->coords(); + SPAposition dummy_pos; + double min_distance = -1, tmp_distance = 0; + for( i=common_vertices.count(); i--; ) + { + if( is_CELL( common_vertices[i] ) ) + { + CELL *tmp_cell = NULL; + tmp_cell = static_cast<CELL*>( common_vertices[i] ); + BODY *tmp_body = NULL; + api_ct_copy_cell( tmp_cell, tmp_body ); - api_entity_point_distance( tmp_body, point_on_surf, dummy_pos, tmp_distance ); - api_delent( tmp_body ); + api_entity_point_distance( tmp_body, point_on_surf, dummy_pos, tmp_distance ); + api_delent( tmp_body ); - if( min_distance < 0 ) - { - min_distance = tmp_distance; - vertex_to_keep = common_vertices[i]; - } - else if( tmp_distance < min_distance ) - { - min_distance = tmp_distance; - vertex_to_keep = common_vertices[i]; - } - } + if( min_distance < 0 ) + { + min_distance = tmp_distance; + vertex_to_keep = common_vertices[i]; + } + else if( tmp_distance < min_distance ) + { + min_distance = tmp_distance; + vertex_to_keep = common_vertices[i]; + } + } + } } - } ENTITY_LIST ent_list; if( vertex_to_keep ) @@ -2833,472 +2157,512 @@ // Creation Date : //------------------------------------------------------------------------- CubitStatus AcisModifyEngine::sweep_FACE_along_vector( - FACE *& FACE_ptr, - const CubitVector& sweep_vector, - bool& volume_is_negative, - bool primary_side, - double draft_angle, - int draft_type, - bool rigid, - FACE *to_FACE) const + FACE *& FACE_ptr, + const CubitVector& sweep_vector, + bool& volume_is_negative, + bool primary_side, + double draft_angle, + int draft_type, + bool rigid, + FACE *to_FACE, + BODY *to_BODY) const { - // Make sure the distance of the sweep is not zero - if ( sweep_vector.length() < (1.0E5 * CUBIT_DBL_MIN) ) - { + // Make sure the distance of the sweep is not zero + if ( sweep_vector.length() < (1.0E5 * CUBIT_DBL_MIN) ) + { PRINT_WARNING("Distance of sweep is almost zero. No sweep was performed.\n"); return CUBIT_FAILURE; - } + } - // Make sure the draft angle is reasonable - if (draft_angle >= CUBIT_PI/2.0 || draft_angle <= -(CUBIT_PI/2.0)) - { + // Make sure the draft angle is reasonable + if (draft_angle >= CUBIT_PI/2.0 || draft_angle <= -(CUBIT_PI/2.0)) + { PRINT_ERROR("Draft angle cannot be greater than %e radians\n", CUBIT_PI/2.0); return CUBIT_FAILURE; - } + } - // Make sure the draft type is either 0 or 1 (this is an ACISism, of course!) - if ( !(draft_type == 0 || draft_type == 1) ) - { + // Make sure the draft type is either 0 or 1 (this is an ACISism, of course!) + if ( !(draft_type == 0 || draft_type == 1) ) + { PRINT_ERROR("Draft type must be either 0 or 1\n"); return CUBIT_FAILURE; - } + } - // Sweep ho!! - CubitStatus sweep_status = CUBIT_SUCCESS; - SPAvector ACIS_sweep_vector; - ACIS_sweep_vector.set_x(sweep_vector.x()); - ACIS_sweep_vector.set_y(sweep_vector.y()); - ACIS_sweep_vector.set_z(sweep_vector.z()); + // Sweep ho!! + CubitStatus sweep_status = CUBIT_SUCCESS; + SPAvector ACIS_sweep_vector; + ACIS_sweep_vector.set_x(sweep_vector.x()); + ACIS_sweep_vector.set_y(sweep_vector.y()); + ACIS_sweep_vector.set_z(sweep_vector.z()); - logical ACIS_primary_side = CUBIT_TRUE; - if (!primary_side) - ACIS_primary_side = CUBIT_FALSE; + logical ACIS_primary_side = CUBIT_TRUE; + if (!primary_side) + ACIS_primary_side = CUBIT_FALSE; - // Turn off the merge option in ACIS so FACEs used to sweep won't be - // "simplified" in their topology (i.e., 5-sided squared faces won't - // be reduced to 4-sided square faces) -- in other words, turn on - // non-regularized booleans. - outcome result = api_set_int_option ( "merge", - CUBIT_FALSE ); - if (!result.ok()) - { + // Turn off the merge option in ACIS so FACEs used to sweep won't be + // "simplified" in their topology (i.e., 5-sided squared faces won't + // be reduced to 4-sided square faces) -- in other words, turn on + // non-regularized booleans. + outcome result = api_set_int_option ( "merge", + CUBIT_FALSE ); + if (!result.ok()) + { PRINT_WARNING("In AcisModifyEngine::sweep_FACE_along_vector.\n" " Error in api_set_int_option.\n"); AcisQueryEngine::instance()->ACIS_API_error(result); - // As the problem is not really serious, continue and make sure that - // the value of result is set to "OK" so no rollback occurs + // As the problem is not really serious, continue and make sure that + // the value of result is set to "OK" so no rollback occurs result = outcome(0); - } + } - sweep_options ACIS_sweep_options; - ACIS_sweep_options.set_draft_angle(draft_angle); - ACIS_sweep_options.set_gap_type(draft_type); - ACIS_sweep_options.set_which_side(ACIS_primary_side); - ACIS_sweep_options.set_rigid(rigid); + sweep_options ACIS_sweep_options; + ACIS_sweep_options.set_draft_angle(draft_angle); + ACIS_sweep_options.set_gap_type(draft_type); + ACIS_sweep_options.set_which_side(ACIS_primary_side); + ACIS_sweep_options.set_rigid(rigid); + + FACE *FACE_to_sweep_to = NULL; + if( to_FACE ) + { + //get face type + SURFACE *SURFACE_ptr = to_FACE->geometry(); + int type = SURFACE_ptr->identity(); - FACE *FACE_to_sweep_to = NULL; - if( to_FACE ) - { - //get face type - SURFACE *SURFACE_ptr = to_FACE->geometry(); - int type = SURFACE_ptr->identity(); + //if face is planar...vector must not be parallel to surf normal + if (type == PLANE_TYPE) + { + FACE_to_sweep_to = make_FACE( to_FACE, true ); + } + //vector must intersect surf + else + { + FACE_to_sweep_to = make_FACE( to_FACE ); + } - //if face is planar...vector must not be parallel to surf normal - if (type == PLANE_TYPE) - { - FACE_to_sweep_to = make_FACE( to_FACE, true ); - } - //vector must intersect surf - else - { - FACE_to_sweep_to = make_FACE( to_FACE ); - } + SPAtransf trans = get_face_trans(FACE_to_sweep_to); + surface *eq_surf = FACE_to_sweep_to->geometry()->trans_surface(trans ); + ACIS_sweep_options.set_to_face( eq_surf ); + } - SPAtransf trans = get_face_trans(FACE_to_sweep_to); - surface *eq_surf = FACE_to_sweep_to->geometry()->trans_surface(trans ); - ACIS_sweep_options.set_to_face( eq_surf ); - } + else if(to_BODY) + { + ACIS_sweep_options.set_sweep_to_body(to_BODY); + //Creates one body out of the fixed body and the result of the sweep up + //to the location of the intersection between the sweep and the fixed + //body. + ACIS_sweep_options.set_bool_type(INTERSECT); + } + BODY* BODYptr = NULL; + result = api_sweep_with_options (FACE_ptr, ACIS_sweep_vector, + &ACIS_sweep_options, BODYptr); - BODY* BODYptr = NULL; - result = api_sweep_with_options (FACE_ptr, ACIS_sweep_vector, - &ACIS_sweep_options, BODYptr); + if (BODYptr) + { + //when setting the sweep to end at a face, result is BODYptr. + if( to_FACE || to_BODY) + { + //swept body & to_FACE must intersect some + BODY *tmp_body = NULL; + if(to_FACE) + tmp_body = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_to_sweep_to ); + else + tmp_body = to_BODY; + if ( !BODYs_interfering( tmp_body, BODYptr ) ) + { + PRINT_ERROR("Terminating surface must intersect swept tool volume.\n"); + if (to_FACE) + api_delent( tmp_body ); + return CUBIT_FAILURE; + } + FACE_ptr = BODYptr->lump()->shell()->first_face(); + } + + else + { + PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options\n"); + PRINT_ERROR("API wants to create a new volume.\n"); + api_delent( BODYptr ); + sweep_status = CUBIT_FAILURE; + } + } - if (BODYptr) - { - //when setting the sweep to end at a face, result is BODYptr. - if( to_FACE ) - { - //swept body & to_FACE must intersect some - BODY *tmp_body = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_to_sweep_to ); - if ( !BODYs_interfering( tmp_body, BODYptr ) ) - { - PRINT_ERROR("Terminating surface must intersect swept tool volume.\n"); - api_delent( tmp_body ); - return CUBIT_FAILURE; - } - FACE_ptr = BODYptr->lump()->shell()->first_face(); - } - else - { - PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options\n"); - PRINT_ERROR("API wants to create a new volume.\n"); - api_delent( BODYptr ); - sweep_status = CUBIT_FAILURE; - } - } - - if (!result.ok()) - { - if(rigid) + if (!result.ok()) + { + if(rigid) PRINT_WARNING("Because surface is not planar, the 'rigid' keyword will be ignored.\n"); - PRINT_DEBUG_99("api_sweep_with_options failed, reverting to api_sw_face_vec.\n"); + PRINT_DEBUG_99("api_sweep_with_options failed, reverting to api_sw_face_vec.\n"); - result = api_sw_face_vec (FACE_ptr, ACIS_primary_side, ACIS_sweep_vector, - draft_angle, draft_type); + result = api_sw_face_vec (FACE_ptr, ACIS_primary_side, ACIS_sweep_vector, + draft_angle, draft_type); - if (!result.ok()) - { + if (!result.ok()) + { - PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options\n"); - PRINT_INFO("in sweep_FACE_along_vector\n"); - AcisQueryEngine::instance()->ACIS_API_error(result); - sweep_status = CUBIT_FAILURE; - } - } + PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options\n"); + PRINT_INFO("in sweep_FACE_along_vector\n"); + AcisQueryEngine::instance()->ACIS_API_error(result); + sweep_status = CUBIT_FAILURE; + } + } - if( FACE_to_sweep_to ) - api_delent( FACE_to_sweep_to ); + if( FACE_to_sweep_to ) + api_delent( FACE_to_sweep_to ); - if (!result.ok()) - { - PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options\n"); - PRINT_INFO("in sweep_FACE_along_vector\n"); - AcisQueryEngine::instance()->ACIS_API_error(result); - sweep_status = CUBIT_FAILURE; - } + if (!result.ok()) + { + PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options\n"); + PRINT_INFO("in sweep_FACE_along_vector\n"); + AcisQueryEngine::instance()->ACIS_API_error(result); + sweep_status = CUBIT_FAILURE; + } - // Now set the option back to its default - result = api_set_int_option ( "merge", - CUBIT_TRUE ); - if (!result.ok()) - { + // Now set the option back to its default + result = api_set_int_option ( "merge", + CUBIT_TRUE ); + if (!result.ok()) + { PRINT_WARNING("In AcisModifyEngine::sweep_FACE_along_vector.\n" " Error in api_set_int_option.\n"); AcisQueryEngine::instance()->ACIS_API_error(result); - // As the problem is not really serious, continue and make sure that - // the value of result is set to "OK" so no rollback occurs + // As the problem is not really serious, continue and make sure that + // the value of result is set to "OK" so no rollback occurs result = outcome(0); - } + } - // Finally, check to make sure that the volume of the swept BODY is positive. - // Note that ACIS allows the creation of swept solids that have - // negative volume (all the surface normals point inward -- i.e., - // the swept solid is topologically identical to a void) - if ( AcisQueryEngine::instance()->volume(AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr)) < 0.0) - { + // Finally, check to make sure that the volume of the swept BODY is positive. + // Note that ACIS allows the creation of swept solids that have + // negative volume (all the surface normals point inward -- i.e., + // the swept solid is topologically identical to a void) + if ( AcisQueryEngine::instance()->volume(AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr)) < 0.0) + { sweep_status = CUBIT_FAILURE; volume_is_negative = true; - // Set the value of result such that the API_END macro performs - // a bulletin board rollback operation to the corresponding API_BEGIN - //result = outcome(API_FAILED); - } + // Set the value of result such that the API_END macro performs + // a bulletin board rollback operation to the corresponding API_BEGIN + //result = outcome(API_FAILED); + } - return sweep_status; + return sweep_status; } CubitStatus AcisModifyEngine::sweep_FACE_perpendicular( - FACE *& FACE_ptr, - double distance, - bool& volume_is_negative, - bool primary_side, - double draft_angle, - int draft_type, - bool rigid, - FACE *to_FACE) const + FACE *& FACE_ptr, + double distance, + bool& volume_is_negative, + bool primary_side, + double draft_angle, + int draft_type, + bool rigid, + FACE *to_FACE, + BODY *to_BODY) const { - // Make sure the distance of the sweep is not zero - if ( distance < (1.0E5 * CUBIT_DBL_MIN) ) - { + // Make sure the distance of the sweep is not zero + if ( distance < (1.0E5 * CUBIT_DBL_MIN) ) + { PRINT_WARNING("Distance of sweep is almost zero. No sweep was performed.\n"); return CUBIT_FAILURE; - } + } - // Make sure the draft angle is reasonable - if (draft_angle >= CUBIT_PI/2.0 || draft_angle <= -(CUBIT_PI/2.0)) - { + // Make sure the draft angle is reasonable + if (draft_angle >= CUBIT_PI/2.0 || draft_angle <= -(CUBIT_PI/2.0)) + { PRINT_ERROR("Draft angle cannot be greater than %e radians\n", CUBIT_PI/2.0); return CUBIT_FAILURE; - } + } - // Make sure the draft type is either 0 or 1 (this is an ACISism, of course!) - if ( !(draft_type == 0 || draft_type == 1) ) - { + // Make sure the draft type is either 0 or 1 (this is an ACISism, of course!) + if ( !(draft_type == 0 || draft_type == 1) ) + { PRINT_ERROR("Draft type must be either 0 or 1\n"); return CUBIT_FAILURE; - } + } - // Sweep ho!! - CubitStatus sweep_status = CUBIT_SUCCESS; + // Sweep ho!! + CubitStatus sweep_status = CUBIT_SUCCESS; - logical ACIS_primary_side = CUBIT_FALSE; - if (!primary_side) - ACIS_primary_side = CUBIT_TRUE; + logical ACIS_primary_side = CUBIT_FALSE; + if (!primary_side) + ACIS_primary_side = CUBIT_TRUE; - // Turn off the merge option in ACIS so FACEs used to sweep won't be - // "simplified" in their topology (i.e., 5-sided squared faces won't - // be reduced to 4-sided square faces) -- in other words, turn on - // non-regularized booleans. - outcome result = api_set_int_option ( "merge", - CUBIT_FALSE ); - if (!result.ok()) - { + // Turn off the merge option in ACIS so FACEs used to sweep won't be + // "simplified" in their topology (i.e., 5-sided squared faces won't + // be reduced to 4-sided square faces) -- in other words, turn on + // non-regularized booleans. + outcome result = api_set_int_option ( "merge", + CUBIT_FALSE ); + if (!result.ok()) + { PRINT_WARNING("In AcisModifyEngine::sweep_FACE_perpendicular.\n" " Error in api_set_int_option.\n"); AcisQueryEngine::instance()->ACIS_API_error(result); - // As the problem is not really serious, continue and make sure that - // the value of result is set to "OK" so no rollback occurs + // As the problem is not really serious, continue and make sure that + // the value of result is set to "OK" so no rollback occurs result = outcome(0); - } + } - sweep_options ACIS_sweep_options; - ACIS_sweep_options.set_draft_angle(draft_angle); - ACIS_sweep_options.set_gap_type(draft_type); - ACIS_sweep_options.set_which_side(ACIS_primary_side); - ACIS_sweep_options.set_rigid(rigid); + sweep_options ACIS_sweep_options; + ACIS_sweep_options.set_draft_angle(draft_angle); + ACIS_sweep_options.set_gap_type(draft_type); + ACIS_sweep_options.set_which_side(ACIS_primary_side); + ACIS_sweep_options.set_rigid(rigid); - FACE *FACE_to_sweep_to = NULL; - if( to_FACE ) - { - //get face type - SURFACE *SURFACE_ptr = to_FACE->geometry(); - int type = SURFACE_ptr->identity(); + FACE *FACE_to_sweep_to = NULL; + if( to_FACE )//mutually exclusive with sweep_to_body + { + //get face type + SURFACE *SURFACE_ptr = to_FACE->geometry(); + int type = SURFACE_ptr->identity(); - //if face is planar...vector must not be parallel to surf normal - if (type == PLANE_TYPE) - { - FACE_to_sweep_to = make_FACE( to_FACE, true ); - } - //vector must intersect surf - else - { - FACE_to_sweep_to = make_FACE( to_FACE ); - } + //if face is planar...vector must not be parallel to surf normal + if (type == PLANE_TYPE) + { + FACE_to_sweep_to = make_FACE( to_FACE, true ); + } + //vector must intersect surf + else + { + FACE_to_sweep_to = make_FACE( to_FACE ); + } - SPAtransf trans = get_face_trans(FACE_to_sweep_to); - surface *eq_surf = FACE_to_sweep_to->geometry()->trans_surface(trans ); - ACIS_sweep_options.set_to_face( eq_surf ); - } + SPAtransf trans = get_face_trans(FACE_to_sweep_to); + surface *eq_surf = FACE_to_sweep_to->geometry()->trans_surface(trans ); + ACIS_sweep_options.set_to_face( eq_surf ); + } - BODY* BODYptr = NULL; - result = api_sweep_with_options (FACE_ptr, distance, - &ACIS_sweep_options, BODYptr); + else if(to_BODY)//mutually exclusive with to_face + { + ACIS_sweep_options.set_sweep_to_body(to_BODY); + //Creates one body out of the fixed body and the result of the sweep up + //to the location of the intersection between the sweep and the fixed + //body. + ACIS_sweep_options.set_bool_type(INTERSECT); + } - if (BODYptr) - { - //when setting the sweep to end at a face, result is BODYptr. - if( to_FACE) - { - //swept body & to_FACE must intersect some - BODY *tmp_body = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_to_sweep_to ); - if ( !BODYs_interfering( tmp_body, BODYptr ) ) - { - PRINT_ERROR("Terminating surface must intersect swept tool volume.\n"); - api_delent( tmp_body ); - return CUBIT_FAILURE; - } - FACE_ptr = BODYptr->lump()->shell()->first_face(); - } - else - { - PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options\n"); - PRINT_ERROR("API wants to create a new volume \n"); - api_delent( BODYptr ); - sweep_status = CUBIT_FAILURE; - } - } + BODY* BODYptr = NULL; + result = api_sweep_with_options (FACE_ptr, distance, + &ACIS_sweep_options, BODYptr); - if( FACE_to_sweep_to ) - api_delent( FACE_to_sweep_to ); + if (BODYptr) + { + //when setting the sweep to end at a face, result is BODYptr. + if( to_FACE || to_BODY) + { + BODY *tmp_body = NULL; + //swept body & to_FACE must intersect some + if(to_FACE) + tmp_body = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_to_sweep_to ); + else + tmp_body = to_BODY; + if ( !BODYs_interfering( tmp_body, BODYptr ) ) + { + PRINT_ERROR("Terminating surface must intersect swept tool volume.\n"); + if(to_FACE) + api_delent( tmp_body ); + return CUBIT_FAILURE; + } + FACE_ptr = BODYptr->lump()->shell()->first_face(); + } + else + { + PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options\n"); + PRINT_ERROR("API wants to create a new volume \n"); + api_delent( BODYptr ); + sweep_status = CUBIT_FAILURE; + } + } - if (!result.ok()) - { + if( FACE_to_sweep_to ) + api_delent( FACE_to_sweep_to ); + + if (!result.ok()) + { PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options \n"); PRINT_INFO("in sweep_FACE_perpendicular\n"); PRINT_INFO("If face is not planar, perpendicular doesn't make sense.\n" "Try sweeping along a vector instead.\n"); AcisQueryEngine::instance()->ACIS_API_error(result); sweep_status = CUBIT_FAILURE; - } + } - // Now set the option back to its default - result = api_set_int_option ( "merge", - CUBIT_TRUE ); - if (!result.ok()) - { + // Now set the option back to its default + result = api_set_int_option ( "merge", + CUBIT_TRUE ); + if (!result.ok()) + { PRINT_WARNING("In AcisModifyEngine::sweep_FACE_perpendicular.\n" " Error in api_set_int_option.\n"); AcisQueryEngine::instance()->ACIS_API_error(result); - // As the problem is not really serious, continue and make sure that - // the value of result is set to "OK" so no rollback occurs + // As the problem is not really serious, continue and make sure that + // the value of result is set to "OK" so no rollback occurs result = outcome(0); - } + } - // Finally, check to make sure that the volume of the swept BODY is positive. - // Note that ACIS allows the creation of swept solids that have - // negative volume (all the surface normals point inward -- i.e., - // the swept solid is topologically identical to a void) - if ( AcisQueryEngine::instance()->volume(AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr)) < 0.0) - { + // Finally, check to make sure that the volume of the swept BODY is positive. + // Note that ACIS allows the creation of swept solids that have + // negative volume (all the surface normals point inward -- i.e., + // the swept solid is topologically identical to a void) + if ( AcisQueryEngine::instance()->volume(AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr)) < 0.0) + { sweep_status = CUBIT_FAILURE; volume_is_negative = CUBIT_TRUE; - // Set the value of result such that the API_END macro performs - // a bulletin board rollback operation to the corresponding API_BEGIN - //result = outcome(API_FAILED); - } + // Set the value of result such that the API_END macro performs + // a bulletin board rollback operation to the corresponding API_BEGIN + //result = outcome(API_FAILED); + } - return sweep_status; + return sweep_status; } CubitStatus AcisModifyEngine::sweep_EDGE_along_vector( - EDGE* EDGE_ptr, - BODY *&BODYptr, - const CubitVector& sweep_vector, - double draft_angle, - int draft_type, - bool rigid, - FACE *to_FACE) const + EDGE* EDGE_ptr, + BODY *&BODYptr, + const CubitVector& sweep_vector, + double draft_angle, + int draft_type, + bool rigid, + FACE *to_FACE, + BODY *to_BODY) const { - // Make sure the distance of the sweep is not zero - if ( sweep_vector.length() < (1.0E5 * CUBIT_DBL_MIN) ) - { + // Make sure the distance of the sweep is not zero + if ( sweep_vector.length() < (1.0E5 * CUBIT_DBL_MIN) ) + { PRINT_WARNING("Distance of sweep is almost zero. No sweep was performed.\n"); return CUBIT_FAILURE; - } + } - // Make sure the draft angle is reasonable - if (draft_angle >= CUBIT_PI/2.0 || draft_angle <= -(CUBIT_PI/2.0)) - { + // Make sure the draft angle is reasonable + if (draft_angle >= CUBIT_PI/2.0 || draft_angle <= -(CUBIT_PI/2.0)) + { PRINT_ERROR("Draft angle cannot be greater than %e radians\n", CUBIT_PI/2.0); return CUBIT_FAILURE; - } + } - // Make sure the draft type is either 0 or 1 (this is an ACISism, of course!) - if ( !(draft_type == 0 || draft_type == 1) ) - { + // Make sure the draft type is either 0 or 1 (this is an ACISism, of course!) + if ( !(draft_type == 0 || draft_type == 1) ) + { PRINT_ERROR("Draft type must be either 0 or 1\n"); return CUBIT_FAILURE; - } + } - // Sweep ho!! - CubitStatus sweep_status = CUBIT_SUCCESS; - SPAvector ACIS_sweep_vector; - ACIS_sweep_vector.set_x(sweep_vector.x()); - ACIS_sweep_vector.set_y(sweep_vector.y()); - ACIS_sweep_vector.set_z(sweep_vector.z()); + // Sweep ho!! + CubitStatus sweep_status = CUBIT_SUCCESS; + SPAvector ACIS_sweep_vector; + ACIS_sweep_vector.set_x(sweep_vector.x()); + ACIS_sweep_vector.set_y(sweep_vector.y()); + ACIS_sweep_vector.set_z(sweep_vector.z()); - // Turn off the merge option in ACIS so EDGEs used to sweep won't be - // "simplified" in their topology (i.e., 5-sided squared faces won't - // be reduced to 4-sided square faces) -- in other words, turn on - // non-regularized booleans. - outcome result = api_set_int_option ( "merge", - CUBIT_FALSE ); - if (!result.ok()) - { + // Turn off the merge option in ACIS so EDGEs used to sweep won't be + // "simplified" in their topology (i.e., 5-sided squared faces won't + // be reduced to 4-sided square faces) -- in other words, turn on + // non-regularized booleans. + outcome result = api_set_int_option ( "merge", + CUBIT_FALSE ); + if (!result.ok()) + { PRINT_WARNING("In AcisModifyEngine::sweep_EDGE_along_vector.\n" " Error in api_set_int_option.\n"); AcisQueryEngine::instance()->ACIS_API_error(result); - // As the problem is not really serious, continue and make sure that - // the value of result is set to "OK" so no rollback occurs + // As the problem is not really serious, continue and make sure that + // the value of result is set to "OK" so no rollback occurs result = outcome(0); - } + } - sweep_options ACIS_sweep_options; - ACIS_sweep_options.set_draft_angle(draft_angle); - ACIS_sweep_options.set_gap_type(draft_type); - ACIS_sweep_options.set_rigid(rigid); - EDGE *copied_EDGE_ptr = NULL; - result = api_edge( EDGE_ptr, copied_EDGE_ptr); + sweep_options ACIS_sweep_options; + ACIS_sweep_options.set_draft_angle(draft_angle); + ACIS_sweep_options.set_gap_type(draft_type); + ACIS_sweep_options.set_rigid(rigid); + EDGE *copied_EDGE_ptr = NULL; + result = api_edge( EDGE_ptr, copied_EDGE_ptr); - FACE *FACE_to_sweep_to = NULL; - if( to_FACE ) - { - //get face type - SURFACE *SURFACE_ptr = to_FACE->geometry(); - int type = SURFACE_ptr->identity(); + FACE *FACE_to_sweep_to = NULL; + if( to_FACE )//mutually exclusive with sweep_to_body + { + //get face type + SURFACE *SURFACE_ptr = to_FACE->geometry(); + int type = SURFACE_ptr->identity(); - //if face is planar...vector must not be parallel to surf normal - if (type == PLANE_TYPE) - { - FACE_to_sweep_to = make_FACE( to_FACE, true ); - } - //vector must intersect surf - else - { - FACE_to_sweep_to = make_FACE( to_FACE ); - } + //if face is planar...vector must not be parallel to surf normal + if (type == PLANE_TYPE) + { + FACE_to_sweep_to = make_FACE( to_FACE, true ); + } + //vector must intersect surf + else + { + FACE_to_sweep_to = make_FACE( to_FACE ); + } - SPAtransf trans = get_face_trans(FACE_to_sweep_to); - surface *eq_surf = FACE_to_sweep_to->geometry()->trans_surface(trans ); - ACIS_sweep_options.set_to_face( eq_surf ); - } + SPAtransf trans = get_face_trans(FACE_to_sweep_to); + surface *eq_surf = FACE_to_sweep_to->geometry()->trans_surface(trans ); + ACIS_sweep_options.set_to_face( eq_surf ); + } - if( !result.ok() ) - { - PRINT_ERROR( "Unable to copy edge\n"); - return CUBIT_FAILURE; - } - ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr, - CUBIT_TRUE ); - result = api_sweep_with_options (copied_EDGE_ptr, ACIS_sweep_vector, - &ACIS_sweep_options, BODYptr); + else if(to_BODY)//mutually exclusive with to_face + { + ACIS_sweep_options.set_sweep_to_body(to_BODY); + //Creates one body out of the fixed body and the result of the sweep up + //to the location of the intersection between the sweep and the fixed + //body. + ACIS_sweep_options.set_bool_type(INTERSECT); + } - if (BODYptr) - { - sweep_status = CUBIT_SUCCESS; - } - if (!result.ok()) - { + if( !result.ok() ) + { + PRINT_ERROR( "Unable to copy edge\n"); + return CUBIT_FAILURE; + } + ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr, + CUBIT_TRUE ); + result = api_sweep_with_options (copied_EDGE_ptr, ACIS_sweep_vector, + &ACIS_sweep_options, BODYptr); + + if (BODYptr) + { + sweep_status = CUBIT_SUCCESS; + } + if (!result.ok()) + { PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options\n"); AcisQueryEngine::instance()->ACIS_API_error(result); if ( copied_EDGE_ptr != NULL ) api_delent(copied_EDGE_ptr); sweep_status = CUBIT_FAILURE; - } + } - // Now set the option back to its default - result = api_set_int_option ( "merge", - CUBIT_TRUE ); - if (!result.ok()) - { + // Now set the option back to its default + result = api_set_int_option ( "merge", + CUBIT_TRUE ); + if (!result.ok()) + { PRINT_WARNING("In AcisModifyEngine::sweep_EDGE_along_vector.\n" " Error in api_set_int_option.\n"); AcisQueryEngine::instance()->ACIS_API_error(result); - // As the problem is not really serious, continue and make sure that - // the value of result is set to "OK" so no rollback occurs + // As the problem is not really serious, continue and make sure that + // the value of result is set to "OK" so no rollback occurs result = outcome(0); - } + } - if( FACE_to_sweep_to ) - api_delent( FACE_to_sweep_to ); + if( FACE_to_sweep_to ) + api_delent( FACE_to_sweep_to ); - // Finally, check to make sure that the volume of the swept BODY is positive. - // Note that ACIS allows the creation of swept solids that have - // negative volume (all the surface normals point inward -- i.e., - // the swept solid is topologically identical to a void) + // Finally, check to make sure that the volume of the swept BODY is positive. + // Note that ACIS allows the creation of swept solids that have + // negative volume (all the surface normals point inward -- i.e., + // the swept solid is topologically identical to a void) - return sweep_status; + return sweep_status; } @@ -3313,269 +2677,295 @@ // Creation Date : 8/7/98 //------------------------------------------------------------------------- CubitStatus AcisModifyEngine::sweep_FACE_along_WIRE( - FACE *& FACE_ptr, - BODY* wire_BODY_ptr, - double draft_angle, - int draft_type, - bool rigid, - FACE *to_FACE ) const + FACE *& FACE_ptr, + BODY* wire_BODY_ptr, + double draft_angle, + int draft_type, + bool rigid, + FACE *to_FACE, + BODY *to_BODY ) const { - // Make sure the draft angle is reasonable - if (draft_angle >= CUBIT_PI/2.0 || draft_angle <= -(CUBIT_PI/2.0)) - { + // Make sure the draft angle is reasonable + if (draft_angle >= CUBIT_PI/2.0 || draft_angle <= -(CUBIT_PI/2.0)) + { PRINT_ERROR("Draft angle cannot be greater than %e radians\n", CUBIT_PI/2.0); return CUBIT_FAILURE; - } + } - CubitStatus sweep_status = CUBIT_SUCCESS; + CubitStatus sweep_status = CUBIT_SUCCESS; - sweep_options ACIS_sweep_options; + sweep_options ACIS_sweep_options; - // Turn off the merge option in ACIS so FACEs used to sweep won't be - // "simplified" in their topology (i.e., 5-sided squared faces won't - // be reduced to 4-sided square faces) -- in other words, turn on - // non-regularized booleans. - outcome result = api_set_int_option ( "merge", CUBIT_FALSE ); + // Turn off the merge option in ACIS so FACEs used to sweep won't be + // "simplified" in their topology (i.e., 5-sided squared faces won't + // be reduced to 4-sided square faces) -- in other words, turn on + // non-regularized booleans. + outcome result = api_set_int_option ( "merge", CUBIT_FALSE ); - if (!result.ok()) - { - PRINT_WARNING("In AcisModifyEngine::sweep_FACE_along_WIRE.\n" - " Error in api_set_int_option.\n"); - AcisQueryEngine::instance()->ACIS_API_error(result); + if (!result.ok()) + { + PRINT_WARNING("In AcisModifyEngine::sweep_FACE_along_WIRE.\n" + " Error in api_set_int_option.\n"); + AcisQueryEngine::instance()->ACIS_API_error(result); - // As the problem is not really serious, continue and make sure that - // the value of result is set to "OK" so no rollback occurs - result = outcome(0); - } + // As the problem is not really serious, continue and make sure that + // the value of result is set to "OK" so no rollback occurs + result = outcome(0); + } - ACIS_sweep_options.set_draft_angle(draft_angle); - ACIS_sweep_options.set_gap_type(draft_type); - ACIS_sweep_options.set_rigid(rigid); + ACIS_sweep_options.set_draft_angle(draft_angle); + ACIS_sweep_options.set_gap_type(draft_type); + ACIS_sweep_options.set_rigid(rigid); - FACE *FACE_to_sweep_to = NULL; - if( to_FACE ) - { - //get face type - SURFACE *SURFACE_ptr = to_FACE->geometry(); - int type = SURFACE_ptr->identity(); + FACE *FACE_to_sweep_to = NULL; + if( to_FACE )//mutually exclusive with sweep_to_body. + { + //get face type + SURFACE *SURFACE_ptr = to_FACE->geometry(); + int type = SURFACE_ptr->identity(); - //if face is planar...vector must not be parallel to surf normal - if (type == PLANE_TYPE) - { - FACE_to_sweep_to = make_FACE( to_FACE, true ); - } - //vector must intersect surf - else - { - FACE_to_sweep_to = make_FACE( to_FACE ); - } + //if face is planar...vector must not be parallel to surf normal + if (type == PLANE_TYPE) + { + FACE_to_sweep_to = make_FACE( to_FACE, true ); + } + //vector must intersect surf + else + { + FACE_to_sweep_to = make_FACE( to_FACE ); + } - SPAtransf trans = get_face_trans(FACE_to_sweep_to); - surface *eq_surf = FACE_to_sweep_to->geometry()->trans_surface(trans ); - ACIS_sweep_options.set_to_face( eq_surf ); - } + SPAtransf trans = get_face_trans(FACE_to_sweep_to); + surface *eq_surf = FACE_to_sweep_to->geometry()->trans_surface(trans ); + ACIS_sweep_options.set_to_face( eq_surf ); + } - // Do the real work!! - BODY* BODYptr = NULL; - result = api_sweep_with_options (FACE_ptr, (EDGE*)wire_BODY_ptr, &ACIS_sweep_options, BODYptr); + else if(to_BODY)//mutually exclusive with to_face + { + ACIS_sweep_options.set_sweep_to_body(to_BODY); + //Creates one body out of the fixed body and the result of the sweep up + //to the location of the intersection between the sweep and the fixed + //body. + ACIS_sweep_options.set_bool_type(INTERSECT); + } - if (BODYptr) - { - //when setting the sweep to end at a face, result is BODYptr. - if( to_FACE ) - { - //swept body & to_FACE must intersect some - BODY *tmp_body = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_to_sweep_to ); - if ( !BODYs_interfering( tmp_body, BODYptr ) ) - { - PRINT_ERROR("Terminating surface must intersect swept tool volume.\n"); - api_delent( tmp_body ); - return CUBIT_FAILURE; - } - FACE_ptr = BODYptr->lump()->shell()->first_face(); - } - else - { - PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options\n"); - PRINT_ERROR("API wants to create a new volume \n"); - api_delent( BODYptr ); - sweep_status = CUBIT_FAILURE; - } - } + // Do the real work!! + BODY* BODYptr = NULL; + result = api_sweep_with_options (FACE_ptr, (EDGE*)wire_BODY_ptr, &ACIS_sweep_options, BODYptr); - if( FACE_to_sweep_to ) - api_delent( FACE_to_sweep_to ); + if (BODYptr) + { + //when setting the sweep to end at a face, result is BODYptr. + if( to_FACE || to_BODY) + { + BODY *tmp_body = NULL; + //swept body & to_FACE must intersect some + if(to_FACE) + tmp_body = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_to_sweep_to ); + else + tmp_body = to_BODY; - if (!result.ok()) - { + if ( !BODYs_interfering( tmp_body, BODYptr ) ) + { + PRINT_ERROR("Terminating surface must intersect swept tool volume.\n"); + if(to_FACE) + api_delent( tmp_body ); + return CUBIT_FAILURE; + } + FACE_ptr = BODYptr->lump()->shell()->first_face(); + } + else + { + PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options\n"); + PRINT_ERROR("API wants to create a new volume \n"); + api_delent( BODYptr ); + sweep_status = CUBIT_FAILURE; + } + } + + if( FACE_to_sweep_to ) + api_delent( FACE_to_sweep_to ); + + if (!result.ok()) + { PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options\n"); AcisQueryEngine::instance()->ACIS_API_error(result); sweep_status = CUBIT_FAILURE; - } + } - // Now set the option back to its default - result = api_set_int_option ( "merge", CUBIT_TRUE ); - if (!result.ok()) - { + // Now set the option back to its default + result = api_set_int_option ( "merge", CUBIT_TRUE ); + if (!result.ok()) + { PRINT_WARNING("In AcisModifyEngine::sweep_FACE_along_WIRE.\n" " Error in api_set_int_option.\n"); AcisQueryEngine::instance()->ACIS_API_error(result); - // As the problem is not really serious, continue and make sure that - // the value of result is set to "OK" so no rollback occurs + // As the problem is not really serious, continue and make sure that + // the value of result is set to "OK" so no rollback occurs result = outcome(0); - } + } - return sweep_status; + return sweep_status; } CubitStatus AcisModifyEngine::sweep_EDGE_along_WIRE( - EDGE* EDGE_ptr, - BODY* wire_BODY_ptr, - BODY *&BODYptr, - double draft_angle, - int draft_type, - bool rigid, - FACE *to_FACE) const + EDGE* EDGE_ptr, + BODY* wire_BODY_ptr, + BODY *&BODYptr, + double draft_angle, + int draft_type, + bool rigid, + FACE *to_FACE, + BODY *to_BODY) const { - // Make sure the draft angle is reasonable - if (draft_angle >= CUBIT_PI/2.0 || draft_angle <= -(CUBIT_PI/2.0)) - { + // Make sure the draft angle is reasonable + if (draft_angle >= CUBIT_PI/2.0 || draft_angle <= -(CUBIT_PI/2.0)) + { PRINT_ERROR("Draft angle cannot be greater than %e radians\n", CUBIT_PI/2.0); return CUBIT_FAILURE; - } + } - CubitStatus sweep_status = CUBIT_SUCCESS; + CubitStatus sweep_status = CUBIT_SUCCESS; - sweep_options ACIS_sweep_options; + sweep_options ACIS_sweep_options; - // Turn off the merge option in ACIS so FACEs used to sweep won't be - // "simplified" in their topology (i.e., 5-sided squared faces won't - // be reduced to 4-sided square faces) -- in other words, turn on - // non-regularized booleans. - outcome result = api_set_int_option ( "merge", CUBIT_FALSE ); - if (!result.ok()) - { + // Turn off the merge option in ACIS so FACEs used to sweep won't be + // "simplified" in their topology (i.e., 5-sided squared faces won't + // be reduced to 4-sided square faces) -- in other words, turn on + // non-regularized booleans. + outcome result = api_set_int_option ( "merge", CUBIT_FALSE ); + if (!result.ok()) + { PRINT_WARNING("In AcisModifyEngine::sweep_EDGE_along_WIRE.\n" " Error in api_set_int_option.\n"); AcisQueryEngine::instance()->ACIS_API_error(result); - // As the problem is not really serious, continue and make sure that - // the value of result is set to "OK" so no rollback occurs + // As the problem is not really serious, continue and make sure that + // the value of result is set to "OK" so no rollback occurs result = outcome(0); - } + } - ACIS_sweep_options.set_draft_angle(draft_angle); - ACIS_sweep_options.set_gap_type(draft_type); - ACIS_sweep_options.set_rigid(rigid); - EDGE *copied_EDGE_ptr = NULL; - result = api_edge( EDGE_ptr, copied_EDGE_ptr ); - if( !result.ok() ) - { - PRINT_ERROR( "Unable to copy edge\n"); - return CUBIT_FAILURE; - } + ACIS_sweep_options.set_draft_angle(draft_angle); + ACIS_sweep_options.set_gap_type(draft_type); + ACIS_sweep_options.set_rigid(rigid); + EDGE *copied_EDGE_ptr = NULL; + result = api_edge( EDGE_ptr, copied_EDGE_ptr ); + if( !result.ok() ) + { + PRINT_ERROR( "Unable to copy edge\n"); + return CUBIT_FAILURE; + } - //if edge-to-sweep has start or end vertex coincident w/ - //end vertex on path wire, flip all edges in path wire - SPAposition end_coords; - get_wire_end_position(wire_BODY_ptr, end_coords); + //if edge-to-sweep has start or end vertex coincident w/ + //end vertex on path wire, flip all edges in path wire + SPAposition end_coords; + get_wire_end_position(wire_BODY_ptr, end_coords); - SPAposition tmp_coords = EDGE_ptr->start()->geometry()->coords(); - CubitVector start_coord( tmp_coords.x(), tmp_coords.y(), tmp_coords.z() ); + SPAposition tmp_coords = EDGE_ptr->start()->geometry()->coords(); + CubitVector start_coord( tmp_coords.x(), tmp_coords.y(), tmp_coords.z() ); - tmp_coords = EDGE_ptr->end()->geometry()->coords(); - CubitVector end_coord( tmp_coords.x(), tmp_coords.y(), tmp_coords.z() ); + tmp_coords = EDGE_ptr->end()->geometry()->coords(); + CubitVector end_coord( tmp_coords.x(), tmp_coords.y(), tmp_coords.z() ); - CubitVector wire_end_coord( end_coords.x(), end_coords.y(), end_coords.z() ); + CubitVector wire_end_coord( end_coords.x(), end_coords.y(), end_coords.z() ); - if ( (GeometryQueryTool::instance()->about_spatially_equal(start_coord, wire_end_coord, - GeometryQueryTool::get_geometry_factor())) || - (GeometryQueryTool::instance()->about_spatially_equal(end_coord, wire_end_coord, - GeometryQueryTool::get_geometry_factor())) ) - { - //reverse all edges in wire body - ENTITY_LIST EDGE_list; - api_get_edges( wire_BODY_ptr, EDGE_list ); + if ( (GeometryQueryTool::instance()->about_spatially_equal(start_coord, wire_end_coord, + GeometryQueryTool::get_geometry_factor())) || + (GeometryQueryTool::instance()->about_spatially_equal(end_coord, wire_end_coord, + GeometryQueryTool::get_geometry_factor())) ) + { + //reverse all edges in wire body + ENTITY_LIST EDGE_list; + api_get_edges( wire_BODY_ptr, EDGE_list ); - EDGE_list.init(); - ENTITY *tmp_ent = NULL; - while( (tmp_ent = EDGE_list.next()) != NULL ) - { - EDGE *tmp_edge = (EDGE*)tmp_ent; - VERTEX *old_start = tmp_edge->start(); - VERTEX *old_end = tmp_edge->end(); - tmp_edge->set_sense( tmp_edge->sense() == FORWARD ? REVERSED : FORWARD ); - tmp_edge->set_start( old_end ); - tmp_edge->set_end( old_start ); - } - } + EDGE_list.init(); + ENTITY *tmp_ent = NULL; + while( (tmp_ent = EDGE_list.next()) != NULL ) + { + EDGE *tmp_edge = (EDGE*)tmp_ent; + VERTEX *old_start = tmp_edge->start(); + VERTEX *old_end = tmp_edge->end(); + tmp_edge->set_sense( tmp_edge->sense() == FORWARD ? REVERSED : FORWARD ); + tmp_edge->set_start( old_end ); + tmp_edge->set_end( old_start ); + } + } - ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr, - CUBIT_TRUE ); + ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr, + CUBIT_TRUE ); - FACE *FACE_to_sweep_to = NULL; - if( to_FACE ) - { - //get face type - SURFACE *SURFACE_ptr = to_FACE->geometry(); - int type = SURFACE_ptr->identity(); + FACE *FACE_to_sweep_to = NULL; + if( to_FACE )//mutually exclusive with sweep_to_body + { + //get face type + SURFACE *SURFACE_ptr = to_FACE->geometry(); + int type = SURFACE_ptr->identity(); - //if face is planar...vector must not be parallel to surf normal - if (type == PLANE_TYPE) - { - FACE_to_sweep_to = make_FACE( to_FACE, true ); - } - //vector must intersect surf - else - { - FACE_to_sweep_to = make_FACE( to_FACE ); - } + //if face is planar...vector must not be parallel to surf normal + if (type == PLANE_TYPE) + { + FACE_to_sweep_to = make_FACE( to_FACE, true ); + } + //vector must intersect surf + else + { + FACE_to_sweep_to = make_FACE( to_FACE ); + } - SPAtransf trans = get_face_trans(FACE_to_sweep_to); - surface *eq_surf = FACE_to_sweep_to->geometry()->trans_surface(trans ); - ACIS_sweep_options.set_to_face( eq_surf ); - } + SPAtransf trans = get_face_trans(FACE_to_sweep_to); + surface *eq_surf = FACE_to_sweep_to->geometry()->trans_surface(trans ); + ACIS_sweep_options.set_to_face( eq_surf ); + } - // Do the real work!! - result = api_sweep_with_options (copied_EDGE_ptr, wire_BODY_ptr, &ACIS_sweep_options, BODYptr); + else if(to_BODY)//mutually exclusive with to_face + { + ACIS_sweep_options.set_sweep_to_body(to_BODY); + //Creates one body out of the fixed body and the result of the sweep up + //to the location of the intersection between the sweep and the fixed + //body. + ACIS_sweep_options.set_bool_type(INTERSECT); + } - if (BODYptr) - { + // Do the real work!! + result = api_sweep_with_options (copied_EDGE_ptr, wire_BODY_ptr, &ACIS_sweep_options, BODYptr); + + if (BODYptr) + { sweep_status = CUBIT_SUCCESS; - } + } - if (!result.ok()) - { + if (!result.ok()) + { PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options\n"); AcisQueryEngine::instance()->ACIS_API_error(result); if ( copied_EDGE_ptr != NULL ) api_delent(copied_EDGE_ptr); sweep_status = CUBIT_FAILURE; - } + } - if( FACE_to_sweep_to ) - api_delent( FACE_to_sweep_to ); + if( FACE_to_sweep_to ) + api_delent( FACE_to_sweep_to ); - // Now set the option back to its default - result = api_set_int_option ( "merge", CUBIT_TRUE ); - if (!result.ok()) - { + // Now set the option back to its default + result = api_set_int_option ( "merge", CUBIT_TRUE ); + if (!result.ok()) + { PRINT_WARNING("In AcisModifyEngine::sweep_EDGE_along_WIRE.\n" " Error in api_set_int_option.\n"); AcisQueryEngine::instance()->ACIS_API_error(result); - // As the problem is not really serious, continue and make sure that - // the value of result is set to "OK" so no rollback occurs + // As the problem is not really serious, continue and make sure that + // the value of result is set to "OK" so no rollback occurs result = outcome(0); - } + } - return sweep_status; + return sweep_status; } //------------------------------------------------------------------------- @@ -3591,363 +2981,387 @@ // Creation Date : //------------------------------------------------------------------------- CubitStatus AcisModifyEngine::sweep_FACE_about_axis( - FACE *&FACE_ptr, - const CubitVector& axis_unit_vector, - const CubitVector& point, - double angle, - bool &volume_is_negative, - bool primary_side, - int steps, - double draft_angle, - int draft_type, - bool rigid, - FACE *to_FACE ) const + FACE *&FACE_ptr, + const CubitVector& axis_unit_vector, + const CubitVector& point, + double angle, + bool &volume_is_negative, + bool primary_side, + int steps, + double draft_angle, + int draft_type, + bool rigid, + FACE *to_FACE, + BODY *to_BODY ) const { - // Sweep ho!! - CubitStatus sweep_status = CUBIT_SUCCESS; + // Sweep ho!! + CubitStatus sweep_status = CUBIT_SUCCESS; - // Convert the Cubit point and SPAvector into an ACIS point and SPAvector - // before calling the member function that calls the ACIS API - // function. - SPAunit_vector ACIS_axis_unit_vector( - axis_unit_vector.x(), - axis_unit_vector.y(), - axis_unit_vector.z() ); - SPAposition ACIS_point( point.x(), point.y(), point.z() ); - logical ACIS_primary_side = CUBIT_TRUE; - if (!primary_side) ACIS_primary_side = CUBIT_FALSE; + // Convert the Cubit point and SPAvector into an ACIS point and SPAvector + // before calling the member function that calls the ACIS API + // function. + SPAunit_vector ACIS_axis_unit_vector( + axis_unit_vector.x(), + axis_unit_vector.y(), + axis_unit_vector.z() ); + SPAposition ACIS_point( point.x(), point.y(), point.z() ); + logical ACIS_primary_side = CUBIT_TRUE; + if (!primary_side) ACIS_primary_side = CUBIT_FALSE; - // Make sure the distance of the sweep is not zero - if (angle == 0.0) - { + // Make sure the distance of the sweep is not zero + if (angle == 0.0) + { PRINT_ERROR("The angle of the sweep must be > 0.0. Nothing done.\n"); return CUBIT_FAILURE; - } + } - // Make sure the draft angle is reasonable - if (draft_angle >= CUBIT_PI/2.0 || draft_angle <= -(CUBIT_PI/2.0)) - { + // Make sure the draft angle is reasonable + if (draft_angle >= CUBIT_PI/2.0 || draft_angle <= -(CUBIT_PI/2.0)) + { PRINT_ERROR("Draft angle cannot be greater than %e radians\n", CUBIT_PI/2.0); return CUBIT_FAILURE; - } + } - // Make sure the draft type is either 0 or 1 (this is an ACISism, of course!) - if ( !(draft_type == 0 || draft_type == 1) ) - { + // Make sure the draft type is either 0 or 1 (this is an ACISism, of course!) + if ( !(draft_type == 0 || draft_type == 1) ) + { PRINT_ERROR("Draft type must be either 0 or 1\n"); return CUBIT_FAILURE; - } + } - // Make sure we have a reasonable number of steps - if (steps < 0) - { + // Make sure we have a reasonable number of steps + if (steps < 0) + { PRINT_WARNING("Number of steps must be a positive number.\n" " It is set to 0 and the sweep operation will proceed.\n"); steps = 0; - } + } - // Turn off the merge option in ACIS so FACEs used to sweep won't be - // "simplified" in their topology (i.e., 5-sided squared faces won't - // be reduced to 4-sided square faces) -- in other words, turn on - // non-regularized booleans - outcome result = api_set_int_option ( "merge", - CUBIT_FALSE ); - if (!result.ok()) - { + // Turn off the merge option in ACIS so FACEs used to sweep won't be + // "simplified" in their topology (i.e., 5-sided squared faces won't + // be reduced to 4-sided square faces) -- in other words, turn on + // non-regularized booleans + outcome result = api_set_int_option ( "merge", + CUBIT_FALSE ); + if (!result.ok()) + { PRINT_WARNING("In AcisModifyEngine::sweep_FACE_about_axis.\n" " Error in api_set_int_option.\n"); AcisQueryEngine::instance()->ACIS_API_error(result); - // As the problem is not really serious, continue and make sure that - // the value of result is set to "OK" so no rollback occurs + // As the problem is not really serious, continue and make sure that + // the value of result is set to "OK" so no rollback occurs result = outcome(0); - } + } - sweep_options ACIS_sweep_options; - ACIS_sweep_options.set_draft_angle(draft_angle); - ACIS_sweep_options.set_gap_type(draft_type); - ACIS_sweep_options.set_which_side(ACIS_primary_side); - ACIS_sweep_options.set_steps(steps); - ACIS_sweep_options.set_sweep_angle(angle); - ACIS_sweep_options.set_rigid(rigid); + sweep_options ACIS_sweep_options; + ACIS_sweep_options.set_draft_angle(draft_angle); + ACIS_sweep_options.set_gap_type(draft_type); + ACIS_sweep_options.set_which_side(ACIS_primary_side); + ACIS_sweep_options.set_steps(steps); + ACIS_sweep_options.set_sweep_angle(angle); + ACIS_sweep_options.set_rigid(rigid); - FACE *FACE_to_sweep_to = NULL; - if( to_FACE ) - { - //get face type - SURFACE *SURFACE_ptr = to_FACE->geometry(); - int type = SURFACE_ptr->identity(); + FACE *FACE_to_sweep_to = NULL; + if( to_FACE )//mutually exclusive with sweep_to_body + { + //get face type + SURFACE *SURFACE_ptr = to_FACE->geometry(); + int type = SURFACE_ptr->identity(); - //if face is planar...vector must not be parallel to surf normal - if (type == PLANE_TYPE) - { - FACE_to_sweep_to = make_FACE( to_FACE, true ); - } - //vector must intersect surf - else - { - FACE_to_sweep_to = make_FACE( to_FACE ); - } + //if face is planar...vector must not be parallel to surf normal + if (type == PLANE_TYPE) + { + FACE_to_sweep_to = make_FACE( to_FACE, true ); + } + //vector must intersect surf + else + { + FACE_to_sweep_to = make_FACE( to_FACE ); + } - SPAtransf trans = get_face_trans(FACE_to_sweep_to); - surface *eq_surf = FACE_to_sweep_to->geometry()->trans_surface(trans ); - ACIS_sweep_options.set_to_face( eq_surf ); - } + SPAtransf trans = get_face_trans(FACE_to_sweep_to); + surface *eq_surf = FACE_to_sweep_to->geometry()->trans_surface(trans ); + ACIS_sweep_options.set_to_face( eq_surf ); + } - BODY* face_body_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr); - BODY* BODYptr = NULL; - result = api_sweep_with_options(FACE_ptr, + else if(to_BODY)//mutually exclusive with to_face + { + ACIS_sweep_options.set_sweep_to_body(to_BODY); + //Creates one body out of the fixed body and the result of the sweep up + //to the location of the intersection between the sweep and the fixed + //body. + ACIS_sweep_options.set_bool_type(INTERSECT); + } + BODY* face_body_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr); + BODY* BODYptr = NULL; + result = api_sweep_with_options(FACE_ptr, ACIS_point, ACIS_axis_unit_vector, &ACIS_sweep_options, BODYptr); - if (BODYptr) - { - //when setting the sweep to end at a face, result is BODYptr. - if( to_FACE ) - { - //swept body & to_FACE must intersect some - BODY *tmp_body = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_to_sweep_to ); - if ( !BODYs_interfering( tmp_body, BODYptr ) ) - { - PRINT_ERROR("Terminating surface must intersect swept tool volume.\n"); - api_delent( tmp_body ); - return CUBIT_FAILURE; - } - FACE_ptr = BODYptr->lump()->shell()->first_face(); - } - else - { - PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options\n"); - PRINT_ERROR("API wants to create a new volume \n"); - api_delent( BODYptr ); - sweep_status = CUBIT_FAILURE; - } - } + if (BODYptr) + { + //when setting the sweep to end at a face, result is BODYptr. + if( to_FACE || to_BODY) + { + BODY *tmp_body = NULL; + //swept body & to_FACE must intersect some + if(to_FACE) + tmp_body = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_to_sweep_to ); + else + tmp_body = to_BODY; - if( FACE_to_sweep_to ) - api_delent( FACE_to_sweep_to ); + if ( !BODYs_interfering( tmp_body, BODYptr ) ) + { + PRINT_ERROR("Terminating surface must intersect swept tool volume.\n"); + if(to_FACE) + api_delent( tmp_body ); + return CUBIT_FAILURE; + } + FACE_ptr = BODYptr->lump()->shell()->first_face(); + } + else + { + PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options\n"); + PRINT_ERROR("API wants to create a new volume \n"); + api_delent( BODYptr ); + sweep_status = CUBIT_FAILURE; + } + } - if (!result.ok()) - { + if( FACE_to_sweep_to ) + api_delent( FACE_to_sweep_to ); + + if (!result.ok()) + { PRINT_ERROR("Error during ACIS sweep operation, api_sw_face_axis\n"); AcisQueryEngine::instance()->ACIS_API_error(result); sweep_status = CUBIT_FAILURE; - } + } - // Now set the option back to its default - result = api_set_int_option ( "merge", - CUBIT_TRUE ); - if (!result.ok()) - { + // Now set the option back to its default + result = api_set_int_option ( "merge", + CUBIT_TRUE ); + if (!result.ok()) + { PRINT_WARNING("In AcisModifyEngine::sweep_FACE_about_axis.\n" " Error in api_set_int_option.\n"); AcisQueryEngine::instance()->ACIS_API_error(result); - // As the problem is not really serious, continue and make sure that - // the value of result is set to "OK" so no rollback occurs + // As the problem is not really serious, continue and make sure that + // the value of result is set to "OK" so no rollback occurs result = outcome(0); - } + } - // Finally, check to make sure that the volume of the swept BODY is positive. - // Note that ACIS allows the creation of swept solids that have - // negative volume (all the surface normals point inward -- i.e., - // the swept solid is topologically identical to a void) - BODY *new_body = NULL; - if(BODYptr) - { + // Finally, check to make sure that the volume of the swept BODY is positive. + // Note that ACIS allows the creation of swept solids that have + // negative volume (all the surface normals point inward -- i.e., + // the swept solid is topologically identical to a void) + BODY *new_body = NULL; + if(BODYptr) + { new_body = BODYptr; - } - else if(face_body_ptr) - { + } + else if(face_body_ptr) + { new_body = face_body_ptr; - } + } - if(new_body) - { + if(new_body) + { if ( AcisQueryEngine::instance()->volume(new_body) < 0.0) - { - sweep_status = CUBIT_FAILURE; - volume_is_negative = CUBIT_SUCCESS; + { + sweep_status = CUBIT_FAILURE; + volume_is_negative = CUBIT_SUCCESS; - // Set the value of result such that the API_END macro performs - // a bulletin board rollback operation to the corresponding API_BEGIN - //result = outcome(API_FAILURE); - } - } + // Set the value of result such that the API_END macro performs + // a bulletin board rollback operation to the corresponding API_BEGIN + //result = outcome(API_FAILURE); + } + } - return sweep_status; + return sweep_status; } CubitStatus AcisModifyEngine::sweep_EDGE_about_axis( - EDGE* EDGE_ptr, - BODY *&BODYptr, - const CubitVector& axis_unit_vector, - const CubitVector& point, - double angle, - int steps, - double draft_angle, - int draft_type, - bool make_solid, - bool rigid, - FACE *to_FACE) const + EDGE* EDGE_ptr, + BODY *&BODYptr, + const CubitVector& axis_unit_vector, + const CubitVector& point, + double angle, + int steps, + double draft_angle, + int draft_type, + bool make_solid, + bool rigid, + FACE *to_FACE, + BODY *to_BODY) const { - // Sweep ho!! - CubitStatus sweep_status = CUBIT_SUCCESS; + // Sweep ho!! + CubitStatus sweep_status = CUBIT_SUCCESS; - // Convert the Cubit point and SPAvector into an ACIS point and SPAvector - // before calling the member function that calls the ACIS API - // function. - SPAunit_vector ACIS_axis_unit_vector( - axis_unit_vector.x(), - axis_unit_vector.y(), - axis_unit_vector.z() ); - SPAposition ACIS_point( point.x(), point.y(), point.z() ); - if (angle == 0.0) - { + // Convert the Cubit point and SPAvector into an ACIS point and SPAvector + // before calling the member function that calls the ACIS API + // function. + SPAunit_vector ACIS_axis_unit_vector( + axis_unit_vector.x(), + axis_unit_vector.y(), + axis_unit_vector.z() ); + SPAposition ACIS_point( point.x(), point.y(), point.z() ); + if (angle == 0.0) + { PRINT_ERROR("The angle of the sweep must be > 0.0. Nothing done.\n"); return CUBIT_FAILURE; - } + } - // Make sure the draft angle is reasonable - if (draft_angle >= CUBIT_PI/2.0 || draft_angle <= -(CUBIT_PI/2.0)) - { + // Make sure the draft angle is reasonable + if (draft_angle >= CUBIT_PI/2.0 || draft_angle <= -(CUBIT_PI/2.0)) + { PRINT_ERROR("Draft angle cannot be greater than %e radians\n", CUBIT_PI/2.0); return CUBIT_FAILURE; - } + } - // Make sure the draft type is either 0 or 1 (this is an ACISism, of course!) - if ( !(draft_type == 0 || draft_type == 1) ) - { + // Make sure the draft type is either 0 or 1 (this is an ACISism, of course!) + if ( !(draft_type == 0 || draft_type == 1) ) + { PRINT_ERROR("Draft type must be either 0 or 1\n"); return CUBIT_FAILURE; - } + } - // Make sure we have a reasonable number of steps - if (steps < 0) - { + // Make sure we have a reasonable number of steps + if (steps < 0) + { PRINT_WARNING("Number of steps must be a positive number.\n" " It is set to 0 and the sweep operation will proceed.\n"); steps = 0; - } + } - // Turn off the merge option in ACIS so FACEs used to sweep won't be - // "simplified" in their topology (i.e., 5-sided squared faces won't - // be reduced to 4-sided square faces) -- in other words, turn on - // non-regularized booleans - outcome result = api_set_int_option ( "merge", - CUBIT_FALSE ); - if (!result.ok()) - { + // Turn off the merge option in ACIS so FACEs used to sweep won't be + // "simplified" in their topology (i.e., 5-sided squared faces won't + // be reduced to 4-sided square faces) -- in other words, turn on + // non-regularized booleans + outcome result = api_set_int_option ( "merge", + CUBIT_FALSE ); + if (!result.ok()) + { PRINT_WARNING("In AcisModifyEngine::sweep_EDGE_about_axis.\n" " Error in api_set_int_option.\n"); AcisQueryEngine::instance()->ACIS_API_error(result); - // As the problem is not really serious, continue and make sure that - // the value of result is set to "OK" so no rollback occurs + // As the problem is not really serious, continue and make sure that + // the value of result is set to "OK" so no rollback occurs result = outcome(0); - } + } - sweep_options ACIS_sweep_options; - ACIS_sweep_options.set_draft_angle(draft_angle); - ACIS_sweep_options.set_gap_type(draft_type); - ACIS_sweep_options.set_steps(steps); - ACIS_sweep_options.set_sweep_angle(angle); - ACIS_sweep_options.set_rigid(rigid); - EDGE *copied_EDGE_ptr = NULL; - result = api_edge( EDGE_ptr, copied_EDGE_ptr ); - if( !result.ok() ) - { - PRINT_ERROR( "Unable to copy edge\n"); - return CUBIT_FAILURE; - } - ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr, - CUBIT_TRUE ); + sweep_options ACIS_sweep_options; + ACIS_sweep_options.set_draft_angle(draft_angle); + ACIS_sweep_options.set_gap_type(draft_type); + ACIS_sweep_options.set_steps(steps); + ACIS_sweep_options.set_sweep_angle(angle); + ACIS_sweep_options.set_rigid(rigid); + EDGE *copied_EDGE_ptr = NULL; + result = api_edge( EDGE_ptr, copied_EDGE_ptr ); + if( !result.ok() ) + { + PRINT_ERROR( "Unable to copy edge\n"); + return CUBIT_FAILURE; + } + ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr, + CUBIT_TRUE ); - FACE *FACE_to_sweep_to = NULL; - if( to_FACE ) - { - //get face type - SURFACE *SURFACE_ptr = to_FACE->geometry(); - int type = SURFACE_ptr->identity(); + FACE *FACE_to_sweep_to = NULL; + if( to_FACE )//mutually exclusive with sweep_to_body + { + //get face type + SURFACE *SURFACE_ptr = to_FACE->geometry(); + int type = SURFACE_ptr->identity(); - //if face is planar...vector must not be parallel to surf normal - if (type == PLANE_TYPE) - { - FACE_to_sweep_to = make_FACE( to_FACE, true ); - } - //vector must intersect surf - else - { - FACE_to_sweep_to = make_FACE( to_FACE ); - } + //if face is planar...vector must not be parallel to surf normal + if (type == PLANE_TYPE) + { + FACE_to_sweep_to = make_FACE( to_FACE, true ); + } + //vector must intersect surf + else + { + FACE_to_sweep_to = make_FACE( to_FACE ); + } - SPAtransf trans = get_face_trans(FACE_to_sweep_to); - surface *eq_surf = FACE_to_sweep_to->geometry()->trans_surface(trans ); - ACIS_sweep_options.set_to_face( eq_surf ); - } + SPAtransf trans = get_face_trans(FACE_to_sweep_to); + surface *eq_surf = FACE_to_sweep_to->geometry()->trans_surface(trans ); + ACIS_sweep_options.set_to_face( eq_surf ); + } + else if(to_BODY)//utually exclusive with to_face + { + ACIS_sweep_options.set_sweep_to_body(to_BODY); + //Creates one body out of the fixed body and the result of the sweep up + //to the location of the intersection between the sweep and the fixed + //body. + ACIS_sweep_options.set_bool_type(INTERSECT); + } - if(make_solid) - { - ACIS_sweep_options.set_close_to_axis(TRUE); - EDGE* EDGES[1]; - EDGES[0] = copied_EDGE_ptr; - BODY* EDGE_BODY_ptr = NULL; + if(make_solid) + { + ACIS_sweep_options.set_close_to_axis(TRUE); + EDGE* EDGES[1]; + EDGES[0] = copied_EDGE_ptr; + BODY* EDGE_BODY_ptr = NULL; - result = api_make_ewire(1, EDGES, EDGE_BODY_ptr); + result = api_make_ewire(1, EDGES, EDGE_BODY_ptr); -// WIRE* WIRE_ptr = EDGE_BODY_ptr->lump()->shell()->wire(); - result = api_sweep_with_options(EDGE_BODY_ptr, - ACIS_point, ACIS_axis_unit_vector, - &ACIS_sweep_options, BODYptr); - BODYptr = EDGE_BODY_ptr; + // WIRE* WIRE_ptr = EDGE_BODY_ptr->lump()->shell()->wire(); + result = api_sweep_with_options(EDGE_BODY_ptr, + ACIS_point, ACIS_axis_unit_vector, + &ACIS_sweep_options, BODYptr); + BODYptr = EDGE_BODY_ptr; - } - else { - result = api_sweep_with_options(copied_EDGE_ptr, - ACIS_point, ACIS_axis_unit_vector, - &ACIS_sweep_options, BODYptr); - } + } + else { + result = api_sweep_with_options(copied_EDGE_ptr, + ACIS_point, ACIS_axis_unit_vector, + &ACIS_sweep_options, BODYptr); + } - if (BODYptr) - { - sweep_status = CUBIT_SUCCESS; - } - if (!result.ok()) - { + if (BODYptr) + { + sweep_status = CUBIT_SUCCESS; + } + if (!result.ok()) + { PRINT_ERROR("Error during ACIS sweep operation, api_sweep_with_options\n"); AcisQueryEngine::instance()->ACIS_API_error(result); if ( copied_EDGE_ptr != NULL ) api_delent(copied_EDGE_ptr); sweep_status = CUBIT_FAILURE; - } + } - if( FACE_to_sweep_to ) - api_delent( FACE_to_sweep_to ); + if( FACE_to_sweep_to ) + api_delent( FACE_to_sweep_to ); - // Now set the option back to its default - result = api_set_int_option ( "merge", - CUBIT_TRUE ); - if (!result.ok()) - { + // Now set the option back to its default + result = api_set_int_option ( "merge", + CUBIT_TRUE ); + if (!result.ok()) + { PRINT_WARNING("In AcisModifyEngine::sweep_EDGE_about_axis.\n" " Error in api_set_int_option.\n"); AcisQueryEngine::instance()->ACIS_API_error(result); - // As the problem is not really serious, continue and make sure that - // the value of result is set to "OK" so no rollback occurs + // As the problem is not really serious, continue and make sure that + // the value of result is set to "OK" so no rollback occurs result = outcome(0); - } + } - // Finally, check to make sure that the volume of the swept BODY is positive. - // Note that ACIS allows the creation of swept solids that have - // negative volume (all the surface normals point inward -- i.e., - // the swept solid is topologically identical to a void) + // Finally, check to make sure that the volume of the swept BODY is positive. + // Note that ACIS allows the creation of swept solids that have + // negative volume (all the surface normals point inward -- i.e., + // the swept solid is topologically identical to a void) - return sweep_status; + return sweep_status; } //------------------------------------------------------------------------- @@ -3964,168 +3378,168 @@ const CubitVector& V3, const CubitVector& V4 ) const { - GeometryQueryTool* GT_ptr = GeometryQueryTool::instance(); - BODY* Body1 = NULL; + GeometryQueryTool* GT_ptr = GeometryQueryTool::instance(); + BODY* Body1 = NULL; - // Debug info - PRINT_DEBUG_18( - "Debug output from AcisModifyEngine::make_planar_quad_BODY\n"); + // Debug info + PRINT_DEBUG_18( + "Debug output from AcisModifyEngine::make_planar_quad_BODY\n"); - // First make sure that none of the points have the same coordinates. - if ( (GT_ptr->about_spatially_equal(V1, V2, - GeometryQueryTool::get_geometry_factor())) || - (GT_ptr->about_spatially_equal(V1, V3, - GeometryQueryTool::get_geometry_factor())) || - (GT_ptr->about_spatially_equal(V1, V4, - GeometryQueryTool::get_geometry_factor())) || - (GT_ptr->about_spatially_equal(V2, V3, - GeometryQueryTool::get_geometry_factor())) || - (GT_ptr->about_spatially_equal(V2, V4, - GeometryQueryTool::get_geometry_factor())) || - (GT_ptr->about_spatially_equal(V3, V4, - GeometryQueryTool::get_geometry_factor())) ) - { + // First make sure that none of the points have the same coordinates. + if ( (GT_ptr->about_spatially_equal(V1, V2, + GeometryQueryTool::get_geometry_factor())) || + (GT_ptr->about_spatially_equal(V1, V3, + GeometryQueryTool::get_geometry_factor())) || + (GT_ptr->about_spatially_equal(V1, V4, + GeometryQueryTool::get_geometry_factor())) || + (GT_ptr->about_spatially_equal(V2, V3, + GeometryQueryTool::get_geometry_factor())) || + (GT_ptr->about_spatially_equal(V2, V4, + GeometryQueryTool::get_geometry_factor())) || + (GT_ptr->about_spatially_equal(V3, V4, + GeometryQueryTool::get_geometry_factor())) ) + { PRINT_ERROR("In AcisModifyEngine::make_planar_quad_BODY.\n" " Some of the input points are spatially equivalent.\n" " Cannot create a planar quadrilateral ACIS BODY.\n"); return NULL; - } + } - // Make sure that the 4 input points are coplanar. - // If the 4 points are coplanar, then the scalar triple product - // of the 3 vectors joining points 1 and 2, 2 and 3, and 3 and 4, will - // equal zero. - // For 4 coplanar points, Vector12 . (Vector23 * Vector34) = 0 + // Make sure that the 4 input points are coplanar. + // If the 4 points are coplanar, then the scalar triple product + // of the 3 vectors joining points 1 and 2, 2 and 3, and 3 and 4, will + // equal zero. + // For 4 coplanar points, Vector12 . (Vector23 * Vector34) = 0 - CubitVector vector12 = V2 - V1; - CubitVector vector23 = V3 - V2; - CubitVector vector34 = V4 - V3; + CubitVector vector12 = V2 - V1; + CubitVector vector23 = V3 - V2; + CubitVector vector34 = V4 - V3; - // normalize the vectors - vector12.normalize(); - vector23.normalize(); - vector34.normalize(); + // normalize the vectors + vector12.normalize(); + vector23.normalize(); + vector34.normalize(); - double tripleProd = vector12 % (vector23 * vector34); + double tripleProd = vector12 % (vector23 * vector34); - // MJP Note: - // The following tests to make sure that tripleProd is "0.0". But this - // cannot be tested exactly, so we have to approximate the notion of zero. - // I have run into a case where a not-so-large (size about 2000 units) - // set of 4 points results in a tripleProd value of approximately - // -3.5E-6 whose fabs is 3.5E-6 which is larger than SPAresabs (1E-6). - // I have put in an arbitrary factor of 100 here!!!!!!! This raises - // our notion of "zero" from 1E-6 to 1E-4......:-) - if (fabs(tripleProd) > 100.0 * GEOMETRY_RESABS) - { + // MJP Note: + // The following tests to make sure that tripleProd is "0.0". But this + // cannot be tested exactly, so we have to approximate the notion of zero. + // I have run into a case where a not-so-large (size about 2000 units) + // set of 4 points results in a tripleProd value of approximately + // -3.5E-6 whose fabs is 3.5E-6 which is larger than SPAresabs (1E-6). + // I have put in an arbitrary factor of 100 here!!!!!!! This raises + // our notion of "zero" from 1E-6 to 1E-4......:-) + if (fabs(tripleProd) > 100.0 * GEOMETRY_RESABS) + { PRINT_ERROR("In AcisModifyEngine::make_planar_quad_BODY.\n" " The 4 input points are not coplanar.\n" " Cannot create a planar quadrilateral ACIS BODY.\n"); return NULL; - } + } - // Initialize the bulletin board (this is done so that if there is an - // error while building this body, ACIS will automatically roll its - // state back to what it was before this next statement was executed. - int success = CUBIT_TRUE; - API_BEGIN; + // Initialize the bulletin board (this is done so that if there is an + // error while building this body, ACIS will automatically roll its + // state back to what it was before this next statement was executed. + int success = CUBIT_TRUE; + API_BEGIN; - // Create an ACIS Body using the direct interface (it's tons of fun :-) + // Create an ACIS Body using the direct interface (it's tons of fun :-) - // Create ACIS points - APOINT* P1 = new APOINT (V1.x(), V1.y(), V1.z()); - APOINT* P2 = new APOINT (V2.x(), V2.y(), V2.z()); - APOINT* P3 = new APOINT (V3.x(), V3.y(), V3.z()); - APOINT* P4 = new APOINT (V4.x(), V4.y(), V4.z()); + // Create ACIS points + APOINT* P1 = new APOINT (V1.x(), V1.y(), V1.z()); + APOINT* P2 = new APOINT (V2.x(), V2.y(), V2.z()); + APOINT* P3 = new APOINT (V3.x(), V3.y(), V3.z()); + APOINT* P4 = new APOINT (V4.x(), V4.y(), V4.z()); - // Create ACIS straight lines between the 4 input points - STRAIGHT* S1 = new STRAIGHT( P1->coords(), - normalise(P2->coords() - P1->coords()) ); - STRAIGHT* S2 = new STRAIGHT( P2->coords(), - normalise(P3->coords() - P2->coords()) ); - STRAIGHT* S3 = new STRAIGHT( P3->coords(), - normalise(P4->coords() - P3->coords()) ); - STRAIGHT* S4 = new STRAIGHT( P4->coords(), - normalise(P1->coords() - P4->coords()) ); + // Create ACIS straight lines between the 4 input points + STRAIGHT* S1 = new STRAIGHT( P1->coords(), + normalise(P2->coords() - P1->coords()) ); + STRAIGHT* S2 = new STRAIGHT( P2->coords(), + normalise(P3->coords() - P2->coords()) ); + STRAIGHT* S3 = new STRAIGHT( P3->coords(), + normalise(P4->coords() - P3->coords()) ); + STRAIGHT* S4 = new STRAIGHT( P4->coords(), + normalise(P1->coords() - P4->coords()) ); - // Compute the unit SPAvector of the plane containing the 4 points - CubitVector planeNormal; - planeNormal = (vector12 * vector23); - planeNormal.normalize(); + // Compute the unit SPAvector of the plane containing the 4 points + CubitVector planeNormal; + planeNormal = (vector12 * vector23); + planeNormal.normalize(); - // Create an ACIS surface - PLANE* Plane1 = new PLANE( P1->coords(), - SPAunit_vector(planeNormal.x(), - planeNormal.y(), - planeNormal.z() ) ); + // Create an ACIS surface + PLANE* Plane1 = new PLANE( P1->coords(), + SPAunit_vector(planeNormal.x(), + planeNormal.y(), + planeNormal.z() ) ); - // Create ACIS vertices - VERTEX* Vertex1 = new VERTEX (P1); - VERTEX* Vertex2 = new VERTEX (P2); - VERTEX* Vertex3 = new VERTEX (P3); - VERTEX* Vertex4 = new VERTEX (P4); + // Create ACIS vertices + VERTEX* Vertex1 = new VERTEX (P1); + VERTEX* Vertex2 = new VERTEX (P2); + VERTEX* Vertex3 = new VERTEX (P3); + VERTEX* Vertex4 = new VERTEX (P4); - // Create ACIS edges - EDGE* Edge1 = new EDGE (Vertex1, Vertex2, S1, FORWARD); - EDGE* Edge2 = new EDGE (Vertex2, Vertex3, S2, FORWARD); - EDGE* Edge3 = new EDGE (Vertex3, Vertex4, S3, FORWARD); - EDGE* Edge4 = new EDGE (Vertex4, Vertex1, S4, FORWARD); + // Create ACIS edges + EDGE* Edge1 = new EDGE (Vertex1, Vertex2, S1, FORWARD); + EDGE* Edge2 = new EDGE (Vertex2, Vertex3, S2, FORWARD); + EDGE* Edge3 = new EDGE (Vertex3, Vertex4, S3, FORWARD); + EDGE* Edge4 = new EDGE (Vertex4, Vertex1, S4, FORWARD); - // Create an ACIS loop of coedges - COEDGE* Coedge1 = new COEDGE (Edge1, FORWARD, NULL, NULL); - COEDGE* Coedge2 = new COEDGE (Edge2, FORWARD, Coedge1, NULL); - COEDGE* Coedge3 = new COEDGE (Edge3, FORWARD, Coedge2, NULL); - /*COEDGE* Coedge4 =*/ new COEDGE (Edge4, FORWARD, Coedge3, Coedge1); - LOOP* Loop1 = new LOOP (Coedge1, NULL); + // Create an ACIS loop of coedges + COEDGE* Coedge1 = new COEDGE (Edge1, FORWARD, NULL, NULL); + COEDGE* Coedge2 = new COEDGE (Edge2, FORWARD, Coedge1, NULL); + COEDGE* Coedge3 = new COEDGE (Edge3, FORWARD, Coedge2, NULL); + /*COEDGE* Coedge4 =*/ new COEDGE (Edge4, FORWARD, Coedge3, Coedge1); + LOOP* Loop1 = new LOOP (Coedge1, NULL); - // Create an ACIS face - FACE* Face1 = new FACE (Loop1, NULL, Plane1, FORWARD); + // Create an ACIS face + FACE* Face1 = new FACE (Loop1, NULL, Plane1, FORWARD); - // Create an ACIS shell - SHELL* Shell1 = new SHELL (Face1, NULL, NULL); + // Create an ACIS shell + SHELL* Shell1 = new SHELL (Face1, NULL, NULL); - // Create an ACIS lump - LUMP* Lump1 = new LUMP (Shell1, NULL); + // Create an ACIS lump + LUMP* Lump1 = new LUMP (Shell1, NULL); - // Create the ACIS body - Body1 = new BODY (Lump1); + // Create the ACIS body + Body1 = new BODY (Lump1); - // Make sure all's well with this BODY and then 2D-it! - if (Body1 != NULL) - { - // Finally, make sure this BODY consists of a DOUBLE-SIDED, - // BOTH_OUTSIDE FACE + // Make sure all's well with this BODY and then 2D-it! + if (Body1 != NULL) + { + // Finally, make sure this BODY consists of a DOUBLE-SIDED, + // BOTH_OUTSIDE FACE result = api_body_to_2d(Body1); if (!result.ok()) - { - PRINT_ERROR("In AcisModifyEngine::make_planar_quad_BODY.\n" - " Unable to convert FACE to a 2D BODY using api_body_to2d.\n"); - success = CUBIT_FALSE; - } - } + { + PRINT_ERROR("In AcisModifyEngine::make_planar_quad_BODY.\n" + " Unable to convert FACE to a 2D BODY using api_body_to2d.\n"); + success = CUBIT_FALSE; + } + } - // Scream bloody murder....only if necessary, of course :-) - if (Body1 == NULL) - { + // Scream bloody murder....only if necessary, of course :-) + if (Body1 == NULL) + { PRINT_ERROR("In AcisModifyEngine::make_planar_quad_BODY.\n" " Problem creating a Planar Quadrilateral ACIS BODY.\n"); success = CUBIT_FALSE; - } + } - // Terminate the bulletin board - API_END; + // Terminate the bulletin board + API_END; - if (success) - { - // Debug info - PRINT_DEBUG_18(" Successfully created a planar quadrilateral ACIS BODY.\n"); - return Body1; - } + if (success) + { + // Debug info + PRINT_DEBUG_18(" Successfully created a planar quadrilateral ACIS BODY.\n"); + return Body1; + } - else - { - return NULL; - } + else + { + return NULL; + } } //------------------------------------------------------------------------- @@ -4143,55 +3557,55 @@ const CubitVector axes[3], const CubitVector &extension ) const { - BODY* BODY_ptr = NULL; + BODY* BODY_ptr = NULL; - double width = 2.0*extension.x(); - double depth = 2.0*extension.y(); - double height = 2.0*extension.z(); + double width = 2.0*extension.x(); + double depth = 2.0*extension.y(); + double height = 2.0*extension.z(); - // Create a BODY that represents the cuboid - outcome result = api_make_cuboid ( width, depth, height, BODY_ptr ); - if (!result.ok()) - { + // Create a BODY that represents the cuboid + outcome result = api_make_cuboid ( width, depth, height, BODY_ptr ); + if (!result.ok()) + { PRINT_ERROR("In AcisGeometryEngine::make_brick_BODY, Line# %d\n" " Problems creating a brick\n", __LINE__); return NULL ; - } + } - // Transform the brick into SPAposition + // Transform the brick into SPAposition - SPAposition brick_center( center.x(), center.y(), center.z() ); - SPAunit_vector x_axis_this( axes[0].x(), axes[0].y(), axes[0].z() ); - SPAunit_vector y_axis_this( axes[1].x(), axes[1].y(), axes[1].z() ); + SPAposition brick_center( center.x(), center.y(), center.z() ); + SPAunit_vector x_axis_this( axes[0].x(), axes[0].y(), axes[0].z() ); + SPAunit_vector y_axis_this( axes[1].x(), axes[1].y(), axes[1].z() ); - SPAtransf transformation = coordinate_transf( brick_center, x_axis_this, y_axis_this ); + SPAtransf transformation = coordinate_transf( brick_center, x_axis_this, y_axis_this ); - // Concatenate the input transformation to the existing one - result = api_apply_transf ( BODY_ptr, transformation ); - if (!result.ok()) - { + // Concatenate the input transformation to the existing one + result = api_apply_transf ( BODY_ptr, transformation ); + if (!result.ok()) + { AcisQueryEngine::instance()->ACIS_API_error ( result ); PRINT_ERROR("In AcisGeometryEngine::make_brick_BODY, Line# %d\n" " Problems creating a brick\n", __LINE__); return NULL; - } - TRANSFORM* identity = new TRANSFORM(scale_transf(1.0)); - result = api_change_body_trans ( BODY_ptr, identity, FALSE ); - identity->lose(); - if (!result.ok()) - { + } + TRANSFORM* identity = new TRANSFORM(scale_transf(1.0)); + result = api_change_body_trans ( BODY_ptr, identity, FALSE ); + identity->lose(); + if (!result.ok()) + { AcisQueryEngine::instance()->ACIS_API_error ( result ); PRINT_ERROR("In AcisGeometryEngine::make_brick_BODY, Line# %d\n" " Problems creating a brick\n", __LINE__); return NULL; - } - //The bounding SPAbox does not get re-computed, so we need - //to do it. - AcisQueryEngine::instance()->clear_bounding_box( BODY_ptr ); - AcisQueryEngine::instance()->bounding_box( BODY_ptr ); + } + //The bounding SPAbox does not get re-computed, so we need + //to do it. + AcisQueryEngine::instance()->clear_bounding_box( BODY_ptr ); + AcisQueryEngine::instance()->bounding_box( BODY_ptr ); - return BODY_ptr; + return BODY_ptr; } //------------------------------------------------------------------------- @@ -4209,220 +3623,270 @@ CubitStatus AcisModifyEngine::webcut_BODY( BODY* bodyPtr, BODY* CuttingToolPtr, BODY*& webcutBody1, - BODY*& webcutBody2) const + BODY*& webcutBody2, + CubitBoolean cutting_with_sheet) const { - // Algorithm for webcut of the ACIS BODY, bodyPtr, using the solid - // ACIS BODY, CuttingToolPtr, as the Cutting Tool: - // 1) Save 2 copies of bodyPtr as body1Save and body2Save - // 2) Save 2 copies of CuttingToolPtr as CuttingToolSave1 and CuttingToolSave2 - // 3) Subtract CuttingToolSave1 from bodySave1 => returns Body2 - // 4) Intersect CuttingToolSave2 with bodySave2 => returns Body3 - // 5) Clean up and return Body2 and Body3 - // + // Algorithm for webcut of the ACIS BODY, bodyPtr, using the solid + // ACIS BODY, CuttingToolPtr, as the Cutting Tool: + // 1) Save 2 copies of bodyPtr as body1Save and body2Save + // 2) Save 2 copies of CuttingToolPtr as CuttingToolSave1 and CuttingToolSave2 + // 3) Subtract CuttingToolSave1 from bodySave1 => returns Body2 + // 4) Intersect CuttingToolSave2 with bodySave2 => returns Body3 + // 5) Clean up and return Body2 and Body3 + // - // MJP Note: - // By the end of this procedure, whether the operation is successful or not, - // BODYs pointed to by CuttingToolPtr and bodyPtr are returned intact. + // MJP Note: + // By the end of this procedure, whether the operation is successful or not, + // BODYs pointed to by CuttingToolPtr and bodyPtr are returned intact. - // MJP Note: - // The final 2 ACIS BODYs are *not* combined into a single BODY with - // multiple LUMPs as Acis does not consider a BODY with multiple LUMPs some - // of whose FACEs overlap in space, a valid BODY. LUMPs of a BODY need - // to be disjoint. + // MJP Note: + // The final 2 ACIS BODYs are *not* combined into a single BODY with + // multiple LUMPs as Acis does not consider a BODY with multiple LUMPs some + // of whose FACEs overlap in space, a valid BODY. LUMPs of a BODY need + // to be disjoint. - int webcut_debug_flag = 18; - int webcut_debug_flag_on = DEBUG_FLAG(webcut_debug_flag); + int webcut_debug_flag = 18; + int webcut_debug_flag_on = DEBUG_FLAG(webcut_debug_flag); - // Debug info - if (webcut_debug_flag_on) - { + // Debug info + if (webcut_debug_flag_on) + { PRINT_DEBUG_18("\n...Performing the webcut operation on the Acis BODY\n"); - } + } - // Set the output webcut BODY pointers to NULL - webcutBody1 = NULL; - webcutBody2 = NULL; + // Set the output webcut BODY pointers to NULL + webcutBody1 = NULL; + webcutBody2 = NULL; - // Make sure that none of the input BODY pointers are NULL. - // Note: webcutBody1 and webcutBody2 are "empty" Acis BODYs that were - // created by the calling procedure and will probably be set to - // NULL - if (bodyPtr == NULL) - { + // Make sure that none of the input BODY pointers are NULL. + // Note: webcutBody1 and webcutBody2 are "empty" Acis BODYs that were + // created by the calling procedure and will probably be set to + // NULL + if (bodyPtr == NULL) + { PRINT_ERROR("The pointer to the input volume to be webcut is NULL.\n"); return CUBIT_FAILURE; - } - if (CuttingToolPtr == NULL) - { + } + if (CuttingToolPtr == NULL) + { PRINT_ERROR("The pointer to the input CuttingTool volume is NULL.\n"); return CUBIT_FAILURE; - } + } - // Save the BODY being cut, if debug is on - if (webcut_debug_flag_on) - { + //don't try to webcut a body with itself + if( bodyPtr == CuttingToolPtr ) + { + return CUBIT_FAILURE; + } + + //first test to see if these intersect. If they don't + //then continueing on will not show the error and duplicate + //bodies will be created. + if ( !BODYs_interfering( bodyPtr, CuttingToolPtr ) ) + { + PRINT_WARNING("Cutting Tool does not intersect the original volume.\n" + " The original volume is restored.\n" ); + return CUBIT_FAILURE; + } + + // Save the BODY being cut, if debug is on + if (webcut_debug_flag_on) + { AcisQueryEngine::instance()->save_ENTITY_as_sat_file(bodyPtr, "OrigBody.sat", "w"); - } + } - // Make a copy of the body to be decomposed as well as the - // CuttingTool. - BODY* body1Save = NULL; - BODY* body2Save = NULL; - BODY* CuttingToolSave = NULL; - BODY* CuttingToolSave2 = NULL; + // Make a copy of the body to be decomposed as well as the + // CuttingTool. + BODY* body1Save = NULL; + BODY* body2Save = NULL; + BODY* CuttingToolSave = NULL; + BODY* CuttingToolSave2 = NULL; - CubitBoolean copy_attribs = GeometryModifyTool::instance()->get_new_ids(); - CubitBoolean delete_owners = CUBIT_TRUE; - if (copy_attribs == CUBIT_TRUE) delete_owners = CUBIT_FALSE; + CubitBoolean copy_attribs = GeometryModifyTool::instance()->get_new_ids(); + CubitBoolean delete_owners = CUBIT_TRUE; + if (copy_attribs == CUBIT_TRUE) delete_owners = CUBIT_FALSE; - body1Save = this->copy_BODY(bodyPtr, copy_attribs); - if ( body1Save == NULL ) - { - // If the original ACIS BODY was destroyed, then make sure that the - // associated Body is deactivated and removed. + body1Save = this->copy_BODY(bodyPtr, copy_attribs); + + if ( body1Save == NULL ) + { + // If the original ACIS BODY was destroyed, then make sure that the + // associated Body is deactivated and removed. if (bodyPtr == NULL) - { - PRINT_ERROR("During the webcut operation, the original\n" - " ACIS volume was destroyed.\n" - " ...Deleting the original volume...\n"); - } + { + PRINT_ERROR("During the webcut operation, the original\n" + " ACIS volume was destroyed.\n" + " ...Deleting the original volume...\n"); + } return CUBIT_FAILURE; - } + } - CuttingToolSave = this->copy_BODY(CuttingToolPtr); - if ( CuttingToolSave == NULL ) - { + CuttingToolSave = this->copy_BODY(CuttingToolPtr); + + if(cutting_with_sheet && CuttingToolSave) + { + //set all faces to one sided + API_BEGIN; + sg_body_to_1d( CuttingToolSave ); + API_END; + } + + CuttingToolSave2 = this->copy_BODY(CuttingToolSave); + + if ( CuttingToolSave == NULL || CuttingToolSave2 == NULL) + { AcisQueryEngine::instance()->delete_ACIS_BODY(body1Save, delete_owners); + if (CuttingToolSave != NULL) + AcisQueryEngine::instance()->delete_ACIS_BODY(CuttingToolSave, CUBIT_TRUE); + + if(CuttingToolSave2 != NULL) + AcisQueryEngine::instance()->delete_ACIS_BODY(CuttingToolSave2, CUBIT_TRUE); return CUBIT_FAILURE; - } + } - // Subtract CuttingToolSave from body1Save - // NOTE: in the api_subtract, the resulting body is put into the - // body being subtracted from. - outcome result = api_subtract(CuttingToolSave, body1Save); - if ( !result.ok() ) - { + if(cutting_with_sheet) + { + outcome rc_3 = api_reverse_body( CuttingToolSave2 ); + if ( !rc_3.ok() || CuttingToolSave2 == NULL ) + { + PRINT_ERROR("Error in webcutting volume with sheet.\n"); + if (body1Save != NULL) + AcisQueryEngine::instance()-> + delete_ACIS_BODY(body1Save, delete_owners); + + AcisQueryEngine::instance()-> + delete_ACIS_BODY(CuttingToolSave, CUBIT_TRUE); + + if( CuttingToolSave2 != NULL ) + AcisQueryEngine::instance()-> + delete_ACIS_BODY(CuttingToolSave2, delete_owners); + + return CUBIT_FAILURE; + } + } + + // Subtract CuttingToolSave from body1Save + // NOTE: in the api_subtract, the resulting body is put into the + // body being subtracted from. + outcome result = api_subtract(CuttingToolSave, body1Save); + if ( !result.ok() ||( body1Save&& + !BodyACIS::is_sheet_body( body1Save ) && + !is_closed_solid_body( body1Save ) )) + { AcisQueryEngine::instance()->ACIS_API_error(result); - if (CuttingToolSave != NULL) - AcisQueryEngine::instance()->delete_ACIS_BODY(CuttingToolSave, CUBIT_TRUE); + + if (body1Save != NULL) - AcisQueryEngine::instance()->delete_ACIS_BODY(body1Save, delete_owners); + AcisQueryEngine::instance()->delete_ACIS_BODY(body1Save, delete_owners); + + AcisQueryEngine::instance()->delete_ACIS_BODY(CuttingToolSave2, CUBIT_TRUE); return CUBIT_FAILURE; - } + } - // As the subtract operation was successful, the blank has already been deleted. - // So set the pointer to NULL so we don't try to delete it again. - CuttingToolSave = NULL; + // As the subtract operation was successful, the blank has already + // been deleted. + // So set the pointer to NULL so we don't try to delete it again. + CuttingToolSave = NULL; - // Before proceeding any further, make sure that result of the - // subtraction is not a NULL BODY or a BODY that has no LUMPs. - if ( (body1Save == NULL) || (body1Save->lump() == NULL) ) - { + // Before proceeding any further, make sure that result of the + // subtraction is not a NULL BODY or a BODY that has no LUMPs. + if ( (body1Save == NULL) || (body1Save->lump() == NULL) ) + { if (body1Save != NULL) - AcisQueryEngine::instance()->delete_ACIS_BODY(body1Save, delete_owners); + AcisQueryEngine::instance()->delete_ACIS_BODY(body1Save, delete_owners); + PRINT_INFO("INFO: Cutting Tool overlaps the original volume,\n" " Or cutting plane does not pass through volume.\n" " The original volume is unaffected.\n" ); return CUBIT_FAILURE; - } + } + + //make copy of the the bodyPtr for a second cut. + body2Save = this->copy_BODY(bodyPtr, copy_attribs); - // Make another copy of the original body. - // NOTE: I want to preserve the original body in case something - // goes haywire before we're done :-) - body2Save = this->copy_BODY(bodyPtr, copy_attribs); - if ( body2Save == NULL ) - { - if (body1Save != NULL) - AcisQueryEngine::instance()->delete_ACIS_BODY(body1Save, delete_owners); + if ( body2Save == NULL ) + { + // If the original ACIS BODY was destroyed, then make sure that the + // associated Body is deactivated and removed. if (bodyPtr == NULL) - { - PRINT_ERROR("During the webcut operation, the original\n" - " volume was destroyed.\n" - " ...Deleting the original volume...\n"); - } + { + PRINT_ERROR("During the webcut operation, the original\n" + " ACIS volume was destroyed.\n" + " ...Deleting the original volume...\n"); + } return CUBIT_FAILURE; - } + } + + // Now intersect CuttingToolSave2 with body2Save + // Note: If the outcome is successful, the result is the second BODY + // and the first BODY is deleted. + // Debug output + if (webcut_debug_flag_on) + { + //Save the result of the subtract operation + AcisQueryEngine::instance()->save_ENTITY_as_sat_file(CuttingToolPtr, + "Subtract.sat", "w"); - // Make another copy of the CuttingTool body - CuttingToolSave2 = this->copy_BODY(CuttingToolPtr); - if ( CuttingToolSave2 == NULL ) - { - if (body1Save != NULL) - AcisQueryEngine::instance()->delete_ACIS_BODY(body1Save, delete_owners); - if (body2Save != NULL) - AcisQueryEngine::instance()->delete_ACIS_BODY(body2Save, delete_owners); - if (bodyPtr == NULL) - { - PRINT_ERROR("During the webcut operation, the original\n" - " volume was destroyed.\n" - " ...Deleting the original volume...\n"); - } + //Save the result of the intersect operation + AcisQueryEngine::instance()->save_ENTITY_as_sat_file(bodyPtr, + "Intersect.sat", "w"); + } - return CUBIT_FAILURE; - } + if (cutting_with_sheet) + result = api_subtract(CuttingToolSave2, body2Save); - // Now intersect CuttingToolSave2 with body2Save - // Note: If the outcome is successful, the result is the second BODY - // and the first BODY is deleted. - // Debug output - if (webcut_debug_flag_on) - { - //Save the result of the subtract operation - AcisQueryEngine::instance()->save_ENTITY_as_sat_file(CuttingToolPtr, "Subtract.sat", "w"); - - //Save the result of the intersect operation - AcisQueryEngine::instance()->save_ENTITY_as_sat_file(bodyPtr, "Intersect.sat", "w"); - } - result = api_intersect(CuttingToolSave2, body2Save); - if ( !result.ok() ) - { + else + result = api_intersect(CuttingToolSave2, body2Save); + if ( !result.ok() || (body2Save && + !BodyACIS::is_sheet_body( body2Save) && + !is_closed_solid_body( body2Save) ) ) + { AcisQueryEngine::instance()->ACIS_API_error(result); - if (CuttingToolSave2 != NULL) - AcisQueryEngine::instance()->delete_ACIS_BODY(CuttingToolSave2, CUBIT_TRUE); + if (body1Save != NULL) - AcisQueryEngine::instance()->delete_ACIS_BODY(body1Save, delete_owners); + AcisQueryEngine::instance()->delete_ACIS_BODY(body1Save, delete_owners); if (body2Save != NULL) - AcisQueryEngine::instance()->delete_ACIS_BODY(body2Save, delete_owners); + AcisQueryEngine::instance()->delete_ACIS_BODY(body2Save, delete_owners); return CUBIT_FAILURE; - } + } - // As the intersect operation was successful, the blank has already - // been deleted. - // So set the pointer to NULL so we don't try to delete it again. - CuttingToolSave2 = NULL; + // As the intersect operation was successful, the blank has already + // been deleted. + // So set the pointer to NULL so we don't try to delete it again. + CuttingToolSave2 = NULL; - // Debug output - if (webcut_debug_flag_on) - { - //Save the result of the subtract operation + // Debug output + if (webcut_debug_flag_on) + { + //Save the result of the subtract operation AcisQueryEngine::instance()->save_ENTITY_as_sat_file(body1Save, "Subtract.sat", "w"); - //Save the result of the intersect operation + //Save the result of the intersect operation AcisQueryEngine::instance()->save_ENTITY_as_sat_file(body2Save, "Intersect.sat", "w"); - } + } - // Check to make sure that the BODY resulting from the intersection - // operation is not NULL and it has at lease one valid LUMP. This - // would occur if there is no intersection between the 2 bodies - // being operated on. - if ( (body2Save == NULL) || (body2Save->lump() == NULL) ) - { + // Check to make sure that the BODY resulting from the intersection + // operation is not NULL and it has at lease one valid LUMP. This + // would occur if there is no intersection between the 2 bodies + // being operated on. + if ( (body2Save == NULL) || (body2Save->lump() == NULL) ) + { PRINT_WARNING("Cutting Tool does not intersect the original volume.\n" " The original volume is restored.\n" ); - + AcisQueryEngine::instance()->delete_ACIS_BODY(body1Save, delete_owners); AcisQueryEngine::instance()->delete_ACIS_BODY(body2Save, delete_owners); return CUBIT_FAILURE; - } - // Finally, set the BODY pointers, webcutBodyPtr1 and webcutBodyPtr2, to - // the resulting Acis BODYs (after the imprint operation) - webcutBody1 = body1Save; - webcutBody2 = body2Save; - AcisQueryEngine::instance()->clear_bounding_box( webcutBody1 ); - AcisQueryEngine::instance()->bounding_box( webcutBody1 ); - AcisQueryEngine::instance()->clear_bounding_box( webcutBody2 ); - AcisQueryEngine::instance()->bounding_box( webcutBody2 ); + } + // Finally, set the BODY pointers, webcutBodyPtr1 and webcutBodyPtr2, to + // the resulting Acis BODYs (after the imprint operation) + webcutBody1 = body1Save; + webcutBody2 = body2Save; + AcisQueryEngine::instance()->clear_bounding_box( webcutBody1 ); + AcisQueryEngine::instance()->bounding_box( webcutBody1 ); + AcisQueryEngine::instance()->clear_bounding_box( webcutBody2 ); + AcisQueryEngine::instance()->bounding_box( webcutBody2 ); - return CUBIT_SUCCESS; + return CUBIT_SUCCESS; } //------------------------------------------------------------------------- @@ -4441,15 +3905,15 @@ VERTEX* VERTEX_ptr = NULL; API_BEGIN; - // Create a new ACIS VERTEX -- it is not attached to a BODY - APOINT* APOINT_ptr = new APOINT ( point.x(), point.y(), point.z() ); + // Create a new ACIS VERTEX -- it is not attached to a BODY + APOINT* APOINT_ptr = new APOINT ( point.x(), point.y(), point.z() ); - if ( APOINT_ptr != NULL ) + if ( APOINT_ptr != NULL ) { VERTEX_ptr = new VERTEX ( APOINT_ptr ); } - else + else { PRINT_ERROR("In AcisModifyEngine::make_VERTEX\n" " ACIS could not make an APOINT object.\n" @@ -4457,8 +3921,8 @@ status = CUBIT_FAILURE; } - // Complain if ACIS wasn't able to create the VERTEX - if ( VERTEX_ptr == NULL && status == CUBIT_SUCCESS) + // Complain if ACIS wasn't able to create the VERTEX + if ( VERTEX_ptr == NULL && status == CUBIT_SUCCESS) { PRINT_ERROR("In AcisModifyEngine::make_VERTEX\n" " ACIS could not make a VERTEX object.\n"); @@ -4494,59 +3958,59 @@ // Creation Date : 03-27-97 //------------------------------------------------------------------------- EDGE* AcisModifyEngine::make_EDGE( GeometryType EDGE_type, - VERTEX* start_VERTEX, - VERTEX* end_VERTEX, - SPAposition* intermediate_point_ptr, + VERTEX* start_VERTEX, + VERTEX* end_VERTEX, + SPAposition* intermediate_point_ptr, bool sense ) const { - // Make sure the input VERTEX'es are non-NULL -- these are needed by - // all the EDGE generation routines. - if ( start_VERTEX == NULL || end_VERTEX == NULL ) - { + // Make sure the input VERTEX'es are non-NULL -- these are needed by + // all the EDGE generation routines. + if ( start_VERTEX == NULL || end_VERTEX == NULL ) + { PRINT_ERROR("In AcisModifyEngine::make_EDGE\n" " An input end VERTEX is invalid (NULL).\n"); assert (start_VERTEX != NULL && end_VERTEX != NULL); return (EDGE *)NULL; - } + } - // Make a straight EDGE - if ( EDGE_type == STRAIGHT_CURVE_TYPE ) - { + // Make a straight EDGE + if ( EDGE_type == STRAIGHT_CURVE_TYPE ) + { return make_straight_EDGE(start_VERTEX, end_VERTEX); - } + } - // Make a parabolic EDGE - else if ( EDGE_type == PARABOLA_CURVE_TYPE ) - { + // Make a parabolic EDGE + else if ( EDGE_type == PARABOLA_CURVE_TYPE ) + { return make_parabolic_EDGE( start_VERTEX, end_VERTEX, intermediate_point_ptr); - } + } - // Make an elliptical EDGE - else if ( EDGE_type == ELLIPSE_CURVE_TYPE ) - { + // Make an elliptical EDGE + else if ( EDGE_type == ELLIPSE_CURVE_TYPE ) + { return make_elliptical_EDGE( start_VERTEX, end_VERTEX, intermediate_point_ptr, sense); - } + } - else if (EDGE_type == ARC_CURVE_TYPE) - { - return make_circular_EDGE(start_VERTEX, - end_VERTEX, - intermediate_point_ptr); - } + else if (EDGE_type == ARC_CURVE_TYPE) + { + return make_circular_EDGE(start_VERTEX, + end_VERTEX, + intermediate_point_ptr); + } - // OOps!!!! - else - { + // OOps!!!! + else + { PRINT_ERROR("In AcisModifyEngine::make_EDGE\n" " Invalid curve type.\n"); assert (0 == 1); return (EDGE *)NULL; - } + } } // This function will create a supper cone using the info @@ -4556,110 +4020,110 @@ // in cubit. FACE* AcisModifyEngine::make_type_FACE( CONE *CONE_ptr ) const { - //Given this lets create another face that is extended from it. - CubitBox bounding_box = GeometryQueryTool::instance()->model_bounding_box(); + //Given this lets create another face that is extended from it. + CubitBox bounding_box = GeometryQueryTool::instance()->model_bounding_box(); - BODY *sheet_body; - CubitBoolean cylinder = CUBIT_FALSE; + BODY *sheet_body; + CubitBoolean cylinder = CUBIT_FALSE; - double const st_ang = 0.0; - double const end_ang = 2*CUBIT_PI; - double cost = CONE_ptr->cosine_angle(); - double sint = CONE_ptr->sine_angle(); - if ( sint == 0.0 && fabs(cost) == 1.0 ) - { - //This is a cylinder. - cylinder = CUBIT_TRUE; - } - SPAvector major_a = CONE_ptr->major_axis(); - SPAunit_vector normal_a = CONE_ptr->direction(); - double const radius_ratio = CONE_ptr->radius_ratio(); - double const height = 2*(bounding_box.diagonal()).length(); - SPAposition root = CONE_ptr->root_point(); - CubitVector elipse_radius, center_vec; - CubitVector temp_norm( normal_a.x(), normal_a.y(), normal_a.z()); - if ( !cylinder ) - { - if ( sint > 0.0 && cost > 0.0 ) - { - sint = -sint; - temp_norm *= -1.0; - } - else if ( sint < 0.0 && cost < 0.0 ) - { - cost = -cost; - temp_norm *= -1.0; - } - //First we need to calculate the new radius. - //Also calc the old height to find the new center SPAposition. - double theta_rad = acos(cost); - elipse_radius.set(major_a.x(), major_a.y(), major_a.z() ); - double old_radius = elipse_radius.length(); - double old_height = old_radius/tan(theta_rad); + double const st_ang = 0.0; + double const end_ang = 2*CUBIT_PI; + double cost = CONE_ptr->cosine_angle(); + double sint = CONE_ptr->sine_angle(); + if ( sint == 0.0 && fabs(cost) == 1.0 ) + { + //This is a cylinder. + cylinder = CUBIT_TRUE; + } + SPAvector major_a = CONE_ptr->major_axis(); + SPAunit_vector normal_a = CONE_ptr->direction(); + double const radius_ratio = CONE_ptr->radius_ratio(); + double const height = 2*(bounding_box.diagonal()).length(); + SPAposition root = CONE_ptr->root_point(); + CubitVector elipse_radius, center_vec; + CubitVector temp_norm( normal_a.x(), normal_a.y(), normal_a.z()); + if ( !cylinder ) + { + if ( sint > 0.0 && cost > 0.0 ) + { + sint = -sint; + temp_norm *= -1.0; + } + else if ( sint < 0.0 && cost < 0.0 ) + { + cost = -cost; + temp_norm *= -1.0; + } + //First we need to calculate the new radius. + //Also calc the old height to find the new center SPAposition. + double theta_rad = acos(cost); + elipse_radius.set(major_a.x(), major_a.y(), major_a.z() ); + double old_radius = elipse_radius.length(); + double old_height = old_radius/tan(theta_rad); - //make center of surface along axis, 1/2 height of - //bounding box of entire model. - CubitVector root_vec( root.x(), root.y(), root.z() ); - center_vec = root_vec + (-0.5*height)*temp_norm; + //make center of surface along axis, 1/2 height of + //bounding box of entire model. + CubitVector root_vec( root.x(), root.y(), root.z() ); + center_vec = root_vec + (-0.5*height)*temp_norm; - //calculate new radius - double new_radius = (old_height+ 0.5*height) * tan (theta_rad ); - elipse_radius.normalize(); - elipse_radius *= new_radius; - } - else - { - CubitVector root_vec( root.x(), root.y(), root.z() ); - center_vec = .5*height*temp_norm; - center_vec = root_vec - center_vec; - elipse_radius.set(major_a.x(), major_a.y(), major_a.z() ); - } - SPAvector const major_axis(elipse_radius.x(), elipse_radius.y(), elipse_radius.z() ); + //calculate new radius + double new_radius = (old_height+ 0.5*height) * tan (theta_rad ); + elipse_radius.normalize(); + elipse_radius *= new_radius; + } + else + { + CubitVector root_vec( root.x(), root.y(), root.z() ); + center_vec = .5*height*temp_norm; + center_vec = root_vec - center_vec; + elipse_radius.set(major_a.x(), major_a.y(), major_a.z() ); + } + SPAvector const major_axis(elipse_radius.x(), elipse_radius.y(), elipse_radius.z() ); - SPAunit_vector const normal_axis(temp_norm.x(), temp_norm.y(), temp_norm.z()); - SPAposition const center ( center_vec.x(), center_vec.y(), center_vec.z() ); + SPAunit_vector const normal_axis(temp_norm.x(), temp_norm.y(), temp_norm.z()); + SPAposition const center ( center_vec.x(), center_vec.y(), center_vec.z() ); - FACE *new_FACE_ptr = NULL; - outcome result = api_make_cnface( center, normal_axis, major_axis, - radius_ratio, sint, cost, st_ang, - end_ang, height, new_FACE_ptr ); - if (!result.ok() || new_FACE_ptr == NULL || - new_FACE_ptr->geometry() == NULL ) - { + FACE *new_FACE_ptr = NULL; + outcome result = api_make_cnface( center, normal_axis, major_axis, + radius_ratio, sint, cost, st_ang, + end_ang, height, new_FACE_ptr ); + if (!result.ok() || new_FACE_ptr == NULL || + new_FACE_ptr->geometry() == NULL ) + { PRINT_ERROR("In AcisModifyEngine::make_type_FACE(cone)\n" " ACIS api_make_cnface function failed.\n\n"); AcisQueryEngine::instance()->ACIS_API_error (result); return (FACE *)NULL; - } - FACE *face_list[1]; - face_list[0] = new_FACE_ptr; - result = api_sheet_from_ff( 1, face_list, sheet_body ); - if (!result.ok() || sheet_body == NULL || sheet_body->lump() == NULL - || sheet_body->lump()->shell() == NULL || - sheet_body->lump()->shell()->first_face() == NULL ) - { + } + FACE *face_list[1]; + face_list[0] = new_FACE_ptr; + result = api_sheet_from_ff( 1, face_list, sheet_body ); + if (!result.ok() || sheet_body == NULL || sheet_body->lump() == NULL + || sheet_body->lump()->shell() == NULL || + sheet_body->lump()->shell()->first_face() == NULL ) + { PRINT_ERROR("In AcisModifyEngine::make_type_FACE(cone)\n" " ACIS api_sheet_from_ff function failed.\n\n"); AcisQueryEngine::instance()->ACIS_API_error (result); return (FACE *)NULL; - } - result = api_body_to_2d( sheet_body ); - if (!result.ok()) - { + } + result = api_body_to_2d( sheet_body ); + if (!result.ok()) + { PRINT_ERROR("In AcisModifyEngine::make_type_FACE(cone)\n" " ACIS api_body_to_2d function failed.\n\n"); AcisQueryEngine::instance()->ACIS_API_error (result); return (FACE *)NULL; - } - int debug_flg = 0; - // Save the BODY being cut, if debug is on - if (debug_flg) - { + } + int debug_flg = 0; + // Save the BODY being cut, if debug is on + if (debug_flg) + { AcisQueryEngine::instance()->save_ENTITY_as_sat_file(sheet_body, "cone_sheet.sat", "w"); - } + } - return sheet_body->lump()->shell()->first_face(); + return sheet_body->lump()->shell()->first_face(); } // This function will create a sphere face using the info // from the existing sphere. It is actually a face or sheet @@ -4667,73 +4131,73 @@ // will be the grand sphere itself, not a section of it. FACE* AcisModifyEngine::make_type_FACE( SPHERE *SPHERE_ptr ) const { - BODY *sheet_body; + BODY *sheet_body; - BODY *sphere_body; - SPAposition const center = SPHERE_ptr->centre(); - double const radius = SPHERE_ptr->radius(); + BODY *sphere_body; + SPAposition const center = SPHERE_ptr->centre(); + double const radius = SPHERE_ptr->radius(); - //make a sphere body then move it to the give place. - outcome result = api_make_sphere( radius, sphere_body ); - if (!result.ok() || sphere_body == NULL || - sphere_body->lump() == NULL || - sphere_body->lump()->shell() == NULL || - sphere_body->lump()->shell()->first_face() == NULL ) - { + //make a sphere body then move it to the give place. + outcome result = api_make_sphere( radius, sphere_body ); + if (!result.ok() || sphere_body == NULL || + sphere_body->lump() == NULL || + sphere_body->lump()->shell() == NULL || + sphere_body->lump()->shell()->first_face() == NULL ) + { PRINT_ERROR("In AcisModifyEngine::make_type_FACE(sphere)\n" " ACIS api_make_sphere function failed.\n\n"); AcisQueryEngine::instance()->ACIS_API_error (result); return (FACE *)NULL; - } - //now move the body. - SPAvector translation_vector( center.x(), center.y(), center.z() ); - result = api_apply_transf ( sphere_body, - translate_transf (translation_vector) ); - if ( !result.ok() ) - { + } + //now move the body. + SPAvector translation_vector( center.x(), center.y(), center.z() ); + result = api_apply_transf ( sphere_body, + translate_transf (translation_vector) ); + if ( !result.ok() ) + { PRINT_ERROR("In AcisModifyEngine::make_type_FACE(sphere)\n" " ACIS api_aply_transf function failed.\n\n"); AcisQueryEngine::instance()->ACIS_API_error ( result, "transforming body" ); return (FACE*)NULL; - } - TRANSFORM* identity = new TRANSFORM(scale_transf(1.0)); - result = api_change_body_trans ( sphere_body, identity, FALSE ); - identity->lose(); - if (!result.ok()) - { + } + TRANSFORM* identity = new TRANSFORM(scale_transf(1.0)); + result = api_change_body_trans ( sphere_body, identity, FALSE ); + identity->lose(); + if (!result.ok()) + { AcisQueryEngine::instance()->ACIS_API_error ( result, "transforming body" ); return (FACE*)NULL; - } - //The bounding SPAbox does not get re-computed, so we need - //to do it. - AcisQueryEngine::instance()->clear_bounding_box( sphere_body ); - AcisQueryEngine::instance()->bounding_box(sphere_body); + } + //The bounding SPAbox does not get re-computed, so we need + //to do it. + AcisQueryEngine::instance()->clear_bounding_box( sphere_body ); + AcisQueryEngine::instance()->bounding_box(sphere_body); - FACE *face_list[1]; - face_list[0] = sphere_body->lump()->shell()->first_face(); - result = api_sheet_from_ff( 1, face_list, sheet_body ); - if (!result.ok() || sheet_body == NULL || sheet_body->lump() == NULL - || sheet_body->lump()->shell() == NULL || - sheet_body->lump()->shell()->first_face() == NULL ) - { + FACE *face_list[1]; + face_list[0] = sphere_body->lump()->shell()->first_face(); + result = api_sheet_from_ff( 1, face_list, sheet_body ); + if (!result.ok() || sheet_body == NULL || sheet_body->lump() == NULL + || sheet_body->lump()->shell() == NULL || + sheet_body->lump()->shell()->first_face() == NULL ) + { PRINT_ERROR("In AcisModifyEngine::make_type_FACE(sphere)\n" " ACIS api_sheet_from_ff function failed.\n\n"); AcisQueryEngine::instance()->ACIS_API_error (result); return (FACE *)NULL; - } - result = api_body_to_2d( sheet_body ); - if (!result.ok()) - { + } + result = api_body_to_2d( sheet_body ); + if (!result.ok()) + { PRINT_ERROR("In AcisModifyEngine::make_type_FACE(sphere)\n" " ACIS api_body_to_2d function failed.\n\n"); AcisQueryEngine::instance()->ACIS_API_error (result); return (FACE *)NULL; - } - AcisQueryEngine::instance()->delete_ACIS_BODY(sphere_body, CUBIT_TRUE); + } + AcisQueryEngine::instance()->delete_ACIS_BODY(sphere_body, CUBIT_TRUE); - return sheet_body->lump()->shell()->first_face(); + return sheet_body->lump()->shell()->first_face(); } // This function will create a torus face using the info // from the existing torus. It is actually a face or sheet @@ -4742,66 +4206,66 @@ FACE* AcisModifyEngine::make_type_FACE( TORUS *TORUS_ptr ) const { if ( TORUS_ptr == NULL ) - { - PRINT_ERROR("NULL pointer passed to make face from. (torus).\n"); - return (FACE*)NULL; - } + { + PRINT_ERROR("NULL pointer passed to make face from. (torus).\n"); + return (FACE*)NULL; + } - BODY *sheet_body; - SPAposition const center = TORUS_ptr->centre(); - SPAunit_vector const normal = TORUS_ptr->normal(); - double const uf = 0.0; - double const ut = 2*CUBIT_PI; - double const vf = 0.0; - double const vt = 2*CUBIT_PI; - double const major_radius = TORUS_ptr->major_radius(); - double const minor_radius = TORUS_ptr->minor_radius(); - CubitVector temp_center(center.x(), center.y(), center.z()); - CubitVector temp_normal(normal.x(), normal.y(), normal.z()); - temp_normal.normalize(); - CubitVector temp_point = temp_center + major_radius*temp_normal; - SPAposition const point(temp_point.x(), temp_point.y(), temp_point.z()); + BODY *sheet_body; + SPAposition const center = TORUS_ptr->centre(); + SPAunit_vector const normal = TORUS_ptr->normal(); + double const uf = 0.0; + double const ut = 2*CUBIT_PI; + double const vf = 0.0; + double const vt = 2*CUBIT_PI; + double const major_radius = TORUS_ptr->major_radius(); + double const minor_radius = TORUS_ptr->minor_radius(); + CubitVector temp_center(center.x(), center.y(), center.z()); + CubitVector temp_normal(normal.x(), normal.y(), normal.z()); + temp_normal.normalize(); + CubitVector temp_point = temp_center + major_radius*temp_normal; + SPAposition const point(temp_point.x(), temp_point.y(), temp_point.z()); - //make a torus body then move it to the give place. - FACE *new_FACE_ptr = NULL; - outcome result = api_make_trface( center, normal, major_radius, - minor_radius, point, - uf, ut, vf, vt, new_FACE_ptr ); - if (!result.ok() || new_FACE_ptr == NULL ) - { + //make a torus body then move it to the give place. + FACE *new_FACE_ptr = NULL; + outcome result = api_make_trface( center, normal, major_radius, + minor_radius, point, + uf, ut, vf, vt, new_FACE_ptr ); + if (!result.ok() || new_FACE_ptr == NULL ) + { PRINT_ERROR("In AcisModifyEngine::make_type_FACE(torus)\n" " ACIS api_make_trface function failed.\n\n"); AcisQueryEngine::instance()->ACIS_API_error (result); return (FACE *)NULL; - } - FACE *face_list[1]; - face_list[0] = new_FACE_ptr; - result = api_sheet_from_ff( 1, face_list, sheet_body ); - if (!result.ok() || sheet_body == NULL || sheet_body->lump() == NULL - || sheet_body->lump()->shell() == NULL || - sheet_body->lump()->shell()->first_face() == NULL ) - { + } + FACE *face_list[1]; + face_list[0] = new_FACE_ptr; + result = api_sheet_from_ff( 1, face_list, sheet_body ); + if (!result.ok() || sheet_body == NULL || sheet_body->lump() == NULL + || sheet_body->lump()->shell() == NULL || + sheet_body->lump()->shell()->first_face() == NULL ) + { PRINT_ERROR("In AcisModifyEngine::make_type_FACE(torus)\n" " ACIS api_sheet_from_ff function failed.\n\n"); AcisQueryEngine::instance()->ACIS_API_error (result); return (FACE *)NULL; - } - result = api_body_to_2d( sheet_body ); - if (!result.ok()) - { + } + result = api_body_to_2d( sheet_body ); + if (!result.ok()) + { PRINT_ERROR("In AcisModifyEngine::make_type_FACE(torus)\n" " ACIS api_body_to_2d function failed.\n\n"); AcisQueryEngine::instance()->ACIS_API_error (result); return (FACE *)NULL; - } - int debug_flg = 0; - // Save the BODY being cut, if debug is on - if (debug_flg) - { + } + int debug_flg = 0; + // Save the BODY being cut, if debug is on + if (debug_flg) + { AcisQueryEngine::instance()->save_ENTITY_as_sat_file(sheet_body, "torus_sheet.sat", "w"); - } + } - return sheet_body->lump()->shell()->first_face(); + return sheet_body->lump()->shell()->first_face(); } // This function will create a spline face using the info // from the existing spline. It is actually a face or sheet @@ -4809,36 +4273,36 @@ // will be the grand spline itself, not a section of it. FACE* AcisModifyEngine::make_type_FACE( SPLINE *SPLINE_ptr ) const { - BODY *sheet_body; - PRINT_WARNING("Extents of spline will be only as far as\n" - "the spline definition, this really isn't an infinite surface.\n"); + BODY *sheet_body; + PRINT_WARNING("Extents of spline will be only as far as\n" + "the spline definition, this really isn't an infinite surface.\n"); - //use the geometry to make the spline body. - surface const *this_spline = &(SPLINE_ptr->equation()); + //use the geometry to make the spline body. + surface const *this_spline = &(SPLINE_ptr->equation()); - //make a spline body then move it to the give place. - outcome result = api_make_spline( *((spline*)this_spline), sheet_body ); - if (!result.ok() || sheet_body == NULL || - sheet_body->lump() == NULL || - sheet_body->lump()->shell() == NULL || - sheet_body->lump()->shell()->first_face() == NULL || - sheet_body->lump()->shell()->first_face()->geometry() == NULL ) - { + //make a spline body then move it to the give place. + outcome result = api_make_spline( *((spline*)this_spline), sheet_body ); + if (!result.ok() || sheet_body == NULL || + sheet_body->lump() == NULL || + sheet_body->lump()->shell() == NULL || + sheet_body->lump()->shell()->first_face() == NULL || + sheet_body->lump()->shell()->first_face()->geometry() == NULL ) + { PRINT_ERROR("In AcisModifyEngine::make_type_FACE(spline)\n" " ACIS api_make_spline function failed.\n\n"); AcisQueryEngine::instance()->ACIS_API_error (result); return (FACE *)NULL; - } - result = api_body_to_2d( sheet_body ); - if (!result.ok()) - { + } + result = api_body_to_2d( sheet_body ); + if (!result.ok()) + { PRINT_ERROR("In AcisModifyEngine::make_type_FACE(spline)\n" " ACIS api_body_to_2d function failed.\n\n"); AcisQueryEngine::instance()->ACIS_API_error (result); return (FACE *)NULL; - } + } - return sheet_body->lump()->shell()->first_face(); + return sheet_body->lump()->shell()->first_face(); } // This function will create a plane face using the info // from the existing plane. It is actually a face or sheet @@ -4846,37 +4310,37 @@ // will be the grand plane itself, not a section of it. FACE* AcisModifyEngine::make_type_FACE( PLANE *PLANE_ptr ) const { - //first lets find 3 points. - SPAposition point_1, point_2, point_3; - SPApar_pos const pos_1( 0, 1 ); - SPApar_pos const pos_2( 1, 0 ); - SPApar_pos const pos_3( 0, 0 ); - PLANE_ptr->equation().eval( pos_1, point_1 ); - PLANE_ptr->equation().eval( pos_2, point_2 ); - PLANE_ptr->equation().eval( pos_3, point_3 ); + //first lets find 3 points. + SPAposition point_1, point_2, point_3; + SPApar_pos const pos_1( 0, 1 ); + SPApar_pos const pos_2( 1, 0 ); + SPApar_pos const pos_3( 0, 0 ); + PLANE_ptr->equation().eval( pos_1, point_1 ); + PLANE_ptr->equation().eval( pos_2, point_2 ); + PLANE_ptr->equation().eval( pos_3, point_3 ); - CubitBox cubit_super_box = GeometryQueryTool::instance()->model_bounding_box(); - SPAbox super_box = AcisQueryEngine::bounding_box(cubit_super_box); + CubitBox cubit_super_box = GeometryQueryTool::instance()->model_bounding_box(); + SPAbox super_box = AcisQueryEngine::bounding_box(cubit_super_box); - CubitVector vec_1( point_1.x(), point_1.y(), point_1.z() ); - CubitVector vec_2( point_2.x(), point_2.y(), point_2.z() ); - CubitVector vec_3( point_3.x(), point_3.y(), point_3.z() ); + CubitVector vec_1( point_1.x(), point_1.y(), point_1.z() ); + CubitVector vec_2( point_2.x(), point_2.y(), point_2.z() ); + CubitVector vec_3( point_3.x(), point_3.y(), point_3.z() ); - BODY *sheet_body = this->create_infinite_plane_cutting_tool( - vec_1, vec_2, vec_3, super_box, CUBIT_TRUE ); - if (sheet_body == NULL || - sheet_body->lump() == NULL || - sheet_body->lump()->shell() == NULL || - sheet_body->lump()->shell()->first_face() == NULL || - sheet_body->lump()->shell()->first_face()->geometry() == NULL ) - { - //webcut_failed(refbody_cleanup_list, BODY_cleanup_list); + BODY *sheet_body = this->create_infinite_plane_cutting_tool( + vec_1, vec_2, vec_3, super_box, CUBIT_TRUE ); + if (sheet_body == NULL || + sheet_body->lump() == NULL || + sheet_body->lump()->shell() == NULL || + sheet_body->lump()->shell()->first_face() == NULL || + sheet_body->lump()->shell()->first_face()->geometry() == NULL ) + { + //webcut_failed(refbody_cleanup_list, BODY_cleanup_list); PRINT_ERROR("In AcisModifyEngine::make_type_FACE(plane)" " Cannot create infinite plane cutting tool using \n" " the give surface. \n"); return (FACE*)NULL; - } - return sheet_body->lump()->shell()->first_face(); + } + return sheet_body->lump()->shell()->first_face(); } //------------------------------------------------------------------------- // Purpose : Create a face from the face pointer. This will create @@ -4888,66 +4352,66 @@ // Creation Date : 10/6/97 //------------------------------------------------------------------------- FACE* AcisModifyEngine::make_FACE(FACE* FACE_ptr, - CubitBoolean extended_from) const + CubitBoolean extended_from) const { if (FACE_ptr == NULL) return NULL; if (extended_from == CUBIT_TRUE) - { + { // We need to get the type of surface. // For some reason I can't get it to cast on the fly. - SURFACE *SURFACE_ptr = FACE_ptr->geometry(); - int type = SURFACE_ptr->identity(); - if (type == CONE_TYPE) - return make_type_FACE((CONE*)SURFACE_ptr); - else if (type == SPHERE_TYPE) - return make_type_FACE((SPHERE*)SURFACE_ptr); - else if (type == TORUS_TYPE) - return make_type_FACE((TORUS*)SURFACE_ptr); - else if (type == SPLINE_TYPE) - return make_type_FACE((SPLINE*)SURFACE_ptr); - else if (type == PLANE_TYPE) - return make_type_FACE((PLANE*)SURFACE_ptr); - else - return NULL; - } + SURFACE *SURFACE_ptr = FACE_ptr->geometry(); + int type = SURFACE_ptr->identity(); + if (type == CONE_TYPE) + return make_type_FACE((CONE*)SURFACE_ptr); + else if (type == SPHERE_TYPE) + return make_type_FACE((SPHERE*)SURFACE_ptr); + else if (type == TORUS_TYPE) + return make_type_FACE((TORUS*)SURFACE_ptr); + else if (type == SPLINE_TYPE) + return make_type_FACE((SPLINE*)SURFACE_ptr); + else if (type == PLANE_TYPE) + return make_type_FACE((PLANE*)SURFACE_ptr); + else + return NULL; + } FACE *face_list[1]; BODY *sheet_body; face_list[0] = FACE_ptr; - // Make a FACE from copy_FACE. + // Make a FACE from copy_FACE. outcome rc = api_sheet_from_ff(1, face_list, sheet_body); - // Now check to see if we created the sheet successfully. + // Now check to see if we created the sheet successfully. if (!rc.ok()) - { - PRINT_ERROR("In AcisModifyEngine::make_FACE\n" - " ACIS api_sheet_from_ff function failed.\n\n"); - AcisQueryEngine::instance()->ACIS_API_error (rc); - return (FACE *)NULL; - } + { + PRINT_ERROR("In AcisModifyEngine::make_FACE\n" + " ACIS api_sheet_from_ff function failed.\n\n"); + AcisQueryEngine::instance()->ACIS_API_error (rc); + return (FACE *)NULL; + } - // Convert the FACE to a true sheet BODY. + // Convert the FACE to a true sheet BODY. outcome rc_2 = api_body_to_2d(sheet_body); if (!rc_2.ok()) - { - PRINT_ERROR("In AcisModifyEngine::make_FACE\n" - " ACIS api_body_to_2d function failed.\n\n"); - AcisQueryEngine::instance()->ACIS_API_error (rc_2); - return (FACE *)NULL; - } + { + PRINT_ERROR("In AcisModifyEngine::make_FACE\n" + " ACIS api_body_to_2d function failed.\n\n"); + AcisQueryEngine::instance()->ACIS_API_error (rc_2); + return (FACE *)NULL; + } - // Make sure we were successful + // Make sure we were successful if ( sheet_body->lump() == NULL || sheet_body->lump()->shell() == NULL || sheet_body->lump()->shell()->first_face() == NULL ) - { - PRINT_ERROR("In AcisModifyEngine::make_FACE\n" - " ACIS api_sheet_from_ff function failed.\n\n"); - return (FACE*)NULL; - } + { + PRINT_ERROR("In AcisModifyEngine::make_FACE\n" + " ACIS api_sheet_from_ff function failed.\n\n"); + return (FACE*)NULL; + } return sheet_body->lump()->shell()->first_face(); } @@ -4968,26 +4432,26 @@ DLIList<EDGE*>& input_EDGE_list, Surface *old_surface_ptr) const { - // Make sure a supported type of surface is being requested. + // Make sure a supported type of surface is being requested. if ( FACE_type != PLANE_SURFACE_TYPE && FACE_type != BEST_FIT_SURFACE_TYPE) - { - PRINT_WARNING("In AcisGeometryEngine::make_FACE\n" - " At this time, cannot make a FACE that isn't" - " planar or best fit.\n"); - return (FACE *)NULL; - } + { + PRINT_WARNING("In AcisGeometryEngine::make_FACE\n" + " At this time, cannot make a FACE that isn't" + " planar or best fit.\n"); + return (FACE *)NULL; + } - // Set the FACE pointer, if requested. + // Set the FACE pointer, if requested. FACE *fit_FACE = NULL; if ( old_surface_ptr != NULL ) - { - SurfaceACIS *surf_ACIS = CAST_TO(old_surface_ptr, SurfaceACIS ); - fit_FACE = surf_ACIS->get_FACE_ptr(); - } + { + SurfaceACIS *surf_ACIS = CAST_TO(old_surface_ptr, SurfaceACIS ); + fit_FACE = surf_ACIS->get_FACE_ptr(); + } - // Copy the original EDGEs and put them into an array. - // Also initialize variables that will be used/returned by ACIS. + // Copy the original EDGEs and put them into an array. + // Also initialize variables that will be used/returned by ACIS. int edge_count = input_EDGE_list.size(); FACE* FACE_ptr = NULL; BODY* wire_BODY = NULL; @@ -4997,12 +4461,12 @@ int i; for (i = 0 ; i < edge_count ; i++) - { - copy_single_entity( (ENTITY *)input_EDGE_list.get_and_step(), temp_ENTITY_ptr); - EDGEs[i] = (EDGE*)temp_ENTITY_ptr; + { + copy_single_entity( (ENTITY *)input_EDGE_list.get_and_step(), temp_ENTITY_ptr); + EDGEs[i] = (EDGE*)temp_ENTITY_ptr; // Deactivate the RefEntities attached to the EDGE and its VERTEXes. - mark_owners_deactivated_flag(EDGEs[i], CUBIT_TRUE, CUBIT_TRUE); - } + mark_owners_deactivated_flag(EDGEs[i], CUBIT_TRUE, CUBIT_TRUE); + } // Make a wire BODY from the copied EDGEs. // Coincident VERTEXes will be deleted by ACIS. @@ -5015,116 +4479,116 @@ wire_BODYs.add( wireBODYs[i] ); if ( !result.ok() || wire_BODYs.count() == 0 ) - { - PRINT_ERROR("In AcisGeometryEngine::make_FACE\n" - " ACIS api_make_ewire function failed.\n\n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - if (wire_BODYs.count()) - for(i=0; i<wire_BODYs.count(); i++ ) - api_delent(wire_BODYs[i]); - else { - while (edge_count--) - api_delent(EDGEs[edge_count]); + PRINT_ERROR("In AcisGeometryEngine::make_FACE\n" + " ACIS api_make_ewire function failed.\n\n"); + AcisQueryEngine::instance()->ACIS_API_error (result); + if (wire_BODYs.count()) + for(i=0; i<wire_BODYs.count(); i++ ) + api_delent(wire_BODYs[i]); + else + { + while (edge_count--) + api_delent(EDGEs[edge_count]); + } + + delete [] EDGEs; + return (FACE *)NULL; } - delete [] EDGEs; - return (FACE *)NULL; - } - - // Check to make sure the wire is closed + // Check to make sure the wire is closed for(i=0; i<wire_BODYs.count(); i++ ) - { - result = api_closed_wire( (BODY*)wire_BODYs[i] ); - if( !result.ok() ) { - PRINT_ERROR( "ACIS reports that a closed loop was not found\n" ); - // Delete the wire BODY. This will also delete - // each copied EDGE - for(i=0; i<wire_BODYs.count(); i++ ) - api_delent(wire_BODYs[i]); - // Delete the array - delete [] EDGEs; - return (FACE *)NULL; + result = api_closed_wire( (BODY*)wire_BODYs[i] ); + if( !result.ok() ) + { + PRINT_ERROR( "ACIS reports that a closed loop was not found\n" ); + // Delete the wire BODY. This will also delete + // each copied EDGE + for(i=0; i<wire_BODYs.count(); i++ ) + api_delent(wire_BODYs[i]); + // Delete the array + delete [] EDGEs; + return (FACE *)NULL; + } } - } //check planarity & co-planarity if( wire_BODYs.count() > 1 ) - { - CubitVector master_centroid; - CubitVector master_normal; - for(i=0; i<wire_BODYs.count(); i++ ) { - SPAposition centroid; - SPAunit_vector normal; + CubitVector master_centroid; + CubitVector master_normal; + for(i=0; i<wire_BODYs.count(); i++ ) + { + SPAposition centroid; + SPAunit_vector normal; - if( !is_planar_wire( (WIRE*)wire_BODYs[i], centroid, normal ) ) - { - PRINT_ERROR( "Multiple loops must be planar.\n" ); - for(i=0; i<wire_BODYs.count(); i++ ) - api_delent(wire_BODYs[i]); - delete [] EDGEs; - return (FACE *)NULL; - } - //make the plane - if( i==0 ) - { - master_centroid.set( centroid.x(), centroid.y(), centroid.z() ); - master_normal.set( normal.x(), normal.y(), normal.z() ); - } - else - { - CubitVector tmp_centroid( centroid.x(), centroid.y(), centroid.z() ); - CubitVector tmp_normal( normal.x(), normal.y(), normal.z() ); - CubitVector tmp_vec( tmp_centroid - master_centroid ); - tmp_vec.normalize(); - double dot = master_normal % tmp_vec; - tmp_normal = tmp_normal * master_normal; + if( !is_planar_wire( (WIRE*)wire_BODYs[i], centroid, normal ) ) + { + PRINT_ERROR( "Multiple loops must be planar.\n" ); + for(i=0; i<wire_BODYs.count(); i++ ) + api_delent(wire_BODYs[i]); + delete [] EDGEs; + return (FACE *)NULL; + } + //make the plane + if( i==0 ) + { + master_centroid.set( centroid.x(), centroid.y(), centroid.z() ); + master_normal.set( normal.x(), normal.y(), normal.z() ); + } + else + { + CubitVector tmp_centroid( centroid.x(), centroid.y(), centroid.z() ); + CubitVector tmp_normal( normal.x(), normal.y(), normal.z() ); + CubitVector tmp_vec( tmp_centroid - master_centroid ); + tmp_vec.normalize(); + double dot = master_normal % tmp_vec; + tmp_normal = tmp_normal * master_normal; - if( tmp_normal.length() > GEOMETRY_RESABS || - fabs(dot) > GEOMETRY_RESABS ) - { - PRINT_ERROR( "Multiple loops must be co-planar.\n" ); - for(i=0; i<wire_BODYs.count(); i++ ) - api_delent(wire_BODYs[i]); - delete [] EDGEs; - return (FACE *)NULL; - } - } + if( tmp_normal.length() > GEOMETRY_RESABS || + fabs(dot) > GEOMETRY_RESABS ) + { + PRINT_ERROR( "Multiple loops must be co-planar.\n" ); + for(i=0; i<wire_BODYs.count(); i++ ) + api_delent(wire_BODYs[i]); + delete [] EDGEs; + return (FACE *)NULL; + } + } + } } - } //check intersecting if( wire_BODYs.count() > 1 ) - { - for(i=0; i<wire_BODYs.count(); i++ ) { - ENTITY *ent1 = wire_BODYs[i]; + for(i=0; i<wire_BODYs.count(); i++ ) + { + ENTITY *ent1 = wire_BODYs[i]; - int j; - for(j=0; j<wire_BODYs.count(); j++ ) - { - if( i==j ) - continue; + int j; + for(j=0; j<wire_BODYs.count(); j++ ) + { + if( i==j ) + continue; - ENTITY *ent2 = wire_BODYs[j]; - logical touching = FALSE; + ENTITY *ent2 = wire_BODYs[j]; + logical touching = FALSE; - api_entity_entity_touch( ent1, ent2, touching ); + api_entity_entity_touch( ent1, ent2, touching ); - if( touching ) - { - PRINT_ERROR( "Multiple loops cannot intersect.\n" ); - for(i=0; i<wire_BODYs.count(); i++ ) - api_delent(wire_BODYs[i]); - delete [] EDGEs; - return (FACE *)NULL; - } - } + if( touching ) + { + PRINT_ERROR( "Multiple loops cannot intersect.\n" ); + for(i=0; i<wire_BODYs.count(); i++ ) + api_delent(wire_BODYs[i]); + delete [] EDGEs; + return (FACE *)NULL; + } + } + } } - } //sort wires so that the outermost is first wire_BODYs.init(); @@ -5132,256 +4596,256 @@ ENTITY *outermost_wire= NULL; double longest_diagonal = 0.0; if( wire_BODYs.count() > 1 ) - { - for(i=0; i<wire_BODYs.count(); i++ ) { - SPAbox tmp_box; - CubitBox tmp_cbox; - ENTITY *tmp_wire = wire_BODYs.next(); - if(i==0) - { - tmp_box = AcisQueryEngine::instance()->bounding_box( (BODY*)tmp_wire); - outermost_wire = tmp_wire; - tmp_cbox = AcisQueryEngine::bounding_box( tmp_box ); - longest_diagonal = tmp_cbox.diagonal().length(); - } - else - { - tmp_box = AcisQueryEngine::instance()->bounding_box( (BODY*)tmp_wire); - tmp_cbox = AcisQueryEngine::bounding_box( tmp_box ); + for(i=0; i<wire_BODYs.count(); i++ ) + { + SPAbox tmp_box; + CubitBox tmp_cbox; + ENTITY *tmp_wire = wire_BODYs.next(); + if(i==0) + { + tmp_box = AcisQueryEngine::instance()->bounding_box( (BODY*)tmp_wire); + outermost_wire = tmp_wire; + tmp_cbox = AcisQueryEngine::bounding_box( tmp_box ); + longest_diagonal = tmp_cbox.diagonal().length(); + } + else + { + tmp_box = AcisQueryEngine::instance()->bounding_box( (BODY*)tmp_wire); + tmp_cbox = AcisQueryEngine::bounding_box( tmp_box ); - if( tmp_cbox.diagonal().length() > longest_diagonal ) - { - longest_diagonal = tmp_cbox.diagonal().length(); - outermost_wire = tmp_wire; - } - } - } + if( tmp_cbox.diagonal().length() > longest_diagonal ) + { + longest_diagonal = tmp_cbox.diagonal().length(); + outermost_wire = tmp_wire; + } + } + } - //now that we found the outermost, put it first in the list - wire_BODYs.clear(); - tmp_wire_BODYs.remove( outermost_wire ); - wire_BODYs.add( outermost_wire ); + //now that we found the outermost, put it first in the list + wire_BODYs.clear(); + tmp_wire_BODYs.remove( outermost_wire ); + wire_BODYs.add( outermost_wire ); - tmp_wire_BODYs.init(); - for(i=0; i<tmp_wire_BODYs.count(); i++ ) - wire_BODYs.add( tmp_wire_BODYs.next() ); - } + tmp_wire_BODYs.init(); + for(i=0; i<tmp_wire_BODYs.count(); i++ ) + wire_BODYs.add( tmp_wire_BODYs.next() ); + } - // Use the WIRE to make a FACE. - // Note that the call to api_cover_wires creates not - // only the FACE but the entire topological data - // structure above FACE (till BODY). + // Use the WIRE to make a FACE. + // Note that the call to api_cover_wires creates not + // only the FACE but the entire topological data + // structure above FACE (till BODY). ENTITY_LIST acis_FACE_list; if ( fit_FACE != NULL ) - { - wire_BODY = static_cast<BODY*>(wire_BODYs[0]); - outcome result_2 = api_cover_wires ( wire_BODY, - fit_FACE->geometry()->equation(), - acis_FACE_list ); + { + wire_BODY = static_cast<BODY*>(wire_BODYs[0]); + outcome result_2 = api_cover_wires ( wire_BODY, + fit_FACE->geometry()->equation(), + acis_FACE_list ); // Now check to see if we covered the wire successfully - if ( !result_2.ok() || acis_FACE_list.count() == 0 || - wire_BODY == NULL ) - { - PRINT_ERROR("Error in constructing surface on top of another" - "surface, the edges must fit the surface...\n"); - AcisQueryEngine::instance()->ACIS_API_error (result_2); - acis_FACE_list.clear(); - if (wire_BODY) - api_delent(wire_BODY); - else - // TO DO: Delete each EDGE in EDGEs - void (0); - delete [] EDGEs; - return (FACE*)NULL; + if ( !result_2.ok() || acis_FACE_list.count() == 0 || + wire_BODY == NULL ) + { + PRINT_ERROR("Error in constructing surface on top of another" + "surface, the edges must fit the surface...\n"); + AcisQueryEngine::instance()->ACIS_API_error (result_2); + acis_FACE_list.clear(); + if (wire_BODY) + api_delent(wire_BODY); + else + // TO DO: Delete each EDGE in EDGEs + void (0); + delete [] EDGEs; + return (FACE*)NULL; + } } - } else - { - outcome surface_creation; - bool valid_loops = true; - outcome loop_check; - - //can create non-planar surfs with one wire - if( wire_BODYs.count() == 1 ) { - wire_BODY = static_cast<BODY*>(wire_BODYs[0]); - surface_creation = api_cover_wires ( wire_BODY, - *(surface*)NULL_REF, - acis_FACE_list ); - } - else - { - wire_BODY = NULL; - surface_creation = api_cover_wire_loops( wire_BODYs, - wire_BODY); - //check all nested in largest - //check doubly nested - api_get_faces( wire_BODY, acis_FACE_list); - loop_check = api_check_face_loops( static_cast<FACE*>(acis_FACE_list[0]) ); - if( !loop_check.ok() ) - valid_loops = false; - } + outcome surface_creation; + bool valid_loops = true; + outcome loop_check; + //can create non-planar surfs with one wire + if( wire_BODYs.count() == 1 ) + { + wire_BODY = static_cast<BODY*>(wire_BODYs[0]); + surface_creation = api_cover_wires ( wire_BODY, + *(surface*)NULL_REF, + acis_FACE_list ); + } + else + { + wire_BODY = NULL; + surface_creation = api_cover_wire_loops( wire_BODYs, + wire_BODY); + //check all nested in largest + //check doubly nested + api_get_faces( wire_BODY, acis_FACE_list); + loop_check = api_check_face_loops( static_cast<FACE*>(acis_FACE_list[0]) ); + if( !loop_check.ok() ) + valid_loops = false; + } - if ( !surface_creation.ok() || wire_BODY == NULL || - !valid_loops || acis_FACE_list.count() != 1 ) - { - PRINT_ERROR("In AcisGeometryEngine::make_FACE\n" - " problem covering wires.\n\n"); - if( !surface_creation.ok() ) - AcisQueryEngine::instance()->ACIS_API_error (surface_creation); - if( !valid_loops ) - AcisQueryEngine::instance()->ACIS_API_error( loop_check ); + if ( !surface_creation.ok() || wire_BODY == NULL || + !valid_loops || acis_FACE_list.count() != 1 ) + { + PRINT_ERROR("In AcisGeometryEngine::make_FACE\n" + " problem covering wires.\n\n"); + if( !surface_creation.ok() ) + AcisQueryEngine::instance()->ACIS_API_error (surface_creation); + if( !valid_loops ) + AcisQueryEngine::instance()->ACIS_API_error( loop_check ); + + acis_FACE_list.clear(); + if (wire_BODY) + api_delent(wire_BODY); + else + { + // TO DO: delete each EDGE in EDGEs + void(0); + + wire_BODYs.init(); + ENTITY *ent_to_del; + while( (ent_to_del = wire_BODYs.next())!=NULL ) + api_delent( ent_to_del ); + } + delete [] EDGEs; + return (FACE *)NULL; + } + } + if (acis_FACE_list.count() != 1) + { + PRINT_ERROR("ACIS api_cover_wires function created " + "more than one FACE.\n" + " At this time, we cannot deal with this.\n"); acis_FACE_list.clear(); if (wire_BODY) - api_delent(wire_BODY); + api_delent(wire_BODY); else - { - // TO DO: delete each EDGE in EDGEs - void(0); - - wire_BODYs.init(); - ENTITY *ent_to_del; - while( (ent_to_del = wire_BODYs.next())!=NULL ) - api_delent( ent_to_del ); - } + // TO DO: delete each EDGE in EDGEs + void(0); delete [] EDGEs; return (FACE *)NULL; } - } - if (acis_FACE_list.count() != 1) - { - PRINT_ERROR("ACIS api_cover_wires function created " - "more than one FACE.\n" - " At this time, we cannot deal with this.\n"); - acis_FACE_list.clear(); - if (wire_BODY) - api_delent(wire_BODY); - else - // TO DO: delete each EDGE in EDGEs - void(0); - delete [] EDGEs; - return (FACE *)NULL; - } - //make this a 2d body. + //make this a 2d body. outcome result_2 = api_body_to_2d( wire_BODY ); if ( !result_2.ok() ) - { - PRINT_ERROR("In AcisGeometryEngine::make_FACE\n" - " ACIS api_body_to_2d function failed.\n\n"); - AcisQueryEngine::instance()->ACIS_API_error (result_2); - acis_FACE_list.clear(); - if (wire_BODY) - api_delent(wire_BODY); - else + { + PRINT_ERROR("In AcisGeometryEngine::make_FACE\n" + " ACIS api_body_to_2d function failed.\n\n"); + AcisQueryEngine::instance()->ACIS_API_error (result_2); + acis_FACE_list.clear(); + if (wire_BODY) + api_delent(wire_BODY); + else // TO DO: delete each EDGE in EDGEs - void(0); - delete [] EDGEs; - return (FACE *)NULL; - } + void(0); + delete [] EDGEs; + return (FACE *)NULL; + } FACE_ptr = (FACE*) acis_FACE_list[0]; if ( FACE_ptr == NULL || FACE_ptr->geometry() == NULL ) - { - PRINT_ERROR("In AcisGeometryEngine::make_FACE\n" - "FACE or FACE's geometry was NULL.\n"); - acis_FACE_list.clear(); - if (wire_BODY) - api_delent(wire_BODY); - else + { + PRINT_ERROR("In AcisGeometryEngine::make_FACE\n" + "FACE or FACE's geometry was NULL.\n"); + acis_FACE_list.clear(); + if (wire_BODY) + api_delent(wire_BODY); + else // TO DO: delete each EDGE in EDGEs - void(0); - delete [] EDGEs; - return (FACE*)NULL; - } + void(0); + delete [] EDGEs; + return (FACE*)NULL; + } acis_FACE_list.clear(); if ( !result.ok() ) - { - if (wire_BODY) - api_delent(wire_BODY); - else + { + if (wire_BODY) + api_delent(wire_BODY); + else // TO DO: delete each EDGE in EDGEs - void(0); - delete [] EDGEs; - return (FACE*)NULL; - } + void(0); + delete [] EDGEs; + return (FACE*)NULL; + } - // This will reactivate all the RefEntities that need to be kept. + // This will reactivate all the RefEntities that need to be kept. mark_owners_deactivated_flag(FACE_ptr, CUBIT_FALSE, CUBIT_TRUE); - // Where coincident vertices were merged by ACIS, - // make sure the lower ID is used. + // Where coincident vertices were merged by ACIS, + // make sure the lower ID is used. input_EDGE_list.reset(); for (i = 0; i < input_EDGE_list.size(); i++) - { + { // get the copy and original EDGE - EDGE* cur_EDGE_new = EDGEs[i]; - EDGE* cur_EDGE_old = input_EDGE_list.get_and_step(); + EDGE* cur_EDGE_new = EDGEs[i]; + EDGE* cur_EDGE_old = input_EDGE_list.get_and_step(); // If the original start RefVertex is deactivated, // see if we need to swap it with the replacement RefVertex - VERTEX* cur_VERT_new = cur_EDGE_new->start(); - VERTEX* cur_VERT_old = cur_EDGE_old->start(); + VERTEX* cur_VERT_new = cur_EDGE_new->start(); + VERTEX* cur_VERT_old = cur_EDGE_old->start(); - for (int j = 2; j--; ) - { - RefVertex* ref_vert_old = - CAST_TO(ATTRIB_CUBIT_OWNER::get_topology_entity(cur_VERT_old), - RefVertex); + for (int j = 2; j--; ) + { + RefVertex* ref_vert_old = + CAST_TO(ATTRIB_CUBIT_OWNER::get_topology_entity(cur_VERT_old), + RefVertex); - AcisBridge* bridge = ATTRIB_CUBIT_OWNER::cubit_owner(cur_VERT_old); + AcisBridge* bridge = ATTRIB_CUBIT_OWNER::cubit_owner(cur_VERT_old); - if (ref_vert_old && bridge_deactivated(bridge)) - { - RefVertex* ref_vert_new = - CAST_TO(ATTRIB_CUBIT_OWNER::get_topology_entity(cur_VERT_new), - RefVertex); - if (ref_vert_new && ref_vert_old->id() < ref_vert_new->id()) - { - int id_old = ref_vert_old->id(); - int id_new = ref_vert_new->id(); - ref_vert_old->set_id(0); - ref_vert_new->set_id(id_old); - ref_vert_old->set_id(id_new); - } - } + if (ref_vert_old && bridge_deactivated(bridge)) + { + RefVertex* ref_vert_new = + CAST_TO(ATTRIB_CUBIT_OWNER::get_topology_entity(cur_VERT_new), + RefVertex); + if (ref_vert_new && ref_vert_old->id() < ref_vert_new->id()) + { + int id_old = ref_vert_old->id(); + int id_new = ref_vert_new->id(); + ref_vert_old->set_id(0); + ref_vert_new->set_id(id_old); + ref_vert_old->set_id(id_new); + } + } -/* - PointACIS* ref_vert_old = - CAST_TO(ATTRIB_CUBIT_OWNER::cubit_owner(cur_VERT_old),PointACIS); + /* + PointACIS* ref_vert_old = + CAST_TO(ATTRIB_CUBIT_OWNER::cubit_owner(cur_VERT_old),PointACIS); - if (ref_vert_old && bridge_deactivated(ref_vert_old) && ref_vert_old->owner()) - { - //RefVertex* ref_vert_new = - // CAST_TO(ATTRIB_CUBIT_OWNER::get_topology_entity(cur_VERT_new), - // RefVertex); - PointACIS* ref_vert_new = - CAST_TO(ATTRIB_CUBIT_OWNER::cubit_owner(cur_VERT_new),PointACIS); - if (ref_vert_new) - { - ref_vert_old->owner()->swap_bridge(ref_vert_old,ref_vert_new,true); - } - } -*/ - cur_VERT_new = cur_EDGE_new->end(); - cur_VERT_old = cur_EDGE_old->end(); + if (ref_vert_old && bridge_deactivated(ref_vert_old) && ref_vert_old->owner()) + { + //RefVertex* ref_vert_new = + // CAST_TO(ATTRIB_CUBIT_OWNER::get_topology_entity(cur_VERT_new), + // RefVertex); + PointACIS* ref_vert_new = + CAST_TO(ATTRIB_CUBIT_OWNER::cubit_owner(cur_VERT_new),PointACIS); + if (ref_vert_new) + { + ref_vert_old->owner()->swap_bridge(ref_vert_old,ref_vert_new,true); + } + } + */ + cur_VERT_new = cur_EDGE_new->end(); + cur_VERT_old = cur_EDGE_old->end(); + } } - } - // Get rid of the stuff we aren't using. This will delete the RefVertices - // that correspond to the VERTEXes deleted by ACIS in api_make_ewire. - // We also delete the original ACIS EDGEs since they are no longer - // being used. + // Get rid of the stuff we aren't using. This will delete the RefVertices + // that correspond to the VERTEXes deleted by ACIS in api_make_ewire. + // We also delete the original ACIS EDGEs since they are no longer + // being used. for (i = input_EDGE_list.size(); i--; ) - { - AcisQueryEngine::instance()->unhook_ENTITY_from_VGI(input_EDGE_list.get()); - api_delent(input_EDGE_list.get_and_step()); - } + { + AcisQueryEngine::instance()->unhook_ENTITY_from_VGI(input_EDGE_list.get()); + api_delent(input_EDGE_list.get_and_step()); + } //GeometryQueryTool::instance()->cleanout_deactivated_geometry(); cleanout_deactivated_geometry(); delete [] EDGEs; @@ -5399,35 +4863,35 @@ // Creation Date : 03-27-97 //------------------------------------------------------------------------- EDGE* AcisModifyEngine::make_straight_EDGE( VERTEX* start_VERTEX, - VERTEX* end_VERTEX ) const + VERTEX* end_VERTEX ) const { - // Make a straight EDGE - EDGE* EDGE_ptr = NULL; - outcome result = api_mk_ed_line ( start_VERTEX->geometry()->coords(), - end_VERTEX->geometry()->coords(), - EDGE_ptr ); - if (!result.ok() || EDGE_ptr == NULL) - { + // Make a straight EDGE + EDGE* EDGE_ptr = NULL; + outcome result = api_mk_ed_line ( start_VERTEX->geometry()->coords(), + end_VERTEX->geometry()->coords(), + EDGE_ptr ); + if (!result.ok() || EDGE_ptr == NULL) + { PRINT_ERROR("In AcisModifyEngine::make_straight_EDGE\n" " ACIS api_mk_ed_line function failed.\n\n"); AcisQueryEngine::instance()->ACIS_API_error (result); return (EDGE *)NULL; - } + } - else - { - // Switch the end VERTEXes of the new EDGE to the input VERTEXes. Keep - // in mind that the back links (from the VERTEX back to the EDGE) - // need to be modified as well. + else + { + // Switch the end VERTEXes of the new EDGE to the input VERTEXes. Keep + // in mind that the back links (from the VERTEX back to the EDGE) + // need to be modified as well. EDGE_ptr->set_start(start_VERTEX); start_VERTEX->add_edge(EDGE_ptr); EDGE_ptr->set_end(end_VERTEX); end_VERTEX->add_edge(EDGE_ptr); - // Return the newly created EDGE + // Return the newly created EDGE return EDGE_ptr; - } + } } //------------------------------------------------------------------------- @@ -5441,87 +4905,87 @@ // Creation Date : 03-27-97 //------------------------------------------------------------------------- EDGE* AcisModifyEngine::make_parabolic_EDGE( - VERTEX* from, - VERTEX* to, - SPAposition* peak_ptr ) const + VERTEX* from, + VERTEX* to, + SPAposition* peak_ptr ) const { - if ( peak_ptr == NULL ) - { + if ( peak_ptr == NULL ) + { PRINT_ERROR("In AcisModifyEngine::make_parabolic_EDGE\n" " Input parabola tip is invalid (NULL pointer).\n"); assert ( peak_ptr != NULL ); return (EDGE *)NULL; - } + } - // Convert positions to CubitVectors (legacy code!!!) - SPAposition from_position = from->geometry()->coords(); - SPAposition to_position = to->geometry()->coords(); + // Convert positions to CubitVectors (legacy code!!!) + SPAposition from_position = from->geometry()->coords(); + SPAposition to_position = to->geometry()->coords(); - CubitVector from_vec( from_position.x(), - from_position.y(), - from_position.z() ); - CubitVector to_vec( to_position.x(), - to_position.y(), - to_position.z() ); - CubitVector peak_vec( peak_ptr->x(), - peak_ptr->y(), - peak_ptr->z() ); + CubitVector from_vec( from_position.x(), + from_position.y(), + from_position.z() ); + CubitVector to_vec( to_position.x(), + to_position.y(), + to_position.z() ); + CubitVector peak_vec( peak_ptr->x(), + peak_ptr->y(), + peak_ptr->z() ); - CubitVector width_vec, midpoint_vec, height_vec; - width_vec = to_vec - from_vec; - midpoint_vec = (from_vec + to_vec)/2.0; - height_vec = peak_vec - midpoint_vec; + CubitVector width_vec, midpoint_vec, height_vec; + width_vec = to_vec - from_vec; + midpoint_vec = (from_vec + to_vec)/2.0; + height_vec = peak_vec - midpoint_vec; - // rho = 0.5 is a (spline) parabola - - // see ACIS Geometric Modeler API Reference 3-138 ver. 1.7 - double rho = 0.5; - EDGE* EDGE_ptr = NULL; - // Find the focus of this parabola. - // Since for a parabola with its peak at the origin, y = (1/(4*a))*x^2, - // and since we have restricted this parabola to be symmetric (per the FastQ - // method, see the FastQ file getwt.f), we can use the following relationship - // to determine "a", the distance the focus lies from the peak on the line - // formed by the peak and the midpoint of the start and end points - //double a = width_vec.length_squared()/(16. * height_vec.length()); - CubitVector height_vec_unit = height_vec; - height_vec_unit.normalize(); + // rho = 0.5 is a (spline) parabola - + // see ACIS Geometric Modeler API Reference 3-138 ver. 1.7 + double rho = 0.5; + EDGE* EDGE_ptr = NULL; + // Find the focus of this parabola. + // Since for a parabola with its peak at the origin, y = (1/(4*a))*x^2, + // and since we have restricted this parabola to be symmetric (per the FastQ + // method, see the FastQ file getwt.f), we can use the following relationship + // to determine "a", the distance the focus lies from the peak on the line + // formed by the peak and the midpoint of the start and end points + //double a = width_vec.length_squared()/(16. * height_vec.length()); + CubitVector height_vec_unit = height_vec; + height_vec_unit.normalize(); - // See Geometric Modeling by M. E. Mortenson, pg. 82, Fig 2.28 c, we need p2 - // as the center_vec from which to get the tangents - // Our approach assumes that midpoint_vec, peak, and center_vec will all lie - // on the same line, a valid assumption with the restrictions from FastQ - CubitVector vec_E_C = peak_vec - midpoint_vec; - CubitVector center_vec = ((2./rho)*vec_E_C + to_vec + from_vec)/2.; + // See Geometric Modeling by M. E. Mortenson, pg. 82, Fig 2.28 c, we need p2 + // as the center_vec from which to get the tangents + // Our approach assumes that midpoint_vec, peak, and center_vec will all lie + // on the same line, a valid assumption with the restrictions from FastQ + CubitVector vec_E_C = peak_vec - midpoint_vec; + CubitVector center_vec = ((2./rho)*vec_E_C + to_vec + from_vec)/2.; - SPAvector start_tan = SPAvector ( center_vec.x() - from_vec.x(), - center_vec.y() - from_vec.y(), - center_vec.z() - from_vec.z() ); + SPAvector start_tan = SPAvector ( center_vec.x() - from_vec.x(), + center_vec.y() - from_vec.y(), + center_vec.z() - from_vec.z() ); - SPAvector end_tan = SPAvector ( center_vec.x() - to_vec.x(), - center_vec.y() - to_vec.y(), - center_vec.z() - to_vec.z() ); + SPAvector end_tan = SPAvector ( center_vec.x() - to_vec.x(), + center_vec.y() - to_vec.y(), + center_vec.z() - to_vec.z() ); - SPAunit_vector start_tan_unit = normalise( start_tan ); - SPAunit_vector end_tan_unit = normalise( end_tan ); + SPAunit_vector start_tan_unit = normalise( start_tan ); + SPAunit_vector end_tan_unit = normalise( end_tan ); - outcome result = api_mk_ed_conic ( from_position, - start_tan_unit, - to_position, - end_tan_unit, - rho, - EDGE_ptr ); - if (!result.ok() || EDGE_ptr == NULL) - { + outcome result = api_mk_ed_conic ( from_position, + start_tan_unit, + to_position, + end_tan_unit, + rho, + EDGE_ptr ); + if (!result.ok() || EDGE_ptr == NULL) + { PRINT_ERROR("ACIS api_mk_ed_conic function failed\n"); AcisQueryEngine::instance()->ACIS_API_error (result); return (EDGE *)NULL; - } + } - else - { - // Switch the end VERTEXes of the EDGE to the input VERTEXes. Keep - // in mind that the back links (from the VERTEX back to the EDGE) - // need to be modified as well. + else + { + // Switch the end VERTEXes of the EDGE to the input VERTEXes. Keep + // in mind that the back links (from the VERTEX back to the EDGE) + // need to be modified as well. EDGE_ptr->set_start ( from ); from->add_edge( EDGE_ptr ); @@ -5529,7 +4993,7 @@ to->add_edge( EDGE_ptr ); return EDGE_ptr; - } + } } //------------------------------------------------------------------------- @@ -5549,94 +5013,94 @@ //------------------------------------------------------------------------- EDGE* AcisModifyEngine::make_elliptical_EDGE( VERTEX* from, - VERTEX* to, - SPAposition* ctr_ptr, - bool sense ) const + VERTEX* to, + SPAposition* ctr_ptr, + bool sense ) const { - if ( ctr_ptr == NULL ) - { + if ( ctr_ptr == NULL ) + { PRINT_ERROR("In AcisModifyEngine::make_elliptical_EDGE\n" " Input ellipse center is invalid (NULL pointer).\n"); return (EDGE *)NULL; - } + } - // Convert positions to CubitVectors (legacy code!!!) - SPAposition from_position = from->geometry()->coords(); - SPAposition to_position = to->geometry()->coords(); + // Convert positions to CubitVectors (legacy code!!!) + SPAposition from_position = from->geometry()->coords(); + SPAposition to_position = to->geometry()->coords(); - CubitVector from_vec( from_position.x(), - from_position.y(), - from_position.z() ); - CubitVector to_vec( to_position.x(), - to_position.y(), - to_position.z() ); - CubitVector ctr_vec( ctr_ptr->x(), - ctr_ptr->y(), - ctr_ptr->z() ); + CubitVector from_vec( from_position.x(), + from_position.y(), + from_position.z() ); + CubitVector to_vec( to_position.x(), + to_position.y(), + to_position.z() ); + CubitVector ctr_vec( ctr_ptr->x(), + ctr_ptr->y(), + ctr_ptr->z() ); - // delta_vee_1 gives major axis of ellipse (circle) - SPAvector delta_vee_1 = from_position - *ctr_ptr; - SPAvector delta_vee_2 = to_position - *ctr_ptr; - if ( delta_vee_1.len() < CUBIT_RESABS*.000001 ) - { - PRINT_ERROR("Zero length distance to center point.\n"); - return (EDGE*) NULL; - } - if ( delta_vee_2.len() < CUBIT_RESABS*.000001 ) - { - PRINT_ERROR("Zero length distance to center point.\n"); - return (EDGE*) NULL; - } - SPAunit_vector normal = normalise( delta_vee_1 * delta_vee_2 ); - // Since this is a normalised SPAvector, its length should be 1.0. - // If it is not, then the delta_vee_1 and delta_vee_2 - // vectors are collinear and we have to manually set the normal - // SPAvector. Assume that this is being done in FASTQ and set the normal - // to be the Z axis. - if (normal.len() == 0.0) - { - // The start and end vertex are in the same SPAposition, or they are - // 180 degrees opposed. + // delta_vee_1 gives major axis of ellipse (circle) + SPAvector delta_vee_1 = from_position - *ctr_ptr; + SPAvector delta_vee_2 = to_position - *ctr_ptr; + if ( delta_vee_1.len() < CUBIT_RESABS*.000001 ) + { + PRINT_ERROR("Zero length distance to center point.\n"); + return (EDGE*) NULL; + } + if ( delta_vee_2.len() < CUBIT_RESABS*.000001 ) + { + PRINT_ERROR("Zero length distance to center point.\n"); + return (EDGE*) NULL; + } + SPAunit_vector normal = normalise( delta_vee_1 * delta_vee_2 ); + // Since this is a normalised SPAvector, its length should be 1.0. + // If it is not, then the delta_vee_1 and delta_vee_2 + // vectors are collinear and we have to manually set the normal + // SPAvector. Assume that this is being done in FASTQ and set the normal + // to be the Z axis. + if (normal.len() == 0.0) + { + // The start and end vertex are in the same SPAposition, or they are + // 180 degrees opposed. normal.set_x(0.0); normal.set_y(0.0); normal.set_z(1.0); - } - double radius_ratio = delta_vee_2.len() / delta_vee_1.len(); + } + double radius_ratio = delta_vee_2.len() / delta_vee_1.len(); - EDGE* EDGE_ptr = NULL; + EDGE* EDGE_ptr = NULL; - // if radius_ratio is not 1.0, then this code probably won't produce - // the intended geometry since delta_vee_1 does not necessarily - // represent the major axis of an ellipse unless it is circular - outcome result; - if ( radius_ratio <= 0.999 || radius_ratio > 1.001 ) - { + // if radius_ratio is not 1.0, then this code probably won't produce + // the intended geometry since delta_vee_1 does not necessarily + // represent the major axis of an ellipse unless it is circular + outcome result; + if ( radius_ratio <= 0.999 || radius_ratio > 1.001 ) + { EDGE_ptr = make_spiral_EDGE(from, to, ctr_ptr, sense); - } - else - { + } + else + { PRINT_DEBUG_5( "radius ratio = %f\n", radius_ratio); - // Calculate the included angle between from and to on the - // circular ellipse + // Calculate the included angle between from and to on the + // circular ellipse CubitVector cubit_normal (normal.x(), normal.y(), normal.z()); CubitVector cubit_from = from_vec - ctr_vec; CubitVector cubit_to = to_vec - ctr_vec; double incl_angle = cubit_normal.vector_angle ( cubit_from, cubit_to ); if (incl_angle == 0.0) - incl_angle = 2.0 * CUBIT_PI; + incl_angle = 2.0 * CUBIT_PI; double start_angle = 0.0; double end_angle = incl_angle; if (radius_ratio > 1.0) - { - delta_vee_1 = delta_vee_2; - radius_ratio = 1.0 / radius_ratio; - start_angle = -incl_angle; - end_angle = 0.0; - } + { + delta_vee_1 = delta_vee_2; + radius_ratio = 1.0 / radius_ratio; + start_angle = -incl_angle; + end_angle = 0.0; + } result = api_mk_ed_ellipse ( *ctr_ptr, @@ -5646,26 +5110,26 @@ start_angle, end_angle, EDGE_ptr ); - } - if (!result.ok() || EDGE_ptr == NULL) - { + } + if (!result.ok() || EDGE_ptr == NULL) + { PRINT_ERROR("In AGE:make_elliptical_EDGE.\n" "ACIS api_mk_ed_ellipse function failed\n"); AcisQueryEngine::instance()->ACIS_API_error (result); if ( from == NULL || to == NULL ) - { - PRINT_ERROR("In AGE:make_elliptical_EDGE.\n" - " Input VERTEX is NULL\n"); - } + { + PRINT_ERROR("In AGE:make_elliptical_EDGE.\n" + " Input VERTEX is NULL\n"); + } return (EDGE *)NULL; - } + } - else - { - // Switch the end VERTEXes of the EDGE to the input VERTEXes. Keep - // in mind that the back links (from the VERTEX back to the EDGE) - // need to be modified as well. + else + { + // Switch the end VERTEXes of the EDGE to the input VERTEXes. Keep + // in mind that the back links (from the VERTEX back to the EDGE) + // need to be modified as well. EDGE_ptr->set_start ( from ); from->add_edge( EDGE_ptr ); @@ -5673,7 +5137,7 @@ to->add_edge( EDGE_ptr ); return EDGE_ptr ; - } + } } //------------------------------------------------------------------------- @@ -5686,30 +5150,30 @@ // Creation Date : 12/10/99 //------------------------------------------------------------------------- EDGE* AcisModifyEngine::make_circular_EDGE( VERTEX* from, - VERTEX* to, - SPAposition* third_pt ) const + VERTEX* to, + SPAposition* third_pt ) const { assert (from != NULL); assert (to != NULL); assert (third_pt != NULL); - // get the 3 points + // get the 3 points SPAposition start_pt = from->geometry()->coords(); SPAposition end_pt = to->geometry()->coords(); - // create the arc + // create the arc EDGE *e_arc; outcome result = api_curve_arc_3pt(start_pt, *third_pt, end_pt, FALSE, e_arc); if (!result.ok()) - { - AcisQueryEngine::instance()->ACIS_API_error(result); - return NULL; - } + { + AcisQueryEngine::instance()->ACIS_API_error(result); + return NULL; + } - // Switch the end VERTEXes of the EDGE to the input VERTEXes. Keep - // in mind that the back links (from the VERTEX back to the EDGE) - // need to be modified as well. + // Switch the end VERTEXes of the EDGE to the input VERTEXes. Keep + // in mind that the back links (from the VERTEX back to the EDGE) + // need to be modified as well. e_arc->set_start(from); from->add_edge(e_arc); e_arc->set_end (to); @@ -5732,91 +5196,91 @@ //------------------------------------------------------------------------- EDGE* AcisModifyEngine::make_spiral_EDGE( VERTEX* from, - VERTEX* to, - SPAposition* ctr_ptr, - bool sense) const + VERTEX* to, + SPAposition* ctr_ptr, + bool sense) const { - if ( ctr_ptr == NULL ) - { + if ( ctr_ptr == NULL ) + { PRINT_ERROR("In AcisModifyEngine::make_spiral_EDGE\n" " Input spiral center is invalid (NULL pointer).\n"); return (EDGE *)NULL; - } + } - // Convert positions to CubitVectors (legacy code!!!) - SPAposition from_position = from->geometry()->coords(); - SPAposition to_position = to->geometry()->coords(); + // Convert positions to CubitVectors (legacy code!!!) + SPAposition from_position = from->geometry()->coords(); + SPAposition to_position = to->geometry()->coords(); - // NOTE: This function assumes that vertices from, to, and ctr lie in the - // X-Y plane. - if (from_position.z() != to_position.z() || - from_position.z() != ctr_ptr->z()) { - PRINT_ERROR("In AcisModifyEngine::make_spiral_EDGE\n" - " Points must be in the constant-z plane.\n"); - return (EDGE *)NULL; - } + // NOTE: This function assumes that vertices from, to, and ctr lie in the + // X-Y plane. + if (from_position.z() != to_position.z() || + from_position.z() != ctr_ptr->z()) { + PRINT_ERROR("In AcisModifyEngine::make_spiral_EDGE\n" + " Points must be in the constant-z plane.\n"); + return (EDGE *)NULL; + } - CubitVector from_vec( from_position.x(), - from_position.y(), - from_position.z() ); - CubitVector to_vec( to_position.x(), - to_position.y(), - to_position.z() ); - //CubitVector ctr_vec( ctr_ptr->x(), - // ctr_ptr->y(), - // ctr_ptr->z() ); + CubitVector from_vec( from_position.x(), + from_position.y(), + from_position.z() ); + CubitVector to_vec( to_position.x(), + to_position.y(), + to_position.z() ); + //CubitVector ctr_vec( ctr_ptr->x(), + // ctr_ptr->y(), + // ctr_ptr->z() ); - SPAvector delta_vee_1 = from_position - *ctr_ptr; - SPAvector delta_vee_2 = to_position - *ctr_ptr; + SPAvector delta_vee_1 = from_position - *ctr_ptr; + SPAvector delta_vee_2 = to_position - *ctr_ptr; - CubitVector side1( delta_vee_1.x(), - delta_vee_1.y(), - delta_vee_1.z()) ; + CubitVector side1( delta_vee_1.x(), + delta_vee_1.y(), + delta_vee_1.z()) ; - CubitVector side2( delta_vee_2.x(), - delta_vee_2.y(), - delta_vee_2.z()) ; + CubitVector side2( delta_vee_2.x(), + delta_vee_2.y(), + delta_vee_2.z()) ; - CubitVector center( ctr_ptr->x(), - ctr_ptr->y(), - ctr_ptr->z()) ; + CubitVector center( ctr_ptr->x(), + ctr_ptr->y(), + ctr_ptr->z()) ; - // Calcualate parameters for the spiral. See FASTQ source, arcpar.f - double radius1 = side1.length(); - double radius2 = side2.length(); + // Calcualate parameters for the spiral. See FASTQ source, arcpar.f + double radius1 = side1.length(); + double radius2 = side2.length(); - double theta1 = atan2(side1.y(), side1.x()); - double theta2 = atan2(side2.y(), side2.x()); - if (sense && theta2 <= theta1) - { + double theta1 = atan2(side1.y(), side1.x()); + double theta2 = atan2(side2.y(), side2.x()); + if (sense && theta2 <= theta1) + { theta2 += 2.0 * CUBIT_PI; - } - if (!sense && theta1 <= theta2) - { + } + if (!sense && theta1 <= theta2) + { theta1 += 2.0 * CUBIT_PI; - } + } - double total_angle = theta2 - theta1; + double total_angle = theta2 - theta1; - double xk = log(radius2 / radius1) / (theta2 - theta1); - double xa = radius2 / exp(xk * theta2); + double xk = log(radius2 / radius1) / (theta2 - theta1); + double xa = radius2 / exp(xk * theta2); - // Calculate points at 2.0 degree intervals - int number_points = int(total_angle * 180.0 / CUBIT_PI / 2.0 + 0.5); - number_points = number_points < 20 ? 20 : number_points; + // Calculate points at 2.0 degree intervals + int number_points = int(total_angle * 180.0 / CUBIT_PI / 2.0 + 0.5); + number_points = number_points < 20 ? 20 : number_points; - SPAposition *pos_array = new SPAposition [number_points]; + SPAposition *pos_array = new SPAposition [number_points]; - pos_array[0].set_x(from_vec.x()); - pos_array[0].set_y(from_vec.y()); - pos_array[0].set_z(from_vec.z()); + pos_array[0].set_x(from_vec.x()); + pos_array[0].set_y(from_vec.y()); + pos_array[0].set_z(from_vec.z()); - pos_array[number_points - 1].set_x(to_vec.x()); - pos_array[number_points - 1].set_y(to_vec.y()); - pos_array[number_points - 1].set_z(to_vec.z()); + pos_array[number_points - 1].set_x(to_vec.x()); + pos_array[number_points - 1].set_y(to_vec.y()); + pos_array[number_points - 1].set_z(to_vec.z()); - for (int i=1; i < number_points-1; i++) - { + for (int i=1; i < number_points-1; i++) + { double theta = theta1 + total_angle * ((double)i/(double)number_points); double radius = xa * exp(xk * theta); double x = center.x() + radius * cos(theta); @@ -5825,49 +5289,49 @@ pos_array[i].set_x(x); pos_array[i].set_y(y); pos_array[i].set_z(to_vec.z()); - } + } - // calculate default tangent directions using up to three points - // at the ends of the point array. - SPAunit_vector uv1(0, 0, 0); - SPAunit_vector uv2(0, 0, 0); + // calculate default tangent directions using up to three points + // at the ends of the point array. + SPAunit_vector uv1(0, 0, 0); + SPAunit_vector uv2(0, 0, 0); - EDGE* EDGE_ptr = NULL; - outcome result; + EDGE* EDGE_ptr = NULL; + outcome result; - // fifth SPAparameter 0.0 -> interpolate the sequence of points. - result = api_mk_ed_cubic(number_points, pos_array, - uv1, uv2, 0.0, EDGE_ptr); + // fifth SPAparameter 0.0 -> interpolate the sequence of points. + result = api_mk_ed_cubic(number_points, pos_array, + uv1, uv2, 0.0, EDGE_ptr); - // Free memory - delete [] pos_array; + // Free memory + delete [] pos_array; - if ( !result.ok() || EDGE_ptr == NULL ) - { + if ( !result.ok() || EDGE_ptr == NULL ) + { PRINT_ERROR("ACIS api_mk_ed_cubic function failed\n"); AcisQueryEngine::instance()->ACIS_API_error (result); if ( from == NULL || to == NULL ) - { - PRINT_ERROR("In AGE:make_spiral_EDGE.\n" - " Input VERTEX is NULL\n"); - return (EDGE *)NULL; - } - } + { + PRINT_ERROR("In AGE:make_spiral_EDGE.\n" + " Input VERTEX is NULL\n"); + return (EDGE *)NULL; + } + } - else - { - // Switch the end VERTEXes of the EDGE to the input VERTEXes. Keep - // in mind that the back links (from the VERTEX back to the EDGE) - // need to be modified as well. + else + { + // Switch the end VERTEXes of the EDGE to the input VERTEXes. Keep + // in mind that the back links (from the VERTEX back to the EDGE) + // need to be modified as well. EDGE_ptr->set_start ( from ); from->add_edge( EDGE_ptr ); EDGE_ptr->set_end ( to ); to->add_edge( EDGE_ptr ); - } + } - return EDGE_ptr; + return EDGE_ptr; } //------------------------------------------------------------------------- // Purpose : Create a curve on a surface. @@ -5881,17 +5345,17 @@ // Creation Date : 05/15/97 //------------------------------------------------------------------------- EDGE* AcisModifyEngine::make_surface_EDGE( VERTEX* from_VERTEX, - VERTEX* to_VERTEX, - FACE *FACE_ptr, - const CubitVector &plane_normal, - const CubitVector *third_point) const + VERTEX* to_VERTEX, + FACE *FACE_ptr, + const CubitVector &plane_normal, + const CubitVector *third_point) const { - //Now create a cutting plane using the normal passed in. This - //normal should point sort of tangential to the surface. We - //want the plane to intersect the surface. + //Now create a cutting plane using the normal passed in. This + //normal should point sort of tangential to the surface. We + //want the plane to intersect the surface. SPAposition const plane_point = from_VERTEX->geometry()->coords(); SPAunit_vector const normal_vector( plane_normal.x(), plane_normal.y(), - plane_normal.z() ); + plane_normal.z() ); plane const new_plane( plane_point, normal_vector ); SPAposition point_1, point_2, point_3; SPApar_pos const pos_1( 0, 1 ); @@ -5901,35 +5365,35 @@ new_plane.eval( pos_2, point_2 ); new_plane.eval( pos_3, point_3 ); - // Get the size of the model so we can create an "infinite" - // cutting plane + // Get the size of the model so we can create an "infinite" + // cutting plane CubitBox cubit_super_box = GeometryQueryTool::instance()->model_bounding_box(); SPAbox super_box = AcisQueryEngine::bounding_box(cubit_super_box); CubitVector vec_1( point_1.x(), point_1.y(), point_1.z() ); CubitVector vec_2( point_2.x(), point_2.y(), point_2.z() ); CubitVector vec_3( point_3.x(), point_3.y(), point_3.z() ); - // Create the infinite plane, get a FACE + // Create the infinite plane, get a FACE BODY *sheet_body = this->create_infinite_plane_cutting_tool( - vec_1, vec_2, vec_3, super_box, CUBIT_TRUE ); + vec_1, vec_2, vec_3, super_box, CUBIT_TRUE ); if (sheet_body == NULL || sheet_body->lump() == NULL || sheet_body->lump()->shell() == NULL || sheet_body->lump()->shell()->first_face() == NULL || sheet_body->lump()->shell()->first_face()->geometry() == NULL ) - { + { //webcut_failed(refbody_cleanup_list, BODY_cleanup_list); - PRINT_ERROR("In AcisModifyEngine::make_surface_EDGE" - " Cannot create infinite plane cutting tool using \n" - " the give surface. \n"); - return (EDGE*)NULL; - } + PRINT_ERROR("In AcisModifyEngine::make_surface_EDGE" + " Cannot create infinite plane cutting tool using \n" + " the give surface. \n"); + return (EDGE*)NULL; + } FACE *FACE_1 = sheet_body->lump()->shell()->first_face(); - // Copy the FACE + // Copy the FACE FACE *FACE_2 = make_FACE( FACE_ptr ); - // Now we can create a body representing the intersection - // of the infinite plane and the passed in surface + // Now we can create a body representing the intersection + // of the infinite plane and the passed in surface EDGE* new_EDGE = NULL; BODY *intersect_BODY = NULL; LUMP *cur_LUMP = NULL; @@ -5937,199 +5401,199 @@ COEDGE *cur_COEDGE; WIRE *cur_WIRE; - // Get the intersection + // Get the intersection outcome result_1 = api_fafa_int ( FACE_1, FACE_2, intersect_BODY ); - // for some reason a NULL body still returns an ok result. - KGM + // for some reason a NULL body still returns an ok result. - KGM if (intersect_BODY == NULL) - { - return (EDGE*)NULL; - } + { + return (EDGE*)NULL; + } - // Make sure it was OK, and get the appropriate entity - // Get a WIRE if it's there + // Make sure it was OK, and get the appropriate entity + // Get a WIRE if it's there if ( !result_1.ok() || intersect_BODY->wire() == NULL || intersect_BODY->wire()->coedge() == NULL || intersect_BODY->wire()->coedge()->edge() == NULL ) - { - // If there was no WIRE, see if there is a lump - if ( result_1.ok() && intersect_BODY->lump() != NULL && - intersect_BODY->lump()->shell() != NULL && - intersect_BODY->lump()->shell()->wire() != NULL && - intersect_BODY->lump()->shell()->wire()->coedge() != NULL && - intersect_BODY->lump()->shell()->wire()->coedge()->edge() != NULL ) { - PRINT_DEBUG_18( "Using wire from lumps.\n"); - cur_LUMP = intersect_BODY->lump(); - cur_WIRE = cur_LUMP->shell()->wire(); + // If there was no WIRE, see if there is a lump + if ( result_1.ok() && intersect_BODY->lump() != NULL && + intersect_BODY->lump()->shell() != NULL && + intersect_BODY->lump()->shell()->wire() != NULL && + intersect_BODY->lump()->shell()->wire()->coedge() != NULL && + intersect_BODY->lump()->shell()->wire()->coedge()->edge() != NULL ) + { + PRINT_DEBUG_18( "Using wire from lumps.\n"); + cur_LUMP = intersect_BODY->lump(); + cur_WIRE = cur_LUMP->shell()->wire(); + } + else + { + PRINT_ERROR("ACIS api_fafa_int function failed\n"); + AcisQueryEngine::instance()->ACIS_API_error (result_1); + return (EDGE*)NULL; + } } - else + else { - PRINT_ERROR("ACIS api_fafa_int function failed\n"); - AcisQueryEngine::instance()->ACIS_API_error (result_1); - return (EDGE*)NULL; + PRINT_DEBUG_18( "Using wire straight from BODY\n"); + cur_WIRE = intersect_BODY->wire(); } - } - else - { - PRINT_DEBUG_18( "Using wire straight from BODY\n"); - cur_WIRE = intersect_BODY->wire(); - } - // Now find an EDGE that the points lie on. - // Start by going through each LUMP, if LUMPs are being used. + // Now find an EDGE that the points lie on. + // Start by going through each LUMP, if LUMPs are being used. LUMP* start_LUMP = cur_LUMP; CURVE *geometry = NULL; do - { - PRINT_DEBUG_18( "**New Lump check**\n"); + { + PRINT_DEBUG_18( "**New Lump check**\n"); // Now go through the wires, coedges, and edges // to find an edge that the points lie on - WIRE* start_WIRE = cur_WIRE; - do - { - // Get the first coedge in this wire - COEDGE* start_COEDGE = cur_WIRE->coedge(); - cur_COEDGE = start_COEDGE; - // Check it and loop through the rest + WIRE* start_WIRE = cur_WIRE; do - { - PRINT_DEBUG_18( " **New CoEdge check**\n"); - cur_EDGE = cur_COEDGE->edge(); - geometry = cur_EDGE->geometry(); - // See if this is close enough to - // the start and end points - if (geometry != NULL) - { - SPAposition new_point; - // Make sure start vertex is on curve - geometry->equation().point_perp(from_VERTEX->geometry()->coords(), - new_point); - PRINT_DEBUG_18( "\n\tNew Point 1: (%g, %g, %g)\n" - "\t From Vert: (%g, %g, %g)\n", - new_point.x(), - new_point.y(), - new_point.z(), - from_VERTEX->geometry()->coords().x(), - from_VERTEX->geometry()->coords().y(), - from_VERTEX->geometry()->coords().z()); - if (AcisQueryEngine::instance()->about_spatially_equal(from_VERTEX->geometry()->coords(), - new_point, 1.0)) - { - // Make sure end vertex is on curve - geometry->equation().point_perp(to_VERTEX->geometry()->coords(), - new_point); - PRINT_DEBUG_18( "\tNew Point 2: (%g, %g, %g)\n" - "\t To Vert: (%g, %g, %g) \n", - new_point.x(), - new_point.y(), - new_point.z(), - to_VERTEX->geometry()->coords().x(), - to_VERTEX->geometry()->coords().y(), - to_VERTEX->geometry()->coords().z()); - if (AcisQueryEngine::instance()->about_spatially_equal(to_VERTEX->geometry()->coords(), - new_point, 1.0)) - { - // You found it!!! - cur_WIRE = NULL; - start_LUMP = NULL; - break; - } - } - } - cur_COEDGE = cur_COEDGE->next(); - geometry = NULL; // Make sure you indicate we haven't found geom - }while (cur_COEDGE != NULL && cur_COEDGE != start_COEDGE); - // You break out of this do-while loop when - // a) You find the correct EDGE - // b) There are no more COEDGEs in this WIRE - // c) You loop through all of the COEDGES in this WIRE + { + // Get the first coedge in this wire + COEDGE* start_COEDGE = cur_WIRE->coedge(); + cur_COEDGE = start_COEDGE; + // Check it and loop through the rest + do + { + PRINT_DEBUG_18( " **New CoEdge check**\n"); + cur_EDGE = cur_COEDGE->edge(); + geometry = cur_EDGE->geometry(); + // See if this is close enough to + // the start and end points + if (geometry != NULL) + { + SPAposition new_point; + // Make sure start vertex is on curve + geometry->equation().point_perp(from_VERTEX->geometry()->coords(), + new_point); + PRINT_DEBUG_18( "\n\tNew Point 1: (%g, %g, %g)\n" + "\t From Vert: (%g, %g, %g)\n", + new_point.x(), + new_point.y(), + new_point.z(), + from_VERTEX->geometry()->coords().x(), + from_VERTEX->geometry()->coords().y(), + from_VERTEX->geometry()->coords().z()); + if (AcisQueryEngine::instance()->about_spatially_equal(from_VERTEX->geometry()->coords(), + new_point, 1.0)) + { + // Make sure end vertex is on curve + geometry->equation().point_perp(to_VERTEX->geometry()->coords(), + new_point); + PRINT_DEBUG_18( "\tNew Point 2: (%g, %g, %g)\n" + "\t To Vert: (%g, %g, %g) \n", + new_point.x(), + new_point.y(), + new_point.z(), + to_VERTEX->geometry()->coords().x(), + to_VERTEX->geometry()->coords().y(), + to_VERTEX->geometry()->coords().z()); + if (AcisQueryEngine::instance()->about_spatially_equal(to_VERTEX->geometry()->coords(), + new_point, 1.0)) + { + // You found it!!! + cur_WIRE = NULL; + start_LUMP = NULL; + break; + } + } + } + cur_COEDGE = cur_COEDGE->next(); + geometry = NULL; // Make sure you indicate we haven't found geom + }while (cur_COEDGE != NULL && cur_COEDGE != start_COEDGE); + // You break out of this do-while loop when + // a) You find the correct EDGE + // b) There are no more COEDGEs in this WIRE + // c) You loop through all of the COEDGES in this WIRE - // Print out some debug diagnostics - if (DEBUG_FLAG(18)) - { - if (cur_COEDGE == NULL) - PRINT_INFO("Exit loop because CoEdge was NULL\n"); - else if (cur_COEDGE == start_COEDGE) - PRINT_INFO("Exit loop because cur_COEDGE == start_COEDGE\n"); - else - PRINT_INFO("Exit loop for Other Reason!!!\n"); - } + // Print out some debug diagnostics + if (DEBUG_FLAG(18)) + { + if (cur_COEDGE == NULL) + PRINT_INFO("Exit loop because CoEdge was NULL\n"); + else if (cur_COEDGE == start_COEDGE) + PRINT_INFO("Exit loop because cur_COEDGE == start_COEDGE\n"); + else + PRINT_INFO("Exit loop for Other Reason!!!\n"); + } - // cur_WIRE is NULL if the correct EDGE has been found - if (cur_WIRE) - cur_WIRE = cur_WIRE->next(); - }while (cur_WIRE && cur_WIRE != start_WIRE); + // cur_WIRE is NULL if the correct EDGE has been found + if (cur_WIRE) + cur_WIRE = cur_WIRE->next(); + }while (cur_WIRE && cur_WIRE != start_WIRE); // You break out of this do-while loop when // a) You find the correct EDGE // b) There are no more WIREs in this WIRE list // c) You loop through all the WIREs // Print out some debug diagnostics - if (DEBUG_FLAG(18)) - { - if (cur_WIRE == NULL) - PRINT_DEBUG_18( "Exit loop because Wire was NULL\n"); - else if (cur_WIRE == start_WIRE) - PRINT_DEBUG_18( "Exit loop because cur_WIRE == start_WIRE\n"); - else - PRINT_DEBUG_18( "Exit loop for Other Reason!!!\n"); - } + if (DEBUG_FLAG(18)) + { + if (cur_WIRE == NULL) + PRINT_DEBUG_18( "Exit loop because Wire was NULL\n"); + else if (cur_WIRE == start_WIRE) + PRINT_DEBUG_18( "Exit loop because cur_WIRE == start_WIRE\n"); + else + PRINT_DEBUG_18( "Exit loop for Other Reason!!!\n"); + } // If we are using lumps, go to the next lump // and get its first wire. - if (start_LUMP) - { - cur_LUMP = cur_LUMP->next(); - if (cur_LUMP) - cur_WIRE = cur_LUMP->shell()->wire(); - } + if (start_LUMP) + { + cur_LUMP = cur_LUMP->next(); + if (cur_LUMP) + cur_WIRE = cur_LUMP->shell()->wire(); + } - }while (start_LUMP && cur_LUMP && start_LUMP != cur_LUMP); - // You break out of this do-while loop when - // a) You find the correct EDGE - // b) There are no more LUMPs in the BODY - // c) You looped through all the LUMPs in the BODY - // d) We weren't using LUMPs to start with + }while (start_LUMP && cur_LUMP && start_LUMP != cur_LUMP); + // You break out of this do-while loop when + // a) You find the correct EDGE + // b) There are no more LUMPs in the BODY + // c) You looped through all the LUMPs in the BODY + // d) We weren't using LUMPs to start with - // Print out some debug diagnostics + // Print out some debug diagnostics if (DEBUG_FLAG(18)) - { - if (start_LUMP == NULL) - PRINT_INFO("Exit loop because start_LUMP was NULL\n"); - else if (cur_LUMP == NULL) - PRINT_INFO("Exit loop because cur_LUMP == NULL\n"); - else if (cur_LUMP == start_LUMP) - PRINT_INFO("Exit loop because cur_WIRE == start_WIRE\n"); - else - PRINT_INFO("Exit loop for Other Reason!!!\n"); - } + { + if (start_LUMP == NULL) + PRINT_INFO("Exit loop because start_LUMP was NULL\n"); + else if (cur_LUMP == NULL) + PRINT_INFO("Exit loop because cur_LUMP == NULL\n"); + else if (cur_LUMP == start_LUMP) + PRINT_INFO("Exit loop because cur_WIRE == start_WIRE\n"); + else + PRINT_INFO("Exit loop for Other Reason!!!\n"); + } - // Make sure you found something valid + // Make sure you found something valid if ( geometry == NULL ) - { - PRINT_ERROR("ACIS failed to find geometry for new curve.\n"); - return (EDGE*)NULL; - } + { + PRINT_ERROR("ACIS failed to find geometry for new curve.\n"); + return (EDGE*)NULL; + } PRINT_DEBUG_18( " The EDGE coords:\n" - " start: (%g, %g, %g)\n" - " end: (%g, %g, %g)\n", - cur_EDGE->end_pos().x(), - cur_EDGE->end_pos().y(), - cur_EDGE->end_pos().z(), - cur_EDGE->start_pos().x(), - cur_EDGE->start_pos().y(), - cur_EDGE->start_pos().z()); + " start: (%g, %g, %g)\n" + " end: (%g, %g, %g)\n", + cur_EDGE->end_pos().x(), + cur_EDGE->end_pos().y(), + cur_EDGE->end_pos().z(), + cur_EDGE->start_pos().x(), + cur_EDGE->start_pos().y(), + cur_EDGE->start_pos().z()); - // Handle special stuff for periodic curves + // Handle special stuff for periodic curves int periodic = geometry->equation().periodic(); double period = 0.0; if ( periodic ) - { - period = geometry->equation().param_period(); - } + { + period = geometry->equation().param_period(); + } double start_param, end_param; start_param = cur_EDGE->start_param(); @@ -6144,32 +5608,32 @@ // If periodic get the params in the range of the curve's param range. if(periodic) - { - // forward param range - if(curve_range > 0.0) { - while(v1_param < start_param - GEOMETRY_RESABS) - v1_param += period; - while(v1_param > end_param + GEOMETRY_RESABS) - v1_param -= period; - while(v2_param < start_param - GEOMETRY_RESABS) - v2_param += period; - while(v2_param > end_param + GEOMETRY_RESABS) - v2_param -= period; + // forward param range + if(curve_range > 0.0) + { + while(v1_param < start_param - GEOMETRY_RESABS) + v1_param += period; + while(v1_param > end_param + GEOMETRY_RESABS) + v1_param -= period; + while(v2_param < start_param - GEOMETRY_RESABS) + v2_param += period; + while(v2_param > end_param + GEOMETRY_RESABS) + v2_param -= period; + } + // reversed param range (will this ever happen?) + else + { + while(v1_param < end_param - GEOMETRY_RESABS) + v1_param += period; + while(v1_param > start_param + GEOMETRY_RESABS) + v1_param -= period; + while(v2_param < end_param - GEOMETRY_RESABS) + v2_param += period; + while(v2_param > start_param + GEOMETRY_RESABS) + v2_param -= period; + } } - // reversed param range (will this ever happen?) - else - { - while(v1_param < end_param - GEOMETRY_RESABS) - v1_param += period; - while(v1_param > start_param + GEOMETRY_RESABS) - v1_param -= period; - while(v2_param < end_param - GEOMETRY_RESABS) - v2_param += period; - while(v2_param > start_param + GEOMETRY_RESABS) - v2_param -= period; - } - } double new_param_range = v2_param-v1_param; @@ -6180,34 +5644,34 @@ if(curve_range*new_param_range < 0.0) sense_int = 0; /* REVERSED */ - //if we have a third point and we are periodic... use - //it to nail down the direction. + //if we have a third point and we are periodic... use + //it to nail down the direction. if ( third_point != NULL && periodic ) - { - SPAposition const some_point( third_point->x(), - third_point->y(), - third_point->z() ); - SPAposition closest_point; - geometry->equation().point_perp( some_point, closest_point ); - double some_param = geometry->equation().param( closest_point ); - int val1 = (curve_range > 0.0); - int val2 = (sense_int == 1); - - // val1 will equal val2 for two cases. In either case v1_param will - // be less than v2_param. - if (val1 == val2) { - if ( some_param < v1_param || some_param > v2_param ) - sense_int = !sense_int; + SPAposition const some_point( third_point->x(), + third_point->y(), + third_point->z() ); + SPAposition closest_point; + geometry->equation().point_perp( some_point, closest_point ); + double some_param = geometry->equation().param( closest_point ); + int val1 = (curve_range > 0.0); + int val2 = (sense_int == 1); + + // val1 will equal val2 for two cases. In either case v1_param will + // be less than v2_param. + if (val1 == val2) + { + if ( some_param < v1_param || some_param > v2_param ) + sense_int = !sense_int; + } + // val1 will NOT equal val2 for two cases. In either case v1_param will + // be greater than v2_param. + else + { + if ( some_param < v2_param || some_param > v1_param ) + sense_int = !sense_int; + } } - // val1 will NOT equal val2 for two cases. In either case v1_param will - // be greater than v2_param. - else - { - if ( some_param < v2_param || some_param > v1_param ) - sense_int = !sense_int; - } - } REVBIT sense; if(sense_int == 0) @@ -6215,13 +5679,13 @@ else sense = FORWARD; - // Actually create the new EDGE + // Actually create the new EDGE API_BEGIN; new_EDGE = new EDGE ( from_VERTEX, to_VERTEX, geometry, sense ); API_END; - //Delete the body and the sheet_body and the other body associated with - //this other face... + //Delete the body and the sheet_body and the other body associated with + //this other face... AcisQueryEngine::instance()->delete_ACIS_BODY(intersect_BODY, CUBIT_TRUE); AcisQueryEngine::instance()->delete_ACIS_BODY(sheet_body, CUBIT_TRUE); AcisQueryEngine::instance()->delete_ACIS_BODY(AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_2), CUBIT_TRUE); @@ -6241,34 +5705,34 @@ // Creation Date : 05/15/97 //------------------------------------------------------------------------- EDGE* AcisModifyEngine::make_spline_EDGE( VERTEX* from_VERTEX, - VERTEX* to_VERTEX, - SPAposition* pos_array, - int number_points ) const + VERTEX* to_VERTEX, + SPAposition* pos_array, + int number_points ) const { - // Create the spline curve and attach it to the EDGE + // Create the spline curve and attach it to the EDGE EDGE* EDGE_ptr = NULL; outcome result = api_curve_spline(number_points, pos_array, 0, 0, EDGE_ptr, FALSE, from_VERTEX == to_VERTEX); if (result.ok() == FALSE || EDGE_ptr == NULL) - { - PRINT_ERROR("In AcisModifyEngine::make_spline_EDGE\n" - " ACIS function, api_mk_ed_cubic, failed\n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - return (EDGE *)NULL; - } + { + PRINT_ERROR("In AcisModifyEngine::make_spline_EDGE\n" + " ACIS function, api_mk_ed_cubic, failed\n"); + AcisQueryEngine::instance()->ACIS_API_error (result); + return (EDGE *)NULL; + } else - { + { // Switch the end VERTEXes of the EDGE to the input VERTEXes. Keep // in mind that the back links (from the VERTEX back to the EDGE) // need to be modified as well. - EDGE_ptr->set_start ( from_VERTEX ); - from_VERTEX->add_edge( EDGE_ptr ); + EDGE_ptr->set_start ( from_VERTEX ); + from_VERTEX->add_edge( EDGE_ptr ); - EDGE_ptr->set_end ( to_VERTEX ); - to_VERTEX->add_edge( EDGE_ptr ); + EDGE_ptr->set_end ( to_VERTEX ); + to_VERTEX->add_edge( EDGE_ptr ); - return EDGE_ptr; - } + return EDGE_ptr; + } } //------------------------------------------------------------------------- @@ -6289,26 +5753,26 @@ { leftoverBody = 0; - // chops the blank with the tool, returing the body formed by subtracting the tool from the blank, - // and the body formed by intersecting the tool with the blank, - // simultaneously. + // chops the blank with the tool, returing the body formed by subtracting the tool from the blank, + // and the body formed by intersecting the tool with the blank, + // simultaneously. if (bodysms.size() <= 1) - { - PRINT_WARNING("There is only one volume in the list. Nothing modified\n"); - return CUBIT_FAILURE; - } + { + PRINT_WARNING("There is only one volume in the list. Nothing modified\n"); + return CUBIT_FAILURE; + } - // Create new acis bodies that are copies of the original acis bodies. - // If something goes wrong in the choping, we can then delete our copies - // and the originals are intact. If everything goes fine, we will delete - // the originals at that time. + // Create new acis bodies that are copies of the original acis bodies. + // If something goes wrong in the choping, we can then delete our copies + // and the originals are intact. If everything goes fine, we will delete + // the originals at that time. - // pass in keep_old to the delete_owner_attrib flag; if we're not keeping - // old bodies, we want to keep the owner attrib, so we can pick up entities - // that didn't change + // pass in keep_old to the delete_owner_attrib flag; if we're not keeping + // old bodies, we want to keep the owner attrib, so we can pick up entities + // that didn't change bool delete_attribs = - (GeometryModifyTool::instance()->get_new_ids() || keep_old); + (GeometryModifyTool::instance()->get_new_ids() || keep_old); DLIList<BODY*> old_BODY_list; DLIList<BodySM*> old_BodySM_list; @@ -6320,56 +5784,56 @@ BODY *blank_BODY = this->copy_BODY(BODYPtr, delete_attribs); if (blank_BODY == NULL) - { - return CUBIT_FAILURE; // Nothing to clean up at this point. - } + { + return CUBIT_FAILURE; // Nothing to clean up at this point. + } BODY* outside_BODY=NULL; BODY* leftovers_BODY=NULL; - // get the tool Body + // get the tool Body BodySMPtr = bodysms.get_and_step(); BODYPtr = AcisQueryEngine::get_BODY(BodySMPtr); BODY *tool_BODY = this->copy_BODY(BODYPtr, delete_attribs); if (tool_BODY == NULL) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(blank_BODY, CUBIT_TRUE); - return CUBIT_FAILURE; - } + { + AcisQueryEngine::instance()->delete_ACIS_BODY(blank_BODY, CUBIT_TRUE); + return CUBIT_FAILURE; + } // Chop the blank_BODY using the tool_BODY. // If this is successful, the result is blank_BODY and outside_BODY, leftovers_BODY outcome result = api_boolean_chop_body(tool_BODY, blank_BODY, nonreg,outside_BODY, leftovers_BODY); if (!result.ok() || blank_BODY == NULL || - tool_BODY == NULL || blank_BODY->lump() == NULL ) - { + tool_BODY == NULL || blank_BODY->lump() == NULL ) + { - if( !result.ok() ) - { - PRINT_ERROR("In AcisModifyEngine::chop\n"); - AcisQueryEngine::instance()->ACIS_API_error(result, "chop Bodies"); - if (blank_BODY != NULL) - AcisQueryEngine::instance()->delete_ACIS_BODY(blank_BODY, CUBIT_TRUE); - if (tool_BODY != NULL) - AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY, CUBIT_TRUE); - } + if( !result.ok() ) + { + PRINT_ERROR("In AcisModifyEngine::chop\n"); + AcisQueryEngine::instance()->ACIS_API_error(result, "chop Bodies"); + if (blank_BODY != NULL) + AcisQueryEngine::instance()->delete_ACIS_BODY(blank_BODY, CUBIT_TRUE); + if (tool_BODY != NULL) + AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY, CUBIT_TRUE); + } - if( blank_BODY->lump() == NULL ) - { - PRINT_ERROR("Bodies do not intersect\n"); - if (blank_BODY != NULL) - AcisQueryEngine::instance()->delete_ACIS_BODY(blank_BODY, CUBIT_TRUE); - if (leftovers_BODY != NULL) - AcisQueryEngine::instance()->delete_ACIS_BODY(leftovers_BODY, CUBIT_TRUE); - if (outside_BODY != NULL) - AcisQueryEngine::instance()->delete_ACIS_BODY(outside_BODY, CUBIT_TRUE); + if( blank_BODY->lump() == NULL ) + { + PRINT_ERROR("Bodies do not intersect\n"); + if (blank_BODY != NULL) + AcisQueryEngine::instance()->delete_ACIS_BODY(blank_BODY, CUBIT_TRUE); + if (leftovers_BODY != NULL) + AcisQueryEngine::instance()->delete_ACIS_BODY(leftovers_BODY, CUBIT_TRUE); + if (outside_BODY != NULL) + AcisQueryEngine::instance()->delete_ACIS_BODY(outside_BODY, CUBIT_TRUE); + } + + return CUBIT_FAILURE; } - return CUBIT_FAILURE; - } - BodySM* intersectBody = get_new_Body(BodySMPtr, BODYPtr, blank_BODY, keep_old); intersectBodies.append( intersectBody ); BodySM* outsideBody = get_new_Body(old_BodySM_list, old_BODY_list, outside_BODY, keep_old); @@ -6401,60 +5865,60 @@ DLIList<SurfaceACIS*> copied_ref_face_list(ref_face_list.size()); CAST_LIST(ref_face_list, copied_ref_face_list, SurfaceACIS); if (ref_face_list.size() != copied_ref_face_list.size()) - { - PRINT_ERROR("Non-ACIS surface at %s:%d\n", __FILE__, __LINE__ ); - return CUBIT_FAILURE; - } + { + PRINT_ERROR("Non-ACIS surface at %s:%d\n", __FILE__, __LINE__ ); + return CUBIT_FAILURE; + } // Loop on FACEs. We will work on reversing surfaces from one body at a time. copied_ref_face_list.reset(); while( copied_ref_face_list.size() ) - { - BODY *copied_BODY_ptr; + { + BODY *copied_BODY_ptr; #ifdef BOYD07 - DLIList<SurfaceACIS*> reverse_face_list; + DLIList<SurfaceACIS*> reverse_face_list; #endif - DLIList<FACE*> reverse_FACE_list; - if( get_copied_FACES_of_body( copied_ref_face_list, reverse_FACE_list, - copied_BODY_ptr ) == CUBIT_FAILURE ) - break; + DLIList<FACE*> reverse_FACE_list; + if( get_copied_FACES_of_body( copied_ref_face_list, reverse_FACE_list, + copied_BODY_ptr ) == CUBIT_FAILURE ) + break; - // Get original Body and BODY - BodySM *body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( copied_BODY_ptr ); - BODY *BODY_ptr = AcisQueryEngine::get_BODY(body_ptr); + // Get original Body and BODY + BodySM *body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( copied_BODY_ptr ); + BODY *BODY_ptr = AcisQueryEngine::get_BODY(body_ptr); - // Now cleanout the owner attributes from the copied BODY, if required - if( delete_attribs ) - AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copied_BODY_ptr); + // Now cleanout the owner attributes from the copied BODY, if required + if( delete_attribs ) + AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copied_BODY_ptr); - reverse_FACE_list.reset(); - for( i=reverse_FACE_list.size(); i--; ) - { - FACE *FACE_ptr = reverse_FACE_list.get_and_step(); - result = api_reverse_face( FACE_ptr ); + reverse_FACE_list.reset(); + for( i=reverse_FACE_list.size(); i--; ) + { + FACE *FACE_ptr = reverse_FACE_list.get_and_step(); + result = api_reverse_face( FACE_ptr ); - if (!result.ok()) - { - //TODO: get ref_face from FACE - //PRINT_INFO("Surface %d did not reverse\n", ref_face->id()); - PRINT_INFO("Surface did not reverse\n"); - return CUBIT_FAILURE; - } - } + if (!result.ok()) + { + //TODO: get ref_face from FACE + //PRINT_INFO("Surface %d did not reverse\n", ref_face->id()); + PRINT_INFO("Surface did not reverse\n"); + return CUBIT_FAILURE; + } + } - BodySM* new_body_ptr = get_new_Body( body_ptr, BODY_ptr, copied_BODY_ptr, CUBIT_FALSE ); + BodySM* new_body_ptr = get_new_Body( body_ptr, BODY_ptr, copied_BODY_ptr, CUBIT_FALSE ); - if( new_body_ptr!=NULL && new_body_ptr!=body_ptr ) - { - PRINT_INFO( "Created new volume\n" ); + if( new_body_ptr!=NULL && new_body_ptr!=body_ptr ) + { + PRINT_INFO( "Created new volume\n" ); + } + else if( new_body_ptr!=NULL && new_body_ptr==body_ptr ) + { + PRINT_INFO( "Modified volume\n" ); + } + else + PRINT_WARNING( "Volume was not modified\n" ); } - else if( new_body_ptr!=NULL && new_body_ptr==body_ptr ) - { - PRINT_INFO( "Modified volume\n" ); - } - else - PRINT_WARNING( "Volume was not modified\n" ); - } return CUBIT_SUCCESS; } @@ -6476,10441 +5940,9944 @@ PRINT_ERROR( "This function is not available in ACIS versions below 800\n" ); return CUBIT_FAILURE; #else -CubitStatus AcisModifyEngine::thicken( DLIList<BodySM*>& bodies, - DLIList<BodySM*>& new_body_list, - double depth, - bool both) const -{ - if (bodies.size() < 1) - { - PRINT_WARNING("There are no volumes in the list. Nothing modified\n"); - return CUBIT_FAILURE; - } + CubitStatus AcisModifyEngine::thicken( DLIList<BodySM*>& bodies, + DLIList<BodySM*>& new_body_list, + double depth, + bool both) const + { + if (bodies.size() < 1) + { + PRINT_WARNING("There are no volumes in the list. Nothing modified\n"); + return CUBIT_FAILURE; + } - SPAposition box_l(0,0,0); - SPAposition box_h(0,0,0); + SPAposition box_l(0,0,0); + SPAposition box_h(0,0,0); - BODY* in_out_BODY; - DLIList<BODY*> old_BODY_list; - DLIList<BodySM*> old_Body_list; + BODY* in_out_BODY; + DLIList<BODY*> old_BODY_list; + DLIList<BodySM*> old_Body_list; - for(int i = bodies.size(); i >= 1 ; i-- ){ + for(int i = bodies.size(); i >= 1 ; i-- ){ - BodySM* BodyPtr = bodies.get_and_step(); - BodySM* new_bodysm; - BodyACIS* acis_body = dynamic_cast<BodyACIS*>(BodyPtr); - if (!acis_body) - { - PRINT_ERROR("Non-ACIS BodySM passed to AcisModifyEngine::thicken.\n"); - continue; - } + BodySM* BodyPtr = bodies.get_and_step(); + BodySM* new_bodysm; + BodyACIS* acis_body = dynamic_cast<BodyACIS*>(BodyPtr); + if (!acis_body) + { + PRINT_ERROR("Non-ACIS BodySM passed to AcisModifyEngine::thicken.\n"); + continue; + } - BODY* BODYPtr = AcisQueryEngine::get_BODY(BodyPtr); + BODY* BODYPtr = AcisQueryEngine::get_BODY(BodyPtr); - in_out_BODY = this->copy_BODY(BODYPtr, CUBIT_FALSE); + in_out_BODY = this->copy_BODY(BODYPtr, CUBIT_FALSE); - if (in_out_BODY == NULL) - { - return CUBIT_FAILURE; // Nothing to clean up at this point. - } + if (in_out_BODY == NULL) + { + return CUBIT_FAILURE; // Nothing to clean up at this point. + } - if( !acis_body->is_sheet_body() ) - { - PRINT_WARNING("Only surface volumes should be thickened\n" - " results may be different than expected\n"); - } + if( !acis_body->is_sheet_body() ) + { + PRINT_WARNING("Only surface volumes should be thickened\n" + " results may be different than expected\n"); + } - outcome result = api_sheet_thicken(in_out_BODY, depth, both, box_l, box_h); + outcome result = api_sheet_thicken(in_out_BODY, depth, both, box_l, box_h); - if (!result.ok())// - { - if(result.error_number() == 41000) // checking surface normals - { - PRINT_ERROR("In AcisModifyEngine::thicken\n" - " Surface normals may not be consistent\n" - " use: validate normal reverse\n"); - return CUBIT_FAILURE; - } + if (!result.ok())// + { + if(result.error_number() == 41000) // checking surface normals + { + PRINT_ERROR("In AcisModifyEngine::thicken\n" + " Surface normals may not be consistent\n" + " use: validate normal reverse\n"); + return CUBIT_FAILURE; + } - PRINT_ERROR("In AcisModifyEngine::thicken \n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - return CUBIT_FAILURE; - } + PRINT_ERROR("In AcisModifyEngine::thicken \n"); + AcisQueryEngine::instance()->ACIS_API_error (result); + return CUBIT_FAILURE; + } - new_bodysm = get_new_Body(BodyPtr, BODYPtr, in_out_BODY, CUBIT_FALSE); - if (new_bodysm) - new_body_list.append(new_bodysm); - } - return CUBIT_SUCCESS; + new_bodysm = get_new_Body(BodyPtr, BODYPtr, in_out_BODY, CUBIT_FALSE); + if (new_bodysm) + new_body_list.append(new_bodysm); + } + return CUBIT_SUCCESS; #endif -} + } -//------------------------------------------------------------------------- -// Purpose : Boolean Operation of a list of Bodies: unite -// -// Special Notes : -// -// Creator : Malcolm J. Panthaki -// -// Creation Date : 10/31/96 -//------------------------------------------------------------------------- -CubitStatus AcisModifyEngine::unite(DLIList<BodySM*> &bodies, - DLIList<BodySM*> &newBodies, + //------------------------------------------------------------------------- + // Purpose : Boolean Operation of a list of Bodies: unite + // + // Special Notes : + // + // Creator : Malcolm J. Panthaki + // + // Creation Date : 10/31/96 + //------------------------------------------------------------------------- + CubitStatus AcisModifyEngine::unite(DLIList<BodySM*> &bodies, + DLIList<BodySM*> &newBodies, bool keep_old) const -{ - // Union all bodies in the bodies list into a single body. - if (bodies.size() <= 1) - { - PRINT_WARNING("There is only one volume in the list. Nothing modified\n"); - return CUBIT_FAILURE; - } + { + // Union all bodies in the bodies list into a single body. + if (bodies.size() <= 1) + { + PRINT_WARNING("There is only one volume in the list. Nothing modified\n"); + return CUBIT_FAILURE; + } - // Create new acis bodies that are copies of the original acis bodies. - // If something goes wrong in the unioning, we can then delete our copies - // and the originals are intact. If everything goes fine, we will delete - // the originals at that time. + // Create new acis bodies that are copies of the original acis bodies. + // If something goes wrong in the unioning, we can then delete our copies + // and the originals are intact. If everything goes fine, we will delete + // the originals at that time. - // pass in keep_old to the delete_owner_attrib flag; if we're not keeping - // old bodies, we want to keep the owner attrib, so we can pick up entities - // that didn't change - bool delete_attribs = - (GeometryModifyTool::instance()->get_new_ids() || keep_old); + // pass in keep_old to the delete_owner_attrib flag; if we're not keeping + // old bodies, we want to keep the owner attrib, so we can pick up entities + // that didn't change + bool delete_attribs = + (GeometryModifyTool::instance()->get_new_ids() || keep_old); - // check if the boolean operation is regularized or nonregularized - BOOL_TYPE bool_type = UNION; - CubitBoolean boolean_regularize = GeometryModifyTool::instance()->boolean_regularize(); + // check if the boolean operation is regularized or nonregularized + BOOL_TYPE bool_type = UNION; + CubitBoolean boolean_regularize = GeometryModifyTool::instance()->boolean_regularize(); - if (boolean_regularize == FALSE) + if (boolean_regularize == FALSE) { - bool_type = NONREG_UNION; + bool_type = NONREG_UNION; } - DLIList<BODY*> old_BODY_list; - DLIList<BodySM*> old_Body_list; + DLIList<BODY*> old_BODY_list; + DLIList<BodySM*> old_Body_list; - BodySM* BodyPtr = bodies.get_and_step(); - BODY* BODYPtr = AcisQueryEngine::get_BODY(BodyPtr); - old_Body_list.append(BodyPtr); - old_BODY_list.append(BODYPtr); + BodySM* BodyPtr = bodies.get_and_step(); + BODY* BODYPtr = AcisQueryEngine::get_BODY(BodyPtr); + old_Body_list.append(BodyPtr); + old_BODY_list.append(BODYPtr); - BODY *master = this->copy_BODY(BODYPtr, delete_attribs); - if (master == NULL) - { - return CUBIT_FAILURE; // Nothing to clean up at this point. - } + BODY *master = this->copy_BODY(BODYPtr, delete_attribs); + if (master == NULL) + { + return CUBIT_FAILURE; // Nothing to clean up at this point. + } - // Note: one iteration less because we already pulled out one body above - for (int i = 1; i < bodies.size(); i++) - { - BodyPtr = bodies.get_and_step(); - BODYPtr = AcisQueryEngine::get_BODY(BodyPtr); + // Note: one iteration less because we already pulled out one body above + for (int i = 1; i < bodies.size(); i++) + { + BodyPtr = bodies.get_and_step(); + BODYPtr = AcisQueryEngine::get_BODY(BodyPtr); - BODY *copy = this->copy_BODY(BODYPtr, delete_attribs); - if (copy == NULL) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(master, CUBIT_TRUE); - return CUBIT_FAILURE; - } + BODY *copy = this->copy_BODY(BODYPtr, delete_attribs); + if (copy == NULL) + { + AcisQueryEngine::instance()->delete_ACIS_BODY(master, CUBIT_TRUE); + return CUBIT_FAILURE; + } - // Do the union of the master and the copy. - // If this is successful, the result is master and copy will be deleted - // outcome result = api_unite(copy, master); - // replaced with the api_boolean call in order to do nonregularize boolean operation + // Do the union of the master and the copy. + // If this is successful, the result is master and copy will be deleted + // outcome result = api_unite(copy, master); + // replaced with the api_boolean call in order to do nonregularize boolean operation - outcome result = api_boolean (copy,master,bool_type); + outcome result = api_boolean (copy,master,bool_type); - if (!result.ok() || (master && master->lump() == NULL)) - { - // If there are no LUMPs in the resulting BODY, return with a failure - if (master && master->lump() == NULL) - PRINT_ERROR("Unite produced volume with no volume - " - "check for (and remove) co-incident surfaces\n"); - else - PRINT_ERROR("In AcisModifyEngine::unite\n"); + if (!result.ok() || (master && master->lump() == NULL)) + { + // If there are no LUMPs in the resulting BODY, return with a failure + if (master && master->lump() == NULL) + PRINT_ERROR("Unite produced volume with no volume - " + "check for (and remove) co-incident surfaces\n"); + else + PRINT_ERROR("In AcisModifyEngine::unite\n"); - AcisQueryEngine::instance()->ACIS_API_error(result, "unite Bodies"); - if (master != NULL) AcisQueryEngine::instance()->delete_ACIS_BODY(master, CUBIT_TRUE); - if (copy != NULL) AcisQueryEngine::instance()->delete_ACIS_BODY(copy, CUBIT_TRUE); + AcisQueryEngine::instance()->ACIS_API_error(result, "unite Bodies"); + if (master != NULL) AcisQueryEngine::instance()->delete_ACIS_BODY(master, CUBIT_TRUE); + if (copy != NULL) AcisQueryEngine::instance()->delete_ACIS_BODY(copy, CUBIT_TRUE); - return CUBIT_FAILURE; - } - else { - old_Body_list.append(BodyPtr); - old_BODY_list.append(BODYPtr); - } + return CUBIT_FAILURE; + } + else { + old_Body_list.append(BodyPtr); + old_BODY_list.append(BODYPtr); + } - //For nonregularized boolean, find all internal surfaces and delete + //For nonregularized boolean, find all internal surfaces and delete - if ( bool_type == NONREG_UNION) - { - outcome result1; - // ENTITY_LIST FACES; - DLIList<FACE*> FACE_list ; - FACE *this_FACE; - AcisQueryEngine::instance()->get_FACEs(master,FACE_list); - // loop through all faces - for( int i = 0; i< FACE_list.size(); i++) - { - this_FACE = FACE_list.get_and_step(); - assert( this_FACE != NULL ); - // Make sure this is a DOUBLE_SIDED FACE - if (this_FACE->sides() == DOUBLE_SIDED) - { - if (this_FACE->cont()==BOTH_INSIDE) - { - // found internal faces - // Now we have the FACE - unhook it from the BODY. Keep track of new - // BODIES that are created as this is done. - PRINT_INFO( " Unhooking and deleting each internal surface...\n" ); - BODY *new_BODY_ptr; - result1 = api_unhook_face( this_FACE, new_BODY_ptr ); - if( !result1.ok() ) - { - AcisModifyEngine::instance()->get_acis_query_engine()->ACIS_API_error( result1 ); - PRINT_ERROR( " Face unhooking during rebuild of volume didn't work\n" ); - return CUBIT_FAILURE; - } - AcisQueryEngine::instance()->delete_ACIS_BODY (new_BODY_ptr); - } - } - } + if ( bool_type == NONREG_UNION) + { + outcome result1; + // ENTITY_LIST FACES; + DLIList<FACE*> FACE_list ; + FACE *this_FACE; + AcisQueryEngine::instance()->get_FACEs(master,FACE_list); + // loop through all faces + for( int i = 0; i< FACE_list.size(); i++) + { + this_FACE = FACE_list.get_and_step(); + assert( this_FACE != NULL ); + // Make sure this is a DOUBLE_SIDED FACE + if (this_FACE->sides() == DOUBLE_SIDED) + { + if (this_FACE->cont()==BOTH_INSIDE) + { + // found internal faces + // Now we have the FACE - unhook it from the BODY. Keep track of new + // BODIES that are created as this is done. + PRINT_INFO( " Unhooking and deleting each internal surface...\n" ); + BODY *new_BODY_ptr; + result1 = api_unhook_face( this_FACE, new_BODY_ptr ); + if( !result1.ok() ) + { + AcisModifyEngine::instance()->get_acis_query_engine()->ACIS_API_error( result1 ); + PRINT_ERROR( " Face unhooking during rebuild of volume didn't work\n" ); + return CUBIT_FAILURE; + } + AcisQueryEngine::instance()->delete_ACIS_BODY (new_BODY_ptr); + } + } + } - // heal the leftover body -// -// PRINT_INFO(" Healing the leftover volume...\n"); -// if( AcisHealerTool::instance()->init_BODY_for_healing( master ) == CUBIT_SUCCESS ) -// { -// int percent_before, percent_after, number_splines_simplified; -// if( AcisHealerTool::instance()->heal_BODY( master, percent_before, -// percent_after, number_splines_simplified ) == CUBIT_FAILURE ) -// PRINT_ERROR( "Error healing the combined volume\n" ); -// else -// PRINT_INFO( "Successfully healed the combined volume!\n" ); -// AcisHealerTool::instance()->end_BODY_for_healing( master ); -// } + // heal the leftover body + // + // PRINT_INFO(" Healing the leftover volume...\n"); + // if( AcisHealerTool::instance()->init_BODY_for_healing( master ) == CUBIT_SUCCESS ) + // { + // int percent_before, percent_after, number_splines_simplified; + // if( AcisHealerTool::instance()->heal_BODY( master, percent_before, + // percent_after, number_splines_simplified ) == CUBIT_FAILURE ) + // PRINT_ERROR( "Error healing the combined volume\n" ); + // else + // PRINT_INFO( "Successfully healed the combined volume!\n" ); + // AcisHealerTool::instance()->end_BODY_for_healing( master ); + // } + } + } - } + AcisQueryEngine::instance()->clear_bounding_box( master ); + AcisQueryEngine::instance()->bounding_box( master ); - AcisQueryEngine::instance()->clear_bounding_box( master ); - AcisQueryEngine::instance()->bounding_box( master ); + BodySM *newBodyPtr = get_new_Body(old_Body_list, old_BODY_list, master, keep_old); + newBodies.append( newBodyPtr ); - BodySM *newBodyPtr = get_new_Body(old_Body_list, old_BODY_list, master, keep_old); - newBodies.append( newBodyPtr ); + return CUBIT_SUCCESS; + } - return CUBIT_SUCCESS; -} + CubitStatus AcisModifyEngine::subtract( DLIList<BodySM*> &tool_body_list, + DLIList<BodySM*> &from_bodies, + DLIList<BodySM*> &new_from_bodies, + bool imprint, + bool keep_old) const + { + // pass in keep_old to the delete_owner_attrib flag; if we're not keeping + // old bodies, we want to keep the owner attrib, so we can pick up entities + // that didn't change + bool delete_attribs = + (GeometryModifyTool::instance()->get_new_ids() || keep_old); -CubitStatus AcisModifyEngine::subtract( DLIList<BodySM*> &tool_body_list, - DLIList<BodySM*> &from_bodies, - DLIList<BodySM*> &new_from_bodies, - bool imprint, - bool keep_old) const -{ - // pass in keep_old to the delete_owner_attrib flag; if we're not keeping - // old bodies, we want to keep the owner attrib, so we can pick up entities - // that didn't change - bool delete_attribs = - (GeometryModifyTool::instance()->get_new_ids() || keep_old); + // check if the boolean operation is regularized or nonregularized + BOOL_TYPE bool_type = SUBTRACTION; + CubitBoolean boolean_regularize = GeometryModifyTool::instance()->boolean_regularize(); - // check if the boolean operation is regularized or nonregularized - BOOL_TYPE bool_type = SUBTRACTION; - CubitBoolean boolean_regularize = GeometryModifyTool::instance()->boolean_regularize(); - - if (boolean_regularize == FALSE) + if (boolean_regularize == FALSE) { - bool_type = NONREG_SUBTRACTION; + bool_type = NONREG_SUBTRACTION; } - int ii; - DLIList<CubitBox*> tool_boxes; + int ii; + DLIList<CubitBox*> tool_boxes; - CubitBox tool_box; + CubitBox tool_box; - DLIList<BODY*> tool_BODY_list; - DLIList<BODY*> tool_BODY_list_copy; + DLIList<BODY*> tool_BODY_list; + DLIList<BODY*> tool_BODY_list_copy; - // get acis bodies, and copy them - tool_body_list.reset(); + // get acis bodies, and copy them + tool_body_list.reset(); - for (ii = tool_body_list.size(); ii > 0; ii--) { - CubitBox *temp_box = new CubitBox( - AcisQueryEngine::instance()->bounding_box(tool_body_list.get())); - tool_boxes.append(temp_box); + for (ii = tool_body_list.size(); ii > 0; ii--) { + CubitBox *temp_box = new CubitBox( + AcisQueryEngine::instance()->bounding_box(tool_body_list.get())); + tool_boxes.append(temp_box); - BODY *BODYPtr1 = AcisQueryEngine::get_BODY(tool_body_list.get_and_step()); - tool_BODY_list.append(BODYPtr1); + BODY *BODYPtr1 = AcisQueryEngine::get_BODY(tool_body_list.get_and_step()); + tool_BODY_list.append(BODYPtr1); - BODYPtr1 = this->copy_BODY(BODYPtr1, delete_attribs); - tool_BODY_list_copy.append(BODYPtr1); - } + BODYPtr1 = this->copy_BODY(BODYPtr1, delete_attribs); + tool_BODY_list_copy.append(BODYPtr1); + } - if (tool_BODY_list.size() != tool_body_list.size()) - { - for(ii = tool_boxes.size(); ii>0; ii--) - delete tool_boxes.get_and_step(); - return CUBIT_FAILURE; - } + if (tool_BODY_list.size() != tool_body_list.size()) + { + for(ii = tool_boxes.size(); ii>0; ii--) + delete tool_boxes.get_and_step(); + return CUBIT_FAILURE; + } - DLIList<BODY*> from_BODY_list; - DLIList<BODY*> from_BODY_list_copy; + DLIList<BODY*> from_BODY_list; + DLIList<BODY*> from_BODY_list_copy; - // get acis bodies, and copy them - from_bodies.reset(); + // get acis bodies, and copy them + from_bodies.reset(); - for (ii = from_bodies.size(); ii > 0; ii--) { - BODY *BODYPtr1 = AcisQueryEngine::get_BODY(from_bodies.get_and_step()); - from_BODY_list.append(BODYPtr1); + for (ii = from_bodies.size(); ii > 0; ii--) { + BODY *BODYPtr1 = AcisQueryEngine::get_BODY(from_bodies.get_and_step()); + from_BODY_list.append(BODYPtr1); - BODYPtr1 = this->copy_BODY(BODYPtr1, delete_attribs); - from_BODY_list_copy.append(BODYPtr1); - } + BODYPtr1 = this->copy_BODY(BODYPtr1, delete_attribs); + from_BODY_list_copy.append(BODYPtr1); + } - if (from_BODY_list.size() != from_bodies.size()) - { - for(ii = tool_boxes.size(); ii>0; ii--) - delete tool_boxes.get_and_step(); - return CUBIT_FAILURE; - } + if (from_BODY_list.size() != from_bodies.size()) + { + for(ii = tool_boxes.size(); ii>0; ii--) + delete tool_boxes.get_and_step(); + return CUBIT_FAILURE; + } - // now, subtract the tool from the list of bodies - tool_BODY_list.reset(); - tool_BODY_list_copy.reset(); - tool_body_list.reset(); - tool_boxes.reset(); + // now, subtract the tool from the list of bodies + tool_BODY_list.reset(); + tool_BODY_list_copy.reset(); + tool_body_list.reset(); + tool_boxes.reset(); - from_BODY_list.reset(); - from_BODY_list_copy.reset(); - from_bodies.reset(); + from_BODY_list.reset(); + from_BODY_list_copy.reset(); + from_bodies.reset(); - int fraction_remaining = 10; - CubitStatus sub_stat = CUBIT_SUCCESS; + int fraction_remaining = 10; + CubitStatus sub_stat = CUBIT_SUCCESS; - // subtract the tool body from each body in the list - CubitMessage* cmi = CubitMessage::instance(); - for (ii = 1; ii <= from_BODY_list.size(); ii++) - { - BODY *from_BODY = from_BODY_list.get(); - BODY *from_BODY_copy = from_BODY_list_copy.get(); - BodySM *from_Body = from_bodies.get(); - CubitBox box1 = AcisQueryEngine::instance()->bounding_box(from_Body); + // subtract the tool body from each body in the list + CubitMessage* cmi = CubitMessage::instance(); + for (ii = 1; ii <= from_BODY_list.size(); ii++) + { + BODY *from_BODY = from_BODY_list.get(); + BODY *from_BODY_copy = from_BODY_list_copy.get(); + BodySM *from_Body = from_bodies.get(); + CubitBox box1 = AcisQueryEngine::instance()->bounding_box(from_Body); - for(int jj = tool_BODY_list.size(); jj>0; jj--) - { - if (cmi->Interrupt()) - { - PRINT_ERROR("Subtraction interrupted. Aborting...\n"); - while (tool_boxes.size()) - delete tool_boxes.pop(); - while (tool_BODY_list_copy.size()) - AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY_list_copy.pop(),CUBIT_TRUE); - while (from_BODY_list_copy.size()) - AcisQueryEngine::instance()->delete_ACIS_BODY(from_BODY_list_copy.pop(),CUBIT_TRUE); - return CUBIT_FAILURE; - } + for(int jj = tool_BODY_list.size(); jj>0; jj--) + { + if (cmi->Interrupt()) + { + PRINT_ERROR("Subtraction interrupted. Aborting...\n"); + while (tool_boxes.size()) + delete tool_boxes.pop(); + while (tool_BODY_list_copy.size()) + AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY_list_copy.pop(),CUBIT_TRUE); + while (from_BODY_list_copy.size()) + AcisQueryEngine::instance()->delete_ACIS_BODY(from_BODY_list_copy.pop(),CUBIT_TRUE); + return CUBIT_FAILURE; + } - tool_box = *tool_boxes.get(); - BODY* tool_BODY = tool_BODY_list.get(); - BODY *tool_BODY_copy = tool_BODY_list_copy.get(); + tool_box = *tool_boxes.get(); + BODY* tool_BODY = tool_BODY_list.get(); + BODY *tool_BODY_copy = tool_BODY_list_copy.get(); - // first, check bounding SPAbox; if they don't intersect, don't do the subtract - if ( tool_box.overlap( SPAresabs, box1 ) ) - { - // the bodies overlap; proceed with the subtract + // first, check bounding SPAbox; if they don't intersect, don't do the subtract + if ( tool_box.overlap( SPAresabs, box1 ) ) + { + // the bodies overlap; proceed with the subtract - // Subtract body1 from body2. - // outcome result = api_subtract( tool_BODY_copy, from_BODY_copy ); - outcome result = api_boolean( tool_BODY_copy, from_BODY_copy, bool_type ); - // We may or may not get an error if the resulting BODY is - // empty (body1 totally encloses body2). - // Also check the result. - if (from_BODY_copy == NULL || - (from_BODY_copy->lump() == NULL && from_BODY_copy->wire() == NULL) || - !result.ok()) - { - if (!result.ok()) - { - PRINT_ERROR("Subtraction operation failed.\n"); - AcisQueryEngine::instance()->ACIS_API_error(result, "subtract Bodies"); - if (tool_BODY_copy != NULL) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY_copy, CUBIT_TRUE); - } - } - else - PRINT_ERROR("Subtraction operation failed.\n" - " Empty volume created. Original volume is probably\n" - " completely enclosed by the subtracting volume.\n"); - if (from_BODY_copy != NULL) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(from_BODY_copy, CUBIT_TRUE); - } + // Subtract body1 from body2. + // outcome result = api_subtract( tool_BODY_copy, from_BODY_copy ); + outcome result = api_boolean( tool_BODY_copy, from_BODY_copy, bool_type ); + // We may or may not get an error if the resulting BODY is + // empty (body1 totally encloses body2). + // Also check the result. + if (from_BODY_copy == NULL || + (from_BODY_copy->lump() == NULL && from_BODY_copy->wire() == NULL) || + !result.ok()) + { + if (!result.ok()) + { + PRINT_ERROR("Subtraction operation failed.\n"); + AcisQueryEngine::instance()->ACIS_API_error(result, "subtract Bodies"); + if (tool_BODY_copy != NULL) + { + AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY_copy, CUBIT_TRUE); + } + } + else + PRINT_ERROR("Subtraction operation failed.\n" + " Empty volume created. Original volume is probably\n" + " completely enclosed by the subtracting volume.\n"); + if (from_BODY_copy != NULL) + { + AcisQueryEngine::instance()->delete_ACIS_BODY(from_BODY_copy, CUBIT_TRUE); + } - // we had an error, so copy the original body into the copy list - from_BODY_copy = this->copy_BODY(from_BODY); - from_BODY_list_copy.change_to(from_BODY_copy); - tool_BODY_copy = this->copy_BODY(tool_BODY); - tool_BODY_list_copy.change_to(tool_BODY_copy); - sub_stat = CUBIT_FAILURE; - } - else - { - // else subtract was successful; make another tool body - tool_BODY_copy = this->copy_BODY(tool_BODY); - if( imprint ) - imprint_BODYs( tool_BODY_copy, from_BODY_copy ); - tool_BODY_list_copy.change_to(tool_BODY_copy); - } + // we had an error, so copy the original body into the copy list + from_BODY_copy = this->copy_BODY(from_BODY); + from_BODY_list_copy.change_to(from_BODY_copy); + tool_BODY_copy = this->copy_BODY(tool_BODY); + tool_BODY_list_copy.change_to(tool_BODY_copy); + sub_stat = CUBIT_FAILURE; + } + else + { + // else subtract was successful; make another tool body + tool_BODY_copy = this->copy_BODY(tool_BODY); + if( imprint ) + imprint_BODYs( tool_BODY_copy, from_BODY_copy ); + tool_BODY_list_copy.change_to(tool_BODY_copy); + } - //For nonregularized boolean, find all internal surfaces and delete + //For nonregularized boolean, find all internal surfaces and delete - if ( bool_type == NONREG_SUBTRACTION) - { - outcome result1; - // ENTITY_LIST FACES; - DLIList<FACE*> FACE_list ; - FACE *this_FACE; - AcisQueryEngine::instance()->get_FACEs(from_BODY_copy,FACE_list); - // loop through all faces - for( int i = 0; i< FACE_list.size(); i++) - { + if ( bool_type == NONREG_SUBTRACTION) + { + outcome result1; + // ENTITY_LIST FACES; + DLIList<FACE*> FACE_list ; + FACE *this_FACE; + AcisQueryEngine::instance()->get_FACEs(from_BODY_copy,FACE_list); + // loop through all faces + for( int i = 0; i< FACE_list.size(); i++) + { this_FACE = FACE_list.get_and_step(); assert( this_FACE != NULL ); // Make sure this is a DOUBLE_SIDED FACE if (this_FACE->sides() == DOUBLE_SIDED) - { - if (this_FACE->cont()==BOTH_INSIDE) - { - // found internal faces - // Now we have the FACE - unhook it from the BODY. Keep track of new - // BODIES that are created as this is done. - PRINT_INFO( " Unhooking and deleting each internal surface...\n" ); - BODY *new_BODY_ptr; - result1 = api_unhook_face( this_FACE, new_BODY_ptr ); - if( !result1.ok() ) - { - AcisModifyEngine::instance()->get_acis_query_engine()->ACIS_API_error( result1 ); - PRINT_ERROR( " Face unhooking during rebuild of volume didn't work\n" ); - return CUBIT_FAILURE; - } - AcisQueryEngine::instance()->delete_ACIS_BODY (new_BODY_ptr); - } - } - } + { + if (this_FACE->cont()==BOTH_INSIDE) + { + // found internal faces + // Now we have the FACE - unhook it from the BODY. Keep track of new + // BODIES that are created as this is done. + PRINT_INFO( " Unhooking and deleting each internal surface...\n" ); + BODY *new_BODY_ptr; + result1 = api_unhook_face( this_FACE, new_BODY_ptr ); + if( !result1.ok() ) + { + AcisModifyEngine::instance()->get_acis_query_engine()->ACIS_API_error( result1 ); + PRINT_ERROR( " Face unhooking during rebuild of volume didn't work\n" ); + return CUBIT_FAILURE; + } + AcisQueryEngine::instance()->delete_ACIS_BODY (new_BODY_ptr); + } + } + } - // heal the leftover body -// -// PRINT_INFO(" Healing the leftover volume...\n"); -// if( AcisHealerTool::instance()->init_BODY_for_healing( master ) == CUBIT_SUCCESS ) -// { -// int percent_before, percent_after, number_splines_simplified; -// if( AcisHealerTool::instance()->heal_BODY( master, percent_before, -// percent_after, number_splines_simplified ) == CUBIT_FAILURE ) -// PRINT_ERROR( "Error healing the combined volume\n" ); -// else -// PRINT_INFO( "Successfully healed the combined volume.\n" ); -// AcisHealerTool::instance()->end_BODY_for_healing( master ); -// } + // heal the leftover body + // + // PRINT_INFO(" Healing the leftover volume...\n"); + // if( AcisHealerTool::instance()->init_BODY_for_healing( master ) == CUBIT_SUCCESS ) + // { + // int percent_before, percent_after, number_splines_simplified; + // if( AcisHealerTool::instance()->heal_BODY( master, percent_before, + // percent_after, number_splines_simplified ) == CUBIT_FAILURE ) + // PRINT_ERROR( "Error healing the combined volume\n" ); + // else + // PRINT_INFO( "Successfully healed the combined volume.\n" ); + // AcisHealerTool::instance()->end_BODY_for_healing( master ); + // } + } + + // done with this j iteration; write out count, if necessary + if (from_bodies.size() * tool_body_list.size() > 1) + { + int frac_done = (10 * ii) / (from_bodies.size()* tool_body_list.size()); + if ((10 - frac_done) < fraction_remaining) + { + PRINT_INFO("%d ", fraction_remaining); + fraction_remaining--; + } + } + } + tool_boxes.step(); + tool_BODY_list.step(); + tool_BODY_list_copy.step(); + + } + + // done with iteration over ii; step the lists + from_BODY_list_copy.step(); + from_BODY_list.step(); + from_bodies.step(); } - // done with this j iteration; write out count, if necessary - if (from_bodies.size() * tool_body_list.size() > 1) - { - int frac_done = (10 * ii) / (from_bodies.size()* tool_body_list.size()); - if ((10 - frac_done) < fraction_remaining) - { - PRINT_INFO("%d ", fraction_remaining); - fraction_remaining--; - } - } - } - tool_boxes.step(); - tool_BODY_list.step(); - tool_BODY_list_copy.step(); + // ok, we're done with all the imprints; construct new Body's for the new BODY's + from_BODY_list_copy.reset(); + from_BODY_list.reset(); + from_bodies.reset(); - } + for (ii = 0; ii< from_BODY_list_copy.size(); ii++) + { + BODY *old_BODY = from_BODY_list.get(); + BODY *new_BODY = from_BODY_list_copy.get(); - // done with iteration over ii; step the lists - from_BODY_list_copy.step(); - from_BODY_list.step(); - from_bodies.step(); - } + BodySM *new_body = NULL; + if (old_BODY != new_BODY) + new_body = get_new_Body(from_bodies.get(), old_BODY, new_BODY, keep_old); - // ok, we're done with all the imprints; construct new Body's for the new BODY's - from_BODY_list_copy.reset(); - from_BODY_list.reset(); - from_bodies.reset(); + if (new_body) + { + new_from_bodies.append(new_body); + from_bodies.change_to(NULL); + } - for (ii = 0; ii< from_BODY_list_copy.size(); ii++) - { - BODY *old_BODY = from_BODY_list.get(); - BODY *new_BODY = from_BODY_list_copy.get(); + // now step all the lists + from_BODY_list.step(); + from_BODY_list_copy.step(); + from_bodies.step(); + } - BodySM *new_body = NULL; - if (old_BODY != new_BODY) - new_body = get_new_Body(from_bodies.get(), old_BODY, new_BODY, keep_old); + from_bodies.remove_all_with_value(NULL); + from_bodies.reset(); + new_from_bodies.reset(); - if (new_body) - { - new_from_bodies.append(new_body); - from_bodies.change_to(NULL); - } + for(ii = tool_BODY_list_copy.size(); ii>0; ii--) + AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY_list_copy.get_and_step(), CUBIT_TRUE); - // now step all the lists - from_BODY_list.step(); - from_BODY_list_copy.step(); - from_bodies.step(); - } + if (sub_stat == CUBIT_SUCCESS && !keep_old) + AcisQueryEngine::instance()->delete_solid_model_entities(tool_body_list); - from_bodies.remove_all_with_value(NULL); - from_bodies.reset(); - new_from_bodies.reset(); + for(ii = tool_boxes.size(); ii>0; ii--) + delete tool_boxes.get_and_step(); - for(ii = tool_BODY_list_copy.size(); ii>0; ii--) - AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY_list_copy.get_and_step(), CUBIT_TRUE); + return CUBIT_SUCCESS; + } - if (sub_stat == CUBIT_SUCCESS && !keep_old) - AcisQueryEngine::instance()->delete_solid_model_entities(tool_body_list); + //------------------------------------------------------------------------- + // Purpose : Boolean Operation of two Bodys: imprint + // + // Special Notes : + // + // Creator : Malcolm J. Panthaki + // + // Creation Date : 10/30/96 + //------------------------------------------------------------------------- + CubitStatus AcisModifyEngine::imprint(BodySM* BodyPtr1, + BodySM* BodyPtr2, + BodySM*& newBodyPtr1, + BodySM*& newBodyPtr2, + bool keep_old) const + { + // There are two many places things can go wrong. When they do, in + // addition to returning a CUBIT_FAILURE, we should return some sensible + // values through the output arguments. Before any of the output Body's can + // be created, the most sensible for these is NULL. + newBodyPtr1 = NULL ; + newBodyPtr2 = NULL ; - for(ii = tool_boxes.size(); ii>0; ii--) - delete tool_boxes.get_and_step(); + // first, check bounding SPAbox; if they don't intersect, imprint will fail + AcisQueryEngine* aqe = AcisQueryEngine::instance(); + BODY* BODYPtr1 = aqe->get_BODY(BodyPtr1); + BODY* BODYPtr2 = aqe->get_BODY(BodyPtr2); - return CUBIT_SUCCESS; -} + if( (BODYPtr1 == NULL) || (BODYPtr2 == NULL) ) + { + return CUBIT_FAILURE; + } -//------------------------------------------------------------------------- -// Purpose : Boolean Operation of two Bodys: imprint -// -// Special Notes : -// -// Creator : Malcolm J. Panthaki -// -// Creation Date : 10/30/96 -//------------------------------------------------------------------------- -CubitStatus AcisModifyEngine::imprint(BodySM* BodyPtr1, - BodySM* BodyPtr2, - BodySM*& newBodyPtr1, - BodySM*& newBodyPtr2, - bool keep_old) const -{ - // There are two many places things can go wrong. When they do, in - // addition to returning a CUBIT_FAILURE, we should return some sensible - // values through the output arguments. Before any of the output Body's can - // be created, the most sensible for these is NULL. - newBodyPtr1 = NULL ; - newBodyPtr2 = NULL ; + CubitBox box1 = aqe->bounding_box(aqe->bounding_box(BODYPtr1)); + CubitBox box2 = aqe->bounding_box(aqe->bounding_box(BODYPtr2)); + if (! box1.overlap(SPAresabs, box2)) + return CUBIT_FAILURE; - // first, check bounding SPAbox; if they don't intersect, imprint will fail - AcisQueryEngine* aqe = AcisQueryEngine::instance(); - BODY* BODYPtr1 = aqe->get_BODY(BodyPtr1); - BODY* BODYPtr2 = aqe->get_BODY(BodyPtr2); + // Make copies of the ACIS bodies. This is required because if the ultimate + // result is a body with no LUMPs, then we need to be able to restore + // the original BODY's and their Bodies. + BODY* BODYPtr1Save; + BODY* BODYPtr2Save; - if( (BODYPtr1 == NULL) || (BODYPtr2 == NULL) ) - { - return CUBIT_FAILURE; - } + // pass in keep_old to the delete_owner_attrib flag; if we're not keeping + // old bodies, we want to keep the owner attrib, so we can pick up entities + // that didn't change + bool delete_attribs = + (GeometryModifyTool::instance()->get_new_ids() || keep_old); + BODYPtr1Save = this->copy_BODY(BODYPtr1, delete_attribs); + if (BODYPtr1Save == NULL) + { + PRINT_ERROR("Copy of volume failed.\n Imprint failed.\n"); + return CUBIT_FAILURE; + } + BODYPtr2Save = this->copy_BODY(BODYPtr2, delete_attribs); + if (BODYPtr2Save == NULL) + { + AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr1Save, CUBIT_TRUE); + PRINT_ERROR("Copy of volume failed.\n Imprint failed.\n"); + return CUBIT_FAILURE; + } - CubitBox box1 = aqe->bounding_box(aqe->bounding_box(BODYPtr1)); - CubitBox box2 = aqe->bounding_box(aqe->bounding_box(BODYPtr2)); - if (! box1.overlap(SPAresabs, box2)) - return CUBIT_FAILURE; + // Keep track of the number of curves/surfaces/vertices in each body. That + // way we can tell if they really changed. + int num_vol1_bef, num_face1_bef, num_edge1_bef, num_vertex1_bef; + if( AcisQueryEngine::instance()->number_ENTITIES( BODYPtr1Save, num_vol1_bef, num_face1_bef, num_edge1_bef, + num_vertex1_bef ) == CUBIT_FAILURE ) + { + PRINT_ERROR( "Unable to count number of entities in volume\n" ); + return CUBIT_FAILURE; + } + int num_vol2_bef, num_face2_bef, num_edge2_bef, num_vertex2_bef; + if( AcisQueryEngine::instance()->number_ENTITIES( BODYPtr2Save, num_vol2_bef, num_face2_bef, num_edge2_bef, + num_vertex2_bef ) == CUBIT_FAILURE ) + { + PRINT_ERROR( "Unable to count number of entities in volume\n" ); + return CUBIT_FAILURE; + } - // Make copies of the ACIS bodies. This is required because if the ultimate - // result is a body with no LUMPs, then we need to be able to restore - // the original BODY's and their Bodies. - BODY* BODYPtr1Save; - BODY* BODYPtr2Save; + // Now, imprint the 2 BODYs + if ( GeometryModifyTool::get_all_edges_imprint() ) + { + api_set_int_option("all_free_edges", TRUE ); + } - // pass in keep_old to the delete_owner_attrib flag; if we're not keeping - // old bodies, we want to keep the owner attrib, so we can pick up entities - // that didn't change - bool delete_attribs = - (GeometryModifyTool::instance()->get_new_ids() || keep_old); - BODYPtr1Save = this->copy_BODY(BODYPtr1, delete_attribs); - if (BODYPtr1Save == NULL) - { - PRINT_ERROR("Copy of volume failed.\n Imprint failed.\n"); - return CUBIT_FAILURE; - } - BODYPtr2Save = this->copy_BODY(BODYPtr2, delete_attribs); - if (BODYPtr2Save == NULL) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr1Save, CUBIT_TRUE); - PRINT_ERROR("Copy of volume failed.\n Imprint failed.\n"); - return CUBIT_FAILURE; - } + outcome result = api_imprint( BODYPtr1Save, BODYPtr2Save ); - // Keep track of the number of curves/surfaces/vertices in each body. That - // way we can tell if they really changed. - int num_vol1_bef, num_face1_bef, num_edge1_bef, num_vertex1_bef; - if( AcisQueryEngine::instance()->number_ENTITIES( BODYPtr1Save, num_vol1_bef, num_face1_bef, num_edge1_bef, - num_vertex1_bef ) == CUBIT_FAILURE ) - { - PRINT_ERROR( "Unable to count number of entities in volume\n" ); - return CUBIT_FAILURE; - } - int num_vol2_bef, num_face2_bef, num_edge2_bef, num_vertex2_bef; - if( AcisQueryEngine::instance()->number_ENTITIES( BODYPtr2Save, num_vol2_bef, num_face2_bef, num_edge2_bef, - num_vertex2_bef ) == CUBIT_FAILURE ) - { - PRINT_ERROR( "Unable to count number of entities in volume\n" ); - return CUBIT_FAILURE; - } + //Gets rid of sliver curves/surfaces that could get produced by the imprint. + AcisModifyEngine::instance()->cleanup_slivers( BODYPtr1Save ); + AcisModifyEngine::instance()->cleanup_slivers( BODYPtr2Save ); - // Now, imprint the 2 BODYs - if ( GeometryModifyTool::get_all_edges_imprint() ) - { - api_set_int_option("all_free_edges", TRUE ); - } + if ( GeometryModifyTool::get_all_edges_imprint() ) + { + api_set_int_option("all_free_edges", FALSE ); + } - outcome result = api_imprint( BODYPtr1Save, BODYPtr2Save ); + if (!result.ok()) + { + // might just be no overlap, check smaller boxes + if (!BODYPtr1Save || !BODYPtr2Save || + box1.overlap(SPAresabs,box2) == CUBIT_TRUE) + { + if (DEBUG_FLAG(95)) + { + AcisQueryEngine::instance()->ACIS_API_error(result, "imprint Bodies"); + } - //Gets rid of sliver curves/surfaces that could get produced by the imprint. - AcisModifyEngine::instance()->cleanup_slivers( BODYPtr1Save ); - AcisModifyEngine::instance()->cleanup_slivers( BODYPtr2Save ); + if (BODYPtr1Save != NULL) + { + AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr1Save, CUBIT_TRUE); + } + if (BODYPtr2Save != NULL) + { + AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr2Save, CUBIT_TRUE); + } + return CUBIT_FAILURE; + } + } - if ( GeometryModifyTool::get_all_edges_imprint() ) - { - api_set_int_option("all_free_edges", FALSE ); - } - if (!result.ok()) - { - // might just be no overlap, check smaller boxes - if (!BODYPtr1Save || !BODYPtr2Save || - box1.overlap(SPAresabs,box2) == CUBIT_TRUE) - { - if (DEBUG_FLAG(95)) - { - AcisQueryEngine::instance()->ACIS_API_error(result, "imprint Bodies"); - } + // Compare body 1 before & after imprint + int num_vol1_aft, num_face1_aft, num_edge1_aft, num_vertex1_aft; + if( AcisQueryEngine::instance()-> + number_ENTITIES( BODYPtr1Save, num_vol1_aft, num_face1_aft, num_edge1_aft, + num_vertex1_aft ) == CUBIT_FAILURE ) + { + PRINT_ERROR( "Unable to count number of entities in volume\n" ); + if (BODYPtr1Save != NULL) + { + AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr1Save, CUBIT_TRUE); + } + if (BODYPtr2Save != NULL) + { + AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr2Save, CUBIT_TRUE); + } + return CUBIT_FAILURE; + } - if (BODYPtr1Save != NULL) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr1Save, CUBIT_TRUE); - } - if (BODYPtr2Save != NULL) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr2Save, CUBIT_TRUE); - } - return CUBIT_FAILURE; - } - } + // Only create a new Body1 if it changed + if( num_vol1_bef != num_vol1_aft || + num_face1_bef != num_face1_aft || + num_edge1_bef != num_edge1_aft || + num_vertex1_bef != num_vertex1_aft || + GeometryModifyTool::instance()->get_group_imprint() == CUBIT_FALSE) + { + DLIList<EDGE*> new_edges = AcisModifyEngine::instance()->find_new_EDGES(BODYPtr2Save); + newBodyPtr1 = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr1Save); + if (newBodyPtr1 == NULL ) + { + PRINT_ERROR("Problems creating topology for imprinted volume.\n") ; + if (BODYPtr1Save != NULL) + { + AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr1Save, CUBIT_TRUE); + } + if (BODYPtr2Save != NULL) + { + AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr2Save, CUBIT_TRUE); + } + return CUBIT_FAILURE; + } - // Compare body 1 before & after imprint - int num_vol1_aft, num_face1_aft, num_edge1_aft, num_vertex1_aft; - if( AcisQueryEngine::instance()-> - number_ENTITIES( BODYPtr1Save, num_vol1_aft, num_face1_aft, num_edge1_aft, - num_vertex1_aft ) == CUBIT_FAILURE ) - { - PRINT_ERROR( "Unable to count number of entities in volume\n" ); - if (BODYPtr1Save != NULL) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr1Save, CUBIT_TRUE); - } - if (BODYPtr2Save != NULL) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr2Save, CUBIT_TRUE); - } - return CUBIT_FAILURE; - } + // Add a imprint feature to the topo edges + for (int edge_count = new_edges.size(); edge_count--; ) + { + CubitSimpleAttrib *tmp_attrib = new CubitSimpleAttrib( "SOURCE_FEATURE", "IMPRINT" ); + new ATTRIB_SNL_SIMPLE( new_edges[edge_count], tmp_attrib ); + delete tmp_attrib; + } - // Only create a new Body1 if it changed - if( num_vol1_bef != num_vol1_aft || - num_face1_bef != num_face1_aft || - num_edge1_bef != num_edge1_aft || - num_vertex1_bef != num_vertex1_aft || - GeometryModifyTool::instance()->get_group_imprint() == CUBIT_FALSE) - { - DLIList<EDGE*> new_edges = AcisModifyEngine::instance()->find_new_EDGES(BODYPtr2Save); + //BodyPtr1->switch_entity_names(newBodyPtr1); + if (GeometryModifyTool::get_old_names()) + { + Body* model_ent = dynamic_cast<Body*>(BodyPtr1->topology_entity()); + if (model_ent) + { + Body* new_model_ent = dynamic_cast<Body*>(newBodyPtr1->topology_entity()); + if (!new_model_ent) + new_model_ent = GeometryQueryTool::instance()->make_Body(newBodyPtr1); + model_ent->switch_entity_names(new_model_ent); + } + } - newBodyPtr1 = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr1Save); - if (newBodyPtr1 == NULL ) - { - PRINT_ERROR("Problems creating topology for imprinted volume.\n") ; - if (BODYPtr1Save != NULL) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr1Save, CUBIT_TRUE); - } - if (BODYPtr2Save != NULL) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr2Save, CUBIT_TRUE); - } - return CUBIT_FAILURE; - } + if (keep_old == CUBIT_FALSE) + AcisQueryEngine::instance()->delete_solid_model_entities(BodyPtr1); + } + else + { + AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr1Save, CUBIT_TRUE); + } - // Add a imprint feature to the topo edges - for (int edge_count = new_edges.size(); edge_count--; ) - { - CubitSimpleAttrib *tmp_attrib = new CubitSimpleAttrib( "SOURCE_FEATURE", "IMPRINT" ); - new ATTRIB_SNL_SIMPLE( new_edges[edge_count], tmp_attrib ); - delete tmp_attrib; - } + // Compare body 2 before & after imprint + int num_vol2_aft, num_face2_aft, num_edge2_aft, num_vertex2_aft; + if( AcisQueryEngine::instance()->number_ENTITIES( BODYPtr2Save, num_vol2_aft, num_face2_aft, num_edge2_aft, + num_vertex2_aft ) == CUBIT_FAILURE ) + { + PRINT_ERROR( "Unable to count number of entities in volume.\n"); + if (BODYPtr1Save != NULL) + { + AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr1Save, CUBIT_TRUE); + } + if (BODYPtr2Save != NULL) + { + AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr2Save, CUBIT_TRUE); + } + return CUBIT_FAILURE; + } - //BodyPtr1->switch_entity_names(newBodyPtr1); - if (GeometryModifyTool::get_old_names()) - { - Body* model_ent = dynamic_cast<Body*>(BodyPtr1->topology_entity()); - if (model_ent) - { - Body* new_model_ent = dynamic_cast<Body*>(newBodyPtr1->topology_entity()); - if (!new_model_ent) - new_model_ent = GeometryQueryTool::instance()->make_Body(newBodyPtr1); - model_ent->switch_entity_names(new_model_ent); - } - } + // Only create a new Body2 if it changed + if( num_vol2_bef != num_vol2_aft || + num_face2_bef != num_face2_aft || + num_edge2_bef != num_edge2_aft || + num_vertex2_bef != num_vertex2_aft || + GeometryModifyTool::instance()->get_group_imprint() == CUBIT_FALSE) + { + DLIList<EDGE*> new_edges = AcisModifyEngine::instance()->find_new_EDGES(BODYPtr2Save); - if (keep_old == CUBIT_FALSE) - AcisQueryEngine::instance()->delete_solid_model_entities(BodyPtr1); - } - else - { - AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr1Save, CUBIT_TRUE); - } + newBodyPtr2 = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr2Save); + if (newBodyPtr2 == NULL ) + { + PRINT_ERROR("Problems creating topology for imprinted volume.\n" ) ; + if (BODYPtr2Save != NULL) + { + AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr2Save, CUBIT_TRUE); + } + return CUBIT_FAILURE; + } - // Compare body 2 before & after imprint - int num_vol2_aft, num_face2_aft, num_edge2_aft, num_vertex2_aft; - if( AcisQueryEngine::instance()->number_ENTITIES( BODYPtr2Save, num_vol2_aft, num_face2_aft, num_edge2_aft, - num_vertex2_aft ) == CUBIT_FAILURE ) - { - PRINT_ERROR( "Unable to count number of entities in volume.\n"); - if (BODYPtr1Save != NULL) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr1Save, CUBIT_TRUE); - } - if (BODYPtr2Save != NULL) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr2Save, CUBIT_TRUE); - } - return CUBIT_FAILURE; - } + // Add a imprint feature to the topo edges + for (int edge_count = new_edges.size(); edge_count--; ) + { + CubitSimpleAttrib *tmp_attrib = new CubitSimpleAttrib( "SOURCE_FEATURE", "IMPRINT" ); + new ATTRIB_SNL_SIMPLE( new_edges[edge_count], tmp_attrib ); + delete tmp_attrib; + } - // Only create a new Body2 if it changed - if( num_vol2_bef != num_vol2_aft || - num_face2_bef != num_face2_aft || - num_edge2_bef != num_edge2_aft || - num_vertex2_bef != num_vertex2_aft || - GeometryModifyTool::instance()->get_group_imprint() == CUBIT_FALSE) - { - DLIList<EDGE*> new_edges = AcisModifyEngine::instance()->find_new_EDGES(BODYPtr2Save); + if (GeometryModifyTool::get_old_names()) + { + Body* model_ent = dynamic_cast<Body*>(BodyPtr2->topology_entity()); + if (model_ent) + { + Body* new_model_ent = dynamic_cast<Body*>(newBodyPtr2->topology_entity()); + if (!new_model_ent) + new_model_ent = GeometryQueryTool::instance()->make_Body(newBodyPtr2); + model_ent->switch_entity_names(new_model_ent); + } + } - newBodyPtr2 = AcisQueryEngine::instance()->populate_topology_bridges(BODYPtr2Save); - if (newBodyPtr2 == NULL ) - { - PRINT_ERROR("Problems creating topology for imprinted volume.\n" ) ; - if (BODYPtr2Save != NULL) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr2Save, CUBIT_TRUE); - } - return CUBIT_FAILURE; - } + if (keep_old == CUBIT_FALSE) + AcisQueryEngine::instance()->delete_solid_model_entities(BodyPtr2); + //actuate_mesh_intervals( newBodyPtr2 ); + } + else + { + AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr2Save, CUBIT_TRUE); + } - // Add a imprint feature to the topo edges - for (int edge_count = new_edges.size(); edge_count--; ) - { - CubitSimpleAttrib *tmp_attrib = new CubitSimpleAttrib( "SOURCE_FEATURE", "IMPRINT" ); - new ATTRIB_SNL_SIMPLE( new_edges[edge_count], tmp_attrib ); - delete tmp_attrib; - } + // All's well with the world :-) + return CUBIT_SUCCESS; - if (GeometryModifyTool::get_old_names()) - { - Body* model_ent = dynamic_cast<Body*>(BodyPtr2->topology_entity()); - if (model_ent) - { - Body* new_model_ent = dynamic_cast<Body*>(newBodyPtr2->topology_entity()); - if (!new_model_ent) - new_model_ent = GeometryQueryTool::instance()->make_Body(newBodyPtr2); - model_ent->switch_entity_names(new_model_ent); - } - } + } - if (keep_old == CUBIT_FALSE) - AcisQueryEngine::instance()->delete_solid_model_entities(BodyPtr2); - //actuate_mesh_intervals( newBodyPtr2 ); - } - else - { - AcisQueryEngine::instance()->delete_ACIS_BODY(BODYPtr2Save, CUBIT_TRUE); - } + BodySM *AcisModifyEngine::get_new_Body( BodySM *old_Body, + BODY *old_BODY, + BODY *new_BODY, + const bool keep_old, + const bool topology_check, + const bool delete_old) const + { + if (topology_check) + { + // must do topology check between old & new bodies. In the case + // of a topology check, we know there's only one old and new body + int num_vol_bef, num_face_bef, num_edge_bef, num_vertex_bef; + CubitStatus status1 = AcisQueryEngine::instance()->number_ENTITIES( old_BODY, num_vol_bef, + num_face_bef, num_edge_bef, + num_vertex_bef ); - // All's well with the world :-) - return CUBIT_SUCCESS; + int num_vol_aft, num_face_aft, num_edge_aft, num_vertex_aft; + CubitStatus status2 = AcisQueryEngine::instance()->number_ENTITIES( new_BODY, num_vol_aft, + num_face_aft, num_edge_aft, + num_vertex_aft ); -} + if( status1 == CUBIT_FAILURE || + status2 == CUBIT_FAILURE ) + { + PRINT_ERROR( "Unable to count number of entities in volume\n" ); -BodySM *AcisModifyEngine::get_new_Body( BodySM *old_Body, - BODY *old_BODY, - BODY *new_BODY, - const bool keep_old, - const bool topology_check, - const bool delete_old) const -{ - if (topology_check) - { - // must do topology check between old & new bodies. In the case - // of a topology check, we know there's only one old and new body - int num_vol_bef, num_face_bef, num_edge_bef, num_vertex_bef; - CubitStatus status1 = AcisQueryEngine::instance()->number_ENTITIES( old_BODY, num_vol_bef, - num_face_bef, num_edge_bef, - num_vertex_bef ); + return 0; + } - int num_vol_aft, num_face_aft, num_edge_aft, num_vertex_aft; - CubitStatus status2 = AcisQueryEngine::instance()->number_ENTITIES( new_BODY, num_vol_aft, - num_face_aft, num_edge_aft, - num_vertex_aft ); + if( num_vol_bef == num_vol_aft && + num_face_bef == num_face_aft && + num_edge_bef == num_edge_aft && + num_vertex_bef == num_vertex_aft) + { + AcisQueryEngine::instance()->delete_ACIS_BODY(new_BODY, CUBIT_TRUE); + return 0; + } + } - if( status1 == CUBIT_FAILURE || - status2 == CUBIT_FAILURE ) - { - PRINT_ERROR( "Unable to count number of entities in volume\n" ); + // convert input to list-based version and pass to overloaded version of + // get_new_body + DLIList<BodySM*> Body_list(1); + if(old_Body != NULL) + Body_list.append(old_Body); + DLIList<BODY*> BODY_list(1); + if(old_BODY != NULL) + BODY_list.append(old_BODY); - return 0; + return get_new_Body(Body_list, BODY_list, new_BODY, keep_old, delete_old); } - if( num_vol_bef == num_vol_aft && - num_face_bef == num_face_aft && - num_edge_bef == num_edge_aft && - num_vertex_bef == num_vertex_aft) + BodySM *AcisModifyEngine::get_new_Body(DLIList<BodySM*> &old_Body_list, + DLIList<BODY*> &old_BODY_list, + BODY *new_BODY, + const bool keep_old, + const bool delete_old) const { - AcisQueryEngine::instance()->delete_ACIS_BODY(new_BODY, CUBIT_TRUE); - return 0; - } - } + DLIList<BODY*> new_BODY_list; + new_BODY_list.append(new_BODY); + DLIList<BodySM*> new_Body_list; + CubitStatus status = get_new_Body(old_Body_list, old_BODY_list, + new_BODY_list, new_Body_list, + keep_old, delete_old); - // convert input to list-based version and pass to overloaded version of - // get_new_body - DLIList<BodySM*> Body_list(1); - if(old_Body != NULL) - Body_list.append(old_Body); - DLIList<BODY*> BODY_list(1); - if(old_BODY != NULL) - BODY_list.append(old_BODY); + if (status == CUBIT_FAILURE || + new_Body_list.size() == 0) return NULL; - return get_new_Body(Body_list, BODY_list, new_BODY, keep_old, delete_old); -} + assert(new_Body_list.size() == 1); -BodySM *AcisModifyEngine::get_new_Body(DLIList<BodySM*> &old_Body_list, - DLIList<BODY*> &old_BODY_list, - BODY *new_BODY, - const bool keep_old, - const bool delete_old) const -{ - DLIList<BODY*> new_BODY_list; - new_BODY_list.append(new_BODY); - DLIList<BodySM*> new_Body_list; - CubitStatus status = get_new_Body(old_Body_list, old_BODY_list, - new_BODY_list, new_Body_list, - keep_old, delete_old); + return new_Body_list.get(); + } - if (status == CUBIT_FAILURE || - new_Body_list.size() == 0) return NULL; + CubitStatus AcisModifyEngine::get_new_Body( BodySM *old_Body, + BODY *old_BODY, + DLIList<BODY*> &new_BODY_list, + DLIList<BodySM*> &new_Body_list, + const bool keep_old, + const bool delete_old) const + { + DLIList<BODY*> old_BODY_list; + old_BODY_list.append(old_BODY); + DLIList<BodySM*> old_Body_list; + old_Body_list.append(old_Body); + return get_new_Body(old_Body_list, old_BODY_list, + new_BODY_list, new_Body_list, + keep_old, delete_old); + } - assert(new_Body_list.size() == 1); - - return new_Body_list.get(); -} - -CubitStatus AcisModifyEngine::get_new_Body( BodySM *old_Body, - BODY *old_BODY, - DLIList<BODY*> &new_BODY_list, - DLIList<BodySM*> &new_Body_list, - const bool keep_old, - const bool delete_old) const -{ - DLIList<BODY*> old_BODY_list; - old_BODY_list.append(old_BODY); - DLIList<BodySM*> old_Body_list; - old_Body_list.append(old_Body); - return get_new_Body(old_Body_list, old_BODY_list, - new_BODY_list, new_Body_list, - keep_old, delete_old); -} - -CubitStatus AcisModifyEngine::get_new_Body(DLIList<BodySM*> &old_Body_list, + CubitStatus AcisModifyEngine::get_new_Body(DLIList<BodySM*> &old_Body_list, DLIList<BODY*> &old_BODY_list, DLIList<BODY*> &new_BODY_list, DLIList<BodySM*> &new_Body_list, const bool keep_old, const bool delete_old) const -{ - assert(old_Body_list.size() == old_BODY_list.size()); + { + assert(old_Body_list.size() == old_BODY_list.size()); - //&& old_Body_list.size() > 0); It's possible now to have no - //old bodies, so don't stress over this + //&& old_Body_list.size() > 0); It's possible now to have no + //old bodies, so don't stress over this - // Only create a new Body if it changed - BodySM *new_Body = NULL; + // Only create a new Body if it changed + BodySM *new_Body = NULL; - // body changed; need to build a new vgi body around - // old_BODY, either by reusing old_Body or creating new one + // body changed; need to build a new vgi body around + // old_BODY, either by reusing old_Body or creating new one - if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_FALSE && - keep_old == CUBIT_FALSE) - { - // if we're reusing old refentities, prepare by marking - // deactivated the ones that don't get reused, then delete - // those - int num_deactivd = 0; - int i; - for (i = old_BODY_list.size(); i > 0; i--) - num_deactivd += mark_owners_deactivated_flag(old_BODY_list.get_and_step(), - CUBIT_TRUE); + if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_FALSE && + keep_old == CUBIT_FALSE) + { + // if we're reusing old refentities, prepare by marking + // deactivated the ones that don't get reused, then delete + // those + int num_deactivd = 0; + int i; + for (i = old_BODY_list.size(); i > 0; i--) + num_deactivd += mark_owners_deactivated_flag(old_BODY_list.get_and_step(), + CUBIT_TRUE); - int num_reactivd = 0; - for (i = new_BODY_list.size(); i > 0; i--) - num_reactivd = mark_owners_deactivated_flag(new_BODY_list.get_and_step(), - CUBIT_FALSE); - if (DEBUG_FLAG(99)) - { - PRINT_DEBUG_99( "Number of entities deactivated = %d," - " reactivated = %d\n", num_deactivd, num_reactivd); - print_deleted_reused(old_BODY_list, new_BODY_list); - } + int num_reactivd = 0; + for (i = new_BODY_list.size(); i > 0; i--) + num_reactivd = mark_owners_deactivated_flag(new_BODY_list.get_and_step(), + CUBIT_FALSE); + if (DEBUG_FLAG(99)) + { + PRINT_DEBUG_99( "Number of entities deactivated = %d," + " reactivated = %d\n", num_deactivd, num_reactivd); + print_deleted_reused(old_BODY_list, new_BODY_list); + } - // ok, now unhook the old body from the vgi data (only done if - // we aren't keeping old geometry) - if (keep_old == CUBIT_FALSE) - { - for (i = old_BODY_list.size(); i > 0; i--) - AcisQueryEngine::instance()->delete_ACIS_BODY(old_BODY_list.get_and_step(), CUBIT_FALSE); - } + // ok, now unhook the old body from the vgi data (only done if + // we aren't keeping old geometry) + if (keep_old == CUBIT_FALSE) + { + for (i = old_BODY_list.size(); i > 0; i--) + AcisQueryEngine::instance()->delete_ACIS_BODY(old_BODY_list.get_and_step(), CUBIT_FALSE); + } - // now cleanout the deactivated geometry; automatically unhooks - // from the dag - cleanout_deactivated_geometry(); - } - // now delete the old body, either obeying or not obeying the - // deactivated flags (which is opposite of the - // create_new_refents flag) - if (GeometryModifyTool::instance()->get_new_ids() && !keep_old && delete_old) - { - for (int i = old_Body_list.size(); i > 0; i--) - { - BodySM *old_Body = old_Body_list.get_and_step(); - AcisQueryEngine::instance()->delete_solid_model_entities(old_Body); - } - } + // now cleanout the deactivated geometry; automatically unhooks + // from the dag + cleanout_deactivated_geometry(); + } + // now delete the old body, either obeying or not obeying the + // deactivated flags (which is opposite of the + // create_new_refents flag) + if (GeometryModifyTool::instance()->get_new_ids() && !keep_old && delete_old) + { + for (int i = old_Body_list.size(); i > 0; i--) + { + BodySM *old_Body = old_Body_list.get_and_step(); + AcisQueryEngine::instance()->delete_solid_model_entities(old_Body); + } + } - int i; - for (i = new_BODY_list.size(); i > 0; i--) - { - new_Body = AcisQueryEngine::instance()->populate_topology_bridges(new_BODY_list.get_and_step()); - if (new_Body != NULL) - new_Body_list.append(new_Body); - else - { - PRINT_ERROR("Problems creating new Body from new BODY.\n" - " get_new_Body failed.\n") ; - return CUBIT_FAILURE; + int i; + for (i = new_BODY_list.size(); i > 0; i--) + { + new_Body = AcisQueryEngine::instance()->populate_topology_bridges(new_BODY_list.get_and_step()); + if (new_Body != NULL) + new_Body_list.append(new_Body); + else + { + PRINT_ERROR("Problems creating new Body from new BODY.\n" + " get_new_Body failed.\n") ; + return CUBIT_FAILURE; + } + } + + if( keep_old && GeometryModifyTool::get_old_names() ) + { + // switch names with the first body only + old_Body_list.reset(); + BodySM* old_bodysm = old_Body_list.get(); + Body* body = dynamic_cast<Body*>(old_bodysm->topology_entity()); + if (body) + { + Body* new_body = dynamic_cast<Body*>(new_Body->topology_entity()); + if (!new_body) + new_body = GeometryQueryTool::instance()->make_Body(new_Body); + body->switch_entity_names(new_body); + } + } + + return CUBIT_SUCCESS; } - } - if( keep_old && GeometryModifyTool::get_old_names() ) - { - // switch names with the first body only - old_Body_list.reset(); - BodySM* old_bodysm = old_Body_list.get(); - Body* body = dynamic_cast<Body*>(old_bodysm->topology_entity()); - if (body) + CubitStatus AcisModifyEngine::get_new_Body( DLIList<TopologyBridge*> &old_entity_list, + DLIList<BODY*> &new_BODY_list, + DLIList<BodySM*> &new_Body_list, + const bool keep_old, + const bool delete_old) const { - Body* new_body = dynamic_cast<Body*>(new_Body->topology_entity()); - if (!new_body) - new_body = GeometryQueryTool::instance()->make_Body(new_Body); - body->switch_entity_names(new_body); - } - } + assert(old_entity_list.size() > 0 || keep_old ); - return CUBIT_SUCCESS; -} + // don't do a topology check in this version of get_new_Body -CubitStatus AcisModifyEngine::get_new_Body( DLIList<TopologyBridge*> &old_entity_list, - DLIList<BODY*> &new_BODY_list, - DLIList<BodySM*> &new_Body_list, - const bool keep_old, - const bool delete_old) const -{ - assert(old_entity_list.size() > 0 || keep_old ); + // need to build a new body or bodies - // don't do a topology check in this version of get_new_Body + if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_FALSE && + keep_old == CUBIT_FALSE) + { + // if we're reusing old refentities, prepare by marking + // deactivated the ones that don't get reused, then delete + // those + int i, j, num_deactivd = 0, num_reactivd = 0; - // need to build a new body or bodies + ENTITY_LIST old_ENTITY_list, tmp_ENTITY_list; + old_entity_list.reset(); + for (i = old_entity_list.size(); i--; ) + { + tmp_ENTITY_list.clear(); + TopologyBridge* geom_ptr = old_entity_list.get_and_step(); + AcisBridge* bridge_ptr = dynamic_cast<AcisBridge*>(geom_ptr); + if (!bridge_ptr) + { + PRINT_ERROR("Non-ACIS geometry at %s:%d\n",__FILE__,__LINE__); + continue; + } + ENTITY* ENTITY_ptr = bridge_ptr->ENTITY_ptr(); + if (!ENTITY_ptr) + continue; - if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_FALSE && - keep_old == CUBIT_FALSE) - { - // if we're reusing old refentities, prepare by marking - // deactivated the ones that don't get reused, then delete - // those - int i, j, num_deactivd = 0, num_reactivd = 0; + old_ENTITY_list.add(ENTITY_ptr); - ENTITY_LIST old_ENTITY_list, tmp_ENTITY_list; - old_entity_list.reset(); - for (i = old_entity_list.size(); i--; ) - { - tmp_ENTITY_list.clear(); - TopologyBridge* geom_ptr = old_entity_list.get_and_step(); - AcisBridge* bridge_ptr = dynamic_cast<AcisBridge*>(geom_ptr); - if (!bridge_ptr) - { - PRINT_ERROR("Non-ACIS geometry at %s:%d\n",__FILE__,__LINE__); - continue; - } - ENTITY* ENTITY_ptr = bridge_ptr->ENTITY_ptr(); - if (!ENTITY_ptr) - continue; - old_ENTITY_list.add(ENTITY_ptr); + CubitStatus stat = AcisQueryEngine::instance()-> + get_child_ENTITYs( ENTITY_ptr, tmp_ENTITY_list, true); + if (!stat) + { + PRINT_ERROR("AcisQueryEngine::get_child_ENTITYs failed at %s:%d\n",__FILE__,__LINE__); + continue; + } + for (j = 0; j < tmp_ENTITY_list.count(); j++) + { + old_ENTITY_list.add( tmp_ENTITY_list[j] ); + } + } - CubitStatus stat = AcisQueryEngine::instance()-> - get_child_ENTITYs( ENTITY_ptr, tmp_ENTITY_list, true); - if (!stat) - { - PRINT_ERROR("AcisQueryEngine::get_child_ENTITYs failed at %s:%d\n",__FILE__,__LINE__); - continue; - } + for (i = 0; i < old_ENTITY_list.count(); i++) + { + // mark the owners deactivated, but don't recurse, since we've got all + // the lower order topology already + num_deactivd += mark_owners_deactivated_flag(old_ENTITY_list[i], + CUBIT_TRUE, + CUBIT_FALSE); + } - for (j = 0; j < tmp_ENTITY_list.count(); j++) - { - old_ENTITY_list.add( tmp_ENTITY_list[j] ); - } - } - for (i = 0; i < old_ENTITY_list.count(); i++) - { - // mark the owners deactivated, but don't recurse, since we've got all - // the lower order topology already - num_deactivd += mark_owners_deactivated_flag(old_ENTITY_list[i], - CUBIT_TRUE, - CUBIT_FALSE); - } + for (i = new_BODY_list.size(); i > 0; i--) + num_reactivd += mark_owners_deactivated_flag(new_BODY_list.get_and_step(), + CUBIT_FALSE); + if (DEBUG_FLAG(99)) + { + PRINT_DEBUG_99( "Number of entities deactivated = %d," + " reactivated = %d\n", num_deactivd, num_reactivd); + } + // ok, now unhook the old body from the vgi data (only done if + // we aren't keeping old geometry) + if (keep_old == CUBIT_FALSE) + { + ENTITY_LIST to_be_deleted; + for (i = 0; i < old_ENTITY_list.count(); i++) + { + // need to check to make sure the old entity isn't in the new body + ENTITY *this_ENTITY = old_ENTITY_list[i]; + BODY *this_BODY = AcisQueryEngine::instance()->get_BODY_of_ENTITY(this_ENTITY); + //if the entity is not in the new body, add it to a list of + //entities to be deleted + if (!new_BODY_list.move_to(this_BODY)) + to_be_deleted.add(this_ENTITY); + } + //delete the ENTITYs in the list + AcisQueryEngine::instance()->delete_ACIS_ENTITY(to_be_deleted); + } - for (i = new_BODY_list.size(); i > 0; i--) - num_reactivd += mark_owners_deactivated_flag(new_BODY_list.get_and_step(), - CUBIT_FALSE); - if (DEBUG_FLAG(99)) - { - PRINT_DEBUG_99( "Number of entities deactivated = %d," - " reactivated = %d\n", num_deactivd, num_reactivd); - } + // now cleanout the deactivated geometry; automatically unhooks + // from the dag + cleanout_deactivated_geometry(); + } - // ok, now unhook the old body from the vgi data (only done if - // we aren't keeping old geometry) - if (keep_old == CUBIT_FALSE) - { - ENTITY_LIST to_be_deleted; - for (i = 0; i < old_ENTITY_list.count(); i++) - { - // need to check to make sure the old entity isn't in the new body - ENTITY *this_ENTITY = old_ENTITY_list[i]; - BODY *this_BODY = AcisQueryEngine::instance()->get_BODY_of_ENTITY(this_ENTITY); - //if the entity is not in the new body, add it to a list of - //entities to be deleted - if (!new_BODY_list.move_to(this_BODY)) - to_be_deleted.add(this_ENTITY); - } - //delete the ENTITYs in the list - AcisQueryEngine::instance()->delete_ACIS_ENTITY(to_be_deleted); - } - // now cleanout the deactivated geometry; automatically unhooks - // from the dag - cleanout_deactivated_geometry(); - } + // now delete the old body, either obeying or not obeying the + // deactivated flags (which is opposite of the + // create_new_refents flag) + int i; + if (GeometryModifyTool::instance()->get_new_ids() && !keep_old && delete_old) + { + for (i = old_entity_list.size(); i > 0; i--) + { + TopologyBridge *old_entity = old_entity_list.get_and_step(); + if (BodySM* bod_ptr = dynamic_cast<BodySM*>(old_entity)) + AcisQueryEngine::instance()->delete_solid_model_entities(bod_ptr); + else + AcisQueryEngine::instance()->delete_solid_model_entities( + dynamic_cast<GeometryEntity*>(old_entity),true); + } + cleanout_deactivated_geometry(); + } + for (i = new_BODY_list.size(); i > 0; i--) + { + BodySM *new_Body = AcisQueryEngine::instance()->populate_topology_bridges(new_BODY_list.get_and_step()); + if (new_Body != NULL) + new_Body_list.append(new_Body); + else + { + PRINT_ERROR("Problems creating new Body from new BODY.\n" + " get_new_Body failed.\n") ; + return CUBIT_FAILURE; + } + } - // now delete the old body, either obeying or not obeying the - // deactivated flags (which is opposite of the - // create_new_refents flag) - int i; - if (GeometryModifyTool::instance()->get_new_ids() && !keep_old && delete_old) - { - for (i = old_entity_list.size(); i > 0; i--) - { - TopologyBridge *old_entity = old_entity_list.get_and_step(); - if (BodySM* bod_ptr = dynamic_cast<BodySM*>(old_entity)) - AcisQueryEngine::instance()->delete_solid_model_entities(bod_ptr); - else - AcisQueryEngine::instance()->delete_solid_model_entities( - dynamic_cast<GeometryEntity*>(old_entity),true); + return CUBIT_SUCCESS; } - cleanout_deactivated_geometry(); - } - for (i = new_BODY_list.size(); i > 0; i--) - { - BodySM *new_Body = AcisQueryEngine::instance()->populate_topology_bridges(new_BODY_list.get_and_step()); - if (new_Body != NULL) - new_Body_list.append(new_Body); - else - { - PRINT_ERROR("Problems creating new Body from new BODY.\n" - " get_new_Body failed.\n") ; - return CUBIT_FAILURE; - } - } - - return CUBIT_SUCCESS; -} - -int AcisModifyEngine::mark_owners_deactivated_flag(ENTITY *this_ENTITY, + int AcisModifyEngine::mark_owners_deactivated_flag(ENTITY *this_ENTITY, bool flag, bool recurse) const -{ - // marks as deactivated all the owners of the input BODY, - // along with all its children - // - // order is important here; entities must be put in the - // deactivated list from lower order to higher order, that saves - // work when removing the DAG nodes from the DAG - // (not sure it's absolutely necessary though, since the - // remove_from_DAG() function calls that function recursively for - // lower order entities) + { + // marks as deactivated all the owners of the input BODY, + // along with all its children + // + // order is important here; entities must be put in the + // deactivated list from lower order to higher order, that saves + // work when removing the DAG nodes from the DAG + // (not sure it's absolutely necessary though, since the + // remove_from_DAG() function calls that function recursively for + // lower order entities) - int num_deactivated = 0; + int num_deactivated = 0; - // if we're not recursing, set the skip flag to true - CubitBoolean skip = (recurse ? CUBIT_FALSE : CUBIT_TRUE); - ENTITY_LIST ENTITIES; - outcome result; + // if we're not recursing, set the skip flag to true + CubitBoolean skip = (recurse ? CUBIT_FALSE : CUBIT_TRUE); + ENTITY_LIST ENTITIES; + outcome result; - // vertices - if (IS_ENTITY_TYPE( this_ENTITY, VERTEX )) skip = CUBIT_TRUE; - if (!skip) { - result = api_get_vertices( this_ENTITY, ENTITIES); - num_deactivated += mark_owners_deactivated_flag( ENTITIES, flag ); - ENTITIES.clear(); - } + // vertices + if (IS_ENTITY_TYPE( this_ENTITY, VERTEX )) skip = CUBIT_TRUE; + if (!skip) { + result = api_get_vertices( this_ENTITY, ENTITIES); + num_deactivated += mark_owners_deactivated_flag( ENTITIES, flag ); + ENTITIES.clear(); + } - // edges - if (IS_ENTITY_TYPE( this_ENTITY, EDGE )) skip = CUBIT_TRUE; - if (!skip) { - result = api_get_edges( this_ENTITY, ENTITIES); - num_deactivated += mark_owners_deactivated_flag( ENTITIES, flag ); - ENTITIES.clear(); - } + // edges + if (IS_ENTITY_TYPE( this_ENTITY, EDGE )) skip = CUBIT_TRUE; + if (!skip) { + result = api_get_edges( this_ENTITY, ENTITIES); + num_deactivated += mark_owners_deactivated_flag( ENTITIES, flag ); + ENTITIES.clear(); + } - // coedges - if (IS_ENTITY_TYPE( this_ENTITY, COEDGE )) skip = CUBIT_TRUE; - if (!skip) { - result = api_get_coedges( this_ENTITY, ENTITIES); - num_deactivated += mark_owners_deactivated_flag( ENTITIES, flag ); - ENTITIES.clear(); - } + // coedges + if (IS_ENTITY_TYPE( this_ENTITY, COEDGE )) skip = CUBIT_TRUE; + if (!skip) { + result = api_get_coedges( this_ENTITY, ENTITIES); + num_deactivated += mark_owners_deactivated_flag( ENTITIES, flag ); + ENTITIES.clear(); + } - // loops - if (IS_ENTITY_TYPE( this_ENTITY, LOOP )) skip = CUBIT_TRUE; - if (!skip) { - result = api_get_loops( this_ENTITY, ENTITIES); - num_deactivated += mark_owners_deactivated_flag( ENTITIES, flag ); - ENTITIES.clear(); - } + // loops + if (IS_ENTITY_TYPE( this_ENTITY, LOOP )) skip = CUBIT_TRUE; + if (!skip) { + result = api_get_loops( this_ENTITY, ENTITIES); + num_deactivated += mark_owners_deactivated_flag( ENTITIES, flag ); + ENTITIES.clear(); + } - // faces - if (IS_ENTITY_TYPE( this_ENTITY, FACE )) skip = CUBIT_TRUE; - if (!skip) { - result = api_get_faces( this_ENTITY, ENTITIES); - num_deactivated += mark_owners_deactivated_flag( ENTITIES, flag ); - ENTITIES.clear(); - } + // faces + if (IS_ENTITY_TYPE( this_ENTITY, FACE )) skip = CUBIT_TRUE; + if (!skip) { + result = api_get_faces( this_ENTITY, ENTITIES); + num_deactivated += mark_owners_deactivated_flag( ENTITIES, flag ); + ENTITIES.clear(); + } - // shells - if (IS_ENTITY_TYPE( this_ENTITY, SHELL )) skip = CUBIT_TRUE; - if (!skip) { - result = api_get_shells( this_ENTITY, ENTITIES); - num_deactivated += mark_owners_deactivated_flag( ENTITIES, flag ); - ENTITIES.clear(); - } + // shells + if (IS_ENTITY_TYPE( this_ENTITY, SHELL )) skip = CUBIT_TRUE; + if (!skip) { + result = api_get_shells( this_ENTITY, ENTITIES); + num_deactivated += mark_owners_deactivated_flag( ENTITIES, flag ); + ENTITIES.clear(); + } - // volumes - if (IS_ENTITY_TYPE( this_ENTITY, LUMP )) skip = CUBIT_TRUE; - if (!skip) { - result = api_get_lumps( this_ENTITY, ENTITIES); - num_deactivated += mark_owners_deactivated_flag( ENTITIES, flag ); - ENTITIES.clear(); - } + // volumes + if (IS_ENTITY_TYPE( this_ENTITY, LUMP )) skip = CUBIT_TRUE; + if (!skip) { + result = api_get_lumps( this_ENTITY, ENTITIES); + num_deactivated += mark_owners_deactivated_flag( ENTITIES, flag ); + ENTITIES.clear(); + } - // now, finally, do the entity itself - ENTITIES.add(this_ENTITY); - num_deactivated += mark_owners_deactivated_flag( ENTITIES, flag ); + // now, finally, do the entity itself + ENTITIES.add(this_ENTITY); + num_deactivated += mark_owners_deactivated_flag( ENTITIES, flag ); - return num_deactivated; -} + return num_deactivated; + } -int AcisModifyEngine::mark_owners_deactivated_flag( ENTITY_LIST& ENTITIES, - bool flag ) const + int AcisModifyEngine::mark_owners_deactivated_flag( ENTITY_LIST& ENTITIES, + bool flag ) const -{ - int num_deactivated = 0; - - for (int i = 0; i < ENTITIES.count(); i++) - { - AcisBridge *acis_bridge = ATTRIB_CUBIT_OWNER::cubit_owner(ENTITIES[i]); - if (acis_bridge != NULL) { - if (flag == false) - { - // if bridge was deactivated, re-activate it and... - if (reactivate_bridge(acis_bridge)) - { - // ...and get the pointers between - // ACIS and the TB right. - acis_bridge->ENTITY_ptr(ENTITIES[i]); - num_deactivated++; - } - else // bridge was already reactivated - { - // if we're reactivating an entity and it has already been reactivated, - // that means another acis entity is using it - make this acis entity - // get a new one - ATTRIB_CUBIT_OWNER::remove_cubit_owner(ENTITIES[i]); - } - } + int num_deactivated = 0; - // if flag is true and acis_bridge is NOT deactivated, - // deactivate it. - else if (deactivate_bridge(acis_bridge)) - { - num_deactivated++; - } - } - } + for (int i = 0; i < ENTITIES.count(); i++) + { + AcisBridge *acis_bridge = ATTRIB_CUBIT_OWNER::cubit_owner(ENTITIES[i]); + if (acis_bridge != NULL) + { + if (flag == false) + { + // if bridge was deactivated, re-activate it and... + if (reactivate_bridge(acis_bridge)) + { + // ...and get the pointers between + // ACIS and the TB right. + acis_bridge->ENTITY_ptr(ENTITIES[i]); + num_deactivated++; + } + else // bridge was already reactivated + { + // if we're reactivating an entity and it has already been reactivated, + // that means another acis entity is using it - make this acis entity + // get a new one + ATTRIB_CUBIT_OWNER::remove_cubit_owner(ENTITIES[i]); + } + } - return num_deactivated; -} + // if flag is true and acis_bridge is NOT deactivated, + // deactivate it. + else if (deactivate_bridge(acis_bridge)) + { + num_deactivated++; + } + } + } -void AcisModifyEngine::print_deleted_reused(DLIList<BODY*> &old_BODY_list, + return num_deactivated; + } + + void AcisModifyEngine::print_deleted_reused(DLIList<BODY*> &old_BODY_list, DLIList<BODY*> &new_BODY_list) const -{ + { - // print out what's saved and what's not - DLIList<TopologyBridge*> deact_list, react_list; - int i; - for (i = old_BODY_list.size(); i > 0; i--) - AcisQueryEngine::instance()->get_all_cubit_owners(old_BODY_list.get_and_step(), deact_list); - for (i = new_BODY_list.size(); i > 0; i--) - AcisQueryEngine::instance()->get_all_cubit_owners(new_BODY_list.get_and_step(), react_list); - for (i = react_list.size(); i > 0; i--) - deact_list.remove(react_list.get_and_step()); - PRINT_DEBUG_99( "Deleted entities:\n"); - for (i = deact_list.size(); i > 0; i--) { - TopologyBridge* bridge = deact_list.get_and_step(); - TopologyEntity *entity = bridge->topology_entity(); - BasicTopologyEntity *bte = CAST_TO(entity, BasicTopologyEntity); - GroupingEntity *grpe = CAST_TO(entity, GroupingEntity); - SenseEntity *se = CAST_TO(entity, SenseEntity); - if (bte != NULL) { - PRINT_DEBUG_99( "%s %d\n", - bte->class_name(), - bte->id()); + // print out what's saved and what's not + DLIList<TopologyBridge*> deact_list, react_list; + int i; + for (i = old_BODY_list.size(); i > 0; i--) + AcisQueryEngine::instance()->get_all_cubit_owners(old_BODY_list.get_and_step(), deact_list); + for (i = new_BODY_list.size(); i > 0; i--) + AcisQueryEngine::instance()->get_all_cubit_owners(new_BODY_list.get_and_step(), react_list); + for (i = react_list.size(); i > 0; i--) + deact_list.remove(react_list.get_and_step()); + PRINT_DEBUG_99( "Deleted entities:\n"); + for (i = deact_list.size(); i > 0; i--) { + TopologyBridge* bridge = deact_list.get_and_step(); + TopologyEntity *entity = bridge->topology_entity(); + BasicTopologyEntity *bte = CAST_TO(entity, BasicTopologyEntity); + GroupingEntity *grpe = CAST_TO(entity, GroupingEntity); + SenseEntity *se = CAST_TO(entity, SenseEntity); + if (bte != NULL) { + PRINT_DEBUG_99( "%s %d\n", + bte->class_name(), + bte->id()); + } + else if (se != NULL) { + PRINT_DEBUG_99( "%s (lower BTE: %d)\n", + entity->class_name(), + (se->get_basic_topology_entity_ptr() ? + se->get_basic_topology_entity_ptr()->id() : 0)); + } + else if (grpe != NULL) { + PRINT_DEBUG_99( "%s (upper BTE: %d)\n", + entity->class_name(), + (grpe->get_basic_topology_entity_ptr() ? + grpe->get_basic_topology_entity_ptr()->id() : 0)); + } + } + PRINT_DEBUG_99( "ReUsed entities:\n"); + for (i = react_list.size(); i > 0; i--) { + TopologyBridge* bridge = react_list.get_and_step(); + TopologyEntity *entity = bridge->topology_entity(); + BasicTopologyEntity *bte = CAST_TO(entity, BasicTopologyEntity); + GroupingEntity *grpe = CAST_TO(entity, GroupingEntity); + SenseEntity *se = CAST_TO(entity, SenseEntity); + if (bte != NULL) { + PRINT_DEBUG_99( "%s %d\n", + bte->class_name(), + bte->id()); + } + else if (se != NULL) { + PRINT_DEBUG_99( "%s (lower BTE: %d)\n", + entity->class_name(), + (se->get_basic_topology_entity_ptr() ? + se->get_basic_topology_entity_ptr()->id() : 0)); + } + else if (grpe != NULL) { + PRINT_DEBUG_99( "%s (upper BTE: %d)\n", + entity->class_name(), + (grpe->get_basic_topology_entity_ptr() ? + grpe->get_basic_topology_entity_ptr()->id() : 0)); + } + } } - else if (se != NULL) { - PRINT_DEBUG_99( "%s (lower BTE: %d)\n", - entity->class_name(), - (se->get_basic_topology_entity_ptr() ? - se->get_basic_topology_entity_ptr()->id() : 0)); - } - else if (grpe != NULL) { - PRINT_DEBUG_99( "%s (upper BTE: %d)\n", - entity->class_name(), - (grpe->get_basic_topology_entity_ptr() ? - grpe->get_basic_topology_entity_ptr()->id() : 0)); - } - } - PRINT_DEBUG_99( "ReUsed entities:\n"); - for (i = react_list.size(); i > 0; i--) { - TopologyBridge* bridge = react_list.get_and_step(); - TopologyEntity *entity = bridge->topology_entity(); - BasicTopologyEntity *bte = CAST_TO(entity, BasicTopologyEntity); - GroupingEntity *grpe = CAST_TO(entity, GroupingEntity); - SenseEntity *se = CAST_TO(entity, SenseEntity); - if (bte != NULL) { - PRINT_DEBUG_99( "%s %d\n", - bte->class_name(), - bte->id()); - } - else if (se != NULL) { - PRINT_DEBUG_99( "%s (lower BTE: %d)\n", - entity->class_name(), - (se->get_basic_topology_entity_ptr() ? - se->get_basic_topology_entity_ptr()->id() : 0)); - } - else if (grpe != NULL) { - PRINT_DEBUG_99( "%s (upper BTE: %d)\n", - entity->class_name(), - (grpe->get_basic_topology_entity_ptr() ? - grpe->get_basic_topology_entity_ptr()->id() : 0)); - } - } -} -//------------------------------------------------------------------------- -// Purpose : Imprint multiple bodies at once -// -// Special Notes : -// -// Creator : Tim Tautges -// -// Creation Date : 12/8/98 -//------------------------------------------------------------------------- -CubitStatus AcisModifyEngine::imprint(DLIList<BodySM*> &from_body_list, - DLIList<BodySM*> &new_from_body_list, - bool keep_old, - DLIList<TopologyBridge*> *new_tbs, - DLIList<TopologyBridge*> *att_tbs) const -{ + //------------------------------------------------------------------------- + // Purpose : Imprint multiple bodies at once + // + // Special Notes : + // + // Creator : Tim Tautges + // + // Creation Date : 12/8/98 + //------------------------------------------------------------------------- + CubitStatus AcisModifyEngine::imprint(DLIList<BodySM*> &from_body_list, + DLIList<BodySM*> &new_from_body_list, + bool keep_old, + DLIList<TopologyBridge*> *new_tbs, + DLIList<TopologyBridge*> *att_tbs) const + { - DLIList<BODY*> from_BODY_list; - DLIList<BODY*> from_BODY_list_copy; - CubitStatus success = CUBIT_SUCCESS; + DLIList<BODY*> from_BODY_list; + DLIList<BODY*> from_BODY_list_copy; + CubitStatus success = CUBIT_SUCCESS; - // get acis bodies, and copy them - from_body_list.reset(); - int i, j; + // get acis bodies, and copy them + from_body_list.reset(); + int i, j; - // pass in keep_old to the delete_owner_attrib flag; if we're not keeping - // old bodies, we want to keep the owner attrib, so we can pick up entities - // that didn't change - bool delete_attribs = - (GeometryModifyTool::instance()->get_new_ids() || keep_old); + // pass in keep_old to the delete_owner_attrib flag; if we're not keeping + // old bodies, we want to keep the owner attrib, so we can pick up entities + // that didn't change + bool delete_attribs = + (GeometryModifyTool::instance()->get_new_ids() || keep_old); - const int num_bodies = from_body_list.size(); - from_body_list.reset(); - for (i = 0; i < num_bodies; i++) { - BODY *BODYPtr1 = AcisQueryEngine::get_BODY(from_body_list.next(i)); - from_BODY_list.append(BODYPtr1); - //BODY *BODYPtr1Save = this->copy_BODY(BODYPtr1, delete_attribs); - //from_BODY_list_copy.append(BODYPtr1Save); - from_BODY_list_copy.append(NULL); - } + const int num_bodies = from_body_list.size(); + from_body_list.reset(); + for (i = 0; i < num_bodies; i++) { + BODY *BODYPtr1 = AcisQueryEngine::get_BODY(from_body_list.next(i)); + from_BODY_list.append(BODYPtr1); + //BODY *BODYPtr1Save = this->copy_BODY(BODYPtr1, delete_attribs); + //from_BODY_list_copy.append(BODYPtr1Save); + from_BODY_list_copy.append(NULL); + } - if (from_BODY_list.is_in_list(NULL)) - return CUBIT_FAILURE; + if (from_BODY_list.is_in_list(NULL)) + return CUBIT_FAILURE; - // set the free_edges acis option - if ( GeometryModifyTool::get_all_edges_imprint() ) - { - api_set_int_option("all_free_edges", TRUE ); - } + // set the free_edges acis option + if ( GeometryModifyTool::get_all_edges_imprint() ) + { + api_set_int_option("all_free_edges", TRUE ); + } // total number of imprints to be done - int total_imprints = (from_body_list.size() * - (from_body_list.size()-1))/2; + int total_imprints = (from_body_list.size() * + (from_body_list.size()-1))/2; - if( num_bodies > 2 ) - { - char message[128]; - sprintf(message, "Imprinting %d ACIS Bodies", from_BODY_list.size() ); - AppUtil::instance()->progress_tool()->start(0, total_imprints, message); - } + if( num_bodies > 2 ) + { + char message[128]; + sprintf(message, "Imprinting %d ACIS Bodies", from_BODY_list.size() ); + AppUtil::instance()->progress_tool()->start(0, total_imprints, message); + } - // imprint each body with each one later in the list - from_BODY_list.reset(); - from_BODY_list_copy.reset(); - for (i = 0; success && i < num_bodies - 1; i++) { - //BODY *BODY_Ptr1 = from_BODY_list_copy.next(i); - BodySM *Body_Ptr1 = from_body_list.next(i); - CubitBox box1 = AcisQueryEngine::instance()->bounding_box(Body_Ptr1); + // imprint each body with each one later in the list + from_BODY_list.reset(); + from_BODY_list_copy.reset(); + for (i = 0; success && i < num_bodies - 1; i++) { + //BODY *BODY_Ptr1 = from_BODY_list_copy.next(i); + BodySM *Body_Ptr1 = from_body_list.next(i); + CubitBox box1 = AcisQueryEngine::instance()->bounding_box(Body_Ptr1); - for (j = i + 1; j < num_bodies; j++) { + for (j = i + 1; j < num_bodies; j++) { - if (CubitMessage::instance()->Interrupt()) - { - success = CUBIT_FAILURE; - break; - } + if (CubitMessage::instance()->Interrupt()) + { + success = CUBIT_FAILURE; + break; + } - //BODY *BODY_Ptr2 = from_BODY_list_copy.next(j); - BodySM *Body_Ptr2 = from_body_list.next(j); - CubitBox box2 = AcisQueryEngine::instance()->bounding_box(Body_Ptr2); + //BODY *BODY_Ptr2 = from_BODY_list_copy.next(j); + BodySM *Body_Ptr2 = from_body_list.next(j); + CubitBox box2 = AcisQueryEngine::instance()->bounding_box(Body_Ptr2); - // first, check bounding SPAbox; if they don't intersect, imprint will fail + // first, check bounding SPAbox; if they don't intersect, imprint will fail - if (box1.overlap(SPAresabs, box2)) - { - if (DEBUG_FLAG(95)) - { - TopologyEntity *te1 = Body_Ptr1->topology_entity(); - TopologyEntity *te2 = Body_Ptr2->topology_entity(); - RefEntity *ref1 = CAST_TO(te1, RefEntity ); - RefEntity *ref2 = CAST_TO(te2, RefEntity ); - PRINT_INFO("Imprinting bodies %d and %d\n", ref1->id(), ref2->id() ); - } + if (box1.overlap(SPAresabs, box2)) + { + if (DEBUG_FLAG(95)) + { + TopologyEntity *te1 = Body_Ptr1->topology_entity(); + TopologyEntity *te2 = Body_Ptr2->topology_entity(); + RefEntity *ref1 = CAST_TO(te1, RefEntity ); + RefEntity *ref2 = CAST_TO(te2, RefEntity ); + PRINT_INFO("Imprinting bodies %d and %d\n", ref1->id(), ref2->id() ); + } - BODY* BODY_Ptr1 = from_BODY_list_copy.next(i); - BODY* BODY_Ptr2 = from_BODY_list_copy.next(j); - if (!BODY_Ptr1) - BODY_Ptr1 = from_BODY_list.next(i); - if (!BODY_Ptr2) - BODY_Ptr2 = from_BODY_list.next(j); + BODY* BODY_Ptr1 = from_BODY_list_copy.next(i); + BODY* BODY_Ptr2 = from_BODY_list_copy.next(j); + if (!BODY_Ptr1) + BODY_Ptr1 = from_BODY_list.next(i); + if (!BODY_Ptr2) + BODY_Ptr2 = from_BODY_list.next(j); - BODY_Ptr1 = copy_BODY(BODY_Ptr1, delete_attribs); - BODY_Ptr2 = copy_BODY(BODY_Ptr2, delete_attribs); - // the bodies overlap; proceed with the imprint - outcome result = api_imprint(BODY_Ptr1, BODY_Ptr2); + BODY_Ptr1 = copy_BODY(BODY_Ptr1, delete_attribs); + BODY_Ptr2 = copy_BODY(BODY_Ptr2, delete_attribs); + // the bodies overlap; proceed with the imprint + outcome result = api_imprint(BODY_Ptr1, BODY_Ptr2); - AcisModifyEngine::instance()->cleanup_slivers( BODY_Ptr1 ); - AcisModifyEngine::instance()->cleanup_slivers( BODY_Ptr2 ); + AcisModifyEngine::instance()->cleanup_slivers( BODY_Ptr1 ); + AcisModifyEngine::instance()->cleanup_slivers( BODY_Ptr2 ); - if (result.ok()) - { - from_BODY_list_copy.step(i); - if (from_BODY_list_copy.get()) - api_delent(from_BODY_list_copy.get()); - from_BODY_list_copy.change_to(BODY_Ptr1); - from_BODY_list_copy.reset(); + if (result.ok()) + { + from_BODY_list_copy.step(i); + if (from_BODY_list_copy.get()) + api_delent(from_BODY_list_copy.get()); + from_BODY_list_copy.change_to(BODY_Ptr1); + from_BODY_list_copy.reset(); - from_BODY_list_copy.step(j); - if (from_BODY_list_copy.get()) - api_delent(from_BODY_list_copy.get()); - from_BODY_list_copy.change_to(BODY_Ptr2); - from_BODY_list_copy.reset(); - } - else - { - if (DEBUG_FLAG(95)) { - AcisQueryEngine::instance()->ACIS_API_error(result, "imprint Bodies"); - } + from_BODY_list_copy.step(j); + if (from_BODY_list_copy.get()) + api_delent(from_BODY_list_copy.get()); + from_BODY_list_copy.change_to(BODY_Ptr2); + from_BODY_list_copy.reset(); + } + else + { + if (DEBUG_FLAG(95)) { + AcisQueryEngine::instance()->ACIS_API_error(result, "imprint Bodies"); + } - if (BODY_Ptr1) - api_delent(BODY_Ptr1); - if (BODY_Ptr2) - api_delent(BODY_Ptr2); - } - } // if overlap + if (BODY_Ptr1) + api_delent(BODY_Ptr1); + if (BODY_Ptr2) + api_delent(BODY_Ptr2); + } + } // if overlap + if( num_bodies > 2 ) + AppUtil::instance()->progress_tool()->step(); + } + } + if( num_bodies > 2 ) - AppUtil::instance()->progress_tool()->step(); - } - } + AppUtil::instance()->progress_tool()->end(); - if( num_bodies > 2 ) - AppUtil::instance()->progress_tool()->end(); + if( CubitMessage::instance()->Interrupt() ) + PRINT_INFO("Imprint aborted.\n"); - if( CubitMessage::instance()->Interrupt() ) - PRINT_INFO("Imprint aborted.\n"); + // new_ENTITIES will hold new entities that were created by + // the imprint operation. att_ENTITIES will hold entities + // from the original bodies that had composite attributes + // on them. At the end we will compare the new entities + // with the ones that had attributes and if we find matches + // we will put a composite attribute on the new entity. + // This is how we are handling the imprinting of bodies + // with composites. + DLIList<ENTITY*> new_ENTITIES; + DLIList<ENTITY*> att_ENTITIES; - // new_ENTITIES will hold new entities that were created by - // the imprint operation. att_ENTITIES will hold entities - // from the original bodies that had composite attributes - // on them. At the end we will compare the new entities - // with the ones that had attributes and if we find matches - // we will put a composite attribute on the new entity. - // This is how we are handling the imprinting of bodies - // with composites. - DLIList<ENTITY*> new_ENTITIES; - DLIList<ENTITY*> att_ENTITIES; + // Create/update ACIS Bridges. + for ( i = 0; i < num_bodies; i++ ) + { + BodySM* from_body = from_body_list.next(i); + BODY* from_BODY = from_BODY_list.next(i); + BODY* new_BODY = from_BODY_list_copy.next(i); + if (new_BODY) + { + // Get the new entities (just edges for now) + // created by the imprint operation. + DLIList<ENTITY*> cur_new_ENTITIES; + if(new_tbs) + get_new_ENTITIES(new_BODY, cur_new_ENTITIES); - // Create/update ACIS Bridges. - for ( i = 0; i < num_bodies; i++ ) - { - BodySM* from_body = from_body_list.next(i); - BODY* from_BODY = from_BODY_list.next(i); - BODY* new_BODY = from_BODY_list_copy.next(i); - if (new_BODY) - { - // Get the new entities (just edges for now) - // created by the imprint operation. - DLIList<ENTITY*> cur_new_ENTITIES; - if(new_tbs) - get_new_ENTITIES(new_BODY, cur_new_ENTITIES); + DLIList<EDGE*> new_edges = AcisModifyEngine::instance()->find_new_EDGES(new_BODY); - DLIList<EDGE*> new_edges = AcisModifyEngine::instance()->find_new_EDGES(new_BODY); + BodySM* new_body = get_new_Body( from_body, from_BODY, new_BODY, keep_old, true ); + if (new_body) + { + // Add the new entities to the list we are + // accumulating. + if(new_tbs) + new_ENTITIES += cur_new_ENTITIES; - BodySM* new_body = get_new_Body( from_body, from_BODY, new_BODY, keep_old, true ); - if (new_body) - { - // Add the new entities to the list we are - // accumulating. - if(new_tbs) - new_ENTITIES += cur_new_ENTITIES; + // Get entities with composite attributes. + if(att_tbs) + get_att_ENTITIES(new_BODY, att_ENTITIES, "COMPOSITE_GEOM"); - // Get entities with composite attributes. - if(att_tbs) - get_att_ENTITIES(new_BODY, att_ENTITIES, "COMPOSITE_GEOM"); + // Add a imprint feature to the topo edges + for (int edge_count = new_edges.size(); edge_count--; ) + { + CubitSimpleAttrib *tmp_attrib = new CubitSimpleAttrib( "SOURCE_FEATURE", "IMPRINT" ); + new ATTRIB_SNL_SIMPLE( new_edges[edge_count], tmp_attrib ); + delete tmp_attrib; + } + new_from_body_list.append(new_body); + } + else + { + // Get entities with composite attributes. + if(att_tbs) + get_att_ENTITIES(from_BODY, att_ENTITIES, "COMPOSITE_GEOM"); + } + } + } - // Add a imprint feature to the topo edges - for (int edge_count = new_edges.size(); edge_count--; ) - { - CubitSimpleAttrib *tmp_attrib = new CubitSimpleAttrib( "SOURCE_FEATURE", "IMPRINT" ); - new ATTRIB_SNL_SIMPLE( new_edges[edge_count], tmp_attrib ); - delete tmp_attrib; - } - new_from_body_list.append(new_body); - } - else - { - // Get entities with composite attributes. - if(att_tbs) - get_att_ENTITIES(from_BODY, att_ENTITIES, "COMPOSITE_GEOM"); - } - } - } + // Convert the new_ENTITIES/att_ENTITIES lists into + // topology bridge lists. + if(new_tbs) + { + for(i=new_ENTITIES.size(); i--;) + { + ENTITY *cur_ENT = new_ENTITIES.get_and_step(); + AcisBridge *acis_bridge = ATTRIB_CUBIT_OWNER::cubit_owner(cur_ENT); + if(dynamic_cast<TopologyBridge*>(acis_bridge)) + new_tbs->append_unique(dynamic_cast<TopologyBridge*>(acis_bridge)); + } + } + if(att_tbs) + { + for(i=att_ENTITIES.size(); i--;) + { + ENTITY *cur_ENT = att_ENTITIES.get_and_step(); + AcisBridge *acis_bridge = ATTRIB_CUBIT_OWNER::cubit_owner(cur_ENT); + if(dynamic_cast<TopologyBridge*>(acis_bridge)) + att_tbs->append_unique(dynamic_cast<TopologyBridge*>(acis_bridge)); + } + } - // Convert the new_ENTITIES/att_ENTITIES lists into - // topology bridge lists. - if(new_tbs) - { - for(i=new_ENTITIES.size(); i--;) - { - ENTITY *cur_ENT = new_ENTITIES.get_and_step(); - AcisBridge *acis_bridge = ATTRIB_CUBIT_OWNER::cubit_owner(cur_ENT); - if(dynamic_cast<TopologyBridge*>(acis_bridge)) - new_tbs->append_unique(dynamic_cast<TopologyBridge*>(acis_bridge)); - } - } - if(att_tbs) - { - for(i=att_ENTITIES.size(); i--;) - { - ENTITY *cur_ENT = att_ENTITIES.get_and_step(); - AcisBridge *acis_bridge = ATTRIB_CUBIT_OWNER::cubit_owner(cur_ENT); - if(dynamic_cast<TopologyBridge*>(acis_bridge)) - att_tbs->append_unique(dynamic_cast<TopologyBridge*>(acis_bridge)); - } - } + PRINT_INFO("Group imprint finished.\n"); - PRINT_INFO("Group imprint finished.\n"); + // reset the free_edges acis option + api_set_int_option("all_free_edges", FALSE ); - // reset the free_edges acis option - api_set_int_option("all_free_edges", FALSE ); + return success; + } - return success; -} + //------------------------------------------------------------------------- + // Purpose : Projects an EDGE to a FACE + // + // Special Notes : + // + // + // Creator : Eric Nielsen + // + // Creation Date : 06/14/00 + //------------------------------------------------------------------------- + EDGE* AcisModifyEngine::project_EDGE(EDGE* EDGE_in_ptr, FACE* FACE_ptr, bool print_error ) const + { + curve* in_crv=NULL; + surface *in_srf=NULL; + curve * out_crv = NULL; + EDGE * new_EDGE = NULL; -//------------------------------------------------------------------------- -// Purpose : Projects an EDGE to a FACE -// -// Special Notes : -// -// -// Creator : Eric Nielsen -// -// Creation Date : 06/14/00 -//------------------------------------------------------------------------- -EDGE* AcisModifyEngine::project_EDGE(EDGE* EDGE_in_ptr, FACE* FACE_ptr, bool print_error ) const -{ - curve* in_crv=NULL; - surface *in_srf=NULL; - curve * out_crv = NULL; - EDGE * new_EDGE = NULL; + if(FACE_ptr && FACE_ptr->geometry()) + { + SPAtransf t= get_owner_transf(FACE_ptr); + in_srf = FACE_ptr->geometry()->trans_surface(t); + } - if(FACE_ptr && FACE_ptr->geometry()) - { - SPAtransf t= get_owner_transf(FACE_ptr); - in_srf = FACE_ptr->geometry()->trans_surface(t); - } + if(EDGE_in_ptr && EDGE_in_ptr->geometry()) + { + SPAtransf t= get_owner_transf(EDGE_in_ptr); + in_crv = EDGE_in_ptr->geometry()->trans_curve(t); + } - if(EDGE_in_ptr && EDGE_in_ptr->geometry()) - { - SPAtransf t= get_owner_transf(EDGE_in_ptr); - in_crv = EDGE_in_ptr->geometry()->trans_curve(t); - } + if(in_crv && in_srf) + { + // create the curve + SPAinterval in_range = EDGE_in_ptr->param_range(); - if(in_crv && in_srf) - { - // create the curve - SPAinterval in_range = EDGE_in_ptr->param_range(); + if( EDGE_in_ptr->sense() ) + in_range.negate(); - if( EDGE_in_ptr->sense() ) - in_range.negate(); + outcome result = api_project_curve_to_surface(*in_crv, in_range, *in_srf, out_crv); - outcome result = api_project_curve_to_surface(*in_crv, in_range, *in_srf, out_crv); + if (!result.ok() || out_crv == NULL) //out_crv check added 6/18/04 by aga@cat + //api CAN return a null curve in some failures- if so we'll end the fcn here and return + { + if( print_error ) + { + AcisQueryEngine::instance()->ACIS_API_error (result); + PRINT_ERROR( "api_project_curve_to_surface failed "); + } + return (EDGE *)NULL; + } - if (!result.ok() || out_crv == NULL) //out_crv check added 6/18/04 by aga@cat - //api CAN return a null curve in some failures- if so we'll end the fcn here and return - { - if( print_error ) - { - AcisQueryEngine::instance()->ACIS_API_error (result); - PRINT_ERROR( "api_project_curve_to_surface failed "); - } - return (EDGE *)NULL; - } + // create the CURVE + CURVE *the_curve=make_curve(*out_crv); - // create the CURVE - CURVE *the_curve=make_curve(*out_crv); + // get ends of the edge + SPAposition pt0=out_crv->eval_position(in_range.start_pt()); + SPAposition pt1=out_crv->eval_position(in_range.end_pt()); - // get ends of the edge - SPAposition pt0=out_crv->eval_position(in_range.start_pt()); - SPAposition pt1=out_crv->eval_position(in_range.end_pt()); + ACIS_DELETE out_crv; - ACIS_DELETE out_crv; + // create the vertices + VERTEX *svert= ACIS_NEW VERTEX( ACIS_NEW APOINT(pt0)); - // create the vertices - VERTEX *svert= ACIS_NEW VERTEX( ACIS_NEW APOINT(pt0)); + // -- check for a closed edge + VERTEX *evert= NULL; + if ( pt0 != pt1 ) + evert = ACIS_NEW VERTEX( ACIS_NEW APOINT(pt1)); + else + evert = svert; - // -- check for a closed edge - VERTEX *evert= NULL; - if ( pt0 != pt1 ) - evert = ACIS_NEW VERTEX( ACIS_NEW APOINT(pt1)); - else - evert = svert; + // make the edge + new_EDGE= ACIS_NEW EDGE(svert,evert,the_curve,FORWARD,EDGE_cvty_unknown,in_range); + } - // make the edge - new_EDGE= ACIS_NEW EDGE(svert,evert,the_curve,FORWARD,EDGE_cvty_unknown,in_range); - } + if(in_crv) + ACIS_DELETE in_crv; + if(in_srf) + ACIS_DELETE in_srf; - if(in_crv) - ACIS_DELETE in_crv; - if(in_srf) - ACIS_DELETE in_srf; + if(new_EDGE) + { + ENTITY *edge_entity = (ENTITY*)new_EDGE; + api_simplify_entity( edge_entity ); + return new_EDGE; + } + else + return (EDGE *)NULL; + } - if(new_EDGE) - { - ENTITY *edge_entity = (ENTITY*)new_EDGE; - api_simplify_entity( edge_entity ); - return new_EDGE; - } - else - return (EDGE *)NULL; -} + //------------------------------------------------------------------------- + // Purpose : Projects a list of RefEdges on to a list of RefFaces + // returning a list of new RefEdges + // + // Special Notes : + // + // + // Creator : Eric Nielsen + // + // Creation Date : 06/14/00 + //------------------------------------------------------------------------- + CubitStatus AcisModifyEngine::project_edges( DLIList<Surface*> &ref_face_list, + DLIList<Curve*> &ref_edge_list_in, + DLIList<Curve*> &ref_edge_list_new, + bool print_error ) const + { + Curve* ref_edge = NULL; + Surface* ref_face = NULL; + EDGE *new_EDGE_ptr = NULL; -//------------------------------------------------------------------------- -// Purpose : Projects a list of RefEdges on to a list of RefFaces -// returning a list of new RefEdges -// -// Special Notes : -// -// -// Creator : Eric Nielsen -// -// Creation Date : 06/14/00 -//------------------------------------------------------------------------- -CubitStatus AcisModifyEngine::project_edges( DLIList<Surface*> &ref_face_list, - DLIList<Curve*> &ref_edge_list_in, - DLIList<Curve*> &ref_edge_list_new, - bool print_error ) const -{ - Curve* ref_edge = NULL; - Surface* ref_face = NULL; - EDGE *new_EDGE_ptr = NULL; + for(int j=0; j< ref_face_list.size(); j++) + { + ref_face = ref_face_list.get_and_step(); - for(int j=0; j< ref_face_list.size(); j++) - { - ref_face = ref_face_list.get_and_step(); + FACE *FACE_ptr = AcisQueryEngine::get_FACE( ref_face ); - FACE *FACE_ptr = AcisQueryEngine::get_FACE( ref_face ); + for(int i=0; i< ref_edge_list_in.size(); i++) + { + ref_edge = ref_edge_list_in.get_and_step(); - for(int i=0; i< ref_edge_list_in.size(); i++) - { - ref_edge = ref_edge_list_in.get_and_step(); + EDGE *EDGE_ptr = AcisQueryEngine::get_EDGE(ref_edge); - EDGE *EDGE_ptr = AcisQueryEngine::get_EDGE(ref_edge); + new_EDGE_ptr = project_EDGE(EDGE_ptr,FACE_ptr, print_error ); - new_EDGE_ptr = project_EDGE(EDGE_ptr,FACE_ptr, print_error ); + if (!new_EDGE_ptr) + { + if( print_error ) + PRINT_ERROR( "Unable to project curve on surface\n" ); + continue; + } + else{ + Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges(new_EDGE_ptr); + ref_edge_list_new.append(curve_ptr); + } - if (!new_EDGE_ptr) - { - if( print_error ) - PRINT_ERROR( "Unable to project curve on surface\n" ); - continue; - } - else{ - Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges(new_EDGE_ptr); - ref_edge_list_new.append(curve_ptr); - } + } + } + if (ref_edge_list_new.size() == ref_edge_list_in.size()) + return CUBIT_SUCCESS; + else + return CUBIT_FAILURE; } - } - if (ref_edge_list_new.size() == ref_edge_list_in.size()) - return CUBIT_SUCCESS; - else - return CUBIT_FAILURE; -} + //------------------------------------------------------------------------- + // Purpose : Projects a list of RefEdges on to a list of RefFaces + // and imprint the faces with the new RefEdges + // + // Special Notes : + // + // + // Creator : Eric Nielsen + // + // Creation Date : 06/14/00 + //------------------------------------------------------------------------- + CubitStatus AcisModifyEngine::imprint_projected_edges(DLIList<Surface*> &ref_face_list, + DLIList<Curve*> &ref_edge_list_in, + DLIList<BodySM*>& new_body_list, + bool keep_old_body, + bool keep_free_edges) const + { + CubitStatus status; -//------------------------------------------------------------------------- -// Purpose : Projects a list of RefEdges on to a list of RefFaces -// and imprint the faces with the new RefEdges -// -// Special Notes : -// -// -// Creator : Eric Nielsen -// -// Creation Date : 06/14/00 -//------------------------------------------------------------------------- -CubitStatus AcisModifyEngine::imprint_projected_edges(DLIList<Surface*> &ref_face_list, - DLIList<Curve*> &ref_edge_list_in, - DLIList<BodySM*>& new_body_list, - bool keep_old_body, - bool keep_free_edges) const -{ - CubitStatus status; + DLIList<Curve*> ref_edge_list_new; - DLIList<Curve*> ref_edge_list_new; + project_edges(ref_face_list, ref_edge_list_in, ref_edge_list_new); - project_edges(ref_face_list, ref_edge_list_in, ref_edge_list_new); + // imprint Surface with curves + status = imprint(ref_face_list, ref_edge_list_new, new_body_list, keep_old_body ); - // imprint Surface with curves - status = imprint(ref_face_list, ref_edge_list_new, new_body_list, keep_old_body ); + if (keep_free_edges) + return status; - if (keep_free_edges) - return status; + PRINT_INFO( "Removing projected curves \n"); + for(int i=0; i< ref_edge_list_new.size();i++){ + // Now delete this RefEdge and its underlying solid model entities - PRINT_INFO( "Removing projected curves \n"); - for(int i=0; i< ref_edge_list_new.size();i++){ - // Now delete this RefEdge and its underlying solid model entities + Curve* ref_edge = ref_edge_list_new.get_and_step(); + status = AcisQueryEngine::instance()-> + delete_solid_model_entities( ref_edge ); + if (status == CUBIT_FAILURE) + { + PRINT_ERROR("In GeometryQueryTool::delete_geometry\n" + " Could not delete RefEdge.\n" + " The Model database is likely corrupted " + "due to\n this unsuccessful deletion.\n" ); + } + } + return status; + } - Curve* ref_edge = ref_edge_list_new.get_and_step(); - status = AcisQueryEngine::instance()-> - delete_solid_model_entities( ref_edge ); - if (status == CUBIT_FAILURE) + //------------------------------------------------------------------------- + // Purpose : Projects a list of RefEdges on to a list of RefFaces + // and imprint the bodies with the new RefEdges + // + // Special Notes : + // + // + // Creator : Eric Nielsen + // + // Creation Date : 06/14/00 + //------------------------------------------------------------------------- + CubitStatus AcisModifyEngine::imprint_projected_edges(DLIList<Surface*> &ref_face_list, + DLIList<BodySM*> &body_list, + DLIList<Curve*> &ref_edge_list_in, + DLIList<BodySM*>& new_body_list, + bool keep_old_body, + bool keep_free_edges) const { - PRINT_ERROR("In GeometryQueryTool::delete_geometry\n" - " Could not delete RefEdge.\n" - " The Model database is likely corrupted " - "due to\n this unsuccessful deletion.\n" ); - } - } - return status; -} + CubitStatus status; -//------------------------------------------------------------------------- -// Purpose : Projects a list of RefEdges on to a list of RefFaces -// and imprint the bodies with the new RefEdges -// -// Special Notes : -// -// -// Creator : Eric Nielsen -// -// Creation Date : 06/14/00 -//------------------------------------------------------------------------- -CubitStatus AcisModifyEngine::imprint_projected_edges(DLIList<Surface*> &ref_face_list, - DLIList<BodySM*> &body_list, - DLIList<Curve*> &ref_edge_list_in, - DLIList<BodySM*>& new_body_list, - bool keep_old_body, - bool keep_free_edges) const -{ - CubitStatus status; + DLIList<Curve*> ref_edge_list_new; - DLIList<Curve*> ref_edge_list_new; + project_edges(ref_face_list, ref_edge_list_in, ref_edge_list_new); - project_edges(ref_face_list, ref_edge_list_in, ref_edge_list_new); + // imprint bodies with curves + status = imprint(body_list,ref_edge_list_new,new_body_list, keep_old_body ); - // imprint bodies with curves - status = imprint(body_list,ref_edge_list_new,new_body_list, keep_old_body ); + if (keep_free_edges) + return status; - if (keep_free_edges) - return status; + PRINT_INFO( "Removing projected curves \n"); + for(int i=0; i< ref_edge_list_new.size();i++){ + // Now delete this RefEdge and its underlying solid model entities - PRINT_INFO( "Removing projected curves \n"); - for(int i=0; i< ref_edge_list_new.size();i++){ - // Now delete this RefEdge and its underlying solid model entities - - Curve* ref_edge = ref_edge_list_new.get_and_step(); - status = AcisQueryEngine::instance()-> - delete_solid_model_entities( ref_edge ); - if (status == CUBIT_FAILURE) - { - PRINT_ERROR("In GeometryModifyTool::delete_geometry\n" - " Could not delete RefEdge.\n" - " The Model database is likely corrupted " - "due to\n this unsuccessful deletion.\n" ); + Curve* ref_edge = ref_edge_list_new.get_and_step(); + status = AcisQueryEngine::instance()-> + delete_solid_model_entities( ref_edge ); + if (status == CUBIT_FAILURE) + { + PRINT_ERROR("In GeometryModifyTool::delete_geometry\n" + " Could not delete RefEdge.\n" + " The Model database is likely corrupted " + "due to\n this unsuccessful deletion.\n" ); + } + } + return status; } - } - return status; -} -//------------------------------------------------------------------------- -// Purpose : Boolean Operation of body with list of bodies. -// -// Special Notes : INTERSECTION -// -// Creator : David White -// -// Creation Date : 11/24/97 -//------------------------------------------------------------------------ -CubitStatus AcisModifyEngine::intersect( BodySM* tool_body, + //------------------------------------------------------------------------- + // Purpose : Boolean Operation of body with list of bodies. + // + // Special Notes : INTERSECTION + // + // Creator : David White + // + // Creation Date : 11/24/97 + //------------------------------------------------------------------------ + CubitStatus AcisModifyEngine::intersect( BodySM* tool_body, DLIList<BodySM*> &from_bodies, DLIList<BodySM*> &new_from_bodies, bool keep_old) const -{ - // pass in keep_old to the delete_owner_attrib flag; if we're not keeping - // old bodies, we want to keep the owner attrib, so we can pick up entities - // that didn't change - bool delete_attribs = - (GeometryModifyTool::instance()->get_new_ids() || keep_old); + { + // pass in keep_old to the delete_owner_attrib flag; if we're not keeping + // old bodies, we want to keep the owner attrib, so we can pick up entities + // that didn't change + bool delete_attribs = + (GeometryModifyTool::instance()->get_new_ids() || keep_old); - int ii; - CubitBox tool_box = AcisQueryEngine::instance()->bounding_box(tool_body); + int ii; + CubitBox tool_box = AcisQueryEngine::instance()->bounding_box(tool_body); - DLIList<BODY*> from_BODY_list; - DLIList<BODY*> from_BODY_list_copy; + DLIList<BODY*> from_BODY_list; + DLIList<BODY*> from_BODY_list_copy; - // get acis bodies, and copy them - from_bodies.reset(); + // get acis bodies, and copy them + from_bodies.reset(); - for (ii = from_bodies.size(); ii > 0; ii--) { - BODY *BODYPtr1 = AcisQueryEngine::get_BODY(from_bodies.get_and_step()); - from_BODY_list.append(BODYPtr1); - BODYPtr1 = this->copy_BODY(BODYPtr1, delete_attribs); - from_BODY_list_copy.append(BODYPtr1); - } + for (ii = from_bodies.size(); ii > 0; ii--) { + BODY *BODYPtr1 = AcisQueryEngine::get_BODY(from_bodies.get_and_step()); + from_BODY_list.append(BODYPtr1); + BODYPtr1 = this->copy_BODY(BODYPtr1, delete_attribs); + from_BODY_list_copy.append(BODYPtr1); + } - if (from_BODY_list.size() != from_bodies.size()) - return CUBIT_FAILURE; + if (from_BODY_list.size() != from_bodies.size()) + return CUBIT_FAILURE; - // check if the boolean operation is regularized or nonregularized - BOOL_TYPE bool_type = INTERSECTION; - CubitBoolean boolean_regularize = GeometryModifyTool::instance()->boolean_regularize(); + // check if the boolean operation is regularized or nonregularized + BOOL_TYPE bool_type = INTERSECTION; + CubitBoolean boolean_regularize = GeometryModifyTool::instance()->boolean_regularize(); - if (boolean_regularize == FALSE) - { - bool_type = NONREG_INTERSECTION; - } + if (boolean_regularize == FALSE) + { + bool_type = NONREG_INTERSECTION; + } - // now, intersect the tool with the list of bodies - from_BODY_list.reset(); - from_BODY_list_copy.reset(); - from_bodies.reset(); + // now, intersect the tool with the list of bodies + from_BODY_list.reset(); + from_BODY_list_copy.reset(); + from_bodies.reset(); - CubitStatus int_stat = CUBIT_SUCCESS; + CubitStatus int_stat = CUBIT_SUCCESS; - // intersect the tool body with each body in the list - for (ii = 1; ii <= from_BODY_list.size(); ii++) { - BODY *from_BODY = from_BODY_list.get(); - BODY *from_BODY_copy = from_BODY_list_copy.get(); - BodySM *from_Body = from_bodies.get(); - CubitBox box1 = AcisQueryEngine::instance()->bounding_box(from_Body); + // intersect the tool body with each body in the list + for (ii = 1; ii <= from_BODY_list.size(); ii++) { + BODY *from_BODY = from_BODY_list.get(); + BODY *from_BODY_copy = from_BODY_list_copy.get(); + BodySM *from_Body = from_bodies.get(); + CubitBox box1 = AcisQueryEngine::instance()->bounding_box(from_Body); - // first, check bounding SPAbox; if they don't intersect, don't do the intersection + // first, check bounding SPAbox; if they don't intersect, don't do the intersection - if (from_Body == tool_body) { - PRINT_ERROR("Can't intersect volume with itself.\n"); - } + if (from_Body == tool_body) { + PRINT_ERROR("Can't intersect volume with itself.\n"); + } - else if (tool_box.overlap(SPAresabs, box1)) { + else if (tool_box.overlap(SPAresabs, box1)) { - // the bodies overlap; proceed with the intersect - BODY* tool_BODY = AcisQueryEngine::get_BODY(tool_body); - BODY *tool_BODY_copy = this->copy_BODY(tool_BODY); + // the bodies overlap; proceed with the intersect + BODY* tool_BODY = AcisQueryEngine::get_BODY(tool_body); + BODY *tool_BODY_copy = this->copy_BODY(tool_BODY); - // Intersect body1 with body2. - //outcome result = api_intersect( tool_BODY_copy, from_BODY_copy ); - outcome result = api_boolean(tool_BODY_copy, from_BODY_copy, bool_type ); + // Intersect body1 with body2. + //outcome result = api_intersect( tool_BODY_copy, from_BODY_copy ); + outcome result = api_boolean(tool_BODY_copy, from_BODY_copy, bool_type ); - // We may or may not get an error if the resulting BODY is - // empty - // Also check the result. - if (from_BODY_copy == NULL || - (from_BODY_copy->lump() == NULL && from_BODY_copy->wire() == NULL) || - !result.ok()) - { - if (!result.ok()) - { - PRINT_ERROR("Intersection operation failed.\n"); - AcisQueryEngine::instance()->ACIS_API_error(result, "intersect Bodies"); - int_stat = CUBIT_FAILURE; + // We may or may not get an error if the resulting BODY is + // empty + // Also check the result. + if (from_BODY_copy == NULL || + (from_BODY_copy->lump() == NULL && from_BODY_copy->wire() == NULL) || + !result.ok()) + { + if (!result.ok()) + { + PRINT_ERROR("Intersection operation failed.\n"); + AcisQueryEngine::instance()->ACIS_API_error(result, "intersect Bodies"); + int_stat = CUBIT_FAILURE; - //I might need to take this out. Not sure. CDE 10/17/2003 - if (tool_BODY_copy != NULL) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY_copy, CUBIT_TRUE); - } - } - else - PRINT_ERROR("Intersection operation failed.\n" - " Empty volume created and will be deleted.\n"); - if (from_BODY_copy != NULL) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(from_BODY_copy, CUBIT_TRUE); - } + //I might need to take this out. Not sure. CDE 10/17/2003 + if (tool_BODY_copy != NULL) + { + AcisQueryEngine::instance()->delete_ACIS_BODY(tool_BODY_copy, CUBIT_TRUE); + } + } + else + PRINT_ERROR("Intersection operation failed.\n" + " Empty volume created and will be deleted.\n"); + if (from_BODY_copy != NULL) + { + AcisQueryEngine::instance()->delete_ACIS_BODY(from_BODY_copy, CUBIT_TRUE); + } - // we had an error, so put the original body into the copy list - from_BODY_list_copy.change_to(from_BODY); - } + // we had an error, so put the original body into the copy list + from_BODY_list_copy.change_to(from_BODY); + } - if ( bool_type == NONREG_INTERSECTION) - { - outcome result1; - // ENTITY_LIST FACES; - DLIList<FACE*> FACE_list ; - FACE *this_FACE; - AcisQueryEngine::instance()->get_FACEs(from_BODY_copy,FACE_list); - // loop through all faces - for( int i = 0; i< FACE_list.size(); i++) + if ( bool_type == NONREG_INTERSECTION) + { + outcome result1; + // ENTITY_LIST FACES; + DLIList<FACE*> FACE_list ; + FACE *this_FACE; + AcisQueryEngine::instance()->get_FACEs(from_BODY_copy,FACE_list); + // loop through all faces + for( int i = 0; i< FACE_list.size(); i++) + { + this_FACE = FACE_list.get_and_step(); + assert( this_FACE != NULL ); + // Make sure this is a DOUBLE_SIDED FACE + if (this_FACE->sides() == DOUBLE_SIDED) { - this_FACE = FACE_list.get_and_step(); - assert( this_FACE != NULL ); - // Make sure this is a DOUBLE_SIDED FACE - if (this_FACE->sides() == DOUBLE_SIDED) + if (this_FACE->cont()==BOTH_INSIDE) + { + // found internal faces + // Now we have the FACE - unhook it from the BODY. Keep track of new + // BODIES that are created as this is done. + PRINT_INFO( " Unhooking and deleting each internal surface...\n" ); + BODY *new_BODY_ptr; + result1 = api_unhook_face( this_FACE, new_BODY_ptr ); + if( !result1.ok() ) { - if (this_FACE->cont()==BOTH_INSIDE) - { - // found internal faces - // Now we have the FACE - unhook it from the BODY. Keep track of new - // BODIES that are created as this is done. - PRINT_INFO( " Unhooking and deleting each internal surface...\n" ); - BODY *new_BODY_ptr; - result1 = api_unhook_face( this_FACE, new_BODY_ptr ); - if( !result1.ok() ) - { - AcisModifyEngine::instance()->get_acis_query_engine()->ACIS_API_error( result1 ); - PRINT_ERROR( " Face unhooking during rebuild of volume didn't work\n" ); - return CUBIT_FAILURE; - } - AcisQueryEngine::instance()->delete_ACIS_BODY (new_BODY_ptr); - } + AcisModifyEngine::instance()->get_acis_query_engine()->ACIS_API_error( result1 ); + PRINT_ERROR( " Face unhooking during rebuild of volume didn't work\n" ); + return CUBIT_FAILURE; } + AcisQueryEngine::instance()->delete_ACIS_BODY (new_BODY_ptr); + } } + } - // heal the leftover body -// -// PRINT_INFO(" Healing the leftover volume...\n"); -// if( AcisHealerTool::instance()->init_BODY_for_healing( master ) == CUBIT_SUCCESS ) -// { -// int percent_before, percent_after, number_splines_simplified; -// if( AcisHealerTool::instance()->heal_BODY( master, percent_before, -// percent_after, number_splines_simplified ) == CUBIT_FAILURE ) -// PRINT_ERROR( "Error healing the combined volume\n" ); -// else -// PRINT_INFO( "Successfully healed the combined volume.\n" ); -// AcisHealerTool::instance()->end_BODY_for_healing( master ); -// } + // heal the leftover body + // + // PRINT_INFO(" Healing the leftover volume...\n"); + // if( AcisHealerTool::instance()->init_BODY_for_healing( master ) == CUBIT_SUCCESS ) + // { + // int percent_before, percent_after, number_splines_simplified; + // if( AcisHealerTool::instance()->heal_BODY( master, percent_before, + // percent_after, number_splines_simplified ) == CUBIT_FAILURE ) + // PRINT_ERROR( "Error healing the combined volume\n" ); + // else + // PRINT_INFO( "Successfully healed the combined volume.\n" ); + // AcisHealerTool::instance()->end_BODY_for_healing( master ); + // } } - // done with this j iteration; write out count, if necessary -// if (from_bodies.size() > 1) { -// int frac_done = (10 * ii) / from_bodies.size(); -// if ((10 - frac_done) < fraction_remaining) { -// PRINT_INFO("%d ", fraction_remaining); -// fraction_remaining--; -// } -// } - } + // done with this j iteration; write out count, if necessary + // if (from_bodies.size() > 1) { + // int frac_done = (10 * ii) / from_bodies.size(); + // if ((10 - frac_done) < fraction_remaining) { + // PRINT_INFO("%d ", fraction_remaining); + // fraction_remaining--; + // } + // } + } - else { - AcisQueryEngine::instance()->delete_ACIS_BODY(from_BODY_copy, CUBIT_TRUE); - from_BODY_list_copy.change_to(from_BODY); - } + else { + AcisQueryEngine::instance()->delete_ACIS_BODY(from_BODY_copy, CUBIT_TRUE); + from_BODY_list_copy.change_to(from_BODY); + } - // done with iteration over ii; step the lists - from_BODY_list_copy.step(); - from_BODY_list.step(); - from_bodies.step(); - } + // done with iteration over ii; step the lists + from_BODY_list_copy.step(); + from_BODY_list.step(); + from_bodies.step(); + } -// PRINT_INFO("\n"); + // PRINT_INFO("\n"); - // ok, we're done; construct new Body's for the new BODY's - from_BODY_list_copy.reset(); - from_BODY_list.reset(); - from_bodies.reset(); + // ok, we're done; construct new Body's for the new BODY's + from_BODY_list_copy.reset(); + from_BODY_list.reset(); + from_bodies.reset(); - for (ii = from_BODY_list_copy.size(); ii > 0; ii--) { + for (ii = from_BODY_list_copy.size(); ii > 0; ii--) { - BODY *old_BODY = from_BODY_list.get(); - BODY *new_BODY = from_BODY_list_copy.get(); + BODY *old_BODY = from_BODY_list.get(); + BODY *new_BODY = from_BODY_list_copy.get(); - BodySM *new_body = NULL; - if (old_BODY != new_BODY) - new_body = get_new_Body(from_bodies.get(), old_BODY, new_BODY, keep_old); - else if (!keep_old && int_stat == CUBIT_SUCCESS) { - //GeometryQueryTool::instance()->delete_Body(from_bodies.get()); - AcisQueryEngine::instance()->delete_solid_model_entities(from_bodies.get()); - from_bodies.change_to(NULL); - } + BodySM *new_body = NULL; + if (old_BODY != new_BODY) + new_body = get_new_Body(from_bodies.get(), old_BODY, new_BODY, keep_old); + else if (!keep_old && int_stat == CUBIT_SUCCESS) { + //GeometryQueryTool::instance()->delete_Body(from_bodies.get()); + AcisQueryEngine::instance()->delete_solid_model_entities(from_bodies.get()); + from_bodies.change_to(NULL); + } - if (new_body) { - new_from_bodies.append(new_body); - from_bodies.change_to(NULL); - } + if (new_body) { + new_from_bodies.append(new_body); + from_bodies.change_to(NULL); + } - // now step all the lists - from_BODY_list.step(); - from_BODY_list_copy.step(); - from_bodies.step(); - } + // now step all the lists + from_BODY_list.step(); + from_BODY_list_copy.step(); + from_bodies.step(); + } - from_bodies.remove_all_with_value(NULL); - from_bodies.reset(); - new_from_bodies.reset(); + from_bodies.remove_all_with_value(NULL); + from_bodies.reset(); + new_from_bodies.reset(); - if (int_stat == CUBIT_SUCCESS && !keep_old ) - //GeometryQueryTool::instance()->delete_Body(tool_body); - AcisQueryEngine::instance()->delete_solid_model_entities(tool_body); -/* - // write the message about bodies kept and not kept -//NOTE TO JS: - PRINT_INFO("Intersect finished; \n" - "Old bodies retained: "); - if (from_bodies.size() > 0) { - for (ii = from_bodies.size(); ii > 0; ii--) + if (int_stat == CUBIT_SUCCESS && !keep_old ) + //GeometryQueryTool::instance()->delete_Body(tool_body); + AcisQueryEngine::instance()->delete_solid_model_entities(tool_body); + /* + // write the message about bodies kept and not kept + //NOTE TO JS: + PRINT_INFO("Intersect finished; \n" + "Old bodies retained: "); + if (from_bodies.size() > 0) { + for (ii = from_bodies.size(); ii > 0; ii--) PRINT_INFO("%d ", from_bodies.get_and_step()->id()); - } - else { - PRINT_INFO(" (none)"); - } + } + else { + PRINT_INFO(" (none)"); + } - PRINT_INFO("\n"); + PRINT_INFO("\n"); -//NOTE TO JS: - PRINT_INFO("New bodies created: "); - if (new_from_bodies.size() > 0) { - for (ii = new_from_bodies.size(); ii > 0; ii--) + //NOTE TO JS: + PRINT_INFO("New bodies created: "); + if (new_from_bodies.size() > 0) { + for (ii = new_from_bodies.size(); ii > 0; ii--) PRINT_INFO("%d ", new_from_bodies.get_and_step()->id()); - } - else { - PRINT_INFO(" (none)"); - } - PRINT_INFO("\n"); -*/ - return CUBIT_SUCCESS; -} - -//------------------------------------------------------------------------- -// Purpose : Perform a rotational sweep -// -// Special Notes : -// -// Creator : Malcolm J. Panthaki -// -// Creation Date : 10/31/96 -//------------------------------------------------------------------------- -CubitStatus AcisModifyEngine::sweep_rotational( - DLIList<GeometryEntity*>& ref_ent_list, - DLIList<BodySM*>& result_body_list, - const CubitVector& point, - const CubitVector& sweep_axis, - double angle, - int steps, - double draft_angle, - int draft_type, - bool switchside, - bool make_solid, - bool rigid) const -{ - - DLIList<FACE*> FACEs_to_be_swept_list; - DLIList<EDGE*> EDGEs_to_be_swept_list; - DLIList<Surface*> ref_faces_list; - DLIList<Curve*> ref_edges_list; - - // First get the ACIS FACEs associated with the input RefFaces - //DLIList<FACE*> temp_faces; - int i; - for (i = ref_ent_list.size(); i > 0; i--) - { - GeometryEntity *ref_ent = ref_ent_list.get_and_step(); - Surface *ref_face = CAST_TO(ref_ent, Surface); - Curve* ref_edge = CAST_TO(ref_ent, Curve); - - if(ref_face != NULL) - { - FACE* FACE_ptr = AcisQueryEngine::get_FACE(ref_face); - if (!FACE_ptr) - return CUBIT_FAILURE; - //SurfaceACIS::get_FACEs_of_RefFace( ref_face, temp_faces); - //if (temp_faces.size() > 1) { - // PRINT_ERROR("Surface %d cannot be swept as the number of ACIS FACEs associated \n" - // " with it is not 1.\n", - // ref_face->id()); - // return CUBIT_FAILURE; - //} - // - //if (temp_faces.size() > 0) - // FACEs_to_be_swept_list += temp_faces; - //temp_faces.clean_out(); - FACEs_to_be_swept_list.append(FACE_ptr); - ref_faces_list.append(ref_face); + } + else { + PRINT_INFO(" (none)"); + } + PRINT_INFO("\n"); + */ + return CUBIT_SUCCESS; } - else if (ref_edge != NULL) - { - //EDGEs_to_be_swept_list.append(CurveACIS::get_first_EDGE(ref_edge)); - EDGEs_to_be_swept_list.append(AcisQueryEngine::get_EDGE(ref_edge)); - ref_edges_list.append(ref_edge); - } - } - ref_edges_list.reset(); - ref_faces_list.reset(); - - // Next, call ACIS to do the real work for each of the FACEs in the list!! - FACEs_to_be_swept_list.reset(); - EDGEs_to_be_swept_list.reset(); - FACE* FACE_ptr = NULL; - FACE* copied_FACE_ptr = NULL; - EDGE* copied_EDGE_ptr = NULL; - Surface* refface_ptr = NULL; - BodySM* body_ptr = NULL; - BODY* BODY_ptr = NULL; - BODY* copy_of_original_BODY_ptr = NULL; - bool primary_side = true; - bool skip_loop = false; - CubitStatus sweep_status = CUBIT_FAILURE; - for (i = 0; i < FACEs_to_be_swept_list.size(); i++) - { - skip_loop = CUBIT_FALSE; - copied_FACE_ptr = NULL; - - // Get the RefFace we're going to sweep - GeometryEntity* ref_ent = ref_ent_list.get_and_step(); - refface_ptr = CAST_TO(ref_ent, Surface); - if(make_solid) + //------------------------------------------------------------------------- + // Purpose : Perform a rotational sweep + // + // Special Notes : + // + // Creator : Malcolm J. Panthaki + // + // Creation Date : 10/31/96 + //------------------------------------------------------------------------- + CubitStatus AcisModifyEngine::sweep_rotational( + DLIList<GeometryEntity*>& ref_ent_list, + DLIList<BodySM*>& result_body_list, + const CubitVector& point, + const CubitVector& sweep_axis, + double angle, + int steps, + double draft_angle, + int draft_type, + bool switchside, + bool make_solid, + bool rigid, + Surface *stop_surf, + BodySM* stop_body) const { - PRINT_WARNING("The make_solid option is ignored for surface\n"); - } - // Get the FACE we're going to sweep - FACE_ptr = FACEs_to_be_swept_list.get_and_step(); + DLIList<FACE*> FACEs_to_be_swept_list; + DLIList<EDGE*> EDGEs_to_be_swept_list; + DLIList<Surface*> ref_faces_list; + DLIList<Curve*> ref_edges_list; - // If the FACE is DOUBLE-SIDED; deal with the switchside option - if (FACE_ptr->sides() && switchside) - { - primary_side = CUBIT_FALSE; - } + // First get the ACIS FACEs associated with the input RefFaces + //DLIList<FACE*> temp_faces; + int i; + for (i = ref_ent_list.size(); i > 0; i--) + { + GeometryEntity *ref_ent = ref_ent_list.get_and_step(); + Surface *ref_face = CAST_TO(ref_ent, Surface); + Curve* ref_edge = CAST_TO(ref_ent, Curve); - // Make sure the FACE has a plane surface as it's underlying geometry - if (FACE_ptr->geometry()->equation().type() != plane_type) - { - PRINT_ERROR("One of the surfaces being swept is not planar.\n" - " Skipping to the next surface.\n"); - skip_loop = CUBIT_TRUE; - } + if(ref_face != NULL) + { + FACE* FACE_ptr = AcisQueryEngine::get_FACE(ref_face); + if (!FACE_ptr) + return CUBIT_FAILURE; + //SurfaceACIS::get_FACEs_of_RefFace( ref_face, temp_faces); + //if (temp_faces.size() > 1) { + // PRINT_ERROR("Surface %d cannot be swept as the number of ACIS FACEs associated \n" + // " with it is not 1.\n", + // ref_face->id()); + // return CUBIT_FAILURE; + //} + // + //if (temp_faces.size() > 0) + // FACEs_to_be_swept_list += temp_faces; + //temp_faces.clean_out(); + FACEs_to_be_swept_list.append(FACE_ptr); + ref_faces_list.append(ref_face); + } + else if (ref_edge != NULL) + { + //EDGEs_to_be_swept_list.append(CurveACIS::get_first_EDGE(ref_edge)); + EDGEs_to_be_swept_list.append(AcisQueryEngine::get_EDGE(ref_edge)); + ref_edges_list.append(ref_edge); + } + } - // If this FACE is planar, continue - if( !skip_loop ) - { - // Get the associated Body and it's ACIS BODY - body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY(FACE_ptr); - if (body_ptr != NULL) - { - BODY_ptr = AcisQueryEngine::get_BODY(body_ptr); + //see if surface-where-sweep-is-to-stop has been specified + FACE *stop_FACE= NULL; + BODY *stop_BODY = NULL; + if( stop_surf ) + { + SurfaceACIS *surf_ACIS = CAST_TO(stop_surf, SurfaceACIS ); + stop_FACE = surf_ACIS->get_FACE_ptr(); + } - // Make sure we have a valid ACIS BODY associated with this Body - // and FACE - if (BODY_ptr == NULL) - { - PRINT_ERROR("No valid volume associated with the RefFace.\n"); - skip_loop = CUBIT_TRUE; - } - } + if( stop_body ) + { + BodyACIS* bodyACISPtr = CAST_TO(stop_body, BodyACIS) ; + assert(bodyACISPtr); + stop_BODY = bodyACISPtr->get_BODY_ptr() ; + } - else - { - PRINT_WARNING("No volume associated with this surface.\n" - " Sweeping will continue with the ACIS BODY.\n"); - BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr); - if (BODY_ptr == NULL) - { - PRINT_ERROR("No valid volume associated with the RefFace.\n"); - skip_loop = CUBIT_TRUE; - } - } + ref_edges_list.reset(); + ref_faces_list.reset(); - // If there were no problems finding an associated ACIS BODY, proceed - if( !skip_loop ) - { - // Make a copy of the original BODY before doing the sweep. - // We will perform the sweep on the copy, not on the original body. - copy_of_original_BODY_ptr = this->copy_BODY(BODY_ptr, - CUBIT_FALSE); + // Next, call ACIS to do the real work for each of the FACEs in the list!! + FACEs_to_be_swept_list.reset(); + EDGEs_to_be_swept_list.reset(); + FACE* FACE_ptr = NULL; + FACE* copied_FACE_ptr = NULL; + EDGE* copied_EDGE_ptr = NULL; + Surface* refface_ptr = NULL; + BodySM* body_ptr = NULL; + BODY* BODY_ptr = NULL; + BODY* copy_of_original_BODY_ptr = NULL; + bool primary_side = true; + bool skip_loop = false; + CubitStatus sweep_status = CUBIT_FAILURE; + for (i = 0; i < FACEs_to_be_swept_list.size(); i++) + { + skip_loop = CUBIT_FALSE; + copied_FACE_ptr = NULL; - // Find the FACE in the copied BODY that corresponds to the FACE - // being swept in the original BODY. Note that when we made a copy - // of the original BODY, all the "parent" attributes were copied - // over to the new BODY. - if (copy_of_original_BODY_ptr) - { - copied_FACE_ptr = (FACE *) (AcisQueryEngine::instance()-> - get_ENTITY_of_entity( copy_of_original_BODY_ptr, refface_ptr) ); - } + // Get the RefFace we're going to sweep + GeometryEntity* ref_ent = ref_ent_list.get_and_step(); + refface_ptr = CAST_TO(ref_ent, Surface); + if(make_solid) + { + PRINT_WARNING("The make_solid option is ignored for surface\n"); + } - if (copied_FACE_ptr) - { - // Remove all the CUBIT_OWNER attributes from the copied BODY - // as we're going to sweep it. - if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_TRUE) - AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr); + // Get the FACE we're going to sweep + FACE_ptr = FACEs_to_be_swept_list.get_and_step(); - // Rotate the FACE about the axis, sweep_vector. - int reverse_failed = CUBIT_FALSE; - bool volume_is_negative = false; - if ( !this->sweep_FACE_about_axis( copied_FACE_ptr, - sweep_axis, - point, - angle, - volume_is_negative, - primary_side, - steps, - draft_angle, - draft_type, - rigid) ) - { - // Volume was negative, so we're going to try to reverse the - // BODY - if (volume_is_negative) - { - // Delete the BODY that was just created (the one with the - // negative volume). - //AcisQueryEngine::instance()->delete_ACIS_BODY(copy_of_original_BODY_ptr); + // If the FACE is DOUBLE-SIDED; deal with the switchside option + if (FACE_ptr->sides() && switchside) + { + primary_side = CUBIT_FALSE; + } - // Make another copy of the original BODY before attempting - // the sweep again. We will perform the sweep on this copy, - // not on the original body. - copy_of_original_BODY_ptr = this->copy_BODY(BODY_ptr, CUBIT_FALSE); + // Make sure the FACE has a plane surface as it's underlying geometry + if (FACE_ptr->geometry()->equation().type() != plane_type) + { + PRINT_ERROR("One of the surfaces being swept is not planar.\n" + " Skipping to the next surface.\n"); + skip_loop = CUBIT_TRUE; + } - // Find the FACE in the copied BODY that corresponds to the FACE - // being swept in the original BODY. Note that when we made a copy - // of the original BODY, all the "parent" attributes were copied - // over to the new BODY. - if (copy_of_original_BODY_ptr) - { - copied_FACE_ptr = (FACE *) (AcisQueryEngine::instance()-> - get_ENTITY_of_entity( copy_of_original_BODY_ptr, refface_ptr )); - } + // If this FACE is planar, continue + if( !skip_loop ) + { + // Get the associated Body and it's ACIS BODY + body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY(FACE_ptr); + if (body_ptr != NULL) + { + BODY_ptr = AcisQueryEngine::get_BODY(body_ptr); - if (copied_FACE_ptr) - { - // Remove all the CUBIT_OWNER attributes from the copied BODY - // as we're going to sweep it. - if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_TRUE) - AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr); + // Make sure we have a valid ACIS BODY associated with this Body + // and FACE + if (BODY_ptr == NULL) + { + PRINT_ERROR("No valid volume associated with the RefFace.\n"); + skip_loop = CUBIT_TRUE; + } + } - // Find out how many FACEs exist in the BODY that owns - // copied_FACE_ptr - DLIList<FACE*> FACE_list; - if (AcisQueryEngine::instance()->get_FACEs( (ENTITY *)copy_of_original_BODY_ptr, FACE_list )) - { - // If copied_FACE_ptr is the only FACE in this BODY, then we can - // try reversing the BODY before attempting the sweep again - if (FACE_list.size() == 1) - { - // Make sure this is a DOUBLE_SIDED FACE - if (copied_FACE_ptr->sides() == DOUBLE_SIDED) - { - // Reverse the BODY that this FACE belongs to - if (!api_reverse_body(copy_of_original_BODY_ptr).ok()) - { - reverse_failed = CUBIT_TRUE; - } - } + else + { + PRINT_WARNING("No volume associated with this surface.\n" + " Sweeping will continue with the ACIS BODY.\n"); + BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr); + if (BODY_ptr == NULL) + { + PRINT_ERROR("No valid volume associated with the RefFace.\n"); + skip_loop = CUBIT_TRUE; + } + } - // The single FACE in this BODY is *not* DOUBLE_SIDED. - // Cannot do the reversal and sweep. - else - { - reverse_failed = CUBIT_TRUE; - } - } + // If there were no problems finding an associated ACIS BODY, proceed + if( !skip_loop ) + { + // Make a copy of the original BODY before doing the sweep. + // We will perform the sweep on the copy, not on the original body. + copy_of_original_BODY_ptr = this->copy_BODY(BODY_ptr, + CUBIT_FALSE); - // More than 1 FACE in this BODY. Cannot do the reversal and sweep. - else - { - reverse_failed = CUBIT_TRUE; - } - } + // Find the FACE in the copied BODY that corresponds to the FACE + // being swept in the original BODY. Note that when we made a copy + // of the original BODY, all the "parent" attributes were copied + // over to the new BODY. + if (copy_of_original_BODY_ptr) + { + copied_FACE_ptr = (FACE *) (AcisQueryEngine::instance()-> + get_ENTITY_of_entity( copy_of_original_BODY_ptr, refface_ptr) ); + } - // Couldn't get the FACES of the BODY being swept. Cannot do - // the reversal and sweep. - else - { - reverse_failed = CUBIT_TRUE; - } - } + if (copied_FACE_ptr) + { + // Remove all the CUBIT_OWNER attributes from the copied BODY + // as we're going to sweep it. + if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_TRUE) + AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr); - // Couldn't find the FACE in the copied BODY that corresponds to - // the FACE being swept in the original BODY. Cannot do the - // reversal and sweep. - else - { - reverse_failed = CUBIT_TRUE; - } - } + // Rotate the FACE about the axis, sweep_vector. + int reverse_failed = CUBIT_FALSE; + bool volume_is_negative = false; + //copy stop_BODY + BODY* temp_BODY = NULL; + if (stop_BODY) + copy_BODY(stop_BODY); - // The sweep failed for reasons other than the creation of a negative - // volume. Doesn't make sense to do the reversal and sweep. - else - { - reverse_failed = CUBIT_TRUE; - } + if ( !this->sweep_FACE_about_axis( copied_FACE_ptr, + sweep_axis, + point, + angle, + volume_is_negative, + primary_side, + steps, + draft_angle, + draft_type, + rigid, + stop_FACE, + temp_BODY) ) + { + // Volume was negative, so we're going to try to reverse the + // BODY + if (volume_is_negative) + { + // Delete the BODY that was just created (the one with the + // negative volume). + //AcisQueryEngine::instance()->delete_ACIS_BODY(copy_of_original_BODY_ptr); - // If the reverse was successful, then try the sweep again - if (reverse_failed == CUBIT_FALSE) - { - if ( !this->sweep_FACE_about_axis( copied_FACE_ptr, - sweep_axis, - point, - angle, - volume_is_negative, - primary_side, - steps, - draft_angle, - draft_type, - rigid) ) - { - // The attempt to reverse the BODY and sweep it again failed. - PRINT_ERROR("Problem sweeping one of the surfaces.\n"); + // Make another copy of the original BODY before attempting + // the sweep again. We will perform the sweep on this copy, + // not on the original body. + copy_of_original_BODY_ptr = this->copy_BODY(BODY_ptr, CUBIT_FALSE); - // Delete the BODY created by this sweep - AcisQueryEngine::instance()->delete_ACIS_BODY( copy_of_original_BODY_ptr, CUBIT_TRUE); - copy_of_original_BODY_ptr = NULL; + // Find the FACE in the copied BODY that corresponds to the FACE + // being swept in the original BODY. Note that when we made a copy + // of the original BODY, all the "parent" attributes were copied + // over to the new BODY. + if (copy_of_original_BODY_ptr) + { + copied_FACE_ptr = (FACE *) (AcisQueryEngine::instance()-> + get_ENTITY_of_entity( copy_of_original_BODY_ptr, refface_ptr )); + } - skip_loop = CUBIT_TRUE; - } - } + if (copied_FACE_ptr) + { + // Remove all the CUBIT_OWNER attributes from the copied BODY + // as we're going to sweep it. + if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_TRUE) + AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr); - else - { - skip_loop = CUBIT_TRUE; - } - } // End of if branch for initial sweep attemp - } + // Find out how many FACEs exist in the BODY that owns + // copied_FACE_ptr + DLIList<FACE*> FACE_list; + if (AcisQueryEngine::instance()->get_FACEs( (ENTITY *)copy_of_original_BODY_ptr, FACE_list )) + { + // If copied_FACE_ptr is the only FACE in this BODY, then we can + // try reversing the BODY before attempting the sweep again + if (FACE_list.size() == 1) + { + // Make sure this is a DOUBLE_SIDED FACE + if (copied_FACE_ptr->sides() == DOUBLE_SIDED) + { + // Reverse the BODY that this FACE belongs to + if (!api_reverse_body(copy_of_original_BODY_ptr).ok()) + { + reverse_failed = CUBIT_TRUE; + } + } - // There were problems getting the FACE in the copied BODY, corresponding - // to the FACE being swept in the original BODY. We can't proceed with the - // sweep of this RefFace. - else - { - skip_loop = CUBIT_TRUE; - } // End of if branch if copied_FACE_ptr exists + // The single FACE in this BODY is *not* DOUBLE_SIDED. + // Cannot do the reversal and sweep. + else + { + reverse_failed = CUBIT_TRUE; + } + } - // As all went well (apparently :-), create a new Body using the new - // swept solid and get rid of the original Body and its associated - // ACIS BODY. - if( !skip_loop ) - { - BodySM* new_body_ptr = get_new_Body(body_ptr, BODY_ptr, - copy_of_original_BODY_ptr, - CUBIT_FALSE, CUBIT_FALSE); - if (new_body_ptr) - { - sweep_status = CUBIT_SUCCESS; - result_body_list.append(new_body_ptr); - } - } // End of if branch if skip_loop != TRUE of final new_body_ptr construction - else - { - // Get rid of the copied body, if it exists - if( copy_of_original_BODY_ptr ) - { - AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr); - AcisQueryEngine::instance()->delete_ACIS_BODY( copy_of_original_BODY_ptr); - copy_of_original_BODY_ptr = NULL; - } - } - } // End of if branch if skip_loop != TRUE for problems finding assoc. ACIS BODY - } // End of if branch if skip_loop != TRUE for non-planar FACE_ptr - } + // More than 1 FACE in this BODY. Cannot do the reversal and sweep. + else + { + reverse_failed = CUBIT_TRUE; + } + } + // Couldn't get the FACES of the BODY being swept. Cannot do + // the reversal and sweep. + else + { + reverse_failed = CUBIT_TRUE; + } + } - for (i = 0; i < EDGEs_to_be_swept_list.size(); i++) - { - // Get the EDGE we're going to sweep - copied_EDGE_ptr = EDGEs_to_be_swept_list.get_and_step(); + // Couldn't find the FACE in the copied BODY that corresponds to + // the FACE being swept in the original BODY. Cannot do the + // reversal and sweep. + else + { + reverse_failed = CUBIT_TRUE; + } + } - BODY* new_BODY_ptr = NULL; - sweep_status = sweep_EDGE_about_axis( copied_EDGE_ptr, - new_BODY_ptr, - sweep_axis, - point, - angle, - steps, - draft_angle, - draft_type, - make_solid, - rigid); + // The sweep failed for reasons other than the creation of a negative + // volume. Doesn't make sense to do the reversal and sweep. + else + { + reverse_failed = CUBIT_TRUE; + } - if(sweep_status == CUBIT_FAILURE) - { - PRINT_ERROR("Problem sweeping curve.\n"); - continue; - } + // If the reverse was successful, then try the sweep again + if (reverse_failed == CUBIT_FALSE) + { + if ( !this->sweep_FACE_about_axis( copied_FACE_ptr, + sweep_axis, + point, + angle, + volume_is_negative, + primary_side, + steps, + draft_angle, + draft_type, + rigid, + stop_FACE, + stop_BODY) ) + { + // The attempt to reverse the BODY and sweep it again failed. + PRINT_ERROR("Problem sweeping one of the surfaces.\n"); - BodySM* new_body_ptr = get_new_Body(body_ptr, BODY_ptr, - new_BODY_ptr, - CUBIT_FALSE, CUBIT_FALSE); - if (new_body_ptr) - { - result_body_list.append(new_body_ptr); - sweep_status = CUBIT_SUCCESS; - } - } // End of i loop, iterating over EDGEs_to_be_swept_list + // Delete the BODY created by this sweep + AcisQueryEngine::instance()->delete_ACIS_BODY( copy_of_original_BODY_ptr, CUBIT_TRUE); + copy_of_original_BODY_ptr = NULL; - return sweep_status; -} + skip_loop = CUBIT_TRUE; + } + } -//------------------------------------------------------------------------- -// Purpose : Perform a translational sweep operation -// -// Special Notes : -// -// Creator : Malcolm J. Panthaki -// -// Creation Date : 10/31/96 -//------------------------------------------------------------------------- -CubitStatus AcisModifyEngine::sweep_translational( - DLIList<GeometryEntity*>& ref_ent_list, - DLIList<BodySM*>& result_body_list, - const CubitVector& sweep_vector, - double draft_angle, - int draft_type, - bool switchside, - bool rigid) const -{ - DLIList<FACE*> FACEs_to_be_swept_list; - DLIList<EDGE*> EDGEs_to_be_swept_list; - DLIList<Surface*> ref_faces_list; - DLIList<Curve*> ref_edges_list; + else + { + skip_loop = CUBIT_TRUE; + } + } // End of if branch for initial sweep attemp + } - // First get the ACIS FACEs associated with the input RefFaces - //DLIList<FACE*> temp_faces; - int i; - for (i = ref_ent_list.size(); i > 0; i--) - { - GeometryEntity *ref_ent = ref_ent_list.get_and_step(); - Surface *ref_face = CAST_TO(ref_ent, Surface); - Curve* ref_edge = CAST_TO(ref_ent, Curve); + // There were problems getting the FACE in the copied BODY, corresponding + // to the FACE being swept in the original BODY. We can't proceed with the + // sweep of this RefFace. + else + { + skip_loop = CUBIT_TRUE; + } // End of if branch if copied_FACE_ptr exists - if(ref_face != NULL) - { - //SurfaceACIS::get_FACEs_of_RefFace( ref_face, temp_faces); - //if (temp_faces.size() > 1) { - // PRINT_ERROR("Surface %d cannot be swept as the number of ACIS FACEs associated \n" - // " with it is not 1.\n", - // ref_face->id()); - // return CUBIT_FAILURE; - //} - //if (temp_faces.size() > 0) - // FACEs_to_be_swept_list += temp_faces; - //temp_faces.clean_out(); - FACE* FACE_ptr = AcisQueryEngine::get_FACE(ref_face); - if (!FACE_ptr) - return CUBIT_FAILURE; - FACEs_to_be_swept_list.append(FACE_ptr); - ref_faces_list.append(ref_face); - } - else if (ref_edge != NULL) - { - //EDGEs_to_be_swept_list.append(CurveACIS::get_first_EDGE(ref_edge)); - EDGEs_to_be_swept_list.append(AcisQueryEngine::get_EDGE(ref_edge)); - ref_edges_list.append(ref_edge); - } + // As all went well (apparently :-), create a new Body using the new + // swept solid and get rid of the original Body and its associated + // ACIS BODY. + copy_of_original_BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(copied_FACE_ptr); + if( !skip_loop ) + { + BodySM* new_body_ptr = get_new_Body(body_ptr, BODY_ptr, + copy_of_original_BODY_ptr, + CUBIT_FALSE, CUBIT_FALSE); + if (new_body_ptr) + { + sweep_status = CUBIT_SUCCESS; + result_body_list.append(new_body_ptr); + } + } // End of if branch if skip_loop != TRUE of final new_body_ptr construction + else + { + // Get rid of the copied body, if it exists + if( copy_of_original_BODY_ptr ) + { + AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr); + AcisQueryEngine::instance()->delete_ACIS_BODY( copy_of_original_BODY_ptr); + copy_of_original_BODY_ptr = NULL; + } + } + } // End of if branch if skip_loop != TRUE for problems finding assoc. ACIS BODY + } // End of if branch if skip_loop != TRUE for non-planar FACE_ptr + } - } - ref_edges_list.reset(); - ref_faces_list.reset(); + for (i = 0; i < EDGEs_to_be_swept_list.size(); i++) + { + // Get the EDGE we're going to sweep + copied_EDGE_ptr = EDGEs_to_be_swept_list.get_and_step(); - // Now sweep them along the sweep_vector, a distance equal to the length of - // the sweep SPAvector, with the input draft angle and draft type. + BODY* new_BODY_ptr = NULL; + sweep_status = sweep_EDGE_about_axis( copied_EDGE_ptr, + new_BODY_ptr, + sweep_axis, + point, + angle, + steps, + draft_angle, + draft_type, + make_solid, + rigid, + stop_FACE); - FACEs_to_be_swept_list.reset(); - EDGEs_to_be_swept_list.reset(); - FACE* FACE_ptr = NULL; - FACE* copied_FACE_ptr = NULL; - EDGE* copied_EDGE_ptr = NULL; - Surface* refface_ptr = NULL; - BodySM* body_ptr = NULL; - BODY* BODY_ptr = NULL; - BODY* copy_of_original_BODY_ptr = NULL; - bool primary_side = true; - bool skip_loop = false; - CubitStatus sweep_status = CUBIT_FAILURE; - for (i = 0; i < FACEs_to_be_swept_list.size(); i++) - { - skip_loop = CUBIT_FALSE; - copied_FACE_ptr = NULL; + if(sweep_status == CUBIT_FAILURE) + { + PRINT_ERROR("Problem sweeping curve.\n"); + continue; + } - // Get the RefFace we're going to sweep - refface_ptr = ref_faces_list.get_and_step(); + BodySM* new_body_ptr = get_new_Body(body_ptr, BODY_ptr, + new_BODY_ptr, + CUBIT_FALSE, CUBIT_FALSE); + if (new_body_ptr) + { + result_body_list.append(new_body_ptr); + sweep_status = CUBIT_SUCCESS; + } + } // End of i loop, iterating over EDGEs_to_be_swept_list - // Get the FACE we're going to sweep - FACE_ptr = FACEs_to_be_swept_list.get_and_step(); - - // If the FACE is DOUBLE-SIDED and the switchside option is TRUE - if (FACE_ptr->sides() && switchside) - { - primary_side = CUBIT_FALSE; + return sweep_status; } - // Get the associated Body and its ACIS BODY - body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY(FACE_ptr); - if (body_ptr != NULL) + //------------------------------------------------------------------------- + // Purpose : Perform a translational sweep operation + // + // Special Notes : + // + // Creator : Malcolm J. Panthaki + // + // Creation Date : 10/31/96 + //------------------------------------------------------------------------- + CubitStatus AcisModifyEngine::sweep_translational( + DLIList<GeometryEntity*>& ref_ent_list, + DLIList<BodySM*>& result_body_list, + const CubitVector& sweep_vector, + double draft_angle, + int draft_type, + bool switchside, + bool rigid, + Surface* stop_surf, + BodySM* stop_body) const { - BODY_ptr = AcisQueryEngine::get_BODY(body_ptr); + DLIList<FACE*> FACEs_to_be_swept_list; + DLIList<EDGE*> EDGEs_to_be_swept_list; + DLIList<Surface*> ref_faces_list; + DLIList<Curve*> ref_edges_list; - // Make sure we have a valid ACIS BODY associated with this Body - // and FACE - if (BODY_ptr == NULL) - { - PRINT_ERROR("No valid volume associated with the RefFace.\n"); - skip_loop = CUBIT_TRUE; - } - } + FACE * stop_FACE = NULL; + BODY * stop_BODY = NULL; - else - { - PRINT_WARNING("No volume associated with this surface.\n" - " Sweeping will continue with the ACIS BODY.\n"); - BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr); - if (BODY_ptr == NULL) - { - PRINT_ERROR("No valid volume associated with the RefFace.\n"); - skip_loop = CUBIT_TRUE; - } - } + if (stop_surf) + stop_FACE = AcisQueryEngine::get_FACE(stop_surf); - // If there were no problems finding an associated ACIS BODY, proceed - if( !skip_loop ) - { - // Make a copy of the original BODY before doing the sweep. - // We will perform the sweep on the copy, not on the original body. - copy_of_original_BODY_ptr = this->copy_BODY(BODY_ptr, CUBIT_FALSE); + if (stop_body) + { + BodyACIS* bodyACISPtr = CAST_TO(stop_body, BodyACIS) ; + assert(bodyACISPtr); + stop_BODY = bodyACISPtr->get_BODY_ptr() ; + } - // Find the FACE in the copied BODY that corresponds to the FACE - // being swept in the original BODY. Note that when we made a copy - // of the original BODY, all the "parent" attributes were copied - // over to the new BODY. - if (copy_of_original_BODY_ptr) - { - copied_FACE_ptr = (FACE *) (AcisQueryEngine::instance()-> - get_ENTITY_of_entity( copy_of_original_BODY_ptr, refface_ptr )); - } + // First get the ACIS FACEs associated with the input RefFaces + //DLIList<FACE*> temp_faces; + int i; + for (i = ref_ent_list.size(); i > 0; i--) + { + GeometryEntity *ref_ent = ref_ent_list.get_and_step(); + Surface *ref_face = CAST_TO(ref_ent, Surface); + Curve* ref_edge = CAST_TO(ref_ent, Curve); - if (copied_FACE_ptr) - { - // Remove all the CUBIT_OWNER attributes from the copied BODY - // as we're going to sweep it. - if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_TRUE) - AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr); + if(ref_face != NULL) + { + //SurfaceACIS::get_FACEs_of_RefFace( ref_face, temp_faces); + //if (temp_faces.size() > 1) { + // PRINT_ERROR("Surface %d cannot be swept as the number of ACIS FACEs associated \n" + // " with it is not 1.\n", + // ref_face->id()); + // return CUBIT_FAILURE; + //} + //if (temp_faces.size() > 0) + // FACEs_to_be_swept_list += temp_faces; + //temp_faces.clean_out(); + FACE* FACE_ptr = AcisQueryEngine::get_FACE(ref_face); + if (!FACE_ptr) + return CUBIT_FAILURE; + FACEs_to_be_swept_list.append(FACE_ptr); + ref_faces_list.append(ref_face); + } + else if (ref_edge != NULL) + { + //EDGEs_to_be_swept_list.append(CurveACIS::get_first_EDGE(ref_edge)); + EDGEs_to_be_swept_list.append(AcisQueryEngine::get_EDGE(ref_edge)); + ref_edges_list.append(ref_edge); + } - // Sweep the FACE along the SPAvector, sweep_vector - bool reverse_failed = false; - bool volume_is_negative = false; + } - if ( this->sweep_FACE_along_vector( copied_FACE_ptr, - sweep_vector, - volume_is_negative, - primary_side, - draft_angle, - draft_type, - rigid) == CUBIT_FAILURE) - { - // Volume was negative, so we're going to try to reverse the - // BODY - if (volume_is_negative) - { - // Delete the BODY that was just created (the one with the - // negative volume). - AcisQueryEngine::instance()->delete_ACIS_BODY(copy_of_original_BODY_ptr, CUBIT_TRUE); + ref_edges_list.reset(); + ref_faces_list.reset(); - // Make another copy of the original BODY before attempting - // the sweep again. We will perform the sweep on this copy, - // not on the original body. - copy_of_original_BODY_ptr = this->copy_BODY(BODY_ptr, CUBIT_FALSE); + // Now sweep them along the sweep_vector, a distance equal to the length of + // the sweep SPAvector, with the input draft angle and draft type. - // Find the FACE in the copied BODY that corresponds to the FACE - // being swept in the original BODY. Note that when we made a copy - // of the original BODY, all the "parent" attributes were copied - // over to the new BODY. - if (copy_of_original_BODY_ptr) - { - copied_FACE_ptr = (FACE *) (AcisQueryEngine::instance()-> - get_ENTITY_of_entity( copy_of_original_BODY_ptr, refface_ptr )); - } + FACEs_to_be_swept_list.reset(); + EDGEs_to_be_swept_list.reset(); + FACE* FACE_ptr = NULL; + FACE* copied_FACE_ptr = NULL; + EDGE* copied_EDGE_ptr = NULL; + Surface* refface_ptr = NULL; + BodySM* body_ptr = NULL; + BODY* BODY_ptr = NULL; + BODY* copy_of_original_BODY_ptr = NULL; + bool primary_side = true; + bool skip_loop = false; + CubitStatus sweep_status = CUBIT_FAILURE; + for (i = 0; i < FACEs_to_be_swept_list.size(); i++) + { + skip_loop = CUBIT_FALSE; + copied_FACE_ptr = NULL; - if (copied_FACE_ptr) - { - // Remove all the CUBIT_OWNER attributes from the copied BODY - // as we're going to sweep it. - if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_TRUE) - AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr); + // Get the RefFace we're going to sweep + refface_ptr = ref_faces_list.get_and_step(); - // Find out how many FACEs exist in the BODY that owns - // copied_FACE_ptr - DLIList<FACE*> FACE_list; - if (AcisQueryEngine::instance()->get_FACEs( (ENTITY *)copy_of_original_BODY_ptr, FACE_list )) - { - // If copied_FACE_ptr is the only FACE in this BODY, then we can - // try reversing the BODY before attempting the sweep again - if (FACE_list.size() == 1) - { - // Make sure this is a DOUBLE_SIDED FACE - if (copied_FACE_ptr->sides() == DOUBLE_SIDED) - { - // Reverse the BODY that this FACE belongs to - if (!api_reverse_body(copy_of_original_BODY_ptr).ok()) - { - reverse_failed = CUBIT_TRUE; - } - } + // Get the FACE we're going to sweep + FACE_ptr = FACEs_to_be_swept_list.get_and_step(); - // The single FACE in this BODY is *not* DOUBLE_SIDED. - // Cannot do the reversal and sweep. - else - { - reverse_failed = CUBIT_TRUE; - } - } + // If the FACE is DOUBLE-SIDED and the switchside option is TRUE + if (FACE_ptr->sides() && switchside) + { + primary_side = CUBIT_FALSE; + } - // More than 1 FACE in this BODY. Cannot do the reversal and sweep. - else - { - reverse_failed = CUBIT_TRUE; - } - } + // Get the associated Body and its ACIS BODY + body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY(FACE_ptr); + if (body_ptr != NULL) + { + BODY_ptr = AcisQueryEngine::get_BODY(body_ptr); - // Couldn't get the FACES of the BODY being swept. Cannot do - // the reversal and sweep. - else - { - reverse_failed = CUBIT_TRUE; - } - } + // Make sure we have a valid ACIS BODY associated with this Body + // and FACE + if (BODY_ptr == NULL) + { + PRINT_ERROR("No valid volume associated with the RefFace.\n"); + skip_loop = CUBIT_TRUE; + } + } - // Couldn't find the FACE in the copied BODY that corresponds to - // the FACE being swept in the original BODY. Cannot do the - // reversal and sweep. - else - { - reverse_failed = CUBIT_TRUE; - } - } + else + { + PRINT_WARNING("No volume associated with this surface.\n" + " Sweeping will continue with the ACIS BODY.\n"); + BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr); + if (BODY_ptr == NULL) + { + PRINT_ERROR("No valid volume associated with the RefFace.\n"); + skip_loop = CUBIT_TRUE; + } + } - // The sweep failed for reasons other than the creation of a negative - // volume. Doesn't make sense to do the reversal and sweep. - else - { - reverse_failed = CUBIT_TRUE; - } + // If there were no problems finding an associated ACIS BODY, proceed + if( !skip_loop ) + { + // Make a copy of the original BODY before doing the sweep. + // We will perform the sweep on the copy, not on the original body. + copy_of_original_BODY_ptr = this->copy_BODY(BODY_ptr, CUBIT_FALSE); - // If reverse was successful, then try the sweep again - if ( reverse_failed == CUBIT_FALSE ) - { - if ( this->sweep_FACE_along_vector( copied_FACE_ptr, - sweep_vector, - volume_is_negative, - primary_side, - draft_angle, - draft_type, - rigid) == CUBIT_FAILURE ) - { - // The attempt to reverse the BODY and sweep it again failed. - PRINT_ERROR("Problem sweeping one of the surfaces.\n"); + // Find the FACE in the copied BODY that corresponds to the FACE + // being swept in the original BODY. Note that when we made a copy + // of the original BODY, all the "parent" attributes were copied + // over to the new BODY. + if (copy_of_original_BODY_ptr) + { + copied_FACE_ptr = (FACE *) (AcisQueryEngine::instance()-> + get_ENTITY_of_entity( copy_of_original_BODY_ptr, refface_ptr )); + } - // Delete the BODY created by this sweep - AcisQueryEngine::instance()->delete_ACIS_BODY( copy_of_original_BODY_ptr, CUBIT_TRUE ); + if (copied_FACE_ptr) + { + // Remove all the CUBIT_OWNER attributes from the copied BODY + // as we're going to sweep it. + if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_TRUE) + AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr); - skip_loop = CUBIT_TRUE; - } - } - else - { - skip_loop = CUBIT_TRUE; - } - } // End of if branch for initial sweep attemp - } + // Sweep the FACE along the SPAvector, sweep_vector + bool reverse_failed = false; + bool volume_is_negative = false; - // There were problems getting the FACE in the copied BODY, corresponding - // to the FACE being swept in the original BODY. We can't proceed with the - // sweep of this RefFace. - else - { - skip_loop = CUBIT_TRUE; - } // End of if branch if copied_FACE_ptr exists + //copy stop_BODY + BODY* temp_BODY = NULL; + if (stop_BODY) + copy_BODY(stop_BODY); - // As all went well (apparently :-), create a new Body using the new - // swept solid and get rid of the original Body and its associated - // ACIS BODY. - if( !skip_loop ) - { - BodySM* new_body_ptr = get_new_Body(body_ptr, BODY_ptr, - copy_of_original_BODY_ptr, - CUBIT_FALSE, CUBIT_FALSE); - if (new_body_ptr) - { - result_body_list.append(new_body_ptr); - sweep_status = CUBIT_SUCCESS; - } + if ( this->sweep_FACE_along_vector( copied_FACE_ptr, + sweep_vector, + volume_is_negative, + primary_side, + draft_angle, + draft_type, + rigid, + stop_FACE, + temp_BODY) == CUBIT_FAILURE) + { + // Volume was negative, so we're going to try to reverse the + // BODY + if (volume_is_negative) + { + // Delete the BODY that was just created (the one with the + // negative volume). + AcisQueryEngine::instance()->delete_ACIS_BODY(copy_of_original_BODY_ptr, CUBIT_TRUE); - } // End of if branch if skip_loop != TRUE of final new_body_ptr construction - else - { - // Get rid of the copied body, if it exists - if( copy_of_original_BODY_ptr ) - { - AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr); - AcisQueryEngine::instance()->delete_ACIS_BODY( copy_of_original_BODY_ptr); + // Make another copy of the original BODY before attempting + // the sweep again. We will perform the sweep on this copy, + // not on the original body. + copy_of_original_BODY_ptr = this->copy_BODY(BODY_ptr, CUBIT_FALSE); - copy_of_original_BODY_ptr = NULL; - } - } - } // End of if branch if skip_loop != TRUE for problems finding assoc. ACIS BODY - } // End of i loop, iterating over FACEs_to_be_swept_list + // Find the FACE in the copied BODY that corresponds to the FACE + // being swept in the original BODY. Note that when we made a copy + // of the original BODY, all the "parent" attributes were copied + // over to the new BODY. + if (copy_of_original_BODY_ptr) + { + copied_FACE_ptr = (FACE *) (AcisQueryEngine::instance()-> + get_ENTITY_of_entity( copy_of_original_BODY_ptr, refface_ptr )); + } + if (copied_FACE_ptr) + { + // Remove all the CUBIT_OWNER attributes from the copied BODY + // as we're going to sweep it. + if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_TRUE) + AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr); - //Now we iterate over the EDGEs - for (i = 0; i < EDGEs_to_be_swept_list.size(); i++) - { - // Get the EDGE we're going to sweep - copied_EDGE_ptr = EDGEs_to_be_swept_list.get_and_step(); + // Find out how many FACEs exist in the BODY that owns + // copied_FACE_ptr + DLIList<FACE*> FACE_list; + if (AcisQueryEngine::instance()->get_FACEs( (ENTITY *)copy_of_original_BODY_ptr, FACE_list )) + { + // If copied_FACE_ptr is the only FACE in this BODY, then we can + // try reversing the BODY before attempting the sweep again + if (FACE_list.size() == 1) + { + // Make sure this is a DOUBLE_SIDED FACE + if (copied_FACE_ptr->sides() == DOUBLE_SIDED) + { + // Reverse the BODY that this FACE belongs to + if (!api_reverse_body(copy_of_original_BODY_ptr).ok()) + { + reverse_failed = CUBIT_TRUE; + } + } - BODY* new_BODY_ptr = NULL; - sweep_status = sweep_EDGE_along_vector( copied_EDGE_ptr, - new_BODY_ptr, - sweep_vector, - draft_angle, - draft_type, - rigid); - if(sweep_status == CUBIT_FAILURE) - { - PRINT_ERROR("Problem sweeping curve.\n"); - continue; - } + // The single FACE in this BODY is *not* DOUBLE_SIDED. + // Cannot do the reversal and sweep. + else + { + reverse_failed = CUBIT_TRUE; + } + } - BodySM* new_body_ptr = get_new_Body(body_ptr, BODY_ptr, - new_BODY_ptr, - CUBIT_FALSE, CUBIT_FALSE); - if (new_body_ptr) - { - sweep_status = CUBIT_SUCCESS; - result_body_list.append(new_body_ptr); - } + // More than 1 FACE in this BODY. Cannot do the reversal and sweep. + else + { + reverse_failed = CUBIT_TRUE; + } + } - } // End of i loop, iterating over EDGEs_to_be_swept_list + // Couldn't get the FACES of the BODY being swept. Cannot do + // the reversal and sweep. + else + { + reverse_failed = CUBIT_TRUE; + } + } - return sweep_status; -} + // Couldn't find the FACE in the copied BODY that corresponds to + // the FACE being swept in the original BODY. Cannot do the + // reversal and sweep. + else + { + reverse_failed = CUBIT_TRUE; + } + } -CubitStatus AcisModifyEngine::sweep_perpendicular( - DLIList<GeometryEntity*>& ref_ent_list, - DLIList<BodySM*>& result_body_list, - double distance, - double draft_angle, - int draft_type, - bool switchside, - bool rigid) const -{ - DLIList<FACE*> FACEs_to_be_swept_list; + // The sweep failed for reasons other than the creation of a negative + // volume. Doesn't make sense to do the reversal and sweep. + else + { + reverse_failed = CUBIT_TRUE; + } - DLIList<Surface*> ref_faces_list; - DLIList<Curve*> ref_edges_list; + // If reverse was successful, then try the sweep again + if ( reverse_failed == CUBIT_FALSE ) + { + //copy stop_BODY + BODY* temp_BODY = NULL; + if (stop_BODY) + copy_BODY(stop_BODY); - // First get the ACIS FACEs associated with the input RefFaces - //DLIList<FACE*> temp_faces; - int i; - for (i = ref_ent_list.size(); i > 0; i--) - { - GeometryEntity *ref_ent = ref_ent_list.get_and_step(); - Surface *ref_face = CAST_TO(ref_ent, Surface); - Curve* ref_edge = CAST_TO(ref_ent, Curve); + if ( this->sweep_FACE_along_vector( copied_FACE_ptr, + sweep_vector, + volume_is_negative, + primary_side, + draft_angle, + draft_type, + rigid, + stop_FACE, + temp_BODY) == CUBIT_FAILURE ) + { + // The attempt to reverse the BODY and sweep it again failed. + PRINT_ERROR("Problem sweeping one of the surfaces.\n"); - if(ref_face != NULL) - { - //SurfaceACIS::get_FACEs_of_RefFace( ref_face, temp_faces); - //if (temp_faces.size() > 1) { - // PRINT_ERROR("Surface %d cannot be swept as the number of ACIS FACEs associated \n" - // " with it is not 1.\n", - // ref_face->id()); - // return CUBIT_FAILURE; - //} - //if (temp_faces.size() > 0) - // FACEs_to_be_swept_list += temp_faces; - //temp_faces.clean_out(); - FACE* FACE_ptr = AcisQueryEngine::get_FACE(ref_face); - if (!FACE_ptr) - return CUBIT_FAILURE; - FACEs_to_be_swept_list.append(FACE_ptr); - ref_faces_list.append(ref_face); - } - else if (ref_edge != NULL) - { - ref_edges_list.append(ref_edge); - } - } + // Delete the BODY created by this sweep + AcisQueryEngine::instance()->delete_ACIS_BODY( copy_of_original_BODY_ptr, CUBIT_TRUE ); - if(ref_edges_list.size()) - PRINT_ERROR("Curves cannot be swept perpendicularly, please use the vector sweep.\n"); + skip_loop = CUBIT_TRUE; + } + } + else + { + skip_loop = CUBIT_TRUE; + } + } // End of if branch for initial sweep attemp + } - ref_faces_list.reset(); + // There were problems getting the FACE in the copied BODY, corresponding + // to the FACE being swept in the original BODY. We can't proceed with the + // sweep of this RefFace. + else + { + skip_loop = CUBIT_TRUE; + } // End of if branch if copied_FACE_ptr exists - // Now sweep them perpendicularly, a distance equal to the - // distance given with the input draft angle and - // draft type. + // As all went well (apparently :-), create a new Body using the new + // swept solid and get rid of the original Body and its associated + // ACIS BODY. + if( !skip_loop ) + { + BodySM* new_body_ptr = get_new_Body(body_ptr, BODY_ptr, + copy_of_original_BODY_ptr, + CUBIT_FALSE, CUBIT_FALSE); + if (new_body_ptr) + { + result_body_list.append(new_body_ptr); + sweep_status = CUBIT_SUCCESS; + } - FACEs_to_be_swept_list.reset(); - FACE* FACE_ptr = NULL; - FACE* copied_FACE_ptr = NULL; + } // End of if branch if skip_loop != TRUE of final new_body_ptr construction + else + { + // Get rid of the copied body, if it exists + if( copy_of_original_BODY_ptr ) + { + AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr); + AcisQueryEngine::instance()->delete_ACIS_BODY( copy_of_original_BODY_ptr); - Surface* refface_ptr = NULL; - BodySM* body_ptr = NULL; - BODY* BODY_ptr = NULL; - BODY* copy_of_original_BODY_ptr = NULL; - bool primary_side = CUBIT_TRUE; - int skip_loop = CUBIT_FALSE; - CubitStatus sweep_status = CUBIT_FAILURE; - for (i = 0; i < FACEs_to_be_swept_list.size(); i++) - { - skip_loop = CUBIT_FALSE; - copied_FACE_ptr = NULL; + copy_of_original_BODY_ptr = NULL; + } + } + } // End of if branch if skip_loop != TRUE for problems finding assoc. ACIS BODY + } // End of i loop, iterating over FACEs_to_be_swept_list - // Get the RefFace we're going to sweep - refface_ptr = ref_faces_list.get_and_step(); - // Get the FACE we're going to sweep - FACE_ptr = FACEs_to_be_swept_list.get_and_step(); + //Now we iterate over the EDGEs + for (i = 0; i < EDGEs_to_be_swept_list.size(); i++) + { + // Get the EDGE we're going to sweep + copied_EDGE_ptr = EDGEs_to_be_swept_list.get_and_step(); - // If the FACE is DOUBLE-SIDED and the switchside option is TRUE - if (FACE_ptr->sides() && switchside) - { - primary_side = CUBIT_FALSE; - } + BODY* new_BODY_ptr = NULL; + sweep_status = sweep_EDGE_along_vector( copied_EDGE_ptr, + new_BODY_ptr, + sweep_vector, + draft_angle, + draft_type, + rigid, + stop_FACE); + if(sweep_status == CUBIT_FAILURE) + { + PRINT_ERROR("Problem sweeping curve.\n"); + continue; + } - // Get the associated Body and its ACIS BODY - body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY(FACE_ptr); - if (body_ptr != NULL) - { - BODY_ptr = AcisQueryEngine::get_BODY(body_ptr); + BodySM* new_body_ptr = get_new_Body(body_ptr, BODY_ptr, + new_BODY_ptr, + CUBIT_FALSE, CUBIT_FALSE); + if (new_body_ptr) + { + sweep_status = CUBIT_SUCCESS; + result_body_list.append(new_body_ptr); + } - // Make sure we have a valid ACIS BODY associated with this Body - // and FACE - if (BODY_ptr == NULL) - { - PRINT_ERROR("No valid volume associated with the RefFace.\n"); - skip_loop = CUBIT_TRUE; - } - } + } // End of i loop, iterating over EDGEs_to_be_swept_list - else - { - PRINT_WARNING("No volume associated with this surface.\n" - " Sweeping will continue with the ACIS BODY.\n"); - BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr); - if (BODY_ptr == NULL) - { - PRINT_ERROR("No valid volume associated with the RefFace.\n"); - skip_loop = CUBIT_TRUE; - } + return sweep_status; } - // If there were no problems finding an associated ACIS BODY, proceed - if( !skip_loop ) + CubitStatus AcisModifyEngine::sweep_perpendicular( + DLIList<GeometryEntity*>& ref_ent_list, + DLIList<BodySM*>& result_body_list, + double distance, + double draft_angle, + int draft_type, + bool switchside, + bool rigid, + Surface* stop_surf, + BodySM* stop_body) const { - // Make a copy of the original BODY before doing the sweep. - // We will perform the sweep on the copy, not on the original body. - copy_of_original_BODY_ptr = this->copy_BODY(BODY_ptr, CUBIT_FALSE); + DLIList<FACE*> FACEs_to_be_swept_list; - // Find the FACE in the copied BODY that corresponds to the FACE - // being swept in the original BODY. Note that when we made a copy - // of the original BODY, all the "parent" attributes were copied - // over to the new BODY. - if (copy_of_original_BODY_ptr) - { - copied_FACE_ptr = (FACE *) (AcisQueryEngine::instance()-> - get_ENTITY_of_entity( copy_of_original_BODY_ptr, refface_ptr )); - } + DLIList<Surface*> ref_faces_list; + DLIList<Curve*> ref_edges_list; + FACE * stop_FACE = NULL; + BODY * stop_BODY = NULL; - if (copied_FACE_ptr) - { - // Remove all the CUBIT_OWNER attributes from the copied BODY - // as we're going to sweep it. - if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_TRUE) - AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr); + if (stop_surf) + stop_FACE = AcisQueryEngine::get_FACE(stop_surf); - // Sweep the FACE along the SPAvector, sweep_vector - bool reverse_failed = CUBIT_FALSE; - bool volume_is_negative = CUBIT_FALSE; + if (stop_body) + { + BodyACIS* bodyACISPtr = CAST_TO(stop_body, BodyACIS) ; + assert(bodyACISPtr); + stop_BODY = bodyACISPtr->get_BODY_ptr() ; + } - if ( this->sweep_FACE_perpendicular( copied_FACE_ptr, - distance, - volume_is_negative, - primary_side, - draft_angle, - draft_type, - rigid) == CUBIT_FAILURE) - { - // Volume was negative, so we're going to try to reverse the - // BODY - if (volume_is_negative) - { - // Delete the BODY that was just created (the one with the - // negative volume). - AcisQueryEngine::instance()->delete_ACIS_BODY(copy_of_original_BODY_ptr, CUBIT_TRUE); + // First get the ACIS FACEs associated with the input RefFaces + // DLIList<FACE*> temp_faces; + int i; + for (i = ref_ent_list.size(); i > 0; i--) + { + GeometryEntity *ref_ent = ref_ent_list.get_and_step(); + Surface *ref_face = CAST_TO(ref_ent, Surface); + Curve* ref_edge = CAST_TO(ref_ent, Curve); - // Make another copy of the original BODY before attempting - // the sweep again. We will perform the sweep on this copy, - // not on the original body. - copy_of_original_BODY_ptr = this->copy_BODY(BODY_ptr, CUBIT_FALSE); + if(ref_face != NULL) + { + //SurfaceACIS::get_FACEs_of_RefFace( ref_face, temp_faces); + //if (temp_faces.size() > 1) { + // PRINT_ERROR("Surface %d cannot be swept as the number of ACIS FACEs associated \n" + // " with it is not 1.\n", + // ref_face->id()); + // return CUBIT_FAILURE; + //} + //if (temp_faces.size() > 0) + // FACEs_to_be_swept_list += temp_faces; + //temp_faces.clean_out(); + FACE* FACE_ptr = AcisQueryEngine::get_FACE(ref_face); + if (!FACE_ptr) + return CUBIT_FAILURE; + FACEs_to_be_swept_list.append(FACE_ptr); + ref_faces_list.append(ref_face); + } + else if (ref_edge != NULL) + { + ref_edges_list.append(ref_edge); + } + } - // Find the FACE in the copied BODY that corresponds to the FACE - // being swept in the original BODY. Note that when we made a copy - // of the original BODY, all the "parent" attributes were copied - // over to the new BODY. - if (copy_of_original_BODY_ptr) - { - copied_FACE_ptr = (FACE *) (AcisQueryEngine::instance()-> - get_ENTITY_of_entity( copy_of_original_BODY_ptr, refface_ptr )); - } + if(ref_edges_list.size()) + PRINT_ERROR("Curves cannot be swept perpendicularly, please use the vector sweep.\n"); - if (copied_FACE_ptr) - { - // Remove all the CUBIT_OWNER attributes from the copied BODY - // as we're going to sweep it. - if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_TRUE) - AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr); + ref_faces_list.reset(); - // Find out how many FACEs exist in the BODY that owns - // copied_FACE_ptr - DLIList<FACE*> FACE_list; - if (AcisQueryEngine::instance()->get_FACEs( (ENTITY *)copy_of_original_BODY_ptr, FACE_list )) - { - // If copied_FACE_ptr is the only FACE in this BODY, then we can - // try reversing the BODY before attempting the sweep again - if (FACE_list.size() == 1) - { - // Make sure this is a DOUBLE_SIDED FACE - if (copied_FACE_ptr->sides() == DOUBLE_SIDED) - { - // Reverse the BODY that this FACE belongs to - if (!api_reverse_body(copy_of_original_BODY_ptr).ok()) - { - reverse_failed = CUBIT_TRUE; - } - } + // Now sweep them perpendicularly, a distance equal to the + // distance given with the input draft angle and + // draft type. - // The single FACE in this BODY is *not* DOUBLE_SIDED. - // Cannot do the reversal and sweep. - else - { - reverse_failed = CUBIT_TRUE; - } - } + FACEs_to_be_swept_list.reset(); + FACE* FACE_ptr = NULL; + FACE* copied_FACE_ptr = NULL; - // More than 1 FACE in this BODY. Cannot do the reversal and sweep. - else - { - reverse_failed = CUBIT_TRUE; - } - } + Surface* refface_ptr = NULL; + BodySM* body_ptr = NULL; + BODY* BODY_ptr = NULL; + BODY* copy_of_original_BODY_ptr = NULL; + bool primary_side = CUBIT_TRUE; + int skip_loop = CUBIT_FALSE; + CubitStatus sweep_status = CUBIT_FAILURE; + for (i = 0; i < FACEs_to_be_swept_list.size(); i++) + { + skip_loop = CUBIT_FALSE; + copied_FACE_ptr = NULL; - // Couldn't get the FACES of the BODY being swept. Cannot do - // the reversal and sweep. - else - { - reverse_failed = CUBIT_TRUE; - } - } + // Get the RefFace we're going to sweep + refface_ptr = ref_faces_list.get_and_step(); - // Couldn't find the FACE in the copied BODY that corresponds to - // the FACE being swept in the original BODY. Cannot do the - // reversal and sweep. - else - { - reverse_failed = CUBIT_TRUE; - } - } + // Get the FACE we're going to sweep + FACE_ptr = FACEs_to_be_swept_list.get_and_step(); - // The sweep failed for reasons other than the creation of a negative - // volume. Doesn't make sense to do the reversal and sweep. - else - { - reverse_failed = CUBIT_TRUE; - } + // If the FACE is DOUBLE-SIDED and the switchside option is TRUE + if (FACE_ptr->sides() && switchside) + { + primary_side = CUBIT_FALSE; + } - // If reverse was successful, then try the sweep again - if ( reverse_failed == CUBIT_FALSE ) - { - if ( this->sweep_FACE_perpendicular( copied_FACE_ptr, - distance, - volume_is_negative, - primary_side, - draft_angle, - draft_type, - rigid) == CUBIT_FAILURE ) - { - // The attempt to reverse the BODY and sweep it again failed. - PRINT_ERROR("Problem sweeping one of the surfaces.\n"); + // Get the associated Body and its ACIS BODY + body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY(FACE_ptr); + if (body_ptr != NULL) + { + BODY_ptr = AcisQueryEngine::get_BODY(body_ptr); - // Delete the BODY created by this sweep - AcisQueryEngine::instance()->delete_ACIS_BODY( copy_of_original_BODY_ptr, CUBIT_TRUE ); + // Make sure we have a valid ACIS BODY associated with this Body + // and FACE + if (BODY_ptr == NULL) + { + PRINT_ERROR("No valid volume associated with the RefFace.\n"); + skip_loop = CUBIT_TRUE; + } + } - skip_loop = CUBIT_TRUE; - } - } - else - { - skip_loop = CUBIT_TRUE; - } - } // End of if branch for initial sweep attemp - } + else + { + PRINT_WARNING("No volume associated with this surface.\n" + " Sweeping will continue with the ACIS BODY.\n"); + BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr); + if (BODY_ptr == NULL) + { + PRINT_ERROR("No valid volume associated with the RefFace.\n"); + skip_loop = CUBIT_TRUE; + } + } - // There were problems getting the FACE in the copied BODY, corresponding - // to the FACE being swept in the original BODY. We can't proceed with the - // sweep of this RefFace. - else - { - skip_loop = CUBIT_TRUE; - } // End of if branch if copied_FACE_ptr exists + // If there were no problems finding an associated ACIS BODY, proceed + if( !skip_loop ) + { + // Make a copy of the original BODY before doing the sweep. + // We will perform the sweep on the copy, not on the original body. + copy_of_original_BODY_ptr = this->copy_BODY(BODY_ptr, CUBIT_FALSE); - // As all went well (apparently :-), create a new Body using the new - // swept solid and get rid of the original Body and its associated - // ACIS BODY. - if( !skip_loop ) - { - BodySM* new_body_ptr = get_new_Body(body_ptr, BODY_ptr, - copy_of_original_BODY_ptr, - CUBIT_FALSE, CUBIT_FALSE); - if (new_body_ptr) - { - result_body_list.append(new_body_ptr); - sweep_status = CUBIT_SUCCESS; - } + // Find the FACE in the copied BODY that corresponds to the FACE + // being swept in the original BODY. Note that when we made a copy + // of the original BODY, all the "parent" attributes were copied + // over to the new BODY. + if (copy_of_original_BODY_ptr) + { + copied_FACE_ptr = (FACE *) (AcisQueryEngine::instance()-> + get_ENTITY_of_entity( copy_of_original_BODY_ptr, refface_ptr )); + } - } // End of if branch if skip_loop != TRUE of final new_body_ptr construction - else - { - // Get rid of the copied body, if it exists - if( copy_of_original_BODY_ptr ) - { - AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr); - AcisQueryEngine::instance()->delete_ACIS_BODY( copy_of_original_BODY_ptr); + if (copied_FACE_ptr) + { + // Remove all the CUBIT_OWNER attributes from the copied BODY + // as we're going to sweep it. + if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_TRUE) + AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr); - copy_of_original_BODY_ptr = NULL; - } - } - } // End of if branch if skip_loop != TRUE for problems finding assoc. ACIS BODY - } // End of i loop, iterating over FACEs_to_be_swept_list - return sweep_status; -} + // Sweep the FACE along the SPAvector, sweep_vector + bool reverse_failed = CUBIT_FALSE; + bool volume_is_negative = CUBIT_FALSE; -//------------------------------------------------------------------------- -// Purpose : Perform a face sweep operation along a curve -// -// Special Notes : In ACIS v4.2, I was unable to get it to sweep along -// multiple curves, so for now it gives an error message -// if this is attempted. -// -// The function will not allow you to sweep back into -// a solid. -// -// Creator : Steve Storm -// -// Creation Date : 8/7/98 -//------------------------------------------------------------------------- -CubitStatus AcisModifyEngine::sweep_along_curve( - DLIList<GeometryEntity*>& ref_ent_list, - DLIList<BodySM*>& result_body_list, - DLIList<Curve*>& ref_edge_list, - double draft_angle, - int draft_type, - bool rigid) const -{ - outcome result; - DLIList<FACE*> FACEs_to_be_swept_list; - DLIList<EDGE*> EDGEs_to_be_swept_list; - DLIList<Surface*> ref_faces_list; - DLIList<Curve*> ref_edges_list; + //copy stop_BODY + BODY* temp_BODY = NULL; + if (stop_BODY) + copy_BODY(stop_BODY); + if ( this->sweep_FACE_perpendicular( copied_FACE_ptr, + distance, + volume_is_negative, + primary_side, + draft_angle, + draft_type, + rigid, + stop_FACE, + temp_BODY ) == CUBIT_FAILURE) + { + // Volume was negative, so we're going to try to reverse the + // BODY + if (volume_is_negative) + { + // Delete the BODY that was just created (the one with the + // negative volume). + AcisQueryEngine::instance()->delete_ACIS_BODY(copy_of_original_BODY_ptr, CUBIT_TRUE); - // First get the ACIS FACEs associated with the input RefFaces -// DLIList<FACE*> temp_faces; - int i; - for (i = ref_ent_list.size(); i > 0; i--) - { - GeometryEntity* ref_ent = ref_ent_list.get_and_step(); - Surface *ref_face = CAST_TO(ref_ent, Surface); - Curve* ref_edge = CAST_TO(ref_ent, Curve); - if(ref_face != NULL) - { -// SurfaceACIS::get_FACEs_of_RefFace( ref_face, temp_faces); -// if (temp_faces.size() > 1) { -// PRINT_ERROR("Surface %d cannot be swept as the number of ACIS FACEs associated \n" -// " with it is not 1.\n", -// ref_face->id()); - // return CUBIT_FAILURE; -// } -// if (temp_faces.size() > 0) -// FACEs_to_be_swept_list += temp_faces; -// temp_faces.clean_out(); - FACE* FACE_ptr = AcisQueryEngine::get_FACE(ref_face); - if (!FACE_ptr) - return CUBIT_FAILURE; - FACEs_to_be_swept_list.append(FACE_ptr); - ref_faces_list.append(ref_face); - } - else if (ref_edge != NULL) - { - //EDGEs_to_be_swept_list.append(CurveACIS::get_first_EDGE(ref_edge)); - EDGEs_to_be_swept_list.append(AcisQueryEngine::get_EDGE(ref_edge)); - ref_edges_list.append(ref_edge); - } + // Make another copy of the original BODY before attempting + // the sweep again. We will perform the sweep on this copy, + // not on the original body. + copy_of_original_BODY_ptr = this->copy_BODY(BODY_ptr, CUBIT_FALSE); - } + // Find the FACE in the copied BODY that corresponds to the FACE + // being swept in the original BODY. Note that when we made a copy + // of the original BODY, all the "parent" attributes were copied + // over to the new BODY. + if (copy_of_original_BODY_ptr) + { + copied_FACE_ptr = (FACE *) (AcisQueryEngine::instance()-> + get_ENTITY_of_entity( copy_of_original_BODY_ptr, refface_ptr )); + } - // Now sweep them along the EDGE. + if (copied_FACE_ptr) + { + // Remove all the CUBIT_OWNER attributes from the copied BODY + // as we're going to sweep it. + if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_TRUE) + AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr); - BODY* EDGE_BODY_ptr = NULL; + // Find out how many FACEs exist in the BODY that owns + // copied_FACE_ptr + DLIList<FACE*> FACE_list; + if (AcisQueryEngine::instance()->get_FACEs( (ENTITY *)copy_of_original_BODY_ptr, FACE_list )) + { + // If copied_FACE_ptr is the only FACE in this BODY, then we can + // try reversing the BODY before attempting the sweep again + if (FACE_list.size() == 1) + { + // Make sure this is a DOUBLE_SIDED FACE + if (copied_FACE_ptr->sides() == DOUBLE_SIDED) + { + // Reverse the BODY that this FACE belongs to + if (!api_reverse_body(copy_of_original_BODY_ptr).ok()) + { + reverse_failed = CUBIT_TRUE; + } + } - FACEs_to_be_swept_list.reset(); - EDGEs_to_be_swept_list.reset(); - ref_edges_list.reset(); + // The single FACE in this BODY is *not* DOUBLE_SIDED. + // Cannot do the reversal and sweep. + else + { + reverse_failed = CUBIT_TRUE; + } + } - FACE* FACE_ptr = NULL; - FACE* copied_FACE_ptr = NULL; - Surface* ref_face_ptr = NULL; - BodySM* body_ptr = NULL; - BODY* BODY_ptr = NULL; - BODY* copied_BODY_ptr = NULL; + // More than 1 FACE in this BODY. Cannot do the reversal and sweep. + else + { + reverse_failed = CUBIT_TRUE; + } + } - // Get the EDGE to sweep along. No need to copy it as it is going into - // a WIRE body (it's copied into the WIRE body). - // - Curve* ref_edge_ptr = NULL; + // Couldn't get the FACES of the BODY being swept. Cannot do + // the reversal and sweep. + else + { + reverse_failed = CUBIT_TRUE; + } + } - // Sweep the FACE along the chain of EDGES. - int num_edges = ref_edge_list.size(); - EDGE** EDGES = new EDGE*[num_edges]; - ref_edge_list.reset(); - for( int j=0; j<num_edges; j++ ) - { - ref_edge_ptr = ref_edge_list.get_and_step(); - //Curve* curve_ptr = ref_edge_ptr->get_curve_ptr(); - //CurveACIS *curve_ACIS = CAST_TO(curve_ptr, CurveACIS); - CurveACIS *curve_ACIS = CAST_TO(ref_edge_ptr, CurveACIS); - EDGE *EDGE_ptr = curve_ACIS->get_EDGE_ptr(); + // Couldn't find the FACE in the copied BODY that corresponds to + // the FACE being swept in the original BODY. Cannot do the + // reversal and sweep. + else + { + reverse_failed = CUBIT_TRUE; + } + } - if (!EDGE_ptr) - { - PRINT_ERROR("Unable to get ACIS EDGE from Curve\n" ); - delete [] EDGES; - return CUBIT_FAILURE; - } + // The sweep failed for reasons other than the creation of a negative + // volume. Doesn't make sense to do the reversal and sweep. + else + { + reverse_failed = CUBIT_TRUE; + } - EDGE *copied_EDGE_ptr = NULL; - result = api_edge( EDGE_ptr, copied_EDGE_ptr ); - if (!result.ok() || copied_EDGE_ptr == NULL ) - { - AcisQueryEngine::instance()->ACIS_API_error (result); - PRINT_ERROR( "Unable to copy ACIS curve\n" ); - delete [] EDGES; - return CUBIT_FAILURE; - } - EDGES[j] = copied_EDGE_ptr; - } + // If reverse was successful, then try the sweep again + if ( reverse_failed == CUBIT_FALSE ) + { + //copy stop_BODY + BODY* temp_BODY = NULL; + if (stop_BODY) + copy_BODY(stop_BODY); - // Make a WIRE body to sweep along. If we have to reverse the EDGE - // (since ACIS only allows you to sweep from start to end), the wire - // will be needed. - result = api_make_ewire( num_edges, EDGES, EDGE_BODY_ptr ); - WIRE* WIRE_ptr = NULL; - if (!result.ok()) - { - AcisQueryEngine::instance()->ACIS_API_error (result); - PRINT_ERROR( "Unable to make ACIS wire body from curve to sweep along\n" ); - } - else - WIRE_ptr = EDGE_BODY_ptr->lump()->shell()->wire(); + if ( this->sweep_FACE_perpendicular( copied_FACE_ptr, + distance, + volume_is_negative, + primary_side, + draft_angle, + draft_type, + rigid, + stop_FACE, + temp_BODY) == CUBIT_FAILURE ) + { + // The attempt to reverse the BODY and sweep it again failed. + PRINT_ERROR("Problem sweeping one of the surfaces.\n"); - CubitStatus sweep_status = CUBIT_FAILURE; - for (i = 0; i < FACEs_to_be_swept_list.size(); i++) - { - copied_FACE_ptr = NULL; + // Delete the BODY created by this sweep + AcisQueryEngine::instance()->delete_ACIS_BODY( copy_of_original_BODY_ptr, CUBIT_TRUE ); - // Get the RefFace we're going to sweep - ref_face_ptr = ref_faces_list.get_and_step(); + skip_loop = CUBIT_TRUE; + } + } + else + { + skip_loop = CUBIT_TRUE; + } + } // End of if branch for initial sweep attemp + } - // Get the FACE we're going to sweep - FACE_ptr = FACEs_to_be_swept_list.get_and_step(); + // There were problems getting the FACE in the copied BODY, corresponding + // to the FACE being swept in the original BODY. We can't proceed with the + // sweep of this RefFace. + else + { + skip_loop = CUBIT_TRUE; + } // End of if branch if copied_FACE_ptr exists - // Get the associated Body and its ACIS BODY - body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY(FACE_ptr); - if (body_ptr != NULL) - { - BODY_ptr = AcisQueryEngine::get_BODY(body_ptr); + // As all went well (apparently :-), create a new Body using the new + // swept solid and get rid of the original Body and its associated + // ACIS BODY. + if( !skip_loop ) + { + BodySM* new_body_ptr = get_new_Body(body_ptr, BODY_ptr, + copy_of_original_BODY_ptr, + CUBIT_FALSE, CUBIT_FALSE); + if (new_body_ptr) + { + result_body_list.append(new_body_ptr); + sweep_status = CUBIT_SUCCESS; + } - // Make sure we have a valid ACIS BODY associated with this Body - // and FACE - if (BODY_ptr == NULL) - { - PRINT_ERROR("No valid volume associated with Surface.\n" ); - continue; - } - } + } // End of if branch if skip_loop != TRUE of final new_body_ptr construction + else + { + // Get rid of the copied body, if it exists + if( copy_of_original_BODY_ptr ) + { + AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copy_of_original_BODY_ptr); + AcisQueryEngine::instance()->delete_ACIS_BODY( copy_of_original_BODY_ptr); - else - { - // This can happen when a Surface entity is created at the SM level for temp use - // This function should only care about the ACIS BODY anyway - BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr); - if (BODY_ptr == NULL) - { - PRINT_ERROR("No valid volume associated with Surface\n" ); - continue; - } - } + copy_of_original_BODY_ptr = NULL; + } + } + } // End of if branch if skip_loop != TRUE for problems finding assoc. ACIS BODY + } // End of i loop, iterating over FACEs_to_be_swept_list + return sweep_status; + } - // Make a copy of the original BODY before doing the sweep. - // We will perform the sweep on the copy, not on the original body. - copied_BODY_ptr = this->copy_BODY(BODY_ptr, CUBIT_FALSE); + //------------------------------------------------------------------------- + // Purpose : Perform a face sweep operation along a curve + // + // Special Notes : In ACIS v4.2, I was unable to get it to sweep along + // multiple curves, so for now it gives an error message + // if this is attempted. + // + // The function will not allow you to sweep back into + // a solid. + // + // Creator : Steve Storm + // + // Creation Date : 8/7/98 + //------------------------------------------------------------------------- + CubitStatus AcisModifyEngine::sweep_along_curve( + DLIList<GeometryEntity*>& ref_ent_list, + DLIList<BodySM*>& result_body_list, + DLIList<Curve*>& ref_edge_list, + double draft_angle, + int draft_type, + bool rigid, + Surface* stop_surf, + BodySM* stop_body) const + { + outcome result; + DLIList<FACE*> FACEs_to_be_swept_list; + DLIList<EDGE*> EDGEs_to_be_swept_list; + DLIList<Surface*> ref_faces_list; + DLIList<Curve*> ref_edges_list; - if( copied_BODY_ptr == NULL ) - { - PRINT_ERROR( "Unable to copy volume before sweeping\n" ); - continue; - } + FACE * stop_FACE = NULL; + BODY * stop_BODY = NULL; + + if (stop_surf) + stop_FACE = AcisQueryEngine::get_FACE(stop_surf); - // Find the FACE in the copied BODY that corresponds to the FACE - // being swept in the original BODY. Note that when we made a copy - // of the original BODY, all the "parent" attributes were copied - // over to the new BODY. - copied_FACE_ptr = (FACE *) (AcisQueryEngine::instance()->get_ENTITY_of_entity( - copied_BODY_ptr, ref_face_ptr ) ); + if (stop_body) + { + BodyACIS* bodyACISPtr = CAST_TO(stop_body, BodyACIS) ; + assert(bodyACISPtr); + stop_BODY = bodyACISPtr->get_BODY_ptr() ; + } - if( copied_FACE_ptr == NULL ) - { - PRINT_ERROR( "Unable to find FACE to sweep in copied volume\n" ); - continue; - } + // First get the ACIS FACEs associated with the input RefFaces + // DLIList<FACE*> temp_faces; + int i; + for (i = ref_ent_list.size(); i > 0; i--) + { + GeometryEntity* ref_ent = ref_ent_list.get_and_step(); + Surface *ref_face = CAST_TO(ref_ent, Surface); + Curve* ref_edge = CAST_TO(ref_ent, Curve); + if(ref_face != NULL) + { + // SurfaceACIS::get_FACEs_of_RefFace( ref_face, temp_faces); + // if (temp_faces.size() > 1) { + // PRINT_ERROR("Surface %d cannot be swept as the number of ACIS FACEs associated \n" + // " with it is not 1.\n", + // ref_face->id()); + // return CUBIT_FAILURE; + // } + // if (temp_faces.size() > 0) + // FACEs_to_be_swept_list += temp_faces; + // temp_faces.clean_out(); + FACE* FACE_ptr = AcisQueryEngine::get_FACE(ref_face); + if (!FACE_ptr) + return CUBIT_FAILURE; + FACEs_to_be_swept_list.append(FACE_ptr); + ref_faces_list.append(ref_face); + } + else if (ref_edge != NULL) + { + //EDGEs_to_be_swept_list.append(CurveACIS::get_first_EDGE(ref_edge)); + EDGEs_to_be_swept_list.append(AcisQueryEngine::get_EDGE(ref_edge)); + ref_edges_list.append(ref_edge); + } - // Remove all the CUBIT_OWNER attributes from the copied BODY - // as we're going to sweep it. - if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_TRUE) - AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copied_BODY_ptr); + } - // Check to see if the start of the edge is in the profile of - // the face. If not, check the end - if this is, we'll need to - // reverse the WIRE body. - // - // When we support a chain of EDGES, here we will need to get the start - // and end vertices of the WIRE. This should be the only change needed. - //VERTEX* start_VERTEX_ptr;// copied_EDGE_ptr->start(); - //VERTEX* end_VERTEX_ptr;// copied_EDGE_ptr->end(); - //if( start_VERTEX_ptr == end_VERTEX_ptr ) - //{ - // PRINT_ERROR( "Edge start and end are the same - sweeping not possible\n" ); - // return CUBIT_FAILURE; - //} - ENTITY *ent = WIRE_ptr; + // Now sweep them along the EDGE. - SPAposition acis_start_coords; - get_wire_start_position(ent, acis_start_coords); - CubitVector start_vec( acis_start_coords.x(), acis_start_coords.y(), - acis_start_coords.z() ); + BODY* EDGE_BODY_ptr = NULL; - bool start_flg; - Curve* start_curve = find_curve_by_end_coord( start_vec, - ref_edge_list, start_flg ); - if( !start_curve ) - { - PRINT_ERROR( "unable to find start vertex of sweep chain; aborting\n" ); - delete []EDGES; - return CUBIT_FAILURE; - } - CubitVector start_position; - start_curve->position_from_fraction( start_flg ? 0.0 : 1.0, start_position); + FACEs_to_be_swept_list.reset(); + EDGEs_to_be_swept_list.reset(); + ref_edges_list.reset(); - SPAposition acis_end_coords; - get_wire_end_position(ent, acis_end_coords); - CubitVector end_vec( acis_end_coords.x(), acis_end_coords.y(), - acis_end_coords.z() ); + FACE* FACE_ptr = NULL; + FACE* copied_FACE_ptr = NULL; + Surface* ref_face_ptr = NULL; + BodySM* body_ptr = NULL; + BODY* BODY_ptr = NULL; + BODY* copied_BODY_ptr = NULL; - Curve* end_curve = find_curve_by_end_coord( end_vec, - ref_edge_list, start_flg ); - if( !end_curve ) - { - PRINT_ERROR( "unable to find end vertex of sweep chain; aborting\n" ); - delete []EDGES; - return CUBIT_FAILURE; - } - CubitVector end_position; - end_curve->position_from_fraction( start_flg ? 0.0 : 1.0, end_position ); + // Get the EDGE to sweep along. No need to copy it as it is going into + // a WIRE body (it's copied into the WIRE body). + // + Curve* ref_edge_ptr = NULL; - //SPAposition pos1, pos2; - double distance1, distance2; - SPAposition acis_closest_point; - (copied_FACE_ptr->geometry()->equation()).point_perp ( acis_start_coords, - acis_closest_point ); - CubitVector closest_point_start( acis_closest_point.x(), - acis_closest_point.y(), - acis_closest_point.z() ); - distance1 = closest_point_start.distance_between( start_vec ); + // Sweep the FACE along the chain of EDGES. + int num_edges = ref_edge_list.size(); + EDGE** EDGES = new EDGE*[num_edges]; + ref_edge_list.reset(); + for( int j=0; j<num_edges; j++ ) + { + ref_edge_ptr = ref_edge_list.get_and_step(); + //Curve* curve_ptr = ref_edge_ptr->get_curve_ptr(); + //CurveACIS *curve_ACIS = CAST_TO(curve_ptr, CurveACIS); + CurveACIS *curve_ACIS = CAST_TO(ref_edge_ptr, CurveACIS); + EDGE *EDGE_ptr = curve_ACIS->get_EDGE_ptr(); - //VERTEX* close_VERTEX_ptr = NULL; - CubitVector closest_position; - EDGE* start_EDGE_ptr = NULL; + if (!EDGE_ptr) + { + PRINT_ERROR("Unable to get ACIS EDGE from Curve\n" ); + delete [] EDGES; + return CUBIT_FAILURE; + } - if( distance1 > SPAresabs ) - { - // Try the other end - (copied_FACE_ptr->geometry()->equation()).point_perp ( acis_end_coords, - acis_closest_point ); - CubitVector closest_point_end( acis_closest_point.x(), acis_closest_point.y(), - acis_closest_point.z() ); - distance2 = closest_point_end.distance_between( end_vec ); + EDGE *copied_EDGE_ptr = NULL; + result = api_edge( EDGE_ptr, copied_EDGE_ptr ); + if (!result.ok() || copied_EDGE_ptr == NULL ) + { + AcisQueryEngine::instance()->ACIS_API_error (result); + PRINT_ERROR( "Unable to copy ACIS curve\n" ); + delete [] EDGES; + return CUBIT_FAILURE; + } + EDGES[j] = copied_EDGE_ptr; + } - if( distance2 > SPAresabs ) - { - PRINT_ERROR( "Neither chain end lies in the plane of surface\n" ); - continue; - } - else - { - //close_VERTEX_ptr = end_VERTEX_ptr; - closest_position = end_position; - start_curve = end_curve; - start_EDGE_ptr = EDGES[ref_edge_list.size()-1]; - } - - // Reverse the WIRE in the BODY - //api_reverse_body( EDGE_BODY_ptr ); - api_reverse_wire( WIRE_ptr ); - - } + // Make a WIRE body to sweep along. If we have to reverse the EDGE + // (since ACIS only allows you to sweep from start to end), the wire + // will be needed. + result = api_make_ewire( num_edges, EDGES, EDGE_BODY_ptr ); + WIRE* WIRE_ptr = NULL; + if (!result.ok()) + { + AcisQueryEngine::instance()->ACIS_API_error (result); + PRINT_ERROR( "Unable to make ACIS wire body from curve to sweep along\n" ); + } else - { - //close_VERTEX_ptr = start_VERTEX_ptr; - closest_position = start_position; - start_EDGE_ptr = EDGES[0]; - } + WIRE_ptr = EDGE_BODY_ptr->lump()->shell()->wire(); - SPAposition acis_closest_position; - SPAunit_vector acis_surface_normal; + CubitStatus sweep_status = CUBIT_FAILURE; + for (i = 0; i < FACEs_to_be_swept_list.size(); i++) + { + copied_FACE_ptr = NULL; - //APOINT* acis_point = close_VERTEX_ptr->geometry() ; - //SPAposition acis_curve_position = acis_point->coords() ; - SPAposition acis_curve_position( closest_position.x(), - closest_position.y(), closest_position.z() ); + // Get the RefFace we're going to sweep + ref_face_ptr = ref_faces_list.get_and_step(); - // Need to compute the FACE normal at the start of the sweep - (copied_FACE_ptr->geometry()->equation()).point_perp ( acis_curve_position, - acis_closest_position, acis_surface_normal ); + // Get the FACE we're going to sweep + FACE_ptr = FACEs_to_be_swept_list.get_and_step(); - CubitVector surface_normal( acis_surface_normal.x(), acis_surface_normal.y(), - acis_surface_normal.z() ); + // Get the associated Body and its ACIS BODY + body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY(FACE_ptr); + if (body_ptr != NULL) + { + BODY_ptr = AcisQueryEngine::get_BODY(body_ptr); - // Check to see if SENSE of FACE is REVERSED. The direction of the - // ACIS face is the direction of sweep. - if( copied_FACE_ptr->sense() == REVERSED ) - { - if( copied_FACE_ptr->geometry()->equation().left_handed_uv() == CUBIT_FALSE ) - surface_normal *= -1.0; - } - else - { - if( copied_FACE_ptr->geometry()->equation().left_handed_uv() ) - surface_normal *= -1.0; - } + // Make sure we have a valid ACIS BODY associated with this Body + // and FACE + if (BODY_ptr == NULL) + { + PRINT_ERROR("No valid volume associated with Surface.\n" ); + continue; + } + } - // Get curve tangent at start of the sweep - SPAunit_vector acis_curve_tangent; + else + { + // This can happen when a Surface entity is created at the SM level for temp use + // This function should only care about the ACIS BODY anyway + BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr); + if (BODY_ptr == NULL) + { + PRINT_ERROR("No valid volume associated with Surface\n" ); + continue; + } + } - (start_EDGE_ptr->geometry()->equation()).point_perp( acis_curve_position, - acis_closest_position, - acis_curve_tangent ); + // Make a copy of the original BODY before doing the sweep. + // We will perform the sweep on the copy, not on the original body. + copied_BODY_ptr = this->copy_BODY(BODY_ptr, CUBIT_FALSE); - CubitVector curve_tangent( acis_curve_tangent.x(), acis_curve_tangent.y(), - acis_curve_tangent.z() ); + if( copied_BODY_ptr == NULL ) + { + PRINT_ERROR( "Unable to copy volume before sweeping\n" ); + continue; + } - // Determine if the WIRE has been reversed - ??? there's a better way to - // do this but I don't know it. I would think you could just go by the - // underlying EDGE but apparently when the WIRE get's reversed, the EDGE - // doesn't change - the sweep uses the WIRE, not the EDGE. - if( closest_position == end_position ) - curve_tangent *= -1.0; + // Find the FACE in the copied BODY that corresponds to the FACE + // being swept in the original BODY. Note that when we made a copy + // of the original BODY, all the "parent" attributes were copied + // over to the new BODY. + copied_FACE_ptr = (FACE *) (AcisQueryEngine::instance()->get_ENTITY_of_entity( + copied_BODY_ptr, ref_face_ptr ) ); - // Make sure the sense is correct based on the underlying EDGE sense - if( start_EDGE_ptr->sense() == REVERSED ) - curve_tangent *= -1.0; + if( copied_FACE_ptr == NULL ) + { + PRINT_ERROR( "Unable to find FACE to sweep in copied volume\n" ); + continue; + } + // Remove all the CUBIT_OWNER attributes from the copied BODY + // as we're going to sweep it. + if (GeometryModifyTool::instance()->get_new_ids() == CUBIT_TRUE) + AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copied_BODY_ptr); - // Properties of dot product - // angle acute if dot product > 0 - // angle obtuse if dot product < 0 - // angle 90 deg if dot product = 0 + // Check to see if the start of the edge is in the profile of + // the face. If not, check the end - if this is, we'll need to + // reverse the WIRE body. + // + // When we support a chain of EDGES, here we will need to get the start + // and end vertices of the WIRE. This should be the only change needed. + //VERTEX* start_VERTEX_ptr;// copied_EDGE_ptr->start(); + //VERTEX* end_VERTEX_ptr;// copied_EDGE_ptr->end(); + //if( start_VERTEX_ptr == end_VERTEX_ptr ) + //{ + // PRINT_ERROR( "Edge start and end are the same - sweeping not possible\n" ); + // return CUBIT_FAILURE; + //} + ENTITY *ent = WIRE_ptr; - if( surface_normal%curve_tangent < 0 ) - { - if( FACE_ptr->sides() != DOUBLE_SIDED ) - { - PRINT_ERROR( "Attempting to sweep Surface back into the solid\n" - " Sweeping of Surface aborted\n" ); - api_delent(copied_FACE_ptr); - continue; - } - api_reverse_face( copied_FACE_ptr ); - } + SPAposition acis_start_coords; + get_wire_start_position(ent, acis_start_coords); + CubitVector start_vec( acis_start_coords.x(), acis_start_coords.y(), + acis_start_coords.z() ); - sweep_status = sweep_FACE_along_WIRE( copied_FACE_ptr, - EDGE_BODY_ptr, - draft_angle, - draft_type, - rigid); - if( sweep_status == CUBIT_FAILURE ) - { - // Get rid of the copied body, if it exists - if( copied_BODY_ptr ) - { - AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copied_BODY_ptr); - AcisQueryEngine::instance()->delete_ACIS_BODY( copied_BODY_ptr ); - copied_BODY_ptr = NULL; - continue; - } - } + bool start_flg; + Curve* start_curve = find_curve_by_end_coord( start_vec, + ref_edge_list, start_flg ); + if( !start_curve ) + { + PRINT_ERROR( "unable to find start vertex of sweep chain; aborting\n" ); + delete []EDGES; + return CUBIT_FAILURE; + } + CubitVector start_position; + start_curve->position_from_fraction( start_flg ? 0.0 : 1.0, start_position); - // Create a new Body using the new swept solid and delete the - // original Body and its associated ACIS BODY. - BodySM* new_body_ptr = 0; - if(body_ptr) - new_body_ptr = get_new_Body(body_ptr, BODY_ptr, copied_BODY_ptr, - CUBIT_FALSE, CUBIT_FALSE); - else // this handles the case of a NULL body sweep surface (typically the result of a SM only entity) - // in this case the caller must properly handle the sweep surface deletion - new_body_ptr = AcisQueryEngine::instance()->populate_topology_bridges(copied_BODY_ptr); + SPAposition acis_end_coords; + get_wire_end_position(ent, acis_end_coords); + CubitVector end_vec( acis_end_coords.x(), acis_end_coords.y(), + acis_end_coords.z() ); - if (new_body_ptr) - { - sweep_status = CUBIT_SUCCESS; - result_body_list.append(new_body_ptr); - } - } // End of i loop, iterating over FACEs_to_be_swept_list - //Now let's iterate over the EDGEs_to_be_swept_list - for (i = 0; i < EDGEs_to_be_swept_list.size(); i++) - { - EDGE *copied_EDGE_ptr = EDGEs_to_be_swept_list.get_and_step(); - BODY* new_BODY_ptr = NULL; + Curve* end_curve = find_curve_by_end_coord( end_vec, + ref_edge_list, start_flg ); + if( !end_curve ) + { + PRINT_ERROR( "unable to find end vertex of sweep chain; aborting\n" ); + delete []EDGES; + return CUBIT_FAILURE; + } + CubitVector end_position; + end_curve->position_from_fraction( start_flg ? 0.0 : 1.0, end_position ); - sweep_status = sweep_EDGE_along_WIRE( copied_EDGE_ptr, - EDGE_BODY_ptr, - new_BODY_ptr, - draft_angle, - draft_type, - rigid); - if( sweep_status == CUBIT_FAILURE ) - { - PRINT_ERROR("Problem sweeping curve.\n"); - continue; + //SPAposition pos1, pos2; + double distance1, distance2; + SPAposition acis_closest_point; + (copied_FACE_ptr->geometry()->equation()).point_perp ( acis_start_coords, + acis_closest_point ); + CubitVector closest_point_start( acis_closest_point.x(), + acis_closest_point.y(), + acis_closest_point.z() ); + distance1 = closest_point_start.distance_between( start_vec ); - } + //VERTEX* close_VERTEX_ptr = NULL; + CubitVector closest_position; + EDGE* start_EDGE_ptr = NULL; - // Create a new Body using the new swept solid + if( distance1 > SPAresabs ) + { + // Try the other end + (copied_FACE_ptr->geometry()->equation()).point_perp ( acis_end_coords, + acis_closest_point ); + CubitVector closest_point_end( acis_closest_point.x(), acis_closest_point.y(), + acis_closest_point.z() ); + distance2 = closest_point_end.distance_between( end_vec ); - BodySM* new_body_ptr = get_new_Body(body_ptr, BODY_ptr, new_BODY_ptr, - CUBIT_FALSE, CUBIT_FALSE); - if (new_body_ptr) - { - sweep_status = CUBIT_SUCCESS; - result_body_list.append(new_body_ptr); - } + if( distance2 > SPAresabs ) + { + PRINT_ERROR( "Neither chain end lies in the plane of surface\n" ); + continue; + } + else + { + //close_VERTEX_ptr = end_VERTEX_ptr; + closest_position = end_position; + start_curve = end_curve; + start_EDGE_ptr = EDGES[ref_edge_list.size()-1]; + } - } // End of i loop, iterating over FACEs_to_be_swept_list - delete []EDGES; + // Reverse the WIRE in the BODY + //api_reverse_body( EDGE_BODY_ptr ); + api_reverse_wire( WIRE_ptr ); - // Remove the created WIRE body - api_delent( EDGE_BODY_ptr ); + } + else + { + //close_VERTEX_ptr = start_VERTEX_ptr; + closest_position = start_position; + start_EDGE_ptr = EDGES[0]; + } + SPAposition acis_closest_position; + SPAunit_vector acis_surface_normal; - return sweep_status; -} + //APOINT* acis_point = close_VERTEX_ptr->geometry() ; + //SPAposition acis_curve_position = acis_point->coords() ; + SPAposition acis_curve_position( closest_position.x(), + closest_position.y(), closest_position.z() ); -CubitStatus AcisModifyEngine::webcut_with_cylinder( - DLIList<BodySM*> &webcut_body_list, - double radius, - const CubitVector &axis, - const CubitVector ¢er, - DLIList<BodySM*> &results_list, - bool imprint ) -{ - //create the cylinder body. - SPAbox super_box; - CubitStatus rv = AcisQueryEngine::instance()->create_super_acis_bounding_box( webcut_body_list, super_box ); - if (rv != CUBIT_SUCCESS) - return CUBIT_FAILURE; - double max_size = AcisQueryEngine::instance()->get_max_size_of_acis_box( super_box ); - //lets find the distance to the center for each body and take - //the max. - double curr; - CubitVector cent_bod; - BodySM *body_ptr; - for ( int ii = webcut_body_list.size(); ii > 0; ii-- ) - { - body_ptr = webcut_body_list.get_and_step(); - cent_bod = AcisQueryEngine::instance()->bounding_box(body_ptr).center(); - cent_bod = cent_bod - center; - curr = cent_bod.length(); - if ( curr > max_size ) - max_size = curr; - } - double height; - if ( center.x() > max_size ) - { - height = 500.0 * center.x(); - } - else if ( center.y() > max_size ) - { - height = 500.0 * center.y(); - } - else if ( center.z() > max_size ) - { - height = 500.0 * center.z(); - } - else - { - height = 500.0 * max_size; - } - //lets make certain we have a valid height.. - if ( height < GEOMETRY_RESABS ) - { - height = 500.0; - } + // Need to compute the FACE normal at the start of the sweep + (copied_FACE_ptr->geometry()->equation()).point_perp ( acis_curve_position, + acis_closest_position, acis_surface_normal ); - BODY* cutting_tool_ptr; + CubitVector surface_normal( acis_surface_normal.x(), acis_surface_normal.y(), + acis_surface_normal.z() ); + // Check to see if SENSE of FACE is REVERSED. The direction of the + // ACIS face is the direction of sweep. + if( copied_FACE_ptr->sense() == REVERSED ) + { + if( copied_FACE_ptr->geometry()->equation().left_handed_uv() == CUBIT_FALSE ) + surface_normal *= -1.0; + } + else + { + if( copied_FACE_ptr->geometry()->equation().left_handed_uv() ) + surface_normal *= -1.0; + } - outcome result = api_make_frustum( height, radius, radius, radius, cutting_tool_ptr ); - if ( !result.ok() || cutting_tool_ptr == NULL || - cutting_tool_ptr->lump() == NULL ) - { + // Get curve tangent at start of the sweep + SPAunit_vector acis_curve_tangent; - PRINT_ERROR("In AcisModifyEngine::webcut_with_cylinder\n" - " ACIS api_make_frustum function failed.\n\n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - return CUBIT_FAILURE; - } - // The current frustum is centered on the z axis. - CubitVector axis2(0., 0., 1.0 ); - //now find the normal to the current axis and axis we want to be - //at. This normal is where we will rotate about. - CubitVector normal_axis = axis2 * axis; - if ( normal_axis.length() > CUBIT_RESABS ) - { - //angle in degrees. - double angle = normal_axis.vector_angle( axis2, axis ); - SPAvector rotation_axis( normal_axis.x(), normal_axis.y(), - normal_axis.z() ); - SPAtransf transformation = rotate_transf( angle, rotation_axis ); + (start_EDGE_ptr->geometry()->equation()).point_perp( acis_curve_position, + acis_closest_position, + acis_curve_tangent ); - result = api_apply_transf( cutting_tool_ptr, transformation ); - if (!result.ok()) - { - AcisQueryEngine::instance()->ACIS_API_error ( result, "rotating body" ); - return CUBIT_FAILURE; - } - } + CubitVector curve_tangent( acis_curve_tangent.x(), acis_curve_tangent.y(), + acis_curve_tangent.z() ); - if ( center.length() > CUBIT_RESABS ) - { - //move the body to the center SPAposition. - SPAvector translation_vector( center.x(), center.y(), center.z() ); - SPAtransf transformation = translate_transf( translation_vector ); - result = api_apply_transf( cutting_tool_ptr, transformation ); - if (!result.ok()) - { - AcisQueryEngine::instance()->ACIS_API_error ( result, "transforming body" ); - return CUBIT_FAILURE; - } - } - //okay we should be ready now. + // Determine if the WIRE has been reversed - ??? there's a better way to + // do this but I don't know it. I would think you could just go by the + // underlying EDGE but apparently when the WIRE get's reversed, the EDGE + // doesn't change - the sweep uses the WIRE, not the EDGE. + if( closest_position == end_position ) + curve_tangent *= -1.0; - // Use the BODY to perform webcut - CubitStatus stat = - this->webcut(webcut_body_list, cutting_tool_ptr, results_list, imprint ) ; + // Make sure the sense is correct based on the underlying EDGE sense + if( start_EDGE_ptr->sense() == REVERSED ) + curve_tangent *= -1.0; - // Delete the BODY that was created to be used as a tool - AcisQueryEngine::instance()->delete_ACIS_BODY(cutting_tool_ptr, CUBIT_TRUE) ; - cutting_tool_ptr = NULL; - return stat; -} + // Properties of dot product + // angle acute if dot product > 0 + // angle obtuse if dot product < 0 + // angle 90 deg if dot product = 0 -CubitStatus -AcisModifyEngine::webcut_with_brick( DLIList<BodySM*>& webcut_body_list, - const CubitVector ¢er, - const CubitVector axes[3], - const CubitVector &extension, - DLIList<BodySM*> &results_list, - bool imprint ) -{ - // Create the brick to cut with - BODY *cutting_tool_ptr = make_brick_BODY( center, axes, extension ); - if( cutting_tool_ptr == NULL ) - return CUBIT_FAILURE; + if( surface_normal%curve_tangent < 0 ) + { + if( FACE_ptr->sides() != DOUBLE_SIDED ) + { + PRINT_ERROR( "Attempting to sweep Surface back into the solid\n" + " Sweeping of Surface aborted\n" ); + api_delent(copied_FACE_ptr); + continue; + } + api_reverse_face( copied_FACE_ptr ); + } - CubitStatus stat = - this->webcut(webcut_body_list, cutting_tool_ptr, results_list, imprint) ; + //copy stop_BODY + BODY* temp_BODY = NULL; + if (stop_BODY) + copy_BODY(stop_BODY); - // Delete the BODY that was created to be used as a tool - AcisQueryEngine::instance()->delete_ACIS_BODY(cutting_tool_ptr, CUBIT_TRUE) ; + sweep_status = sweep_FACE_along_WIRE( copied_FACE_ptr, + EDGE_BODY_ptr, + draft_angle, + draft_type, + rigid, + stop_FACE, + temp_BODY); + if( sweep_status == CUBIT_FAILURE ) + { + // Get rid of the copied body, if it exists + if( copied_BODY_ptr ) + { + AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copied_BODY_ptr); + AcisQueryEngine::instance()->delete_ACIS_BODY( copied_BODY_ptr ); + copied_BODY_ptr = NULL; + continue; + } + } - return stat; -} + // Create a new Body using the new swept solid and delete the + // original Body and its associated ACIS BODY. + BodySM* new_body_ptr = 0; + if(body_ptr) + new_body_ptr = get_new_Body(body_ptr, BODY_ptr, copied_BODY_ptr, + CUBIT_FALSE, CUBIT_FALSE); + else // this handles the case of a NULL body sweep surface (typically the result of a SM only entity) + // in this case the caller must properly handle the sweep surface deletion + new_body_ptr = AcisQueryEngine::instance()->populate_topology_bridges(copied_BODY_ptr); -CubitStatus -AcisModifyEngine::webcut_with_planar_sheet( DLIList<BodySM*>& webcut_body_list, - const CubitVector ¢er, - const CubitVector axes[2], - double width, - double height, - DLIList<BodySM*> &results_list, - bool imprint ) -{ - // Create the planar sheet to cut with - CubitVector p1, p2, p3, p4; + if (new_body_ptr) + { + sweep_status = CUBIT_SUCCESS; + result_body_list.append(new_body_ptr); + } + } // End of i loop, iterating over FACEs_to_be_swept_list + //Now let's iterate over the EDGEs_to_be_swept_list + for (i = 0; i < EDGEs_to_be_swept_list.size(); i++) + { + EDGE *copied_EDGE_ptr = EDGEs_to_be_swept_list.get_and_step(); + BODY* new_BODY_ptr = NULL; - // Get the corners of the sheet - center.next_point( axes[0], width/2.0, p1 ); - p1.next_point( axes[1], -height/2.0, p1 ); - p1.next_point( axes[1], height, p2 ); - p2.next_point( axes[0], -width, p3 ); - p3.next_point( axes[1], -height, p4 ); + sweep_status = sweep_EDGE_along_WIRE( copied_EDGE_ptr, + EDGE_BODY_ptr, + new_BODY_ptr, + draft_angle, + draft_type, + rigid, + stop_FACE); + if( sweep_status == CUBIT_FAILURE ) + { + PRINT_ERROR("Problem sweeping curve.\n"); + continue; - BODY* cutting_tool_ptr = make_planar_quad_BODY( p1, p2, p3, p4 ); - if( cutting_tool_ptr == NULL ) - return CUBIT_FAILURE; + } - BodySM *webcut_body; - DLIList<BodySM*> temp_new_bodies; - int num_cut = 0; - for ( int ii = webcut_body_list.size(); ii > 0; ii-- ) - { - webcut_body = webcut_body_list.remove(); - BODY *webcut_BODY = AcisQueryEngine::get_BODY(webcut_body ); - //now webcut with it. - BODY *new_BODY_1, *new_BODY_2; - CubitStatus status = webcut_with_sheet( webcut_BODY, - cutting_tool_ptr, - new_BODY_1, - new_BODY_2, - imprint ); - if ( status == CUBIT_SUCCESS ) - { - DLIList<BODY*> new_BODY_list; - new_BODY_list.append(new_BODY_1); - new_BODY_list.append(new_BODY_2); - temp_new_bodies.clean_out(); + // Create a new Body using the new swept solid - CubitStatus result = get_new_Body(webcut_body, webcut_BODY, - new_BODY_list, temp_new_bodies, CUBIT_FALSE); - if ( result != CUBIT_SUCCESS ) - { - PRINT_ERROR("Problems with building volume.\n"); - num_cut = 0; - return CUBIT_FAILURE; - } - else - { - results_list += temp_new_bodies; - num_cut++; - } - } - } + BodySM* new_body_ptr = get_new_Body(body_ptr, BODY_ptr, new_BODY_ptr, + CUBIT_FALSE, CUBIT_FALSE); + if (new_body_ptr) + { + sweep_status = CUBIT_SUCCESS; + result_body_list.append(new_body_ptr); + } - // Delete the BODY that was created to be used as a tool - AcisQueryEngine::instance()->delete_ACIS_BODY(cutting_tool_ptr, CUBIT_TRUE) ; + } // End of i loop, iterating over FACEs_to_be_swept_list + delete []EDGES; - // Return CUBIT_SUCCESS as long as one body is webcut, earlier failures should - // return CUBIT_FAILURE independently of these return statments - if (num_cut>0) - { - return CUBIT_SUCCESS; - } - else - { - return CUBIT_FAILURE; - } -} + // Remove the created WIRE body + api_delent( EDGE_BODY_ptr ); -//------------------------------------------------------------------------- -// Purpose : creates a sheet body with the given curve loop -// uses the new sheet body to cut the body list. -// -// Special Notes : -// -// Creator : Eric W. Nielsen -// -// Creation Date : 12/20/99 -//------------------------------------------------------------------------- -CubitStatus -AcisModifyEngine::webcut_with_curve_loop( DLIList<BodySM*> &webcut_body_list, - DLIList<Curve*> &refedge_list, - DLIList<BodySM*>& results_list, - bool imprint) -{ - Curve* ref_edge_ptr; - int edge_count = refedge_list.size() ; - EDGE** EDGEs = new EDGE* [edge_count] ; - EDGE* EDGE_ptr = NULL; - ENTITY_LIST acis_FACE_list ; - int i; + return sweep_status; + } - for( i=0; i<edge_count; i++ ) - { - ref_edge_ptr = refedge_list.get_and_step(); + //------------------------------------------------------------------------- + // Purpose : Sections the list of bodies (cuts in half). This is + // when trying to see a cross section of the model. + // + // Special Notes : Rewritten - J.Kraftcheck - 2004-4-5 + // + // Creator : David White + // + // Creation Date : 12/10/97 + //------------------------------------------------------------------------- + CubitStatus AcisModifyEngine::section( DLIList<BodySM*>& section_body_list, + const CubitVector &point_1, + const CubitVector &point_2, + const CubitVector &point_3, + DLIList<BodySM*>& new_body_list, + bool keep_normal_side, + bool keep_old, + bool keep_both_sides ) + { + int i; + bool delete_attribs = + (GeometryModifyTool::instance()->get_new_ids() || keep_old); - // Get the EDGE ptr from the RefEdge - EDGE_ptr = AcisQueryEngine::get_EDGE( ref_edge_ptr ); - if( EDGE_ptr == NULL ) - { - for( i=0; i<edge_count; i++ ) - api_delent( EDGEs[i] ); - delete [] EDGEs; - PRINT_ERROR( "Curve is not an ACIS curve\n" ); - acis_FACE_list.clear(); - return CUBIT_FAILURE; - } + if (keep_both_sides == CUBIT_TRUE ) + { + PRINT_ERROR("keeping both sides of section is not implemented."); + return CUBIT_FAILURE; + } - // copy each EDGE - outcome result = api_edge( EDGE_ptr, EDGEs[i] ); - if (!result.ok()) - { - for( i=0; i<edge_count; i++ ) - api_delent( EDGEs[i] ); - delete [] EDGEs; - PRINT_ERROR( "Unable to copy curve; aborting\n" ); - AcisQueryEngine::instance()->ACIS_API_error (result); - return CUBIT_FAILURE; - } + // Compute the super bounding SPAbox + SPAbox super_bounding_box; + CubitStatus rv = + AcisQueryEngine::instance()->create_super_acis_bounding_box (section_body_list, + super_bounding_box); + if (rv != CUBIT_SUCCESS) + return rv; - } + // Construct a BODY from the given CubitVectors and the size of + // the super bounding SPAbox. + BODY *cutting_tool_ptr; + cutting_tool_ptr = this->create_infinite_plane_cutting_tool( + point_1, + point_2, + point_3, + super_bounding_box ); + if (cutting_tool_ptr == NULL || cutting_tool_ptr->lump() == NULL ) + { + PRINT_ERROR("failed in sectioning volumes.\n"); + return CUBIT_FAILURE; + } - BODY* wire_BODY = NULL ; + // Copy BODYs + i = section_body_list.size(); + DLIList<BODY*> tool_BODY_list(i); + DLIList<BODY*> blank_BODY_list(i); + DLIList<BODY*> input_BODY_list(i); + section_body_list.reset(); + tool_BODY_list.append( cutting_tool_ptr ); + for (i = section_body_list.size(); i > 0; i-- ) + { + BodySM* body_sm = section_body_list.get_and_step(); - // make a wire Body - outcome result = api_make_ewire(edge_count, EDGEs, wire_BODY) ; - if ( !result.ok() || wire_BODY == NULL ) - { - PRINT_ERROR("In AcisModifyEngine::webcut_with_curve_loop\n" - " ACIS api_make_ewire function failed.\n\n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - for( i=0; i<edge_count; i++ ) - api_delent( EDGEs[i] ); - delete [] EDGEs; - acis_FACE_list.clear(); - return CUBIT_FAILURE; - } + BODY* input_BODY = AcisQueryEngine::get_BODY( body_sm ); + if (!input_BODY) continue; - delete [] EDGEs; + //also make sure that the cutting plane and blank body intersect + if ( !BODYs_interfering( input_BODY, cutting_tool_ptr) ) + { + TopologyEntity *topo_entity = body_sm->topology_entity(); + RefEntity *ref_entity = CAST_TO(topo_entity, RefEntity); + assert(ref_entity != 0); + PRINT_WARNING("Volume %d does not interect sectioning plane\n", ref_entity->id() ); + section_body_list.remove( body_sm ); + continue; + } - // Check to make sure the wire is closed - result = api_closed_wire( wire_BODY ); - if( !result.ok() ) - { - PRINT_ERROR( "ACIS reports that a closed loop was not found\n" ); - if( wire_BODY ) - api_delent( wire_BODY ); - acis_FACE_list.clear(); - return CUBIT_FAILURE; - } + input_BODY_list.append( input_BODY ); - // Cover the wire Body - outcome result_1 = api_cover_wires ( wire_BODY, - *(surface*)NULL_REF, - acis_FACE_list ); + BODY* blank_BODY = copy_BODY( input_BODY, delete_attribs ); + if (!blank_BODY) continue; + blank_BODY_list.append( blank_BODY ); - if ( !result_1.ok() || acis_FACE_list.count() == 0 || - wire_BODY == NULL ) - { - PRINT_ERROR("In AcisModifyEngine::webcut_with_curve_loop\n" - " ACIS api_cover_wires function failed.\n\n"); - AcisQueryEngine::instance()->ACIS_API_error (result_1); - acis_FACE_list.clear(); - if( wire_BODY ) - api_delent( wire_BODY ); - return CUBIT_FAILURE; - } + if (i < section_body_list.size()) // not first iteration + { + BODY* tool_BODY = copy_BODY( cutting_tool_ptr ); + if (tool_BODY) + tool_BODY_list.append( tool_BODY ); + } + } - if (acis_FACE_list.count() != 1) - { - PRINT_ERROR("ACIS api_cover_wires function created " - "more than one FACE.\n" - " At this time, we cannot deal with this.\n"); - acis_FACE_list.clear(); - if( wire_BODY ) - api_delent( wire_BODY ); - return CUBIT_FAILURE; - } + if( input_BODY_list.size() == 0 ) + { + PRINT_WARNING("No geometry interects sectioning plane\n"); + return CUBIT_FAILURE; + } - else - { - //make this a 2d body. - outcome result_2 = api_body_to_2d( wire_BODY ); - if ( !result_2.ok() ) - { - PRINT_ERROR("In AcisModifyEngine::webcut_with_curve_loop\n" - " ACIS api_body_to_2d function failed.\n\n"); - AcisQueryEngine::instance()->ACIS_API_error (result_2); - acis_FACE_list.clear(); - if( wire_BODY ) - api_delent( wire_BODY ); - return CUBIT_FAILURE; - } - FACE *FACE_ptr = (FACE*) acis_FACE_list.next(); - if ( FACE_ptr == NULL || FACE_ptr->geometry() == NULL ) - { - PRINT_ERROR("In AcisModifyEngine::webcut_with_curve_loop\n" - "FACE or FACE's geometry was NULL.\n"); - if( wire_BODY ) - api_delent( wire_BODY ); - acis_FACE_list.clear(); - return CUBIT_FAILURE; - } - } + // If there were any errors in the above loop, clean up and exit + if ( input_BODY_list.size() < section_body_list.size() || + blank_BODY_list.size() < section_body_list.size() || + tool_BODY_list.size() < section_body_list.size() ) + { + if (input_BODY_list.size() < section_body_list.size()) + PRINT_ERROR("Internal error: Invalid BodySM at %s:%d\n", __FILE__, __LINE__ ); + else + PRINT_ERROR("Internal error: BODY copy failed at %s:%d\n", __FILE__, __LINE__ ); + while (tool_BODY_list.size()) + api_delent( input_BODY_list.pop() ); + while (blank_BODY_list.size()) + api_delent( input_BODY_list.pop() ); + return CUBIT_FAILURE; + } - BodySM* webcut_body; - DLIList<BodySM*> temp_new_bodies; - int num_cut = 0; - for ( int ii = webcut_body_list.size(); ii > 0; ii-- ) - { - webcut_body = webcut_body_list.remove(); - BODY *webcut_BODY = AcisQueryEngine::get_BODY(webcut_body ); - //now webcut with it. - BODY *new_BODY_1, *new_BODY_2; - CubitStatus status = webcut_with_sheet( webcut_BODY, - wire_BODY, - new_BODY_1, - new_BODY_2, - imprint ); - if ( status == CUBIT_SUCCESS ) - { - DLIList<BODY*> new_BODY_list; - new_BODY_list.append(new_BODY_1); - new_BODY_list.append(new_BODY_2); - temp_new_bodies.clean_out(); - - CubitStatus cub_result = get_new_Body(webcut_body, webcut_BODY, - new_BODY_list, temp_new_bodies, - CUBIT_FALSE); - if ( cub_result != CUBIT_SUCCESS ) - { - PRINT_ERROR("Problems with building volume.\n"); - num_cut = 0; - if( wire_BODY ) - api_delent( wire_BODY ); - return CUBIT_FAILURE; - } + // Deterine which type of Boolean to use. + BOOL_TYPE bool_type; + CubitBoolean nonreg = !GeometryModifyTool::instance()->boolean_regularize(); + if (keep_normal_side && !nonreg) + bool_type = SUBTRACTION; + else if (keep_normal_side && nonreg) + bool_type = NONREG_SUBTRACTION; + else if (!keep_normal_side && !nonreg) + bool_type = INTERSECTION; else - { - results_list += temp_new_bodies; - num_cut++; - } - } - } + bool_type = NONREG_INTERSECTION; - if( wire_BODY ) - api_delent( wire_BODY ); - acis_FACE_list.clear(); + // Do Boolean for each blank body + input_BODY_list.reset(); + blank_BODY_list.reset(); + tool_BODY_list.reset(); + for ( i = input_BODY_list.size(); i--; ) + { + input_BODY_list.step(); + BODY* blank_BODY = blank_BODY_list.get_and_step(); + BODY* tool_BODY = tool_BODY_list.get_and_step(); + outcome result = api_boolean( tool_BODY, blank_BODY, bool_type ); + if (!result.ok()) + { + PRINT_ERROR("Volume section failed.\n"); + blank_BODY_list.back(); + BODY *blank = blank_BODY_list.remove(); + AcisBridge *tb_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(blank); + if( tb_ptr && keep_old == false ) + { + BodyACIS *body_acis = CAST_TO(tb_ptr, BodyACIS ); + if( body_acis ) + { + BodySM *body_sm = CAST_TO(body_acis, BodySM ); + TopologyEntity *topo_entity = body_sm->topology_entity(); + RefEntity *ref_entity = CAST_TO(topo_entity, RefEntity); + section_body_list.remove( body_sm ); + } + } - return CUBIT_SUCCESS; -} + api_delent( blank ); + tool_BODY_list.back(); + api_delent( tool_BODY_list.remove() ); + input_BODY_list.back(); + input_BODY_list.remove(); + } + } -//------------------------------------------------------------------------- -// Purpose : Sections the list of bodies (cuts in half). This is -// when trying to see a cross section of the model. -// -// Special Notes : Rewritten - J.Kraftcheck - 2004-4-5 -// -// Creator : David White -// -// Creation Date : 12/10/97 -//------------------------------------------------------------------------- -CubitStatus AcisModifyEngine::section( DLIList<BodySM*>& section_body_list, - const CubitVector &point_1, - const CubitVector &point_2, - const CubitVector &point_3, - DLIList<BodySM*>& new_body_list, - bool keep_normal_side, - bool keep_old, - bool keep_both_sides ) -{ - int i; - bool delete_attribs = - (GeometryModifyTool::instance()->get_new_ids() || keep_old); + if( input_BODY_list.size() == 0 ) + return CUBIT_FAILURE; - if (keep_both_sides == CUBIT_TRUE ) - { - PRINT_ERROR("keeping both sides of section is not implemented."); - return CUBIT_FAILURE; - } + // If a non-regularized operation, clean up internal surfaces + if (nonreg) + { + DLIList<FACE*> FACE_list; + input_BODY_list.reset(); + blank_BODY_list.reset(); - // Compute the super bounding SPAbox - SPAbox super_bounding_box; - CubitStatus rv = - AcisQueryEngine::instance()->create_super_acis_bounding_box (section_body_list, - super_bounding_box); - if (rv != CUBIT_SUCCESS) - return rv; + for (i = input_BODY_list.size(); i--; ) + { + input_BODY_list.step(); + BODY* blank_BODY = blank_BODY_list.get_and_step(); - // Construct a BODY from the given CubitVectors and the size of - // the super bounding SPAbox. - BODY *cutting_tool_ptr; - cutting_tool_ptr = this->create_infinite_plane_cutting_tool( - point_1, - point_2, - point_3, - super_bounding_box ); - if (cutting_tool_ptr == NULL || cutting_tool_ptr->lump() == NULL ) - { - PRINT_ERROR("failed in sectioning volumes.\n"); - return CUBIT_FAILURE; - } + FACE_list.clean_out(); + AcisQueryEngine::instance()->get_FACEs( blank_BODY, FACE_list ); - // Copy BODYs - i = section_body_list.size(); - DLIList<BODY*> tool_BODY_list(i); - DLIList<BODY*> blank_BODY_list(i); - DLIList<BODY*> input_BODY_list(i); - section_body_list.reset(); - tool_BODY_list.append( cutting_tool_ptr ); - for (i = section_body_list.size(); i > 0; i-- ) - { - BodySM* body_sm = section_body_list.get_and_step(); + FACE_list.reset(); + for (int j = FACE_list.size(); j--; ) + { + FACE* FACE_ptr = FACE_list.get_and_step(); + assert( FACE_ptr != NULL ); - BODY* input_BODY = AcisQueryEngine::get_BODY( body_sm ); - if (!input_BODY) continue; + if (FACE_ptr->sides() == DOUBLE_SIDED && + FACE_ptr->cont() == BOTH_INSIDE) + { + PRINT_INFO("Unhooking and deleting internal surface.\n"); + BODY* FACE_BODY_ptr; + outcome result = api_unhook_face( FACE_ptr, FACE_BODY_ptr ); + if (!result.ok()) + { + AcisModifyEngine::instance()->get_acis_query_engine()->ACIS_API_error( result ); + PRINT_ERROR( " Face unhooking during rebuild of volume didn't work\n" ); + } + else + { + api_delent( FACE_BODY_ptr ); + } + } + } + } + } - //also make sure that the cutting plane and blank body intersect - if ( !BODYs_interfering( input_BODY, cutting_tool_ptr) ) - { - TopologyEntity *topo_entity = body_sm->topology_entity(); - RefEntity *ref_entity = CAST_TO(topo_entity, RefEntity); - assert(ref_entity != 0); - PRINT_WARNING("Volume %d does not interect sectioning plane\n", ref_entity->id() ); - section_body_list.remove( body_sm ); - continue; + // Create/update AcisBridges + if( keep_old == true ) + { + int k; + for( k=blank_BODY_list.size(); k--; ) + { + BodySM *this_bodysm = AcisQueryEngine::instance()-> + populate_topology_bridges( blank_BODY_list.get_and_step() ); + new_body_list.append( this_bodysm ); + } + } + else + get_new_Body( section_body_list, + input_BODY_list, + blank_BODY_list, + new_body_list, + keep_old ); + + return CUBIT_SUCCESS; } - input_BODY_list.append( input_BODY ); - BODY* blank_BODY = copy_BODY( input_BODY, delete_attribs ); - if (!blank_BODY) continue; - blank_BODY_list.append( blank_BODY ); - - if (i < section_body_list.size()) // not first iteration + //------------------------------------------------------------------------- + // Purpose : webcuts a list of bodies using a plane. + // The newly created bodies are merged and imprinted + // depending on the respective flags. + // + // Special Notes : + // + // Creator : Malcolm J. Panthaki + // + // Creation Date : 12/17/96 + //------------------------------------------------------------------------- + CubitStatus AcisModifyEngine::webcut( DLIList<BodySM*>& webcut_body_list, + const CubitVector &vecVertex1, + const CubitVector &vecVertex2, + const CubitVector &vecVertex3, + DLIList<BodySM*>& results_list, + bool imprint ) const { - BODY* tool_BODY = copy_BODY( cutting_tool_ptr ); - if (tool_BODY) - tool_BODY_list.append( tool_BODY ); - } - } + //int webcut_debug_flag = 18; + //int webcut_debug_flag_on = DEBUG_FLAG(webcut_debug_flag); - if( input_BODY_list.size() == 0 ) - { - PRINT_WARNING("No geometry interects sectioning plane\n"); - return CUBIT_FAILURE; - } + BODY* cutting_tool_ptr = NULL; - // If there were any errors in the above loop, clean up and exit - if ( input_BODY_list.size() < section_body_list.size() || - blank_BODY_list.size() < section_body_list.size() || - tool_BODY_list.size() < section_body_list.size() ) - { - if (input_BODY_list.size() < section_body_list.size()) - PRINT_ERROR("Internal error: Invalid BodySM at %s:%d\n", __FILE__, __LINE__ ); - else - PRINT_ERROR("Internal error: BODY copy failed at %s:%d\n", __FILE__, __LINE__ ); - while (tool_BODY_list.size()) - api_delent( input_BODY_list.pop() ); - while (blank_BODY_list.size()) - api_delent( input_BODY_list.pop() ); - return CUBIT_FAILURE; - } + // To be able to create a Cutting Tool of the appropriate ("infinite") + // size, first generate the bounding SPAbox that surrounds all the BODYs + // being webcut. The procedure, GeometryModifyTool::create_infinite_plane_cutting + // _tool, will use the size of this "super" bounding SPAbox to determine an + // appropriate "infinite-enough" size for the Cutting Tool. - // Deterine which type of Boolean to use. - BOOL_TYPE bool_type; - CubitBoolean nonreg = !GeometryModifyTool::instance()->boolean_regularize(); - if (keep_normal_side && !nonreg) - bool_type = SUBTRACTION; - else if (keep_normal_side && nonreg) - bool_type = NONREG_SUBTRACTION; - else if (!keep_normal_side && !nonreg) - bool_type = INTERSECTION; - else - bool_type = NONREG_INTERSECTION; + // Compute the super bounding SPAbox + SPAbox super_bounding_box; + CubitStatus rv = + AcisQueryEngine::instance()->create_super_acis_bounding_box ( webcut_body_list, super_bounding_box ); + if (rv != CUBIT_SUCCESS) + return CUBIT_FAILURE; - // Do Boolean for each blank body - input_BODY_list.reset(); - blank_BODY_list.reset(); - tool_BODY_list.reset(); - for ( i = input_BODY_list.size(); i--; ) - { - input_BODY_list.step(); - BODY* blank_BODY = blank_BODY_list.get_and_step(); - BODY* tool_BODY = tool_BODY_list.get_and_step(); - outcome result = api_boolean( tool_BODY, blank_BODY, bool_type ); - if (!result.ok()) - { - PRINT_ERROR("Volume section failed.\n"); - blank_BODY_list.back(); - BODY *blank = blank_BODY_list.remove(); - AcisBridge *tb_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(blank); - if( tb_ptr && keep_old == false ) - { - BodyACIS *body_acis = CAST_TO(tb_ptr, BodyACIS ); - if( body_acis ) - { - BodySM *body_sm = CAST_TO(body_acis, BodySM ); - TopologyEntity *topo_entity = body_sm->topology_entity(); - RefEntity *ref_entity = CAST_TO(topo_entity, RefEntity); - section_body_list.remove( body_sm ); - } - } + // Construct a BODY from the given CubitVectors and the size of + // the super bounding SPAbox. + cutting_tool_ptr = this-> create_infinite_plane_cutting_tool( + vecVertex1, + vecVertex2, + vecVertex3, + super_bounding_box ); - api_delent( blank ); - tool_BODY_list.back(); - api_delent( tool_BODY_list.remove() ); - input_BODY_list.back(); - input_BODY_list.remove(); - } - } + if (cutting_tool_ptr == NULL) + { + //webcut_failed(refbody_cleanup_list, BODY_cleanup_list); + PRINT_ERROR("In AcisModifyEngine::webcut(,Vector,,,),%d" + " Cannot create infinite plane cutting tool using \n" + " the vectors. \n", __LINE__ ); + return CUBIT_FAILURE; + } - if( input_BODY_list.size() == 0 ) - return CUBIT_FAILURE; + else + { + // Use the BODY to perform webcut + CubitStatus stat = + this->webcut(webcut_body_list, cutting_tool_ptr, results_list, imprint) ; - // If a non-regularized operation, clean up internal surfaces - if (nonreg) - { - DLIList<FACE*> FACE_list; - input_BODY_list.reset(); - blank_BODY_list.reset(); + // Delete the BODY that was created to be used as a tool + AcisQueryEngine::instance()->delete_ACIS_BODY(cutting_tool_ptr, CUBIT_TRUE) ; + cutting_tool_ptr = NULL; - for (i = input_BODY_list.size(); i--; ) + return stat ; + } + } + + //------------------------------------------------------------------------- + // Purpose : webcuts a list of bodies using another Body as the tool. + // The newly created bodies are merged and imprinted + // depending on the respective flags. + // + // Special Notes : + // + // Creator : Jihong Ma + // + // Creation Date : 12/23/96 + //------------------------------------------------------------------------- + CubitStatus AcisModifyEngine::webcut( + DLIList<BodySM*>& webcut_body_list, + BodySM const* tool_body, + DLIList<BodySM*>& results_list, + bool imprint)const { - input_BODY_list.step(); - BODY* blank_BODY = blank_BODY_list.get_and_step(); + // check the tool body if it is made of AcisModifyEngine + if( !is_modify_engine(tool_body)) + { + PRINT_ERROR("In AcisModifyEngine::webcut() %d, \n" + " The tool volume is not made of AGE itself.\n", __LINE__); + return CUBIT_FAILURE; + } - FACE_list.clean_out(); - AcisQueryEngine::instance()->get_FACEs( blank_BODY, FACE_list ); - FACE_list.reset(); - for (int j = FACE_list.size(); j--; ) - { - FACE* FACE_ptr = FACE_list.get_and_step(); - assert( FACE_ptr != NULL ); + BODY* tool_BODY = NULL; - if (FACE_ptr->sides() == DOUBLE_SIDED && - FACE_ptr->cont() == BOTH_INSIDE) - { - PRINT_INFO("Unhooking and deleting internal surface.\n"); - BODY* FACE_BODY_ptr; - outcome result = api_unhook_face( FACE_ptr, FACE_BODY_ptr ); - if (!result.ok()) - { - AcisModifyEngine::instance()->get_acis_query_engine()->ACIS_API_error( result ); - PRINT_ERROR( " Face unhooking during rebuild of volume didn't work\n" ); - } - else - { - api_delent( FACE_BODY_ptr ); - } - } - } + //get the ACIS BODY of tool_body + tool_BODY = AcisQueryEngine::get_BODY( const_cast<BodySM*>(tool_body) ); + if( tool_BODY == NULL ) + { + PRINT_ERROR("In AcisModifyEngine::webcut() %d, \n" + " There is no underlying tool volume.\n",__LINE__); + return CUBIT_FAILURE; + } + + return this->webcut( webcut_body_list, tool_BODY, results_list, imprint); } - } - // Create/update AcisBridges - if( keep_old == true ) - { - int k; - for( k=blank_BODY_list.size(); k--; ) + //------------------------------------------------------------------------- + // Purpose : webcuts a list of bodies using another Body as the tool. + // The newly created bodies are merged and imprinted + // depending on the respective flags. + // Special Notes : + // + // Creator : Jihong Ma + // + // Creation Date : 12/17/96 + //------------------------------------------------------------------------- + CubitStatus AcisModifyEngine::webcut( + DLIList<BodySM*>& webcut_body_list, + BODY* tool_BODY, + DLIList<BodySM*>& results_list, + bool imprint) const { - BodySM *this_bodysm = AcisQueryEngine::instance()-> - populate_topology_bridges( blank_BODY_list.get_and_step() ); - new_body_list.append( this_bodysm ); - } - } - else - get_new_Body( section_body_list, - input_BODY_list, - blank_BODY_list, - new_body_list, - keep_old ); + CubitBoolean delete_bodies = (GeometryModifyTool::instance()->get_new_ids() ? + CUBIT_FALSE : CUBIT_TRUE); - return CUBIT_SUCCESS; -} + // Number of bodies that were webcut + int count = 0 ; + bool cutting_with_sheet = BodyACIS::is_sheet_body(tool_BODY); + BodySM* Body_to_be_webcut = NULL; + BODY* BODY_to_be_webcut = NULL; -//------------------------------------------------------------------------- -// Purpose : webcuts a list of bodies using a plane. -// The newly created bodies are merged and imprinted -// depending on the respective flags. -// -// Special Notes : -// -// Creator : Malcolm J. Panthaki -// -// Creation Date : 12/17/96 -//------------------------------------------------------------------------- -CubitStatus AcisModifyEngine::webcut( DLIList<BodySM*>& webcut_body_list, - const CubitVector &vecVertex1, - const CubitVector &vecVertex2, - const CubitVector &vecVertex3, - DLIList<BodySM*>& results_list, - bool imprint ) const -{ - //int webcut_debug_flag = 18; - //int webcut_debug_flag_on = DEBUG_FLAG(webcut_debug_flag); + // List to maintain thew newly created BODYs + DLIList<BODY*> new_webcut_BODY_list; - BODY* cutting_tool_ptr = NULL; + // List of old bodies that did get webcut + DLIList<BodySM*> old_body_list; + DLIList<BODY*> old_BODY_list; - // To be able to create a Cutting Tool of the appropriate ("infinite") - // size, first generate the bounding SPAbox that surrounds all the BODYs - // being webcut. The procedure, GeometryModifyTool::create_infinite_plane_cutting - // _tool, will use the size of this "super" bounding SPAbox to determine an - // appropriate "infinite-enough" size for the Cutting Tool. + // Variables to get the results of webcut from another routine. + BODY* BODY_result1 = NULL; + BODY* BODY_result2 = NULL; - // Compute the super bounding SPAbox - SPAbox super_bounding_box; - CubitStatus rv = - AcisQueryEngine::instance()->create_super_acis_bounding_box ( webcut_body_list, super_bounding_box ); - if (rv != CUBIT_SUCCESS) - return CUBIT_FAILURE; + // For each Body in the input list, make sure that it is associated + // with AGE before the webcutting is done. + CubitStatus status = CUBIT_FAILURE; + webcut_body_list.reset() ; + int i; - // Construct a BODY from the given CubitVectors and the size of - // the super bounding SPAbox. - cutting_tool_ptr = this-> create_infinite_plane_cutting_tool( - vecVertex1, - vecVertex2, - vecVertex3, - super_bounding_box ); + // step 1: bodies taken from webcut_body_list and webcut; if + // successful, the old Body and BODY are put on old_Body(BODY)_list + // and pieces put on new_webcut_BODY_list + // => 2 important lists: + // a) new_webcut_BODY_list (new pieces from bodies in old_...) + // b) results_list - bodies that weren't cut by the tool + for( i = 0 ; i < webcut_body_list.size() ; i++) + { + Body_to_be_webcut = webcut_body_list.get_and_step(); + if( !is_modify_engine(Body_to_be_webcut)) + { + PRINT_ERROR("In AcisModifyEngine::webcut(), \n" + " Volumes are associated with a different \n" + " geometric modeling engine.\n" ); + } - if (cutting_tool_ptr == NULL) - { - //webcut_failed(refbody_cleanup_list, BODY_cleanup_list); - PRINT_ERROR("In AcisModifyEngine::webcut(,Vector,,,),%d" - " Cannot create infinite plane cutting tool using \n" - " the vectors. \n", __LINE__ ); - return CUBIT_FAILURE; - } + //otherwise, get the BODY of the Body_to_be_webcut + BODY_to_be_webcut = AcisQueryEngine::get_BODY( Body_to_be_webcut ); + if( BODY_to_be_webcut == NULL ) + { + PRINT_ERROR("In AcisModifyEngine::webcut() %d, \n" + " There is no underlying volume.\n", + __LINE__); + assert(BODY_to_be_webcut != NULL) ; + } - else - { - // Use the BODY to perform webcut - CubitStatus stat = - this->webcut(webcut_body_list, cutting_tool_ptr, results_list, imprint) ; + //now can do a webcut, using a BODY tool, resulting two BODYs + status = webcut_BODY( BODY_to_be_webcut, tool_BODY, + BODY_result1, BODY_result2, + cutting_with_sheet); - // Delete the BODY that was created to be used as a tool - AcisQueryEngine::instance()->delete_ACIS_BODY(cutting_tool_ptr, CUBIT_TRUE) ; - cutting_tool_ptr = NULL; + if (status == CUBIT_SUCCESS ) + { + // Add the 2 new BODYs to the list of webcut BODYs + new_webcut_BODY_list.append(BODY_result1); + new_webcut_BODY_list.append(BODY_result2); + old_body_list.append(Body_to_be_webcut); + old_BODY_list.append(BODY_to_be_webcut); - return stat ; - } -} + // Since we have successfully webcut this BODY, delete it. + // Delete the corresponding Body too. (only do this if we're not + // using persistent objects) -//------------------------------------------------------------------------- -// Purpose : webcuts a list of bodies using another Body as the tool. -// The newly created bodies are merged and imprinted -// depending on the respective flags. -// -// Special Notes : -// -// Creator : Jihong Ma -// -// Creation Date : 12/23/96 -//------------------------------------------------------------------------- -CubitStatus AcisModifyEngine::webcut( DLIList<BodySM*>& webcut_body_list, - BodySM const* tool_body, - DLIList<BodySM*>& results_list, - bool imprint ) const -{ - // check the tool body if it is made of AcisModifyEngine - if( !is_modify_engine(tool_body)) - { - PRINT_ERROR("In AcisModifyEngine::webcut() %d, \n" - " The tool volume is not made of AGE itself.\n", __LINE__); - return CUBIT_FAILURE; - } + if (delete_bodies == CUBIT_FALSE) { + AcisQueryEngine::instance()->delete_ACIS_BODY(BODY_to_be_webcut) ; + //AcisQueryEngine::instance()->delete_solid_model_entities(Body_to_be_webcut); + } + // Increment the counter + count++ ; + } - BODY* tool_BODY = NULL; + else + { + //Since the body wasn't cut, it is a result... + results_list.append_unique( Body_to_be_webcut ); + } + } - //get the ACIS BODY of tool_body - tool_BODY = AcisQueryEngine::get_BODY( const_cast<BodySM*>(tool_body) ); - if( tool_BODY == NULL ) - { - PRINT_ERROR("In AcisModifyEngine::webcut() %d, \n" - " There is no underlying tool volume.\n",__LINE__); - return CUBIT_FAILURE; - } + // A list to hold the newly created Bodies due to imprint operations + // on the remaining Bodys in the Model. The new Bodys replace the old + // Bodys if any of the new BODYs created by webcutting imprint + // on the old Bodys. + DLIList<BodySM*> new_webcut_body_list; - return this->webcut( webcut_body_list, tool_BODY, results_list, imprint ); -} + DLIList<BODY*> just_webcut_list; + // A list to get the BODY's created that were webcut from the imprint + // operation. -//------------------------------------------------------------------------- -// Purpose : webcuts a list of bodies using another Body as the tool. -// The newly created bodies are merged and imprinted -// depending on the respective flags. -// Special Notes : -// -// Creator : Jihong Ma -// -// Creation Date : 12/17/96 -//------------------------------------------------------------------------- -CubitStatus AcisModifyEngine::webcut( DLIList<BodySM*>& webcut_body_list, - BODY* tool_BODY, - DLIList<BodySM*>& results_list, - bool imprint ) const -{ - CubitBoolean delete_bodies = (GeometryModifyTool::instance()->get_new_ids() ? - CUBIT_FALSE : CUBIT_TRUE); - // Number of bodies that were webcut - int count = 0 ; + // Perform the imprinting operations, if required. Note that this + // operation needs to be performed *after* the model has been cleared of + // Bodies that were already webcut. Also, note that it returns a list + // of all the new Bodies created during the imprint operation. This + // list is then enhanced by adding any new Bodies created due to the + // actual cutting of an old Body, before it is sent into the webcut_merge + // procedure. This is the list of Bodies that is "merged". + if (new_webcut_BODY_list.size() > 0) + { + DLIList<BODY*> old_model_BODY_list; + DLIList<BodySM*> old_model_Body_list; - BodySM* Body_to_be_webcut = NULL; - BODY* BODY_to_be_webcut = NULL; + if ( imprint == CUBIT_TRUE ) + { + // Work-in-progress message + PRINT_INFO (" Performing the imprint operations...\n"); - // List to maintain thew newly created BODYs - DLIList<BODY*> new_webcut_BODY_list; + // Imprint away :) + webcut_imprint(tool_BODY, old_body_list, new_webcut_BODY_list, + just_webcut_list, results_list, + old_model_Body_list, old_model_BODY_list) ; + } + if ( just_webcut_list.size() == 0 ) + just_webcut_list = new_webcut_BODY_list; - // List of old bodies that did get webcut - DLIList<BodySM*> old_body_list; - DLIList<BODY*> old_BODY_list; + // Work-in-progress message + PRINT_INFO (" Creating the new (webcut) volumes...\n"); - // Variables to get the results of webcut from another routine. - BODY* BODY_result1 = NULL; - BODY* BODY_result2 = NULL; + // Now create the new Bodies from the ACIS BODYs that were created + // by webcutting the original BODYs using the Cutting Tool. + BodySM* new_body_ptr = NULL; + BODY* webcut_BODY_ptr = NULL; + new_webcut_BODY_list.reset(); + old_body_list.reset(); + old_BODY_list.reset(); + old_model_Body_list.reset(); + old_model_BODY_list.reset(); - // For each Body in the input list, make sure that it is associated - // with AGE before the webcutting is done. - CubitStatus status = CUBIT_FAILURE; - webcut_body_list.reset() ; - int i; + for ( i = 0 ; i < new_webcut_BODY_list.size(); i++ ) + { + DLIList<BODY*> temp_BODY_list; + DLIList<BodySM*> temp_body_list; + BodySM *old_Body; + BODY *old_BODY; - // step 1: bodies taken from webcut_body_list and webcut; if - // successful, the old Body and BODY are put on old_Body(BODY)_list - // and pieces put on new_webcut_BODY_list - // => 2 important lists: - // a) new_webcut_BODY_list (new pieces from bodies in old_...) - // b) results_list - bodies that weren't cut by the tool - for( i = 0 ; i < webcut_body_list.size() ; i++) - { - Body_to_be_webcut = webcut_body_list.get_and_step(); - if( !is_modify_engine(Body_to_be_webcut)) - { - PRINT_ERROR("In AcisModifyEngine::webcut(), \n" - " Volumes are associated with a different \n" - " geometric modeling engine.\n" ); - } + webcut_BODY_ptr = new_webcut_BODY_list.get_and_step(); + temp_BODY_list.append(webcut_BODY_ptr); + // in call to get_new_Body, don't delete old bodies if + // they were successfully webcut (need to do it that way to + // preserve name propagation as before); otherwise, delete the + // imprinted bodies + if (imprint == CUBIT_FALSE || just_webcut_list.move_to(webcut_BODY_ptr)) { + webcut_BODY_ptr = new_webcut_BODY_list.get_and_step(); + temp_BODY_list.append(webcut_BODY_ptr); + i++; + old_Body = old_body_list.get_and_step(); + old_BODY = old_BODY_list.get_and_step(); + status = get_new_Body( old_Body, old_BODY, temp_BODY_list, temp_body_list, + false, delete_bodies ); + } + else { + old_Body = old_model_Body_list.get_and_step(); + old_BODY = old_model_BODY_list.get_and_step(); + BodySM* new_Body = get_new_Body( old_Body, old_BODY, webcut_BODY_ptr, + false, true, true ); + status = CUBIT_SUCCESS; + if (new_Body) + temp_body_list.append(new_Body); + } - //otherwise, get the BODY of the Body_to_be_webcut - BODY_to_be_webcut = AcisQueryEngine::get_BODY( Body_to_be_webcut ); - if( BODY_to_be_webcut == NULL ) - { - PRINT_ERROR("In AcisModifyEngine::webcut() %d, \n" - " There is no underlying volume.\n", - __LINE__); - assert(BODY_to_be_webcut != NULL) ; - } + if (status == CUBIT_FAILURE) { + PRINT_ERROR("Failed to build new volume in AGE::webcut.\n"); + } - //now can do a webcut, using a BODY tool, resulting two BODYs - status = webcut_BODY( BODY_to_be_webcut, tool_BODY, - BODY_result1, BODY_result2); + // if we didn't get any new bodies back from get_new_Body, + // that means that an imprinted body wasn't really imprinted + if (temp_body_list.size() > 0) { + temp_BODY_list.reset(); + temp_body_list.reset(); + for (int j = 0; j < temp_BODY_list.size(); j++) { + webcut_BODY_ptr = temp_BODY_list.get_and_step(); + new_body_ptr = temp_body_list.get_and_step(); - if (status == CUBIT_SUCCESS ) - { - // Add the 2 new BODYs to the list of webcut BODYs - new_webcut_BODY_list.append(BODY_result1); - new_webcut_BODY_list.append(BODY_result2); - old_body_list.append(Body_to_be_webcut); - old_BODY_list.append(BODY_to_be_webcut); + new_webcut_body_list.append(new_body_ptr); + results_list.append_unique(new_body_ptr); + } + } + else + new_webcut_body_list.append(old_Body); - // Since we have successfully webcut this BODY, delete it. - // Delete the corresponding Body too. (only do this if we're not - // using persistent objects) - - if (delete_bodies == CUBIT_FALSE) { - AcisQueryEngine::instance()->delete_ACIS_BODY(BODY_to_be_webcut) ; - //AcisQueryEngine::instance()->delete_solid_model_entities(Body_to_be_webcut); - } - - // Increment the counter - count++ ; - } - + } + } + // Return CUBIT_SUCCESS as long as one body is webcut, earlier failures should + // return CUBIT_FAILURE independently of these return statments + if (count>0) + { + return CUBIT_SUCCESS; + } else - { - //Since the body wasn't cut, it is a result... - results_list.append_unique( Body_to_be_webcut ); - } - } + { + return CUBIT_FAILURE; + } + } - // A list to hold the newly created Bodies due to imprint operations - // on the remaining Bodys in the Model. The new Bodys replace the old - // Bodys if any of the new BODYs created by webcutting imprint - // on the old Bodys. - DLIList<BodySM*> new_webcut_body_list; - DLIList<BODY*> just_webcut_list; - // A list to get the BODY's created that were webcut from the imprint - // operation. + //------------------------------------------------------------------------- + // Purpose : This function creates a Point, given coordinates. The + // particular type of Point object that is created depends on + // the specific GeometryQueryEngine. For example, this + // engine, AcisModifyEngine, creates a PointACIS and + // returns it. + // + // Special Notes : + // In this routine, a floating ACIS VERTEX is created. This VERTEX + // is not a part of any BODY and, hence, does not take part in + // any boolean operations. + // + // Creator : Malcolm J. Panthaki + // + // Creation Date : 03/05/97 + //------------------------------------------------------------------------- + Point* AcisModifyEngine::make_Point(CubitVector const& point) const + { + // Create a new ACIS VERTEX -- it is not attached to a BODY + VERTEX* VERTEX_ptr = this->make_VERTEX( point ); + if ( VERTEX_ptr == NULL ) + { + PRINT_ERROR("In AcisModifyEngine::make_Point\n" + " Cannot make Point object.\n"); + return (Point *)NULL; + } + // Create a new PointACIS object + return AcisQueryEngine::instance()->populate_topology_bridges( VERTEX_ptr ); - // Perform the imprinting operations, if required. Note that this - // operation needs to be performed *after* the model has been cleared of - // Bodies that were already webcut. Also, note that it returns a list - // of all the new Bodies created during the imprint operation. This - // list is then enhanced by adding any new Bodies created due to the - // actual cutting of an old Body, before it is sent into the webcut_merge - // procedure. This is the list of Bodies that is "merged". - if (new_webcut_BODY_list.size() > 0) - { - DLIList<BODY*> old_model_BODY_list; - DLIList<BodySM*> old_model_Body_list; + } - if ( imprint == CUBIT_TRUE ) - { - // Work-in-progress message - PRINT_INFO (" Performing the imprint operations...\n"); - // Imprint away :) - webcut_imprint(tool_BODY, old_body_list, new_webcut_BODY_list, - just_webcut_list, results_list, - old_model_Body_list, old_model_BODY_list) ; - } - if ( just_webcut_list.size() == 0 ) - just_webcut_list = new_webcut_BODY_list; - // Work-in-progress message - PRINT_INFO (" Creating the new (webcut) volumes...\n"); + // This function creates a curve given an existing curve. + Curve* AcisModifyEngine::make_Curve(Curve *curve_ptr) const + { + EDGE *EDGE_ptr, *new_EDGE_ptr = NULL; + CurveACIS *curve_ACIS = CAST_TO(curve_ptr, CurveACIS); + if (!curve_ACIS) + { + PRINT_ERROR("Cannot create an ACIS curve from the given curve.\n" + "Possible incompatible geometry engines.\n"); + return (Curve *)NULL; + } + EDGE_ptr = curve_ACIS->get_EDGE_ptr(); - // Now create the new Bodies from the ACIS BODYs that were created - // by webcutting the original BODYs using the Cutting Tool. - BodySM* new_body_ptr = NULL; - BODY* webcut_BODY_ptr = NULL; - new_webcut_BODY_list.reset(); - old_body_list.reset(); - old_BODY_list.reset(); - old_model_Body_list.reset(); - old_model_BODY_list.reset(); + outcome result = api_edge( EDGE_ptr, new_EDGE_ptr ); - for ( i = 0 ; i < new_webcut_BODY_list.size(); i++ ) - { - DLIList<BODY*> temp_BODY_list; - DLIList<BodySM*> temp_body_list; - BodySM *old_Body; - BODY *old_BODY; + if ( !result.ok() || new_EDGE_ptr == NULL ) + { + PRINT_ERROR("In AcisModifyEngine::make_Curve\n" + " Cannot make Curve object.\n"); + return (Curve *)NULL; + } - webcut_BODY_ptr = new_webcut_BODY_list.get_and_step(); - temp_BODY_list.append(webcut_BODY_ptr); - // in call to get_new_Body, don't delete old bodies if - // they were successfully webcut (need to do it that way to - // preserve name propagation as before); otherwise, delete the - // imprinted bodies - if (imprint == CUBIT_FALSE || just_webcut_list.move_to(webcut_BODY_ptr)) { - webcut_BODY_ptr = new_webcut_BODY_list.get_and_step(); - temp_BODY_list.append(webcut_BODY_ptr); - i++; - old_Body = old_body_list.get_and_step(); - old_BODY = old_BODY_list.get_and_step(); - status = get_new_Body( old_Body, old_BODY, temp_BODY_list, temp_body_list, - false, delete_bodies ); - } - else { - old_Body = old_model_Body_list.get_and_step(); - old_BODY = old_model_BODY_list.get_and_step(); - BodySM* new_Body = get_new_Body( old_Body, old_BODY, webcut_BODY_ptr, - false, true, true ); - status = CUBIT_SUCCESS; - if (new_Body) - temp_body_list.append(new_Body); - } + // Create a new CurveACIS object + // Use the new EDGE to create a new CurveACIS + return AcisQueryEngine::instance()->populate_topology_bridges(new_EDGE_ptr); + } - if (status == CUBIT_FAILURE) { - PRINT_ERROR("Failed to build new volume in AGE::webcut.\n"); - } + //------------------------------------------------------------------------- + // Purpose : This function creates a Curve of type, curve_type, + // given the end points of the curve and an intermediate + // point. The particular type of Curve object that is + // created depends on the specific modeling engine. For + // example, if the engine is AcisModifyEngine, then a + // CurveACIS is created and returned. + // + // Special Notes : + // + // Creator : Raikanta Sahu + // + // Creation Date : 03/29/97 + //------------------------------------------------------------------------- - // if we didn't get any new bodies back from get_new_Body, - // that means that an imprinted body wasn't really imprinted - if (temp_body_list.size() > 0) { - temp_BODY_list.reset(); - temp_body_list.reset(); - for (int j = 0; j < temp_BODY_list.size(); j++) { - webcut_BODY_ptr = temp_BODY_list.get_and_step(); - new_body_ptr = temp_body_list.get_and_step(); - - new_webcut_body_list.append(new_body_ptr); - results_list.append_unique(new_body_ptr); - } - } - else - new_webcut_body_list.append(old_Body); - - } - } - // Return CUBIT_SUCCESS as long as one body is webcut, earlier failures should - // return CUBIT_FAILURE independently of these return statments - if (count>0) - { - return CUBIT_SUCCESS; - } - else - { - return CUBIT_FAILURE; - } -} - - -//------------------------------------------------------------------------- -// Purpose : This function creates a Point, given coordinates. The -// particular type of Point object that is created depends on -// the specific GeometryQueryEngine. For example, this -// engine, AcisModifyEngine, creates a PointACIS and -// returns it. -// -// Special Notes : -// In this routine, a floating ACIS VERTEX is created. This VERTEX -// is not a part of any BODY and, hence, does not take part in -// any boolean operations. -// -// Creator : Malcolm J. Panthaki -// -// Creation Date : 03/05/97 -//------------------------------------------------------------------------- -Point* AcisModifyEngine::make_Point(CubitVector const& point) const -{ - // Create a new ACIS VERTEX -- it is not attached to a BODY - VERTEX* VERTEX_ptr = this->make_VERTEX( point ); - if ( VERTEX_ptr == NULL ) - { - PRINT_ERROR("In AcisModifyEngine::make_Point\n" - " Cannot make Point object.\n"); - return (Point *)NULL; - } - - // Create a new PointACIS object - return AcisQueryEngine::instance()->populate_topology_bridges( VERTEX_ptr ); - -} - - - -// This function creates a curve given an existing curve. -Curve* AcisModifyEngine::make_Curve(Curve *curve_ptr) const -{ - EDGE *EDGE_ptr, *new_EDGE_ptr = NULL; - CurveACIS *curve_ACIS = CAST_TO(curve_ptr, CurveACIS); - if (!curve_ACIS) - { - PRINT_ERROR("Cannot create an ACIS curve from the given curve.\n" - "Possible incompatible geometry engines.\n"); - return (Curve *)NULL; - } - EDGE_ptr = curve_ACIS->get_EDGE_ptr(); - - outcome result = api_edge( EDGE_ptr, new_EDGE_ptr ); - - if ( !result.ok() || new_EDGE_ptr == NULL ) - { - PRINT_ERROR("In AcisModifyEngine::make_Curve\n" - " Cannot make Curve object.\n"); - return (Curve *)NULL; - } - - // Create a new CurveACIS object - // Use the new EDGE to create a new CurveACIS - return AcisQueryEngine::instance()->populate_topology_bridges(new_EDGE_ptr); -} - -//------------------------------------------------------------------------- -// Purpose : This function creates a Curve of type, curve_type, -// given the end points of the curve and an intermediate -// point. The particular type of Curve object that is -// created depends on the specific modeling engine. For -// example, if the engine is AcisModifyEngine, then a -// CurveACIS is created and returned. -// -// Special Notes : -// -// Creator : Raikanta Sahu -// -// Creation Date : 03/29/97 -//------------------------------------------------------------------------- - -Curve* AcisModifyEngine::make_Curve( GeometryType curve_type, + Curve* AcisModifyEngine::make_Curve( GeometryType curve_type, Point const* point1_ptr, Point const* point2_ptr, CubitVector const* intermediate_point_ptr, CubitSense sense) const -{ - // Extract the VERTEXes from the Points and construct a SPAposition - // from the cubit SPAvector. + { + // Extract the VERTEXes from the Points and construct a SPAposition + // from the cubit SPAvector. - // Cast the Points to PointACIS - PointACIS* pointACIS_ptr1 = CAST_TO(const_cast<Point*>(point1_ptr), PointACIS) ; - PointACIS* pointACIS_ptr2 = CAST_TO(const_cast<Point*>(point2_ptr), PointACIS) ; + // Cast the Points to PointACIS + PointACIS* pointACIS_ptr1 = CAST_TO(const_cast<Point*>(point1_ptr), PointACIS) ; + PointACIS* pointACIS_ptr2 = CAST_TO(const_cast<Point*>(point2_ptr), PointACIS) ; - // Make sure that we don't get NULL pointers after the cast down. - assert ( pointACIS_ptr1 != NULL && pointACIS_ptr2 != NULL ) ; + // Make sure that we don't get NULL pointers after the cast down. + assert ( pointACIS_ptr1 != NULL && pointACIS_ptr2 != NULL ) ; - // Get a reference to the VERTEX list of the PointACIS - VERTEX* VERTEX_ptr1 = pointACIS_ptr1->get_VERTEX_ptr(); - VERTEX* VERTEX_ptr2 = pointACIS_ptr2->get_VERTEX_ptr(); + // Get a reference to the VERTEX list of the PointACIS + VERTEX* VERTEX_ptr1 = pointACIS_ptr1->get_VERTEX_ptr(); + VERTEX* VERTEX_ptr2 = pointACIS_ptr2->get_VERTEX_ptr(); - SPAposition* pos_ptr = NULL ; - SPAposition pos ; + SPAposition* pos_ptr = NULL ; + SPAposition pos ; - if ( curve_type != STRAIGHT_CURVE_TYPE ) - { - assert ( intermediate_point_ptr != NULL) ; + if ( curve_type != STRAIGHT_CURVE_TYPE ) + { + assert ( intermediate_point_ptr != NULL) ; - // Construct a SPAposition from the given intermediate point. - pos = SPAposition (intermediate_point_ptr->x(), - intermediate_point_ptr->y(), - intermediate_point_ptr->z()) ; - pos_ptr = &pos ; - } + // Construct a SPAposition from the given intermediate point. + pos = SPAposition (intermediate_point_ptr->x(), + intermediate_point_ptr->y(), + intermediate_point_ptr->z()) ; + pos_ptr = &pos ; + } - logical acis_sense = TRUE; - if ( sense == CUBIT_REVERSED ) - { - acis_sense = FALSE; - } + logical acis_sense = TRUE; + if ( sense == CUBIT_REVERSED ) + { + acis_sense = FALSE; + } - // Use the VERTEXes and the SPAposition to make a new EDGE - EDGE* EDGE_ptr = this->make_EDGE(curve_type, - VERTEX_ptr1, - VERTEX_ptr2, - pos_ptr, - acis_sense == TRUE) ; + // Use the VERTEXes and the SPAposition to make a new EDGE + EDGE* EDGE_ptr = this->make_EDGE(curve_type, + VERTEX_ptr1, + VERTEX_ptr2, + pos_ptr, + acis_sense == TRUE) ; - if ( EDGE_ptr == NULL ) - { - PRINT_ERROR("In AcisModifyEngine::make_Curve\n" - " Cannot make Curve object.\n"); - return (Curve *)NULL; - } + if ( EDGE_ptr == NULL ) + { + PRINT_ERROR("In AcisModifyEngine::make_Curve\n" + " Cannot make Curve object.\n"); + return (Curve *)NULL; + } - // Use the new EDGE to create a new CurveACIS - return AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr); -} + // Use the new EDGE to create a new CurveACIS + return AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr); + } -//------------------------------------------------------------------------- -// Purpose : This function creates a Curve of type, curve_type, -// given the end points of the curve and an intermediate -// point. The particular type of Curve object that is -// created depends on the specific modeling engine. For -// example, if the engine is AcisModifyEngine, then a -// CurveACIS is created and returned. -// -// Special Notes : -// -// Creator : Malcolm J. Panthaki -// -// Creation Date : 05/16/97 -//------------------------------------------------------------------------- -Curve* AcisModifyEngine::make_Curve( GeometryType curve_type, + //------------------------------------------------------------------------- + // Purpose : This function creates a Curve of type, curve_type, + // given the end points of the curve and an intermediate + // point. The particular type of Curve object that is + // created depends on the specific modeling engine. For + // example, if the engine is AcisModifyEngine, then a + // CurveACIS is created and returned. + // + // Special Notes : + // + // Creator : Malcolm J. Panthaki + // + // Creation Date : 05/16/97 + //------------------------------------------------------------------------- + Curve* AcisModifyEngine::make_Curve( GeometryType curve_type, Point const* point1_ptr, Point const* point2_ptr, DLIList<CubitVector*>& vector_list, Surface* ref_face_ptr ) const -{ - // We make splines here :-) - if ( curve_type != SPLINE_CURVE_TYPE ) - { - PRINT_ERROR("In AcisModifyEngine::make_Curve\n" - " Can only make spline surves in this routine.\n"); - return (Curve *)NULL; - } + { + // We make splines here :-) + if ( curve_type != SPLINE_CURVE_TYPE ) + { + PRINT_ERROR("In AcisModifyEngine::make_Curve\n" + " Can only make spline surves in this routine.\n"); + return (Curve *)NULL; + } - // Extract the VERTEXes from the Points. + // Extract the VERTEXes from the Points. - // Cast the Points to PointACIS - PointACIS* pointACIS_ptr1 = CAST_TO(const_cast<Point*>(point1_ptr), PointACIS) ; - PointACIS* pointACIS_ptr2 = CAST_TO(const_cast<Point*>(point2_ptr), PointACIS) ; + // Cast the Points to PointACIS + PointACIS* pointACIS_ptr1 = CAST_TO(const_cast<Point*>(point1_ptr), PointACIS) ; + PointACIS* pointACIS_ptr2 = CAST_TO(const_cast<Point*>(point2_ptr), PointACIS) ; - // Make sure that we don't get NULL pointers after the cast down. - assert ( pointACIS_ptr1 != NULL && pointACIS_ptr2 != NULL ) ; + // Make sure that we don't get NULL pointers after the cast down. + assert ( pointACIS_ptr1 != NULL && pointACIS_ptr2 != NULL ) ; - // Get a reference to the VERTEX list of the PointACIS - VERTEX* VERTEX_ptr1 = pointACIS_ptr1->get_VERTEX_ptr(); - VERTEX* VERTEX_ptr2 = pointACIS_ptr2->get_VERTEX_ptr(); + // Get a reference to the VERTEX list of the PointACIS + VERTEX* VERTEX_ptr1 = pointACIS_ptr1->get_VERTEX_ptr(); + VERTEX* VERTEX_ptr2 = pointACIS_ptr2->get_VERTEX_ptr(); - // Convert the list of CubitVectors into an array of ACIS position's. - // MJP NOTE: - // Add the positions of the 2 end VERTEX'es into this list. - int number_points = vector_list.size(); - vector_list.reset(); - CubitVector* vector_ptr = NULL, on_surf; - SPAposition* pos_array = new SPAposition [number_points]; + // Convert the list of CubitVectors into an array of ACIS position's. + // MJP NOTE: + // Add the positions of the 2 end VERTEX'es into this list. + int number_points = vector_list.size(); + vector_list.reset(); + CubitVector* vector_ptr = NULL, on_surf; + SPAposition* pos_array = new SPAposition [number_points]; - // Do the vector_list of points - for (int i = 0; i < number_points; i++) - { - vector_ptr = vector_list.get_and_step(); + // Do the vector_list of points + for (int i = 0; i < number_points; i++) + { + vector_ptr = vector_list.get_and_step(); - // If the input RefFace pointer is not NULL, then move this point - // to the surface of the RefFace - if (ref_face_ptr != NULL) - { - ref_face_ptr->closest_point(*vector_ptr, &on_surf); - *vector_ptr = on_surf; - //ref_face_ptr->move_to_surface(*vector_ptr); - } + // If the input RefFace pointer is not NULL, then move this point + // to the surface of the RefFace + if (ref_face_ptr != NULL) + { + ref_face_ptr->closest_point(*vector_ptr, &on_surf); + *vector_ptr = on_surf; + //ref_face_ptr->move_to_surface(*vector_ptr); + } - // Set the coordinates of the SPAposition object - pos_array[i].set_x(vector_ptr->x()); - pos_array[i].set_y(vector_ptr->y()); - pos_array[i].set_z(vector_ptr->z()); - } + // Set the coordinates of the SPAposition object + pos_array[i].set_x(vector_ptr->x()); + pos_array[i].set_y(vector_ptr->y()); + pos_array[i].set_z(vector_ptr->z()); + } - // Use the VERTEXes and the SPAposition array to make a new EDGE - EDGE* EDGE_ptr = this->make_spline_EDGE( VERTEX_ptr1, - VERTEX_ptr2, - pos_array, - number_points ); - // Free memory - delete [] pos_array; + // Use the VERTEXes and the SPAposition array to make a new EDGE + EDGE* EDGE_ptr = this->make_spline_EDGE( VERTEX_ptr1, + VERTEX_ptr2, + pos_array, + number_points ); + // Free memory + delete [] pos_array; - if ( EDGE_ptr == NULL ) - { - PRINT_ERROR("In AcisModifyEngine::make_Curve\n" - " Cannot make Curve object.\n"); - return (Curve *)NULL; - } + if ( EDGE_ptr == NULL ) + { + PRINT_ERROR("In AcisModifyEngine::make_Curve\n" + " Cannot make Curve object.\n"); + return (Curve *)NULL; + } - return AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr); -} + return AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr); + } -//------------------------------------------------------------------------- -// Purpose : This function creats a curve that is on a -// given surface. The third point is used -// for curves that could be periodic to dertermine -// the correct direction. -// -// -// Creator : David White -// -// Creation Date : 10/21/97 -//------------------------------------------------------------------------- -Curve* AcisModifyEngine::make_Curve( Point const* point1_ptr, - Point const* point2_ptr, - Surface* ref_face_ptr, - const CubitVector *third_point) const + //------------------------------------------------------------------------- + // Purpose : This function creats a curve that is on a + // given surface. The third point is used + // for curves that could be periodic to dertermine + // the correct direction. + // + // + // Creator : David White + // + // Creation Date : 10/21/97 + //------------------------------------------------------------------------- + Curve* AcisModifyEngine::make_Curve( Point const* point1_ptr, + Point const* point2_ptr, + Surface* ref_face_ptr, + const CubitVector *third_point) const -{ - CubitVector point_1 = point1_ptr->coordinates(); - CubitVector point_2 = point2_ptr->coordinates(); - CubitVector surf_norm; - ref_face_ptr->closest_point( point_1, NULL, &surf_norm ); + { + CubitVector point_1 = point1_ptr->coordinates(); + CubitVector point_2 = point2_ptr->coordinates(); + CubitVector surf_norm; + ref_face_ptr->closest_point( point_1, NULL, &surf_norm ); - CubitVector plane_norm; + CubitVector plane_norm; - CubitVector edge0 = point_2 - point_1; - CubitVector edge1 = surf_norm; - plane_norm = edge0*edge1; - if ( plane_norm.length() < CUBIT_RESABS ) - { - //try using the normal at point 2. - ref_face_ptr->closest_point(point_2, NULL, &surf_norm); - edge1 = surf_norm; - edge0 = point_1 - point_2; + CubitVector edge0 = point_2 - point_1; + CubitVector edge1 = surf_norm; plane_norm = edge0*edge1; if ( plane_norm.length() < CUBIT_RESABS ) - { - if ( third_point == NULL ) - { - PRINT_ERROR("Can't create curve on surface.\n" - "\tVertices are on opposite sides of surface.\n" - "\tUnable to infer a plane that will cut the surface.\n" - "\tTry specifying a 3rd vertex in the new curve.\n"); - return (Curve*)NULL; - } - else - { - // Try getting a normal from the third point - edge0 = point_1 - *third_point; - plane_norm = edge0*edge1; - if ( plane_norm.length() < CUBIT_RESABS ) - { - PRINT_ERROR("Can't create curve on surface.\n" - "\tVertices are on opposite sides of surface\n" - "\tand all three points are colinear.\n" - "\tTry specifying a non-colinear 3rd vertex.\n"); - return (Curve*)NULL; - } - } - } - } - plane_norm.normalize(); - // Extract the VERTEXes from the Points. + { + //try using the normal at point 2. + ref_face_ptr->closest_point(point_2, NULL, &surf_norm); + edge1 = surf_norm; + edge0 = point_1 - point_2; + plane_norm = edge0*edge1; + if ( plane_norm.length() < CUBIT_RESABS ) + { + if ( third_point == NULL ) + { + PRINT_ERROR("Can't create curve on surface.\n" + "\tVertices are on opposite sides of surface.\n" + "\tUnable to infer a plane that will cut the surface.\n" + "\tTry specifying a 3rd vertex in the new curve.\n"); + return (Curve*)NULL; + } + else + { + // Try getting a normal from the third point + edge0 = point_1 - *third_point; + plane_norm = edge0*edge1; + if ( plane_norm.length() < CUBIT_RESABS ) + { + PRINT_ERROR("Can't create curve on surface.\n" + "\tVertices are on opposite sides of surface\n" + "\tand all three points are colinear.\n" + "\tTry specifying a non-colinear 3rd vertex.\n"); + return (Curve*)NULL; + } + } + } + } + plane_norm.normalize(); + // Extract the VERTEXes from the Points. - // Cast the Points to PointACIS - PointACIS* pointACIS_ptr1 = CAST_TO(const_cast<Point*>(point1_ptr), PointACIS) ; - PointACIS* pointACIS_ptr2 = CAST_TO(const_cast<Point*>(point2_ptr), PointACIS) ; + // Cast the Points to PointACIS + PointACIS* pointACIS_ptr1 = CAST_TO(const_cast<Point*>(point1_ptr), PointACIS) ; + PointACIS* pointACIS_ptr2 = CAST_TO(const_cast<Point*>(point2_ptr), PointACIS) ; - // Make sure that we don't get NULL pointers after the cast down. - assert ( pointACIS_ptr1 != NULL && pointACIS_ptr2 != NULL ) ; + // Make sure that we don't get NULL pointers after the cast down. + assert ( pointACIS_ptr1 != NULL && pointACIS_ptr2 != NULL ) ; - // Get a reference to the VERTEX list of the PointACIS - VERTEX* VERTEX_ptr1 = pointACIS_ptr1->get_VERTEX_ptr(); - VERTEX* VERTEX_ptr2 = pointACIS_ptr2->get_VERTEX_ptr(); + // Get a reference to the VERTEX list of the PointACIS + VERTEX* VERTEX_ptr1 = pointACIS_ptr1->get_VERTEX_ptr(); + VERTEX* VERTEX_ptr2 = pointACIS_ptr2->get_VERTEX_ptr(); - FACE *FACE_ptr = CAST_TO(ref_face_ptr, SurfaceACIS )->get_FACE_ptr(); - //now using the points, vertices, FACE and plane normal, - //creat an edge. - EDGE* EDGE_ptr = this->make_surface_EDGE( VERTEX_ptr1, - VERTEX_ptr2, - FACE_ptr, - plane_norm, - third_point); - // Free memory - if ( EDGE_ptr == NULL ) - { - PRINT_ERROR("In AcisModifyEngine::make_Curve\n" - " Cannot make Curve object.\n"); - return (Curve *)NULL; - } + FACE *FACE_ptr = CAST_TO(ref_face_ptr, SurfaceACIS )->get_FACE_ptr(); + //now using the points, vertices, FACE and plane normal, + //creat an edge. + EDGE* EDGE_ptr = this->make_surface_EDGE( VERTEX_ptr1, + VERTEX_ptr2, + FACE_ptr, + plane_norm, + third_point); + // Free memory + if ( EDGE_ptr == NULL ) + { + PRINT_ERROR("In AcisModifyEngine::make_Curve\n" + " Cannot make Curve object.\n"); + return (Curve *)NULL; + } - return AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr); -} + return AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr); + } -//------------------------------------------------------------------------- -// Purpose : Create a surface given a surface. From another surface -// -// Special Notes : -// -// Creator : David White -// -// Creation Date : 10/6/97 -//------------------------------------------------------------------------- + //------------------------------------------------------------------------- + // Purpose : Create a surface given a surface. From another surface + // + // Special Notes : + // + // Creator : David White + // + // Creation Date : 10/6/97 + //------------------------------------------------------------------------- -Surface* AcisModifyEngine::make_Surface( Surface *old_surface_ptr, + Surface* AcisModifyEngine::make_Surface( Surface *old_surface_ptr, bool extended_from) const -{ - //Get the surface ACIS. - SurfaceACIS *surf_ACIS = CAST_TO(old_surface_ptr, SurfaceACIS ); - if (surf_ACIS == NULL) - { - PRINT_ERROR("surface is not created from acis.\n"); - return (Surface*) NULL; - } + { + //Get the surface ACIS. + SurfaceACIS *surf_ACIS = CAST_TO(old_surface_ptr, SurfaceACIS ); + if (surf_ACIS == NULL) + { + PRINT_ERROR("surface is not created from acis.\n"); + return (Surface*) NULL; + } - //Get the acis face. - FACE *FACE_ptr = surf_ACIS->get_FACE_ptr(); + //Get the acis face. + FACE *FACE_ptr = surf_ACIS->get_FACE_ptr(); - //use this to make a FACE. - if (FACE_ptr == NULL ) - { - PRINT_ERROR("surface is not created from acis.\n"); - return (Surface*) NULL; - } - FACE *new_FACE_ptr = NULL; + //use this to make a FACE. + if (FACE_ptr == NULL ) + { + PRINT_ERROR("surface is not created from acis.\n"); + return (Surface*) NULL; + } + FACE *new_FACE_ptr = NULL; - new_FACE_ptr = make_FACE( FACE_ptr, extended_from ); - if (new_FACE_ptr == NULL) - { - PRINT_ERROR("In AcisModifyEngine::make_Surface\n" - " Cannot make Surface object.\n"); - return (Surface *)NULL; - } + new_FACE_ptr = make_FACE( FACE_ptr, extended_from ); + if (new_FACE_ptr == NULL) + { + PRINT_ERROR("In AcisModifyEngine::make_Surface\n" + " Cannot make Surface object.\n"); + return (Surface *)NULL; + } - //populate the bridges from the body - BODY *body_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(new_FACE_ptr); - BodySM *body_sm = AcisQueryEngine::instance()->populate_topology_bridges( body_ptr ); - DLIList<Surface*> surfs; - body_sm->surfaces( surfs ); - Surface *surface = surfs.get(); + //populate the bridges from the body + BODY *body_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(new_FACE_ptr); + BodySM *body_sm = AcisQueryEngine::instance()->populate_topology_bridges( body_ptr ); + DLIList<Surface*> surfs; + body_sm->surfaces( surfs ); + Surface *surface = surfs.get(); - return surface; + return surface; -} + } -//------------------------------------------------------------------------- -// Purpose : This function creates a Surface of type, -// surface_type, given the list of curves. -// -// Special Notes : -// -// Creator : Raikanta Sahu -// -// Creation Date : 03/29/97 -//------------------------------------------------------------------------- -Surface* AcisModifyEngine::make_Surface( GeometryType surface_type, + //------------------------------------------------------------------------- + // Purpose : This function creates a Surface of type, + // surface_type, given the list of curves. + // + // Special Notes : + // + // Creator : Raikanta Sahu + // + // Creation Date : 03/29/97 + //------------------------------------------------------------------------- + Surface* AcisModifyEngine::make_Surface( GeometryType surface_type, DLIList<Curve*>& curve_list, Surface *old_surface_ptr, bool check_edges ) const -{ - DLIList<RefEdge*> copied_ref_edges; - int i; - if( check_edges ) - { - DLIList<RefEdge*> edge_list; - for( i=curve_list.size(); i--; ) { - RefEdge *tmp_ref_edge = NULL; - tmp_ref_edge = CAST_TO( curve_list.get_and_step()->topology_entity(), RefEdge ); - if( tmp_ref_edge ) - edge_list.append( tmp_ref_edge ); - } + DLIList<RefEdge*> copied_ref_edges; + int i; + if( check_edges ) + { + DLIList<RefEdge*> edge_list; + for( i=curve_list.size(); i--; ) + { + RefEdge *tmp_ref_edge = NULL; + tmp_ref_edge = CAST_TO( curve_list.get_and_step()->topology_entity(), RefEdge ); + if( tmp_ref_edge ) + edge_list.append( tmp_ref_edge ); + } - //duplicate curves possibly + //duplicate curves possibly - //Modified by J.K. to avoid core dump if vertices are merged. - //If vertices belong to edges other than those we are creating - //the surface from, copy the corresponding edges. This will - //also pick up the case where edges already belong to a face. - DLIList<RefEdge*> vtx_edges; - DLIList<RefVertex*> vtx_list; - for ( i = edge_list.size(); i > 0; i-- ) - { - RefEdge *ref_edge = edge_list.get(); + //Modified by J.K. to avoid core dump if vertices are merged. + //If vertices belong to edges other than those we are creating + //the surface from, copy the corresponding edges. This will + //also pick up the case where edges already belong to a face. + DLIList<RefEdge*> vtx_edges; + DLIList<RefVertex*> vtx_list; + for ( i = edge_list.size(); i > 0; i-- ) + { + RefEdge *ref_edge = edge_list.get(); - CubitBoolean other_edge = CUBIT_FALSE; - ref_edge->ref_vertices(vtx_list); - while( vtx_list.size() ) - { - vtx_edges.clean_out(); - vtx_list.pop()->ref_edges( vtx_edges ); - while( vtx_edges.size() ) - { - if( ! edge_list.is_in_list( vtx_edges.pop() ) ) - { - other_edge = CUBIT_TRUE; - vtx_list.clean_out(); - break; - } - } - } + CubitBoolean other_edge = CUBIT_FALSE; + ref_edge->ref_vertices(vtx_list); + while( vtx_list.size() ) + { + vtx_edges.clean_out(); + vtx_list.pop()->ref_edges( vtx_edges ); + while( vtx_edges.size() ) + { + if( ! edge_list.is_in_list( vtx_edges.pop() ) ) + { + other_edge = CUBIT_TRUE; + vtx_list.clean_out(); + break; + } + } + } - if ( other_edge || (ref_edge->get_parents() > 0) ) - { - RefEdge *replacement_edge = GeometryModifyTool::instance()->make_RefEdge( ref_edge ); - if (!replacement_edge) - { - PRINT_WARNING("Creation of Surface Unsuccessful\n"); - return (Surface *)NULL; - } - edge_list.change_to( replacement_edge ); - copied_ref_edges.append( replacement_edge ); - } - edge_list.step(); - } + if ( other_edge || (ref_edge->get_parents() > 0) ) + { + RefEdge *replacement_edge = GeometryModifyTool::instance()->make_RefEdge( ref_edge ); + if (!replacement_edge) + { + PRINT_WARNING("Creation of Surface Unsuccessful\n"); + return (Surface *)NULL; + } + edge_list.change_to( replacement_edge ); + copied_ref_edges.append( replacement_edge ); + } + edge_list.step(); + } - curve_list.clean_out(); - for( i=edge_list.size(); i--; ) - { - Curve *tmp_curve = NULL; - tmp_curve = - CAST_TO( edge_list.get_and_step()->bridge_manager()->topology_bridge(), Curve); - if( tmp_curve ) - curve_list.append( tmp_curve ); - } - } + curve_list.clean_out(); + for( i=edge_list.size(); i--; ) + { + Curve *tmp_curve = NULL; + tmp_curve = + CAST_TO( edge_list.get_and_step()->bridge_manager()->topology_bridge(), Curve); + if( tmp_curve ) + curve_list.append( tmp_curve ); + } + } - DLIList<EDGE*> EDGE_list ; - // List of EDGEs to use to create the FACE from which we can make - // a SurfaceACIS. + DLIList<EDGE*> EDGE_list ; + // List of EDGEs to use to create the FACE from which we can make + // a SurfaceACIS. - // Extract the EDGEs from the given Curves - Curve const* curve_ptr = NULL ; - CurveACIS* curveACIS_ptr = NULL ; - EDGE* EDGE_ptr = NULL ; + // Extract the EDGEs from the given Curves + Curve const* curve_ptr = NULL ; + CurveACIS* curveACIS_ptr = NULL ; + EDGE* EDGE_ptr = NULL ; - curve_list.reset() ; + curve_list.reset() ; - for ( i = 0 ; i < curve_list.size() ; i++ ) - { - curve_ptr = curve_list.get_and_step() ; - curveACIS_ptr = CAST_TO(const_cast<Curve*>(curve_ptr), CurveACIS) ; + for ( i = 0 ; i < curve_list.size() ; i++ ) + { + curve_ptr = curve_list.get_and_step() ; + curveACIS_ptr = CAST_TO(const_cast<Curve*>(curve_ptr), CurveACIS) ; - // Make sure that we don't get NULL pointers after the cast down. - if ( curveACIS_ptr == NULL ) - { - PRINT_ERROR("In AcisModifyEngine::make_Surface\n" - " Got a NULL pointer to CurveACIS\n") ; - assert ( curveACIS_ptr != NULL ) ; - } + // Make sure that we don't get NULL pointers after the cast down. + if ( curveACIS_ptr == NULL ) + { + PRINT_ERROR("In AcisModifyEngine::make_Surface\n" + " Got a NULL pointer to CurveACIS\n") ; + assert ( curveACIS_ptr != NULL ) ; + } - // Get the EDGE - EDGE_ptr = curveACIS_ptr->get_EDGE_ptr() ; + // Get the EDGE + EDGE_ptr = curveACIS_ptr->get_EDGE_ptr() ; - // Add the EDGE to the list of EDGEs to be used to make a FACE - EDGE_list.append(EDGE_ptr) ; - } + // Add the EDGE to the list of EDGEs to be used to make a FACE + EDGE_list.append(EDGE_ptr) ; + } - // Use the EDGEs to make a FACE - FACE* FACE_ptr = this->make_FACE(surface_type, EDGE_list, - old_surface_ptr) ; + // Use the EDGEs to make a FACE + FACE* FACE_ptr = this->make_FACE(surface_type, EDGE_list, + old_surface_ptr) ; - if (FACE_ptr == NULL) - { - //delete all the copied ref edges...copied just for creating this surface - for(i=copied_ref_edges.size(); i--; ) - GeometryQueryTool::instance()->delete_RefEdge( copied_ref_edges.get_and_step() ); + if (FACE_ptr == NULL) + { + //delete all the copied ref edges...copied just for creating this surface + for(i=copied_ref_edges.size(); i--; ) + GeometryQueryTool::instance()->delete_RefEdge( copied_ref_edges.get_and_step() ); - PRINT_ERROR("In AcisModifyEngine::make_Surface\n" - " Cannot make Surface object.\n"); - return (Surface *)NULL; - } + PRINT_ERROR("In AcisModifyEngine::make_Surface\n" + " Cannot make Surface object.\n"); + return (Surface *)NULL; + } - // make the topology bridges for the face - Surface *surface = AcisQueryEngine::instance()->populate_topology_bridges(FACE_ptr); - return surface; + // make the topology bridges for the face + Surface *surface = AcisQueryEngine::instance()->populate_topology_bridges(FACE_ptr); + return surface; -/* + /* - // now generate the body - DLIList<BODY*> new_BODIES; - DLIList<Body*> new_bodies; - new_BODIES.append(AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr)); - CubitStatus success = get_new_Body(old_entities, - new_BODIES, new_bodies, CUBIT_FALSE); + // now generate the body + DLIList<BODY*> new_BODIES; + DLIList<Body*> new_bodies; + new_BODIES.append(AcisQueryEngine::instance()->get_BODY_of_ENTITY(FACE_ptr)); + CubitStatus success = get_new_Body(old_entities, + new_BODIES, new_bodies, CUBIT_FALSE); - AcisBridge *tb_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(FACE_ptr); - return CAST_TO(tb_ptr, Surface); -*/ -} + AcisBridge *tb_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(FACE_ptr); + return CAST_TO(tb_ptr, Surface); + */ + } -//------------------------------------------------------------------------- -// Purpose : This function creates a Lump of type, lump_type, -// given the list of surfaces. -// -// Special Notes : -// -// Creator : Raikanta Sahu -// -// Creation Date : 03/29/97 -//------------------------------------------------------------------------- + //------------------------------------------------------------------------- + // Purpose : This function creates a Lump of type, lump_type, + // given the list of surfaces. + // + // Special Notes : + // + // Creator : Raikanta Sahu + // + // Creation Date : 03/29/97 + //------------------------------------------------------------------------- -Lump* AcisModifyEngine::make_Lump( DLIList<Surface*>& surface_list ) const -{ - // Extract the FACEs of the surface list. Use the FACEs to - // create a SHELL. - Surface const* surface_ptr = NULL ; - SurfaceACIS* surfaceACIS_ptr = NULL ; - FACE* first_FACE_ptr = NULL ; - FACE* current_FACE_ptr = NULL ; - FACE* previous_FACE_ptr = NULL ; + Lump* AcisModifyEngine::make_Lump( DLIList<Surface*>& surface_list ) const + { + // Extract the FACEs of the surface list. Use the FACEs to + // create a SHELL. + Surface const* surface_ptr = NULL ; + SurfaceACIS* surfaceACIS_ptr = NULL ; + FACE* first_FACE_ptr = NULL ; + FACE* current_FACE_ptr = NULL ; + FACE* previous_FACE_ptr = NULL ; - surface_list.reset() ; - for ( int i = 0 ; i < surface_list.size() ; i++ ) - { - surface_ptr = surface_list.get_and_step() ; - surfaceACIS_ptr = CAST_TO(const_cast<Surface*>(surface_ptr), SurfaceACIS) ; + surface_list.reset() ; + for ( int i = 0 ; i < surface_list.size() ; i++ ) + { + surface_ptr = surface_list.get_and_step() ; + surfaceACIS_ptr = CAST_TO(const_cast<Surface*>(surface_ptr), SurfaceACIS) ; - // Make sure that we have a valid SurfaceACIS pointer - if ( surfaceACIS_ptr == NULL ) - { - PRINT_ERROR("In AcisModifyEngine::make_Lump\n" - " Got a NULL pointer to SurfaceACIS\n") ; - assert ( surfaceACIS_ptr != NULL ) ; - } + // Make sure that we have a valid SurfaceACIS pointer + if ( surfaceACIS_ptr == NULL ) + { + PRINT_ERROR("In AcisModifyEngine::make_Lump\n" + " Got a NULL pointer to SurfaceACIS\n") ; + assert ( surfaceACIS_ptr != NULL ) ; + } - current_FACE_ptr = surfaceACIS_ptr->get_FACE_ptr(); + current_FACE_ptr = surfaceACIS_ptr->get_FACE_ptr(); - // Connect up the previous FACE and the current FACE if - // the current FACE is not the first FACE. - if ( previous_FACE_ptr != NULL ) - { - previous_FACE_ptr->set_next(current_FACE_ptr) ; - } - else - { - first_FACE_ptr = current_FACE_ptr ; - } + // Connect up the previous FACE and the current FACE if + // the current FACE is not the first FACE. + if ( previous_FACE_ptr != NULL ) + { + previous_FACE_ptr->set_next(current_FACE_ptr) ; + } + else + { + first_FACE_ptr = current_FACE_ptr ; + } - previous_FACE_ptr = current_FACE_ptr ; - } + previous_FACE_ptr = current_FACE_ptr ; + } - // Create a new SHELL if the first FACE is not attached to - // a SHELL. - SHELL* SHELL_ptr = first_FACE_ptr->shell() ; - if ( SHELL_ptr == NULL ) - { - SHELL_ptr = new SHELL(first_FACE_ptr, NULL, NULL) ; + // Create a new SHELL if the first FACE is not attached to + // a SHELL. + SHELL* SHELL_ptr = first_FACE_ptr->shell() ; if ( SHELL_ptr == NULL ) - { - PRINT_ERROR("In AcisModifyEngine::make_Lump\n" - " ACIS cannot make SHELL object.\n" - " Cannot make Lump object.\n"); - return (Lump *)NULL; - } - } + { + SHELL_ptr = new SHELL(first_FACE_ptr, NULL, NULL) ; + if ( SHELL_ptr == NULL ) + { + PRINT_ERROR("In AcisModifyEngine::make_Lump\n" + " ACIS cannot make SHELL object.\n" + " Cannot make Lump object.\n"); + return (Lump *)NULL; + } + } - // Create a new LUMP and attach the SHELL to it. - LUMP* LUMP_ptr = SHELL_ptr->lump(); - if (LUMP_ptr == NULL) - { - LUMP_ptr = new LUMP(SHELL_ptr, NULL) ; - if ( LUMP_ptr == NULL ) - { - PRINT_ERROR("In AcisModifyEngine::make_Lump\n" - " ACIS cannot make LUMP object.\n" - " Cannot make Lump object.\n"); - return (Lump *)NULL; - } - } + // Create a new LUMP and attach the SHELL to it. + LUMP* LUMP_ptr = SHELL_ptr->lump(); + if (LUMP_ptr == NULL) + { + LUMP_ptr = new LUMP(SHELL_ptr, NULL) ; + if ( LUMP_ptr == NULL ) + { + PRINT_ERROR("In AcisModifyEngine::make_Lump\n" + " ACIS cannot make LUMP object.\n" + " Cannot make Lump object.\n"); + return (Lump *)NULL; + } + } - // Create a LumpACIS using the LUMP_ptr - LumpACIS* lumpACIS_ptr = new LumpACIS(LUMP_ptr) ; - assert( lumpACIS_ptr != NULL ); + // Create a LumpACIS using the LUMP_ptr + LumpACIS* lumpACIS_ptr = new LumpACIS(LUMP_ptr) ; + assert( lumpACIS_ptr != NULL ); - AcisQueryEngine::instance()->populate_topology_bridges(LUMP_ptr); -/* - AcisBridge *tb_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(LUMP_ptr); + AcisQueryEngine::instance()->populate_topology_bridges(LUMP_ptr); + /* + AcisBridge *tb_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(LUMP_ptr); - Lump *this_lump = CAST_TO(tb_ptr, Lump); - ShellSM *shellsm = this_lump->shellsm(); + Lump *this_lump = CAST_TO(tb_ptr, Lump); + ShellSM *shellsm = this_lump->shellsm(); - // Use the SHELL to build VGI Shell and CoFace, using 0 for color - Shell* Shell_ptr = GeometryQueryTool::instance()->make_Shell(shellsm) ; + // Use the SHELL to build VGI Shell and CoFace, using 0 for color + Shell* Shell_ptr = GeometryQueryTool::instance()->make_Shell(shellsm) ; - if (Shell_ptr == NULL) - { - PRINT_ERROR("In AcisModifyEngine::make_Lump\n" - " Could not build a Shell for unknown reasons.\n"); - return (Lump *)NULL; - } -*/ - // Return the new LumpACIS - return lumpACIS_ptr ; -} + if (Shell_ptr == NULL) + { + PRINT_ERROR("In AcisModifyEngine::make_Lump\n" + " Could not build a Shell for unknown reasons.\n"); + return (Lump *)NULL; + } + */ + // Return the new LumpACIS + return lumpACIS_ptr ; + } -BodySM* AcisModifyEngine::make_BodySM( Surface *surface_ptr) const -{ - //- given a Surface, make a BodySM - // make sure this Surface is the right type - SurfaceACIS *sa_ptr = CAST_TO(surface_ptr, SurfaceACIS); - assert(sa_ptr != 0); + BodySM* AcisModifyEngine::make_BodySM( Surface *surface_ptr) const + { + //- given a Surface, make a BodySM + // make sure this Surface is the right type + SurfaceACIS *sa_ptr = CAST_TO(surface_ptr, SurfaceACIS); + assert(sa_ptr != 0); - // now, get the acis BODY and populate the topology bridges - FACE *face = sa_ptr->get_FACE_ptr(); - BODY *body_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(face); + // now, get the acis BODY and populate the topology bridges + FACE *face = sa_ptr->get_FACE_ptr(); + BODY *body_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(face); - return AcisQueryEngine::instance()->populate_topology_bridges(body_ptr); -} + return AcisQueryEngine::instance()->populate_topology_bridges(body_ptr); + } -//------------------------------------------------------------------------- -// Purpose : This function creates a BodySM given a list of Lumps. -// -// Special Notes : -// -// Creator : Raikanta Sahu -// -// Creation Date : 03/29/97 -//------------------------------------------------------------------------- + //------------------------------------------------------------------------- + // Purpose : This function creates a BodySM given a list of Lumps. + // + // Special Notes : + // + // Creator : Raikanta Sahu + // + // Creation Date : 03/29/97 + //------------------------------------------------------------------------- -BodySM* AcisModifyEngine::make_BodySM( DLIList<Lump*>& lump_list ) const -{ - // Extract the LUMPs of the lump list. Use the LUMPs to - // create a BODY. - Lump const* lump_ptr = NULL ; - LumpACIS* lumpACIS_ptr = NULL ; - LUMP* first_LUMP_ptr = NULL ; - LUMP* current_LUMP_ptr = NULL ; - LUMP* previous_LUMP_ptr = NULL ; + BodySM* AcisModifyEngine::make_BodySM( DLIList<Lump*>& lump_list ) const + { + // Extract the LUMPs of the lump list. Use the LUMPs to + // create a BODY. + Lump const* lump_ptr = NULL ; + LumpACIS* lumpACIS_ptr = NULL ; + LUMP* first_LUMP_ptr = NULL ; + LUMP* current_LUMP_ptr = NULL ; + LUMP* previous_LUMP_ptr = NULL ; - lump_list.reset() ; - for ( int i = 0 ; i < lump_list.size() ; i++ ) - { - lump_ptr = lump_list.get_and_step() ; - lumpACIS_ptr = CAST_TO(const_cast<Lump*>(lump_ptr), LumpACIS) ; + lump_list.reset() ; + for ( int i = 0 ; i < lump_list.size() ; i++ ) + { + lump_ptr = lump_list.get_and_step() ; + lumpACIS_ptr = CAST_TO(const_cast<Lump*>(lump_ptr), LumpACIS) ; - // Make sure that we have a valid LumpACIS pointer - if ( lumpACIS_ptr == NULL ) - { - PRINT_ERROR("In AcisModifyEngine::make_Lump\n" - " Input Lump is not a LumpACIS\n") ; - assert ( lumpACIS_ptr != NULL ) ; - } + // Make sure that we have a valid LumpACIS pointer + if ( lumpACIS_ptr == NULL ) + { + PRINT_ERROR("In AcisModifyEngine::make_Lump\n" + " Input Lump is not a LumpACIS\n") ; + assert ( lumpACIS_ptr != NULL ) ; + } - current_LUMP_ptr = lumpACIS_ptr->get_LUMP_ptr(); + current_LUMP_ptr = lumpACIS_ptr->get_LUMP_ptr(); - // Connect up the previous LUMP and the current LUMP if - // the current LUMP is not the first LUMP. - if ( previous_LUMP_ptr != NULL ) - { - previous_LUMP_ptr->set_next(current_LUMP_ptr) ; - } - else - { - first_LUMP_ptr = current_LUMP_ptr ; - } + // Connect up the previous LUMP and the current LUMP if + // the current LUMP is not the first LUMP. + if ( previous_LUMP_ptr != NULL ) + { + previous_LUMP_ptr->set_next(current_LUMP_ptr) ; + } + else + { + first_LUMP_ptr = current_LUMP_ptr ; + } - previous_LUMP_ptr = current_LUMP_ptr ; - } + previous_LUMP_ptr = current_LUMP_ptr ; + } - // Create a new BODY if the first LUMP is not attached to - // a BODY. - BODY* BODY_ptr = first_LUMP_ptr->body() ; - if ( BODY_ptr == NULL ) - { - BODY_ptr = new BODY(first_LUMP_ptr) ; + // Create a new BODY if the first LUMP is not attached to + // a BODY. + BODY* BODY_ptr = first_LUMP_ptr->body() ; if ( BODY_ptr == NULL ) - { - PRINT_ERROR("In AcisModifyEngine::make_BodySM\n" - " ACIS cannot make BODY object.\n" - " Cannot make BodySM object.\n"); - return (BodySM *)NULL; - } - } + { + BODY_ptr = new BODY(first_LUMP_ptr) ; + if ( BODY_ptr == NULL ) + { + PRINT_ERROR("In AcisModifyEngine::make_BodySM\n" + " ACIS cannot make BODY object.\n" + " Cannot make BodySM object.\n"); + return (BodySM *)NULL; + } + } - // Use the BODY to build VGI Body and CoVolume(s) - BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(BODY_ptr); + // Use the BODY to build VGI Body and CoVolume(s) + BodySM *this_bodysm = AcisQueryEngine::instance()->populate_topology_bridges(BODY_ptr); - /* Commenting out following section - we shouldn't be making - Body's yet!!! + /* Commenting out following section - we shouldn't be making + Body's yet!!! - Body* body_ptr = GeometryModifyTool::instance()->make_Body(this_bodysm); - assert( body_ptr != NULL ); + Body* body_ptr = GeometryModifyTool::instance()->make_Body(this_bodysm); + assert( body_ptr != NULL ); - // First get the OSME associated with this Body - BodySM* OSME_ptr = - body_ptr->get_body_sm_ptr() ; + // First get the OSME associated with this Body + BodySM* OSME_ptr = + body_ptr->get_body_sm_ptr() ; - // Cast the OSME to BodyACIS - BodyACIS* bodyACIS_ptr = CAST_TO(OSME_ptr, BodyACIS) ; + // Cast the OSME to BodyACIS + BodyACIS* bodyACIS_ptr = CAST_TO(OSME_ptr, BodyACIS) ; - // Make sure that we have a valid BodyACIS - assert ( bodyACIS_ptr != NULL ) ; - */ - // Return the BodyACIS - return this_bodysm; -} - -CubitStatus -AcisModifyEngine::webcut_with_sheet( DLIList<BodySM*>& webcut_body_list, - BodySM *sheet_body, - DLIList<BodySM*> &new_bodies, - bool imprint ) -{ - int num_cut=0; - DLIList<BodySM*> temp_new_bodies; - - for ( int ii = webcut_body_list.size(); ii > 0; ii-- ) - { - BodySM *webcut_body = webcut_body_list.get_and_step(); - BODY *sheet_BODY = AcisQueryEngine::get_BODY(sheet_body ); - BODY *webcut_BODY = AcisQueryEngine::get_BODY(webcut_body ); - //now webcut it. - BODY *new_BODY_1, *new_BODY_2; - - CubitStatus status = webcut_with_sheet( webcut_BODY, - sheet_BODY, - new_BODY_1, - new_BODY_2, - imprint ); - if ( status == CUBIT_SUCCESS ) - { - DLIList<BODY*> new_BODY_list; - - new_BODY_list.append(new_BODY_1); - new_BODY_list.append(new_BODY_2); - temp_new_bodies.clean_out(); - - CubitStatus result = get_new_Body(webcut_body, webcut_BODY, - new_BODY_list, temp_new_bodies, - CUBIT_FALSE); - if ( result != CUBIT_SUCCESS ) - { - PRINT_ERROR("Problems with building volume.\n"); - num_cut = 0; - return CUBIT_FAILURE; - } - else - { - new_bodies += temp_new_bodies; - num_cut++; - } - } - } - - // Return CUBIT_SUCCESS as long as one body is webcut, earlier failures should - // return CUBIT_FAILURE independently of these return statments - return num_cut > 0 ? CUBIT_SUCCESS : CUBIT_FAILURE; -} - - -// This function does the actuall webcuting with two acis bodies... -CubitStatus AcisModifyEngine::webcut_with_sheet( BODY *webcut_body, - BODY *sheet_body, - BODY *&webcut_body_1, - BODY *&webcut_body_2, - bool imprint ) -{ - //don't try to webcut a sheet body with itself - if( webcut_body == sheet_body ) - { - return CUBIT_FAILURE; - } - - CubitBoolean new_ids = GeometryModifyTool::instance()->get_new_ids(); - CubitBoolean not_new_ids = CUBIT_TRUE; - if (new_ids) not_new_ids = CUBIT_FALSE; - - BODY *sheet_BODY = sheet_body; - BODY *copy_sheet_BODY = this->copy_BODY(sheet_BODY); - BODY *webcut_BODY = webcut_body; - BODY *copy_webcut_BODY1 = copy_BODY(webcut_BODY, - new_ids); - BODY *copy_webcut_BODY2 = copy_BODY(webcut_BODY, - new_ids); -//first test to see if these intersect. If they don't -//then continueing on will not show the error and duplicate -//bodies will be created. - if ( !BODYs_interfering( webcut_BODY, sheet_BODY ) ) - { - PRINT_WARNING("Cutting Sheet does not intersect the original volume.\n" - " The original volume is restored.\n" ); - //These don't intersect. Clean up and exit. - AcisQueryEngine::instance()->delete_ACIS_BODY(copy_sheet_BODY, CUBIT_TRUE); - AcisQueryEngine::instance()->delete_ACIS_BODY(copy_webcut_BODY1, not_new_ids); - AcisQueryEngine::instance()->delete_ACIS_BODY(copy_webcut_BODY2, not_new_ids); - - return CUBIT_FAILURE; - } - - //set all faces to one sided - API_BEGIN; - sg_body_to_1d( copy_sheet_BODY ); - API_END; - - //Now we have to do two subtracts. Lets subtract this face from the body - //to be webcut. Then reverse it and do it again. - BODY *copy_2_sheet_BODY = copy_BODY( copy_sheet_BODY ); - - outcome rc_3 = api_reverse_body( copy_2_sheet_BODY ); - if ( !rc_3.ok() || copy_2_sheet_BODY == NULL ) - { - PRINT_ERROR("Error in webcutting volume with sheet.\n"); - AcisQueryEngine::instance()->delete_ACIS_BODY(copy_sheet_BODY, CUBIT_TRUE); - AcisQueryEngine::instance()->delete_ACIS_BODY(copy_2_sheet_BODY, CUBIT_TRUE); - AcisQueryEngine::instance()->delete_ACIS_BODY(copy_webcut_BODY1, not_new_ids); - AcisQueryEngine::instance()->delete_ACIS_BODY(copy_webcut_BODY2, not_new_ids); - AcisQueryEngine::instance()->ACIS_API_error (rc_3); - return CUBIT_FAILURE; - } - - outcome rc_4 = api_subtract( copy_sheet_BODY, copy_webcut_BODY1 ); - - if ( !rc_4.ok() || copy_sheet_BODY == NULL || - copy_webcut_BODY1 == NULL || - copy_webcut_BODY1->lump() == NULL || - (!BodyACIS::is_sheet_body( copy_webcut_BODY1 ) && - !is_closed_solid_body( copy_webcut_BODY1 ) )) - { - CubitBoolean is_error = CUBIT_TRUE; - if ( rc_4.ok() && copy_webcut_BODY1 && copy_sheet_BODY && - ( copy_webcut_BODY1->lump() == NULL || - !is_closed_solid_body( copy_webcut_BODY1 ))) - { - //This is where the sheet just intersects with the shell - //of the outside body. should do nothing here. - is_error = CUBIT_FALSE; + // Make sure that we have a valid BodyACIS + assert ( bodyACIS_ptr != NULL ) ; + */ + // Return the BodyACIS + return this_bodysm; } - if( !rc_4.ok() ) //was already deleted if api_subtract was successfull - AcisQueryEngine::instance()->delete_ACIS_BODY(copy_sheet_BODY, CUBIT_TRUE); - AcisQueryEngine::instance()->delete_ACIS_BODY(copy_2_sheet_BODY, CUBIT_TRUE); - AcisQueryEngine::instance()->delete_ACIS_BODY(copy_webcut_BODY1, not_new_ids); - AcisQueryEngine::instance()->delete_ACIS_BODY(copy_webcut_BODY2, not_new_ids); - if ( is_error ) + CubitStatus AcisModifyEngine::regularize_body( BodySM *body_ptr, + BodySM *&new_body_ptr) { - PRINT_ERROR("Error in webcutting volume with sheet.\n"); - AcisQueryEngine::instance()->ACIS_API_error (rc_4); - } - else - PRINT_WARNING("Sheet grazes shell of volume. Nothing was cut.\n"); - return CUBIT_FAILURE; - } - outcome rc_5 = api_subtract( copy_2_sheet_BODY, copy_webcut_BODY2 ); + CubitBoolean new_ids = GeometryModifyTool::instance()->get_new_ids(); + CubitBoolean not_new_ids = (new_ids ? CUBIT_FALSE : CUBIT_TRUE); - if ( !rc_5.ok() || copy_2_sheet_BODY == NULL || - copy_webcut_BODY2 == NULL || - copy_webcut_BODY2->lump() == NULL || - (!BodyACIS::is_sheet_body( copy_webcut_BODY2 ) && - !is_closed_solid_body( copy_webcut_BODY2 ) )) - { - CubitBoolean is_error = CUBIT_TRUE; - if ( rc_5.ok() && copy_2_sheet_BODY && copy_webcut_BODY2 - && (copy_webcut_BODY2->lump() == NULL || - !is_closed_solid_body( copy_webcut_BODY2 ))) - is_error = CUBIT_FALSE; + BODY *old_BODY = AcisQueryEngine::get_BODY(body_ptr ); + if (!old_BODY) + return CUBIT_FAILURE; + BODY *acis_BODY = this->copy_BODY(old_BODY, new_ids); - if( !rc_5.ok() ) //was already deleted if api_subtract was successfull - AcisQueryEngine::instance()->delete_ACIS_BODY(copy_2_sheet_BODY, CUBIT_TRUE); + outcome result = api_clean_entity( (ENTITY*) acis_BODY); + //outcome result = api_regularise_entity( (ENTITY*) acis_BODY); + if (!result.ok() || acis_BODY == NULL || + acis_BODY->lump() == NULL ) + { + PRINT_ERROR("found in AcisModifyEngine::regularize_body.\n" + "api_regularise_entity failed.\n"); + AcisQueryEngine::instance()->ACIS_API_error (result); + AcisQueryEngine::instance()->delete_ACIS_BODY(acis_BODY, not_new_ids); + return CUBIT_FAILURE; + } - AcisQueryEngine::instance()->delete_ACIS_BODY(copy_webcut_BODY1, not_new_ids); - AcisQueryEngine::instance()->delete_ACIS_BODY(copy_webcut_BODY2, not_new_ids); - if ( is_error ) - { - PRINT_ERROR("Error in webcutting volume with sheet.\n"); - AcisQueryEngine::instance()->ACIS_API_error (rc_5); - } - else - PRINT_WARNING("Sheet grazes shell of volume. Nothing was cut.\n"); - return CUBIT_FAILURE; - } + new_body_ptr = get_new_Body(body_ptr, old_BODY, acis_BODY, false); - //it is possible that the sheet body tool and sheet blank overlap - //use different webcut function then - - //if copy_webcut_BODY1 is a sheet body, see if resultant bodies overlap - if( BodyACIS::is_sheet_body( copy_webcut_BODY1 ) ) - { - bool overlap = false; - - API_BEGIN; - API_NOP_BEGIN; - outcome my_result = api_intersect( copy_webcut_BODY1, copy_webcut_BODY2 ); - if( my_result.ok() && copy_webcut_BODY2->lump() ) - overlap = true; - API_NOP_END; - API_END; + if (new_body_ptr) return CUBIT_SUCCESS; + else return CUBIT_FAILURE; - //if resultant bodies overlap...use appropriate webcut function - if( overlap ) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(copy_webcut_BODY1, not_new_ids); - AcisQueryEngine::instance()->delete_ACIS_BODY(copy_webcut_BODY2, not_new_ids); - - CubitStatus stat = AcisModifyEngine::webcut_BODY( webcut_body, - sheet_body, - copy_webcut_BODY1, - copy_webcut_BODY2); - if( stat == CUBIT_FAILURE ) - return CUBIT_FAILURE; } - } + //------------------------------------------------------------------------- + // Purpose : clean RefEntity + // + // Special Notes : + // + // Creator : Lingyun Pan (CAT) + // + // Creation Date : 07/15/01 + //------------------------------------------------------------------------- - //okay everything should be okay now. - if ( imprint == CUBIT_TRUE ) - { - CubitStatus stat = imprint_BODYs( copy_webcut_BODY1, - copy_webcut_BODY2 ); - if ( stat != CUBIT_SUCCESS || - copy_webcut_BODY1 == NULL || - copy_webcut_BODY2 == NULL ) + CubitStatus AcisModifyEngine::regularize_entity( GeometryEntity *old_refentity_ptr, + BodySM *&new_body_ptr) { - PRINT_ERROR("Error in webcutting volume with sheet.\n"); - return CUBIT_FAILURE; - } - } - webcut_body_1 = copy_webcut_BODY1; - webcut_body_2 = copy_webcut_BODY2; - AcisQueryEngine::instance()->clear_bounding_box( webcut_body_1 ); - AcisQueryEngine::instance()->bounding_box( webcut_body_1 ); - AcisQueryEngine::instance()->clear_bounding_box( webcut_body_2 ); - AcisQueryEngine::instance()->bounding_box( webcut_body_2 ); + CubitBoolean new_ids = GeometryModifyTool::instance()->get_new_ids(); + CubitBoolean not_new_ids = (new_ids ? CUBIT_FALSE : CUBIT_TRUE); - return CUBIT_SUCCESS; -} + BODY *copied_BODY_ptr; + SurfaceACIS *ref_face = CAST_TO(old_refentity_ptr, SurfaceACIS); + CurveACIS *ref_edge= CAST_TO(old_refentity_ptr, CurveACIS); + PointACIS *ref_vertex= CAST_TO(old_refentity_ptr, PointACIS); -CubitStatus -AcisModifyEngine::webcut_with_extended_surf( DLIList<BodySM*> &webcut_body_list, - Surface *extend_from, - DLIList<BodySM*> &new_bodies, - int &num_cut, - bool imprint ) -{ - //now lets create a new extended face from the surface. - SurfaceACIS *surf_ACIS = CAST_TO(extend_from, SurfaceACIS ); - if(!surf_ACIS) - { - PRINT_ERROR("Couldn't extend face to use for webcutting.\n" - "Possible incompatible geometry engine for this operation.\n"); - return CUBIT_FAILURE; - } - FACE *extend_from_FACE = surf_ACIS->get_FACE_ptr(); + DLIList<SurfaceACIS*> reg_face_list; + DLIList<FACE*> FACE_list; - FACE *extended_FACE = make_FACE( extend_from_FACE, CUBIT_TRUE ); - if ( extended_FACE == NULL ) - { - PRINT_ERROR("Couldn't extend face to use for webcutting.\n"); - return CUBIT_FAILURE; - } - BodySM *webcut_body; - DLIList<BodySM*> temp_new_bodies; - num_cut = 0; - for ( int ii = webcut_body_list.size(); ii > 0; ii-- ) - { - webcut_body = webcut_body_list.remove(); - BODY *tool_BODY = AcisQueryEngine::instance()->get_BODY_of_ENTITY(extended_FACE); - BODY *webcut_BODY = AcisQueryEngine::get_BODY(webcut_body ); - //now webcut with it. - BODY *new_BODY_1, *new_BODY_2; - CubitStatus status = webcut_with_sheet( webcut_BODY, - tool_BODY, - new_BODY_1, - new_BODY_2, - imprint ); - if ( status == CUBIT_SUCCESS ) - { - DLIList<BODY*> new_BODY_list; - new_BODY_list.append(new_BODY_1); - new_BODY_list.append(new_BODY_2); - temp_new_bodies.clean_out(); + DLIList<CurveACIS*> reg_edge_list; + DLIList<EDGE*> EDGE_list; - CubitStatus result = get_new_Body(webcut_body, webcut_BODY, - new_BODY_list, temp_new_bodies, - CUBIT_FALSE); - if ( result != CUBIT_SUCCESS ) - { - PRINT_ERROR("Problems with building volume.\n"); - num_cut = 0; - return CUBIT_FAILURE; - } - else - { - new_bodies += temp_new_bodies; - num_cut++; - } - } - } - return CUBIT_SUCCESS; -} + DLIList<PointACIS*> reg_vertex_list; + DLIList<VERTEX*> VERTEX_list; -CubitStatus AcisModifyEngine::regularize_body( BodySM *body_ptr, - BodySM *&new_body_ptr) -{ - CubitBoolean new_ids = GeometryModifyTool::instance()->get_new_ids(); - CubitBoolean not_new_ids = (new_ids ? CUBIT_FALSE : CUBIT_TRUE); - - BODY *old_BODY = AcisQueryEngine::get_BODY(body_ptr ); - if (!old_BODY) - return CUBIT_FAILURE; - BODY *acis_BODY = this->copy_BODY(old_BODY, new_ids); - - outcome result = api_clean_entity( (ENTITY*) acis_BODY); - //outcome result = api_regularise_entity( (ENTITY*) acis_BODY); - if (!result.ok() || acis_BODY == NULL || - acis_BODY->lump() == NULL ) - { - PRINT_ERROR("found in AcisModifyEngine::regularize_body.\n" - "api_regularise_entity failed.\n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - AcisQueryEngine::instance()->delete_ACIS_BODY(acis_BODY, not_new_ids); - return CUBIT_FAILURE; - } - - new_body_ptr = get_new_Body(body_ptr, old_BODY, acis_BODY, false); - - if (new_body_ptr) return CUBIT_SUCCESS; - else return CUBIT_FAILURE; - -} -//------------------------------------------------------------------------- -// Purpose : clean RefEntity -// -// Special Notes : -// -// Creator : Lingyun Pan (CAT) -// -// Creation Date : 07/15/01 -//------------------------------------------------------------------------- - -CubitStatus AcisModifyEngine::regularize_entity( GeometryEntity *old_refentity_ptr, - BodySM *&new_body_ptr) -{ - CubitBoolean new_ids = GeometryModifyTool::instance()->get_new_ids(); - CubitBoolean not_new_ids = (new_ids ? CUBIT_FALSE : CUBIT_TRUE); - - BODY *copied_BODY_ptr; - SurfaceACIS *ref_face = CAST_TO(old_refentity_ptr, SurfaceACIS); - CurveACIS *ref_edge= CAST_TO(old_refentity_ptr, CurveACIS); - PointACIS *ref_vertex= CAST_TO(old_refentity_ptr, PointACIS); - - DLIList<SurfaceACIS*> reg_face_list; - DLIList<FACE*> FACE_list; - - DLIList<CurveACIS*> reg_edge_list; - DLIList<EDGE*> EDGE_list; - - DLIList<PointACIS*> reg_vertex_list; - DLIList<VERTEX*> VERTEX_list; - - // get the copied_BODY_ptr and FACE_list to clean - if (ref_face) - { + // get the copied_BODY_ptr and FACE_list to clean + if (ref_face) + { reg_face_list.append(ref_face); - if (get_copied_FACES_of_body( reg_face_list, FACE_list, copied_BODY_ptr )== CUBIT_FAILURE ) - { - PRINT_ERROR("Surface has no volume associated with it.\n"); - return CUBIT_FAILURE; - } - } + if (get_copied_FACES_of_body( reg_face_list, FACE_list, copied_BODY_ptr )== CUBIT_FAILURE ) + { + PRINT_ERROR("Surface has no volume associated with it.\n"); + return CUBIT_FAILURE; + } + } -// get the copied_BODY_ptr and EDGE_list to clean - if (ref_edge) - { + // get the copied_BODY_ptr and EDGE_list to clean + if (ref_edge) + { reg_edge_list.append(ref_edge); - if(get_copied_EDGES_of_body( reg_edge_list, EDGE_list, copied_BODY_ptr )== CUBIT_FAILURE ) - { - PRINT_ERROR("Edge has no volume associated with it.\n"); - return CUBIT_FAILURE; - } - } + if(get_copied_EDGES_of_body( reg_edge_list, EDGE_list, copied_BODY_ptr )== CUBIT_FAILURE ) + { + PRINT_ERROR("Edge has no volume associated with it.\n"); + return CUBIT_FAILURE; + } + } - if (ref_vertex) - { + if (ref_vertex) + { reg_vertex_list.append(ref_vertex); - if (get_copied_VERTICES_of_body( reg_vertex_list, VERTEX_list, copied_BODY_ptr )== CUBIT_FAILURE ) - { - PRINT_ERROR("Vertex has no volume associated with it.\n"); - return CUBIT_FAILURE; - } - } + if (get_copied_VERTICES_of_body( reg_vertex_list, VERTEX_list, copied_BODY_ptr )== CUBIT_FAILURE ) + { + PRINT_ERROR("Vertex has no volume associated with it.\n"); + return CUBIT_FAILURE; + } + } - if (!ref_face && !ref_edge && !ref_vertex) - { + if (!ref_face && !ref_edge && !ref_vertex) + { //complain - PRINT_ERROR("RefEntity is neither a RefEdge, RefFace, nor RefVertex.\n"); + PRINT_ERROR("RefEntity is neither a RefEdge, RefFace, nor RefVertex.\n"); PRINT_ERROR("found in AcisModifyEngine::regularize_refentity.\n" - "api_regularise_refentity aborted.\n"); + "api_regularise_refentity aborted.\n"); AcisQueryEngine::instance()->delete_ACIS_BODY(copied_BODY_ptr, not_new_ids); - return CUBIT_FAILURE; - } + return CUBIT_FAILURE; + } - // Get original Body and BODY - BodySM *body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( copied_BODY_ptr ); + // Get original Body and BODY + BodySM *body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( copied_BODY_ptr ); - BODY *BODY_ptr = AcisQueryEngine::get_BODY(body_ptr); + BODY *BODY_ptr = AcisQueryEngine::get_BODY(body_ptr); - int i; - FACE *acis_FACE; - EDGE *acis_EDGE; - VERTEX *acis_VERTEX; + int i; + FACE *acis_FACE; + EDGE *acis_EDGE; + VERTEX *acis_VERTEX; - //clean FACE - for (i=0;i<FACE_list.size();i++) - { + //clean FACE + for (i=0;i<FACE_list.size();i++) + { acis_FACE = FACE_list.get_and_step(); outcome result = api_clean_entity( (ENTITY*) acis_FACE); if (!result.ok() || acis_FACE == NULL ) - { - PRINT_ERROR("found in AcisModifyEngine::regularize_refentity.\n" - "api_regularise_refentity failed.\n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - AcisQueryEngine::instance()->delete_ACIS_BODY(copied_BODY_ptr, not_new_ids); - return CUBIT_FAILURE; - } - } + { + PRINT_ERROR("found in AcisModifyEngine::regularize_refentity.\n" + "api_regularise_refentity failed.\n"); + AcisQueryEngine::instance()->ACIS_API_error (result); + AcisQueryEngine::instance()->delete_ACIS_BODY(copied_BODY_ptr, not_new_ids); + return CUBIT_FAILURE; + } + } - // clean EDGE - for (i=0;i<EDGE_list.size();i++) - { + // clean EDGE + for (i=0;i<EDGE_list.size();i++) + { acis_EDGE = EDGE_list.get_and_step(); outcome result = api_clean_entity( (ENTITY*) acis_EDGE); if (!result.ok() || acis_EDGE == NULL ) - { - PRINT_ERROR("found in AcisModifyEngine::regularize_refentity.\n" - "api_regularise_refentity failed.\n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - AcisQueryEngine::instance()->delete_ACIS_BODY(copied_BODY_ptr, not_new_ids); - return CUBIT_FAILURE; - } - } + { + PRINT_ERROR("found in AcisModifyEngine::regularize_refentity.\n" + "api_regularise_refentity failed.\n"); + AcisQueryEngine::instance()->ACIS_API_error (result); + AcisQueryEngine::instance()->delete_ACIS_BODY(copied_BODY_ptr, not_new_ids); + return CUBIT_FAILURE; + } + } - // clean VERTEX - for (i=0;i<VERTEX_list.size();i++) - { + // clean VERTEX + for (i=0;i<VERTEX_list.size();i++) + { acis_VERTEX = VERTEX_list.get_and_step(); outcome result = api_clean_entity( (ENTITY*) acis_VERTEX); if (!result.ok() || acis_VERTEX == NULL ) - { - PRINT_ERROR("found in AcisModifyEngine::regularize_refentity.\n" - "api_regularise_refentity failed.\n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - AcisQueryEngine::instance()->delete_ACIS_BODY(copied_BODY_ptr, not_new_ids); - return CUBIT_FAILURE; - } - } - //rebuild the cubit geometry - new_body_ptr = get_new_Body( body_ptr, BODY_ptr , copied_BODY_ptr , false); - if (new_body_ptr) return CUBIT_SUCCESS; - else return CUBIT_FAILURE; -} + { + PRINT_ERROR("found in AcisModifyEngine::regularize_refentity.\n" + "api_regularise_refentity failed.\n"); + AcisQueryEngine::instance()->ACIS_API_error (result); + AcisQueryEngine::instance()->delete_ACIS_BODY(copied_BODY_ptr, not_new_ids); + return CUBIT_FAILURE; + } + } + //rebuild the cubit geometry + new_body_ptr = get_new_Body( body_ptr, BODY_ptr , copied_BODY_ptr , false); + if (new_body_ptr) return CUBIT_SUCCESS; + else return CUBIT_FAILURE; + } -CubitStatus AcisModifyEngine::split_body( BodySM *body_ptr, - DLIList<BodySM*> &new_bodies ) -{ - bool delete_attribs = GeometryModifyTool::instance()->get_new_ids() != 0; - //get the acis body. - BODY* acis_BODY = NULL; - BODY **new_BODY_list; - int n_body; + CubitStatus AcisModifyEngine::split_body( BodySM *body_ptr, + DLIList<BodySM*> &new_bodies ) + { + bool delete_attribs = GeometryModifyTool::instance()->get_new_ids() != 0; + //get the acis body. + BODY* acis_BODY = NULL; + BODY **new_BODY_list; + int n_body; - BODY *old_BODY = AcisQueryEngine::get_BODY(body_ptr ); - acis_BODY = this->copy_BODY(old_BODY, delete_attribs); + BODY *old_BODY = AcisQueryEngine::get_BODY(body_ptr ); + acis_BODY = this->copy_BODY(old_BODY, delete_attribs); - outcome result = api_separate_body( acis_BODY, n_body, new_BODY_list ); + outcome result = api_separate_body( acis_BODY, n_body, new_BODY_list ); - if (!result.ok()) - { - PRINT_ERROR("Error in seperating volumes.\n"); - AcisQueryEngine::instance()->delete_ACIS_BODY(acis_BODY, CUBIT_TRUE); - return CUBIT_FAILURE; - } + if (!result.ok()) + { + PRINT_ERROR("Error in seperating volumes.\n"); + AcisQueryEngine::instance()->delete_ACIS_BODY(acis_BODY, CUBIT_TRUE); + return CUBIT_FAILURE; + } - DLIList<BODY*> new_BODYs; - for (int i = 0; i < n_body; i++) - new_BODYs.append(new_BODY_list[i]); + DLIList<BODY*> new_BODYs; + for (int i = 0; i < n_body; i++) + new_BODYs.append(new_BODY_list[i]); - CubitStatus status = get_new_Body(body_ptr, old_BODY, - new_BODYs, new_bodies, - CUBIT_FALSE); - return status; -} + CubitStatus status = get_new_Body(body_ptr, old_BODY, + new_BODYs, new_bodies, + CUBIT_FALSE); + return status; + } -CubitStatus AcisModifyEngine::split_periodic( BodySM *body_ptr, - BodySM *&new_body) -{ + CubitStatus AcisModifyEngine::split_periodic( BodySM *body_ptr, + BodySM *&new_body) + { - BODY* acis_BODY = NULL; + BODY* acis_BODY = NULL; - //get the ACIS BODY of tool_body - BODY *old_BODY = AcisQueryEngine::get_BODY( body_ptr ); - acis_BODY = this->copy_BODY(old_BODY, - GeometryModifyTool::instance()->get_new_ids()); + //get the ACIS BODY of tool_body + BODY *old_BODY = AcisQueryEngine::get_BODY( body_ptr ); + acis_BODY = this->copy_BODY(old_BODY, + GeometryModifyTool::instance()->get_new_ids()); - outcome some_result = api_split_periodic_faces( acis_BODY ); + outcome some_result = api_split_periodic_faces( acis_BODY ); - if ( acis_BODY == NULL || !some_result.ok() ) - { - if (acis_BODY != NULL ) - AcisQueryEngine::instance()->delete_ACIS_BODY( acis_BODY ); + if ( acis_BODY == NULL || !some_result.ok() ) + { + if (acis_BODY != NULL ) + AcisQueryEngine::instance()->delete_ACIS_BODY( acis_BODY ); - PRINT_ERROR("Unable to split periodic surface.\n"); - return CUBIT_FAILURE; - } + PRINT_ERROR("Unable to split periodic surface.\n"); + return CUBIT_FAILURE; + } - new_body = get_new_Body(body_ptr, old_BODY, acis_BODY, false); + new_body = get_new_Body(body_ptr, old_BODY, acis_BODY, false); - if ( new_body == NULL ) - { - PRINT_ERROR("Can not make a volume out of the split volumes.\n"); - return CUBIT_FAILURE; - } + if ( new_body == NULL ) + { + PRINT_ERROR("Can not make a volume out of the split volumes.\n"); + return CUBIT_FAILURE; + } - else return CUBIT_SUCCESS; -} + else return CUBIT_SUCCESS; + } -EDGE * -AcisModifyEngine::make_spline_EDGE( DLIList<CubitVector*> &vec_list ) -{ - int i; - EDGE *new_EDGE_ptr = NULL; + EDGE * + AcisModifyEngine::make_spline_EDGE( DLIList<CubitVector*> &vec_list ) + { + int i; + EDGE *new_EDGE_ptr = NULL; - // Create a spline - int num_pnts = vec_list.size(); - SPAposition* pos_array = new SPAposition[num_pnts]; + // Create a spline + int num_pnts = vec_list.size(); + SPAposition* pos_array = new SPAposition[num_pnts]; - // Fill the vector_list of points - vec_list.reset(); - for( i=0; i<num_pnts; i++) - { - // Set the coordinates of the SPAposition object - pos_array[i].set_x(vec_list.get()->x()); - pos_array[i].set_y(vec_list.get()->y()); - pos_array[i].set_z(vec_list.get()->z()); - vec_list.step(); - } + // Fill the vector_list of points + vec_list.reset(); + for( i=0; i<num_pnts; i++) + { + // Set the coordinates of the SPAposition object + pos_array[i].set_x(vec_list.get()->x()); + pos_array[i].set_y(vec_list.get()->y()); + pos_array[i].set_z(vec_list.get()->z()); + vec_list.step(); + } - outcome result = api_curve_spline(num_pnts, pos_array, NULL, NULL, new_EDGE_ptr); - delete [] pos_array; - if( !result.ok() || new_EDGE_ptr == NULL ) - { - get_acis_query_engine()->ACIS_API_error(result); - PRINT_ERROR( "unable to make spline from list of positions\n" ); - return NULL; - } + outcome result = api_curve_spline(num_pnts, pos_array, NULL, NULL, new_EDGE_ptr); + delete [] pos_array; + if( !result.ok() || new_EDGE_ptr == NULL ) + { + get_acis_query_engine()->ACIS_API_error(result); + PRINT_ERROR( "unable to make spline from list of positions\n" ); + return NULL; + } - return new_EDGE_ptr; -} + return new_EDGE_ptr; + } -//------------------------------------------------------------------------- -// Purpose : Reverse the ACIS BODY -// -// Special Notes : Moved from BodyACIS - j.k, 2004-5-25 -// -// Creator : Tim Tautges -// -// Creation Date : 3/18/97 -//------------------------------------------------------------------------- -CubitStatus AcisModifyEngine::reverse_body( BodySM* body_to_reverse ) -{ - BODY* body_ptr = AcisQueryEngine::get_BODY( body_to_reverse ); - if (!body_ptr) - return CUBIT_FAILURE; + //------------------------------------------------------------------------- + // Purpose : Reverse the ACIS BODY + // + // Special Notes : Moved from BodyACIS - j.k, 2004-5-25 + // + // Creator : Tim Tautges + // + // Creation Date : 3/18/97 + //------------------------------------------------------------------------- + CubitStatus AcisModifyEngine::reverse_body( BodySM* body_to_reverse ) + { + BODY* body_ptr = AcisQueryEngine::get_BODY( body_to_reverse ); + if (!body_ptr) + return CUBIT_FAILURE; - outcome result = api_reverse_body( body_ptr ); - if (!result.ok()) - { - AcisQueryEngine::instance()->ACIS_API_error( result, "reversing BODY." ); - return CUBIT_FAILURE; - } + outcome result = api_reverse_body( body_ptr ); + if (!result.ok()) + { + AcisQueryEngine::instance()->ACIS_API_error( result, "reversing BODY." ); + return CUBIT_FAILURE; + } - return CUBIT_SUCCESS; -} + return CUBIT_SUCCESS; + } -void AcisModifyEngine::webcut_cleanup( DLIList<BodySM*>& body_list, + void AcisModifyEngine::webcut_cleanup( DLIList<BodySM*>& body_list, ENTITY_LIST& BODY_list) const -{ - // This procedure is called by webcut_handler and gets rid of - // all the Body's and Acis BODY's created during the execution - // of the webcut command. The command was unsuccessful and hence, - // these entities need to be removed so the system can be returned - // to its state before the command was invoked. + { + // This procedure is called by webcut_handler and gets rid of + // all the Body's and Acis BODY's created during the execution + // of the webcut command. The command was unsuccessful and hence, + // these entities need to be removed so the system can be returned + // to its state before the command was invoked. - // Delete the Bodies - AcisQueryEngine::instance()->delete_solid_model_entities(body_list); - //GeometryQueryTool::instance()->delete_Body(body_list, CUBIT_TRUE); + // Delete the Bodies + AcisQueryEngine::instance()->delete_solid_model_entities(body_list); + //GeometryQueryTool::instance()->delete_Body(body_list, CUBIT_TRUE); - // Delete the Acis BODYs - AcisQueryEngine::instance()->delete_ACIS_BODY(BODY_list); + // Delete the Acis BODYs + AcisQueryEngine::instance()->delete_ACIS_BODY(BODY_list); - return; + return; -} + } -void AcisModifyEngine::webcut_imprint( - BODY* cutting_tool_BODY_ptr, - DLIList<BodySM*> &old_body_list, - DLIList<BODY*>& new_webcut_BODY_list, - DLIList<BODY*>& just_webcut_BODY_list, - DLIList<BodySM*>& results_list, - DLIList<BodySM*> &imprinted_Body_from_Model_list, - DLIList<BODY*> &imprinted_BODY_from_Model_list) const -{ - // This procedure takes care of the imprint operations that are required - // by the webcut operation. Each of the BODYs in the new_webcut_BODY_list - // is tested against every other BODY in the model as well as every other - // BODY in the same list for interference. If interference exists, then - // the BODYs are imprinted with each other and new (corresponding) Bodies - // are created. Pointers to these new Bodies are inserted into the list, - // new_webcut_body_list. + void AcisModifyEngine::webcut_imprint( + BODY* cutting_tool_BODY_ptr, + DLIList<BodySM*> &old_body_list, + DLIList<BODY*>& new_webcut_BODY_list, + DLIList<BODY*>& just_webcut_BODY_list, + DLIList<BodySM*>& results_list, + DLIList<BodySM*> &imprinted_Body_from_Model_list, + DLIList<BODY*> &imprinted_BODY_from_Model_list) const + { + // This procedure takes care of the imprint operations that are required + // by the webcut operation. Each of the BODYs in the new_webcut_BODY_list + // is tested against every other BODY in the model as well as every other + // BODY in the same list for interference. If interference exists, then + // the BODYs are imprinted with each other and new (corresponding) Bodies + // are created. Pointers to these new Bodies are inserted into the list, + // new_webcut_body_list. - // MJP Note: - // Note that this procedure takes care of imprinting the existing Bodies - // (i.e., the ones in the model) and creating new Bodies when necessary - // to replace these. However, new Body's are *not* created from the list - // of ACIS BODYs in the input list, new_webcut_BODY_list. These are simply - // returned to the calling routine, where it is expected that new Bodies - // will be created, as required. + // MJP Note: + // Note that this procedure takes care of imprinting the existing Bodies + // (i.e., the ones in the model) and creating new Bodies when necessary + // to replace these. However, new Body's are *not* created from the list + // of ACIS BODYs in the input list, new_webcut_BODY_list. These are simply + // returned to the calling routine, where it is expected that new Bodies + // will be created, as required. - int webcut_debug_flag = 18; - int webcut_debug_flag_on = DEBUG_FLAG(webcut_debug_flag); + int webcut_debug_flag = 18; + int webcut_debug_flag_on = DEBUG_FLAG(webcut_debug_flag); - int i = 0; - int j = 0; + int i = 0; + int j = 0; - // Make copies of the input BODYs - DLIList<BODY*> copy_new_webcut_BODY_list ; - DLIList<BODY*> new_results_BODYS; - new_webcut_BODY_list.reset() ; - for (i = 0; i < new_webcut_BODY_list.size() ; i++) - { - BODY* old_BODY = new_webcut_BODY_list.get_and_step() ; - BODY* new_BODY = this->copy_BODY(old_BODY, - GeometryModifyTool::instance()->get_new_ids()) ; + // Make copies of the input BODYs + DLIList<BODY*> copy_new_webcut_BODY_list ; + DLIList<BODY*> new_results_BODYS; + new_webcut_BODY_list.reset() ; + for (i = 0; i < new_webcut_BODY_list.size() ; i++) + { + BODY* old_BODY = new_webcut_BODY_list.get_and_step() ; + BODY* new_BODY = this->copy_BODY(old_BODY, + GeometryModifyTool::instance()->get_new_ids()) ; - // Make sure the the new BODY is a valid BODY - assert( new_BODY != NULL) ; + // Make sure the the new BODY is a valid BODY + assert( new_BODY != NULL) ; - // Add the new BODY to the backup list - copy_new_webcut_BODY_list.append(new_BODY) ; - } + // Add the new BODY to the backup list + copy_new_webcut_BODY_list.append(new_BODY) ; + } - // Loop over each of the new BODYs and imprint it with any other new BODY - // that touches it. - BODY* first_BODY_ptr = NULL; - BODY* second_BODY_ptr = NULL; - copy_new_webcut_BODY_list.reset() ; - for (i = 0; i < (copy_new_webcut_BODY_list.size() - 1); i++) - { - // Get the first BODY - first_BODY_ptr = copy_new_webcut_BODY_list.get_and_step(); + // Loop over each of the new BODYs and imprint it with any other new BODY + // that touches it. + BODY* first_BODY_ptr = NULL; + BODY* second_BODY_ptr = NULL; + copy_new_webcut_BODY_list.reset() ; + for (i = 0; i < (copy_new_webcut_BODY_list.size() - 1); i++) + { + // Get the first BODY + first_BODY_ptr = copy_new_webcut_BODY_list.get_and_step(); - for (j = (i + 1); j < copy_new_webcut_BODY_list.size(); j++) - { - // Get the second BODY - second_BODY_ptr = copy_new_webcut_BODY_list.get_and_step(); + for (j = (i + 1); j < copy_new_webcut_BODY_list.size(); j++) + { + // Get the second BODY + second_BODY_ptr = copy_new_webcut_BODY_list.get_and_step(); - // If these BODYs touch, then imprint them - CubitBoolean result_interfer = - BODYs_interfering( first_BODY_ptr,second_BODY_ptr ); + // If these BODYs touch, then imprint them + CubitBoolean result_interfer = + BODYs_interfering( first_BODY_ptr,second_BODY_ptr ); - if ( result_interfer == CUBIT_TRUE ) - { - CubitStatus resultImprint = - imprint_BODYs( first_BODY_ptr, second_BODY_ptr ); + if ( result_interfer == CUBIT_TRUE ) + { + CubitStatus resultImprint = + imprint_BODYs( first_BODY_ptr, second_BODY_ptr ); - if( resultImprint == CUBIT_FAILURE ) - { - PRINT_WARNING ("Imprint operation failed.\n" - " Going back to the previous state"); + if( resultImprint == CUBIT_FAILURE ) + { + PRINT_WARNING ("Imprint operation failed.\n" + " Going back to the previous state"); - // Delete the new BODYs and return. - copy_new_webcut_BODY_list.reset() ; - for (int k = 0 ; k < copy_new_webcut_BODY_list.size() ; k++) - { - first_BODY_ptr = copy_new_webcut_BODY_list.get_and_step() ; - AcisQueryEngine::instance()->delete_ACIS_BODY(first_BODY_ptr) ; - } - return ; - } - } - } + // Delete the new BODYs and return. + copy_new_webcut_BODY_list.reset() ; + for (int k = 0 ; k < copy_new_webcut_BODY_list.size() ; k++) + { + first_BODY_ptr = copy_new_webcut_BODY_list.get_and_step() ; + AcisQueryEngine::instance()->delete_ACIS_BODY(first_BODY_ptr) ; + } + return ; + } + } + } - // Go to the (i+1)th element of the list - copy_new_webcut_BODY_list.reset() ; - copy_new_webcut_BODY_list.step(i+1) ; + // Go to the (i+1)th element of the list + copy_new_webcut_BODY_list.reset() ; + copy_new_webcut_BODY_list.step(i+1) ; - } + } -/* - CDE-- commented out this code. For now, we've decided that when webcutting - with the 'imprint' option, the imprint should occur between bodies involved - in the webcut. This code was imprinting all resulting pieces of the webcut - with all the other Bodies in the model. + /* + CDE-- commented out this code. For now, we've decided that when webcutting + with the 'imprint' option, the imprint should occur between bodies involved + in the webcut. This code was imprinting all resulting pieces of the webcut + with all the other Bodies in the model. - // Get the Bodys in the Model - DLIList<Body*> Body_in_Model_list_tmp; - GeometryQueryTool::instance()->bodies(Body_in_Model_list_tmp); - DLIList<BodySM*> Body_in_Model_list; - Body_in_Model_list_tmp.reset(); - for (i = Body_in_Model_list_tmp.size(); i--; ) - Body_in_Model_list.append( Body_in_Model_list_tmp.get_and_step()->get_body_sm_ptr()); + // Get the Bodys in the Model + DLIList<Body*> Body_in_Model_list_tmp; + GeometryQueryTool::instance()->bodies(Body_in_Model_list_tmp); + DLIList<BodySM*> Body_in_Model_list; + Body_in_Model_list_tmp.reset(); + for (i = Body_in_Model_list_tmp.size(); i--; ) + Body_in_Model_list.append( Body_in_Model_list_tmp.get_and_step()->get_body_sm_ptr()); - // Loop over each of the new BODYs and imprint it with any of the - // BODYs already existing in the model, if they touch. + // Loop over each of the new BODYs and imprint it with any of the + // BODYs already existing in the model, if they touch. - // List of new imprinted BODYs -- Bodies need to be created from these - DLIList<BODY*> copy_imprinted_BODY_from_Model_list; + // List of new imprinted BODYs -- Bodies need to be created from these + DLIList<BODY*> copy_imprinted_BODY_from_Model_list; - BodySM* model_Body_ptr = NULL; - BODY* model_BODY_ptr = NULL; - BODY* new_model_BODY_ptr = NULL; - BODY* new_BODY_ptr = NULL ; - int copy_made = CUBIT_FALSE; + BodySM* model_Body_ptr = NULL; + BODY* model_BODY_ptr = NULL; + BODY* new_model_BODY_ptr = NULL; + BODY* new_BODY_ptr = NULL ; + int copy_made = CUBIT_FALSE; - Body_in_Model_list.reset(); - // Loop over all the existing Bodies - for (i = 0; i < Body_in_Model_list.size(); i++) - { + Body_in_Model_list.reset(); + // Loop over all the existing Bodies + for (i = 0; i < Body_in_Model_list.size(); i++) + { // Get this existing Body's parent ACIS BODY - model_Body_ptr = Body_in_Model_list.get_and_step() ; - model_BODY_ptr = AcisQueryEngine::get_BODY(model_Body_ptr) ; + model_Body_ptr = Body_in_Model_list.get_and_step() ; + model_BODY_ptr = AcisQueryEngine::get_BODY(model_Body_ptr) ; // Make sure that model_BODY_ptr is not the Cutting Tool as the // user is allowed to use an existing Body as a Cutting Tool. // If this is the case, then don't involve it in the imprint // operations. - if (model_BODY_ptr == cutting_tool_BODY_ptr || old_body_list.move_to(model_Body_ptr)) - { - // Don't do anything - continue; - } + if (model_BODY_ptr == cutting_tool_BODY_ptr || old_body_list.move_to(model_Body_ptr)) + { + // Don't do anything + continue; + } // Loop over all the newly created (by webcutting) ACIS BODYs and test // the existing Body against them (for imprinting purposes, if there // is interference) - copy_made = CUBIT_FALSE; - new_model_BODY_ptr = NULL; - copy_new_webcut_BODY_list.reset(); + copy_made = CUBIT_FALSE; + new_model_BODY_ptr = NULL; + copy_new_webcut_BODY_list.reset(); - for (j = 0; j < copy_new_webcut_BODY_list.size(); j++) - { - // Get the BODY that we're going to test the existing Body against - new_BODY_ptr = copy_new_webcut_BODY_list.get_and_step() ; + for (j = 0; j < copy_new_webcut_BODY_list.size(); j++) + { + // Get the BODY that we're going to test the existing Body against + new_BODY_ptr = copy_new_webcut_BODY_list.get_and_step() ; - // DEBUG stuff - if (webcut_debug_flag_on) - { - //Save the two BODYs - AcisQueryEngine::instance()->save_ENTITY_as_sat_file(new_BODY_ptr, "BODY1.sat", "w"); - AcisQueryEngine::instance()->save_ENTITY_as_sat_file(model_BODY_ptr, "BODY2.sat", "w"); - } + // DEBUG stuff + if (webcut_debug_flag_on) + { + //Save the two BODYs + AcisQueryEngine::instance()->save_ENTITY_as_sat_file(new_BODY_ptr, "BODY1.sat", "w"); + AcisQueryEngine::instance()->save_ENTITY_as_sat_file(model_BODY_ptr, "BODY2.sat", "w"); + } - // If these BODYs touch, then ... - if ( BODYs_interfering(new_BODY_ptr, model_BODY_ptr) == CUBIT_TRUE ) - { - // DEBUG stuff - if (webcut_debug_flag_on) - { - AcisQueryEngine::instance()->save_ENTITY_as_sat_file(new_BODY_ptr, - "BODY1_after_test.sat", - "w"); - AcisQueryEngine::instance()->save_ENTITY_as_sat_file(new_model_BODY_ptr, - "BODY2_after_test.sat", - "w"); - } + // If these BODYs touch, then ... + if ( BODYs_interfering(new_BODY_ptr, model_BODY_ptr) == CUBIT_TRUE ) + { + // DEBUG stuff + if (webcut_debug_flag_on) + { + AcisQueryEngine::instance()->save_ENTITY_as_sat_file(new_BODY_ptr, + "BODY1_after_test.sat", + "w"); + AcisQueryEngine::instance()->save_ENTITY_as_sat_file(new_model_BODY_ptr, + "BODY2_after_test.sat", + "w"); + } - // Because of the fact that the RefEntity datastructure is - // nonmanifold and hence shares underlying ACIS ENTITYs, I have to: - // a) make a copy of the parent ACIS BODY of the Body being - // deactivated (this is done only once for the inner loop) - // b) then all imprinting is done with this copy instead of - // with the original parent ACIS BODY. - // deactivateRefStructure takes care of detaching the RefEntities - // and their associated ACIS ENTITYs (removing the double links - // between them). - if (!copy_made) // Make this copy at most once per outer loop iteration - { - // Make a copy of the parent ACIS BODY. - new_model_BODY_ptr = this->copy_BODY(model_BODY_ptr, - GeometryModifyTool::instance()->get_new_ids()); + // Because of the fact that the RefEntity datastructure is + // nonmanifold and hence shares underlying ACIS ENTITYs, I have to: + // a) make a copy of the parent ACIS BODY of the Body being + // deactivated (this is done only once for the inner loop) + // b) then all imprinting is done with this copy instead of + // with the original parent ACIS BODY. + // deactivateRefStructure takes care of detaching the RefEntities + // and their associated ACIS ENTITYs (removing the double links + // between them). + if (!copy_made) // Make this copy at most once per outer loop iteration + { + // Make a copy of the parent ACIS BODY. + new_model_BODY_ptr = this->copy_BODY(model_BODY_ptr, + GeometryModifyTool::instance()->get_new_ids()); - // Make sure a valid copy was made. If not, then we need to exit - // this loop (i.e., stop testing this Body for imprinting - // and go on to the next one). - if (new_model_BODY_ptr == NULL) - { - PRINT_ERROR("Cannot test imprinting for volume.\n" ); - break; - } - else - { - copy_made = CUBIT_TRUE; - if ( results_list.move_to(model_Body_ptr) ) - new_results_BODYS.append( new_model_BODY_ptr ); - imprinted_Body_from_Model_list.append(model_Body_ptr) ; - imprinted_BODY_from_Model_list.append(model_BODY_ptr) ; - copy_imprinted_BODY_from_Model_list.append(new_model_BODY_ptr) ; - } - } + // Make sure a valid copy was made. If not, then we need to exit + // this loop (i.e., stop testing this Body for imprinting + // and go on to the next one). + if (new_model_BODY_ptr == NULL) + { + PRINT_ERROR("Cannot test imprinting for volume.\n" ); + break; + } + else + { + copy_made = CUBIT_TRUE; + if ( results_list.move_to(model_Body_ptr) ) + new_results_BODYS.append( new_model_BODY_ptr ); + imprinted_Body_from_Model_list.append(model_Body_ptr) ; + imprinted_BODY_from_Model_list.append(model_BODY_ptr) ; + copy_imprinted_BODY_from_Model_list.append(new_model_BODY_ptr) ; + } + } - // Imprint the BODYs (use the new copied BODY). If the imprint - // operation fails, the state of these BODYs is left unchanged. - if (imprint_BODYs(new_BODY_ptr, new_model_BODY_ptr) == CUBIT_SUCCESS ) - { - // DEBUG stuff, if the imprint operation succeeded. - if (webcut_debug_flag_on) - { - AcisQueryEngine::instance()->save_ENTITY_as_sat_file(new_BODY_ptr, - "BODY1_after_imprint.sat", - "w"); - AcisQueryEngine::instance()->save_ENTITY_as_sat_file(new_model_BODY_ptr, - "BODY2_after_imprint.sat", - "w"); - } - } + // Imprint the BODYs (use the new copied BODY). If the imprint + // operation fails, the state of these BODYs is left unchanged. + if (imprint_BODYs(new_BODY_ptr, new_model_BODY_ptr) == CUBIT_SUCCESS ) + { + // DEBUG stuff, if the imprint operation succeeded. + if (webcut_debug_flag_on) + { + AcisQueryEngine::instance()->save_ENTITY_as_sat_file(new_BODY_ptr, + "BODY1_after_imprint.sat", + "w"); + AcisQueryEngine::instance()->save_ENTITY_as_sat_file(new_model_BODY_ptr, + "BODY2_after_imprint.sat", + "w"); + } + } - else - { - PRINT_WARNING ("Imprint operation failed.\n" - " Going back to the previous state"); + else + { + PRINT_WARNING ("Imprint operation failed.\n" + " Going back to the previous state"); - // Delete the new BODYs and return. - copy_new_webcut_BODY_list.reset() ; - int k; - for (k = 0 ; k < copy_new_webcut_BODY_list.size() ; k++) - { - new_BODY_ptr = copy_new_webcut_BODY_list.get_and_step() ; - AcisQueryEngine::instance()->delete_ACIS_BODY(first_BODY_ptr) ; - } + // Delete the new BODYs and return. + copy_new_webcut_BODY_list.reset() ; + int k; + for (k = 0 ; k < copy_new_webcut_BODY_list.size() ; k++) + { + new_BODY_ptr = copy_new_webcut_BODY_list.get_and_step() ; + AcisQueryEngine::instance()->delete_ACIS_BODY(first_BODY_ptr) ; + } - copy_imprinted_BODY_from_Model_list.reset() ; - for (k = 0 ; k < copy_imprinted_BODY_from_Model_list.size() ; k++) - { - new_model_BODY_ptr = copy_imprinted_BODY_from_Model_list.get_and_step() ; - AcisQueryEngine::instance()->delete_ACIS_BODY(new_model_BODY_ptr) ; - } + copy_imprinted_BODY_from_Model_list.reset() ; + for (k = 0 ; k < copy_imprinted_BODY_from_Model_list.size() ; k++) + { + new_model_BODY_ptr = copy_imprinted_BODY_from_Model_list.get_and_step() ; + AcisQueryEngine::instance()->delete_ACIS_BODY(new_model_BODY_ptr) ; + } - return ; - } - } - } // Loop over the new (webcut) BODYs + return ; + } + } + } // Loop over the new (webcut) BODYs - } // Loop over the existing Bodies in Model -*/ - // Now that we have come so far successfully, create the final list - // of new BODYs that will be used to create VGI Bodys. - new_webcut_BODY_list.clean_out() ; + } // Loop over the existing Bodies in Model + */ + // Now that we have come so far successfully, create the final list + // of new BODYs that will be used to create VGI Bodys. + new_webcut_BODY_list.clean_out() ; - // First the BODYs that were copies of the webcut BODYs - BODY* new_BODY_ptr = NULL ; - copy_new_webcut_BODY_list.reset() ; - for (i = 0 ; i < copy_new_webcut_BODY_list.size() ; i++) - { - new_BODY_ptr = copy_new_webcut_BODY_list.get_and_step() ; - new_webcut_BODY_list.append(new_BODY_ptr) ; - } - just_webcut_BODY_list = new_webcut_BODY_list; + // First the BODYs that were copies of the webcut BODYs + BODY* new_BODY_ptr = NULL ; + copy_new_webcut_BODY_list.reset() ; + for (i = 0 ; i < copy_new_webcut_BODY_list.size() ; i++) + { + new_BODY_ptr = copy_new_webcut_BODY_list.get_and_step() ; + new_webcut_BODY_list.append(new_BODY_ptr) ; + } + just_webcut_BODY_list = new_webcut_BODY_list; -/* - // Then the BODYs that were copies of Model BODYs - copy_imprinted_BODY_from_Model_list.reset() ; - for (i = 0 ; i < copy_imprinted_BODY_from_Model_list.size() ; i++) - { + /* + // Then the BODYs that were copies of Model BODYs + copy_imprinted_BODY_from_Model_list.reset() ; + for (i = 0 ; i < copy_imprinted_BODY_from_Model_list.size() ; i++) + { new_BODY_ptr = copy_imprinted_BODY_from_Model_list.get_and_step() ; new_webcut_BODY_list.append(new_BODY_ptr) ; - } -*/ - // now, two important lists: - // a) just_webcut_BODY_list: bodies in original bodies-to-be-webcut list - // that were modified, either by webcut or by imprint - // b) new_webcut_BODY_list: all bodies modified by webcut or imprint, - // including model bodies affected by imprint + } + */ + // now, two important lists: + // a) just_webcut_BODY_list: bodies in original bodies-to-be-webcut list + // that were modified, either by webcut or by imprint + // b) new_webcut_BODY_list: all bodies modified by webcut or imprint, + // including model bodies affected by imprint - return; -} + return; + } -BODY* AcisModifyEngine::create_infinite_plane_cutting_tool( - const CubitVector &input_p1, - const CubitVector &input_p2, - const CubitVector &input_p3, - const SPAbox& box_to_cut, - bool just_face ) const -{ - // Create a plane from the vertices - // Note: The old infinite plane code always swept in the opposite direction - // from the normal of the passed in points, so we create the plane with - // the points in opposite order. - CubitPlane p; - p.mk_plane_with_points(input_p3, input_p2, input_p1); + BODY* AcisModifyEngine::create_infinite_plane_cutting_tool( + const CubitVector &input_p1, + const CubitVector &input_p2, + const CubitVector &input_p3, + const SPAbox& box_to_cut, + bool just_face ) const + { + // Create a plane from the vertices + // Note: The old infinite plane code always swept in the opposite direction + // from the normal of the passed in points, so we create the plane with + // the points in opposite order. + CubitPlane p; + p.mk_plane_with_points(input_p3, input_p2, input_p1); - // Convert it to an ACIS plane - SPAunit_vector plane_normal(p.normal().x(), - p.normal().y(), - p.normal().z()); + // Convert it to an ACIS plane + SPAunit_vector plane_normal(p.normal().x(), + p.normal().y(), + p.normal().z()); - plane the_plane(SPAposition(input_p1.x(), - input_p1.y(), - input_p1.z()), - plane_normal); + plane the_plane(SPAposition(input_p1.x(), + input_p1.y(), + input_p1.z()), + plane_normal); - if (DEBUG_FLAG(18)) - PRINT_DEBUG_18( - "plane created with root point (%g %g %g) and\n" - " normal (%g %g %g).\n", - input_p1.x(), - input_p1.y(), - input_p1.z(), - plane_normal.x(), - plane_normal.y(), - plane_normal.z()); + if (DEBUG_FLAG(18)) + PRINT_DEBUG_18( + "plane created with root point (%g %g %g) and\n" + " normal (%g %g %g).\n", + input_p1.x(), + input_p1.y(), + input_p1.z(), + plane_normal.x(), + plane_normal.y(), + plane_normal.z()); - // Need to declare this up here so that it is outside of the API block - BODY* infinite_plane_BODY = NULL; - API_BEGIN; + // Need to declare this up here so that it is outside of the API block + BODY* infinite_plane_BODY = NULL; + API_BEGIN; - // Make a PLANE from it - PLANE* the_PLANE = new PLANE(the_plane); + // Make a PLANE from it + PLANE* the_PLANE = new PLANE(the_plane); - // Make a FACE out of it - FACE* planar_FACE = new FACE(NULL, NULL, the_PLANE, FORWARD); + // Make a FACE out of it + FACE* planar_FACE = new FACE(NULL, NULL, the_PLANE, FORWARD); - // Get the midpoint and diagonal length of the - // SPAbox this needs to fit around. Make diag length a little - // bigger than necessary as a buffer. - SPAposition midpoint = box_to_cut.mid(); - double diag_length = 1.01 * (box_to_cut.high() - midpoint).len(); + // Get the midpoint and diagonal length of the + // SPAbox this needs to fit around. Make diag length a little + // bigger than necessary as a buffer. + SPAposition midpoint = box_to_cut.mid(); + double diag_length = 1.01 * (box_to_cut.high() - midpoint).len(); - // Get the point on the plane that the SPAbox midpoint projects to. - ENTITY_LIST temp_list; - double distance; - double *dist_ptr = &distance; - ENTITY* entity_ptr = planar_FACE; - // Test points behind plane - result = api_ray_test_ents(midpoint, plane_normal, 1, 1, 1, &entity_ptr, - temp_list, dist_ptr); - if (!result.ok()) - { - AcisQueryEngine::instance()->ACIS_API_error(result); - } - if (temp_list.count() < 1) - { - // Test points in front of plane, if needed - result = api_ray_test_ents(midpoint, -plane_normal, 1, 1, 1, &entity_ptr, - temp_list, dist_ptr); - if (!result.ok()) - { - AcisQueryEngine::instance()->ACIS_API_error(result); - } - // Indicate that the distance is in front of the plane - distance = -distance; - } + // Get the point on the plane that the SPAbox midpoint projects to. + ENTITY_LIST temp_list; + double distance; + double *dist_ptr = &distance; + ENTITY* entity_ptr = planar_FACE; + // Test points behind plane + result = api_ray_test_ents(midpoint, plane_normal, 1, 1, 1, &entity_ptr, + temp_list, dist_ptr); + if (!result.ok()) + { + AcisQueryEngine::instance()->ACIS_API_error(result); + } + if (temp_list.count() < 1) + { + // Test points in front of plane, if needed + result = api_ray_test_ents(midpoint, -plane_normal, 1, 1, 1, &entity_ptr, + temp_list, dist_ptr); + if (!result.ok()) + { + AcisQueryEngine::instance()->ACIS_API_error(result); + } + // Indicate that the distance is in front of the plane + distance = -distance; + } - if (DEBUG_FLAG(18)) - { - PRINT_DEBUG_18( - "Midpoint before moving it: %g, %g, %g.\n", - midpoint.x(), midpoint.y(), midpoint.z()); - } + if (DEBUG_FLAG(18)) + { + PRINT_DEBUG_18( + "Midpoint before moving it: %g, %g, %g.\n", + midpoint.x(), midpoint.y(), midpoint.z()); + } - // Move midpoint from SPAbox to plane - midpoint += distance * plane_normal; + // Move midpoint from SPAbox to plane + midpoint += distance * plane_normal; - if (DEBUG_FLAG(18)) - { - PRINT_DEBUG_18( - "just_face = %d.\n" - "The center of the box was %s the plane.\n", - just_face, - distance >= 0 ? "behind" : "in front of"); - PRINT_DEBUG_18( - "Distance to center of box was determined to be %g.\n", - distance); - PRINT_DEBUG_18( "Mapped point is %g, %g, %g.\n", - midpoint.x(), midpoint.y(), midpoint.z()); - } + if (DEBUG_FLAG(18)) + { + PRINT_DEBUG_18( + "just_face = %d.\n" + "The center of the box was %s the plane.\n", + just_face, + distance >= 0 ? "behind" : "in front of"); + PRINT_DEBUG_18( + "Distance to center of box was determined to be %g.\n", + distance); + PRINT_DEBUG_18( "Mapped point is %g, %g, %g.\n", + midpoint.x(), midpoint.y(), midpoint.z()); + } - // Get 4 points on the plane that form a square with sides of - // length 2*diag_length. - SPAvector in_plane_1 = diag_length * normalise(the_plane.u_deriv); - SPAvector in_plane_2 = plane_normal * in_plane_1; - SPAposition corners[4]; - corners[0] = midpoint - in_plane_1 - in_plane_2; - corners[1] = midpoint + in_plane_1 - in_plane_2; - corners[2] = midpoint + in_plane_1 + in_plane_2; - corners[3] = midpoint - in_plane_1 + in_plane_2; - if (DEBUG_FLAG(18)) - { - // Uncomment this if you want to see the plane before it's swept -// GfxDebug::draw_line( -// corners[0].x(), corners[0].y(), corners[0].z(), -// corners[1].x(), corners[1].y(), corners[1].z(), CUBIT_RED); -// GfxDebug::draw_line( -// corners[1].x(), corners[1].y(), corners[1].z(), -// corners[2].x(), corners[2].y(), corners[2].z(), CUBIT_GREEN); -// GfxDebug::draw_line( -// corners[2].x(), corners[2].y(), corners[2].z(), -// corners[3].x(), corners[3].y(), corners[3].z(), CUBIT_BLUE); -// GfxDebug::draw_line( -// corners[3].x(), corners[3].y(), corners[3].z(), -// corners[0].x(), corners[0].y(), corners[0].z(), CUBIT_CYAN); -// GfxDebug::draw_line( -// midpoint.x(), midpoint.y(), midpoint.z(), -// midpoint.x()+plane_normal.x(), -// midpoint.y()+plane_normal.y(), -// midpoint.z()+plane_normal.z(), CUBIT_BLUE); -// GfxDebug::flush(); - - PRINT_DEBUG_18( "Diag length is %g.\n" - "Got four corners: (%g %g %g)\n" - " (%g %g %g).\n" - " (%g %g %g).\n" - " (%g %g %g).\n", - diag_length, - corners[0].x(), corners[0].y(), corners[0].z(), - corners[1].x(), corners[1].y(), corners[1].z(), - corners[2].x(), corners[2].y(), corners[2].z(), - corners[3].x(), corners[3].y(), corners[3].z()); - } - // Make some geometry and topology from the corners - STRAIGHT* S[4]; - S[0] = new STRAIGHT(corners[0], normalise(in_plane_1)); - S[1] = new STRAIGHT(corners[1], normalise(in_plane_2)); - S[2] = new STRAIGHT(corners[2], normalise(-in_plane_1)); - S[3] = new STRAIGHT(corners[3], normalise(-in_plane_2)); - APOINT* P[4]; - VERTEX* V[4]; - EDGE* E[4]; - COEDGE* CE[4]; - int i; - for ( i = 0; i < 4; i++) - { - P[i] = new APOINT (corners[i]); - V[i] = new VERTEX (P[i]); - } - CE[0] = NULL; - for (i = 0; i < 4; i++) - { - E[i] = new EDGE(V[i], V[(i+ 1)%4], S[i], FORWARD); - CE[i] = new COEDGE(E[i], FORWARD, - i == 0 ? NULL : CE[i-1], - i == 3 ? CE[0] : NULL); - } - LOOP* LOOP1 = new LOOP (CE[0], NULL); - FACE* FACE1 = new FACE (LOOP1, NULL, the_PLANE, FORWARD); - SHELL* SHELL1 = new SHELL(FACE1, NULL, NULL); - LUMP* LUMP1 = new LUMP(SHELL1, NULL); - infinite_plane_BODY = new BODY(LUMP1); - // At this point we are done with planar_FACE. It has been replaced by - // a FACE that is bounded by a LOOPm FACE1. - planar_FACE->lose(); - // Let's make sure everything went as planned. - if (infinite_plane_BODY != NULL) - { - result = api_body_to_2d(infinite_plane_BODY); - if (!result.ok() || infinite_plane_BODY == NULL) - { - PRINT_ERROR("Unable to create infinite plane.\n"); - AcisQueryEngine::instance()->ACIS_API_error(result); - infinite_plane_BODY = NULL; - } - // Just leave it as a 2D body if we are creating a sheet, or - // if the plane never intersects the input box_to_cut. - else if (!just_face && distance < diag_length && distance > -diag_length) - { - // Now sweep the FACE to make a 3D body + // Get 4 points on the plane that form a square with sides of + // length 2*diag_length. + SPAvector in_plane_1 = diag_length * normalise(the_plane.u_deriv); + SPAvector in_plane_2 = plane_normal * in_plane_1; + SPAposition corners[4]; + corners[0] = midpoint - in_plane_1 - in_plane_2; + corners[1] = midpoint + in_plane_1 - in_plane_2; + corners[2] = midpoint + in_plane_1 + in_plane_2; + corners[3] = midpoint - in_plane_1 + in_plane_2; if (DEBUG_FLAG(18)) - PRINT_DEBUG_18( - "Sweeping (%g %g %g).\n", - ((diag_length-distance)*plane_normal).x(), - ((diag_length-distance)*plane_normal).y(), - ((diag_length-distance)*plane_normal).z()); + { + // Uncomment this if you want to see the plane before it's swept + // GfxDebug::draw_line( + // corners[0].x(), corners[0].y(), corners[0].z(), + // corners[1].x(), corners[1].y(), corners[1].z(), CUBIT_RED); + // GfxDebug::draw_line( + // corners[1].x(), corners[1].y(), corners[1].z(), + // corners[2].x(), corners[2].y(), corners[2].z(), CUBIT_GREEN); + // GfxDebug::draw_line( + // corners[2].x(), corners[2].y(), corners[2].z(), + // corners[3].x(), corners[3].y(), corners[3].z(), CUBIT_BLUE); + // GfxDebug::draw_line( + // corners[3].x(), corners[3].y(), corners[3].z(), + // corners[0].x(), corners[0].y(), corners[0].z(), CUBIT_CYAN); + // GfxDebug::draw_line( + // midpoint.x(), midpoint.y(), midpoint.z(), + // midpoint.x()+plane_normal.x(), + // midpoint.y()+plane_normal.y(), + // midpoint.z()+plane_normal.z(), CUBIT_BLUE); + // GfxDebug::flush(); - // A negative distance means that it was in front of the plane, so - // we need to sweep extra distance. A positive distance means behind the - // plane, so we don't need to sweep as far. - sweep_options sweep_ops; - logical ACIS_primary_side = true; - sweep_ops.set_which_side(ACIS_primary_side); - result = api_sweep_with_options(FACE1, - (diag_length-distance)*plane_normal, - &sweep_ops, - infinite_plane_BODY); - if (!result.ok()) - { - PRINT_ERROR("In GeometryModifyTool::create_infinite_plane_cutting_tool.\n" - " Problem sweeping the infinite plane.\n"); - AcisQueryEngine::instance()->ACIS_API_error(result); - infinite_plane_BODY = NULL; - } - } - else if (DEBUG_FLAG(18)) - PRINT_DEBUG_18( "Not sweeping the infinite plane.\n"); - } + PRINT_DEBUG_18( "Diag length is %g.\n" + "Got four corners: (%g %g %g)\n" + " (%g %g %g).\n" + " (%g %g %g).\n" + " (%g %g %g).\n", + diag_length, + corners[0].x(), corners[0].y(), corners[0].z(), + corners[1].x(), corners[1].y(), corners[1].z(), + corners[2].x(), corners[2].y(), corners[2].z(), + corners[3].x(), corners[3].y(), corners[3].z()); + } + // Make some geometry and topology from the corners + STRAIGHT* S[4]; + S[0] = new STRAIGHT(corners[0], normalise(in_plane_1)); + S[1] = new STRAIGHT(corners[1], normalise(in_plane_2)); + S[2] = new STRAIGHT(corners[2], normalise(-in_plane_1)); + S[3] = new STRAIGHT(corners[3], normalise(-in_plane_2)); + APOINT* P[4]; + VERTEX* V[4]; + EDGE* E[4]; + COEDGE* CE[4]; + int i; + for ( i = 0; i < 4; i++) + { + P[i] = new APOINT (corners[i]); + V[i] = new VERTEX (P[i]); + } + CE[0] = NULL; + for (i = 0; i < 4; i++) + { + E[i] = new EDGE(V[i], V[(i+ 1)%4], S[i], FORWARD); + CE[i] = new COEDGE(E[i], FORWARD, + i == 0 ? NULL : CE[i-1], + i == 3 ? CE[0] : NULL); + } + LOOP* LOOP1 = new LOOP (CE[0], NULL); + FACE* FACE1 = new FACE (LOOP1, NULL, the_PLANE, FORWARD); + SHELL* SHELL1 = new SHELL(FACE1, NULL, NULL); + LUMP* LUMP1 = new LUMP(SHELL1, NULL); + infinite_plane_BODY = new BODY(LUMP1); + // At this point we are done with planar_FACE. It has been replaced by + // a FACE that is bounded by a LOOPm FACE1. + planar_FACE->lose(); + // Let's make sure everything went as planned. + if (infinite_plane_BODY != NULL) + { + result = api_body_to_2d(infinite_plane_BODY); + if (!result.ok() || infinite_plane_BODY == NULL) + { + PRINT_ERROR("Unable to create infinite plane.\n"); + AcisQueryEngine::instance()->ACIS_API_error(result); + infinite_plane_BODY = NULL; + } + // Just leave it as a 2D body if we are creating a sheet, or + // if the plane never intersects the input box_to_cut. + else if (!just_face && distance < diag_length && distance > -diag_length) + { + // Now sweep the FACE to make a 3D body + if (DEBUG_FLAG(18)) + PRINT_DEBUG_18( + "Sweeping (%g %g %g).\n", + ((diag_length-distance)*plane_normal).x(), + ((diag_length-distance)*plane_normal).y(), + ((diag_length-distance)*plane_normal).z()); - API_END; + // A negative distance means that it was in front of the plane, so + // we need to sweep extra distance. A positive distance means behind the + // plane, so we don't need to sweep as far. + sweep_options sweep_ops; + logical ACIS_primary_side = true; + sweep_ops.set_which_side(ACIS_primary_side); + result = api_sweep_with_options(FACE1, + (diag_length-distance)*plane_normal, + &sweep_ops, + infinite_plane_BODY); + if (!result.ok()) + { + PRINT_ERROR("In GeometryModifyTool::create_infinite_plane_cutting_tool.\n" + " Problem sweeping the infinite plane.\n"); + AcisQueryEngine::instance()->ACIS_API_error(result); + infinite_plane_BODY = NULL; + } + } + else if (DEBUG_FLAG(18)) + PRINT_DEBUG_18( "Not sweeping the infinite plane.\n"); + } - return infinite_plane_BODY; -} + API_END; -//*********************************************************** -// Function: create_solid_bodies_from_surfs -// Description: This function assumes that the reffaces sent into -// this function are either sheet bodies, or free surfaces. This -// Will have been taken care of in the calling function. GT? -// All the surfaces, in ACIS, will be turned into sheet bodies. They -// will be united, then the void enclosed. The result will be healed -// if the option is specified (default is to heal, from experience). -// This function will not create new reffaces. -//*********************************************************** -CubitStatus AcisModifyEngine::create_solid_bodies_from_surfs( DLIList<Surface*> &ref_face_list, - DLIList<BodySM*> &new_bodies, - bool keep_old, - bool heal ) const -{ - int ii; - Surface* ref_face; - outcome rc; - //First sort the ref_face_list to sheet_bodies and free faces. - DLIList<BodySM*> body_list; - DLIList<Surface*> free_faces; + return infinite_plane_BODY; + } - AcisQueryEngine* aqe = AcisQueryEngine::instance(); + //*********************************************************** + // Function: create_solid_bodies_from_surfs + // Description: This function assumes that the reffaces sent into + // this function are either sheet bodies, or free surfaces. This + // Will have been taken care of in the calling function. GT? + // All the surfaces, in ACIS, will be turned into sheet bodies. They + // will be united, then the void enclosed. The result will be healed + // if the option is specified (default is to heal, from experience). + // This function will not create new reffaces. + //*********************************************************** + CubitStatus AcisModifyEngine::create_solid_bodies_from_surfs( DLIList<Surface*> &ref_face_list, + DLIList<BodySM*> &new_bodies, + bool keep_old, + bool heal ) const + { + int ii; + Surface* ref_face; + outcome rc; + //First sort the ref_face_list to sheet_bodies and free faces. + DLIList<BodySM*> body_list; + DLIList<Surface*> free_faces; - ref_face_list.reset(); - for( ii = ref_face_list.size(); ii > 0; ii-- ) - { - ref_face = ref_face_list.get_and_step(); - FACE* FACE_ptr = aqe->get_FACE(ref_face); - BodySM* body_ptr = aqe->get_body_sm_of_ENTITY(FACE_ptr); + AcisQueryEngine* aqe = AcisQueryEngine::instance(); - if (body_ptr) - body_list.append_unique(body_ptr); - else - free_faces.append_unique(ref_face); - } + ref_face_list.reset(); + for( ii = ref_face_list.size(); ii > 0; ii-- ) + { + ref_face = ref_face_list.get_and_step(); + FACE* FACE_ptr = aqe->get_FACE(ref_face); + BodySM* body_ptr = aqe->get_body_sm_of_ENTITY(FACE_ptr); - //Now for all of the free_faces, create BODYS for them. - DLIList<BODY*> BODY_list, old_BODY_list; - for ( ii = free_faces.size(); ii > 0; ii-- ) - { - ref_face = free_faces.get_and_step(); - FACE *acis_FACE = AcisQueryEngine::get_FACE(ref_face); - if (!acis_FACE) - return CUBIT_FAILURE; + if (body_ptr) + body_list.append_unique(body_ptr); + else + free_faces.append_unique(ref_face); + } - FACE *face_list[1]; - BODY *sheet_body; - face_list[0] = acis_FACE; - rc = api_sheet_from_ff(1, face_list, sheet_body); - if (!rc.ok()) - { - PRINT_ERROR("Couldn't build a volume with Surface.\n") ; - for (int jj = BODY_list.size(); jj > 0; jj-- ) - AcisQueryEngine::instance()->delete_ACIS_BODY(BODY_list.remove()); - AcisQueryEngine::instance()->ACIS_API_error (rc); - return CUBIT_FAILURE; - } - rc = api_body_to_2d(sheet_body); - if (!rc.ok()) - { - PRINT_ERROR("Couldn't build a volume with Surface.\n" ); - for (int jj = BODY_list.size(); jj > 0; jj-- ) - AcisQueryEngine::instance()->delete_ACIS_BODY(BODY_list.remove()); - AcisQueryEngine::instance()->ACIS_API_error (rc); - return CUBIT_FAILURE; - } - // Make sure we were successful - if ( sheet_body->lump() == NULL || - sheet_body->lump()->shell() == NULL || - sheet_body->lump()->shell()->first_face() == NULL ) - { - PRINT_ERROR("Couldn't build a volume with Surface.\n" ); - for (int jj = BODY_list.size(); jj > 0; jj-- ) - AcisQueryEngine::instance()->delete_ACIS_BODY(BODY_list.remove()); - return CUBIT_FAILURE; - } - BODY_list.append(sheet_body); - } - BODY *first_BODY = NULL; + //Now for all of the free_faces, create BODYS for them. + DLIList<BODY*> BODY_list, old_BODY_list; + for ( ii = free_faces.size(); ii > 0; ii-- ) + { + ref_face = free_faces.get_and_step(); + FACE *acis_FACE = AcisQueryEngine::get_FACE(ref_face); + if (!acis_FACE) + return CUBIT_FAILURE; - for ( ii = body_list.size(); ii > 0; ii-- ) - { - BodySM *body_ptr = body_list.get_and_step(); - BODY *BODY_ptr = AcisQueryEngine::get_BODY(body_ptr); - if (!BODY_ptr) - return CUBIT_FAILURE; + FACE *face_list[1]; + BODY *sheet_body; + face_list[0] = acis_FACE; + rc = api_sheet_from_ff(1, face_list, sheet_body); + if (!rc.ok()) + { + PRINT_ERROR("Couldn't build a volume with Surface.\n") ; + for (int jj = BODY_list.size(); jj > 0; jj-- ) + AcisQueryEngine::instance()->delete_ACIS_BODY(BODY_list.remove()); + AcisQueryEngine::instance()->ACIS_API_error (rc); + return CUBIT_FAILURE; + } + rc = api_body_to_2d(sheet_body); + if (!rc.ok()) + { + PRINT_ERROR("Couldn't build a volume with Surface.\n" ); + for (int jj = BODY_list.size(); jj > 0; jj-- ) + AcisQueryEngine::instance()->delete_ACIS_BODY(BODY_list.remove()); + AcisQueryEngine::instance()->ACIS_API_error (rc); + return CUBIT_FAILURE; + } + // Make sure we were successful + if ( sheet_body->lump() == NULL || + sheet_body->lump()->shell() == NULL || + sheet_body->lump()->shell()->first_face() == NULL ) + { + PRINT_ERROR("Couldn't build a volume with Surface.\n" ); + for (int jj = BODY_list.size(); jj > 0; jj-- ) + AcisQueryEngine::instance()->delete_ACIS_BODY(BODY_list.remove()); + return CUBIT_FAILURE; + } + BODY_list.append(sheet_body); + } + BODY *first_BODY = NULL; - if (first_BODY == NULL ) - first_BODY = BODY_ptr; - BODY_list.append(BODY_ptr); - old_BODY_list.append(BODY_ptr); - } - //Okay unite all of these bodies into one body. - BODY_list.reset(); - int new_ids = GeometryModifyTool::instance()->get_new_ids(); - bool delete_attribs = (new_ids || keep_old); - BODY *master; + for ( ii = body_list.size(); ii > 0; ii-- ) + { + BodySM *body_ptr = body_list.get_and_step(); + BODY *BODY_ptr = AcisQueryEngine::get_BODY(body_ptr); + if (!BODY_ptr) + return CUBIT_FAILURE; - //if we're not healing, we're assuming the surfaces have gaps between each other - //less than 1e-6, so we'll use stitching, otherwise we assume the gaps are bigger than - //1e-6 and we'll us api_combine_body, and subsequently we'll heal - ENTITY_LIST bodies_to_be_stitched; + if (first_BODY == NULL ) + first_BODY = BODY_ptr; + BODY_list.append(BODY_ptr); + old_BODY_list.append(BODY_ptr); + } + //Okay unite all of these bodies into one body. + BODY_list.reset(); + int new_ids = GeometryModifyTool::instance()->get_new_ids(); + bool delete_attribs = (new_ids || keep_old); + BODY *master; - if ( first_BODY ) - { - master = this->copy_BODY(first_BODY, delete_attribs); - BODY_list.remove(first_BODY); - } - else - master = this->copy_BODY(BODY_list.remove(), delete_attribs); + //if we're not healing, we're assuming the surfaces have gaps between each other + //less than 1e-6, so we'll use stitching, otherwise we assume the gaps are bigger than + //1e-6 and we'll us api_combine_body, and subsequently we'll heal + ENTITY_LIST bodies_to_be_stitched; - if( !heal ) - bodies_to_be_stitched.add( master ); + if ( first_BODY ) + { + master = this->copy_BODY(first_BODY, delete_attribs); + BODY_list.remove(first_BODY); + } + else + master = this->copy_BODY(BODY_list.remove(), delete_attribs); - for ( ii = BODY_list.size(); ii > 0; ii-- ) - { - BODY *BODY_ptr = BODY_list.get_and_step(); - BODY *copy = this->copy_BODY(BODY_ptr, delete_attribs); - if (copy == NULL) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(master); - return CUBIT_FAILURE; - } - if( !heal ) - bodies_to_be_stitched.add( copy ); - else - { - outcome result = api_combine_body(copy, master ); + if( !heal ) + bodies_to_be_stitched.add( master ); - if (!result.ok() || (!master )) - { - // If there are no LUMPs in the resulting BODY, return with a failure - if (master == NULL) - PRINT_ERROR("In AcisModifyEngine::create_solid_bodies_from_surfs\n"); + for ( ii = BODY_list.size(); ii > 0; ii-- ) + { + BODY *BODY_ptr = BODY_list.get_and_step(); + BODY *copy = this->copy_BODY(BODY_ptr, delete_attribs); + if (copy == NULL) + { + AcisQueryEngine::instance()->delete_ACIS_BODY(master); + return CUBIT_FAILURE; + } + if( !heal ) + bodies_to_be_stitched.add( copy ); + else + { + outcome result = api_combine_body(copy, master ); - AcisQueryEngine::instance()->ACIS_API_error(result, "create body from surfs"); - if (master != NULL) AcisQueryEngine::instance()->delete_ACIS_BODY(master); - if (copy != NULL) AcisQueryEngine::instance()->delete_ACIS_BODY(copy); + if (!result.ok() || (!master )) + { + // If there are no LUMPs in the resulting BODY, return with a failure + if (master == NULL) + PRINT_ERROR("In AcisModifyEngine::create_solid_bodies_from_surfs\n"); - return CUBIT_FAILURE; - } - } - } + AcisQueryEngine::instance()->ACIS_API_error(result, "create body from surfs"); + if (master != NULL) AcisQueryEngine::instance()->delete_ACIS_BODY(master); + if (copy != NULL) AcisQueryEngine::instance()->delete_ACIS_BODY(copy); - if( !heal ) - { - ENTITY_LIST dummy_list, resultant_bodies; - tolerant_stitch_options stitch_opts; - //surfaces better be between GEOMETRY_RESABS or else fail - stitch_opts.set_max_stitch_tol( GEOMETRY_RESABS ); - outcome result = api_stitch( bodies_to_be_stitched, dummy_list, resultant_bodies, &stitch_opts ); + return CUBIT_FAILURE; + } + } + } - master = (BODY*)dummy_list.first(); + if( !heal ) + { + ENTITY_LIST dummy_list, resultant_bodies; + tolerant_stitch_options stitch_opts; + //surfaces better be between GEOMETRY_RESABS or else fail + stitch_opts.set_max_stitch_tol( GEOMETRY_RESABS ); + outcome result = api_stitch( bodies_to_be_stitched, dummy_list, resultant_bodies, &stitch_opts ); - if (!result.ok() || (!master )) - { - // If there are no LUMPs in the resulting BODY, return with a failure - if (master == NULL) - PRINT_ERROR("In AcisModifyEngine::create_solid_bodies_from_surfs\n"); + master = (BODY*)dummy_list.first(); - AcisQueryEngine::instance()->ACIS_API_error(result, "create body from surfs"); - if (master != NULL) AcisQueryEngine::instance()->delete_ACIS_BODY(master); + if (!result.ok() || (!master )) + { + // If there are no LUMPs in the resulting BODY, return with a failure + if (master == NULL) + PRINT_ERROR("In AcisModifyEngine::create_solid_bodies_from_surfs\n"); - return CUBIT_FAILURE; - } - } + AcisQueryEngine::instance()->ACIS_API_error(result, "create body from surfs"); + if (master != NULL) AcisQueryEngine::instance()->delete_ACIS_BODY(master); - // If all went well, delete the old Bodies - DLIList<TopologyBridge*> old_entities; - body_list.reset() ; + return CUBIT_FAILURE; + } + } - CAST_LIST_TO_PARENT(body_list, old_entities); + // If all went well, delete the old Bodies + DLIList<TopologyBridge*> old_entities; + body_list.reset() ; - for ( ii = free_faces.size(); ii > 0; ii-- ) - old_entities.append(free_faces.get_and_step()); + CAST_LIST_TO_PARENT(body_list, old_entities); -/* - if (!keep_old ) - { - for( ii = body_list.size(); ii > 0; ii--) - { - Body* body_ptr = body_list.get_and_step() ; - GeometryModifyTool::instance()->delete_Body(body_ptr) ; - } - for ( ii = free_faces.size(); ii > 0; ii-- ) - { - RefFace *ref_ptr = free_faces.get_and_step(); - RefEntity *ref_entity_ptr = CAST_TO(ref_ptr, RefEntity); - GeometryModifyTool::instance()->delete_RefEntity(ref_entity_ptr); - } - } -*/ + for ( ii = free_faces.size(); ii > 0; ii-- ) + old_entities.append(free_faces.get_and_step()); - BODY *new_master = master; + /* + if (!keep_old ) + { + for( ii = body_list.size(); ii > 0; ii--) + { + Body* body_ptr = body_list.get_and_step() ; + GeometryModifyTool::instance()->delete_Body(body_ptr) ; + } + for ( ii = free_faces.size(); ii > 0; ii-- ) + { + RefFace *ref_ptr = free_faces.get_and_step(); + RefEntity *ref_entity_ptr = CAST_TO(ref_ptr, RefEntity); + GeometryModifyTool::instance()->delete_RefEntity(ref_entity_ptr); + } + } + */ + + BODY *new_master = master; #ifdef ACIS_HEALER -// BODY *new_master = master; - if ( heal ) - { + // BODY *new_master = master; + if ( heal ) + { - // Now heal the combined body - PRINT_INFO(" Healing the combined volume...\n"); - if( AcisHealerTool::instance()->init_BODY_for_healing( master ) == CUBIT_SUCCESS ) - { - int percent_before, percent_after, number_splines_simplified; - if( AcisHealerTool::instance()->heal_BODY( master, percent_before, - percent_after, number_splines_simplified ) == CUBIT_FAILURE ) - PRINT_ERROR( "Error healing the combined volume\n" ); - else - PRINT_INFO( "Healed the combined volume to %d%% good geometry.\n", percent_after ); - AcisHealerTool::instance()->end_BODY_for_healing( master ); - } - } + // Now heal the combined body + PRINT_INFO(" Healing the combined volume...\n"); + if( AcisHealerTool::instance()->init_BODY_for_healing( master ) == CUBIT_SUCCESS ) + { + int percent_before, percent_after, number_splines_simplified; + if( AcisHealerTool::instance()->heal_BODY( master, percent_before, + percent_after, number_splines_simplified ) == CUBIT_FAILURE ) + PRINT_ERROR( "Error healing the combined volume\n" ); + else + PRINT_INFO( "Healed the combined volume to %d%% good geometry.\n", percent_after ); + AcisHealerTool::instance()->end_BODY_for_healing( master ); + } + } #else - PRINT_WARNING("Healer was not included with this version.\n" - " Volume healing is usually required for creating\n" - " volumes out of surfaces.\n"); + PRINT_WARNING("Healer was not included with this version.\n" + " Volume healing is usually required for creating\n" + " volumes out of surfaces.\n"); #endif - //Gather all the FACEs from resultant BODY - ENTITY_LIST tmp_FACEs; - api_get_faces( new_master, tmp_FACEs ); - FACE **tmp_FACE_array = new FACE*[tmp_FACEs.count()]; - tmp_FACEs.init(); - ENTITY *tmp_ent = NULL; - while( (tmp_ent = tmp_FACEs.next()) != NULL) - tmp_FACE_array[ii++] = static_cast<FACE*>(tmp_ent); + //Gather all the FACEs from resultant BODY + ENTITY_LIST tmp_FACEs; + api_get_faces( new_master, tmp_FACEs ); + FACE **tmp_FACE_array = new FACE*[tmp_FACEs.count()]; + tmp_FACEs.init(); + ENTITY *tmp_ent = NULL; + while( (tmp_ent = tmp_FACEs.next()) != NULL) + tmp_FACE_array[ii++] = static_cast<FACE*>(tmp_ent); - //lets make sure that there are not inappropriate intersections between FACEs - ENTITY_LIST insane_ents; - logical bad_ints = true; - api_check_list_ff_ints( tmp_FACEs.count(), tmp_FACE_array, &insane_ents, bad_ints ); + //lets make sure that there are not inappropriate intersections between FACEs + ENTITY_LIST insane_ents; + logical bad_ints = true; + api_check_list_ff_ints( tmp_FACEs.count(), tmp_FACE_array, &insane_ents, bad_ints ); - delete [] tmp_FACE_array; + delete [] tmp_FACE_array; - if( insane_ents.count() || bad_ints ) - { - PRINT_INFO("Bad surface-surface intersections\n"); - insane_ents.init(); - while( (tmp_ent=insane_ents.next()) != NULL) - { - ERROR_ENTITY *error_ent = static_cast<ERROR_ENTITY*>(tmp_ent); - PRINT_ERROR("ACIS error number %d %s\n", error_ent->get_error_id(), - find_err_mess (error_ent->get_error_id())); - } - api_delent( new_master ); - return CUBIT_FAILURE; - } + if( insane_ents.count() || bad_ints ) + { + PRINT_INFO("Bad surface-surface intersections\n"); + insane_ents.init(); + while( (tmp_ent=insane_ents.next()) != NULL) + { + ERROR_ENTITY *error_ent = static_cast<ERROR_ENTITY*>(tmp_ent); + PRINT_ERROR("ACIS error number %d %s\n", error_ent->get_error_id(), + find_err_mess (error_ent->get_error_id())); + } + api_delent( new_master ); + return CUBIT_FAILURE; + } - //separate the bodies so that you have no multi-volume bodies - ENTITY_LIST separated_bodies; - BODY **new_BODY_list; - int n_bodies; - api_separate_body( new_master, n_bodies, new_BODY_list ); + //separate the bodies so that you have no multi-volume bodies + ENTITY_LIST separated_bodies; + BODY **new_BODY_list; + int n_bodies; + api_separate_body( new_master, n_bodies, new_BODY_list ); - DLIList<BODY*> new_BODIES; - int i; - for( i=0; i<n_bodies; i++ ) - new_BODIES.append( new_BODY_list[i] ); + DLIList<BODY*> new_BODIES; + int i; + for( i=0; i<n_bodies; i++ ) + new_BODIES.append( new_BODY_list[i] ); - CubitStatus success = - get_new_Body(old_entities, new_BODIES, new_bodies, keep_old); + CubitStatus success = + get_new_Body(old_entities, new_BODIES, new_bodies, keep_old); - if ( new_bodies.size() == 0 ) - { - PRINT_ERROR("Problems creating new volume.\n" ); - return CUBIT_FAILURE; - } - return CUBIT_SUCCESS; -} + if ( new_bodies.size() == 0 ) + { + PRINT_ERROR("Problems creating new volume.\n" ); + return CUBIT_FAILURE; + } + return CUBIT_SUCCESS; + } -// Currently no command line to this -CubitStatus AcisModifyEngine::webcut_across_translate( - DLIList<BodySM*>& body_list, - Surface* top_surf_ptr, - Surface* bottom_surf_ptr, - DLIList<BodySM*>& , - bool ) const -{ - CubitVector top_orig, top_norm, bottom_orig, bottom_norm; - double top_orig_pnt[3], top_norm_vec[3], bottom_orig_pnt[3], bottom_norm_vec[3]; - //CubitVector top_sweep_vector, bottom_sweep_vector; - double distance; - int i, ii; - BodySM* body_ptr; - Surface* ref_face_ptr; - FACE* FACE_ptr; - FACE* copied_FACE_ptr; - ENTITY *entity_ptr; - DLIList<BODY*> tool_BODY_list; - //int volume_is_negative; - AgtSide side; - AgtOrientation orien; - outcome result; + // Currently no command line to this + CubitStatus AcisModifyEngine::webcut_across_translate( + DLIList<BodySM*>& body_list, + Surface* top_surf_ptr, + Surface* bottom_surf_ptr, + DLIList<BodySM*>& , + bool ) const + { + CubitVector top_orig, top_norm, bottom_orig, bottom_norm; + double top_orig_pnt[3], top_norm_vec[3], bottom_orig_pnt[3], bottom_norm_vec[3]; + //CubitVector top_sweep_vector, bottom_sweep_vector; + double distance; + int i, ii; + BodySM* body_ptr; + Surface* ref_face_ptr; + FACE* FACE_ptr; + FACE* copied_FACE_ptr; + ENTITY *entity_ptr; + DLIList<BODY*> tool_BODY_list; + //int volume_is_negative; + AgtSide side; + AgtOrientation orien; + outcome result; - AnalyticGeometryTool* agt = AnalyticGeometryTool::instance(); + AnalyticGeometryTool* agt = AnalyticGeometryTool::instance(); - // Find top plane - if( top_surf_ptr->get_point_normal( top_orig, top_norm ) == CUBIT_FAILURE ) - { - PRINT_ERROR( "Surface is not planar\n" ); - return CUBIT_FAILURE; - } + // Find top plane + if( top_surf_ptr->get_point_normal( top_orig, top_norm ) == CUBIT_FAILURE ) + { + PRINT_ERROR( "Surface is not planar\n" ); + return CUBIT_FAILURE; + } - if( bottom_surf_ptr->get_point_normal( bottom_orig, bottom_norm ) == CUBIT_FAILURE ) - { - PRINT_ERROR( "Surface is not planar\n" ); - return CUBIT_FAILURE; - } + if( bottom_surf_ptr->get_point_normal( bottom_orig, bottom_norm ) == CUBIT_FAILURE ) + { + PRINT_ERROR( "Surface is not planar\n" ); + return CUBIT_FAILURE; + } - top_orig.get_xyz( top_orig_pnt ); top_norm.get_xyz( top_norm_vec ); - bottom_orig.get_xyz( bottom_orig_pnt ); bottom_norm.get_xyz( bottom_norm_vec ); + top_orig.get_xyz( top_orig_pnt ); top_norm.get_xyz( top_norm_vec ); + bottom_orig.get_xyz( bottom_orig_pnt ); bottom_norm.get_xyz( bottom_norm_vec ); - // Check distance between planes - distance = agt->dist_pln_pln( top_orig_pnt, top_norm_vec, bottom_orig_pnt, bottom_norm_vec, - &side, &orien ); + // Check distance between planes + distance = agt->dist_pln_pln( top_orig_pnt, top_norm_vec, bottom_orig_pnt, bottom_norm_vec, + &side, &orien ); - if( agt->dbl_eq( distance, 0.0 ) ) - { - PRINT_ERROR( "Distance between planes is 0.0\n" ); - return CUBIT_FAILURE; - } + if( agt->dbl_eq( distance, 0.0 ) ) + { + PRINT_ERROR( "Distance between planes is 0.0\n" ); + return CUBIT_FAILURE; + } - double top_bott[3]; - top_bott[0] = top_norm.x(); - top_bott[1] = top_norm.y(); - top_bott[2] = top_norm.z(); - if( side == AGT_NEG_SIDE ) { - agt->reverse_vec( top_bott, top_bott ); - } + double top_bott[3]; + top_bott[0] = top_norm.x(); + top_bott[1] = top_norm.y(); + top_bott[2] = top_norm.z(); + if( side == AGT_NEG_SIDE ) { + agt->reverse_vec( top_bott, top_bott ); + } - // Top plane - for( i=0; i<body_list.size(); i++ ) - { - body_ptr = body_list.get_and_step(); + // Top plane + for( i=0; i<body_list.size(); i++ ) + { + body_ptr = body_list.get_and_step(); - DLIList<Surface*> ref_face_list; - AcisQueryEngine::instance()->get_surfs_on_plane( body_ptr, top_orig_pnt, top_norm_vec, ref_face_list ); + DLIList<Surface*> ref_face_list; + AcisQueryEngine::instance()->get_surfs_on_plane( body_ptr, top_orig_pnt, top_norm_vec, ref_face_list ); - if( ref_face_list.size() == 0 ) - continue; + if( ref_face_list.size() == 0 ) + continue; - for( ii=0; ii<ref_face_list.size(); ii++ ) - { - ref_face_ptr = ref_face_list.get_and_step(); + for( ii=0; ii<ref_face_list.size(); ii++ ) + { + ref_face_ptr = ref_face_list.get_and_step(); - // Copy each surface, reverse and extrude - FACE_ptr = AcisQueryEngine::get_FACE( ref_face_ptr ); + // Copy each surface, reverse and extrude + FACE_ptr = AcisQueryEngine::get_FACE( ref_face_ptr ); - if( FACE_ptr == NULL ) - { - return CUBIT_FAILURE; - } + if( FACE_ptr == NULL ) + { + return CUBIT_FAILURE; + } - result = api_copy_entity_contents( (ENTITY *)FACE_ptr, entity_ptr); - if( !result.ok() ) - { - PRINT_ERROR( "Unable to copy face off volume\n" ); - continue; - } + result = api_copy_entity_contents( (ENTITY *)FACE_ptr, entity_ptr); + if( !result.ok() ) + { + PRINT_ERROR( "Unable to copy face off volume\n" ); + continue; + } - copied_FACE_ptr = (FACE *)entity_ptr; - ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_FACE_ptr, - CUBIT_TRUE ); + copied_FACE_ptr = (FACE *)entity_ptr; + ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_FACE_ptr, + CUBIT_TRUE ); - // Create a sheet body from this free-face - BODY* sheet_BODY_ptr; - result = api_sheet_from_ff( 1, &copied_FACE_ptr, sheet_BODY_ptr ); - if (!result.ok()) - { - PRINT_ERROR("Error in api_sheet_from_ff\n"); - AcisQueryEngine::instance()->ACIS_API_error(result); - PRINT_ERROR( "Unable to create sheet volume from face\n" ); - continue; - } - if( sheet_BODY_ptr == NULL ) - { - PRINT_ERROR( "Unable to create sheet volume from face\n" ); - continue; - } + // Create a sheet body from this free-face + BODY* sheet_BODY_ptr; + result = api_sheet_from_ff( 1, &copied_FACE_ptr, sheet_BODY_ptr ); + if (!result.ok()) + { + PRINT_ERROR("Error in api_sheet_from_ff\n"); + AcisQueryEngine::instance()->ACIS_API_error(result); + PRINT_ERROR( "Unable to create sheet volume from face\n" ); + continue; + } + if( sheet_BODY_ptr == NULL ) + { + PRINT_ERROR( "Unable to create sheet volume from face\n" ); + continue; + } - DLIList<FACE*> sheet_FACE_list; - AcisQueryEngine::instance()->get_FACEs( (ENTITY *)sheet_BODY_ptr, sheet_FACE_list ); - if( sheet_FACE_list.size() != 1 ) - { - PRINT_ERROR( "Sheet doesn't have one face\n" ); - continue; - } - FACE* sheet_FACE_ptr = sheet_FACE_list.get(); + DLIList<FACE*> sheet_FACE_list; + AcisQueryEngine::instance()->get_FACEs( (ENTITY *)sheet_BODY_ptr, sheet_FACE_list ); + if( sheet_FACE_list.size() != 1 ) + { + PRINT_ERROR( "Sheet doesn't have one face\n" ); + continue; + } + FACE* sheet_FACE_ptr = sheet_FACE_list.get(); - // Get underlying plane normal. The FACE normal might be reversed - // of this. - surface const* acis_surface = &(sheet_FACE_ptr->geometry()->equation()); - SPAposition sheet_surf_orig; - SPAunit_vector sheet_surf_norm; - acis_surface->planar( sheet_surf_orig, sheet_surf_norm ); - double sheet_norm[3]; - sheet_norm[0] = sheet_surf_norm.x(); - sheet_norm[1] = sheet_surf_norm.y(); - sheet_norm[2] = sheet_surf_norm.z(); + // Get underlying plane normal. The FACE normal might be reversed + // of this. + surface const* acis_surface = &(sheet_FACE_ptr->geometry()->equation()); + SPAposition sheet_surf_orig; + SPAunit_vector sheet_surf_norm; + acis_surface->planar( sheet_surf_orig, sheet_surf_norm ); + double sheet_norm[3]; + sheet_norm[0] = sheet_surf_norm.x(); + sheet_norm[1] = sheet_surf_norm.y(); + sheet_norm[2] = sheet_surf_norm.z(); - // Get sheet normal in same direction as ACIS FACE. The direction of the - // ACIS face is the direction of sweep. - if( sheet_FACE_ptr->sense() == REVERSED ) - agt->reverse_vec( sheet_norm, sheet_norm ); + // Get sheet normal in same direction as ACIS FACE. The direction of the + // ACIS face is the direction of sweep. + if( sheet_FACE_ptr->sense() == REVERSED ) + agt->reverse_vec( sheet_norm, sheet_norm ); - // Properties of dot product - // angle acute if dot product > 0 - // angle obtuse if dot product < 0 - // angle 90 deg if dot product = 0 + // Properties of dot product + // angle acute if dot product > 0 + // angle obtuse if dot product < 0 + // angle 90 deg if dot product = 0 - if( agt->dot_vec( sheet_norm, top_bott ) < 0.0 ) - { - //PRINT_INFO( "Reversing volume...\n" ); - api_reverse_body( sheet_BODY_ptr ); - } + if( agt->dot_vec( sheet_norm, top_bott ) < 0.0 ) + { + //PRINT_INFO( "Reversing volume...\n" ); + api_reverse_body( sheet_BODY_ptr ); + } - result = api_sw_face_norm( sheet_FACE_ptr, FORWARD, distance+distance*(.50), 0, 0 ); + result = api_sw_face_norm( sheet_FACE_ptr, FORWARD, distance+distance*(.50), 0, 0 ); - if (!result.ok()) - { - PRINT_ERROR("Error during ACIS sweep operation, api_sw_face_norm\n"); - AcisQueryEngine::instance()->ACIS_API_error(result); - continue; - } + if (!result.ok()) + { + PRINT_ERROR("Error during ACIS sweep operation, api_sw_face_norm\n"); + AcisQueryEngine::instance()->ACIS_API_error(result); + continue; + } - BODY* tool_BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(sheet_FACE_ptr); + BODY* tool_BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY(sheet_FACE_ptr); - if (is_BODY(tool_BODY_ptr)) - { - result = api_body_to_2d(tool_BODY_ptr); - if (!result.ok()) - PRINT_WARNING("Couldn't turn a tool into a 3D sheet\n" ); + if (is_BODY(tool_BODY_ptr)) + { + result = api_body_to_2d(tool_BODY_ptr); + if (!result.ok()) + PRINT_WARNING("Couldn't turn a tool into a 3D sheet\n" ); - tool_BODY_list.append( tool_BODY_ptr ); + tool_BODY_list.append( tool_BODY_ptr ); - // Move the body slightly so it overlaps - // Create a SPAvector representing the offsets - double fact = 0.35; - SPAvector translation_vector( -top_bott[0]*distance*fact, -top_bott[1]*distance*fact, -top_bott[2]*distance*fact ); - SPAtransf tran_vec = translate_transf (translation_vector); + // Move the body slightly so it overlaps + // Create a SPAvector representing the offsets + double fact = 0.35; + SPAvector translation_vector( -top_bott[0]*distance*fact, -top_bott[1]*distance*fact, -top_bott[2]*distance*fact ); + SPAtransf tran_vec = translate_transf (translation_vector); - // Concatenate the input transformation to the existing one - result = api_apply_transf ( tool_BODY_ptr, tran_vec ); - if (!result.ok()) - { - AcisQueryEngine::instance()->ACIS_API_error ( result, "transforming body" ); - continue; - } - TRANSFORM* identity = new TRANSFORM(scale_transf(1.0)); - result = api_change_body_trans ( tool_BODY_ptr, identity, FALSE ); - identity->lose(); - if (!result.ok()) - { - AcisQueryEngine::instance()->ACIS_API_error ( result, "transforming body" ); - continue; + // Concatenate the input transformation to the existing one + result = api_apply_transf ( tool_BODY_ptr, tran_vec ); + if (!result.ok()) + { + AcisQueryEngine::instance()->ACIS_API_error ( result, "transforming body" ); + continue; + } + TRANSFORM* identity = new TRANSFORM(scale_transf(1.0)); + result = api_change_body_trans ( tool_BODY_ptr, identity, FALSE ); + identity->lose(); + if (!result.ok()) + { + AcisQueryEngine::instance()->ACIS_API_error ( result, "transforming body" ); + continue; - } + } - } + } - else - { - PRINT_ERROR( "Unable to create tool from surface\n" ); - } - } + else + { + PRINT_ERROR( "Unable to create tool from surface\n" ); + } + } - PRINT_INFO( "Got %d tools\n from the top\n", tool_BODY_list.size() ); + PRINT_INFO( "Got %d tools\n from the top\n", tool_BODY_list.size() ); - // For now just create tools - for( ii=0; ii<tool_BODY_list.size(); ii++ ) - { - BODY *temp_tool_BODY_ptr = tool_BODY_list.get_and_step(); + // For now just create tools + for( ii=0; ii<tool_BODY_list.size(); ii++ ) + { + BODY *temp_tool_BODY_ptr = tool_BODY_list.get_and_step(); - /*BodySM *new_body = */ - AcisQueryEngine::instance()->populate_topology_bridges(temp_tool_BODY_ptr); - } + /*BodySM *new_body = */ + AcisQueryEngine::instance()->populate_topology_bridges(temp_tool_BODY_ptr); + } - } + } - return CUBIT_SUCCESS; -} + return CUBIT_SUCCESS; + } -// Imprints curves to bodies. -CubitStatus AcisModifyEngine::imprint( DLIList<BodySM*> &body_list, - DLIList<Curve*> &ref_edge_list, - DLIList<BodySM*>& new_body_list, - bool keep_old_body, - bool show_messages) const -{ - int i, j; - outcome result; - CubitStatus status = CUBIT_SUCCESS; - CubitBoolean imprint_worked = CUBIT_FALSE; + // Imprints curves to bodies. + CubitStatus AcisModifyEngine::imprint( DLIList<BodySM*> &body_list, + DLIList<Curve*> &ref_edge_list, + DLIList<BodySM*>& new_body_list, + bool keep_old_body, + bool show_messages) const + { + int i, j; + outcome result; + CubitStatus status = CUBIT_SUCCESS; + CubitBoolean imprint_worked = CUBIT_FALSE; - Curve* ref_edge_ptr; - BodySM *body_ptr; + Curve* ref_edge_ptr; + BodySM *body_ptr; - BODY *BODY_ptr; - BODY *copied_BODY_ptr; - BODY *wire_BODY_ptr; + BODY *BODY_ptr; + BODY *copied_BODY_ptr; + BODY *wire_BODY_ptr; - EDGE *EDGE_ptr; - EDGE *copied_EDGE_ptr; + EDGE *EDGE_ptr; + EDGE *copied_EDGE_ptr; - DLIList<BODY*> ewire_list; + DLIList<BODY*> ewire_list; - bool delete_attribs = - (GeometryModifyTool::instance()->get_new_ids() || keep_old_body); + bool delete_attribs = + (GeometryModifyTool::instance()->get_new_ids() || keep_old_body); - // Make wires which can be used to imprint onto the bodies - ref_edge_list.reset(); - for( i=0; i<ref_edge_list.size(); i++ ) - { - ref_edge_ptr = ref_edge_list.get_and_step(); + // Make wires which can be used to imprint onto the bodies + ref_edge_list.reset(); + for( i=0; i<ref_edge_list.size(); i++ ) + { + ref_edge_ptr = ref_edge_list.get_and_step(); - // Get the EDGE pointer - EDGE_ptr = AcisQueryEngine::get_EDGE( ref_edge_ptr ); + // Get the EDGE pointer + EDGE_ptr = AcisQueryEngine::get_EDGE( ref_edge_ptr ); - if( EDGE_ptr == NULL ) - { - return CUBIT_FAILURE; - } + if( EDGE_ptr == NULL ) + { + return CUBIT_FAILURE; + } - // Copy the EDGE. I've found that the ewire will reference - // the original EDGE and that EDGE can get split later when - // doing imprints. Also note that the copied EDGE will get - // deleted when deleting the ewire. - result = api_edge( EDGE_ptr, copied_EDGE_ptr ); - if (!result.ok()) - { - PRINT_ERROR( "Unable to copy curve; aborting\n" ); - AcisQueryEngine::instance()->ACIS_API_error (result); - return CUBIT_FAILURE; - } + // Copy the EDGE. I've found that the ewire will reference + // the original EDGE and that EDGE can get split later when + // doing imprints. Also note that the copied EDGE will get + // deleted when deleting the ewire. + result = api_edge( EDGE_ptr, copied_EDGE_ptr ); + if (!result.ok()) + { + PRINT_ERROR( "Unable to copy curve; aborting\n" ); + AcisQueryEngine::instance()->ACIS_API_error (result); + return CUBIT_FAILURE; + } - // Remove the CUBIT owner attribute from the EDGE - ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr, - CUBIT_TRUE ); + // Remove the CUBIT owner attribute from the EDGE + ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr, + CUBIT_TRUE ); - // Make an ewire from this EDGE - result = api_make_ewire( 1, &copied_EDGE_ptr, wire_BODY_ptr ); - if (!result.ok()) - { - AcisQueryEngine::instance()->ACIS_API_error (result); - PRINT_ERROR( "Unable to make ACIS WIRE from curve; aborting\n" ); - for( j=0; j<ewire_list.size(); j++ ) - api_delent( ewire_list.get_and_step() ); - return CUBIT_FAILURE; - } + // Make an ewire from this EDGE + result = api_make_ewire( 1, &copied_EDGE_ptr, wire_BODY_ptr ); + if (!result.ok()) + { + AcisQueryEngine::instance()->ACIS_API_error (result); + PRINT_ERROR( "Unable to make ACIS WIRE from curve; aborting\n" ); + for( j=0; j<ewire_list.size(); j++ ) + api_delent( ewire_list.get_and_step() ); + return CUBIT_FAILURE; + } - ewire_list.append( wire_BODY_ptr ); - } + ewire_list.append( wire_BODY_ptr ); + } - // Loop on bodies, imprinting each with all the ewires - for( i=0; i<body_list.size(); i++ ) - { - body_ptr = body_list.get_and_step(); + // Loop on bodies, imprinting each with all the ewires + for( i=0; i<body_list.size(); i++ ) + { + body_ptr = body_list.get_and_step(); - BODY_ptr = AcisQueryEngine::get_BODY(body_ptr); - if( BODY_ptr == NULL ) - { - PRINT_ERROR( "Unable to find ACIS BODY from volume; aborting\n" ); - for( j=0; j<ewire_list.size(); j++ ) - api_delent( ewire_list.get_and_step() ); - return CUBIT_FAILURE; - } + BODY_ptr = AcisQueryEngine::get_BODY(body_ptr); + if( BODY_ptr == NULL ) + { + PRINT_ERROR( "Unable to find ACIS BODY from volume; aborting\n" ); + for( j=0; j<ewire_list.size(); j++ ) + api_delent( ewire_list.get_and_step() ); + return CUBIT_FAILURE; + } - // Copy the body before working with it - copied_BODY_ptr = copy_BODY( BODY_ptr, delete_attribs ); + // Copy the body before working with it + copied_BODY_ptr = copy_BODY( BODY_ptr, delete_attribs ); - // Imprint the wire-bodies onto the BODY - api_set_int_option("all_free_edges", TRUE ); - ewire_list.reset(); - ref_edge_list.reset(); - for( j=0; j<ewire_list.size(); j++ ) - { - wire_BODY_ptr = ewire_list.get_and_step(); - ref_edge_ptr = ref_edge_list.get_and_step(); - BODY* temp_BODY_ptr = copy_BODY( copied_BODY_ptr, delete_attribs ); + // Imprint the wire-bodies onto the BODY + api_set_int_option("all_free_edges", TRUE ); + ewire_list.reset(); + ref_edge_list.reset(); + for( j=0; j<ewire_list.size(); j++ ) + { + wire_BODY_ptr = ewire_list.get_and_step(); + ref_edge_ptr = ref_edge_list.get_and_step(); + BODY* temp_BODY_ptr = copy_BODY( copied_BODY_ptr, delete_attribs ); - result = api_imprint( wire_BODY_ptr, copied_BODY_ptr ); + result = api_imprint( wire_BODY_ptr, copied_BODY_ptr ); - //Gets rid of sliver curves/surfaces that could get produced by the imprint. - AcisModifyEngine::instance()->cleanup_slivers( copied_BODY_ptr ); + //Gets rid of sliver curves/surfaces that could get produced by the imprint. + AcisModifyEngine::instance()->cleanup_slivers( copied_BODY_ptr ); - if( !result.ok() && result.error_number()!=200 ) - { - if ( show_messages ) - { - PRINT_ERROR( "problem imprinting curve onto volume\n" ); - AcisQueryEngine::instance()->ACIS_API_error(result); - } - //revert back to the old body. - api_delent(copied_BODY_ptr); - copied_BODY_ptr = temp_BODY_ptr; - status = CUBIT_FAILURE; - } - else - imprint_worked = CUBIT_TRUE; - } - if( imprint_worked ) - { - api_set_int_option("all_free_edges", FALSE ); + if( !result.ok() && result.error_number()!=200 ) + { + if ( show_messages ) + { + PRINT_ERROR( "problem imprinting curve onto volume\n" ); + AcisQueryEngine::instance()->ACIS_API_error(result); + } + //revert back to the old body. + api_delent(copied_BODY_ptr); + copied_BODY_ptr = temp_BODY_ptr; + status = CUBIT_FAILURE; + } + else + imprint_worked = CUBIT_TRUE; + } + if( imprint_worked ) + { + api_set_int_option("all_free_edges", FALSE ); - DLIList<EDGE*> new_edges = AcisModifyEngine::instance()->find_new_EDGES(copied_BODY_ptr); + DLIList<EDGE*> new_edges = AcisModifyEngine::instance()->find_new_EDGES(copied_BODY_ptr); - BodySM* new_body_ptr = get_new_Body( body_ptr, BODY_ptr, copied_BODY_ptr, - keep_old_body, CUBIT_TRUE ); + BodySM* new_body_ptr = get_new_Body( body_ptr, BODY_ptr, copied_BODY_ptr, + keep_old_body, CUBIT_TRUE ); - if( new_body_ptr ) - { - // Add a imprint feature to the topo edges - for (int edge_count = new_edges.size(); edge_count--; ) - { - CubitSimpleAttrib *tmp_attrib = new CubitSimpleAttrib( "SOURCE_FEATURE", "IMPRINT" ); - new ATTRIB_SNL_SIMPLE( new_edges[edge_count], tmp_attrib ); - delete tmp_attrib; - } - new_body_list.append(new_body_ptr); - } - } - } + if( new_body_ptr ) + { + // Add a imprint feature to the topo edges + for (int edge_count = new_edges.size(); edge_count--; ) + { + CubitSimpleAttrib *tmp_attrib = new CubitSimpleAttrib( "SOURCE_FEATURE", "IMPRINT" ); + new ATTRIB_SNL_SIMPLE( new_edges[edge_count], tmp_attrib ); + delete tmp_attrib; + } + new_body_list.append(new_body_ptr); + } + } + } - // Free memory - for( i=0; i<ewire_list.size(); i++ ) - api_delent( ewire_list.get_and_step() ); - if ( imprint_worked && status != CUBIT_SUCCESS ) - status = CUBIT_SUCCESS; - return status; -} + // Free memory + for( i=0; i<ewire_list.size(); i++ ) + api_delent( ewire_list.get_and_step() ); + if ( imprint_worked && status != CUBIT_SUCCESS ) + status = CUBIT_SUCCESS; + return status; + } -// This is a special case - needed because if a curve hangs over -// several surfaces on a body and the user wants to split only one -// of the surfaces. This method sometimes works when function to -// imprint a curve to a body fails. The surfaces must be part of -// a body, but the curves just have to be valid ACIS EDGEs. -CubitStatus AcisModifyEngine::imprint( DLIList<Surface*> &surface_list, - DLIList<Curve*> &curve_list, - DLIList<BodySM*>& new_body_list, - bool keep_old_body ) const -{ - int i; + // This is a special case - needed because if a curve hangs over + // several surfaces on a body and the user wants to split only one + // of the surfaces. This method sometimes works when function to + // imprint a curve to a body fails. The surfaces must be part of + // a body, but the curves just have to be valid ACIS EDGEs. + CubitStatus AcisModifyEngine::imprint( DLIList<Surface*> &surface_list, + DLIList<Curve*> &curve_list, + DLIList<BodySM*>& new_body_list, + bool keep_old_body ) const + { + int i; - outcome result; + outcome result; - // Copy the incoming surface_list since we will be pulling - // surfaces out of it. - DLIList<SurfaceACIS*> copied_surface_list(surface_list.size()); - Curve* curve_ptr; + // Copy the incoming surface_list since we will be pulling + // surfaces out of it. + DLIList<SurfaceACIS*> copied_surface_list(surface_list.size()); + Curve* curve_ptr; - BodySM *body_ptr; - BODY *BODY_ptr; + BodySM *body_ptr; + BODY *BODY_ptr; - EDGE *EDGE_ptr; - EDGE *copied_EDGE_ptr; + EDGE *EDGE_ptr; + EDGE *copied_EDGE_ptr; - bool delete_attribs = - (GeometryModifyTool::instance()->get_new_ids() || keep_old_body); + bool delete_attribs = + (GeometryModifyTool::instance()->get_new_ids() || keep_old_body); - CAST_LIST( surface_list, copied_surface_list, SurfaceACIS ); - if (surface_list.size() != copied_surface_list.size()) - { - PRINT_ERROR("Non-ACIS Surface at %s:%d\n", __FILE__, __LINE__ ); - return CUBIT_FAILURE; - } + CAST_LIST( surface_list, copied_surface_list, SurfaceACIS ); + if (surface_list.size() != copied_surface_list.size()) + { + PRINT_ERROR("Non-ACIS Surface at %s:%d\n", __FILE__, __LINE__ ); + return CUBIT_FAILURE; + } - // Need to copy all of the EDGE's before doing anything, if they are - // part of a body being imprinted on they could be invalidated before - // subsequent imprints. - DLIList<EDGE*> EDGE_list; - curve_list.reset(); - for( i=curve_list.size(); i--; ) - { - curve_ptr = curve_list.get_and_step(); + // Need to copy all of the EDGE's before doing anything, if they are + // part of a body being imprinted on they could be invalidated before + // subsequent imprints. + DLIList<EDGE*> EDGE_list; + curve_list.reset(); + for( i=curve_list.size(); i--; ) + { + curve_ptr = curve_list.get_and_step(); - // Get the EDGE pointer - EDGE_ptr = AcisQueryEngine::get_EDGE( curve_ptr ); + // Get the EDGE pointer + EDGE_ptr = AcisQueryEngine::get_EDGE( curve_ptr ); - if( EDGE_ptr == NULL ) - { - PRINT_ERROR("Non-ACIS Curve at %s:%d\n", __FILE__, __LINE__ ); - return CUBIT_FAILURE; - } + if( EDGE_ptr == NULL ) + { + PRINT_ERROR("Non-ACIS Curve at %s:%d\n", __FILE__, __LINE__ ); + return CUBIT_FAILURE; + } - // Copy the EDGE. - result = api_edge( EDGE_ptr, copied_EDGE_ptr ); - if (!result.ok()) - { - AcisQueryEngine::instance()->ACIS_API_error (result); - PRINT_ERROR( "Unable to copy curve; aborting.\n" ); - return CUBIT_FAILURE; - } + // Copy the EDGE. + result = api_edge( EDGE_ptr, copied_EDGE_ptr ); + if (!result.ok()) + { + AcisQueryEngine::instance()->ACIS_API_error (result); + PRINT_ERROR( "Unable to copy curve; aborting.\n" ); + return CUBIT_FAILURE; + } - // Remove the CUBIT owner attribute from the EDGE - ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr, CUBIT_TRUE ); + // Remove the CUBIT owner attribute from the EDGE + ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr, CUBIT_TRUE ); - // Add the EDGE to the list - EDGE_list.append( copied_EDGE_ptr ); - } + // Add the EDGE to the list + EDGE_list.append( copied_EDGE_ptr ); + } - // Loop on FACEs. We will work on imprinting surfaces from one body at a time. - copied_surface_list.reset(); - while( copied_surface_list.size() ) - { - DLIList<FACE*> imprint_FACE_list; - BODY *copied_BODY_ptr; - if( get_copied_FACES_of_body( copied_surface_list, imprint_FACE_list, - copied_BODY_ptr ) == CUBIT_FAILURE ) - continue; + // Loop on FACEs. We will work on imprinting surfaces from one body at a time. + copied_surface_list.reset(); + while( copied_surface_list.size() ) + { + DLIList<FACE*> imprint_FACE_list; + BODY *copied_BODY_ptr; + if( get_copied_FACES_of_body( copied_surface_list, imprint_FACE_list, + copied_BODY_ptr ) == CUBIT_FAILURE ) + continue; - // Get original Body and BODY - body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( copied_BODY_ptr ); - BODY_ptr = AcisQueryEngine::get_BODY(body_ptr); + // Get original Body and BODY + body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( copied_BODY_ptr ); + BODY_ptr = AcisQueryEngine::get_BODY(body_ptr); - // Now cleanout the owner attributes from the copied BODY, if required - if( delete_attribs ) - AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copied_BODY_ptr); + // Now cleanout the owner attributes from the copied BODY, if required + if( delete_attribs ) + AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copied_BODY_ptr); - if( imprint( copied_BODY_ptr, imprint_FACE_list, EDGE_list ) == CUBIT_FAILURE ) - { - // This only fails if there is a serious error - delete the copied Body - api_delent( copied_BODY_ptr ); - continue; - } + if( imprint( copied_BODY_ptr, imprint_FACE_list, EDGE_list ) == CUBIT_FAILURE ) + { + // This only fails if there is a serious error - delete the copied Body + api_delent( copied_BODY_ptr ); + continue; + } - DLIList<EDGE*> new_edges = AcisModifyEngine::instance()->find_new_EDGES(copied_BODY_ptr); + DLIList<EDGE*> new_edges = AcisModifyEngine::instance()->find_new_EDGES(copied_BODY_ptr); - BodySM* new_body_ptr = get_new_Body( body_ptr, BODY_ptr, copied_BODY_ptr, - keep_old_body, CUBIT_TRUE ); + BodySM* new_body_ptr = get_new_Body( body_ptr, BODY_ptr, copied_BODY_ptr, + keep_old_body, CUBIT_TRUE ); - if( new_body_ptr ) - { - // Add a imprint feature to the topo edges - for (int edge_count = new_edges.size(); edge_count--; ) - { - CubitSimpleAttrib *tmp_attrib = new CubitSimpleAttrib( "SOURCE_FEATURE", "IMPRINT" ); - new ATTRIB_SNL_SIMPLE( new_edges[edge_count], tmp_attrib ); - delete tmp_attrib; - } + if( new_body_ptr ) + { + // Add a imprint feature to the topo edges + for (int edge_count = new_edges.size(); edge_count--; ) + { + CubitSimpleAttrib *tmp_attrib = new CubitSimpleAttrib( "SOURCE_FEATURE", "IMPRINT" ); + new ATTRIB_SNL_SIMPLE( new_edges[edge_count], tmp_attrib ); + delete tmp_attrib; + } - new_body_list.append( new_body_ptr ); - } - } + new_body_list.append( new_body_ptr ); + } + } - // Free the memory allocated when copying edges - for( i=0; i<EDGE_list.size(); i++ ) - { - copied_EDGE_ptr = EDGE_list.get_and_step(); - api_delent( copied_EDGE_ptr ); - } + // Free the memory allocated when copying edges + for( i=0; i<EDGE_list.size(); i++ ) + { + copied_EDGE_ptr = EDGE_list.get_and_step(); + api_delent( copied_EDGE_ptr ); + } - return CUBIT_SUCCESS; -} + return CUBIT_SUCCESS; + } -// Imprint EDGEs to select FACEs. FACEs must be from same BODY. Input FACEs -// are modified but EDGEs are not. -CubitStatus AcisModifyEngine::imprint( BODY *BODY_ptr, - DLIList<FACE*> &FACE_list, - DLIList<EDGE*> &EDGE_list ) const -{ - // Imprint the edges to the surfaces on this body - outcome result; - EDGE *EDGE_ptr; - FACE *FACE_ptr; - EDGE_list.reset(); - FACE_list.reset(); - int i, j; - for( i=EDGE_list.size(); i--; ) - { - // Imprint this edge selectively to the given faces on this body - EDGE_ptr = EDGE_list.get_and_step(); - - // Track the existing FACEs before imprinting this BODY with the edge. - // Needed so we know which new surfaces result from the imprint. These - // new surfaces will need to be imprinted with subsequent edges. - DLIList<FACE*> FACES_BEFORE; - DLIList<FACE*> FACES_AFTER; - AcisQueryEngine::instance()->get_FACEs( (ENTITY *)BODY_ptr, FACES_BEFORE ); - - FACE_list.reset(); - for( j=FACE_list.size(); j--; ) + // Imprint EDGEs to select FACEs. FACEs must be from same BODY. Input FACEs + // are modified but EDGEs are not. + CubitStatus AcisModifyEngine::imprint( BODY *BODY_ptr, + DLIList<FACE*> &FACE_list, + DLIList<EDGE*> &EDGE_list ) const { - // Get the FACE to imprint to - FACE_ptr = FACE_list.get_and_step(); + // Imprint the edges to the surfaces on this body + outcome result; + EDGE *EDGE_ptr; + FACE *FACE_ptr; + EDGE_list.reset(); + FACE_list.reset(); + int i, j; + for( i=EDGE_list.size(); i--; ) + { + // Imprint this edge selectively to the given faces on this body + EDGE_ptr = EDGE_list.get_and_step(); - if( imprint( BODY_ptr, FACE_ptr, EDGE_ptr ) == CUBIT_FAILURE ) - { - PRINT_ERROR( "Unable to imprint EDGE to FACE\n" ); - continue; - } + // Track the existing FACEs before imprinting this BODY with the edge. + // Needed so we know which new surfaces result from the imprint. These + // new surfaces will need to be imprinted with subsequent edges. + DLIList<FACE*> FACES_BEFORE; + DLIList<FACE*> FACES_AFTER; + AcisQueryEngine::instance()->get_FACEs( (ENTITY *)BODY_ptr, FACES_BEFORE ); - // Check against an assumption that if invalid, will - // cause a crash. The assumption is that the imprinted - // FACE_ptr will remain valid after each imprint. - FACES_AFTER.clean_out(); - AcisQueryEngine::instance()->get_FACEs( (ENTITY *)BODY_ptr, FACES_AFTER ); - if( !FACES_AFTER.is_in_list( FACE_ptr ) ) - { - PRINT_ERROR( "serious problem in imprint - an imprinted surface disappeared!\n" - " Model restored - operation aborted\n" ); - return CUBIT_FAILURE; - } + FACE_list.reset(); + for( j=FACE_list.size(); j--; ) + { + // Get the FACE to imprint to + FACE_ptr = FACE_list.get_and_step(); - } - // End of looping over FACES + if( imprint( BODY_ptr, FACE_ptr, EDGE_ptr ) == CUBIT_FAILURE ) + { + PRINT_ERROR( "Unable to imprint EDGE to FACE\n" ); + continue; + } - // Find which new surfaces were created - add these to the - // FACE_list so that additional edges will imprint - // on these as well. - DLIList<FACE*> new_FACES; - FACE* after_FACE_ptr; - for( j=FACES_AFTER.size(); j--; ) - { - after_FACE_ptr = FACES_AFTER.get_and_step(); + // Check against an assumption that if invalid, will + // cause a crash. The assumption is that the imprinted + // FACE_ptr will remain valid after each imprint. + FACES_AFTER.clean_out(); + AcisQueryEngine::instance()->get_FACEs( (ENTITY *)BODY_ptr, FACES_AFTER ); + if( !FACES_AFTER.is_in_list( FACE_ptr ) ) + { + PRINT_ERROR( "serious problem in imprint - an imprinted surface disappeared!\n" + " Model restored - operation aborted\n" ); + return CUBIT_FAILURE; + } - if( !FACES_BEFORE.is_in_list( after_FACE_ptr ) ) - new_FACES.append(after_FACE_ptr); - } - FACE_list += new_FACES; - } + } + // End of looping over FACES - return CUBIT_SUCCESS; -} + // Find which new surfaces were created - add these to the + // FACE_list so that additional edges will imprint + // on these as well. + DLIList<FACE*> new_FACES; + FACE* after_FACE_ptr; + for( j=FACES_AFTER.size(); j--; ) + { + after_FACE_ptr = FACES_AFTER.get_and_step(); -CubitStatus AcisModifyEngine::imprint( BODY *BODY_ptr, - FACE *FACE_ptr, - EDGE *EDGE_ptr ) const -{ - outcome result; + if( !FACES_BEFORE.is_in_list( after_FACE_ptr ) ) + new_FACES.append(after_FACE_ptr); + } + FACE_list += new_FACES; + } - BODY* tbody = NULL; - BODY* bbody = NULL; // Blank body - FACE* bface = NULL; // Blank face - surface* tsurf = NULL; // Tool surface - EDGE* edge = NULL; + return CUBIT_SUCCESS; + } - //EXCEPTION_TRY + CubitStatus AcisModifyEngine::imprint( BODY *BODY_ptr, + FACE *FACE_ptr, + EDGE *EDGE_ptr ) const + { + outcome result; - bbody = BODY_ptr; - bface = FACE_ptr; - edge = EDGE_ptr; + BODY* tbody = NULL; + BODY* bbody = NULL; // Blank body + FACE* bface = NULL; // Blank face + surface* tsurf = NULL; // Tool surface + EDGE* edge = NULL; - // Get the geometry of the blank face. - surface const& bsurf = bface->geometry()->equation(); + //EXCEPTION_TRY - // Create an empty tool body - tbody = ACIS_NEW BODY( (LUMP*) NULL ); + bbody = BODY_ptr; + bface = FACE_ptr; + edge = EDGE_ptr; - // Create the tool body which consists of a single face - // with a "cross surface" geometric support and no loops. - const curve &temp_cur = edge->geometry()->equation(); - SPAinterval cur_range = temp_cur.param_range(); - SPAinterval edge_range = edge->param_range(); - if (edge->sense() == REVERSED) - edge_range = -edge_range; - if (edge_range == cur_range) - tsurf = cross_surface( edge->geometry()->equation(), - bsurf, *(pcurve*) NULL_REF); - else - { - // Create using a subsetted copy of the curve - curve* subset_cur = temp_cur.subset(edge_range&cur_range); - tsurf = cross_surface( *subset_cur, bsurf, *(pcurve*) NULL_REF); - ACIS_DELETE subset_cur; - } - if( !tsurf ) - { - PRINT_ERROR( "Unable to make imprint surface on body\n" ); - return CUBIT_FAILURE; - } - FACE* tface = ACIS_NEW FACE( NULL, NULL, make_surface( *tsurf ), FORWARD ); - ACIS_DELETE tsurf; // SRS Added 10-29-99 - tbody->set_lump( ACIS_NEW LUMP( ACIS_NEW SHELL( tface, NULL, NULL ), NULL ) ); + // Get the geometry of the blank face. + surface const& bsurf = bface->geometry()->equation(); - // Now, imprint the two bodies and throw away the tool body. The - // resultant blank body will have the edge imprinted on the - // selected face. - EDGE* ssi_edges[1]; - FACE* tfaces[1]; - FACE* bfaces[1]; + // Create an empty tool body + tbody = ACIS_NEW BODY( (LUMP*) NULL ); - ssi_edges[0] = edge; - tfaces[0] = tface; - bfaces[0] = bface; + // Create the tool body which consists of a single face + // with a "cross surface" geometric support and no loops. + const curve &temp_cur = edge->geometry()->equation(); + SPAinterval cur_range = temp_cur.param_range(); + SPAinterval edge_range = edge->param_range(); + if (edge->sense() == REVERSED) + edge_range = -edge_range; + if (edge_range == cur_range) + tsurf = cross_surface( edge->geometry()->equation(), + bsurf, *(pcurve*) NULL_REF); + else + { + // Create using a subsetted copy of the curve + curve* subset_cur = temp_cur.subset(edge_range&cur_range); + tsurf = cross_surface( *subset_cur, bsurf, *(pcurve*) NULL_REF); + ACIS_DELETE subset_cur; + } + if( !tsurf ) + { + PRINT_ERROR( "Unable to make imprint surface on body\n" ); + return CUBIT_FAILURE; + } + FACE* tface = ACIS_NEW FACE( NULL, NULL, make_surface( *tsurf ), FORWARD ); + ACIS_DELETE tsurf; // SRS Added 10-29-99 + tbody->set_lump( ACIS_NEW LUMP( ACIS_NEW SHELL( tface, NULL, NULL ), NULL ) ); - result = api_boolean_start( tbody, bbody ); + // Now, imprint the two bodies and throw away the tool body. The + // resultant blank body will have the edge imprinted on the + // selected face. + EDGE* ssi_edges[1]; + FACE* tfaces[1]; + FACE* bfaces[1]; - if( result.ok() ) - { - // If the edge is known to lie on the face, some expensive - // checking can be ommited by changing the last argument from - // TRUE to FALSE. - result = api_update_intersection( tface, *(SPAtransf *)NULL_REF, bface, - *(SPAtransf *)NULL_REF, 1, ssi_edges, TRUE); + ssi_edges[0] = edge; + tfaces[0] = tface; + bfaces[0] = bface; - if( result.ok() ) - { - result = api_selectively_intersect( 1, tfaces, bfaces ); + result = api_boolean_start( tbody, bbody ); + if( result.ok() ) - { - result = api_imprint_complete( tbody, bbody ); - if( !result.ok() ) - { - PRINT_ERROR( "problem in completing imprint for curve on surface\n" ); - AcisQueryEngine::instance()->ACIS_API_error(result); - api_delent( tbody ); - return CUBIT_FAILURE; - } - } - else - { - PRINT_ERROR( "problem in selective intersect for curve on surface\n" ); - AcisQueryEngine::instance()->ACIS_API_error(result); - api_delent( tbody ); - return CUBIT_FAILURE; - } - } - else if( result.error_number()!=200 && result.error_number()!=615 - && result.error_number()!=715 ) - { - // Error 200 can occur when the imprint does nothing (curve that's - // a surface boundary, curve away from surface). Errors 615/715 can occur - // when imprinting a remnant of the same FACE again with the same curve. - // The orignal FACE_ptr remains after an imprint - it lives as one - // of the remnants. Then, when we attempt to imprint the other pieces - // with the same curves, we are getting error 715. The same error - // can occur when trying to use one of the surfaces own edges to - // imprint with. This has been reported to Spatial and logged as r6294. - // It's not fatal so for now we ignore it. + { + // If the edge is known to lie on the face, some expensive + // checking can be ommited by changing the last argument from + // TRUE to FALSE. + result = api_update_intersection( tface, *(SPAtransf *)NULL_REF, bface, + *(SPAtransf *)NULL_REF, 1, ssi_edges, TRUE); - // We get these all the time, and they don't seem to hurt us. - api_delent( tbody ); - return CUBIT_SUCCESS; - } - } - else - { - PRINT_ERROR( "problem starting boolean for curve on surface\n" ); - AcisQueryEngine::instance()->ACIS_API_error(result); - api_delent( tbody ); - return CUBIT_FAILURE; - } + if( result.ok() ) + { + result = api_selectively_intersect( 1, tfaces, bfaces ); + if( result.ok() ) + { + result = api_imprint_complete( tbody, bbody ); + if( !result.ok() ) + { + PRINT_ERROR( "problem in completing imprint for curve on surface\n" ); + AcisQueryEngine::instance()->ACIS_API_error(result); + api_delent( tbody ); + return CUBIT_FAILURE; + } + } + else + { + PRINT_ERROR( "problem in selective intersect for curve on surface\n" ); + AcisQueryEngine::instance()->ACIS_API_error(result); + api_delent( tbody ); + return CUBIT_FAILURE; + } + } + else if( result.error_number()!=200 && result.error_number()!=615 + && result.error_number()!=715 ) + { + // Error 200 can occur when the imprint does nothing (curve that's + // a surface boundary, curve away from surface). Errors 615/715 can occur + // when imprinting a remnant of the same FACE again with the same curve. + // The orignal FACE_ptr remains after an imprint - it lives as one + // of the remnants. Then, when we attempt to imprint the other pieces + // with the same curves, we are getting error 715. The same error + // can occur when trying to use one of the surfaces own edges to + // imprint with. This has been reported to Spatial and logged as r6294. + // It's not fatal so for now we ignore it. - //EXCEPTION_CATCH(TRUE) + // We get these all the time, and they don't seem to hurt us. + api_delent( tbody ); + return CUBIT_SUCCESS; + } + } + else + { + PRINT_ERROR( "problem starting boolean for curve on surface\n" ); + AcisQueryEngine::instance()->ACIS_API_error(result); + api_delent( tbody ); + return CUBIT_FAILURE; + } - // Remove temporary objects - api_delent( tbody ); + //EXCEPTION_CATCH(TRUE) - //EXCEPTION_END + // Remove temporary objects + api_delent( tbody ); - return CUBIT_SUCCESS; -} + //EXCEPTION_END -//- Imprints a list of Surfaces with list of Curves, sorted per -//- Surface (ie., curve_lists_list is same length as surface_list). -//- This version is more efficient than the general-purpose one -//- above, as we know which curves to imprint with which surfaces. -//- All input surfaces must be from the same body. -CubitStatus AcisModifyEngine::imprint( DLIList<Surface*> &surface_list, - DLIList<DLIList<Curve*>*> &curve_lists_list, - BodySM*& new_body, - bool keep_old_body ) const -{ - // Calling code has already ensured that all the Surfaces are from the - // same body + return CUBIT_SUCCESS; + } - bool delete_attribs = - (GeometryModifyTool::instance()->get_new_ids() || keep_old_body); + //- Imprints a list of Surfaces with list of Curves, sorted per + //- Surface (ie., curve_lists_list is same length as surface_list). + //- This version is more efficient than the general-purpose one + //- above, as we know which curves to imprint with which surfaces. + //- All input surfaces must be from the same body. + CubitStatus AcisModifyEngine::imprint( DLIList<Surface*> &surface_list, + DLIList<DLIList<Curve*>*> &curve_lists_list, + BodySM*& new_body, + bool keep_old_body ) const + { + // Calling code has already ensured that all the Surfaces are from the + // same body - SurfaceACIS* surf_ptr = dynamic_cast<SurfaceACIS*>(surface_list.get()); - if( surf_ptr == NULL ) - return CUBIT_FAILURE; - FACE *FACE_ptr = surf_ptr->get_FACE_ptr(); - if (!FACE_ptr) - { - PRINT_ERROR("Invalid SurfaceACIS (no FACE ptr) at %s:%d\n",__FILE__,__LINE__); - return CUBIT_FAILURE; - } - BODY *BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_ptr ); - if( BODY_ptr == NULL ) - return CUBIT_FAILURE; - BodySM *body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( FACE_ptr ); - if( body_ptr == NULL ) - return CUBIT_FAILURE; + bool delete_attribs = + (GeometryModifyTool::instance()->get_new_ids() || keep_old_body); - int i, j; - EDGE *EDGE_ptr; - DLIList<DLIList<EDGE*>*> EDGE_lists_list; - DLIList<EDGE*> *EDGE_list_ptr; - DLIList<SurfaceACIS*> surf_ACIS_list; + SurfaceACIS* surf_ptr = dynamic_cast<SurfaceACIS*>(surface_list.get()); + if( surf_ptr == NULL ) + return CUBIT_FAILURE; + FACE *FACE_ptr = surf_ptr->get_FACE_ptr(); + if (!FACE_ptr) + { + PRINT_ERROR("Invalid SurfaceACIS (no FACE ptr) at %s:%d\n",__FILE__,__LINE__); + return CUBIT_FAILURE; + } + BODY *BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_ptr ); + if( BODY_ptr == NULL ) + return CUBIT_FAILURE; + BodySM *body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( FACE_ptr ); + if( body_ptr == NULL ) + return CUBIT_FAILURE; - surface_list.reset(); - curve_lists_list.reset(); - for( i=surface_list.size(); i--; ) - { - surf_ptr = dynamic_cast<SurfaceACIS*>(surface_list.get_and_step()); - if (!surf_ptr) - { - PRINT_ERROR("Non-ACIS surface at %s: %d\n",__FILE__,__LINE__); - return CUBIT_FAILURE; - } - surf_ACIS_list.append( surf_ptr ); + int i, j; + EDGE *EDGE_ptr; + DLIList<DLIList<EDGE*>*> EDGE_lists_list; + DLIList<EDGE*> *EDGE_list_ptr; + DLIList<SurfaceACIS*> surf_ACIS_list; - // Make sure there is a FACE associated with this SurfaceACIS - FACE_ptr = surf_ptr->get_FACE_ptr(); - if (!FACE_ptr) - { - PRINT_ERROR("Invalid SurfaceACIS (no FACE ptr) at %s:%d\n",__FILE__,__LINE__); - return CUBIT_FAILURE; - } + surface_list.reset(); + curve_lists_list.reset(); + for( i=surface_list.size(); i--; ) + { + surf_ptr = dynamic_cast<SurfaceACIS*>(surface_list.get_and_step()); + if (!surf_ptr) + { + PRINT_ERROR("Non-ACIS surface at %s: %d\n",__FILE__,__LINE__); + return CUBIT_FAILURE; + } + surf_ACIS_list.append( surf_ptr ); - EDGE_list_ptr = new DLIList<EDGE*>; - EDGE_lists_list.append( EDGE_list_ptr ); + // Make sure there is a FACE associated with this SurfaceACIS + FACE_ptr = surf_ptr->get_FACE_ptr(); + if (!FACE_ptr) + { + PRINT_ERROR("Invalid SurfaceACIS (no FACE ptr) at %s:%d\n",__FILE__,__LINE__); + return CUBIT_FAILURE; + } - DLIList<Curve*> *curve_list_ptr = curve_lists_list.get_and_step(); - curve_list_ptr->reset(); - for( j=curve_list_ptr->size(); j--; ) - { - Curve *curve_ptr = curve_list_ptr->get_and_step(); - CurveACIS* curve_acis_ptr = dynamic_cast<CurveACIS*>(curve_ptr); - if (!curve_acis_ptr) - { - PRINT_ERROR("Non-ACIS curve at %s: %d\n",__FILE__,__LINE__); - return CUBIT_FAILURE; - } - EDGE_ptr = curve_acis_ptr->get_EDGE_ptr(); - if( EDGE_ptr == NULL ) - { - PRINT_ERROR("Invalid CurveACIS (no EDGE ptr) at %s:%d\n",__FILE__,__LINE__); - return CUBIT_FAILURE; - } - EDGE_list_ptr->append( EDGE_ptr ); - } - } + EDGE_list_ptr = new DLIList<EDGE*>; + EDGE_lists_list.append( EDGE_list_ptr ); - // Copy the BODY and get the corresponding FACEs on the copied BODY that need - // to be imprinted - DLIList<FACE*> copied_FACE_list; - BODY *copied_BODY_ptr; - if( get_copied_FACES_of_body( surf_ACIS_list, copied_FACE_list, copied_BODY_ptr ) - == CUBIT_FAILURE ) - { - return CUBIT_FAILURE; - } + DLIList<Curve*> *curve_list_ptr = curve_lists_list.get_and_step(); + curve_list_ptr->reset(); + for( j=curve_list_ptr->size(); j--; ) + { + Curve *curve_ptr = curve_list_ptr->get_and_step(); + CurveACIS* curve_acis_ptr = dynamic_cast<CurveACIS*>(curve_ptr); + if (!curve_acis_ptr) + { + PRINT_ERROR("Non-ACIS curve at %s: %d\n",__FILE__,__LINE__); + return CUBIT_FAILURE; + } + EDGE_ptr = curve_acis_ptr->get_EDGE_ptr(); + if( EDGE_ptr == NULL ) + { + PRINT_ERROR("Invalid CurveACIS (no EDGE ptr) at %s:%d\n",__FILE__,__LINE__); + return CUBIT_FAILURE; + } + EDGE_list_ptr->append( EDGE_ptr ); + } + } - // Now cleanout the owner attributes from the copied BODY, if required - if( delete_attribs ) - AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copied_BODY_ptr); + // Copy the BODY and get the corresponding FACEs on the copied BODY that need + // to be imprinted + DLIList<FACE*> copied_FACE_list; + BODY *copied_BODY_ptr; + if( get_copied_FACES_of_body( surf_ACIS_list, copied_FACE_list, copied_BODY_ptr ) + == CUBIT_FAILURE ) + { + return CUBIT_FAILURE; + } - // Imprint the temporary EDGEs to the FACEs - if( imprint( copied_BODY_ptr, copied_FACE_list, EDGE_lists_list ) == CUBIT_FAILURE ) - { - api_delent( copied_BODY_ptr ); - while( EDGE_lists_list.size() ) delete EDGE_lists_list.pop(); - return CUBIT_FAILURE; - } - DLIList<EDGE*> new_edges = AcisModifyEngine::instance()->find_new_EDGES(copied_BODY_ptr); - new_body = get_new_Body( body_ptr, BODY_ptr, copied_BODY_ptr, false); + // Now cleanout the owner attributes from the copied BODY, if required + if( delete_attribs ) + AcisQueryEngine::instance()->remove_cubit_owner_attrib_in_BODY(copied_BODY_ptr); - // Add a imprint feature to the topo edges - for (int edge_count = new_edges.size(); edge_count-- && new_body; ) - { - CubitSimpleAttrib *tmp_attrib = new CubitSimpleAttrib( "SOURCE_FEATURE", "IMPRINT" ); - new ATTRIB_SNL_SIMPLE( new_edges[edge_count], tmp_attrib ); - delete tmp_attrib; - } + // Imprint the temporary EDGEs to the FACEs + if( imprint( copied_BODY_ptr, copied_FACE_list, EDGE_lists_list ) == CUBIT_FAILURE ) + { + api_delent( copied_BODY_ptr ); + while( EDGE_lists_list.size() ) delete EDGE_lists_list.pop(); + return CUBIT_FAILURE; + } + DLIList<EDGE*> new_edges = AcisModifyEngine::instance()->find_new_EDGES(copied_BODY_ptr); + new_body = get_new_Body( body_ptr, BODY_ptr, copied_BODY_ptr, false); - // Free memory allocated in EDGE_lists_list - while( EDGE_lists_list.size() ) delete EDGE_lists_list.pop(); + // Add a imprint feature to the topo edges + for (int edge_count = new_edges.size(); edge_count-- && new_body; ) + { + CubitSimpleAttrib *tmp_attrib = new CubitSimpleAttrib( "SOURCE_FEATURE", "IMPRINT" ); + new ATTRIB_SNL_SIMPLE( new_edges[edge_count], tmp_attrib ); + delete tmp_attrib; + } - return new_body ? CUBIT_SUCCESS : CUBIT_FAILURE; -} + // Free memory allocated in EDGE_lists_list + while( EDGE_lists_list.size() ) delete EDGE_lists_list.pop(); -DLIList<EDGE*> AcisModifyEngine::find_new_EDGES(BODY *copied_BODY_ptr) -{ - DLIList<EDGE*> return_list; - ENTITY_LIST edge_list; - api_get_edges(copied_BODY_ptr, edge_list); - AcisBridge *ab_edge_ptr = NULL; - for(int i=0; i<edge_list.count(); i++) + return new_body ? CUBIT_SUCCESS : CUBIT_FAILURE; + } + + DLIList<EDGE*> AcisModifyEngine::find_new_EDGES(BODY *copied_BODY_ptr) { - ab_edge_ptr = ATTRIB_CUBIT_OWNER::cubit_owner( edge_list[i] ); - if( !ab_edge_ptr ) - { - return_list.append((EDGE*)edge_list[i]); - //AcisDrawTool::instance()->draw_EDGE( (EDGE*)edge_list[i], CUBIT_BLUE ); - } + DLIList<EDGE*> return_list; + ENTITY_LIST edge_list; + api_get_edges(copied_BODY_ptr, edge_list); + AcisBridge *ab_edge_ptr = NULL; + for(int i=0; i<edge_list.count(); i++) + { + ab_edge_ptr = ATTRIB_CUBIT_OWNER::cubit_owner( edge_list[i] ); + if( !ab_edge_ptr ) + { + return_list.append((EDGE*)edge_list[i]); + //AcisDrawTool::instance()->draw_EDGE( (EDGE*)edge_list[i], CUBIT_BLUE ); + } + } + // GfxDebug::flush(); + return return_list; } - // GfxDebug::flush(); - return return_list; -} -// This version is more efficient if it is known exactly which EDGEs -// need to be imprinted with which FACEs (ie., it does not attempt to -// imprint all input EDGEs to all input FACEs - only those in corresponding -// list positions) -CubitStatus AcisModifyEngine::imprint( BODY *BODY_ptr, - DLIList<FACE*> &FACE_list, - DLIList<DLIList<EDGE*>*> &EDGE_lists_list ) const -{ - // Imprint the edges to the surfaces on this body - outcome result; - FACE *FACE_ptr = 0; - EDGE *EDGE_ptr = 0; + // This version is more efficient if it is known exactly which EDGEs + // need to be imprinted with which FACEs (ie., it does not attempt to + // imprint all input EDGEs to all input FACEs - only those in corresponding + // list positions) + CubitStatus AcisModifyEngine::imprint( BODY *BODY_ptr, + DLIList<FACE*> &FACE_list, + DLIList<DLIList<EDGE*>*> &EDGE_lists_list ) const + { + // Imprint the edges to the surfaces on this body + outcome result; + FACE *FACE_ptr = 0; + EDGE *EDGE_ptr = 0; - int i, j, k, m; + int i, j, k, m; - DLIList<EDGE*> *EDGE_list_ptr; - EDGE_lists_list.reset(); - FACE_list.reset(); - for( i=EDGE_lists_list.size(); i--; ) - { - EDGE_list_ptr = EDGE_lists_list.get_and_step(); - FACE_ptr = FACE_list.get_and_step(); + DLIList<EDGE*> *EDGE_list_ptr; + EDGE_lists_list.reset(); + FACE_list.reset(); + for( i=EDGE_lists_list.size(); i--; ) + { + EDGE_list_ptr = EDGE_lists_list.get_and_step(); + FACE_ptr = FACE_list.get_and_step(); - DLIList<FACE*> temp_FACE_list; - temp_FACE_list.append( FACE_ptr ); + DLIList<FACE*> temp_FACE_list; + temp_FACE_list.append( FACE_ptr ); - EDGE_list_ptr->reset(); - for( j=EDGE_list_ptr->size(); j--; ) - { - // Imprint this edge list selectively to the current FACE - EDGE_ptr = EDGE_list_ptr->get_and_step(); + EDGE_list_ptr->reset(); + for( j=EDGE_list_ptr->size(); j--; ) + { + // Imprint this edge list selectively to the current FACE + EDGE_ptr = EDGE_list_ptr->get_and_step(); - // Track the existing FACEs before imprinting this BODY with the edge. - // Needed so we know which new surfaces result from the imprint. These - // new surfaces will need to be imprinted with subsequent edges. - DLIList<FACE*> FACES_BEFORE; - DLIList<FACE*> FACES_AFTER; + // Track the existing FACEs before imprinting this BODY with the edge. + // Needed so we know which new surfaces result from the imprint. These + // new surfaces will need to be imprinted with subsequent edges. + DLIList<FACE*> FACES_BEFORE; + DLIList<FACE*> FACES_AFTER; - temp_FACE_list.reset(); - for( k=0; k<temp_FACE_list.size(); k++ ) - { - FACE_ptr = temp_FACE_list.get_and_step(); + temp_FACE_list.reset(); + for( k=0; k<temp_FACE_list.size(); k++ ) + { + FACE_ptr = temp_FACE_list.get_and_step(); - FACES_BEFORE.clean_out(); - AcisQueryEngine::instance()->get_FACEs( (ENTITY *)BODY_ptr, FACES_BEFORE ); + FACES_BEFORE.clean_out(); + AcisQueryEngine::instance()->get_FACEs( (ENTITY *)BODY_ptr, FACES_BEFORE ); - if( imprint( BODY_ptr, FACE_ptr, EDGE_ptr ) == CUBIT_FAILURE ) - { - PRINT_ERROR( "Unable to imprint EDGE to FACE\n" ); - continue; - } + if( imprint( BODY_ptr, FACE_ptr, EDGE_ptr ) == CUBIT_FAILURE ) + { + PRINT_ERROR( "Unable to imprint EDGE to FACE\n" ); + continue; + } - // Check against an assumption that if invalid, will - // cause a crash. The assumption is that the imprinted - // FACE_ptr will remain valid after each imprint. - FACES_AFTER.clean_out(); - AcisQueryEngine::instance()->get_FACEs( (ENTITY *)BODY_ptr, FACES_AFTER ); - if( !FACES_AFTER.is_in_list( FACE_ptr ) ) - { - PRINT_ERROR( "serious problem in imprint - an imprinted surface disappeared!\n" - " Model restored - operation aborted\n" ); - return CUBIT_FAILURE; - } + // Check against an assumption that if invalid, will + // cause a crash. The assumption is that the imprinted + // FACE_ptr will remain valid after each imprint. + FACES_AFTER.clean_out(); + AcisQueryEngine::instance()->get_FACEs( (ENTITY *)BODY_ptr, FACES_AFTER ); + if( !FACES_AFTER.is_in_list( FACE_ptr ) ) + { + PRINT_ERROR( "serious problem in imprint - an imprinted surface disappeared!\n" + " Model restored - operation aborted\n" ); + return CUBIT_FAILURE; + } - // Find which new surfaces were created - add these to the - // temp_FACE_list so that additional edges will imprint - // on these as well. - DLIList<FACE*> new_FACES; - FACE* after_FACE_ptr; - for( m=FACES_AFTER.size(); m--; ) - { - after_FACE_ptr = FACES_AFTER.get_and_step(); + // Find which new surfaces were created - add these to the + // temp_FACE_list so that additional edges will imprint + // on these as well. + DLIList<FACE*> new_FACES; + FACE* after_FACE_ptr; + for( m=FACES_AFTER.size(); m--; ) + { + after_FACE_ptr = FACES_AFTER.get_and_step(); - if( !FACES_BEFORE.is_in_list( after_FACE_ptr ) ) - new_FACES.append(after_FACE_ptr); - } - temp_FACE_list += new_FACES; + if( !FACES_BEFORE.is_in_list( after_FACE_ptr ) ) + new_FACES.append(after_FACE_ptr); + } + temp_FACE_list += new_FACES; - // Set list back to correct location - temp_FACE_list.move_to( FACE_ptr ); - temp_FACE_list.step(); - } // End of looping over temp_FACE_list + // Set list back to correct location + temp_FACE_list.move_to( FACE_ptr ); + temp_FACE_list.step(); + } // End of looping over temp_FACE_list + } + } + return CUBIT_SUCCESS; } - } - return CUBIT_SUCCESS; -} -// Imprints locations to bodies (for splitting curves or putting hardpoints -// on surfaces). -CubitStatus AcisModifyEngine::imprint( DLIList<BodySM*> &body_list, - DLIList<CubitVector*> &vector_list, - DLIList<BodySM*>& new_body_list, - bool keep_old_body, - DLIList<TopologyBridge*> *new_tbs, - DLIList<TopologyBridge*> *att_tbs ) const -{ - // Until Spatial fixes imprinting with vertices, implement a hack - // (Steve Storm, Caterpillar Inc.) - int i, j, k; - outcome result; - double tol = 1e-3; - //CubitStatus status = CUBIT_SUCCESS; + // Imprints locations to bodies (for splitting curves or putting hardpoints + // on surfaces). + CubitStatus AcisModifyEngine::imprint( DLIList<BodySM*> &body_list, + DLIList<CubitVector*> &vector_list, + DLIList<BodySM*>& new_body_list, + bool keep_old_body, + DLIList<TopologyBridge*> *new_tbs, + DLIList<TopologyBridge*> *att_tbs ) const + { + // Until Spatial fixes imprinting with vertices, implement a hack + // (Steve Storm, Caterpillar Inc.) + int i, j, k; + outcome result; + double tol = 1e-3; + //CubitStatus status = CUBIT_SUCCESS; - CubitVector* vector_ptr; - BodySM *body_ptr; + CubitVector* vector_ptr; + BodySM *body_ptr; - VERTEX *VERTEX_ptr; - EDGE *EDGE_ptr; - FACE *FACE_ptr; + VERTEX *VERTEX_ptr; + EDGE *EDGE_ptr; + FACE *FACE_ptr; - BODY *BODY_ptr; - BODY *copied_BODY_ptr; + BODY *BODY_ptr; + BODY *copied_BODY_ptr; - //CubitVector vertex_coords; + //CubitVector vertex_coords; - bool delete_attribs = - (GeometryModifyTool::instance()->get_new_ids() || keep_old_body); + bool delete_attribs = + (GeometryModifyTool::instance()->get_new_ids() || keep_old_body); - // Set an option for imprinting - api_set_int_option("all_free_edges", TRUE ); + // Set an option for imprinting + api_set_int_option("all_free_edges", TRUE ); - // new_ENTITIES will hold new entities that were created by - // the imprint operation. att_ENTITIES will hold entities - // from the original bodies that had composite attributes - // on them. At the end we will compare the new entities - // with the ones that had attributes and if we find matches - // we will put a composite attribute on the new entity. - // This is how we are handling the imprinting of bodies - // with composites. - DLIList<ENTITY*> new_ENTITIES; - DLIList<ENTITY*> att_ENTITIES; + // new_ENTITIES will hold new entities that were created by + // the imprint operation. att_ENTITIES will hold entities + // from the original bodies that had composite attributes + // on them. At the end we will compare the new entities + // with the ones that had attributes and if we find matches + // we will put a composite attribute on the new entity. + // This is how we are handling the imprinting of bodies + // with composites. + DLIList<ENTITY*> new_ENTITIES; + DLIList<ENTITY*> att_ENTITIES; - body_list.reset(); - for( i=0; i<body_list.size(); i++ ) - { - body_ptr = body_list.get_and_step(); + body_list.reset(); + for( i=0; i<body_list.size(); i++ ) + { + body_ptr = body_list.get_and_step(); - BODY_ptr = AcisQueryEngine::get_BODY( body_ptr ); - if( BODY_ptr == NULL ) - return CUBIT_FAILURE; + BODY_ptr = AcisQueryEngine::get_BODY( body_ptr ); + if( BODY_ptr == NULL ) + return CUBIT_FAILURE; - // Copy the body before working with it - copied_BODY_ptr = copy_BODY( BODY_ptr, delete_attribs ); + // Copy the body before working with it + copied_BODY_ptr = copy_BODY( BODY_ptr, delete_attribs ); - // Get all the vertices of the BODY - DLIList<VERTEX*> VERTEX_list; - AcisQueryEngine::instance()->get_VERTICEs( (ENTITY*)BODY_ptr, VERTEX_list ); + // Get all the vertices of the BODY + DLIList<VERTEX*> VERTEX_list; + AcisQueryEngine::instance()->get_VERTICEs( (ENTITY*)BODY_ptr, VERTEX_list ); - // Get all the FACES of the *original* BODY - DLIList<FACE*> FACE_list; - AcisQueryEngine::instance()->get_FACEs( (ENTITY*)BODY_ptr, FACE_list ); + // Get all the FACES of the *original* BODY + DLIList<FACE*> FACE_list; + AcisQueryEngine::instance()->get_FACEs( (ENTITY*)BODY_ptr, FACE_list ); - // Loop through the passed-in locations, first checking for coincidence - // w/vertices, then if on curves, then on faces. - vector_list.reset(); - for( j=0; j<vector_list.size(); j++ ) - { - vector_ptr = vector_list.get_and_step(); - SPAposition test_point( vector_ptr->x(), vector_ptr->y(), vector_ptr->z() ); + // Loop through the passed-in locations, first checking for coincidence + // w/vertices, then if on curves, then on faces. + vector_list.reset(); + for( j=0; j<vector_list.size(); j++ ) + { + vector_ptr = vector_list.get_and_step(); + SPAposition test_point( vector_ptr->x(), vector_ptr->y(), vector_ptr->z() ); - CubitBoolean on_vertex = CUBIT_FALSE; - VERTEX_list.reset(); - for( k=0; k<VERTEX_list.size(); k++ ) - { - VERTEX_ptr = VERTEX_list.get_and_step(); + CubitBoolean on_vertex = CUBIT_FALSE; + VERTEX_list.reset(); + for( k=0; k<VERTEX_list.size(); k++ ) + { + VERTEX_ptr = VERTEX_list.get_and_step(); - SPAposition VERTEX_coords = VERTEX_ptr->geometry()->coords(); + SPAposition VERTEX_coords = VERTEX_ptr->geometry()->coords(); - if (( fabs(VERTEX_coords.x() - vector_ptr->x()) < tol) && - ( fabs(VERTEX_coords.y() - vector_ptr->y()) < tol) && - ( fabs(VERTEX_coords.z() - vector_ptr->z()) < tol)) - { - on_vertex = CUBIT_TRUE; - break; // Skip - coincident with a vertex - } - } + if (( fabs(VERTEX_coords.x() - vector_ptr->x()) < tol) && + ( fabs(VERTEX_coords.y() - vector_ptr->y()) < tol) && + ( fabs(VERTEX_coords.z() - vector_ptr->z()) < tol)) + { + on_vertex = CUBIT_TRUE; + break; // Skip - coincident with a vertex + } + } - if( on_vertex ) - continue; // No imprinting necessary + if( on_vertex ) + continue; // No imprinting necessary - // Get all the EDGES of the copied BODY - DLIList<EDGE*> EDGE_list; - AcisQueryEngine::instance()->get_EDGEs( (ENTITY*)copied_BODY_ptr, EDGE_list ); + // Get all the EDGES of the copied BODY + DLIList<EDGE*> EDGE_list; + AcisQueryEngine::instance()->get_EDGEs( (ENTITY*)copied_BODY_ptr, EDGE_list ); - // Check the EDGES - CubitBoolean on_edge = CUBIT_FALSE; - EDGE_list.reset(); - for( k=0; k<EDGE_list.size(); k++ ) - { - EDGE_ptr = EDGE_list.get_and_step(); + // Check the EDGES + CubitBoolean on_edge = CUBIT_FALSE; + EDGE_list.reset(); + for( k=0; k<EDGE_list.size(); k++ ) + { + EDGE_ptr = EDGE_list.get_and_step(); - if (EDGE_ptr->geometry() == NULL) - continue; // Check next edge + if (EDGE_ptr->geometry() == NULL) + continue; // Check next edge - //const curve* acis_curve = &EDGE_ptr->geometry()->equation(); + //const curve* acis_curve = &EDGE_ptr->geometry()->equation(); - SPAtransf ftrans; + SPAtransf ftrans; - point_edge_containment pe_rel; + point_edge_containment pe_rel; - ENTITY *ENTITY_ptr = NULL; - SPAparameter param; + ENTITY *ENTITY_ptr = NULL; + SPAparameter param; - pe_rel = sg_point_in_edge( test_point, EDGE_ptr, ftrans, ENTITY_ptr, param ); + pe_rel = sg_point_in_edge( test_point, EDGE_ptr, ftrans, ENTITY_ptr, param ); - if( pe_rel == point_off_edge ) - continue; // Check next edge - else if( pe_rel == point_on_edge ) - { - on_edge = CUBIT_TRUE; - VERTEX *new_vertex = ACIS_NEW VERTEX( ACIS_NEW APOINT( test_point) ); + if( pe_rel == point_off_edge ) + continue; // Check next edge + else if( pe_rel == point_on_edge ) + { + on_edge = CUBIT_TRUE; + VERTEX *new_vertex = ACIS_NEW VERTEX( ACIS_NEW APOINT( test_point) ); - API_BEGIN; - sg_split_edge_at_vertex( EDGE_ptr, new_vertex ); - API_END; + API_BEGIN; + sg_split_edge_at_vertex( EDGE_ptr, new_vertex ); + API_END; - if( !result.ok() && result.error_number()!=200 ) - { - AcisQueryEngine::instance()->ACIS_API_error(result); - PRINT_ERROR( "problem imprinting curve onto volume\n"); - } + if( !result.ok() && result.error_number()!=200 ) + { + AcisQueryEngine::instance()->ACIS_API_error(result); + PRINT_ERROR( "problem imprinting curve onto volume\n"); + } - break; - } - } + break; + } + } - if( on_edge ) - continue; // Already imprinted onto the body - check next vertex + if( on_edge ) + continue; // Already imprinted onto the body - check next vertex - // Check the FACES - FACE_list.reset(); - for( k=0; k<FACE_list.size(); k++ ) - { - FACE_ptr = FACE_list.get_and_step(); + // Check the FACES + FACE_list.reset(); + for( k=0; k<FACE_list.size(); k++ ) + { + FACE_ptr = FACE_list.get_and_step(); - if (FACE_ptr->geometry() == NULL) - continue; // Check next face + if (FACE_ptr->geometry() == NULL) + continue; // Check next face - SPAtransf ftrans; + SPAtransf ftrans; - point_face_containment pf_rel = point_in_face( test_point, FACE_ptr, ftrans ); - if( pf_rel == point_outside_face ) - continue; // Check next face - else if( pf_rel == point_inside_face ) - { - // Create a short curve normal to the surface at the vertex and imprint it - SPAunit_vector norm; - norm = FACE_ptr->geometry()->equation().point_normal( test_point ); + point_face_containment pf_rel = point_in_face( test_point, FACE_ptr, ftrans ); + if( pf_rel == point_outside_face ) + continue; // Check next face + else if( pf_rel == point_inside_face ) + { + // Create a short curve normal to the surface at the vertex and imprint it + SPAunit_vector norm; + norm = FACE_ptr->geometry()->equation().point_normal( test_point ); - if ( FACE_ptr->sense() == REVERSED ) - norm = -norm; + if ( FACE_ptr->sense() == REVERSED ) + norm = -norm; - // Find the end point - SPAposition end_point; - end_point.set_x( test_point.x() + (tol * norm.x()) ); - end_point.set_y( test_point.y() + (tol * norm.y()) ); - end_point.set_z( test_point.z() + (tol * norm.z()) ); + // Find the end point + SPAposition end_point; + end_point.set_x( test_point.x() + (tol * norm.x()) ); + end_point.set_y( test_point.y() + (tol * norm.y()) ); + end_point.set_z( test_point.z() + (tol * norm.z()) ); - // Create the curve - EDGE* new_EDGE_ptr = NULL; - result = api_mk_ed_line ( test_point, end_point, new_EDGE_ptr ); - if (!result.ok() || new_EDGE_ptr == NULL) - { - AcisQueryEngine::instance()->ACIS_API_error (result); - PRINT_WARNING("Unable to make short normal curve for imprint operation\n" ); - continue; - } + // Create the curve + EDGE* new_EDGE_ptr = NULL; + result = api_mk_ed_line ( test_point, end_point, new_EDGE_ptr ); + if (!result.ok() || new_EDGE_ptr == NULL) + { + AcisQueryEngine::instance()->ACIS_API_error (result); + PRINT_WARNING("Unable to make short normal curve for imprint operation\n" ); + continue; + } - // Create a wire from the short curve - BODY *wire_BODY_ptr = NULL; - result = api_make_ewire( 1, &new_EDGE_ptr, wire_BODY_ptr ); - if (!result.ok()) - { - AcisQueryEngine::instance()->ACIS_API_error (result); - PRINT_WARNING( "Unable to make ACIS WIRE from short imprint curve\n" ); + // Create a wire from the short curve + BODY *wire_BODY_ptr = NULL; + result = api_make_ewire( 1, &new_EDGE_ptr, wire_BODY_ptr ); + if (!result.ok()) + { + AcisQueryEngine::instance()->ACIS_API_error (result); + PRINT_WARNING( "Unable to make ACIS WIRE from short imprint curve\n" ); - if( wire_BODY_ptr ) - api_delent( wire_BODY_ptr ); - else - api_delent( new_EDGE_ptr ); - continue; - } + if( wire_BODY_ptr ) + api_delent( wire_BODY_ptr ); + else + api_delent( new_EDGE_ptr ); + continue; + } - // Imprint the wire-body onto the BODY - result = api_imprint( wire_BODY_ptr, copied_BODY_ptr ); + // Imprint the wire-body onto the BODY + result = api_imprint( wire_BODY_ptr, copied_BODY_ptr ); - if( !result.ok() && result.error_number()!=200 ) - { - AcisQueryEngine::instance()->ACIS_API_error(result); - PRINT_ERROR( "problem imprinting short curve onto volume\n"); - } + if( !result.ok() && result.error_number()!=200 ) + { + AcisQueryEngine::instance()->ACIS_API_error(result); + PRINT_ERROR( "problem imprinting short curve onto volume\n"); + } - api_delent( wire_BODY_ptr ); + api_delent( wire_BODY_ptr ); - break; // Done imprinting with this vertex + break; // Done imprinting with this vertex - } - else if( pf_rel == point_boundary_face ) - { - PRINT_WARNING( "Algorithm error - point found on boundary of surface - please report this\n" ); - continue; - } - else if( pf_rel == point_unknown_face ) - continue; // Check next face - } - } + } + else if( pf_rel == point_boundary_face ) + { + PRINT_WARNING( "Algorithm error - point found on boundary of surface - please report this\n" ); + continue; + } + else if( pf_rel == point_unknown_face ) + continue; // Check next face + } + } - AcisModifyEngine::instance()->cleanup_slivers( copied_BODY_ptr ); + AcisModifyEngine::instance()->cleanup_slivers( copied_BODY_ptr ); - // Get the new entities (just edges for now) - // created by the imprint operation. - DLIList<ENTITY*> cur_new_ENTITIES; - if(copied_BODY_ptr && new_tbs) - get_new_ENTITIES(copied_BODY_ptr, cur_new_ENTITIES); + // Get the new entities (just edges for now) + // created by the imprint operation. + DLIList<ENTITY*> cur_new_ENTITIES; + if(copied_BODY_ptr && new_tbs) + get_new_ENTITIES(copied_BODY_ptr, cur_new_ENTITIES); - BodySM* new_body_ptr = get_new_Body( body_ptr, BODY_ptr, - copied_BODY_ptr, keep_old_body, CUBIT_TRUE ); - if (new_body_ptr) - { - new_body_list.append(new_body_ptr); + BodySM* new_body_ptr = get_new_Body( body_ptr, BODY_ptr, + copied_BODY_ptr, keep_old_body, CUBIT_TRUE ); + if (new_body_ptr) + { + new_body_list.append(new_body_ptr); - // Add the new entities to the list we are - // accumulating. - if(new_tbs) - new_ENTITIES += cur_new_ENTITIES; + // Add the new entities to the list we are + // accumulating. + if(new_tbs) + new_ENTITIES += cur_new_ENTITIES; - // Get entities with composite attributes. - if(copied_BODY_ptr && att_tbs) - get_att_ENTITIES(copied_BODY_ptr, att_ENTITIES, "COMPOSITE_GEOM"); + // Get entities with composite attributes. + if(copied_BODY_ptr && att_tbs) + get_att_ENTITIES(copied_BODY_ptr, att_ENTITIES, "COMPOSITE_GEOM"); - } - else - { - // Get entities with composite attributes. - if(att_tbs) - get_att_ENTITIES(BODY_ptr, att_ENTITIES, "COMPOSITE_GEOM"); - } + } + else + { + // Get entities with composite attributes. + if(att_tbs) + get_att_ENTITIES(BODY_ptr, att_ENTITIES, "COMPOSITE_GEOM"); + } - } + } - // Convert the new_ENTITIES/att_ENTITIES lists into - // topology bridge lists. - if(new_tbs) - { - for(i=new_ENTITIES.size(); i--;) - { - ENTITY *cur_ENT = new_ENTITIES.get_and_step(); - AcisBridge *acis_bridge = ATTRIB_CUBIT_OWNER::cubit_owner(cur_ENT); - if(dynamic_cast<TopologyBridge*>(acis_bridge)) - new_tbs->append_unique(dynamic_cast<TopologyBridge*>(acis_bridge)); - } - } - if(att_tbs) - { - for(i=att_ENTITIES.size(); i--;) - { - ENTITY *cur_ENT = att_ENTITIES.get_and_step(); - AcisBridge *acis_bridge = ATTRIB_CUBIT_OWNER::cubit_owner(cur_ENT); - if(dynamic_cast<TopologyBridge*>(acis_bridge)) - att_tbs->append_unique(dynamic_cast<TopologyBridge*>(acis_bridge)); - } - } + // Convert the new_ENTITIES/att_ENTITIES lists into + // topology bridge lists. + if(new_tbs) + { + for(i=new_ENTITIES.size(); i--;) + { + ENTITY *cur_ENT = new_ENTITIES.get_and_step(); + AcisBridge *acis_bridge = ATTRIB_CUBIT_OWNER::cubit_owner(cur_ENT); + if(dynamic_cast<TopologyBridge*>(acis_bridge)) + new_tbs->append_unique(dynamic_cast<TopologyBridge*>(acis_bridge)); + } + } + if(att_tbs) + { + for(i=att_ENTITIES.size(); i--;) + { + ENTITY *cur_ENT = att_ENTITIES.get_and_step(); + AcisBridge *acis_bridge = ATTRIB_CUBIT_OWNER::cubit_owner(cur_ENT); + if(dynamic_cast<TopologyBridge*>(acis_bridge)) + att_tbs->append_unique(dynamic_cast<TopologyBridge*>(acis_bridge)); + } + } - api_set_int_option("all_free_edges", FALSE ); + api_set_int_option("all_free_edges", FALSE ); - return CUBIT_SUCCESS; + return CUBIT_SUCCESS; -// When Spatial gets vertex body to body imprinting working, you should be -// able to replace all of the above code with this code. + // When Spatial gets vertex body to body imprinting working, you should be + // able to replace all of the above code with this code. #if 0 - int i, j; - outcome result; - CubitStatus status = CUBIT_SUCCESS; + int i, j; + outcome result; + CubitStatus status = CUBIT_SUCCESS; - RefVertex* ref_vertex_ptr; - Body *body_ptr; + RefVertex* ref_vertex_ptr; + Body *body_ptr; - BODY *BODY_ptr; - BODY *copied_BODY_ptr; + BODY *BODY_ptr; + BODY *copied_BODY_ptr; - CubitVector vertex_coords; - BODY* vertex_BODY_ptr; - DLIList<BODY*> vertex_BODY_list; + CubitVector vertex_coords; + BODY* vertex_BODY_ptr; + DLIList<BODY*> vertex_BODY_list; - bool delete_attribs = - (GeometryModifyTool::instance()->new_ids() || keep_old_body); + bool delete_attribs = + (GeometryModifyTool::instance()->new_ids() || keep_old_body); - // Create a list of BODYs that consist of single points. These - // will be used for imprinting onto the BODYs. - vector_list.reset(); - SPAposition acis_position[1]; - for( i=0; i<vector_list.size(); i++ ) - { - vector_ptr = vector_list.get_and_step(); + // Create a list of BODYs that consist of single points. These + // will be used for imprinting onto the BODYs. + vector_list.reset(); + SPAposition acis_position[1]; + for( i=0; i<vector_list.size(); i++ ) + { + vector_ptr = vector_list.get_and_step(); - acis_position[0].set_x( vector_ptr->x() ); - acis_position[0].set_y( vector_ptr->y() ); - acis_position[0].set_z( vector_ptr->z() ); + acis_position[0].set_x( vector_ptr->x() ); + acis_position[0].set_y( vector_ptr->y() ); + acis_position[0].set_z( vector_ptr->z() ); - result = api_make_wire( NULL, 1, acis_position, vertex_BODY_ptr ); - if( !result.ok() ) - { - AcisQueryEngine::instance()->ACIS_API_error (result); - PRINT_ERROR( "unable to make degenerate wire body from location %f, %f, %f; aborting\n", - vector_ptr->x(), vector_ptr->y(), vector_ptr->z() ); - for( j=0; j<vertex_BODY_list.size(); j++ ) - api_delent( vertex_BODY_list.get_and_step() ); - return CUBIT_FAILURE; - } + result = api_make_wire( NULL, 1, acis_position, vertex_BODY_ptr ); + if( !result.ok() ) + { + AcisQueryEngine::instance()->ACIS_API_error (result); + PRINT_ERROR( "unable to make degenerate wire body from location %f, %f, %f; aborting\n", + vector_ptr->x(), vector_ptr->y(), vector_ptr->z() ); + for( j=0; j<vertex_BODY_list.size(); j++ ) + api_delent( vertex_BODY_list.get_and_step() ); + return CUBIT_FAILURE; + } - vertex_BODY_list.append( vertex_BODY_ptr ); - } + vertex_BODY_list.append( vertex_BODY_ptr ); + } - // Loop on bodies, imprinting each with all the vertex BODYs. - for( i=0; i<body_list.size(); i++ ) - { - body_ptr = body_list.get_and_step(); + // Loop on bodies, imprinting each with all the vertex BODYs. + for( i=0; i<body_list.size(); i++ ) + { + body_ptr = body_list.get_and_step(); - BODY_ptr = AcisQueryEngine::get_BODY( body_ptr ); - if( BODY_ptr == NULL ) - { -//NOTE TO JS - PRINT_ERROR( "Unable to get ACIS BODY from Body %d; aborting\n", - body_ptr->id() ); - for( j=0; j<vertex_BODY_list.size(); j++ ) - api_delent( vertex_BODY_list.get_and_step() ); - return CUBIT_FAILURE; - } + BODY_ptr = AcisQueryEngine::get_BODY( body_ptr ); + if( BODY_ptr == NULL ) + { + //NOTE TO JS + PRINT_ERROR( "Unable to get ACIS BODY from Body %d; aborting\n", + body_ptr->id() ); + for( j=0; j<vertex_BODY_list.size(); j++ ) + api_delent( vertex_BODY_list.get_and_step() ); + return CUBIT_FAILURE; + } - // Copy the body before working with it - copied_BODY_ptr = copy_BODY( BODY_ptr, delete_attribs ); + // Copy the body before working with it + copied_BODY_ptr = copy_BODY( BODY_ptr, delete_attribs ); - // Imprint the wire-bodies onto the BODY - api_set_int_option("all_free_edges", TRUE ); - vertex_BODY_list.reset(); - vector_list.reset(); - for( i=0; i<vertex_BODY_list.size(); i++ ) - { - vertex_BODY_ptr = vertex_BODY_list.get_and_step(); - vector_ptr = vector_list.get_and_step(); + // Imprint the wire-bodies onto the BODY + api_set_int_option("all_free_edges", TRUE ); + vertex_BODY_list.reset(); + vector_list.reset(); + for( i=0; i<vertex_BODY_list.size(); i++ ) + { + vertex_BODY_ptr = vertex_BODY_list.get_and_step(); + vector_ptr = vector_list.get_and_step(); - result = api_imprint( vertex_BODY_ptr, copied_BODY_ptr ); + result = api_imprint( vertex_BODY_ptr, copied_BODY_ptr ); - if( !result.ok() && result.error_number()!=200 ) - { -//NOTE to JS - PRINT_ERROR( "problem imprinting location %f, %f, %f to body %d\n", - vector_ptr->x(), vector_ptr->y(), vector_ptr->z(), - body_ptr->id() ); - AcisQueryEngine::instance()->ACIS_API_error(result); - status = CUBIT_FAILURE; - } - } - api_set_int_option("all_free_edges", FALSE ); + if( !result.ok() && result.error_number()!=200 ) + { + //NOTE to JS + PRINT_ERROR( "problem imprinting location %f, %f, %f to body %d\n", + vector_ptr->x(), vector_ptr->y(), vector_ptr->z(), + body_ptr->id() ); + AcisQueryEngine::instance()->ACIS_API_error(result); + status = CUBIT_FAILURE; + } + } + api_set_int_option("all_free_edges", FALSE ); - Body* new_body_ptr = get_new_Body( body_ptr, BODY_ptr, copied_BODY_ptr, - keep_old_body, CUBIT_TRUE ); + Body* new_body_ptr = get_new_Body( body_ptr, BODY_ptr, copied_BODY_ptr, + keep_old_body, CUBIT_TRUE ); - if( new_body_ptr!=NULL && new_body_ptr!=body_ptr ) - { -//NOTE TO JS - PRINT_INFO( "Created new body %d\n", new_body_ptr->id() ); - new_body_list.append( new_body_ptr ); - } - else if( new_body_ptr!=NULL && new_body_ptr==body_ptr ) - { -//NOTE TO JS - PRINT_INFO( "Modified body %d\n", body_ptr->id() ); - } -//NOTE TO JS - else - PRINT_WARNING( "Body %d was not modified\n", body_ptr->id() ); - } + if( new_body_ptr!=NULL && new_body_ptr!=body_ptr ) + { + //NOTE TO JS + PRINT_INFO( "Created new body %d\n", new_body_ptr->id() ); + new_body_list.append( new_body_ptr ); + } + else if( new_body_ptr!=NULL && new_body_ptr==body_ptr ) + { + //NOTE TO JS + PRINT_INFO( "Modified body %d\n", body_ptr->id() ); + } + //NOTE TO JS + else + PRINT_WARNING( "Body %d was not modified\n", body_ptr->id() ); + } - // Free memory - for( i=0; i<vertex_BODY_list.size(); i++ ) - api_delent( vertex_BODY_list.get_and_step() ); + // Free memory + for( i=0; i<vertex_BODY_list.size(); i++ ) + api_delent( vertex_BODY_list.get_and_step() ); - return status; + return status; #endif -} + } -CubitStatus -AcisModifyEngine::offset_curves( DLIList<Curve*>& ref_edge_list, - DLIList<Curve*>& new_curves, - double offset_distance, - const CubitVector& offset_direction, - int gap_type ) -{ - int i; + CubitStatus + AcisModifyEngine::offset_curves( DLIList<Curve*>& ref_edge_list, + DLIList<Curve*>& new_curves, + double offset_distance, + const CubitVector& offset_direction, + int gap_type ) + { + int i; - Curve* ref_edge_ptr; - EDGE* EDGE_ptr; - outcome result; + Curve* ref_edge_ptr; + EDGE* EDGE_ptr; + outcome result; - // If there's just one curve, and it's linear, all we can do is copy it and move it. - // SRS Note (1-12-01) - this code should be moved up into GeometryTool...but, we - // would need to be able to move a curve. When that capability exists move the - // code. + // If there's just one curve, and it's linear, all we can do is copy it and move it. + // SRS Note (1-12-01) - this code should be moved up into GeometryTool...but, we + // would need to be able to move a curve. When that capability exists move the + // code. - //CubitBoolean move_curve = CUBIT_FALSE; + //CubitBoolean move_curve = CUBIT_FALSE; - if( ref_edge_list.size() == 1 && (offset_direction.x() || offset_direction.y() || - offset_direction.z()) ) - { - ref_edge_ptr = ref_edge_list.get(); - if( AcisQueryEngine::instance()->is_curve_app_straight( ref_edge_ptr ) == CUBIT_TRUE ) - { + if( ref_edge_list.size() == 1 && (offset_direction.x() || offset_direction.y() || + offset_direction.z()) ) + { + ref_edge_ptr = ref_edge_list.get(); + if( AcisQueryEngine::instance()->is_curve_app_straight( ref_edge_ptr ) == CUBIT_TRUE ) + { - EDGE_ptr = AcisQueryEngine::get_EDGE(ref_edge_ptr); + EDGE_ptr = AcisQueryEngine::get_EDGE(ref_edge_ptr); - if( EDGE_ptr == NULL ) - return CUBIT_FAILURE; + if( EDGE_ptr == NULL ) + return CUBIT_FAILURE; - // Copy and move the EDGE - EDGE* new_EDGE_ptr2 = copy_and_move_EDGE( EDGE_ptr, offset_direction, - offset_distance ); + // Copy and move the EDGE + EDGE* new_EDGE_ptr2 = copy_and_move_EDGE( EDGE_ptr, offset_direction, + offset_distance ); - Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges( new_EDGE_ptr2 ); - new_curves.append(curve_ptr); - return CUBIT_SUCCESS; - } - else - { - PRINT_WARNING( "Direction qualifier ignored - only valid for one straight curve\n" ); - } - } - else if( offset_direction.x() || offset_direction.y() || offset_direction.z() ) - { - PRINT_WARNING( "Direction qualifier ignored - only valid for one straight curve\n" ); - } + Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges( new_EDGE_ptr2 ); + new_curves.append(curve_ptr); + return CUBIT_SUCCESS; + } + else + { + PRINT_WARNING( "Direction qualifier ignored - only valid for one straight curve\n" ); + } + } + else if( offset_direction.x() || offset_direction.y() || offset_direction.z() ) + { + PRINT_WARNING( "Direction qualifier ignored - only valid for one straight curve\n" ); + } - // Create a wire from the given EDGEs + // Create a wire from the given EDGEs - // Offset the RefEdges - DLIList<EDGE*> old_EDGE_list; - if( AcisQueryEngine::instance()->get_EDGEs_of_Curves( ref_edge_list, old_EDGE_list ) - == CUBIT_FAILURE ) - return CUBIT_FAILURE; + // Offset the RefEdges + DLIList<EDGE*> old_EDGE_list; + if( AcisQueryEngine::instance()->get_EDGEs_of_Curves( ref_edge_list, old_EDGE_list ) + == CUBIT_FAILURE ) + return CUBIT_FAILURE; - DLIList<EDGE*> new_EDGE_list; - if( offset_EDGES( old_EDGE_list, offset_distance, gap_type, new_EDGE_list ) == CUBIT_FAILURE ) - { - PRINT_ERROR( "Unable to offset the curves\n" ); - return CUBIT_FAILURE; - } + DLIList<EDGE*> new_EDGE_list; + if( offset_EDGES( old_EDGE_list, offset_distance, gap_type, new_EDGE_list ) == CUBIT_FAILURE ) + { + PRINT_ERROR( "Unable to offset the curves\n" ); + return CUBIT_FAILURE; + } - // Make free curves from the offset EDGEs - new_EDGE_list.reset(); - for( i=0; i<new_EDGE_list.size(); i++ ) - { - EDGE_ptr = new_EDGE_list.get_and_step(); + // Make free curves from the offset EDGEs + new_EDGE_list.reset(); + for( i=0; i<new_EDGE_list.size(); i++ ) + { + EDGE_ptr = new_EDGE_list.get_and_step(); - Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges( EDGE_ptr ); - new_curves.append(curve_ptr); - } + Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges( EDGE_ptr ); + new_curves.append(curve_ptr); + } - return CUBIT_SUCCESS; -} + return CUBIT_SUCCESS; + } -Curve* -AcisModifyEngine::trim_curve( Curve* trim_curve, - const CubitVector& trim_vector, - const CubitVector& keep_vector, - bool keep_old ) -{ - //api_trim_curve(entity_with_ray &eray1, SPAposition* trim_pt, entity_with_ray *peray2); - //The curve is trimmed to either a SPAposition or at its intersection with another curve. To trim - //to a SPAposition, specify a SPAposition in trim_pt and NULL for eray2. The curve is trimmed to - //the normal projection of the SPAposition onto the curve. To trim to the intersection with - //another curve, specify NULL for trim_pt and an entity_with_ray for eray2. The curve - //is trimmed to the intersection with the curve given in eray2 that is closest to the ray given - //in eray2. + Curve* + AcisModifyEngine::trim_curve( Curve* trim_curve, + const CubitVector& trim_vector, + const CubitVector& keep_vector, + bool keep_old ) + { + //api_trim_curve(entity_with_ray &eray1, SPAposition* trim_pt, entity_with_ray *peray2); + //The curve is trimmed to either a SPAposition or at its intersection with another curve. To trim + //to a SPAposition, specify a SPAposition in trim_pt and NULL for eray2. The curve is trimmed to + //the normal projection of the SPAposition onto the curve. To trim to the intersection with + //another curve, specify NULL for trim_pt and an entity_with_ray for eray2. The curve + //is trimmed to the intersection with the curve given in eray2 that is closest to the ray given + //in eray2. - EDGE* EDGE_ptr = AcisQueryEngine::get_EDGE( trim_curve ); - if( EDGE_ptr == NULL ) - return 0; + EDGE* EDGE_ptr = AcisQueryEngine::get_EDGE( trim_curve ); + if( EDGE_ptr == NULL ) + return 0; - ENTITY_LIST edge_VERTS; - api_get_vertices( EDGE_ptr, edge_VERTS ); - VERTEX *start_vertex = static_cast<VERTEX*>(edge_VERTS[0]); - VERTEX *end_vertex = static_cast<VERTEX*>(edge_VERTS[1]); - SPAposition s_vec = start_vertex->geometry()->coords(); - SPAposition e_vec = end_vertex->geometry()->coords(); - CubitVector s_vector( s_vec.x(), s_vec.y(), s_vec.z() ); - CubitVector e_vector( e_vec.x(), e_vec.y(), e_vec.z() ); + ENTITY_LIST edge_VERTS; + api_get_vertices( EDGE_ptr, edge_VERTS ); + VERTEX *start_vertex = static_cast<VERTEX*>(edge_VERTS[0]); + VERTEX *end_vertex = static_cast<VERTEX*>(edge_VERTS[1]); + SPAposition s_vec = start_vertex->geometry()->coords(); + SPAposition e_vec = end_vertex->geometry()->coords(); + CubitVector s_vector( s_vec.x(), s_vec.y(), s_vec.z() ); + CubitVector e_vector( e_vec.x(), e_vec.y(), e_vec.z() ); - int start = 0, end = 0; - if( keep_vector.distance_between( s_vector ) < 0.001 ) - start = 1; - else if( keep_vector.distance_between( e_vector ) < 0.001 ) - end = 1; + int start = 0, end = 0; + if( keep_vector.distance_between( s_vector ) < 0.001 ) + start = 1; + else if( keep_vector.distance_between( e_vector ) < 0.001 ) + end = 1; - if( start || end ) - { - double trim_param = trim_curve->u_from_position( trim_vector ); - double start_param = trim_curve->start_param(); - double end_param = trim_curve->end_param(); + if( start || end ) + { + double trim_param = trim_curve->u_from_position( trim_vector ); + double start_param = trim_curve->start_param(); + double end_param = trim_curve->end_param(); - //if trim_param is not within start and end params, we are extending - //and we don't need keep_vector - bool within_u_param_range = true; - if( start_param < end_param ) - { - if( trim_param > end_param || trim_param < start_param ) - within_u_param_range = false; - } - else - { - if( trim_param > start_param || trim_param < end_param ) - within_u_param_range = false; - } + //if trim_param is not within start and end params, we are extending + //and we don't need keep_vector + bool within_u_param_range = true; + if( start_param < end_param ) + { + if( trim_param > end_param || trim_param < start_param ) + within_u_param_range = false; + } + else + { + if( trim_param > start_param || trim_param < end_param ) + within_u_param_range = false; + } - if( within_u_param_range ) - { - double keep_param; - if( start ) - keep_param = start_param + .95*(trim_param-start_param); - else - keep_param = trim_param + .05*(end_param-trim_param); + if( within_u_param_range ) + { + double keep_param; + if( start ) + keep_param = start_param + .95*(trim_param-start_param); + else + keep_param = trim_param + .05*(end_param-trim_param); - CubitVector tmp_keep_vec = keep_vector; - trim_curve->position_from_u( keep_param, tmp_keep_vec ); - } - } + CubitVector tmp_keep_vec = keep_vector; + trim_curve->position_from_u( keep_param, tmp_keep_vec ); + } + } - // Copy the edge to trim first - EDGE* copied_EDGE_ptr; - outcome result = api_edge( EDGE_ptr, copied_EDGE_ptr ); + // Copy the edge to trim first + EDGE* copied_EDGE_ptr; + outcome result = api_edge( EDGE_ptr, copied_EDGE_ptr ); - SPAposition trim_pos( trim_vector.x(),trim_vector.y(),trim_vector.z() ); - SPAposition* ptrim_pos = &trim_pos; - entity_with_ray *peray2 = NULL; + SPAposition trim_pos( trim_vector.x(),trim_vector.y(),trim_vector.z() ); + SPAposition* ptrim_pos = &trim_pos; + entity_with_ray *peray2 = NULL; - SPAposition keep_pos( keep_vector.x(),keep_vector.y(),keep_vector.z() ); - SPAunit_vector keep_vec( 0.0, 0.0, 0.0 ); - entity_with_ray eray1( copied_EDGE_ptr, keep_pos, keep_vec ); + SPAposition keep_pos( keep_vector.x(),keep_vector.y(),keep_vector.z() ); + SPAunit_vector keep_vec( 0.0, 0.0, 0.0 ); + entity_with_ray eray1( copied_EDGE_ptr, keep_pos, keep_vec ); - // Finally, do the real work - result = api_trim_curve(eray1, ptrim_pos, peray2); + // Finally, do the real work + result = api_trim_curve(eray1, ptrim_pos, peray2); - if( !result.ok() ) - { - AcisQueryEngine::instance()->ACIS_API_error (result); - PRINT_ERROR( "Unable to trim curve\n" ); - api_delent( copied_EDGE_ptr ); - return 0; - } + if( !result.ok() ) + { + AcisQueryEngine::instance()->ACIS_API_error (result); + PRINT_ERROR( "Unable to trim curve\n" ); + api_delent( copied_EDGE_ptr ); + return 0; + } - // Make a free curve from the trimmed EDGE - Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges( copied_EDGE_ptr ); - if (keep_old) - return curve_ptr; + // Make a free curve from the trimmed EDGE + Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges( copied_EDGE_ptr ); + if (keep_old) + return curve_ptr; - // Delete the old curve (trim_curve), if it is a free curve - DLIList<Surface*> surfaces; - trim_curve->surfaces( surfaces ); - if ( surfaces.size() == 0 ) - { - CubitStatus status = - AcisQueryEngine::instance()->delete_solid_model_entities(trim_curve); + // Delete the old curve (trim_curve), if it is a free curve + DLIList<Surface*> surfaces; + trim_curve->surfaces( surfaces ); + if ( surfaces.size() == 0 ) + { + CubitStatus status = + AcisQueryEngine::instance()->delete_solid_model_entities(trim_curve); - if (status == CUBIT_FAILURE) - { - PRINT_ERROR("In AcisModifyEngine::trim_curve\n" - " Could not delete Curve.\n" - " The Model database is likely corrupted " - "due to\nthis unsuccessful deletion.\n" ); - } - } + if (status == CUBIT_FAILURE) + { + PRINT_ERROR("In AcisModifyEngine::trim_curve\n" + " Could not delete Curve.\n" + " The Model database is likely corrupted " + "due to\nthis unsuccessful deletion.\n" ); + } + } - return curve_ptr; -} + return curve_ptr; + } -Curve* -AcisModifyEngine::create_arc_three( Point* vertex1, Point* vertex2, - Point *vertex3, bool full ) -{ - CubitVector vec1 = vertex1->coordinates(); - CubitVector vec2 = vertex2->coordinates(); - CubitVector vec3 = vertex3->coordinates(); + Curve* + AcisModifyEngine::create_arc_three( Point* vertex1, Point* vertex2, + Point *vertex3, bool full ) + { + CubitVector vec1 = vertex1->coordinates(); + CubitVector vec2 = vertex2->coordinates(); + CubitVector vec3 = vertex3->coordinates(); - SPAposition pos1( vec1.x(), vec1.y(), vec1.z() ); - SPAposition pos2( vec2.x(), vec2.y(), vec2.z() ); - SPAposition pos3( vec3.x(), vec3.y(), vec3.z() ); + SPAposition pos1( vec1.x(), vec1.y(), vec1.z() ); + SPAposition pos2( vec2.x(), vec2.y(), vec2.z() ); + SPAposition pos3( vec3.x(), vec3.y(), vec3.z() ); - EDGE *EDGE_ptr; + EDGE *EDGE_ptr; - outcome result = api_curve_arc_3pt( pos1, pos2, pos3, full, EDGE_ptr ); - if( !result.ok() ) - { - AcisQueryEngine::instance()->ACIS_API_error(result); - PRINT_ERROR( "Unable to create arc from given vertices\n" ); - return NULL; - } + outcome result = api_curve_arc_3pt( pos1, pos2, pos3, full, EDGE_ptr ); + if( !result.ok() ) + { + AcisQueryEngine::instance()->ACIS_API_error(result); + PRINT_ERROR( "Unable to create arc from given vertices\n" ); + return NULL; + } - //reuse vertices - if( full ) - { - PointACIS *acis_point1 = CAST_TO( vertex1, PointACIS ); - EDGE_ptr->set_start(acis_point1->get_VERTEX_ptr() ); - EDGE_ptr->set_end(acis_point1->get_VERTEX_ptr() ); - acis_point1->get_VERTEX_ptr()->add_edge(EDGE_ptr); - } - else - { + //reuse vertices + if( full ) + { + PointACIS *acis_point1 = CAST_TO( vertex1, PointACIS ); + EDGE_ptr->set_start(acis_point1->get_VERTEX_ptr() ); + EDGE_ptr->set_end(acis_point1->get_VERTEX_ptr() ); + acis_point1->get_VERTEX_ptr()->add_edge(EDGE_ptr); + } + else + { - PointACIS *acis_point1 = CAST_TO( vertex1, PointACIS ); - PointACIS *acis_point3 = CAST_TO( vertex3, PointACIS ); + PointACIS *acis_point1 = CAST_TO( vertex1, PointACIS ); + PointACIS *acis_point3 = CAST_TO( vertex3, PointACIS ); - EDGE_ptr->set_start(acis_point1->get_VERTEX_ptr() ); - acis_point1->get_VERTEX_ptr()->add_edge(EDGE_ptr); + EDGE_ptr->set_start(acis_point1->get_VERTEX_ptr() ); + acis_point1->get_VERTEX_ptr()->add_edge(EDGE_ptr); - EDGE_ptr->set_end(acis_point3->get_VERTEX_ptr() ); - acis_point3->get_VERTEX_ptr()->add_edge(EDGE_ptr); - } + EDGE_ptr->set_end(acis_point3->get_VERTEX_ptr() ); + acis_point3->get_VERTEX_ptr()->add_edge(EDGE_ptr); + } - return AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr); -} + return AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr); + } -Curve* -AcisModifyEngine::create_arc_three( Curve* ref_edge1, Curve* ref_edge2, - Curve *ref_edge3, bool full ) -{ - EDGE* EDGE_ptr1 = AcisQueryEngine::get_EDGE( ref_edge1 ); - EDGE* EDGE_ptr2 = AcisQueryEngine::get_EDGE( ref_edge2 ); - EDGE* EDGE_ptr3 = AcisQueryEngine::get_EDGE( ref_edge3 ); - if( !EDGE_ptr1 || !EDGE_ptr2 || !EDGE_ptr3) - return NULL; + Curve* + AcisModifyEngine::create_arc_three( Curve* ref_edge1, Curve* ref_edge2, + Curve *ref_edge3, bool full ) + { + EDGE* EDGE_ptr1 = AcisQueryEngine::get_EDGE( ref_edge1 ); + EDGE* EDGE_ptr2 = AcisQueryEngine::get_EDGE( ref_edge2 ); + EDGE* EDGE_ptr3 = AcisQueryEngine::get_EDGE( ref_edge3 ); + if( !EDGE_ptr1 || !EDGE_ptr2 || !EDGE_ptr3) + return NULL; - SPAposition tang_pos( 0.0, 0.0, 0.0 ); - SPAunit_vector tang_vec( 0.0, 0.0, 0.0 ); - entity_with_ray eray1( EDGE_ptr1, tang_pos, tang_vec ); - entity_with_ray eray2( EDGE_ptr2, tang_pos, tang_vec ); - entity_with_ray eray3( EDGE_ptr3, tang_pos, tang_vec ); + SPAposition tang_pos( 0.0, 0.0, 0.0 ); + SPAunit_vector tang_vec( 0.0, 0.0, 0.0 ); + entity_with_ray eray1( EDGE_ptr1, tang_pos, tang_vec ); + entity_with_ray eray2( EDGE_ptr2, tang_pos, tang_vec ); + entity_with_ray eray3( EDGE_ptr3, tang_pos, tang_vec ); - EDGE *EDGE_ptr; + EDGE *EDGE_ptr; - outcome result = api_curve_arc_3curve( eray1, eray2, eray3, full, EDGE_ptr ); - if( !result.ok() ) - { - AcisQueryEngine::instance()->ACIS_API_error(result); - PRINT_ERROR( "Unable to create arc from given curves\n" ); - return NULL; - } + outcome result = api_curve_arc_3curve( eray1, eray2, eray3, full, EDGE_ptr ); + if( !result.ok() ) + { + AcisQueryEngine::instance()->ACIS_API_error(result); + PRINT_ERROR( "Unable to create arc from given curves\n" ); + return NULL; + } - return AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr); -} + return AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr); + } -Curve* -AcisModifyEngine::create_arc_center_edge( Point* vertex1, Point* vertex2, - Point *vertex3, const CubitVector &normal, - double radius, bool full ) -{ - CubitVector vec1 = vertex1->coordinates(); // Center of arc - CubitVector vec2 = vertex2->coordinates(); // Position on arc - CubitVector vec3 = vertex3->coordinates(); // Position on arc + Curve* + AcisModifyEngine::create_arc_center_edge( Point* vertex1, Point* vertex2, + Point *vertex3, const CubitVector &normal, + double radius, bool full ) + { + CubitVector vec1 = vertex1->coordinates(); // Center of arc + CubitVector vec2 = vertex2->coordinates(); // Position on arc + CubitVector vec3 = vertex3->coordinates(); // Position on arc - // Re-adjust vec2 if radius was given - if( radius != CUBIT_DBL_MAX ) - { - CubitVector dir1( vec1, vec2 ); - vec1.next_point( dir1, radius, vec2 ); - } + // Re-adjust vec2 if radius was given + if( radius != CUBIT_DBL_MAX ) + { + CubitVector dir1( vec1, vec2 ); + vec1.next_point( dir1, radius, vec2 ); + } - SPAposition pos1( vec1.x(), vec1.y(), vec1.z() ); - SPAposition pos2( vec2.x(), vec2.y(), vec2.z() ); - SPAposition pos3( vec3.x(), vec3.y(), vec3.z() ); + SPAposition pos1( vec1.x(), vec1.y(), vec1.z() ); + SPAposition pos2( vec2.x(), vec2.y(), vec2.z() ); + SPAposition pos3( vec3.x(), vec3.y(), vec3.z() ); - EDGE *EDGE_ptr; - SPAunit_vector arc_normal; - if( normal.length() != 0 ) - { - arc_normal.set_x( normal.x() ); - arc_normal.set_y( normal.y() ); - arc_normal.set_z( normal.z() ); - } + EDGE *EDGE_ptr; + SPAunit_vector arc_normal; + if( normal.length() != 0 ) + { + arc_normal.set_x( normal.x() ); + arc_normal.set_y( normal.y() ); + arc_normal.set_z( normal.z() ); + } - outcome result; - if( full == CUBIT_FALSE ) - { - if( normal.length() != 0.0 ) - result = api_curve_arc_center_edge( pos1, pos2, pos3, &arc_normal, EDGE_ptr ); - else - result = api_curve_arc_center_edge( pos1, pos2, pos3, NULL, EDGE_ptr ); - } - else - { - if( normal.length() == 0.0 ) - { - CubitVector dir1( vec1, vec2 ); - CubitVector dir2( vec1, vec3 ); - CubitVector tmp_normal = dir1 * dir2; // Cross-product - tmp_normal.normalize(); - arc_normal.set_x( tmp_normal.x() ); - arc_normal.set_y( tmp_normal.y() ); - arc_normal.set_z( tmp_normal.z() ); - } - result = api_curve_arc_center_edge( pos1, pos2, pos2, &arc_normal, EDGE_ptr ); - } + outcome result; + if( full == CUBIT_FALSE ) + { + if( normal.length() != 0.0 ) + result = api_curve_arc_center_edge( pos1, pos2, pos3, &arc_normal, EDGE_ptr ); + else + result = api_curve_arc_center_edge( pos1, pos2, pos3, NULL, EDGE_ptr ); + } + else + { + if( normal.length() == 0.0 ) + { + CubitVector dir1( vec1, vec2 ); + CubitVector dir2( vec1, vec3 ); + CubitVector tmp_normal = dir1 * dir2; // Cross-product + tmp_normal.normalize(); + arc_normal.set_x( tmp_normal.x() ); + arc_normal.set_y( tmp_normal.y() ); + arc_normal.set_z( tmp_normal.z() ); + } + result = api_curve_arc_center_edge( pos1, pos2, pos2, &arc_normal, EDGE_ptr ); + } - if( !result.ok() ) - { - AcisQueryEngine::instance()->ACIS_API_error(result); - PRINT_ERROR( "Unable to create arc from given vertices\n" ); - return NULL; - } + if( !result.ok() ) + { + AcisQueryEngine::instance()->ACIS_API_error(result); + PRINT_ERROR( "Unable to create arc from given vertices\n" ); + return NULL; + } - //reuse vertices...if possible - if( full ) - { - PointACIS *acis_point2 = CAST_TO( vertex2, PointACIS ); - EDGE_ptr->set_start(acis_point2->get_VERTEX_ptr() ); - EDGE_ptr->set_end(acis_point2->get_VERTEX_ptr() ); - acis_point2->get_VERTEX_ptr()->add_edge(EDGE_ptr); - } - else - { - //reuse vertices only if it is coincident with - //new vertex on new curve + //reuse vertices...if possible + if( full ) + { + PointACIS *acis_point2 = CAST_TO( vertex2, PointACIS ); + EDGE_ptr->set_start(acis_point2->get_VERTEX_ptr() ); + EDGE_ptr->set_end(acis_point2->get_VERTEX_ptr() ); + acis_point2->get_VERTEX_ptr()->add_edge(EDGE_ptr); + } + else + { + //reuse vertices only if it is coincident with + //new vertex on new curve - //compare original start vs. new start vertex on EDGE - VERTEX *start_vert = EDGE_ptr->start(); - SPAposition temp_pos = start_vert->geometry()->coords(); - CubitVector tmp_pos1( temp_pos.x(), temp_pos.y(), temp_pos.z() ); - vec2 = vertex2->coordinates(); + //compare original start vs. new start vertex on EDGE + VERTEX *start_vert = EDGE_ptr->start(); + SPAposition temp_pos = start_vert->geometry()->coords(); + CubitVector tmp_pos1( temp_pos.x(), temp_pos.y(), temp_pos.z() ); + vec2 = vertex2->coordinates(); - if(tmp_pos1.distance_between( vec2 ) < GEOMETRY_RESABS ) - { - PointACIS *acis_point2 = CAST_TO( vertex2, PointACIS ); - EDGE_ptr->set_start(acis_point2->get_VERTEX_ptr() ); - acis_point2->get_VERTEX_ptr()->add_edge(EDGE_ptr); - } + if(tmp_pos1.distance_between( vec2 ) < GEOMETRY_RESABS ) + { + PointACIS *acis_point2 = CAST_TO( vertex2, PointACIS ); + EDGE_ptr->set_start(acis_point2->get_VERTEX_ptr() ); + acis_point2->get_VERTEX_ptr()->add_edge(EDGE_ptr); + } - //compare original end vs. new end vertex on EDGE - VERTEX *end_vert = EDGE_ptr->end(); - temp_pos = end_vert->geometry()->coords(); - tmp_pos1.set( temp_pos.x(), temp_pos.y(), temp_pos.z() ); - vec3 = vertex3->coordinates(); + //compare original end vs. new end vertex on EDGE + VERTEX *end_vert = EDGE_ptr->end(); + temp_pos = end_vert->geometry()->coords(); + tmp_pos1.set( temp_pos.x(), temp_pos.y(), temp_pos.z() ); + vec3 = vertex3->coordinates(); - if(tmp_pos1.distance_between( vec3 ) < GEOMETRY_RESABS ) - { - PointACIS *acis_point3 = CAST_TO( vertex3, PointACIS ); - EDGE_ptr->set_end(acis_point3->get_VERTEX_ptr() ); - acis_point3->get_VERTEX_ptr()->add_edge(EDGE_ptr); + if(tmp_pos1.distance_between( vec3 ) < GEOMETRY_RESABS ) + { + PointACIS *acis_point3 = CAST_TO( vertex3, PointACIS ); + EDGE_ptr->set_end(acis_point3->get_VERTEX_ptr() ); + acis_point3->get_VERTEX_ptr()->add_edge(EDGE_ptr); + } + else + { + //make sure this point isn't a free vertex + if( !vertex3->topology_entity() ) + AcisQueryEngine::instance()->delete_solid_model_entities( vertex3 ); + } + } + + + return AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr); } - else + + CubitStatus + AcisModifyEngine::create_curve_combine( DLIList<Curve*>& curve_list, + Curve *&new_curve_ptr ) { - //make sure this point isn't a free vertex - if( !vertex3->topology_entity() ) - AcisQueryEngine::instance()->delete_solid_model_entities( vertex3 ); - } - } + CubitStatus result; + result = AcisEdgeTool::instance()->create_curve_combine(curve_list, + new_curve_ptr); - return AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr); -} + if (result) + { + RefEdge* new_ref_edge_ptr = GeometryQueryTool::instance()->make_free_RefEdge( new_curve_ptr ); -CubitStatus -AcisModifyEngine::create_curve_combine( DLIList<Curve*>& curve_list, - Curve *&new_curve_ptr ) -{ - CubitStatus result; + if (new_ref_edge_ptr) + PRINT_INFO( "Created new \"combined\" curve %d\n", new_ref_edge_ptr->id() ); + else + result = CUBIT_FAILURE; + } - result = AcisEdgeTool::instance()->create_curve_combine(curve_list, - new_curve_ptr); + return result; - if (result) - { - RefEdge* new_ref_edge_ptr = GeometryQueryTool::instance()->make_free_RefEdge( new_curve_ptr ); + } - if (new_ref_edge_ptr) - PRINT_INFO( "Created new \"combined\" curve %d\n", new_ref_edge_ptr->id() ); - else - result = CUBIT_FAILURE; - } + CubitStatus + AcisModifyEngine::get_copied_FACES_of_body( DLIList<SurfaceACIS*>& ref_face_list, + DLIList<FACE*>& FACE_list, + DLIList<SurfaceACIS*>& removed_ref_faces, + BODY*& copied_BODY_ptr ) const + { + int i, num_faces; - return result; + // Note: we will be pulling surfaces out of incoming ref_face_list. + SurfaceACIS* ref_face_ptr; + BodySM *body_ptr; -} + BODY *BODY_ptr; + BODY *BODY_ptr2; -CubitStatus -AcisModifyEngine::get_copied_FACES_of_body( DLIList<SurfaceACIS*>& ref_face_list, - DLIList<FACE*>& FACE_list, - DLIList<SurfaceACIS*>& removed_ref_faces, - BODY*& copied_BODY_ptr ) const -{ - int i, num_faces; + FACE *FACE_ptr; - // Note: we will be pulling surfaces out of incoming ref_face_list. - SurfaceACIS* ref_face_ptr; - BodySM *body_ptr; + copied_BODY_ptr = NULL; - BODY *BODY_ptr; - BODY *BODY_ptr2; + outcome result; - FACE *FACE_ptr; + DLIList<SurfaceACIS*> body_face_list; - copied_BODY_ptr = NULL; + ref_face_list.reset(); + ref_face_ptr = ref_face_list.remove(); + removed_ref_faces.append( ref_face_ptr ); - outcome result; + FACE_ptr = ref_face_ptr->get_FACE_ptr(); + if (!FACE_ptr) + { + PRINT_ERROR( "Unable to get Acis FACE from Surface\n" ); + return CUBIT_FAILURE; + } - DLIList<SurfaceACIS*> body_face_list; + body_face_list.append_unique( ref_face_ptr ); - ref_face_list.reset(); - ref_face_ptr = ref_face_list.remove(); - removed_ref_faces.append( ref_face_ptr ); + body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( FACE_ptr ); + if( body_ptr == NULL ) + { + PRINT_ERROR( "Unable to get volume from FACE\n" ); + return CUBIT_FAILURE; + } - FACE_ptr = ref_face_ptr->get_FACE_ptr(); - if (!FACE_ptr) - { - PRINT_ERROR( "Unable to get Acis FACE from Surface\n" ); - return CUBIT_FAILURE; - } + BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_ptr ); + if( BODY_ptr == NULL ) + { + PRINT_ERROR( "Unable to get volume from FACE\n" ); + return CUBIT_FAILURE; + } - body_face_list.append_unique( ref_face_ptr ); + // Add all remaining faces from this same body to face list + num_faces = ref_face_list.size(); + for( i=0; i<num_faces; i++ ) + { + ref_face_ptr = ref_face_list.get(); - body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( FACE_ptr ); - if( body_ptr == NULL ) - { - PRINT_ERROR( "Unable to get volume from FACE\n" ); - return CUBIT_FAILURE; - } + BODY_ptr2 = AcisQueryEngine::instance()->get_BODY_of_entity( ref_face_ptr ); - BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_ptr ); - if( BODY_ptr == NULL ) - { - PRINT_ERROR( "Unable to get volume from FACE\n" ); - return CUBIT_FAILURE; - } + if( BODY_ptr == BODY_ptr2 ) + { + body_face_list.append_unique( ref_face_ptr ); + ref_face_list.remove(); + removed_ref_faces.append( ref_face_ptr ); + } + else + ref_face_list.step(); + } - // Add all remaining faces from this same body to face list - num_faces = ref_face_list.size(); - for( i=0; i<num_faces; i++ ) - { - ref_face_ptr = ref_face_list.get(); + // Now we have all the faces from this particular BODY. - BODY_ptr2 = AcisQueryEngine::instance()->get_BODY_of_entity( ref_face_ptr ); + // Copy the body before working with it. Here we keep the + // attributes on the BODY so we can get back to the TE's + // in CUBIT from the copy (to find which FACE's to correlate + // to the RefFace's). + copied_BODY_ptr = copy_BODY(BODY_ptr, CUBIT_FALSE); - if( BODY_ptr == BODY_ptr2 ) - { - body_face_list.append_unique( ref_face_ptr ); - ref_face_list.remove(); - removed_ref_faces.append( ref_face_ptr ); - } - else - ref_face_list.step(); - } + // Loop through the copied BODY's FACES to find which one's + // match to the original BODY's RefFaces. + ENTITY_LIST ENTITIES; + result = api_get_faces( copied_BODY_ptr, ENTITIES ); + if( !result.ok() ) + { + PRINT_ERROR( "Unable to get ACIS FACES from volume\n" ); + api_delent( copied_BODY_ptr ); + copied_BODY_ptr = NULL; + return CUBIT_FAILURE; + } - // Now we have all the faces from this particular BODY. + ENTITIES.init(); + ENTITY* ENTITY_ptr; + int index = -1; + DLIList<int> index_list; + DLIList<FACE*> temp_FACE_list; + while( (ENTITY_ptr = ENTITIES.next() ) != NULL ) + { + AcisBridge* ab_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(ENTITY_ptr); + ref_face_ptr = CAST_TO( ab_ptr, SurfaceACIS ); + if( ref_face_ptr == NULL ) + { + PRINT_ERROR( "Unable to find RefFace from ACIS FACE!\n" ); + api_delent( copied_BODY_ptr ); + copied_BODY_ptr = NULL; + return CUBIT_FAILURE; + } - // Copy the body before working with it. Here we keep the - // attributes on the BODY so we can get back to the TE's - // in CUBIT from the copy (to find which FACE's to correlate - // to the RefFace's). - copied_BODY_ptr = copy_BODY(BODY_ptr, CUBIT_FALSE); + index = body_face_list.where_is_item( ref_face_ptr ); + if( index != -1 ) + { + index_list.append( index ); + temp_FACE_list.append( (FACE *)ENTITY_ptr ); + } + if( temp_FACE_list.size() == body_face_list.size() ) + break; + } + ENTITIES.clear(); - // Loop through the copied BODY's FACES to find which one's - // match to the original BODY's RefFaces. - ENTITY_LIST ENTITIES; - result = api_get_faces( copied_BODY_ptr, ENTITIES ); - if( !result.ok() ) - { - PRINT_ERROR( "Unable to get ACIS FACES from volume\n" ); - api_delent( copied_BODY_ptr ); - copied_BODY_ptr = NULL; - return CUBIT_FAILURE; - } + if( temp_FACE_list.size() != body_face_list.size() ) + { + PRINT_ERROR( "Internal error correlating FACE lists\n" ); + api_delent( copied_BODY_ptr ); + copied_BODY_ptr = NULL; + return CUBIT_FAILURE; + } - ENTITIES.init(); - ENTITY* ENTITY_ptr; - int index = -1; - DLIList<int> index_list; - DLIList<FACE*> temp_FACE_list; - while( (ENTITY_ptr = ENTITIES.next() ) != NULL ) - { - AcisBridge* ab_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(ENTITY_ptr); - ref_face_ptr = CAST_TO( ab_ptr, SurfaceACIS ); - if( ref_face_ptr == NULL ) - { - PRINT_ERROR( "Unable to find RefFace from ACIS FACE!\n" ); - api_delent( copied_BODY_ptr ); - copied_BODY_ptr = NULL; - return CUBIT_FAILURE; + // Re-sort the list into the proper order + temp_FACE_list.reset(); + index_list.reset(); + for( i=0; i<index_list.size(); i++ ) + { + // Find the FACE with the corresponding index + index = index_list.where_is_item( i ); + temp_FACE_list.reset(); + temp_FACE_list.step( index ); + + FACE_list.append( temp_FACE_list.get() ); + } + + return CUBIT_SUCCESS; } - index = body_face_list.where_is_item( ref_face_ptr ); - if( index != -1 ) + CubitStatus + AcisModifyEngine::get_copied_FACES_of_body( DLIList<SurfaceACIS*>& ref_face_list, + DLIList<FACE*>& FACE_list, + BODY*& copied_BODY_ptr ) const { - index_list.append( index ); - temp_FACE_list.append( (FACE *)ENTITY_ptr ); + DLIList<SurfaceACIS*> removed_faces; + + return get_copied_FACES_of_body( ref_face_list, FACE_list, removed_faces, + copied_BODY_ptr ); } - if( temp_FACE_list.size() == body_face_list.size() ) - break; - } - ENTITIES.clear(); - if( temp_FACE_list.size() != body_face_list.size() ) - { - PRINT_ERROR( "Internal error correlating FACE lists\n" ); - api_delent( copied_BODY_ptr ); - copied_BODY_ptr = NULL; - return CUBIT_FAILURE; - } + CubitStatus + AcisModifyEngine::get_copied_EDGES_of_body( DLIList<CurveACIS*>& ref_edge_list, + DLIList<EDGE*>& EDGE_list, + DLIList<CurveACIS*>& removed_ref_edges, + BODY*& copied_BODY_ptr ) const + { + int i, num_edges; - // Re-sort the list into the proper order - temp_FACE_list.reset(); - index_list.reset(); - for( i=0; i<index_list.size(); i++ ) - { - // Find the FACE with the corresponding index - index = index_list.where_is_item( i ); - temp_FACE_list.reset(); - temp_FACE_list.step( index ); + // Note: we will be pulling surfaces out of incoming ref_edge_list. + CurveACIS* ref_edge_ptr; + BodySM *body_ptr; - FACE_list.append( temp_FACE_list.get() ); - } + BODY *BODY_ptr; + BODY *BODY_ptr2; - return CUBIT_SUCCESS; -} + EDGE *EDGE_ptr; -CubitStatus -AcisModifyEngine::get_copied_FACES_of_body( DLIList<SurfaceACIS*>& ref_face_list, - DLIList<FACE*>& FACE_list, - BODY*& copied_BODY_ptr ) const -{ - DLIList<SurfaceACIS*> removed_faces; + copied_BODY_ptr = NULL; - return get_copied_FACES_of_body( ref_face_list, FACE_list, removed_faces, - copied_BODY_ptr ); -} + outcome result; -CubitStatus -AcisModifyEngine::get_copied_EDGES_of_body( DLIList<CurveACIS*>& ref_edge_list, - DLIList<EDGE*>& EDGE_list, - DLIList<CurveACIS*>& removed_ref_edges, - BODY*& copied_BODY_ptr ) const -{ - int i, num_edges; + DLIList<CurveACIS*> body_edge_list; - // Note: we will be pulling surfaces out of incoming ref_edge_list. - CurveACIS* ref_edge_ptr; - BodySM *body_ptr; + ref_edge_ptr = ref_edge_list.remove(); + removed_ref_edges.append( ref_edge_ptr ); - BODY *BODY_ptr; - BODY *BODY_ptr2; + EDGE_ptr = ref_edge_ptr->get_EDGE_ptr(); - EDGE *EDGE_ptr; + body_edge_list.append_unique( ref_edge_ptr ); - copied_BODY_ptr = NULL; + body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( EDGE_ptr ); + if( body_ptr == NULL ) + { + PRINT_ERROR( "Unable to get volume from EDGE\n" ); + return CUBIT_FAILURE; + } - outcome result; + BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( EDGE_ptr ); + if( BODY_ptr == NULL ) + { + PRINT_ERROR( "Unable to get volume from EDGE\n" ); + return CUBIT_FAILURE; + } - DLIList<CurveACIS*> body_edge_list; + // Add all remaining edges from this same body to edge list + num_edges = ref_edge_list.size(); + for( i=0; i<num_edges; i++ ) + { + ref_edge_ptr = ref_edge_list.get(); - ref_edge_ptr = ref_edge_list.remove(); - removed_ref_edges.append( ref_edge_ptr ); + BODY_ptr2 = AcisQueryEngine::instance()->get_BODY_of_entity( ref_edge_ptr ); - EDGE_ptr = ref_edge_ptr->get_EDGE_ptr(); + if( BODY_ptr == BODY_ptr2 ) + { + body_edge_list.append_unique( ref_edge_ptr ); + ref_edge_list.remove(); + removed_ref_edges.append( ref_edge_ptr ); + } + else + ref_edge_list.step(); + } - body_edge_list.append_unique( ref_edge_ptr ); + // Now we have all the edges from this particular BODY. - body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( EDGE_ptr ); - if( body_ptr == NULL ) - { - PRINT_ERROR( "Unable to get volume from EDGE\n" ); - return CUBIT_FAILURE; - } + // Copy the body before working with it. Here we keep the + // attributes on the BODY so we can get back to the TE's + // in CUBIT from the copy (to find which EDGE's to correlate + // to the RefEdge's). + copied_BODY_ptr = copy_BODY(BODY_ptr, CUBIT_FALSE); - BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( EDGE_ptr ); - if( BODY_ptr == NULL ) - { - PRINT_ERROR( "Unable to get volume from EDGE\n" ); - return CUBIT_FAILURE; - } + // Loop through the copied BODY's EDGES to find which one's + // match to the original BODY's RefEdges. + ENTITY_LIST ENTITIES; + result = api_get_edges(copied_BODY_ptr, ENTITIES); + if( !result.ok() ) + { + PRINT_ERROR( "Unable to get ACIS EDGES from volume\n" ); + api_delent( copied_BODY_ptr ); + copied_BODY_ptr = NULL; + return CUBIT_FAILURE; + } - // Add all remaining edges from this same body to edge list - num_edges = ref_edge_list.size(); - for( i=0; i<num_edges; i++ ) - { - ref_edge_ptr = ref_edge_list.get(); + ENTITIES.init(); + ENTITY* ENTITY_ptr; + int index = -1; + DLIList<int> index_list; + DLIList<EDGE*> temp_EDGE_list; + while( (ENTITY_ptr = ENTITIES.next() ) != NULL ) + { + AcisBridge* ab_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(ENTITY_ptr); + ref_edge_ptr = CAST_TO( ab_ptr, CurveACIS ); + if( ref_edge_ptr == NULL ) + { + PRINT_ERROR( "Unable to find Cubit curve from ACIS EDGE!\n" ); + api_delent( copied_BODY_ptr ); + copied_BODY_ptr = NULL; + return CUBIT_FAILURE; + } + index = body_edge_list.where_is_item( ref_edge_ptr ); + if( index != -1 ) + { + index_list.append( index ); + temp_EDGE_list.append( (EDGE *)ENTITY_ptr ); + } + if( temp_EDGE_list.size() == body_edge_list.size() ) + break; + } + ENTITIES.clear(); - BODY_ptr2 = AcisQueryEngine::instance()->get_BODY_of_entity( ref_edge_ptr ); + if( temp_EDGE_list.size() != body_edge_list.size() ) + { + PRINT_ERROR( "Internal error correlating EDGE lists\n" ); + api_delent( copied_BODY_ptr ); + copied_BODY_ptr = NULL; + return CUBIT_FAILURE; + } - if( BODY_ptr == BODY_ptr2 ) - { - body_edge_list.append_unique( ref_edge_ptr ); - ref_edge_list.remove(); - removed_ref_edges.append( ref_edge_ptr ); + // Re-sort the list into the proper order + temp_EDGE_list.reset(); + index_list.reset(); + for( i=0; i<index_list.size(); i++ ) + { + // Find the EDGE with the corresponding index + index = index_list.where_is_item( i ); + temp_EDGE_list.reset(); + temp_EDGE_list.step( index ); + + EDGE_list.append( temp_EDGE_list.get() ); + } + + return CUBIT_SUCCESS; } - else - ref_edge_list.step(); - } - // Now we have all the edges from this particular BODY. + CubitStatus + AcisModifyEngine::get_copied_EDGES_of_body( DLIList<CurveACIS*>& ref_edge_list, + DLIList<EDGE*>& EDGE_list, + BODY*& copied_BODY_ptr ) const + { + DLIList<CurveACIS*> removed_edges; - // Copy the body before working with it. Here we keep the - // attributes on the BODY so we can get back to the TE's - // in CUBIT from the copy (to find which EDGE's to correlate - // to the RefEdge's). - copied_BODY_ptr = copy_BODY(BODY_ptr, CUBIT_FALSE); + return get_copied_EDGES_of_body( ref_edge_list, EDGE_list, removed_edges, + copied_BODY_ptr ); + } - // Loop through the copied BODY's EDGES to find which one's - // match to the original BODY's RefEdges. - ENTITY_LIST ENTITIES; - result = api_get_edges(copied_BODY_ptr, ENTITIES); - if( !result.ok() ) - { - PRINT_ERROR( "Unable to get ACIS EDGES from volume\n" ); - api_delent( copied_BODY_ptr ); - copied_BODY_ptr = NULL; - return CUBIT_FAILURE; - } + //------------------------------------------------------------------------- + // Purpose : To get a pointer to a copy of the body along with a list of VERTEXs + // + // Special Notes : + // + // Creator : Lingyun Pan (CAT) + // + // Creation Date : 07/19/01 + //------------------------------------------------------------------------- - ENTITIES.init(); - ENTITY* ENTITY_ptr; - int index = -1; - DLIList<int> index_list; - DLIList<EDGE*> temp_EDGE_list; - while( (ENTITY_ptr = ENTITIES.next() ) != NULL ) - { - AcisBridge* ab_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(ENTITY_ptr); - ref_edge_ptr = CAST_TO( ab_ptr, CurveACIS ); - if( ref_edge_ptr == NULL ) + CubitStatus + AcisModifyEngine::get_copied_VERTICES_of_body( + DLIList<PointACIS*>& ref_vertex_list, + DLIList<VERTEX*>& VERTEX_list, + DLIList<PointACIS*>& removed_ref_vertices, + BODY*& copied_BODY_ptr ) const { - PRINT_ERROR( "Unable to find Cubit curve from ACIS EDGE!\n" ); - api_delent( copied_BODY_ptr ); - copied_BODY_ptr = NULL; - return CUBIT_FAILURE; - } - index = body_edge_list.where_is_item( ref_edge_ptr ); - if( index != -1 ) - { - index_list.append( index ); - temp_EDGE_list.append( (EDGE *)ENTITY_ptr ); - } - if( temp_EDGE_list.size() == body_edge_list.size() ) - break; - } - ENTITIES.clear(); + int i, num_vertices; - if( temp_EDGE_list.size() != body_edge_list.size() ) - { - PRINT_ERROR( "Internal error correlating EDGE lists\n" ); - api_delent( copied_BODY_ptr ); - copied_BODY_ptr = NULL; - return CUBIT_FAILURE; - } + // Note: we will be pulling vertices out of incoming ref_vertex_list. + PointACIS* ref_vertex_ptr; + BodySM *body_ptr; - // Re-sort the list into the proper order - temp_EDGE_list.reset(); - index_list.reset(); - for( i=0; i<index_list.size(); i++ ) - { - // Find the EDGE with the corresponding index - index = index_list.where_is_item( i ); - temp_EDGE_list.reset(); - temp_EDGE_list.step( index ); + BODY *BODY_ptr; + BODY *BODY_ptr2; - EDGE_list.append( temp_EDGE_list.get() ); - } + VERTEX *VERTEX_ptr; - return CUBIT_SUCCESS; -} + copied_BODY_ptr = NULL; -CubitStatus -AcisModifyEngine::get_copied_EDGES_of_body( DLIList<CurveACIS*>& ref_edge_list, - DLIList<EDGE*>& EDGE_list, - BODY*& copied_BODY_ptr ) const -{ - DLIList<CurveACIS*> removed_edges; + outcome result; - return get_copied_EDGES_of_body( ref_edge_list, EDGE_list, removed_edges, - copied_BODY_ptr ); -} + DLIList<PointACIS*> body_vertex_list; -//------------------------------------------------------------------------- -// Purpose : To get a pointer to a copy of the body along with a list of VERTEXs -// -// Special Notes : -// -// Creator : Lingyun Pan (CAT) -// -// Creation Date : 07/19/01 -//------------------------------------------------------------------------- + ref_vertex_ptr =ref_vertex_list .remove(); + removed_ref_vertices.append( ref_vertex_ptr); -CubitStatus -AcisModifyEngine::get_copied_VERTICES_of_body( - DLIList<PointACIS*>& ref_vertex_list, - DLIList<VERTEX*>& VERTEX_list, - DLIList<PointACIS*>& removed_ref_vertices, - BODY*& copied_BODY_ptr ) const -{ - int i, num_vertices; + VERTEX_ptr = ref_vertex_ptr->get_VERTEX_ptr(); - // Note: we will be pulling vertices out of incoming ref_vertex_list. - PointACIS* ref_vertex_ptr; - BodySM *body_ptr; + body_vertex_list.append_unique( ref_vertex_ptr ); - BODY *BODY_ptr; - BODY *BODY_ptr2; + body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY(VERTEX_ptr ); + if( body_ptr == NULL ) + { + PRINT_ERROR( "Unable to get volume from VERTEX\n" ); + return CUBIT_FAILURE; + } - VERTEX *VERTEX_ptr; + BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( VERTEX_ptr ); + if( BODY_ptr == NULL ) + { + PRINT_ERROR( "Unable to get volume from VERTEX\n" ); + return CUBIT_FAILURE; + } - copied_BODY_ptr = NULL; + // Add all remaining vertex from this same body to vertex list + num_vertices = ref_vertex_list.size(); + for( i=0; i<num_vertices; i++ ) + { + ref_vertex_ptr = ref_vertex_list.get(); - outcome result; + BODY_ptr2 = AcisQueryEngine::instance()->get_BODY_of_entity( ref_vertex_ptr ); - DLIList<PointACIS*> body_vertex_list; + if( BODY_ptr == BODY_ptr2 ) + { + body_vertex_list.append_unique( ref_vertex_ptr ); + ref_vertex_list.remove(); + removed_ref_vertices.append( ref_vertex_ptr ); + } + else + ref_vertex_list.step(); + } - ref_vertex_ptr =ref_vertex_list .remove(); - removed_ref_vertices.append( ref_vertex_ptr); + // Now we have all the vertices from this particular BODY. - VERTEX_ptr = ref_vertex_ptr->get_VERTEX_ptr(); + // Copy the body before working with it. Here we keep the + // attributes on the BODY so we can get back to the TE's + // in CUBIT from the copy (to find which VERTICE's to correlate + // to the RefVertice's). + copied_BODY_ptr = copy_BODY(BODY_ptr, CUBIT_FALSE); - body_vertex_list.append_unique( ref_vertex_ptr ); + // Loop through the copied BODY's VERTICEs to find which one's + // match to the original BODY's RefVertices. + ENTITY_LIST ENTITIES; + result = api_get_vertices( copied_BODY_ptr, ENTITIES); + if( !result.ok() ) + { + PRINT_ERROR( "Unable to get ACIS VERTICES from a volume\n" ); + api_delent( copied_BODY_ptr ); + copied_BODY_ptr = NULL; + return CUBIT_FAILURE; + } - body_ptr = AcisQueryEngine::instance()->get_body_sm_of_ENTITY(VERTEX_ptr ); - if( body_ptr == NULL ) - { - PRINT_ERROR( "Unable to get volume from VERTEX\n" ); - return CUBIT_FAILURE; - } + ENTITIES.init(); + ENTITY* ENTITY_ptr; + int index = -1; + DLIList<int> index_list; + DLIList<VERTEX*> temp_VERTEX_list; + while( (ENTITY_ptr = ENTITIES.next() ) != NULL ) + { + AcisBridge* ab_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(ENTITY_ptr); + ref_vertex_ptr = CAST_TO(ab_ptr, PointACIS); + if( ref_vertex_ptr == NULL ) + { + PRINT_ERROR( "Unable to find RefVertex from ACIS VERTEX!\n" ); + VERTEX_list.clean_out(); + api_delent( copied_BODY_ptr ); + copied_BODY_ptr = NULL; + VERTEX_list.clean_out(); + return CUBIT_FAILURE; + } - BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( VERTEX_ptr ); - if( BODY_ptr == NULL ) - { - PRINT_ERROR( "Unable to get volume from VERTEX\n" ); - return CUBIT_FAILURE; - } + index = body_vertex_list.where_is_item( ref_vertex_ptr ); + if( index != -1 ) + { + index_list.append( index ); + temp_VERTEX_list.append( (VERTEX *)ENTITY_ptr ); + } + if( temp_VERTEX_list.size() == body_vertex_list.size() ) + break; + } + ENTITIES.clear(); - // Add all remaining vertex from this same body to vertex list - num_vertices = ref_vertex_list.size(); - for( i=0; i<num_vertices; i++ ) - { - ref_vertex_ptr = ref_vertex_list.get(); + if( temp_VERTEX_list.size() != body_vertex_list.size() ) + { + PRINT_ERROR( "Internal error correlating VERTEX lists\n" ); + api_delent( copied_BODY_ptr ); + copied_BODY_ptr = NULL; + return CUBIT_FAILURE; + } - BODY_ptr2 = AcisQueryEngine::instance()->get_BODY_of_entity( ref_vertex_ptr ); + // Re-sort the list into the proper order + temp_VERTEX_list.reset(); + index_list.reset(); + for( i=0; i<index_list.size(); i++ ) + { + // Find the VERTEX with the corresponding index + index = index_list.where_is_item( i ); + temp_VERTEX_list.reset(); + temp_VERTEX_list.step( index ); - if( BODY_ptr == BODY_ptr2 ) - { - body_vertex_list.append_unique( ref_vertex_ptr ); - ref_vertex_list.remove(); - removed_ref_vertices.append( ref_vertex_ptr ); + VERTEX_list.append( temp_VERTEX_list.get() ); + } + + return CUBIT_SUCCESS; } - else - ref_vertex_list.step(); - } - // Now we have all the vertices from this particular BODY. + CubitStatus + AcisModifyEngine::get_copied_VERTICES_of_body( + DLIList<PointACIS*>& ref_vertex_list, + DLIList<VERTEX*>& VERTEX_list, + BODY*& copied_BODY_ptr ) const + { + DLIList<PointACIS*> removed_vertices; - // Copy the body before working with it. Here we keep the - // attributes on the BODY so we can get back to the TE's - // in CUBIT from the copy (to find which VERTICE's to correlate - // to the RefVertice's). - copied_BODY_ptr = copy_BODY(BODY_ptr, CUBIT_FALSE); + return get_copied_VERTICES_of_body( ref_vertex_list, VERTEX_list, + removed_vertices, copied_BODY_ptr ); + } - // Loop through the copied BODY's VERTICEs to find which one's - // match to the original BODY's RefVertices. - ENTITY_LIST ENTITIES; - result = api_get_vertices( copied_BODY_ptr, ENTITIES); - if( !result.ok() ) - { - PRINT_ERROR( "Unable to get ACIS VERTICES from a volume\n" ); - api_delent( copied_BODY_ptr ); - copied_BODY_ptr = NULL; - return CUBIT_FAILURE; - } - ENTITIES.init(); - ENTITY* ENTITY_ptr; - int index = -1; - DLIList<int> index_list; - DLIList<VERTEX*> temp_VERTEX_list; - while( (ENTITY_ptr = ENTITIES.next() ) != NULL ) - { - AcisBridge* ab_ptr = ATTRIB_CUBIT_OWNER::cubit_owner(ENTITY_ptr); - ref_vertex_ptr = CAST_TO(ab_ptr, PointACIS); - if( ref_vertex_ptr == NULL ) + GeometryQueryEngine *AcisModifyEngine::get_gqe() { - PRINT_ERROR( "Unable to find RefVertex from ACIS VERTEX!\n" ); - VERTEX_list.clean_out(); - api_delent( copied_BODY_ptr ); - copied_BODY_ptr = NULL; - VERTEX_list.clean_out(); - return CUBIT_FAILURE; + return AcisQueryEngine::instance(); } - index = body_vertex_list.where_is_item( ref_vertex_ptr ); - if( index != -1 ) + CubitBoolean AcisModifyEngine::is_modify_engine(const TopologyBridge *tb_ptr) const { - index_list.append( index ); - temp_VERTEX_list.append( (VERTEX *)ENTITY_ptr ); + + if (CAST_TO(const_cast<TopologyBridge*>(tb_ptr), AcisBridge)) return CUBIT_TRUE; + else return CUBIT_FALSE; } - if( temp_VERTEX_list.size() == body_vertex_list.size() ) - break; - } - ENTITIES.clear(); - if( temp_VERTEX_list.size() != body_vertex_list.size() ) - { - PRINT_ERROR( "Internal error correlating VERTEX lists\n" ); - api_delent( copied_BODY_ptr ); - copied_BODY_ptr = NULL; - return CUBIT_FAILURE; - } + CubitStatus + AcisModifyEngine::get_offset_intersections( Curve* ref_edge1, + Curve* ref_edge2, + DLIList<CubitVector*>& intersection_list, + double offset_distance, + bool ext_first ) + { + int i; + //int done = 0; + bool bounded = !ext_first; - // Re-sort the list into the proper order - temp_VERTEX_list.reset(); - index_list.reset(); - for( i=0; i<index_list.size(); i++ ) - { - // Find the VERTEX with the corresponding index - index = index_list.where_is_item( i ); - temp_VERTEX_list.reset(); - temp_VERTEX_list.step( index ); + // Get the ACIS EDGES + EDGE* EDGE_ptr1 = AcisQueryEngine::get_EDGE(ref_edge1); + EDGE* EDGE_ptr2 = AcisQueryEngine::get_EDGE(ref_edge2); + if (!EDGE_ptr1 || !EDGE_ptr2) + return CUBIT_FAILURE; - VERTEX_list.append( temp_VERTEX_list.get() ); - } + // Determine which curves are straight. Use this because some curves, + // esp. from IGES, can be "straight" splines. + bool straight1, straight2; + straight1 = AcisQueryEngine::instance()->is_curve_app_straight( ref_edge1 ); + straight2 = AcisQueryEngine::instance()->is_curve_app_straight( ref_edge2 ); - return CUBIT_SUCCESS; -} + // If first is straight we need to find the plane to offset it in. + CubitVector pln_norm; + EDGE* offset_EDGE_ptr = NULL; + if( straight1 ) + { + // Need to find the plane normal to do offsets in -CubitStatus -AcisModifyEngine::get_copied_VERTICES_of_body( - DLIList<PointACIS*>& ref_vertex_list, - DLIList<VERTEX*>& VERTEX_list, - BODY*& copied_BODY_ptr ) const -{ - DLIList<PointACIS*> removed_vertices; + // Get point normal form + CubitVector orig1, dir1; + if( ref_edge1->get_point_direction( orig1, dir1 ) == CUBIT_FAILURE ) + { + // This must be a straight spline. Get it from endpoints. + ref_edge1->position_from_fraction( 0.0, orig1 ); + CubitVector end_coords; + ref_edge1->position_from_fraction( 1.0, end_coords ); + dir1 = end_coords - orig1; + dir1.normalize(); + } + if( straight2 ) + { + // Get point normal form + CubitVector orig2, dir2; + if( ref_edge2->get_point_direction( orig2, dir2 ) == CUBIT_FAILURE ) + { + // This must be a straight spline. Get it from endpoints. + ref_edge2->position_from_fraction( 0.0, orig2 ); + CubitVector end_coords; + ref_edge2->position_from_fraction( 1.0, end_coords ); + dir2 = end_coords - orig2; + dir2.normalize(); + } - return get_copied_VERTICES_of_body( ref_vertex_list, VERTEX_list, - removed_vertices, copied_BODY_ptr ); -} + // Find SPAvector from orig1 to orig2 + CubitVector vec1 = orig2 - orig1; + vec1.normalize(); + // Cross dir1 with vec1 to get plane normal. + pln_norm = dir1 * vec1; -GeometryQueryEngine *AcisModifyEngine::get_gqe() -{ - return AcisQueryEngine::instance(); -} + // Make sure this isn't a zero SPAvector. + if( pln_norm.length() == 0.0 ) + { + // Cross dir1 with dir2 to get plane normal + pln_norm = dir1 * dir2; + } -CubitBoolean AcisModifyEngine::is_modify_engine(const TopologyBridge *tb_ptr) const -{ + if( pln_norm.length() == 0.0 ) + { + PRINT_ERROR( "Unable to calculate plane that the curves lie in\n" ); + return CUBIT_FAILURE; + } + } + else // EDGE2 is not straight + { + // Proper normal should be normal to curve, but check to see if EDGE 1 is on + // this plane. + CubitVector orig2; + AcisQueryEngine::instance()->get_EDGE_normal( EDGE_ptr2, pln_norm ); - if (CAST_TO(const_cast<TopologyBridge*>(tb_ptr), AcisBridge)) return CUBIT_TRUE; - else return CUBIT_FALSE; -} + double aln_orig[3], aln_vec[3], apln_orig[3], apln_norm[3]; -CubitStatus -AcisModifyEngine::get_offset_intersections( Curve* ref_edge1, - Curve* ref_edge2, - DLIList<CubitVector*>& intersection_list, - double offset_distance, - bool ext_first ) -{ - int i; - //int done = 0; - bool bounded = !ext_first; + AnalyticGeometryTool *agt = AnalyticGeometryTool::instance(); - // Get the ACIS EDGES - EDGE* EDGE_ptr1 = AcisQueryEngine::get_EDGE(ref_edge1); - EDGE* EDGE_ptr2 = AcisQueryEngine::get_EDGE(ref_edge2); - if (!EDGE_ptr1 || !EDGE_ptr2) - return CUBIT_FAILURE; + agt->copy_pnt( orig1, aln_orig ); agt->copy_pnt( dir1, aln_vec ); + ref_edge2->position_from_fraction( 0.0, orig2 ); // + ref_edge2->position_from_u(ref_edge2->start_param(),orig2); + agt->copy_pnt( orig2, apln_orig ); + agt->copy_pnt( pln_norm, apln_norm ); - // Determine which curves are straight. Use this because some curves, - // esp. from IGES, can be "straight" splines. - bool straight1, straight2; - straight1 = AcisQueryEngine::instance()->is_curve_app_straight( ref_edge1 ); - straight2 = AcisQueryEngine::instance()->is_curve_app_straight( ref_edge2 ); + if( !agt->is_ln_on_pln( aln_orig,aln_vec, apln_orig, apln_norm ) ) + { + PRINT_ERROR( "Curve does not lie in the plane defined by Curve\n" ); + return CUBIT_FAILURE; + } + } - // If first is straight we need to find the plane to offset it in. - CubitVector pln_norm; - EDGE* offset_EDGE_ptr = NULL; - if( straight1 ) - { - // Need to find the plane normal to do offsets in + // Get offset direction cross of plane normal and edge 1 direction + CubitVector offset_dir = pln_norm*dir1; - // Get point normal form - CubitVector orig1, dir1; - if( ref_edge1->get_point_direction( orig1, dir1 ) == CUBIT_FAILURE ) - { - // This must be a straight spline. Get it from endpoints. - ref_edge1->position_from_fraction( 0.0, orig1 ); - CubitVector end_coords; - ref_edge1->position_from_fraction( 1.0, end_coords ); - dir1 = end_coords - orig1; - dir1.normalize(); - } - if( straight2 ) - { - // Get point normal form - CubitVector orig2, dir2; - if( ref_edge2->get_point_direction( orig2, dir2 ) == CUBIT_FAILURE ) - { - // This must be a straight spline. Get it from endpoints. - ref_edge2->position_from_fraction( 0.0, orig2 ); - CubitVector end_coords; - ref_edge2->position_from_fraction( 1.0, end_coords ); - dir2 = end_coords - orig2; - dir2.normalize(); - } + // Do first side + offset_EDGE_ptr = copy_and_move_EDGE( EDGE_ptr1, offset_dir, offset_distance ); + if( offset_EDGE_ptr == NULL ) + { + PRINT_ERROR( "unable to offset Curve for intersection calculation\n" ); + return CUBIT_FAILURE; + } - // Find SPAvector from orig1 to orig2 - CubitVector vec1 = orig2 - orig1; - vec1.normalize(); + if( AcisQueryEngine::instance()->get_intersections( offset_EDGE_ptr, EDGE_ptr2, + intersection_list, bounded ) == + CUBIT_FAILURE ) + { + PRINT_ERROR( "unable to calculate intersections of offset Curves\n" ); + api_delent( offset_EDGE_ptr ); + return CUBIT_FAILURE; + } - // Cross dir1 with vec1 to get plane normal. - pln_norm = dir1 * vec1; + api_delent( offset_EDGE_ptr ); - // Make sure this isn't a zero SPAvector. - if( pln_norm.length() == 0.0 ) - { - // Cross dir1 with dir2 to get plane normal - pln_norm = dir1 * dir2; - } + // Do second side + if( offset_distance != 0.0 ) + { + offset_dir = -offset_dir; + offset_EDGE_ptr = copy_and_move_EDGE( EDGE_ptr1, offset_dir, offset_distance ); + if( offset_EDGE_ptr == NULL ) + { + PRINT_ERROR( "unable to offset Curve for intersection calculation\n" ); + return CUBIT_FAILURE; + } - if( pln_norm.length() == 0.0 ) - { - PRINT_ERROR( "Unable to calculate plane that the curves lie in\n" ); - return CUBIT_FAILURE; - } - } - else // EDGE2 is not straight - { - // Proper normal should be normal to curve, but check to see if EDGE 1 is on - // this plane. - CubitVector orig2; - AcisQueryEngine::instance()->get_EDGE_normal( EDGE_ptr2, pln_norm ); + if( AcisQueryEngine::instance()->get_intersections( offset_EDGE_ptr, EDGE_ptr2, intersection_list, bounded ) == CUBIT_FAILURE ) + { + api_delent( offset_EDGE_ptr ); + PRINT_ERROR( "unable to calculate intersections of offset Curves\n" ); + return CUBIT_FAILURE; + } - double aln_orig[3], aln_vec[3], apln_orig[3], apln_norm[3]; + api_delent( offset_EDGE_ptr ); + } - AnalyticGeometryTool *agt = AnalyticGeometryTool::instance(); + } + else if( offset_distance != 0.0 ) + { + // If there is an offset, offset the first curve to each "side" of the original + // and do the intersections - i.e., try each side. Note we already handled the + // special case if the first curve is straight. - agt->copy_pnt( orig1, aln_orig ); agt->copy_pnt( dir1, aln_vec ); - ref_edge2->position_from_fraction( 0.0, orig2 ); // - ref_edge2->position_from_u(ref_edge2->start_param(),orig2); - agt->copy_pnt( orig2, apln_orig ); - agt->copy_pnt( pln_norm, apln_norm ); + // Do first side + DLIList<EDGE*> EDGE_list; + DLIList<EDGE*> new_EDGE_list; - if( !agt->is_ln_on_pln( aln_orig,aln_vec, apln_orig, apln_norm ) ) - { - PRINT_ERROR( "Curve does not lie in the plane defined by Curve\n" ); - return CUBIT_FAILURE; - } - } + EDGE_list.append( EDGE_ptr1 ); + if( offset_EDGES( EDGE_list, offset_distance, 1, new_EDGE_list ) == CUBIT_FAILURE ) + { + PRINT_ERROR( "Unable to offset the curves\n" ); + return CUBIT_FAILURE; + } - // Get offset direction cross of plane normal and edge 1 direction - CubitVector offset_dir = pln_norm*dir1; + // Note: the new_EDGE_list can have more curves in it than EDGE_list + for( i=0; i<new_EDGE_list.size(); i++ ) + { + offset_EDGE_ptr = new_EDGE_list.get_and_step(); + if( AcisQueryEngine::instance()->get_intersections( offset_EDGE_ptr, + EDGE_ptr2, intersection_list, bounded ) == CUBIT_FAILURE ) + { + api_delent( offset_EDGE_ptr ); + PRINT_ERROR( "unable to calculate intersections of offset Curves\n" ); + return CUBIT_FAILURE; + } + api_delent( offset_EDGE_ptr ); + } - // Do first side - offset_EDGE_ptr = copy_and_move_EDGE( EDGE_ptr1, offset_dir, offset_distance ); - if( offset_EDGE_ptr == NULL ) - { - PRINT_ERROR( "unable to offset Curve for intersection calculation\n" ); - return CUBIT_FAILURE; - } + new_EDGE_list.clean_out(); - if( AcisQueryEngine::instance()->get_intersections( offset_EDGE_ptr, EDGE_ptr2, - intersection_list, bounded ) == - CUBIT_FAILURE ) - { - PRINT_ERROR( "unable to calculate intersections of offset Curves\n" ); - api_delent( offset_EDGE_ptr ); - return CUBIT_FAILURE; - } + // Do other side + if( offset_EDGES( EDGE_list, -offset_distance, 1, new_EDGE_list ) == CUBIT_FAILURE ) + { + PRINT_ERROR( "Unable to offset the curves\n" ); + return CUBIT_FAILURE; + } - api_delent( offset_EDGE_ptr ); + for( i=0; i<new_EDGE_list.size(); i++ ) + { + offset_EDGE_ptr = new_EDGE_list.get_and_step(); + if( AcisQueryEngine::instance()->get_intersections( offset_EDGE_ptr, EDGE_ptr2, intersection_list, bounded ) == CUBIT_FAILURE ) + { + api_delent( offset_EDGE_ptr ); + PRINT_ERROR( "unable to calculate intersections of offset Curves\n" ); + return CUBIT_FAILURE; + } + api_delent( offset_EDGE_ptr ); + } - // Do second side - if( offset_distance != 0.0 ) - { - offset_dir = -offset_dir; - offset_EDGE_ptr = copy_and_move_EDGE( EDGE_ptr1, offset_dir, offset_distance ); - if( offset_EDGE_ptr == NULL ) - { - PRINT_ERROR( "unable to offset Curve for intersection calculation\n" ); - return CUBIT_FAILURE; - } + new_EDGE_list.clean_out(); - if( AcisQueryEngine::instance()->get_intersections( offset_EDGE_ptr, EDGE_ptr2, intersection_list, bounded ) == CUBIT_FAILURE ) - { - api_delent( offset_EDGE_ptr ); - PRINT_ERROR( "unable to calculate intersections of offset Curves\n" ); - return CUBIT_FAILURE; - } + } + else + { + // Just get the intersections + if( AcisQueryEngine::instance()->get_intersections( EDGE_ptr1, EDGE_ptr2, intersection_list, bounded ) == CUBIT_FAILURE ) + { + PRINT_ERROR( "unable to calculate intersections of Curves\n" ); + return CUBIT_FAILURE; + } + } - api_delent( offset_EDGE_ptr ); - } + // Cull out any points that are not on bounds of RefEdge 2 + if( bounded == CUBIT_FALSE ) + { + CubitVector *vec_ptr; + for( i=0; i<intersection_list.size(); i++ ) + { + vec_ptr = intersection_list.get(); - } - else if( offset_distance != 0.0 ) - { - // If there is an offset, offset the first curve to each "side" of the original - // and do the intersections - i.e., try each side. Note we already handled the - // special case if the first curve is straight. + if( ref_edge2->point_containment( *vec_ptr ) == CUBIT_PNT_OFF ) + { + delete vec_ptr; + intersection_list.remove(); + } + else + intersection_list.step(); + } + } - // Do first side - DLIList<EDGE*> EDGE_list; - DLIList<EDGE*> new_EDGE_list; + return CUBIT_SUCCESS; + } - EDGE_list.append( EDGE_ptr1 ); - if( offset_EDGES( EDGE_list, offset_distance, 1, new_EDGE_list ) == CUBIT_FAILURE ) - { - PRINT_ERROR( "Unable to offset the curves\n" ); - return CUBIT_FAILURE; - } + CubitStatus + AcisModifyEngine::get_offset_intersections( Curve* ref_edge_ptr, + Surface* ref_face_ptr, + DLIList<CubitVector*> &intersection_list, + double offset_distance, + bool ext_surf ) + { + outcome result; - // Note: the new_EDGE_list can have more curves in it than EDGE_list - for( i=0; i<new_EDGE_list.size(); i++ ) - { - offset_EDGE_ptr = new_EDGE_list.get_and_step(); - if( AcisQueryEngine::instance()->get_intersections( offset_EDGE_ptr, - EDGE_ptr2, intersection_list, bounded ) == CUBIT_FAILURE ) - { - api_delent( offset_EDGE_ptr ); - PRINT_ERROR( "unable to calculate intersections of offset Curves\n" ); - return CUBIT_FAILURE; - } - api_delent( offset_EDGE_ptr ); - } + EDGE* EDGE_ptr = AcisQueryEngine::get_EDGE(ref_edge_ptr); + FACE* FACE_ptr = AcisQueryEngine::get_FACE(ref_face_ptr); + if (!EDGE_ptr || !FACE_ptr) + return CUBIT_FAILURE; - new_EDGE_list.clean_out(); + // If there is an offset, offset the surface to each "side" of the original + // and do the intersections - i.e., try each side. + if( offset_distance != 0.0 ) + { + FACE* offset_FACE_ptr = NULL; - // Do other side - if( offset_EDGES( EDGE_list, -offset_distance, 1, new_EDGE_list ) == CUBIT_FAILURE ) - { - PRINT_ERROR( "Unable to offset the curves\n" ); - return CUBIT_FAILURE; - } + result = api_offset_face ( FACE_ptr, offset_distance, offset_FACE_ptr ); - for( i=0; i<new_EDGE_list.size(); i++ ) - { - offset_EDGE_ptr = new_EDGE_list.get_and_step(); - if( AcisQueryEngine::instance()->get_intersections( offset_EDGE_ptr, EDGE_ptr2, intersection_list, bounded ) == CUBIT_FAILURE ) - { - api_delent( offset_EDGE_ptr ); - PRINT_ERROR( "unable to calculate intersections of offset Curves\n" ); - return CUBIT_FAILURE; - } - api_delent( offset_EDGE_ptr ); - } + if( offset_FACE_ptr == NULL ) + { + AcisQueryEngine::instance()->ACIS_API_error(result); + PRINT_ERROR( "Unable to offset surface\n" ); + return CUBIT_FAILURE; + } - new_EDGE_list.clean_out(); + // This creates a FACE from the given FACE, only it can be extended out. + FACE* ext_offset_FACE_ptr = make_FACE( offset_FACE_ptr, ext_surf ); + BODY *ext_offset_BODY_ptr = + AcisQueryEngine::instance()->get_BODY_of_ENTITY( ext_offset_FACE_ptr ); - } - else - { - // Just get the intersections - if( AcisQueryEngine::instance()->get_intersections( EDGE_ptr1, EDGE_ptr2, intersection_list, bounded ) == CUBIT_FAILURE ) - { - PRINT_ERROR( "unable to calculate intersections of Curves\n" ); - return CUBIT_FAILURE; - } - } + if( AcisQueryEngine::instance()->get_intersections( EDGE_ptr, ext_offset_FACE_ptr, intersection_list ) == CUBIT_FAILURE ) + { + PRINT_ERROR("Problems finding intersections of curve and surface.\n"); + api_delent( offset_FACE_ptr ); + api_delent( ext_offset_BODY_ptr ); + return CUBIT_FAILURE; + } - // Cull out any points that are not on bounds of RefEdge 2 - if( bounded == CUBIT_FALSE ) - { - CubitVector *vec_ptr; - for( i=0; i<intersection_list.size(); i++ ) - { - vec_ptr = intersection_list.get(); + api_delent( offset_FACE_ptr ); offset_FACE_ptr = NULL; + api_delent( ext_offset_BODY_ptr ); ext_offset_BODY_ptr = NULL; + ext_offset_FACE_ptr = NULL; - if( ref_edge2->point_containment( *vec_ptr ) == CUBIT_PNT_OFF ) - { - delete vec_ptr; - intersection_list.remove(); - } - else - intersection_list.step(); - } - } + // Try other side + result = api_offset_face ( FACE_ptr, -offset_distance, offset_FACE_ptr ); - return CUBIT_SUCCESS; -} + if( offset_FACE_ptr == NULL ) + { + AcisQueryEngine::instance()->ACIS_API_error(result); + PRINT_ERROR( "Unable to offset surface\n" ); + return CUBIT_FAILURE; + } -CubitStatus -AcisModifyEngine::get_offset_intersections( Curve* ref_edge_ptr, - Surface* ref_face_ptr, - DLIList<CubitVector*> &intersection_list, - double offset_distance, - bool ext_surf ) -{ - outcome result; + // This creates a FACE from the given FACE, only it is extended out. + ext_offset_FACE_ptr = make_FACE( offset_FACE_ptr, CUBIT_TRUE ); + ext_offset_BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( ext_offset_FACE_ptr ); - EDGE* EDGE_ptr = AcisQueryEngine::get_EDGE(ref_edge_ptr); - FACE* FACE_ptr = AcisQueryEngine::get_FACE(ref_face_ptr); - if (!EDGE_ptr || !FACE_ptr) - return CUBIT_FAILURE; + if( AcisQueryEngine::instance()->get_intersections( EDGE_ptr, ext_offset_FACE_ptr, intersection_list ) == CUBIT_FAILURE ) + { + PRINT_ERROR("Problems finding intersections of curve and surface.\n" ); + api_delent( offset_FACE_ptr ); + api_delent( ext_offset_BODY_ptr ); + return CUBIT_FAILURE; + } - // If there is an offset, offset the surface to each "side" of the original - // and do the intersections - i.e., try each side. - if( offset_distance != 0.0 ) - { - FACE* offset_FACE_ptr = NULL; + api_delent( offset_FACE_ptr ); + api_delent( ext_offset_BODY_ptr ); + } + else + { + FACE* ext_FACE_ptr = make_FACE( FACE_ptr, ext_surf ); + BODY *ext_BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( ext_FACE_ptr ); + if( AcisQueryEngine::instance()->get_intersections( EDGE_ptr, ext_FACE_ptr, intersection_list ) == CUBIT_FAILURE ) + { + PRINT_ERROR("Problems finding intersections of curve and surface.\n" ); + api_delent( ext_BODY_ptr ); + return CUBIT_FAILURE; + } + api_delent( ext_BODY_ptr ); + } - result = api_offset_face ( FACE_ptr, offset_distance, offset_FACE_ptr ); + return CUBIT_SUCCESS; + } - if( offset_FACE_ptr == NULL ) - { - AcisQueryEngine::instance()->ACIS_API_error(result); - PRINT_ERROR( "Unable to offset surface\n" ); - return CUBIT_FAILURE; - } + EDGE * + AcisModifyEngine::copy_and_move_EDGE( EDGE *EDGE_ptr, + const CubitVector &input_dir, + double dist ) + { + // Setup translation transform + SPAtransf tr; + CubitVector dir(input_dir); + dir.normalize(); // For now, allow this SPAvector to be modified + CubitVector delta = dist*dir; + SPAvector vec(delta.x(), delta.y(), delta.z() ); + tr = translate_transf( vec ); - // This creates a FACE from the given FACE, only it can be extended out. - FACE* ext_offset_FACE_ptr = make_FACE( offset_FACE_ptr, ext_surf ); - BODY *ext_offset_BODY_ptr = - AcisQueryEngine::instance()->get_BODY_of_ENTITY( ext_offset_FACE_ptr ); + EDGE* new_EDGE_ptr; + outcome result = api_trans_edge( EDGE_ptr, tr, new_EDGE_ptr ); + if (!result.ok()) + { + AcisQueryEngine::instance()->ACIS_API_error( result ); + return NULL; + } - if( AcisQueryEngine::instance()->get_intersections( EDGE_ptr, ext_offset_FACE_ptr, intersection_list ) == CUBIT_FAILURE ) - { - PRINT_ERROR("Problems finding intersections of curve and surface.\n"); - api_delent( offset_FACE_ptr ); - api_delent( ext_offset_BODY_ptr ); - return CUBIT_FAILURE; - } + // Remove the CUBIT owner attributes from the new edge + ATTRIB_CUBIT_OWNER::remove_cubit_owner((ENTITY*)new_EDGE_ptr, CUBIT_TRUE); - api_delent( offset_FACE_ptr ); offset_FACE_ptr = NULL; - api_delent( ext_offset_BODY_ptr ); ext_offset_BODY_ptr = NULL; - ext_offset_FACE_ptr = NULL; + return new_EDGE_ptr; + } - // Try other side - result = api_offset_face ( FACE_ptr, -offset_distance, offset_FACE_ptr ); + CubitStatus + AcisModifyEngine::offset_EDGES( DLIList<EDGE*> &EDGE_list, + double offset_distance, + int gap_type, + DLIList<EDGE*> &new_EDGE_list ) + { + int i; + EDGE *EDGE_ptr = NULL; + //ENTITY *ENTITY_ptr = NULL; + EDGE *tmp_EDGE_ptr = NULL; - if( offset_FACE_ptr == NULL ) - { - AcisQueryEngine::instance()->ACIS_API_error(result); - PRINT_ERROR( "Unable to offset surface\n" ); - return CUBIT_FAILURE; - } + // Need to create a wire from the EDGEs - // This creates a FACE from the given FACE, only it is extended out. - ext_offset_FACE_ptr = make_FACE( offset_FACE_ptr, CUBIT_TRUE ); - ext_offset_BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( ext_offset_FACE_ptr ); + // Copy them first + int edge_count = EDGE_list.size(); + EDGE** EDGEs = new EDGE*[edge_count]; - if( AcisQueryEngine::instance()->get_intersections( EDGE_ptr, ext_offset_FACE_ptr, intersection_list ) == CUBIT_FAILURE ) - { - PRINT_ERROR("Problems finding intersections of curve and surface.\n" ); - api_delent( offset_FACE_ptr ); - api_delent( ext_offset_BODY_ptr ); - return CUBIT_FAILURE; - } + EDGE_list.reset(); + for( i=0; i<EDGE_list.size(); i++ ) + { + EDGE_ptr = EDGE_list.get_and_step(); - api_delent( offset_FACE_ptr ); - api_delent( ext_offset_BODY_ptr ); - } - else - { - FACE* ext_FACE_ptr = make_FACE( FACE_ptr, ext_surf ); - BODY *ext_BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( ext_FACE_ptr ); - if( AcisQueryEngine::instance()->get_intersections( EDGE_ptr, ext_FACE_ptr, intersection_list ) == CUBIT_FAILURE ) - { - PRINT_ERROR("Problems finding intersections of curve and surface.\n" ); - api_delent( ext_BODY_ptr ); - return CUBIT_FAILURE; - } - api_delent( ext_BODY_ptr ); - } + api_edge( EDGE_ptr, tmp_EDGE_ptr ); - return CUBIT_SUCCESS; -} + EDGEs[i] = tmp_EDGE_ptr; -EDGE * -AcisModifyEngine::copy_and_move_EDGE( EDGE *EDGE_ptr, - const CubitVector &input_dir, - double dist ) -{ - // Setup translation transform - SPAtransf tr; - CubitVector dir(input_dir); - dir.normalize(); // For now, allow this SPAvector to be modified - CubitVector delta = dist*dir; - SPAvector vec(delta.x(), delta.y(), delta.z() ); - tr = translate_transf( vec ); + // Remove the owner attribute from the copied edge & children + ATTRIB_CUBIT_OWNER::remove_cubit_owner(EDGEs[i], CUBIT_TRUE); + } - EDGE* new_EDGE_ptr; - outcome result = api_trans_edge( EDGE_ptr, tr, new_EDGE_ptr ); - if (!result.ok()) - { - AcisQueryEngine::instance()->ACIS_API_error( result ); - return NULL; - } + // The EDGEs are put into the wire so don't delete them. + BODY* wire_BODY = NULL; + outcome result = api_make_ewire( edge_count, EDGEs, wire_BODY ); - // Remove the CUBIT owner attributes from the new edge - ATTRIB_CUBIT_OWNER::remove_cubit_owner((ENTITY*)new_EDGE_ptr, CUBIT_TRUE); + if( !result.ok() || wire_BODY==NULL ) + { + AcisQueryEngine::instance()->ACIS_API_error(result); + PRINT_ERROR( "unable to make ACIS wire body from curves\n" ); + if( wire_BODY ) + api_delent( (ENTITY*)wire_BODY ); + else + { + for( i=0; i<edge_count; i++) + api_delent( (ENTITY*)EDGEs[i] ); + } + return CUBIT_FAILURE; + } - return new_EDGE_ptr; -} + //The gap type is as follows; 0 = rounded like arcs, 1 = extended like lines, and 2 = + //natural like curve extensions. Lines are extend with lines and circles are extended with + //circles. -CubitStatus -AcisModifyEngine::offset_EDGES( DLIList<EDGE*> &EDGE_list, - double offset_distance, - int gap_type, - DLIList<EDGE*> &new_EDGE_list ) -{ - int i; - EDGE *EDGE_ptr = NULL; - //ENTITY *ENTITY_ptr = NULL; - EDGE *tmp_EDGE_ptr = NULL; + law* offset_law = new constant_law( offset_distance ); + law *twist_law=NULL; + BODY* offset_WIRE; + logical trim_flg = TRUE; - // Need to create a wire from the EDGEs + // need to check if wire is planar and calculate the + // normal to the plane + WIRE* this_wire = wire_BODY->wire() ? + wire_BODY->wire() : wire_BODY->lump()->shell()->wire(); - // Copy them first - int edge_count = EDGE_list.size(); - EDGE** EDGEs = new EDGE*[edge_count]; + SPAposition centroid; + SPAunit_vector normal; + if(!is_planar_wire(this_wire, centroid, normal)) + { + PRINT_ERROR("selected curves do not form a planar chain\n"); + api_delent( (ENTITY*)wire_BODY ); + return CUBIT_FAILURE; + } - EDGE_list.reset(); - for( i=0; i<EDGE_list.size(); i++ ) - { - EDGE_ptr = EDGE_list.get_and_step(); + // Offset the wire to get the new curves + result = api_offset_planar_wire( wire_BODY, offset_law, twist_law, + normal, offset_WIRE, gap_type, trim_flg ); - api_edge( EDGE_ptr, tmp_EDGE_ptr ); + if( !result.ok() ) + { + AcisQueryEngine::instance()->ACIS_API_error(result); + PRINT_ERROR( "unable to offset wire volume\n" ); + api_delent( (ENTITY*)wire_BODY ); + return CUBIT_FAILURE; + } - EDGEs[i] = tmp_EDGE_ptr; + // Copy out the EDGES from the WIRE, then delete the WIRE + DLIList<EDGE*> wire_edge_list; + AcisQueryEngine::instance()->get_EDGEs( (ENTITY *)offset_WIRE, wire_edge_list ); - // Remove the owner attribute from the copied edge & children - ATTRIB_CUBIT_OWNER::remove_cubit_owner(EDGEs[i], CUBIT_TRUE); - } + // Sometimes the function works but we don't get any edges + if( !wire_edge_list.size() ) + { + api_delent( (ENTITY*)wire_BODY ); + return CUBIT_FAILURE; + } - // The EDGEs are put into the wire so don't delete them. - BODY* wire_BODY = NULL; - outcome result = api_make_ewire( edge_count, EDGEs, wire_BODY ); + wire_edge_list.reset(); + EDGE *new_EDGE_ptr; + for( i=0; i<wire_edge_list.size(); i++ ) + { + EDGE_ptr = wire_edge_list.get_and_step(); - if( !result.ok() || wire_BODY==NULL ) - { - AcisQueryEngine::instance()->ACIS_API_error(result); - PRINT_ERROR( "unable to make ACIS wire body from curves\n" ); - if( wire_BODY ) - api_delent( (ENTITY*)wire_BODY ); - else - { - for( i=0; i<edge_count; i++) - api_delent( (ENTITY*)EDGEs[i] ); - } - return CUBIT_FAILURE; - } + result = api_edge( EDGE_ptr, new_EDGE_ptr ); + if( !result.ok() ) + { + AcisQueryEngine::instance()->ACIS_API_error(result); + PRINT_INFO( "Unable to copy curve from new WIRE\n" ); + api_delent( (ENTITY*)wire_BODY ); + return CUBIT_FAILURE; + } - //The gap type is as follows; 0 = rounded like arcs, 1 = extended like lines, and 2 = - //natural like curve extensions. Lines are extend with lines and circles are extended with - //circles. + new_EDGE_list.append( new_EDGE_ptr ); + } - law* offset_law = new constant_law( offset_distance ); - law *twist_law=NULL; - BODY* offset_WIRE; - logical trim_flg = TRUE; - - // need to check if wire is planar and calculate the - // normal to the plane - WIRE* this_wire = wire_BODY->wire() ? - wire_BODY->wire() : wire_BODY->lump()->shell()->wire(); - - SPAposition centroid; - SPAunit_vector normal; - if(!is_planar_wire(this_wire, centroid, normal)) - { - PRINT_ERROR("selected curves do not form a planar chain\n"); + // Delete the WIRE api_delent( (ENTITY*)wire_BODY ); - return CUBIT_FAILURE; - } - // Offset the wire to get the new curves - result = api_offset_planar_wire( wire_BODY, offset_law, twist_law, - normal, offset_WIRE, gap_type, trim_flg ); + return CUBIT_SUCCESS; + } - if( !result.ok() ) - { - AcisQueryEngine::instance()->ACIS_API_error(result); - PRINT_ERROR( "unable to offset wire volume\n" ); - api_delent( (ENTITY*)wire_BODY ); - return CUBIT_FAILURE; - } + Curve* AcisModifyEngine::find_curve_by_end_coord( const CubitVector& coords, + DLIList<Curve*>& curves, + bool& start_flag ) const + { + Curve* curve = 0; + CubitVector curve_pt; + const double tol = AcisQueryEngine::instance()->get_sme_resabs_tolerance(); + const double tolsqr = tol*tol; - // Copy out the EDGES from the WIRE, then delete the WIRE - DLIList<EDGE*> wire_edge_list; - AcisQueryEngine::instance()->get_EDGEs( (ENTITY *)offset_WIRE, wire_edge_list ); + DLIList<Curve*> tmp_list(curves); + tmp_list.reset(); + for ( int i = curves.size(); i--; ) + { + curve = tmp_list.get_and_step(); - // Sometimes the function works but we don't get any edges - if( !wire_edge_list.size() ) - { - api_delent( (ENTITY*)wire_BODY ); - return CUBIT_FAILURE; - } + curve->position_from_fraction( 0.0, curve_pt ); + if ( (curve_pt - coords).length_squared() < tolsqr ) + { + start_flag = true; + return curve; + } - wire_edge_list.reset(); - EDGE *new_EDGE_ptr; - for( i=0; i<wire_edge_list.size(); i++ ) - { - EDGE_ptr = wire_edge_list.get_and_step(); + curve->position_from_fraction( 1.0, curve_pt ); + if ( (curve_pt - coords).length_squared() < tolsqr ) + { + start_flag = false; + return curve; + } + } - result = api_edge( EDGE_ptr, new_EDGE_ptr ); - if( !result.ok() ) - { - AcisQueryEngine::instance()->ACIS_API_error(result); - PRINT_INFO( "Unable to copy curve from new WIRE\n" ); - api_delent( (ENTITY*)wire_BODY ); - return CUBIT_FAILURE; - } + return 0; + } - new_EDGE_list.append( new_EDGE_ptr ); - } + bool AcisModifyEngine::bridge_deactivated(AcisBridge* bridge) const + { + return deactivatedSet.count(bridge) > 0; + } - // Delete the WIRE - api_delent( (ENTITY*)wire_BODY ); - - return CUBIT_SUCCESS; -} - -Curve* AcisModifyEngine::find_curve_by_end_coord( const CubitVector& coords, - DLIList<Curve*>& curves, - bool& start_flag ) const -{ - Curve* curve = 0; - CubitVector curve_pt; - const double tol = AcisQueryEngine::instance()->get_sme_resabs_tolerance(); - const double tolsqr = tol*tol; - - DLIList<Curve*> tmp_list(curves); - tmp_list.reset(); - for ( int i = curves.size(); i--; ) - { - curve = tmp_list.get_and_step(); - - curve->position_from_fraction( 0.0, curve_pt ); - if ( (curve_pt - coords).length_squared() < tolsqr ) + CubitStatus AcisModifyEngine::deactivate_bridge( AcisBridge* bridge ) const { - start_flag = true; - return curve; + AcisModifyEngine* nonconst = AcisModifyEngine::instance(); + bool unique = nonconst->deactivatedSet.insert(bridge).second; + return (CubitStatus)unique; } - curve->position_from_fraction( 1.0, curve_pt ); - if ( (curve_pt - coords).length_squared() < tolsqr ) + CubitStatus AcisModifyEngine::reactivate_bridge( AcisBridge* bridge ) const { - start_flag = false; - return curve; + AcisModifyEngine* nonconst = AcisModifyEngine::instance(); + int count = nonconst->deactivatedSet.erase(bridge); + return count > 0 ? CUBIT_SUCCESS : CUBIT_FAILURE; } - } - return 0; -} + void AcisModifyEngine::cleanout_deactivated_geometry() const + { + AcisModifyEngine* nonconst = AcisModifyEngine::instance(); + // std::set<AcisBridge*>::iterator itor = nonconst->deactivatedSet.begin(), + // end = nonconst->deactivatedSet.end(); + // for ( ; itor != end; ++itor ) + // delete *itor; -bool AcisModifyEngine::bridge_deactivated(AcisBridge* bridge) const -{ - return deactivatedSet.count(bridge) > 0; -} + nonconst->deactivatedSet.clear(); + } -CubitStatus AcisModifyEngine::deactivate_bridge( AcisBridge* bridge ) const -{ - AcisModifyEngine* nonconst = AcisModifyEngine::instance(); - bool unique = nonconst->deactivatedSet.insert(bridge).second; - return (CubitStatus)unique; -} - -CubitStatus AcisModifyEngine::reactivate_bridge( AcisBridge* bridge ) const -{ - AcisModifyEngine* nonconst = AcisModifyEngine::instance(); - int count = nonconst->deactivatedSet.erase(bridge); - return count > 0 ? CUBIT_SUCCESS : CUBIT_FAILURE; -} - -void AcisModifyEngine::cleanout_deactivated_geometry() const -{ - AcisModifyEngine* nonconst = AcisModifyEngine::instance(); -// std::set<AcisBridge*>::iterator itor = nonconst->deactivatedSet.begin(), -// end = nonconst->deactivatedSet.end(); -// for ( ; itor != end; ++itor ) -// delete *itor; - - nonconst->deactivatedSet.clear(); -} - -CubitStatus AcisModifyEngine::scale( BodySM *&body, const CubitVector& f ) -{ + CubitStatus AcisModifyEngine::scale( BodySM *&body, const CubitVector& f ) + { #if CUBIT_ACIS_VERSION < 1100 - api_initialize_operators(); + api_initialize_operators(); #elif defined(WIN32) || defined(MACOSX) - api_initialize_warp(); + api_initialize_warp(); #endif - BODY *new_BODY = NULL; + BODY *new_BODY = NULL; - if( f.x() != f.y() || - f.x() != f.z() || - f.y() != f.z() ) - { - BODY *tmp_BODY = AcisQueryEngine::get_BODY( body ); - new_BODY = AcisModifyEngine::instance()->copy_BODY(tmp_BODY, - GeometryModifyTool::instance()->get_new_ids()); - } + if( f.x() != f.y() || + f.x() != f.z() || + f.y() != f.z() ) + { + BODY *tmp_BODY = AcisQueryEngine::get_BODY( body ); + new_BODY = AcisModifyEngine::instance()->copy_BODY(tmp_BODY, + GeometryModifyTool::instance()->get_new_ids()); + } - CubitStatus result = AcisQueryEngine::instance()->transform( new_BODY, scale_transf( f.x(), f.y(), f.z() ) ); + CubitStatus result = AcisQueryEngine::instance()->transform( new_BODY, scale_transf( f.x(), f.y(), f.z() ) ); #if CUBIT_ACIS_VERSION < 1100 - api_terminate_operators(); + api_terminate_operators(); #elif defined(WIN32) || defined(MACOSX) - api_terminate_warp(); + api_terminate_warp(); #endif - if( new_BODY ) - { - BODY *old_BODY = AcisQueryEngine::get_BODY( body ); - BodySM *new_body = get_new_Body( body, old_BODY, new_BODY, false); - body = new_body; - } + if( new_BODY ) + { + BODY *old_BODY = AcisQueryEngine::get_BODY( body ); + BodySM *new_body = get_new_Body( body, old_BODY, new_BODY, false); + body = new_body; + } - return result; -} + return result; + } -CubitStatus AcisModifyEngine::tolerant_imprint( DLIList<BodySM*> &bodies_in, - DLIList<BodySM*> &new_bodies, + CubitStatus AcisModifyEngine::tolerant_imprint( DLIList<BodySM*> &bodies_in, + DLIList<BodySM*> &new_bodies, DLIList<TopologyBridge*> *new_tbs, DLIList<TopologyBridge*> *att_tbs ) const -{ - //make sure all bodies are from the same modify engine - DLIList<BodySM*> new_body_list; + { + //make sure all bodies are from the same modify engine + DLIList<BodySM*> new_body_list; - ProgressTool *progress_tool = NULL; - if( bodies_in.size() > 2 ) - { - progress_tool = AppUtil::instance()->progress_tool(); - progress_tool->start(0, 100, "Tolerant Imprinting" ); - } + ProgressTool *progress_tool = NULL; + if( bodies_in.size() > 2 ) + { + progress_tool = AppUtil::instance()->progress_tool(); + progress_tool->start(0, 100, "Tolerant Imprinting" ); + } - CubitStatus status = imprint_overlapping_curves( bodies_in, new_body_list, progress_tool ); + CubitStatus status = imprint_overlapping_curves( bodies_in, new_body_list, progress_tool ); - status = imprint_overlapping_surfaces( bodies_in, new_body_list, progress_tool ); + status = imprint_overlapping_surfaces( bodies_in, new_body_list, progress_tool ); - status = imprint_overlapping_curves( bodies_in, new_body_list, progress_tool, new_tbs, att_tbs ); + status = imprint_overlapping_curves( bodies_in, new_body_list, progress_tool, new_tbs, att_tbs ); - if( progress_tool ) - progress_tool->end(); + if( progress_tool ) + progress_tool->end(); - return CUBIT_SUCCESS; -} + return CUBIT_SUCCESS; + } -CubitStatus AcisModifyEngine::imprint_overlapping_curves( DLIList<BodySM*> &body_sms, - DLIList<BodySM*> &new_body_sms, - ProgressTool *progress_tool, - DLIList<TopologyBridge*> *new_tbs, - DLIList<TopologyBridge*> *att_tbs ) const -{ - //find all mergeable curves between the bodies - CubitStatus status; + CubitStatus AcisModifyEngine::imprint_overlapping_curves( DLIList<BodySM*> &body_sms, + DLIList<BodySM*> &new_body_sms, + ProgressTool *progress_tool, + DLIList<TopologyBridge*> *new_tbs, + DLIList<TopologyBridge*> *att_tbs ) const + { + //find all mergeable curves between the bodies + CubitStatus status; #ifdef BOYD16 - DLIList<RefEntity*> entities; + DLIList<RefEntity*> entities; #endif - DLIList< DLIList<Curve*>* > lists_of_mergeable_curves; + DLIList< DLIList<Curve*>* > lists_of_mergeable_curves; - status = MergeTool::instance()->find_only_mergeable_curves( body_sms, lists_of_mergeable_curves ); + status = MergeTool::instance()->find_only_mergeable_curves( body_sms, lists_of_mergeable_curves ); - int i,j; - //increment 4% - if( progress_tool ) - { - for( i=4; i--; ) - progress_tool->step(); - } + int i,j; + //increment 4% + if( progress_tool ) + { + for( i=4; i--; ) + progress_tool->step(); + } - //find all overlapping curves between the bodies - std::map<Curve*, DLIList<Curve*>* > curve_to_list_map; - DLIList< DLIList<Curve*>* > lists_of_overlapping_curves; - //for each list, curves 2-n overlap the first curve + //find all overlapping curves between the bodies + std::map<Curve*, DLIList<Curve*>* > curve_to_list_map; + DLIList< DLIList<Curve*>* > lists_of_overlapping_curves; + //for each list, curves 2-n overlap the first curve - SurfaceOverlapTool::instance()->find_overlapping_curves( body_sms, lists_of_overlapping_curves, - curve_to_list_map ); + SurfaceOverlapTool::instance()->find_overlapping_curves( body_sms, lists_of_overlapping_curves, + curve_to_list_map ); - //increment 8% - if( progress_tool ) - { - for( i=9; i--; ) - progress_tool->step(); - } + //increment 8% + if( progress_tool ) + { + for( i=9; i--; ) + progress_tool->step(); + } - //remove idential groups and sub-groups of mergeable curves from - //overlapping groups. For example: If curves A,B,C,D are in a mergeable group - //the following groups will have no need for imprinting, becasue the curves are - //mergeable all - //A,B,C,D - //B,C,D is a sub-group - //C,D is a sub-group - //These groups need not be considered for imprinting + //remove idential groups and sub-groups of mergeable curves from + //overlapping groups. For example: If curves A,B,C,D are in a mergeable group + //the following groups will have no need for imprinting, becasue the curves are + //mergeable all + //A,B,C,D + //B,C,D is a sub-group + //C,D is a sub-group + //These groups need not be considered for imprinting - std::map<Curve*, DLIList<Curve*>*>::iterator curve_iter; - lists_of_mergeable_curves.reset(); + std::map<Curve*, DLIList<Curve*>*>::iterator curve_iter; + lists_of_mergeable_curves.reset(); - DLIList< DLIList<Curve*>* > lists_to_delete; + DLIList< DLIList<Curve*>* > lists_to_delete; - for( i=lists_of_mergeable_curves.size(); i--; ) - { - DLIList<Curve*> *mergeable_curve_list = lists_of_mergeable_curves.get_and_step(); + for( i=lists_of_mergeable_curves.size(); i--; ) + { + DLIList<Curve*> *mergeable_curve_list = lists_of_mergeable_curves.get_and_step(); - for( j=mergeable_curve_list->size(); j--; ) - { - Curve *tmp_curve = mergeable_curve_list->get_and_step(); - curve_iter = curve_to_list_map.find( tmp_curve ); + for( j=mergeable_curve_list->size(); j--; ) + { + Curve *tmp_curve = mergeable_curve_list->get_and_step(); + curve_iter = curve_to_list_map.find( tmp_curve ); - if( curve_iter == curve_to_list_map.end() ) - continue; + if( curve_iter == curve_to_list_map.end() ) + continue; - DLIList<Curve*>* overlapping_curves = curve_iter->second; + DLIList<Curve*>* overlapping_curves = curve_iter->second; - //make sure that list hasn't already been removed - if( lists_to_delete.move_to( overlapping_curves ) ) - continue; + //make sure that list hasn't already been removed + if( lists_to_delete.move_to( overlapping_curves ) ) + continue; - //don't want to perturb the list...make a copy - DLIList<Curve*> copy_list = *mergeable_curve_list; + //don't want to perturb the list...make a copy + DLIList<Curve*> copy_list = *mergeable_curve_list; - //if the list of overlapping curve is the same as the mergeable curve list, - //remove the list list of overlapping curves + //if the list of overlapping curve is the same as the mergeable curve list, + //remove the list list of overlapping curves - if( copy_list == *overlapping_curves ) - { - //remove overlapping_curve_list from the list - lists_of_overlapping_curves.move_to( overlapping_curves ); - lists_of_overlapping_curves.change_to( NULL ); + if( copy_list == *overlapping_curves ) + { + //remove overlapping_curve_list from the list + lists_of_overlapping_curves.move_to( overlapping_curves ); + lists_of_overlapping_curves.change_to( NULL ); - //put in list for deletion - lists_to_delete.append( overlapping_curves ); + //put in list for deletion + lists_to_delete.append( overlapping_curves ); - //remove overlapping_curve_list from the map - curve_to_list_map.erase( curve_iter ); - continue; - } - else if (overlapping_curves->size() < copy_list.size() ) - { - //If every curve in overlapping list is in the merge list, - //remove that overlapping list. - int list_size_before = copy_list.size(); - copy_list.merge_unique( *overlapping_curves ); - if( list_size_before == copy_list.size() ) - { - //remove overlapping_curve_list from the list - lists_of_overlapping_curves.move_to( overlapping_curves ); - lists_of_overlapping_curves.change_to( NULL ); + //remove overlapping_curve_list from the map + curve_to_list_map.erase( curve_iter ); + continue; + } + else if (overlapping_curves->size() < copy_list.size() ) + { + //If every curve in overlapping list is in the merge list, + //remove that overlapping list. + int list_size_before = copy_list.size(); + copy_list.merge_unique( *overlapping_curves ); + if( list_size_before == copy_list.size() ) + { + //remove overlapping_curve_list from the list + lists_of_overlapping_curves.move_to( overlapping_curves ); + lists_of_overlapping_curves.change_to( NULL ); - //put in list for deletion - lists_to_delete.append( overlapping_curves ); - } - } - } - } + //put in list for deletion + lists_to_delete.append( overlapping_curves ); + } + } + } + } - //clean up lists - for( i=lists_of_mergeable_curves.size(); i--; ) - delete lists_of_mergeable_curves.get_and_step(); - lists_of_overlapping_curves.remove_all_with_value( NULL ); + //clean up lists + for( i=lists_of_mergeable_curves.size(); i--; ) + delete lists_of_mergeable_curves.get_and_step(); + lists_of_overlapping_curves.remove_all_with_value( NULL ); - for( i=lists_to_delete.size(); i--; ) - delete lists_to_delete.get_and_step(); + for( i=lists_to_delete.size(); i--; ) + delete lists_to_delete.get_and_step(); - double tolerance = GeometryQueryTool::get_geometry_factor()*GEOMETRY_RESABS; + double tolerance = GeometryQueryTool::get_geometry_factor()*GEOMETRY_RESABS; - DLIList<BodySM*> imprint_body_order; - lists_of_overlapping_curves.reset(); - //Now setup multi-map for imprinting vertices onto bodies - //This is how the curve - vertex imprinting should be done: - // -imprint vertices of curve 1 in list onto curves 2 - n - // -imprint vertcies of curve 2 - n onto curve 1 - std::multimap<BodySM*, CubitVector* > body_point_imprint_map; - std::multimap<BodySM*, CubitVector* >::iterator tmp_iter, upper_iter; + DLIList<BodySM*> imprint_body_order; + lists_of_overlapping_curves.reset(); + //Now setup multi-map for imprinting vertices onto bodies + //This is how the curve - vertex imprinting should be done: + // -imprint vertices of curve 1 in list onto curves 2 - n + // -imprint vertcies of curve 2 - n onto curve 1 + std::multimap<BodySM*, CubitVector* > body_point_imprint_map; + std::multimap<BodySM*, CubitVector* >::iterator tmp_iter, upper_iter; - for( i=lists_of_overlapping_curves.size(); i--; ) - { - DLIList<Curve*> *curve_list = lists_of_overlapping_curves.get_and_step(); - curve_list->reset(); - Curve *first_curve = curve_list->get_and_step(); + for( i=lists_of_overlapping_curves.size(); i--; ) + { + DLIList<Curve*> *curve_list = lists_of_overlapping_curves.get_and_step(); + curve_list->reset(); + Curve *first_curve = curve_list->get_and_step(); - DLIList<Point*> curve_1_points; - first_curve->points( curve_1_points ); - Point *s_point1 = curve_1_points.get_and_step(); - Point *e_point1 = curve_1_points.get_and_step(); + DLIList<Point*> curve_1_points; + first_curve->points( curve_1_points ); + Point *s_point1 = curve_1_points.get_and_step(); + Point *e_point1 = curve_1_points.get_and_step(); - BodySM *first_curve_body = first_curve->bodysm(); + BodySM *first_curve_body = first_curve->bodysm(); - while( curve_list->size() > 1 ) - { - Curve *other_curve = curve_list->pop(); - DLIList<Point*> curve_2_points; - other_curve->points( curve_2_points ); - Point *s_point2 = curve_2_points.get_and_step(); - Point *e_point2 = curve_2_points.get_and_step(); + while( curve_list->size() > 1 ) + { + Curve *other_curve = curve_list->pop(); + DLIList<Point*> curve_2_points; + other_curve->points( curve_2_points ); + Point *s_point2 = curve_2_points.get_and_step(); + Point *e_point2 = curve_2_points.get_and_step(); - BodySM *other_curve_body = other_curve->bodysm(); + BodySM *other_curve_body = other_curve->bodysm(); - CubitVector close_pt; - first_curve->closest_point_trimmed( s_point2->coordinates(), close_pt ); + CubitVector close_pt; + first_curve->closest_point_trimmed( s_point2->coordinates(), close_pt ); - if( close_pt.distance_between( s_point1->coordinates() ) > tolerance && - close_pt.distance_between( e_point1->coordinates() ) > tolerance ) - { - //are there any other points within tolerance to this point - //to be imprinted onto this body? - tmp_iter = body_point_imprint_map.find( first_curve_body ); - bool consider_point = true; - if( tmp_iter != body_point_imprint_map.end() ) - { - CubitVector *tmp_vec = tmp_iter->second; - upper_iter = body_point_imprint_map.upper_bound( tmp_iter->first ); + if( close_pt.distance_between( s_point1->coordinates() ) > tolerance && + close_pt.distance_between( e_point1->coordinates() ) > tolerance ) + { + //are there any other points within tolerance to this point + //to be imprinted onto this body? + tmp_iter = body_point_imprint_map.find( first_curve_body ); + bool consider_point = true; + if( tmp_iter != body_point_imprint_map.end() ) + { + CubitVector *tmp_vec = tmp_iter->second; + upper_iter = body_point_imprint_map.upper_bound( tmp_iter->first ); - for(; tmp_iter!=upper_iter; ++tmp_iter) - { - tmp_vec = tmp_iter->second; - if( close_pt.distance_between( *tmp_vec ) < tolerance ) - { - consider_point = false; - break; - } - } - } + for(; tmp_iter!=upper_iter; ++tmp_iter) + { + tmp_vec = tmp_iter->second; + if( close_pt.distance_between( *tmp_vec ) < tolerance ) + { + consider_point = false; + break; + } + } + } - if( consider_point ) - { - //imprint body of curve1 with vertex at this location - CubitVector *tmp_vec = new CubitVector( close_pt ); - body_point_imprint_map.insert( std::multimap<BodySM*, - CubitVector*>::value_type( first_curve_body, tmp_vec )); - imprint_body_order.append_unique( first_curve_body ); - } - } + if( consider_point ) + { + //imprint body of curve1 with vertex at this location + CubitVector *tmp_vec = new CubitVector( close_pt ); + body_point_imprint_map.insert( std::multimap<BodySM*, + CubitVector*>::value_type( first_curve_body, tmp_vec )); + imprint_body_order.append_unique( first_curve_body ); + } + } - first_curve->closest_point_trimmed( e_point2->coordinates(), close_pt ); + first_curve->closest_point_trimmed( e_point2->coordinates(), close_pt ); - if( close_pt.distance_between( s_point1->coordinates() ) > tolerance && - close_pt.distance_between( e_point1->coordinates() ) > tolerance ) - { - //are there any other points within tolerance to this point - //to be imprinted onto this body? - tmp_iter = body_point_imprint_map.find( first_curve_body ); - bool consider_point = true; - if( tmp_iter != body_point_imprint_map.end() ) - { - CubitVector *tmp_vec = tmp_iter->second; - upper_iter = body_point_imprint_map.upper_bound( tmp_iter->first ); + if( close_pt.distance_between( s_point1->coordinates() ) > tolerance && + close_pt.distance_between( e_point1->coordinates() ) > tolerance ) + { + //are there any other points within tolerance to this point + //to be imprinted onto this body? + tmp_iter = body_point_imprint_map.find( first_curve_body ); + bool consider_point = true; + if( tmp_iter != body_point_imprint_map.end() ) + { + CubitVector *tmp_vec = tmp_iter->second; + upper_iter = body_point_imprint_map.upper_bound( tmp_iter->first ); - for(; tmp_iter!=upper_iter; ++tmp_iter) - { - tmp_vec = tmp_iter->second; - if( close_pt.distance_between( *tmp_vec ) < tolerance ) - { - consider_point = false; - break; - } - } - } + for(; tmp_iter!=upper_iter; ++tmp_iter) + { + tmp_vec = tmp_iter->second; + if( close_pt.distance_between( *tmp_vec ) < tolerance ) + { + consider_point = false; + break; + } + } + } - if( consider_point ) - { - //imprint body of curve1 with vertex at this location - CubitVector *tmp_vec = new CubitVector( close_pt ); - body_point_imprint_map.insert( std::multimap<BodySM*, - CubitVector*>::value_type( first_curve_body, tmp_vec )); - imprint_body_order.append_unique( first_curve_body ); - } - } + if( consider_point ) + { + //imprint body of curve1 with vertex at this location + CubitVector *tmp_vec = new CubitVector( close_pt ); + body_point_imprint_map.insert( std::multimap<BodySM*, + CubitVector*>::value_type( first_curve_body, tmp_vec )); + imprint_body_order.append_unique( first_curve_body ); + } + } - other_curve->closest_point_trimmed( s_point1->coordinates(), close_pt ); + other_curve->closest_point_trimmed( s_point1->coordinates(), close_pt ); - if( close_pt.distance_between( s_point2->coordinates() ) > tolerance && - close_pt.distance_between( e_point2->coordinates() ) > tolerance ) - { - //are there any other points within tolerance to this point - //to be imprinted onto this body? - tmp_iter = body_point_imprint_map.find( other_curve_body ); - bool consider_point = true; - if( tmp_iter != body_point_imprint_map.end() ) - { - CubitVector *tmp_vec = tmp_iter->second; - upper_iter = body_point_imprint_map.upper_bound( tmp_iter->first ); + if( close_pt.distance_between( s_point2->coordinates() ) > tolerance && + close_pt.distance_between( e_point2->coordinates() ) > tolerance ) + { + //are there any other points within tolerance to this point + //to be imprinted onto this body? + tmp_iter = body_point_imprint_map.find( other_curve_body ); + bool consider_point = true; + if( tmp_iter != body_point_imprint_map.end() ) + { + CubitVector *tmp_vec = tmp_iter->second; + upper_iter = body_point_imprint_map.upper_bound( tmp_iter->first ); - for(; tmp_iter!=upper_iter; ++tmp_iter) - { - tmp_vec = tmp_iter->second; - if( close_pt.distance_between( *tmp_vec ) < tolerance ) - { - consider_point = false; - break; - } - } - } + for(; tmp_iter!=upper_iter; ++tmp_iter) + { + tmp_vec = tmp_iter->second; + if( close_pt.distance_between( *tmp_vec ) < tolerance ) + { + consider_point = false; + break; + } + } + } - if( consider_point ) - { - //imprint body of curve1 with vertex at this location - CubitVector *tmp_vec = new CubitVector( close_pt ); - body_point_imprint_map.insert( std::multimap<BodySM*, - CubitVector*>::value_type( other_curve_body, tmp_vec )); - imprint_body_order.append_unique( other_curve_body ); - } - } + if( consider_point ) + { + //imprint body of curve1 with vertex at this location + CubitVector *tmp_vec = new CubitVector( close_pt ); + body_point_imprint_map.insert( std::multimap<BodySM*, + CubitVector*>::value_type( other_curve_body, tmp_vec )); + imprint_body_order.append_unique( other_curve_body ); + } + } - other_curve->closest_point_trimmed( e_point1->coordinates(), close_pt ); + other_curve->closest_point_trimmed( e_point1->coordinates(), close_pt ); - if( close_pt.distance_between( s_point2->coordinates() ) > tolerance && - close_pt.distance_between( e_point2->coordinates() ) > tolerance ) - { - //Are there already any other points within tolerance to this point - //to be imprinted onto this body? - //If so, don't imprint this point. - tmp_iter = body_point_imprint_map.find( other_curve_body ); - bool consider_point = true; - if( tmp_iter != body_point_imprint_map.end() ) - { - CubitVector *tmp_vec = tmp_iter->second; - upper_iter = body_point_imprint_map.upper_bound( tmp_iter->first ); + if( close_pt.distance_between( s_point2->coordinates() ) > tolerance && + close_pt.distance_between( e_point2->coordinates() ) > tolerance ) + { + //Are there already any other points within tolerance to this point + //to be imprinted onto this body? + //If so, don't imprint this point. + tmp_iter = body_point_imprint_map.find( other_curve_body ); + bool consider_point = true; + if( tmp_iter != body_point_imprint_map.end() ) + { + CubitVector *tmp_vec = tmp_iter->second; + upper_iter = body_point_imprint_map.upper_bound( tmp_iter->first ); - for(; tmp_iter!=upper_iter; ++tmp_iter ) - { - tmp_vec = tmp_iter->second; - if( close_pt.distance_between( *tmp_vec ) < tolerance ) - { - consider_point = false; - break; - } - } - } + for(; tmp_iter!=upper_iter; ++tmp_iter ) + { + tmp_vec = tmp_iter->second; + if( close_pt.distance_between( *tmp_vec ) < tolerance ) + { + consider_point = false; + break; + } + } + } - if( consider_point ) - { - //imprint body of curve1 with vertex at this location - CubitVector *tmp_vec = new CubitVector( close_pt ); - body_point_imprint_map.insert( std::multimap<BodySM*, - CubitVector*>::value_type( other_curve_body, tmp_vec )); - imprint_body_order.append_unique( other_curve_body ); - } - } - } - } + if( consider_point ) + { + //imprint body of curve1 with vertex at this location + CubitVector *tmp_vec = new CubitVector( close_pt ); + body_point_imprint_map.insert( std::multimap<BodySM*, + CubitVector*>::value_type( other_curve_body, tmp_vec )); + imprint_body_order.append_unique( other_curve_body ); + } + } + } + } - //Imprint Vertices-onto-Body - imprint_body_order.reset(); - std::multimap<BodySM*, CubitVector*>::iterator point_iter, last_point_iter; - for( i=imprint_body_order.size(); i--; ) - { - BodySM *tmp_body_sm = imprint_body_order.get_and_step(); - DLIList<BodySM*> body_to_imprint; - body_to_imprint.append( tmp_body_sm ); + //Imprint Vertices-onto-Body + imprint_body_order.reset(); + std::multimap<BodySM*, CubitVector*>::iterator point_iter, last_point_iter; + for( i=imprint_body_order.size(); i--; ) + { + BodySM *tmp_body_sm = imprint_body_order.get_and_step(); + DLIList<BodySM*> body_to_imprint; + body_to_imprint.append( tmp_body_sm ); - DLIList<CubitVector*> points_to_imprint; + DLIList<CubitVector*> points_to_imprint; - point_iter = body_point_imprint_map.find( tmp_body_sm ); - last_point_iter = body_point_imprint_map.upper_bound( point_iter->first ); + point_iter = body_point_imprint_map.find( tmp_body_sm ); + last_point_iter = body_point_imprint_map.upper_bound( point_iter->first ); - for(; point_iter!=last_point_iter; ++point_iter ) - points_to_imprint.append( point_iter->second ); + for(; point_iter!=last_point_iter; ++point_iter ) + points_to_imprint.append( point_iter->second ); - DLIList<BodySM*> new_bodies; - CubitStatus status = imprint( body_to_imprint, points_to_imprint, new_bodies, false, new_tbs, att_tbs ); - if( new_bodies.size() ) - new_body_sms.append( new_bodies.get() ); + DLIList<BodySM*> new_bodies; + CubitStatus status = imprint( body_to_imprint, points_to_imprint, new_bodies, false, new_tbs, att_tbs ); + if( new_bodies.size() ) + new_body_sms.append( new_bodies.get() ); - for( j=points_to_imprint.size(); j--; ) - delete points_to_imprint.get_and_step(); - } + for( j=points_to_imprint.size(); j--; ) + delete points_to_imprint.get_and_step(); + } - //increment 4% - if( progress_tool ) - { - for( i=4; i--; ) - progress_tool->step(); - } + //increment 4% + if( progress_tool ) + { + for( i=4; i--; ) + progress_tool->step(); + } - return CUBIT_SUCCESS; -} + return CUBIT_SUCCESS; + } -CubitStatus AcisModifyEngine::imprint_overlapping_surfaces( DLIList<BodySM*> &body_sms, - DLIList<BodySM*> &new_body_sms, - ProgressTool *progress_tool) const -{ - //Find all mergeable surfaces between the bodies - DLIList< DLIList<Surface*>* > lists_of_mergeable_surfaces; - CubitStatus status = MergeTool::instance()-> - find_only_mergeable_surfaces( body_sms, lists_of_mergeable_surfaces ); + CubitStatus AcisModifyEngine::imprint_overlapping_surfaces( DLIList<BodySM*> &body_sms, + DLIList<BodySM*> &new_body_sms, + ProgressTool *progress_tool) const + { + //Find all mergeable surfaces between the bodies + DLIList< DLIList<Surface*>* > lists_of_mergeable_surfaces; + CubitStatus status = MergeTool::instance()-> + find_only_mergeable_surfaces( body_sms, lists_of_mergeable_surfaces ); - if( progress_tool ) - progress_tool->percent( 0.24 ); + if( progress_tool ) + progress_tool->percent( 0.24 ); - //Find all overlapping surfaces between the bodies - DLIList<Surface*> overlapping_surfaces1; - DLIList<Surface*> overlapping_surfaces2; - SurfaceOverlapTool::instance()-> - find_overlapping_surfaces( body_sms, overlapping_surfaces1, overlapping_surfaces2 ); + //Find all overlapping surfaces between the bodies + DLIList<Surface*> overlapping_surfaces1; + DLIList<Surface*> overlapping_surfaces2; + SurfaceOverlapTool::instance()-> + find_overlapping_surfaces( body_sms, overlapping_surfaces1, overlapping_surfaces2 ); - if( progress_tool ) - progress_tool->percent( 0.57 ); + if( progress_tool ) + progress_tool->percent( 0.57 ); - //We only want the non-mergeable overlapping surfaces. - //Remove mergable surfaces from overlapping pairs. - int i, j, k; - for( i=lists_of_mergeable_surfaces.size(); i--; ) - { - DLIList<Surface*> *tmp_surface_list = lists_of_mergeable_surfaces.get_and_step(); - for( j=tmp_surface_list->size(); j--; ) - { - Surface *tmp_surface = tmp_surface_list->get_and_step(); - while( overlapping_surfaces1.move_to( tmp_surface ) ) - overlapping_surfaces1.change_to(NULL); - while( overlapping_surfaces2.move_to( tmp_surface ) ) - overlapping_surfaces2.change_to(NULL); - } - delete tmp_surface_list; - } + //We only want the non-mergeable overlapping surfaces. + //Remove mergable surfaces from overlapping pairs. + int i, j, k; + for( i=lists_of_mergeable_surfaces.size(); i--; ) + { + DLIList<Surface*> *tmp_surface_list = lists_of_mergeable_surfaces.get_and_step(); + for( j=tmp_surface_list->size(); j--; ) + { + Surface *tmp_surface = tmp_surface_list->get_and_step(); + while( overlapping_surfaces1.move_to( tmp_surface ) ) + overlapping_surfaces1.change_to(NULL); + while( overlapping_surfaces2.move_to( tmp_surface ) ) + overlapping_surfaces2.change_to(NULL); + } + delete tmp_surface_list; + } - if( progress_tool ) - progress_tool->percent( 0.59 ); + if( progress_tool ) + progress_tool->percent( 0.59 ); - //Surface A might be mergeable/overlapping with B and just ever-so-slightly - //overlapping with C. Get rid of C or other overlapping surfaces - //that might be in the list. - overlapping_surfaces1.reset(); - overlapping_surfaces2.reset(); - for( i=overlapping_surfaces1.size(); i--; ) - { - Surface *tmp_surface1 = overlapping_surfaces1.get(); - Surface *tmp_surface2 = overlapping_surfaces2.get(); + //Surface A might be mergeable/overlapping with B and just ever-so-slightly + //overlapping with C. Get rid of C or other overlapping surfaces + //that might be in the list. + overlapping_surfaces1.reset(); + overlapping_surfaces2.reset(); + for( i=overlapping_surfaces1.size(); i--; ) + { + Surface *tmp_surface1 = overlapping_surfaces1.get(); + Surface *tmp_surface2 = overlapping_surfaces2.get(); - if( tmp_surface1 != NULL ) - { - if( tmp_surface2 == NULL ) - overlapping_surfaces1.change_to(NULL); - } - else - { - if( tmp_surface2 != NULL ) - overlapping_surfaces2.change_to(NULL); - } + if( tmp_surface1 != NULL ) + { + if( tmp_surface2 == NULL ) + overlapping_surfaces1.change_to(NULL); + } + else + { + if( tmp_surface2 != NULL ) + overlapping_surfaces2.change_to(NULL); + } - overlapping_surfaces1.step(); - overlapping_surfaces2.step(); - } + overlapping_surfaces1.step(); + overlapping_surfaces2.step(); + } - overlapping_surfaces1.remove_all_with_value(NULL); - overlapping_surfaces2.remove_all_with_value(NULL); + overlapping_surfaces1.remove_all_with_value(NULL); + overlapping_surfaces2.remove_all_with_value(NULL); - if ( overlapping_surfaces1.size() != overlapping_surfaces2.size() ) - { - PRINT_ERROR("Number of overlapping pairs of surfaces is wrong.\n"); - return CUBIT_FAILURE; - } + if ( overlapping_surfaces1.size() != overlapping_surfaces2.size() ) + { + PRINT_ERROR("Number of overlapping pairs of surfaces is wrong.\n"); + return CUBIT_FAILURE; + } - if( progress_tool ) - progress_tool->percent( 0.62 ); + if( progress_tool ) + progress_tool->percent( 0.62 ); - // Make sure we are working with ACIS surfaces and not - // something at some higher level. - DLIList<Surface*> surfs_to_append1; - DLIList<Surface*> surfs_to_append2; - for(j=overlapping_surfaces1.size(); j--;) - { - Surface *s1 = overlapping_surfaces1.get(); - Surface *s2 = overlapping_surfaces2.get(); + // Make sure we are working with ACIS surfaces and not + // something at some higher level. + DLIList<Surface*> surfs_to_append1; + DLIList<Surface*> surfs_to_append2; + for(j=overlapping_surfaces1.size(); j--;) + { + Surface *s1 = overlapping_surfaces1.get(); + Surface *s2 = overlapping_surfaces2.get(); - GeometryQueryEngine *gqe1 = s1->get_geometry_query_engine(); - GeometryQueryEngine *gqe2 = s2->get_geometry_query_engine(); + GeometryQueryEngine *gqe1 = s1->get_geometry_query_engine(); + GeometryQueryEngine *gqe2 = s2->get_geometry_query_engine(); - DLIList<TopologyBridge*> tbs1, tbs2; - gqe1->get_underlying_surfaces(s1, tbs1); - gqe2->get_underlying_surfaces(s2, tbs2); - int num_surfs1 = tbs1.size(); - int num_surfs2 = tbs2.size(); - if(num_surfs1 > 0 || num_surfs2 > 0) - { - if(num_surfs1 == 0) - { - for(k=tbs2.size(); k--;) - { - surfs_to_append1.append(s1); - surfs_to_append2.append(dynamic_cast<Surface*>(tbs2.get_and_step())); - } - } - else if(num_surfs2 == 0) - { - for(k=tbs1.size(); k--;) - { - surfs_to_append2.append(s2); - surfs_to_append1.append(dynamic_cast<Surface*>(tbs1.get_and_step())); - } - } - else - { - for(k=tbs1.size(); k--;) - { - int u; - Surface *tmp1 = dynamic_cast<Surface*>(tbs1.get_and_step()); - for(u=num_surfs2; u--;) - { - surfs_to_append1.append(tmp1); - surfs_to_append2.append(dynamic_cast<Surface*>(tbs2.get_and_step())); - } - } - } - overlapping_surfaces1.change_to(NULL); - overlapping_surfaces2.change_to(NULL); - } + DLIList<TopologyBridge*> tbs1, tbs2; + gqe1->get_underlying_surfaces(s1, tbs1); + gqe2->get_underlying_surfaces(s2, tbs2); + int num_surfs1 = tbs1.size(); + int num_surfs2 = tbs2.size(); + if(num_surfs1 > 0 || num_surfs2 > 0) + { + if(num_surfs1 == 0) + { + for(k=tbs2.size(); k--;) + { + surfs_to_append1.append(s1); + surfs_to_append2.append(dynamic_cast<Surface*>(tbs2.get_and_step())); + } + } + else if(num_surfs2 == 0) + { + for(k=tbs1.size(); k--;) + { + surfs_to_append2.append(s2); + surfs_to_append1.append(dynamic_cast<Surface*>(tbs1.get_and_step())); + } + } + else + { + for(k=tbs1.size(); k--;) + { + int u; + Surface *tmp1 = dynamic_cast<Surface*>(tbs1.get_and_step()); + for(u=num_surfs2; u--;) + { + surfs_to_append1.append(tmp1); + surfs_to_append2.append(dynamic_cast<Surface*>(tbs2.get_and_step())); + } + } + } + overlapping_surfaces1.change_to(NULL); + overlapping_surfaces2.change_to(NULL); + } - overlapping_surfaces1.step(); - overlapping_surfaces2.step(); - } - overlapping_surfaces1.remove_all_with_value(NULL); - overlapping_surfaces2.remove_all_with_value(NULL); - for(k=surfs_to_append1.size(); k--;) - { - overlapping_surfaces1.append(surfs_to_append1.get_and_step()); - overlapping_surfaces2.append(surfs_to_append2.get_and_step()); - } + overlapping_surfaces1.step(); + overlapping_surfaces2.step(); + } + overlapping_surfaces1.remove_all_with_value(NULL); + overlapping_surfaces2.remove_all_with_value(NULL); + for(k=surfs_to_append1.size(); k--;) + { + overlapping_surfaces1.append(surfs_to_append1.get_and_step()); + overlapping_surfaces2.append(surfs_to_append2.get_and_step()); + } - //Now that we have non-mergeable overlapping surface pairs, determine which - //curves of surface1 to imprint onto surface2 and vice versa. - //We eliminate curves between the 2 surfaces that overlap. - DLIList<Surface*> surface_ordering_list; - std::multimap<Surface*, Curve*> surface_curve_imprint_map; - overlapping_surfaces1.reset(); - overlapping_surfaces2.reset(); + //Now that we have non-mergeable overlapping surface pairs, determine which + //curves of surface1 to imprint onto surface2 and vice versa. + //We eliminate curves between the 2 surfaces that overlap. + DLIList<Surface*> surface_ordering_list; + std::multimap<Surface*, Curve*> surface_curve_imprint_map; + overlapping_surfaces1.reset(); + overlapping_surfaces2.reset(); - double tolerance = GeometryQueryTool::get_geometry_factor()*GEOMETRY_RESABS; + double tolerance = GeometryQueryTool::get_geometry_factor()*GEOMETRY_RESABS; - for( i=overlapping_surfaces1.size(); i--; ) - { - Surface *overlapping_surface1 = overlapping_surfaces1.get_and_step(); - Surface *overlapping_surface2 = overlapping_surfaces2.get_and_step(); + for( i=overlapping_surfaces1.size(); i--; ) + { + Surface *overlapping_surface1 = overlapping_surfaces1.get_and_step(); + Surface *overlapping_surface2 = overlapping_surfaces2.get_and_step(); - //get all the curves of the surfaces - DLIList<Curve*> curves2, curves1; - overlapping_surface2->curves( curves2 ); - overlapping_surface1->curves( curves1 ); + //get all the curves of the surfaces + DLIList<Curve*> curves2, curves1; + overlapping_surface2->curves( curves2 ); + overlapping_surface1->curves( curves1 ); - // Make sure we are working with ACIS curves - // and not something at some higher level. - DLIList<Curve*> curves_to_remove; - DLIList<Curve*> curves_to_append; - curves2.reset(); - for(j=curves2.size(); j--;) - { - Curve *c = curves2.get_and_step(); - GeometryQueryEngine *gqe = c->get_geometry_query_engine(); - DLIList<TopologyBridge*> tbs; - gqe->get_underlying_curves(c, tbs); - if(tbs.size() > 0) - { - curves_to_remove.append(c); - for(k=tbs.size(); k--;) - curves_to_append.append(dynamic_cast<Curve*>(tbs.get_and_step())); - } - } - curves2 -= curves_to_remove; - curves2 += curves_to_append; - curves_to_remove.clean_out(); - curves_to_append.clean_out(); - curves1.reset(); - for(j=curves1.size(); j--;) - { - Curve *c = curves1.get_and_step(); - GeometryQueryEngine *gqe = c->get_geometry_query_engine(); - DLIList<TopologyBridge*> tbs; - gqe->get_underlying_curves(c, tbs); - if(tbs.size() > 0) - { - curves_to_remove.append(c); - for(k=tbs.size(); k--;) - curves_to_append.append(dynamic_cast<Curve*>(tbs.get_and_step())); - } - } - curves1 -= curves_to_remove; - curves1 += curves_to_append; + // Make sure we are working with ACIS curves + // and not something at some higher level. + DLIList<Curve*> curves_to_remove; + DLIList<Curve*> curves_to_append; + curves2.reset(); + for(j=curves2.size(); j--;) + { + Curve *c = curves2.get_and_step(); + GeometryQueryEngine *gqe = c->get_geometry_query_engine(); + DLIList<TopologyBridge*> tbs; + gqe->get_underlying_curves(c, tbs); + if(tbs.size() > 0) + { + curves_to_remove.append(c); + for(k=tbs.size(); k--;) + curves_to_append.append(dynamic_cast<Curve*>(tbs.get_and_step())); + } + } + curves2 -= curves_to_remove; + curves2 += curves_to_append; + curves_to_remove.clean_out(); + curves_to_append.clean_out(); + curves1.reset(); + for(j=curves1.size(); j--;) + { + Curve *c = curves1.get_and_step(); + GeometryQueryEngine *gqe = c->get_geometry_query_engine(); + DLIList<TopologyBridge*> tbs; + gqe->get_underlying_curves(c, tbs); + if(tbs.size() > 0) + { + curves_to_remove.append(c); + for(k=tbs.size(); k--;) + curves_to_append.append(dynamic_cast<Curve*>(tbs.get_and_step())); + } + } + curves1 -= curves_to_remove; + curves1 += curves_to_append; - //Get bounding box for later - CubitBox bb_surf = overlapping_surface1->bounding_box(); + //Get bounding box for later + CubitBox bb_surf = overlapping_surface1->bounding_box(); - //remove overlapping curves between the 2 surfaces - for( j=curves2.size(); j--; ) - { - Curve *tmp_curve = curves2.get(); + //remove overlapping curves between the 2 surfaces + for( j=curves2.size(); j--; ) + { + Curve *tmp_curve = curves2.get(); - int k; - bool overlap = false; - for( k=curves1.size(); k--; ) - { - if( curves1.get() ) - { - Curve *tmp_curve_2 = curves1.get(); + int k; + bool overlap = false; + for( k=curves1.size(); k--; ) + { + if( curves1.get() ) + { + Curve *tmp_curve_2 = curves1.get(); - if( SurfaceOverlapTool::instance()-> - check_overlap( tmp_curve, tmp_curve_2, NULL)) - { - //They should be about spatially equal too! -// CubitSense dummy_sense; -// if( MergeTool::instance()->about_spatially_equal( curves1.get(), curves2.get(), -// dummy_sense, GeometryQueryTool::get_geometry_factor() ) ) -// { - curves1.change_to(NULL); - curves2.change_to(NULL); - overlap = true; - break; -// } - } - } - curves1.step(); - } - if( overlap ) - { - curves2.step(); - continue; - } + if( SurfaceOverlapTool::instance()-> + check_overlap( tmp_curve, tmp_curve_2, NULL)) + { + //They should be about spatially equal too! + // CubitSense dummy_sense; + // if( MergeTool::instance()->about_spatially_equal( curves1.get(), curves2.get(), + // dummy_sense, GeometryQueryTool::get_geometry_factor() ) ) + // { + curves1.change_to(NULL); + curves2.change_to(NULL); + overlap = true; + break; + // } + } + } + curves1.step(); + } + if( overlap ) + { + curves2.step(); + continue; + } - double distance; - CubitVector v1, v2; + double distance; + CubitVector v1, v2; - //bounding box check between curve and surface - CubitBox bb_curve = tmp_curve->bounding_box(); - if( bb_surf.overlap( tolerance, bb_curve ) ) - { - //measure distance between curve and surface - overlapping_surface1->get_geometry_query_engine()->entity_entity_distance( - overlapping_surface1, tmp_curve, v1, v2, distance ); + //bounding box check between curve and surface + CubitBox bb_curve = tmp_curve->bounding_box(); + if( bb_surf.overlap( tolerance, bb_curve ) ) + { + //measure distance between curve and surface + overlapping_surface1->get_geometry_query_engine()->entity_entity_distance( + overlapping_surface1, tmp_curve, v1, v2, distance ); - if( distance < tolerance ) - { - //check multimap to make sure that this curve has not already - //been added (from another surface that shares it) - //or that is overlaps another curve in the multimap - std::pair< std::multimap<Surface*, Curve* >::iterator, - std::multimap<Surface*, Curve* >::iterator > surface_curve_pair; - surface_curve_pair = surface_curve_imprint_map.equal_range( overlapping_surface1 ); + if( distance < tolerance ) + { + //check multimap to make sure that this curve has not already + //been added (from another surface that shares it) + //or that is overlaps another curve in the multimap + std::pair< std::multimap<Surface*, Curve* >::iterator, + std::multimap<Surface*, Curve* >::iterator > surface_curve_pair; + surface_curve_pair = surface_curve_imprint_map.equal_range( overlapping_surface1 ); - std::multimap<Surface*, Curve*>::iterator iter = surface_curve_pair.first; - std::multimap<Surface*, Curve*>::iterator end = surface_curve_pair.second; - bool match_found = false; - while( iter != end ) - { - if( iter->second == tmp_curve ) - { - match_found = true; - break; - } + std::multimap<Surface*, Curve*>::iterator iter = surface_curve_pair.first; + std::multimap<Surface*, Curve*>::iterator end = surface_curve_pair.second; + bool match_found = false; + while( iter != end ) + { + if( iter->second == tmp_curve ) + { + match_found = true; + break; + } - if( SurfaceOverlapTool::instance()->check_overlap( iter->second, tmp_curve, NULL ) ) - { - match_found = true; - break; - } + if( SurfaceOverlapTool::instance()->check_overlap( iter->second, tmp_curve, NULL ) ) + { + match_found = true; + break; + } - iter++; - } + iter++; + } - if( match_found == false ) - { - surface_curve_imprint_map.insert( std::multimap<Surface*, Curve*>::value_type( - overlapping_surface1, tmp_curve )); - surface_ordering_list.append_unique( overlapping_surface1 ); - } - } - } - curves2.step(); - } + if( match_found == false ) + { + surface_curve_imprint_map.insert( std::multimap<Surface*, Curve*>::value_type( + overlapping_surface1, tmp_curve )); + surface_ordering_list.append_unique( overlapping_surface1 ); + } + } + } + curves2.step(); + } - bb_surf = overlapping_surface2->bounding_box(); - curves1.remove_all_with_value( NULL ); - curves2.remove_all_with_value( NULL ); - //insert body and copied curves into list - for( j=curves1.size(); j--; ) - { - Curve *tmp_curve = curves1.get(); + bb_surf = overlapping_surface2->bounding_box(); + curves1.remove_all_with_value( NULL ); + curves2.remove_all_with_value( NULL ); + //insert body and copied curves into list + for( j=curves1.size(); j--; ) + { + Curve *tmp_curve = curves1.get(); - double distance; - CubitVector v1, v2; - CubitBox bb_curve = tmp_curve->bounding_box(); - //bounding box check between curve and surface - if( bb_surf.overlap( tolerance, bb_curve ) ) - { - //measure distance between curve and surface - overlapping_surface2->get_geometry_query_engine()->entity_entity_distance( - overlapping_surface2, tmp_curve, v1, v2, distance ); + double distance; + CubitVector v1, v2; + CubitBox bb_curve = tmp_curve->bounding_box(); + //bounding box check between curve and surface + if( bb_surf.overlap( tolerance, bb_curve ) ) + { + //measure distance between curve and surface + overlapping_surface2->get_geometry_query_engine()->entity_entity_distance( + overlapping_surface2, tmp_curve, v1, v2, distance ); - if( distance < tolerance ) - { - //check multimap to make sure that this curve has not already - //been added (from another surface that shares it) - //or that is overlaps another curve in the multimap - std::pair< std::multimap<Surface*, Curve* >::iterator, - std::multimap<Surface*, Curve* >::iterator > surface_curve_pair; - surface_curve_pair = surface_curve_imprint_map.equal_range( overlapping_surface2 ); + if( distance < tolerance ) + { + //check multimap to make sure that this curve has not already + //been added (from another surface that shares it) + //or that is overlaps another curve in the multimap + std::pair< std::multimap<Surface*, Curve* >::iterator, + std::multimap<Surface*, Curve* >::iterator > surface_curve_pair; + surface_curve_pair = surface_curve_imprint_map.equal_range( overlapping_surface2 ); - std::multimap<Surface*, Curve*>::iterator end = surface_curve_pair.second; - std::multimap<Surface*, Curve*>::iterator iter = surface_curve_pair.first; - bool match_found = false; - while( iter != end ) - { - if( iter->second == tmp_curve ) - { - match_found = true; - break; - } + std::multimap<Surface*, Curve*>::iterator end = surface_curve_pair.second; + std::multimap<Surface*, Curve*>::iterator iter = surface_curve_pair.first; + bool match_found = false; + while( iter != end ) + { + if( iter->second == tmp_curve ) + { + match_found = true; + break; + } - if( SurfaceOverlapTool::instance()->check_overlap( iter->second, tmp_curve, NULL ) ) - { - match_found = true; - break; - } + if( SurfaceOverlapTool::instance()->check_overlap( iter->second, tmp_curve, NULL ) ) + { + match_found = true; + break; + } - iter++; - } + iter++; + } - if( match_found == false ) - { - surface_curve_imprint_map.insert( std::multimap<Surface*, Curve*>::value_type( - overlapping_surface2, tmp_curve )); - surface_ordering_list.append_unique( overlapping_surface2 ); - } + if( match_found == false ) + { + surface_curve_imprint_map.insert( std::multimap<Surface*, Curve*>::value_type( + overlapping_surface2, tmp_curve )); + surface_ordering_list.append_unique( overlapping_surface2 ); + } - } - } - curves1.step(); - } - } + } + } + curves1.step(); + } + } - if( progress_tool ) - progress_tool->percent( 0.64 ); + if( progress_tool ) + progress_tool->percent( 0.64 ); - //We cannot use the original curves for imprinting....they'll be - //getting modified. Make copies of them here and build a new multimap - std::multimap<Surface*, Curve*>::iterator surf_curve_iter, surf_curve_last; - std::multimap<Surface*, Curve*> final_surface_curve_imprint_map; - for( surf_curve_iter = surface_curve_imprint_map.begin(); - surf_curve_iter != surface_curve_imprint_map.end(); ) - { - Surface *tmp_surf = surf_curve_iter->first; - surf_curve_last = surface_curve_imprint_map.upper_bound( tmp_surf ); + //We cannot use the original curves for imprinting....they'll be + //getting modified. Make copies of them here and build a new multimap + std::multimap<Surface*, Curve*>::iterator surf_curve_iter, surf_curve_last; + std::multimap<Surface*, Curve*> final_surface_curve_imprint_map; + for( surf_curve_iter = surface_curve_imprint_map.begin(); + surf_curve_iter != surface_curve_imprint_map.end(); ) + { + Surface *tmp_surf = surf_curve_iter->first; + surf_curve_last = surface_curve_imprint_map.upper_bound( tmp_surf ); - for(; surf_curve_iter!=surf_curve_last; ++surf_curve_iter ) - { - Curve *copied_curve = make_Curve( surf_curve_iter->second ); - final_surface_curve_imprint_map.insert( std::multimap<Surface*, - Curve*>::value_type( tmp_surf, copied_curve )); - } - } + for(; surf_curve_iter!=surf_curve_last; ++surf_curve_iter ) + { + Curve *copied_curve = make_Curve( surf_curve_iter->second ); + final_surface_curve_imprint_map.insert( std::multimap<Surface*, + Curve*>::value_type( tmp_surf, copied_curve )); + } + } - if( progress_tool ) - progress_tool->percent( 0.67 ); + if( progress_tool ) + progress_tool->percent( 0.67 ); - double percentage_per_surface = 0; - double delta = 0; + double percentage_per_surface = 0; + double delta = 0; - if( progress_tool ) - { - if( surface_ordering_list.size() ) - percentage_per_surface = 0.16 / surface_ordering_list.size(); - else - progress_tool->percent( 0.83 ); + if( progress_tool ) + { + if( surface_ordering_list.size() ) + percentage_per_surface = 0.16 / surface_ordering_list.size(); + else + progress_tool->percent( 0.83 ); - } + } - //Now iterate of each surface that will be imprinted with curves. - surface_ordering_list.reset(); - bool print_errors = false; - for( i=surface_ordering_list.size(); i--; ) - { - if( progress_tool ) - { - delta += percentage_per_surface; - progress_tool->percent( 0.67 + delta ); - } + //Now iterate of each surface that will be imprinted with curves. + surface_ordering_list.reset(); + bool print_errors = false; + for( i=surface_ordering_list.size(); i--; ) + { + if( progress_tool ) + { + delta += percentage_per_surface; + progress_tool->percent( 0.67 + delta ); + } - Surface *tmp_surface = surface_ordering_list.get_and_step(); + Surface *tmp_surface = surface_ordering_list.get_and_step(); - surf_curve_iter = final_surface_curve_imprint_map.find( tmp_surface ); - tmp_surface = surf_curve_iter->first; + surf_curve_iter = final_surface_curve_imprint_map.find( tmp_surface ); + tmp_surface = surf_curve_iter->first; - DLIList<Surface*> surface_list; - surface_list.append( tmp_surface ); + DLIList<Surface*> surface_list; + surface_list.append( tmp_surface ); - DLIList<Curve*> curves_to_imprint; - surf_curve_last = final_surface_curve_imprint_map.upper_bound( surf_curve_iter->first ); - //For each curve that might be imprinted on the surface... + DLIList<Curve*> curves_to_imprint; + surf_curve_last = final_surface_curve_imprint_map.upper_bound( surf_curve_iter->first ); + //For each curve that might be imprinted on the surface... - for(; surf_curve_iter!=surf_curve_last; ++surf_curve_iter ) - { - DLIList<Curve*> tmp_curve_list1, tmp_curve_list2; - Curve *original_curve = surf_curve_iter->second; - tmp_curve_list1.append( original_curve ); + for(; surf_curve_iter!=surf_curve_last; ++surf_curve_iter ) + { + DLIList<Curve*> tmp_curve_list1, tmp_curve_list2; + Curve *original_curve = surf_curve_iter->second; + tmp_curve_list1.append( original_curve ); - //project - CubitStatus projected = project_edges( surface_list, tmp_curve_list1, tmp_curve_list2, print_errors ); + //project + CubitStatus projected = project_edges( surface_list, tmp_curve_list1, tmp_curve_list2, print_errors ); - if( projected == CUBIT_FAILURE ) - { - AcisQueryEngine::instance()->delete_solid_model_entities( original_curve ); - continue; - } + if( projected == CUBIT_FAILURE ) + { + AcisQueryEngine::instance()->delete_solid_model_entities( original_curve ); + continue; + } - Curve *projected_curve = tmp_curve_list2.get(); + Curve *projected_curve = tmp_curve_list2.get(); - //if midpoint of projected is far from original curve, continue - CubitVector original_curve_mid_point = original_curve->center_point(); - if( original_curve_mid_point.distance_between( projected_curve->center_point() ) > tolerance ) - { - AcisQueryEngine::instance()->delete_solid_model_entities( original_curve ); - AcisQueryEngine::instance()->delete_solid_model_entities( projected_curve ); - continue; - } + //if midpoint of projected is far from original curve, continue + CubitVector original_curve_mid_point = original_curve->center_point(); + if( original_curve_mid_point.distance_between( projected_curve->center_point() ) > tolerance ) + { + AcisQueryEngine::instance()->delete_solid_model_entities( original_curve ); + AcisQueryEngine::instance()->delete_solid_model_entities( projected_curve ); + continue; + } - //now intersect - tmp_curve_list1.clean_out(); - CubitStatus intersected = curve_surface_intersection( tmp_surface, projected_curve, tmp_curve_list1 ); + //now intersect + tmp_curve_list1.clean_out(); + CubitStatus intersected = curve_surface_intersection( tmp_surface, projected_curve, tmp_curve_list1 ); - //delete the curves - AcisQueryEngine::instance()->delete_solid_model_entities( original_curve ); - AcisQueryEngine::instance()->delete_solid_model_entities( projected_curve ); + //delete the curves + AcisQueryEngine::instance()->delete_solid_model_entities( original_curve ); + AcisQueryEngine::instance()->delete_solid_model_entities( projected_curve ); - if( intersected == CUBIT_FAILURE) - continue; + if( intersected == CUBIT_FAILURE) + continue; - curves_to_imprint += tmp_curve_list1; - } + curves_to_imprint += tmp_curve_list1; + } - //filter out small curves - int j; - for( j=curves_to_imprint.size(); j--; ) - { - Curve *tmp_curve = curves_to_imprint.get(); - double curve_length = tmp_curve->measure(); - if( curve_length < tolerance ) - { - curves_to_imprint.change_to( NULL ); - AcisQueryEngine::instance()->delete_solid_model_entities( tmp_curve ); - } - curves_to_imprint.step(); - } - curves_to_imprint.remove_all_with_value( NULL ); + //filter out small curves + int j; + for( j=curves_to_imprint.size(); j--; ) + { + Curve *tmp_curve = curves_to_imprint.get(); + double curve_length = tmp_curve->measure(); + if( curve_length < tolerance ) + { + curves_to_imprint.change_to( NULL ); + AcisQueryEngine::instance()->delete_solid_model_entities( tmp_curve ); + } + curves_to_imprint.step(); + } + curves_to_imprint.remove_all_with_value( NULL ); - BodySM *new_body_sm = NULL; + BodySM *new_body_sm = NULL; - //Now imprint the curves onto the surface - CubitStatus status; - if( curves_to_imprint.size() ) - { -/* - GfxDebug::clear(); - AcisDrawTool::instance()->draw_surface( tmp_surface, 4, true); - GfxDebug::mouse_xforms(); - int kkk; - PRINT_INFO("number of curve = %d\n", curves_to_imprint.size() ); - for( kkk=curves_to_imprint.size(); kkk--; ) - { - AcisDrawTool::instance()->draw_curve( curves_to_imprint.get_and_step(), kkk+5 ); - GfxDebug::mouse_xforms(); - } -*/ - status = embed_curves_into_surface( tmp_surface, curves_to_imprint, new_body_sm ); - } + //Now imprint the curves onto the surface + CubitStatus status; + if( curves_to_imprint.size() ) + { + /* + GfxDebug::clear(); + AcisDrawTool::instance()->draw_surface( tmp_surface, 4, true); + GfxDebug::mouse_xforms(); + int kkk; + PRINT_INFO("number of curve = %d\n", curves_to_imprint.size() ); + for( kkk=curves_to_imprint.size(); kkk--; ) + { + AcisDrawTool::instance()->draw_curve( curves_to_imprint.get_and_step(), kkk+5 ); + GfxDebug::mouse_xforms(); + } + */ + status = embed_curves_into_surface( tmp_surface, curves_to_imprint, new_body_sm ); + } - if( new_body_sm == NULL ) - continue; - new_body_sms.append_unique( new_body_sm ); + if( new_body_sm == NULL ) + continue; + new_body_sms.append_unique( new_body_sm ); - //Delete all the curves that were imprinted. We're responsible for deleting them. - for( j=curves_to_imprint.size(); j--; ) - AcisQueryEngine::instance()->delete_solid_model_entities( curves_to_imprint.get_and_step() ); + //Delete all the curves that were imprinted. We're responsible for deleting them. + for( j=curves_to_imprint.size(); j--; ) + AcisQueryEngine::instance()->delete_solid_model_entities( curves_to_imprint.get_and_step() ); - } - return CUBIT_SUCCESS; -} + } + return CUBIT_SUCCESS; + } -//WARNING!!! Only use this function if you KNOW that the curves you want -//to imprint line on the surface.....otherwise you'll get problems. -//api_embed_wire_in_faces returns unexpected results if the curve -//does not lie on the surface. -CubitStatus AcisModifyEngine::embed_curves_into_surface( Surface *surface, + //WARNING!!! Only use this function if you KNOW that the curves you want + //to imprint line on the surface.....otherwise you'll get problems. + //api_embed_wire_in_faces returns unexpected results if the curve + //does not lie on the surface. + CubitStatus AcisModifyEngine::embed_curves_into_surface( Surface *surface, DLIList<Curve*> &curves_to_imprint, BodySM *&new_body ) const -{ - if( curves_to_imprint.size() == 0 ) - return CUBIT_FAILURE; + { + if( curves_to_imprint.size() == 0 ) + return CUBIT_FAILURE; - BODY *copied_BODY = NULL; - DLIList<FACE*> imprint_FACE_list; - DLIList<SurfaceACIS*> acis_surfs; - SurfaceACIS *tmp_acis_surf = CAST_TO( surface, SurfaceACIS ); + BODY *copied_BODY = NULL; + DLIList<FACE*> imprint_FACE_list; + DLIList<SurfaceACIS*> acis_surfs; + SurfaceACIS *tmp_acis_surf = CAST_TO( surface, SurfaceACIS ); - if( tmp_acis_surf == NULL ) - return CUBIT_FAILURE; + if( tmp_acis_surf == NULL ) + return CUBIT_FAILURE; - FACE *FACE_ptr = tmp_acis_surf->get_FACE_ptr(); - BODY *BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_ptr ); - BodySM *old_body_sm = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( FACE_ptr ); + FACE *FACE_ptr = tmp_acis_surf->get_FACE_ptr(); + BODY *BODY_ptr = AcisQueryEngine::instance()->get_BODY_of_ENTITY( FACE_ptr ); + BodySM *old_body_sm = AcisQueryEngine::instance()->get_body_sm_of_ENTITY( FACE_ptr ); - acis_surfs.append( tmp_acis_surf ); - if( get_copied_FACES_of_body( acis_surfs, imprint_FACE_list, copied_BODY ) == CUBIT_FAILURE ) - return CUBIT_FAILURE; + acis_surfs.append( tmp_acis_surf ); + if( get_copied_FACES_of_body( acis_surfs, imprint_FACE_list, copied_BODY ) == CUBIT_FAILURE ) + return CUBIT_FAILURE; - if( imprint_FACE_list.size() == 0 ) - return CUBIT_FAILURE; + if( imprint_FACE_list.size() == 0 ) + return CUBIT_FAILURE; - double tolerance = GeometryQueryTool::get_geometry_factor()*GEOMETRY_RESABS; - if( tolerance < 0.001 ) - tolerance = 0.001; + double tolerance = GeometryQueryTool::get_geometry_factor()*GEOMETRY_RESABS; + if( tolerance < 0.001 ) + tolerance = 0.001; - int i; - EDGE *EDGEs[ 1 ]; - ENTITY_LIST wire_BODYs; + int i; + EDGE *EDGEs[ 1 ]; + ENTITY_LIST wire_BODYs; #ifdef BOYD16 - outcome tmp_result; + outcome tmp_result; #endif - for( i=0; i<curves_to_imprint.size(); i++ ) - { - //copy - EDGE *EDGE_ptr = AcisQueryEngine::get_EDGE( curves_to_imprint.get_and_step() ); + for( i=0; i<curves_to_imprint.size(); i++ ) + { + //copy + EDGE *EDGE_ptr = AcisQueryEngine::get_EDGE( curves_to_imprint.get_and_step() ); - EDGE *copied_EDGE_ptr = NULL; - outcome tmp_result = api_edge( EDGE_ptr, copied_EDGE_ptr ); - ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr, - CUBIT_TRUE ); - EDGEs[0] = copied_EDGE_ptr; - BODY *tmp_BODY = NULL; - tmp_result = api_make_ewire( 1, EDGEs, tmp_BODY ); - wire_BODYs.add( (ENTITY*)tmp_BODY ); - } + EDGE *copied_EDGE_ptr = NULL; + outcome tmp_result = api_edge( EDGE_ptr, copied_EDGE_ptr ); + ATTRIB_CUBIT_OWNER::remove_cubit_owner( (ENTITY *)copied_EDGE_ptr, + CUBIT_TRUE ); + EDGEs[0] = copied_EDGE_ptr; + BODY *tmp_BODY = NULL; + tmp_result = api_make_ewire( 1, EDGEs, tmp_BODY ); + wire_BODYs.add( (ENTITY*)tmp_BODY ); + } - int number_wire_bodies = wire_BODYs.count(); + int number_wire_bodies = wire_BODYs.count(); - if( number_wire_bodies == 0 ) - return CUBIT_FAILURE; + if( number_wire_bodies == 0 ) + return CUBIT_FAILURE; - BODY *wire_BODY_ptr = (BODY*)wire_BODYs[0]; + BODY *wire_BODY_ptr = (BODY*)wire_BODYs[0]; - ENTITY_LIST *face_list = new ENTITY_LIST; - FACE* imprint_FACE = imprint_FACE_list.get(); - face_list->add( (ENTITY*)imprint_FACE ); + ENTITY_LIST *face_list = new ENTITY_LIST; + FACE* imprint_FACE = imprint_FACE_list.get(); + face_list->add( (ENTITY*)imprint_FACE ); - ENTITY_LIST temp_face_list; - api_get_faces( copied_BODY, temp_face_list ); - int number_faces_before = temp_face_list.count(); + ENTITY_LIST temp_face_list; + api_get_faces( copied_BODY, temp_face_list ); + int number_faces_before = temp_face_list.count(); - API_BEGIN - result = api_embed_wire_in_faces( wire_BODY_ptr, copied_BODY, face_list, tolerance ); - API_END + API_BEGIN + result = api_embed_wire_in_faces( wire_BODY_ptr, copied_BODY, face_list, tolerance ); + API_END - for(i=1; i<number_wire_bodies; i++ ) - { + for(i=1; i<number_wire_bodies; i++ ) + { #ifdef BOYD16 - bool embedded = false; + bool embedded = false; #endif - wire_BODY_ptr = (BODY*)wire_BODYs[i]; + wire_BODY_ptr = (BODY*)wire_BODYs[i]; - //get all the faces on the body - ENTITY_LIST FACEs; - api_get_faces( copied_BODY, FACEs ); + //get all the faces on the body + ENTITY_LIST FACEs; + api_get_faces( copied_BODY, FACEs ); - //if number of faces on body did not change, no face got split, and we can - //split the same FACE again. - if( number_faces_before == FACEs.count() ) - { - result = api_embed_wire_in_faces( wire_BODY_ptr, copied_BODY, face_list, tolerance ); - continue; - } + //if number of faces on body did not change, no face got split, and we can + //split the same FACE again. + if( number_faces_before == FACEs.count() ) + { + result = api_embed_wire_in_faces( wire_BODY_ptr, copied_BODY, face_list, tolerance ); + continue; + } - //need to determine which face to embed curve onto - //may be able to remove this later on and just embed into body - //just embed the remining wires into the body - //result = api_embed_wire_in_faces( wire_BODY_ptr, copied_BODY, NULL, tolerance ); - //if( !result.ok() ) - // AcisQueryEngine::instance()->ACIS_API_error (result); + //need to determine which face to embed curve onto + //may be able to remove this later on and just embed into body + //just embed the remining wires into the body + //result = api_embed_wire_in_faces( wire_BODY_ptr, copied_BODY, NULL, tolerance ); + //if( !result.ok() ) + // AcisQueryEngine::instance()->ACIS_API_error (result); - //get midpoint of curve to embed - ENTITY_LIST wire_edge_list; - api_get_edges( wire_BODY_ptr, wire_edge_list ); - EDGE *wire_edge = (EDGE*)wire_edge_list[0]; - SPAposition mid_point = wire_edge->mid_pos(); + //get midpoint of curve to embed + ENTITY_LIST wire_edge_list; + api_get_edges( wire_BODY_ptr, wire_edge_list ); + EDGE *wire_edge = (EDGE*)wire_edge_list[0]; + SPAposition mid_point = wire_edge->mid_pos(); - //get position at fraction 0.79 along curve + //get position at fraction 0.79 along curve #ifdef BOYD16 - SPAposition start_point = wire_edge->start()->geometry()->coords(); + SPAposition start_point = wire_edge->start()->geometry()->coords(); #endif - SPAparameter s_param = wire_edge->start_param(); - SPAparameter e_param = wire_edge->end_param(); + SPAparameter s_param = wire_edge->start_param(); + SPAparameter e_param = wire_edge->end_param(); - //SPAinterval param_interval = wire_edge->param_range(); - SPAparameter new_parameter = s_param + ((e_param - s_param ) * 0.79); + //SPAinterval param_interval = wire_edge->param_range(); + SPAparameter new_parameter = s_param + ((e_param - s_param ) * 0.79); - if (wire_edge->sense() == REVERSED ) - new_parameter = -(new_parameter); + if (wire_edge->sense() == REVERSED ) + new_parameter = -(new_parameter); - SPAposition point_on_curve; - wire_edge->geometry()->equation().eval(new_parameter, point_on_curve ); + SPAposition point_on_curve; + wire_edge->geometry()->equation().eval(new_parameter, point_on_curve ); - //find surface which contains point at parameter 0.79 and midpoint - //loop to find appropriate face - ENTITY *temp_ENT; - FACEs.init(); - FACE *embed_FACE = NULL; - while( (temp_ENT = FACEs.next()) != NULL ) - { - FACE *tmp_FACE = (FACE*)temp_ENT; - SPAposition point1; - api_find_cls_ptto_face(mid_point, tmp_FACE, point1 ); - if ( distance_to_point( point1, mid_point ) < 0.0005 ) - { - api_find_cls_ptto_face(point_on_curve, tmp_FACE, point1 ); + //find surface which contains point at parameter 0.79 and midpoint + //loop to find appropriate face + ENTITY *temp_ENT; + FACEs.init(); + FACE *embed_FACE = NULL; + while( (temp_ENT = FACEs.next()) != NULL ) + { + FACE *tmp_FACE = (FACE*)temp_ENT; + SPAposition point1; + api_find_cls_ptto_face(mid_point, tmp_FACE, point1 ); + if ( distance_to_point( point1, mid_point ) < 0.0005 ) + { + api_find_cls_ptto_face(point_on_curve, tmp_FACE, point1 ); - if ( distance_to_point( point1, point_on_curve ) < 0.0005 ) - { - embed_FACE = tmp_FACE; - break; - } - } - } - if( embed_FACE ) - { - face_list->clear(); - face_list->add( (ENTITY*)embed_FACE ); - result = api_embed_wire_in_faces( wire_BODY_ptr, copied_BODY, face_list, tolerance ); - } - } + if ( distance_to_point( point1, point_on_curve ) < 0.0005 ) + { + embed_FACE = tmp_FACE; + break; + } + } + } + if( embed_FACE ) + { + face_list->clear(); + face_list->add( (ENTITY*)embed_FACE ); + result = api_embed_wire_in_faces( wire_BODY_ptr, copied_BODY, face_list, tolerance ); + } + } - AcisModifyEngine::instance()->cleanup_slivers( copied_BODY ); + AcisModifyEngine::instance()->cleanup_slivers( copied_BODY ); - //check to see if anything actually happened - int num_vol_bef, num_face_bef, num_edge_bef, num_vertex_bef; - CubitStatus status1 = AcisQueryEngine::instance()->number_ENTITIES( BODY_ptr, num_vol_bef, - num_face_bef, num_edge_bef, - num_vertex_bef ); + //check to see if anything actually happened + int num_vol_bef, num_face_bef, num_edge_bef, num_vertex_bef; + CubitStatus status1 = AcisQueryEngine::instance()->number_ENTITIES( BODY_ptr, num_vol_bef, + num_face_bef, num_edge_bef, + num_vertex_bef ); - int num_vol_aft, num_face_aft, num_edge_aft, num_vertex_aft; - CubitStatus status2 = AcisQueryEngine::instance()->number_ENTITIES( copied_BODY, num_vol_aft, - num_face_aft, num_edge_aft, - num_vertex_aft ); + int num_vol_aft, num_face_aft, num_edge_aft, num_vertex_aft; + CubitStatus status2 = AcisQueryEngine::instance()->number_ENTITIES( copied_BODY, num_vol_aft, + num_face_aft, num_edge_aft, + num_vertex_aft ); - if( status1 == CUBIT_FAILURE || - status2 == CUBIT_FAILURE ) - { - return CUBIT_FAILURE; - } + if( status1 == CUBIT_FAILURE || + status2 == CUBIT_FAILURE ) + { + return CUBIT_FAILURE; + } - if( num_vol_bef == num_vol_aft && - num_face_bef == num_face_aft && - num_edge_bef == num_edge_aft && - num_vertex_bef == num_vertex_aft) - { - AcisQueryEngine::instance()->delete_ACIS_BODY(copied_BODY, CUBIT_TRUE); - return CUBIT_SUCCESS; - } + if( num_vol_bef == num_vol_aft && + num_face_bef == num_face_aft && + num_edge_bef == num_edge_aft && + num_vertex_bef == num_vertex_aft) + { + AcisQueryEngine::instance()->delete_ACIS_BODY(copied_BODY, CUBIT_TRUE); + return CUBIT_SUCCESS; + } - BodySM* new_body_ptr = get_new_Body( old_body_sm, BODY_ptr, copied_BODY, - false, CUBIT_TRUE ); + BodySM* new_body_ptr = get_new_Body( old_body_sm, BODY_ptr, copied_BODY, + false, CUBIT_TRUE ); - new_body = new_body_ptr; - return CUBIT_SUCCESS; -} + new_body = new_body_ptr; + return CUBIT_SUCCESS; + } -CubitStatus AcisModifyEngine::curve_surface_intersection( Surface *surface, - Curve* curve, - DLIList<Curve*> &new_curves ) const -{ - FACE *FACE_ptr = AcisQueryEngine::get_FACE( surface ); - EDGE *EDGE_ptr = AcisQueryEngine::get_EDGE( curve ); + CubitStatus AcisModifyEngine::curve_surface_intersection( Surface *surface, + Curve* curve, + DLIList<Curve*> &new_curves ) const + { + FACE *FACE_ptr = AcisQueryEngine::get_FACE( surface ); + EDGE *EDGE_ptr = AcisQueryEngine::get_EDGE( curve ); - ENTITY_LIST *ent_list = new ENTITY_LIST; + ENTITY_LIST *ent_list = new ENTITY_LIST; - outcome result = api_edfa_int( EDGE_ptr, FACE_ptr, ent_list ); + outcome result = api_edfa_int( EDGE_ptr, FACE_ptr, ent_list ); - if( !result.ok() || ent_list->count() == 0 ) - { - delete ent_list; - return CUBIT_FAILURE; - } + if( !result.ok() || ent_list->count() == 0 ) + { + delete ent_list; + return CUBIT_FAILURE; + } - ENTITY *tmp_ent; - ent_list->init(); - while( (tmp_ent=ent_list->next()) != NULL ) - { - if( is_EDGE( tmp_ent ) ) - { - EDGE_ptr = static_cast<EDGE*>(tmp_ent); - Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr); - new_curves.append( curve_ptr ); - } - } - delete ent_list; + ENTITY *tmp_ent; + ent_list->init(); + while( (tmp_ent=ent_list->next()) != NULL ) + { + if( is_EDGE( tmp_ent ) ) + { + EDGE_ptr = static_cast<EDGE*>(tmp_ent); + Curve *curve_ptr = AcisQueryEngine::instance()->populate_topology_bridges(EDGE_ptr); + new_curves.append( curve_ptr ); + } + } + delete ent_list; - if( new_curves.size() == 0 ) - return CUBIT_FAILURE; + if( new_curves.size() == 0 ) + return CUBIT_FAILURE; - return CUBIT_SUCCESS; -} + return CUBIT_SUCCESS; + } -void AcisModifyEngine::get_new_ENTITIES(ENTITY *top_ENTITY, DLIList<ENTITY*> &new_ENTITIES) const -{ - ENTITY_LIST ENTITIES; - int i; - - // vertices - api_get_vertices( top_ENTITY, ENTITIES); - for (i = 0; i < ENTITIES.count(); i++) - { - if (!ATTRIB_CUBIT_OWNER::cubit_owner(ENTITIES[i])) + void AcisModifyEngine::get_new_ENTITIES(ENTITY *top_ENTITY, DLIList<ENTITY*> &new_ENTITIES) const { + ENTITY_LIST ENTITIES; + int i; + + // vertices + api_get_vertices( top_ENTITY, ENTITIES); + for (i = 0; i < ENTITIES.count(); i++) + { + if (!ATTRIB_CUBIT_OWNER::cubit_owner(ENTITIES[i])) + { + new_ENTITIES.append_unique(ENTITIES[i]); + } + } + ENTITIES.clear(); + + // edges + api_get_edges( top_ENTITY, ENTITIES); + for (i = 0; i < ENTITIES.count(); i++) + { + if (!ATTRIB_CUBIT_OWNER::cubit_owner(ENTITIES[i])) + { + new_ENTITIES.append_unique(ENTITIES[i]); + } + } + ENTITIES.clear(); + /* + // faces + api_get_faces( top_ENTITY, ENTITIES); + for (i = 0; i < ENTITIES.count(); i++) + { + if (!ATTRIB_CUBIT_OWNER::cubit_owner(ENTITIES[i])) + { new_ENTITIES.append_unique(ENTITIES[i]); + } + } + ENTITIES.clear(); + */ } - } - ENTITIES.clear(); - // edges - api_get_edges( top_ENTITY, ENTITIES); - for (i = 0; i < ENTITIES.count(); i++) - { - if (!ATTRIB_CUBIT_OWNER::cubit_owner(ENTITIES[i])) + void AcisModifyEngine::get_att_ENTITIES(ENTITY *top_ENTITY, DLIList<ENTITY*> &att_ENTITIES, char *att_name) const { - new_ENTITIES.append_unique(ENTITIES[i]); - } - } - ENTITIES.clear(); -/* - // faces - api_get_faces( top_ENTITY, ENTITIES); - for (i = 0; i < ENTITIES.count(); i++) - { - if (!ATTRIB_CUBIT_OWNER::cubit_owner(ENTITIES[i])) - { - new_ENTITIES.append_unique(ENTITIES[i]); - } - } - ENTITIES.clear(); - */ -} + ENTITY_LIST ENTITIES; + int i; + // vertices + api_get_vertices( top_ENTITY, ENTITIES); + for (i = 0; i < ENTITIES.count(); i++) + { + ATTRIB_SNL_SIMPLE *attribute = + (ATTRIB_SNL_SIMPLE *) find_attrib(ENTITIES[i], + ATTRIB_SNL_TYPE, + ATTRIB_SNL_SIMPLE_TYPE); + for(;attribute != NULL;attribute = (ATTRIB_SNL_SIMPLE *) + find_next_attrib(attribute, + ATTRIB_SNL_TYPE, + ATTRIB_SNL_SIMPLE_TYPE)) + { + if( attribute->attribute_name() == att_name ) + att_ENTITIES.append_unique(ENTITIES[i]); + } + } + ENTITIES.clear(); -void AcisModifyEngine::get_att_ENTITIES(ENTITY *top_ENTITY, DLIList<ENTITY*> &att_ENTITIES, char *att_name) const -{ - ENTITY_LIST ENTITIES; - int i; - // vertices - api_get_vertices( top_ENTITY, ENTITIES); - for (i = 0; i < ENTITIES.count(); i++) - { - ATTRIB_SNL_SIMPLE *attribute = + // edges + api_get_edges( top_ENTITY, ENTITIES); + for (i = 0; i < ENTITIES.count(); i++) + { + ATTRIB_SNL_SIMPLE *attribute = + (ATTRIB_SNL_SIMPLE *) find_attrib(ENTITIES[i], + ATTRIB_SNL_TYPE, + ATTRIB_SNL_SIMPLE_TYPE); + for(;attribute != NULL;attribute = (ATTRIB_SNL_SIMPLE *) + find_next_attrib(attribute, + ATTRIB_SNL_TYPE, + ATTRIB_SNL_SIMPLE_TYPE)) + { + if( attribute->attribute_name() == att_name ) + att_ENTITIES.append_unique(ENTITIES[i]); + } + } + ENTITIES.clear(); + /* + // faces + api_get_faces( top_ENTITY, ENTITIES); + for (i = 0; i < ENTITIES.count(); i++) + { + ATTRIB_SNL_SIMPLE *attribute = (ATTRIB_SNL_SIMPLE *) find_attrib(ENTITIES[i], - ATTRIB_SNL_TYPE, - ATTRIB_SNL_SIMPLE_TYPE); - for(;attribute != NULL;attribute = (ATTRIB_SNL_SIMPLE *) - find_next_attrib(attribute, - ATTRIB_SNL_TYPE, - ATTRIB_SNL_SIMPLE_TYPE)) - { + ATTRIB_SNL_TYPE, + ATTRIB_SNL_SIMPLE_TYPE); + for(;attribute != NULL;attribute = (ATTRIB_SNL_SIMPLE *) + find_next_attrib(attribute, + ATTRIB_SNL_TYPE, + ATTRIB_SNL_SIMPLE_TYPE)) + { if( attribute->attribute_name() == att_name ) - att_ENTITIES.append_unique(ENTITIES[i]); + att_ENTITIES.append_unique(ENTITIES[i]); + } + } + ENTITIES.clear(); + */ } - } - ENTITIES.clear(); - // edges - api_get_edges( top_ENTITY, ENTITIES); - for (i = 0; i < ENTITIES.count(); i++) - { - ATTRIB_SNL_SIMPLE *attribute = - (ATTRIB_SNL_SIMPLE *) find_attrib(ENTITIES[i], - ATTRIB_SNL_TYPE, - ATTRIB_SNL_SIMPLE_TYPE); - for(;attribute != NULL;attribute = (ATTRIB_SNL_SIMPLE *) - find_next_attrib(attribute, - ATTRIB_SNL_TYPE, - ATTRIB_SNL_SIMPLE_TYPE)) + CubitStatus AcisModifyEngine::cleanup_slivers( BODY *body_to_cleanup ) { - if( attribute->attribute_name() == att_name ) - att_ENTITIES.append_unique(ENTITIES[i]); + double sliver_curve_tol = GeometryQueryTool::get_sliver_curve_cleanup_tolerance(); + double sliver_surface_tol = GeometryQueryTool::get_sliver_surface_cleanup_tolerance(); + + ENTITY_LIST dummy_list; + api_detect_short_edges( body_to_cleanup, dummy_list, sliver_curve_tol, true ); + api_detect_sliver_faces( body_to_cleanup, dummy_list, sliver_surface_tol, true ); + + return CUBIT_SUCCESS; } - } - ENTITIES.clear(); -/* - // faces - api_get_faces( top_ENTITY, ENTITIES); - for (i = 0; i < ENTITIES.count(); i++) - { - ATTRIB_SNL_SIMPLE *attribute = - (ATTRIB_SNL_SIMPLE *) find_attrib(ENTITIES[i], - ATTRIB_SNL_TYPE, - ATTRIB_SNL_SIMPLE_TYPE); - for(;attribute != NULL;attribute = (ATTRIB_SNL_SIMPLE *) - find_next_attrib(attribute, - ATTRIB_SNL_TYPE, - ATTRIB_SNL_SIMPLE_TYPE)) + + CubitStatus AcisModifyEngine::remove_curve_slivers( BodySM *body_sm, + double lengthlimit ) const { - if( attribute->attribute_name() == att_name ) - att_ENTITIES.append_unique(ENTITIES[i]); - } - } - ENTITIES.clear(); - */ -} + //get the BODY + BodyACIS *tmp_body_acis = CAST_TO(body_sm, BodyACIS ); + BODY *tmp_BODY = tmp_body_acis->get_BODY_ptr(); -CubitStatus AcisModifyEngine::cleanup_slivers( BODY *body_to_cleanup ) -{ - double sliver_curve_tol = GeometryQueryTool::get_sliver_curve_cleanup_tolerance(); - double sliver_surface_tol = GeometryQueryTool::get_sliver_surface_cleanup_tolerance(); + //copy the BODY + BODY *copy_BODY = AcisModifyEngine::instance()->copy_BODY( tmp_BODY, false ); - ENTITY_LIST dummy_list; - api_detect_short_edges( body_to_cleanup, dummy_list, sliver_curve_tol, true ); - api_detect_sliver_faces( body_to_cleanup, dummy_list, sliver_surface_tol, true ); + //remove the slivers + ENTITY_LIST removed_curves; + outcome result = api_detect_short_edges( copy_BODY, removed_curves, lengthlimit, true ); - return CUBIT_SUCCESS; -} + if( !result.ok() ) + { + PRINT_ERROR("Problem remove sliver curves\n"); + AcisQueryEngine::instance()->ACIS_API_error (result); + api_delent( (ENTITY*)copy_BODY ); + return CUBIT_FAILURE; + } -CubitStatus AcisModifyEngine::remove_curve_slivers( BodySM *body_sm, - double lengthlimit ) const -{ - //get the BODY - BodyACIS *tmp_body_acis = CAST_TO(body_sm, BodyACIS ); - BODY *tmp_BODY = tmp_body_acis->get_BODY_ptr(); + TopologyEntity *te = body_sm->topology_entity(); + RefEntity *ref_ent = CAST_TO( te, RefEntity ); + PRINT_INFO("Removed %d sliver curves on body %d\n", + removed_curves.count(), ref_ent->id() ); - //copy the BODY - BODY *copy_BODY = AcisModifyEngine::instance()->copy_BODY( tmp_BODY, false ); + if( removed_curves.count() == 0 ) + { + api_delent( (ENTITY*)copy_BODY ); + return CUBIT_SUCCESS; + } + + get_new_Body(body_sm, tmp_BODY, copy_BODY, CUBIT_FALSE); - //remove the slivers - ENTITY_LIST removed_curves; - outcome result = api_detect_short_edges( copy_BODY, removed_curves, lengthlimit, true ); + return CUBIT_SUCCESS; + } - if( !result.ok() ) - { - PRINT_ERROR("Problem remove sliver curves\n"); - AcisQueryEngine::instance()->ACIS_API_error (result); - api_delent( (ENTITY*)copy_BODY ); - return CUBIT_FAILURE; - } + CubitStatus AcisModifyEngine::stitch_surfs( + DLIList<BodySM*>& surf_bodies, + BodySM*& stitched_body)const + { + stitched_body = NULL; + if (surf_bodies.size()==0) + return CUBIT_SUCCESS; - TopologyEntity *te = body_sm->topology_entity(); - RefEntity *ref_ent = CAST_TO( te, RefEntity ); - PRINT_INFO("Removed %d sliver curves on body %d\n", - removed_curves.count(), ref_ent->id() ); + if (surf_bodies.size()==1) + { + stitched_body = surf_bodies.get(); + return CUBIT_SUCCESS; + } - if( removed_curves.count() == 0 ) - { - api_delent( (ENTITY*)copy_BODY ); - return CUBIT_SUCCESS; - } + BODY* tool_BODY = NULL; + BodySM * tool_body; + DLIList<FACE*> stitch_FACES; + for(int i=0; i < surf_bodies.size();i++) + { + tool_body = surf_bodies.get_and_step(); + tool_BODY = AcisQueryEngine::get_BODY( const_cast<BodySM*>(tool_body) ); + FACE *FACE_ptr = tool_BODY->lump()->shell()->first_face(); + stitch_FACES.append( FACE_ptr ); + } + + CubitStatus status; + //stitch FACEs together into one BODY + //they may not stitch into one single FACE... - get_new_Body(body_sm, tmp_BODY, copy_BODY, CUBIT_FALSE); + tool_BODY = NULL; + + FACE *dummy_FACE = NULL; + + status = stitch_FACEs(stitch_FACES , dummy_FACE, tool_BODY ); - return CUBIT_SUCCESS; -} + if( status == CUBIT_FAILURE ) + { + PRINT_ERROR("Stitch faces produce surfaces that cannot be stitched together.\n"); + + return CUBIT_FAILURE; + } + + + //get rid of any unnecessary edges + api_clean_entity( (ENTITY*)tool_BODY); + + stitched_body = AcisQueryEngine::instance()->populate_topology_bridges(tool_BODY); + + return CUBIT_SUCCESS; + } + + CubitStatus AcisModifyEngine::trim_up_to_next_surface(BodySM*& tool_body, + DLIList<BodySM*> bodies, + GeometryEntity * surf_vert) + { + assert(tool_body); + assert(surf_vert); + BODY* tool_BODY = AcisQueryEngine::get_BODY( tool_body ); + if (tool_BODY == NULL) + return CUBIT_FAILURE; + + Point * vertex = CAST_TO(surf_vert, Point); + if (!vertex) + return CUBIT_FAILURE; + VERTEX * VERTEX_ptr = AcisQueryEngine::get_VERTEX(vertex); + + CubitStatus stat= trim_up_to_next_surface(tool_BODY, bodies, VERTEX_ptr); + if (stat) + tool_body = AcisQueryEngine::instance()->populate_topology_bridges(tool_BODY); + + return stat; + } Modified: cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp =================================================================== --- cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp 2007-08-24 20:05:52 UTC (rev 1252) +++ cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp 2007-08-24 20:43:22 UTC (rev 1253) @@ -202,14 +202,17 @@ //- Returns the ID of the new Body or CUBIT_FAILURE virtual BodySM* cylinder( double hi, double r1, double r2, - double r3 ) const ; + double r3) const ; //- Creates an ACIS frustum and assigns it to a Body $ //- {hi} input height $ //- {r1} input radius in x-direction at base $ //- {r2} input radius in y-direction at base $ - //- {r3} input radius in x-direction at top + //- {r3} input radius in x-direction at top $ + //- {axis} align axis, optional, if null vector, align in z direction $ + //- {center} optional, if null vector, centered at origin //- Returns the ID of the new Body or CUBIT_FAILURE + virtual BodySM* torus( double r1, double r2 ) const ; //- Creates an ACIS torus and assigns it to a Body $ //- {r1} input major_radius $ @@ -227,6 +230,9 @@ //- {p4} - 4th corner of the sheet //HEADER- Boolean operator functions. + virtual CubitStatus stitch_surfs( + DLIList<BodySM*> &surf_bodies, + BodySM*& stitched_body)const; virtual CubitStatus subtract( DLIList<BodySM*> &tool_body_ptr, DLIList<BodySM*> &from_bodies, @@ -397,7 +403,9 @@ double draft_angle, int draft_type, bool switchside, - bool rigid) const ; + bool rigid, + Surface* stop_surf = NULL, + BodySM* stop_body = NULL) const ; virtual CubitStatus sweep_perpendicular( DLIList<GeometryEntity*>& ref_ent_list, @@ -406,7 +414,9 @@ double draft_angle, int draft_type, bool switchside, - bool rigid) const ; + bool rigid, + Surface* stop_surf = NULL, + BodySM* stop_body = NULL) const ; virtual CubitStatus sweep_rotational( DLIList<GeometryEntity*>& ref_ent_list, @@ -419,7 +429,9 @@ int draft_type = 0, bool switchside = false, bool make_solid = false, - bool rigid = false ) const ; + bool rigid = false, + Surface *stop_surf = NULL, + BodySM* stop_body = NULL) const ; virtual CubitStatus sweep_along_curve( DLIList<GeometryEntity*>& ref_ent_list, @@ -427,7 +439,9 @@ DLIList<Curve*>& ref_edge_list, double draft_angle = 0.0, int draft_type = 0, - bool rigid = false ) const; + bool rigid = false, + Surface *stop_surf = NULL, + BodySM* stop_body = NULL) const; //HEADER- Functions for webcut operations @@ -455,10 +469,11 @@ //- The newly created bodies are merged and imprinted depeding on //- the respective flags. - virtual CubitStatus webcut( DLIList<BodySM*>& webcut_body_list, - BodySM const* tool_body, - DLIList<BodySM*>& results_list, - bool imprint = false ) const ; + virtual CubitStatus webcut( + DLIList<BodySM*>& webcut_body_list, + BodySM const* tool_body, + DLIList<BodySM*>& results_list, + bool imprint = false) const; //R int //R- Number of bodies that were webcut ( >= 0 ) //I webcut_body_list @@ -475,23 +490,25 @@ //- as the webcutting tool. The newly created bodies are //- merged and imprinted depeding on the respective flags. - virtual CubitStatus webcut_with_cylinder( +/* virtual CubitStatus webcut_with_cylinder( DLIList<BodySM*> &webcut_body_list, double radius, const CubitVector &axis, const CubitVector ¢er, DLIList<BodySM*>& results_list, bool imprint = false ); +*/ //- cores the bodies with a cylinder formed by the given //- parameters and the height larger than the model. - virtual CubitStatus webcut_with_brick( +/* virtual CubitStatus webcut_with_brick( DLIList<BodySM*>& webcut_body_list, const CubitVector ¢er, const CubitVector axes[3], const CubitVector &extension, DLIList<BodySM*> &results_list, bool imprint = false ); +*/ /**< Webcuts the bodies in the list with a cutting brick. * The brick is created by the given parameters - center of * brick, xyz axes, and extension. Extension is 1/2 width, @@ -499,6 +516,7 @@ * solid modeling engine to reduce the impact on body ids. */ +/* virtual CubitStatus webcut_with_planar_sheet( DLIList<BodySM*>& webcut_body_list, const CubitVector ¢er, @@ -506,20 +524,22 @@ double width, double height, DLIList<BodySM*> &results_list, bool imprint = false ); +*/ /**< Webcuts the bodies in the list with a cutting planar sheet. * The sheet is created by the given parameters - center of * sheet, xy axes, and width and height. Sheet creation is done * in the solid modeling engine to reduce the impact on body ids. */ - + /* virtual CubitStatus webcut_with_curve_loop( DLIList<BodySM*> &webcut_body_list, DLIList<Curve*> &ref_edge_list, DLIList<BodySM*>& results_list, bool imprint = false); + */ //- creates a sheet body with the given curve loop //- uses the new sheet body to cut the body list - + /* virtual CubitStatus webcut_with_sweep_surfaces_rotated( DLIList<BodySM*> &blank_bodies, DLIList<Surface*> &surfaces, @@ -530,7 +550,8 @@ bool up_to_next, DLIList<BodySM*> &results_list, CubitBoolean imprint = false ); - + */ + /* virtual CubitStatus webcut_with_sweep_curves_rotated( DLIList<BodySM*> &blank_bodies, DLIList<Curve*> &curves, @@ -540,11 +561,13 @@ Surface *stop_surf, DLIList<BodySM*> &results_list, CubitBoolean imprint = false ); + */ //-these 2 functions sweep a surface or curve about an axis, creating a swept //volume or surface respectively, which is in turn used to webcut the blank_bodies. //stop_surface is a surface where the sweep will terminate. If stop_surface is //specified, there MUST be some intersection between sweep and stop_surface. + /* virtual CubitStatus webcut_with_sweep_surfaces( DLIList<BodySM*> &blank_bodies, DLIList<Surface*> &surfaces, @@ -557,6 +580,7 @@ Curve *curve_to_sweep_along, DLIList<BodySM*> &results_list, CubitBoolean imprint = false ); + */ //-sweeps a surface(s) along a vector, curve or perpendicular to the surface //(last case implied when sweep_vector's length is zero) producing a swept body. //If through_all is true, sweep will traverse blank_bodies completely. If stop_surf @@ -567,6 +591,7 @@ //fails, each surface is swept individually and the resultant bodies united. //This tool body is then used for the webcutting. + /* virtual CubitStatus webcut_with_sweep_curves( DLIList<BodySM*> &blank_bodies, DLIList<Curve*> &curves, @@ -576,14 +601,16 @@ Curve *curve_to_sweep_along, DLIList<BodySM*> &results_list, CubitBoolean imprint = false ); + */ //-sweeps a curve(s) along a vector, curve. Swept surface(s)are stitched //together and used as cutting tool to webcut blank_bodies. If surface(s) //do not completely cut blank_bodies, webcut fails. If stop_surface is //specified, there MUST be some intersection between sweept surface and //stop_surface. - CubitStatus trim_up_to_next_surface( BODY *&tool_body, DLIList<BodySM*> &blank_bodies, - VERTEX *surf_VERT ); + CubitStatus trim_up_to_next_surface(BodySM*& tool_body, + DLIList<BodySM*> bodies, + GeometryEntity * surf_vert); virtual CubitStatus section( DLIList<BodySM*> §ion_body_list, const CubitVector &point_1, @@ -771,31 +798,34 @@ //- //HEADER- Miscellaneous functions - +/* virtual CubitStatus webcut_with_sheet(DLIList<BodySM*>& webcut_body_list, BodySM *sheet_body, DLIList<BodySM*> &new_bodies, bool imprint = false); +*/ //- webcuts a body using a sheet body. //- It splits the sheet into two single sided bodies. //- it then subtracts this with the webcut body. //- The result is splitting the webcut_body into halves. //- if the webcut body is a topological torus, this routine //- will fail... - + /* virtual CubitStatus webcut_with_sheet(BODY *webcut_body, BODY *sheet_body, BODY *&webcut_body_1, BODY *&webcut_body_2, CubitBoolean imprint = CUBIT_FALSE); + */ //- webcuts a body using a sheet body. //- It splits the sheet into two single sided bodies. - + /* virtual CubitStatus webcut_with_extended_surf(DLIList<BodySM*> &webcut_body, Surface *extend_from, DLIList<BodySM*> &new_bodies, int &num_cut, bool imprint = false); + */ //- creates a surface by extending one from the given surface then //- webcuts using the this sheet.(see webcut_with_sheet. @@ -1146,7 +1176,21 @@ //HEADER- Functions that create TopologyEntities + CubitStatus stitch_FACEs( DLIList<FACE*> &faces, + FACE *&result_FACE, + BODY *&stitched_BODY )const; + //I List of FACEs you want stitched together + //IO Pointer to FACE...gets set if all FACEs can be stitched into single FACE + //IO If stitching of FACEs is successful, stitched_BODY is resultant BODY. + // Means that all faces could be stitched together, forming a single BODY, + // but not a single FACE. + //returns CUBIT_SUCCESS if stitching was successful, other return FAILURE + + CubitStatus trim_up_to_next_surface( BODY *&tool_BODY, + DLIList<BodySM*> &blank_bodies, + VERTEX *surf_VERT ); + CubitStatus get_new_Body(DLIList<BodySM*> &old_Body_list, DLIList<BODY*> &old_BODY_list, DLIList<BODY*> &new_BODY_list, @@ -1460,7 +1504,8 @@ CubitStatus webcut( DLIList<BodySM*>& webcut_body_list, BODY* tool_BODY, DLIList<BodySM*>& results_list, - bool imprint = false ) const ; + bool imprint = false + ) const ; //R int //R- Number of bodies that were webcut ( >= 0 ) //I webcut_body_list @@ -1492,7 +1537,8 @@ CubitStatus webcut_BODY( BODY* inputAcisBody, BODY* infiniteCuttingTool, BODY*& webcutBody1, - BODY*& webcutBody2) const; + BODY*& webcutBody2, + CubitBoolean cutting_with_sheet = CUBIT_FALSE) const; //- Creates 2 ACIS BODYs that are the result of "webcutting" the input ACIS //- BODY, inputAcisBody, using the "infinite" solid BODY, infiniteCuttingTool. //- The ACIS FACES that overlap (at the cutting tool) are not "merged" -- i.e., @@ -1513,15 +1559,7 @@ //- Deletes the Bodies in body_list and the Acis BODYs in BODY_list - CubitStatus stitch_FACEs( DLIList<FACE*> &faces, - FACE *&result_FACE, - BODY *&stitched_BODY ); - //I List of FACEs you want stitched together - //IO Pointer to FACE...gets set if all FACEs can be stitched into single FACE - //IO If stitching of FACEs is successful, stitched_BODY is resultant BODY. - // Means that all faces could be stitched together, forming a single BODY, - // but not a single FACE. - //returns CUBIT_SUCCESS if stitching was successful, other return FAILURE + void webcut_imprint(BODY* cutting_tool_BODY_ptr, DLIList<BodySM*> &old_body_list, @@ -1566,7 +1604,8 @@ double draft_angle = 0.0, int draft_type = 0, bool rigid = false, - FACE *to_FACE= NULL ) const; + FACE *to_FACE= NULL, + BODY *to_BODY = NULL ) const; //- Sweeps the FACE, FACE_ptr, along the sweep_vector, a distance equal //- to the length of the vector, using the input draft_angle and draft_type. //- The primary side of the FACE is swept unless it is DOUBLE_SIDED @@ -1587,7 +1626,8 @@ double draft_angle = 0.0, int draft_type = 0, bool rigid = false , - FACE *to_FACE= NULL ) const; + FACE *to_FACE= NULL, + BODY *to_BODY = NULL ) const; //- Sweeps the FACE, FACE_ptr, perpendicularly, a distance equal //- to the distance given, using the input draft_angle and draft_type. //- The primary side of the FACE is swept unless it is DOUBLE_SIDED @@ -1608,7 +1648,8 @@ double draft_angle = 0.0, int draft_type = 0, bool rigid = false, - FACE *to_FACE= NULL ) const; + FACE *to_FACE= NULL, + BODY *to_BODY = NULL ) const; //- Sweeps the EDGE, EDGE_ptr, along the sweep_vector, a distance equal //- to the length of the vector, using the input draft_angle and draft_type. //- The draft_type is either 0 or 1 (see the ACIS documentation on the @@ -1627,7 +1668,8 @@ double draft_angle = 0.0, int draft_type = 0, bool rigid = false, - FACE *to_FACE = NULL ) const; + FACE *to_FACE = NULL, + BODY *to_BODY = NULL ) const; //- Revolves the FACE, FACE_ptr, about the unit vector, axis_unit_vector, //- passing through the spatial location, point. //- The angle of revolution is specified by angle and the input @@ -1654,7 +1696,8 @@ int draft_type = 0, bool make_solid = false, bool rigid = false, - FACE *to_FACE= NULL ) const; + FACE *to_FACE= NULL, + BODY *to_BODY = NULL ) const; //- Revolves the EDGE, EDGE_ptr, about the unit vector, axis_unit_vector, //- passing through the spatial location, point. //- The angle of revolution is specified by angle and the input @@ -1670,7 +1713,8 @@ double draft_angle = 0.0, int draft_type = 0, bool rigid = false, - FACE *to_FACE= NULL ) const; + FACE *to_FACE= NULL, + BODY *to_BODY = NULL ) const; //- Sweeps the FACE, FACE_ptr, along a WIRE body. //- The draft_type is either 0, 1 or 2 (see the ACIS documentation on the //- sweep_options) and indicates what should be done to "close" @@ -1684,7 +1728,8 @@ double draft_angle = 0.0, int draft_type = 0, bool rigid = false, - FACE *to_FACE= NULL ) const; + FACE *to_FACE= NULL, + BODY *to_BODY = NULL ) const; //- Sweeps the EDGE, EDGE_ptr, along a WIRE body. //- The draft_type is either 0, 1 or 2 (see the ACIS documentation on the //- sweep_options) and indicates what should be done to "close" Modified: cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.cpp =================================================================== --- cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.cpp 2007-08-24 20:05:52 UTC (rev 1252) +++ cgm/trunk/geom/ACIS_SRC/AcisQueryEngine.cpp 2007-08-24 20:43:22 UTC (rev 1253) @@ -4607,6 +4607,10 @@ this_minor = 0; valid = true; } + else if (major == 16 && this_minor >= 0 && this_minor <= 7) { + this_minor = 0; + valid = true; + } else { PRINT_ERROR("Unrecognized Acis version number %d.%d.\n", major, this_minor); return CUBIT_FAILURE; Modified: cgm/trunk/geom/GeometryModifyEngine.cpp =================================================================== --- cgm/trunk/geom/GeometryModifyEngine.cpp 2007-08-24 20:05:52 UTC (rev 1252) +++ cgm/trunk/geom/GeometryModifyEngine.cpp 2007-08-24 20:43:22 UTC (rev 1253) @@ -1,7 +1,607 @@ #include "CubitDefines.h" #include "GeometryDefines.h" +#include "CubitBox.hpp" #include "CubitVector.hpp" +#include "BodySM.hpp" +#include "Surface.hpp" #include "GeometryModifyEngine.hpp" +#include "GeometryQueryEngine.hpp" +#include "GeometryQueryTool.hpp" - +CubitStatus GeometryModifyEngine::webcut_with_brick( + DLIList<BodySM*>& webcut_body_list, + const CubitVector ¢er, + const CubitVector axes[3], + const CubitVector &extension, + DLIList<BodySM*> &results_list, + bool imprint ) +{ + // Create the brick to cut with + BodySM *cutting_tool_ptr = brick( center, axes, extension ); + if( cutting_tool_ptr == NULL ) + return CUBIT_FAILURE; + + CubitStatus stat = + this->webcut(webcut_body_list, cutting_tool_ptr, results_list, imprint) ; + + // Delete the BodySM that was created to be used as a tool + get_gqe()->delete_solid_model_entities(cutting_tool_ptr) ; + + return stat; +} + +CubitStatus GeometryModifyEngine::webcut_with_cylinder( + DLIList<BodySM*> &webcut_body_list, + double radius, + const CubitVector &axis, + const CubitVector ¢er, + DLIList<BodySM*>& results_list, + bool imprint ) +{ + + double max_size = 0.; + //lets find the distance to the center for each body and take + //the max. + double curr; + CubitVector cent_bod; + CubitBox bounding_box; + BodySM *body_ptr; + bounding_box = webcut_body_list[0]->bounding_box(); + cent_bod = bounding_box.center(); + cent_bod = cent_bod - center; + curr = cent_bod.length(); + if ( curr > max_size ) + max_size = curr; + + + for ( int ii = webcut_body_list.size()-1; ii > 0; ii-- ) + { + body_ptr = webcut_body_list[ii]; + bounding_box |= body_ptr->bounding_box(); + cent_bod = body_ptr->bounding_box().center(); + cent_bod = cent_bod - center; + curr = cent_bod.length(); + if ( curr > max_size ) + max_size = curr; + } + + curr = bounding_box.diagonal().length(); + + if ( curr > max_size ) + max_size = curr; + + double height = 0.0; + if ( center.x() > max_size ) + { + height = 500.0 * center.x(); + } + else if ( center.y() > max_size ) + { + height = 500.0 * center.y(); + } + else if ( center.z() > max_size ) + { + height = 500.0 * center.z(); + } + else + { + height = 500.0 * max_size; + } + + //lets make certain we have a valid height.. + if ( height < GEOMETRY_RESABS ) + { + height = 500.0; + } + + BodySM *cutting_tool_ptr = cylinder( height, radius, radius, radius ); + + if( cutting_tool_ptr == NULL ) + return CUBIT_FAILURE; + + //transform the cyclinder to cernter and axis + // The current frustum is centered on the z axis. + CubitVector axis2(0., 0., 1.0 ); + //now find the normal to the current axis and axis we want to be + //at. This normal is where we will rotate about. + CubitVector normal_axis = axis2 * axis; + if ( normal_axis.length() > CUBIT_RESABS ) + { + //angle in degrees. + double angle = normal_axis.vector_angle( axis2, axis ); + get_gqe()->rotate(cutting_tool_ptr, normal_axis, angle); + } + get_gqe()->translate(cutting_tool_ptr, center); + + CubitStatus stat = + this->webcut(webcut_body_list, cutting_tool_ptr, results_list, imprint) ; + + // Delete the BodySM that was created to be used as a tool + get_gqe()->delete_solid_model_entities(cutting_tool_ptr) ; + + return stat; +} + +CubitStatus GeometryModifyEngine::webcut_with_planar_sheet( + DLIList<BodySM*>& webcut_body_list, + const CubitVector ¢er, + const CubitVector axes[2], + double width, + double height, + DLIList<BodySM*> &results_list, + bool imprint ) +{ + // Create the planar sheet to cut with + CubitVector p1, p2, p3, p4; + + // Get the corners of the sheet + center.next_point( axes[0], width/2.0, p1 ); + p1.next_point( axes[1], -height/2.0, p1 ); + p1.next_point( axes[1], height, p2 ); + p2.next_point( axes[0], -width, p3 ); + p3.next_point( axes[1], -height, p4 ); + + BodySM *cutting_tool_ptr = planar_sheet(p1,p2,p3,p4); + if( cutting_tool_ptr == NULL ) + return CUBIT_FAILURE; + + CubitStatus stat = + this->webcut(webcut_body_list, cutting_tool_ptr, results_list, imprint) ; + + // Delete the BodySM that was created to be used as a tool + get_gqe()->delete_solid_model_entities(cutting_tool_ptr) ; + + return stat; +} + +CubitStatus GeometryModifyEngine::webcut_with_sweep_curves_rotated( + DLIList<BodySM*> &blank_bodies, + DLIList<Curve*> &curves, + const CubitVector& point, + const CubitVector& sweep_axis, + double angle, + Surface *stop_surf, + DLIList<BodySM*> &results_list, + CubitBoolean imprint ) +{ + if(curves.size() == 0 ) + return CUBIT_FAILURE; + + DLIList<GeometryEntity*> ref_ent_list; + for(int i = 0; i < curves.size(); i++) + ref_ent_list.append((GeometryEntity*)(curves.get_and_step())); + + DLIList<BodySM*> swept_bodies; + CubitStatus stat = sweep_rotational(ref_ent_list,swept_bodies,point, + sweep_axis,angle,0, 0.0, 0,false,false, + false,stop_surf); + if(stat == CUBIT_FAILURE && swept_bodies.size() == 0) + return stat; + + //stitch faces together + BodySM* cutting_tool_ptr = NULL; + stat = stitch_surfs(swept_bodies, cutting_tool_ptr); + + if(stat == CUBIT_FAILURE) + { + //delete all swept faces + for(int i = 0; i < swept_bodies.size(); i++) + get_gqe()->delete_solid_model_entities(swept_bodies.get_and_step()) ; + return stat; + } + + stat = + this->webcut(blank_bodies, cutting_tool_ptr, results_list, imprint) ; + + // Delete the BodySM that was created to be used as a tool + get_gqe()->delete_solid_model_entities(cutting_tool_ptr) ; + + //delete all swept faces + for(int i = 0; i < swept_bodies.size(); i++) + get_gqe()->delete_solid_model_entities(swept_bodies.get_and_step()) ; + return stat; + +} + +CubitStatus GeometryModifyEngine::webcut_with_sweep_curves( + DLIList<BodySM*> &blank_bodies, + DLIList<Curve*> &curves, + const CubitVector& sweep_vector, + bool through_all, + Surface *stop_surf, + Curve *curve_to_sweep_along, + DLIList<BodySM*> &results_list, + CubitBoolean imprint ) +{ + if(curves.size() == 0 ) + return CUBIT_FAILURE; + + CubitVector tmp_sweep_vector = sweep_vector; + + //get model bbox info...will scale sweep vector by its diagonal + //so that we go far enough + if( through_all || stop_surf ) + { + CubitBox bounding_box = GeometryQueryTool::instance()->model_bounding_box(); + tmp_sweep_vector.normalize(); + tmp_sweep_vector*=(2*bounding_box.diagonal().length()); + } + + DLIList<GeometryEntity*> ref_ent_list; + for(int i = 0; i < curves.size(); i++) + ref_ent_list.append((GeometryEntity*)(curves.get_and_step())); + DLIList<BodySM*> swept_bodies; + CubitStatus stat; + + //see if we're sweeping along a specified curve + if( curve_to_sweep_along ) + { + DLIList<Curve*> curves_to_sweep_along; + curves_to_sweep_along.append(curve_to_sweep_along); + stat = sweep_along_curve(ref_ent_list, swept_bodies, + curves_to_sweep_along,0.0,0,false,stop_surf); + + if (!stat && swept_bodies.size() == 0) + return stat; + } + + else + { + stat = sweep_translational(ref_ent_list, swept_bodies, + tmp_sweep_vector,0.0,0, false, false, stop_surf); + + if (!stat && swept_bodies.size() == 0) + return stat; + } + + //stitch faces together + BodySM* cutting_tool_ptr = NULL; + stat = stitch_surfs(swept_bodies, cutting_tool_ptr); + + if(stat == CUBIT_FAILURE) + { + //delete all swept faces + for(int i = 0; i < swept_bodies.size(); i++) + get_gqe()->delete_solid_model_entities(swept_bodies.get_and_step()) ; + return stat; + } + + stat = + this->webcut(blank_bodies, cutting_tool_ptr, results_list, imprint) ; + + // Delete the BodySM that was created to be used as a tool + get_gqe()->delete_solid_model_entities(cutting_tool_ptr) ; + + //delete all swept faces + for(int i = 0; i < swept_bodies.size(); i++) + get_gqe()->delete_solid_model_entities(swept_bodies.get_and_step()) ; + return stat; +} + +CubitStatus GeometryModifyEngine::webcut_with_curve_loop( + DLIList<BodySM*> &webcut_body_list, + DLIList<Curve*> &curves, + DLIList<BodySM*>& results_list, + bool imprint ) +{ + if(curves.size() == 0 ) + return CUBIT_FAILURE; + + GeometryType surface_type = PLANE_SURFACE_TYPE; + CubitStatus stat; + + //make copies of the curves. + DLIList<Curve*> copied_curves; + Curve* temp_curve = NULL; + for (int i = curves.size(); i--;) + { + temp_curve = make_Curve(curves.get_and_step()); + if(temp_curve != NULL) + copied_curves.append(temp_curve); + } + + //make a face out of the curves + Surface * surf = make_Surface(surface_type, copied_curves, NULL, false ); + if (surf == NULL) + { + PRINT_ERROR("webcut tool surface is not created from acis.\n"); + return CUBIT_FAILURE; + } + + + //get cutting tool BodySM. + BodySM* cutting_tool_ptr = make_BodySM(surf); + assert(cutting_tool_ptr ); + + stat = + this->webcut(webcut_body_list, cutting_tool_ptr, results_list, imprint) ; + + // Delete the BodySM that was created to be used as a tool + get_gqe()->delete_solid_model_entities(cutting_tool_ptr) ; + return stat; +} + +CubitStatus GeometryModifyEngine::webcut_with_extended_surf( + DLIList<BodySM*> &webcut_body_list, + Surface *extend_from, + DLIList<BodySM*> &results_list, + int &num_cut, + bool imprint ) +{ + assert(extend_from); + //make the extended face + Surface * surf = make_Surface(extend_from, true); + if (surf == NULL) + { + PRINT_ERROR("webcut tool surface is not created from acis.\n"); + return CUBIT_FAILURE; + } + + //get cutting tool BodySM. + BodySM* cutting_tool_ptr = surf->bodysm(); + assert(cutting_tool_ptr ); + + CubitStatus stat; + stat = + this->webcut(webcut_body_list, cutting_tool_ptr, results_list, imprint) ; + + num_cut = results_list.size(); + + // Delete the BodySM that was created to be used as a tool + get_gqe()->delete_solid_model_entities(cutting_tool_ptr) ; + return stat; +} + +CubitStatus GeometryModifyEngine::webcut_with_sweep_surfaces_rotated( + DLIList<BodySM*> &blank_bodies, + DLIList<Surface*> &surfaces, + const CubitVector& point, + const CubitVector& sweep_vector, + double angle, + Surface *stop_surf, + bool up_to_next, + DLIList<BodySM*> &results_list, + CubitBoolean imprint ) +{ + if(surfaces.size() == 0 ) + return CUBIT_FAILURE; + + DLIList<GeometryEntity*> ref_ent_list; + Surface * temp_face = NULL; + for(int i = 0; i < surfaces.size(); i++) + { + //copy the faces before sweep + temp_face = make_Surface(surfaces.get_and_step()); + if (temp_face) + ref_ent_list.append((GeometryEntity*)temp_face); + } + + BodySM* to_body = NULL; + CubitStatus stat = CUBIT_SUCCESS; + if(up_to_next && blank_bodies.size() > 1) //unite all bland_bodies + { + DLIList<BodySM*> newBodies; + + DLIList<BodySM*> copied_bodies; + for(int i = 0; i < blank_bodies.size(); i++) + copied_bodies.append(copy_body(blank_bodies.get_and_step())); + + stat = unite(copied_bodies, newBodies); + + if(stat == CUBIT_FAILURE) + { + PRINT_ERROR("Cannot use 'up_to_next' option with specified geometry\n"); + PRINT_INFO("Try the 'stop surface <id>' option instead\n"); + return stat; + } + to_body = newBodies.get(); + } + + else if(up_to_next && blank_bodies.size() == 1) + to_body = copy_body(blank_bodies.get()); + + DLIList<BodySM*> swept_bodies; + stat = sweep_rotational(ref_ent_list,swept_bodies,point, + sweep_vector,angle,0, 0.0,0,false,false, + false,stop_surf, to_body); + if(stat == CUBIT_FAILURE && swept_bodies.size() == 0) + { + //delete copied faces + GeometryEntity * temp_entity = NULL; + for(int i = ref_ent_list.size();i--;) + { + temp_entity = ref_ent_list.get_and_step(); + if (temp_entity) + get_gqe()->delete_solid_model_entities( (Surface*)temp_entity); + } + + return stat; + } + + //if there are more than 1, unite them all + DLIList<BodySM*> newBodies; + if (swept_bodies.size() > 1) + stat = unite(swept_bodies, newBodies); + else + newBodies = swept_bodies; + + if(stat == CUBIT_FAILURE || newBodies.size()!= 1) + { + PRINT_ERROR("webcut tool body is not created from acis.\n"); + //delete the swept_bodies + BodySM* tmp_body = NULL; + for (int i = swept_bodies.size(); i--;) + { + tmp_body= swept_bodies.get_and_step(); + if (tmp_body) + get_gqe()->delete_solid_model_entities(tmp_body); + } + + //delete copied faces + GeometryEntity * temp_entity = NULL; + for(int i = ref_ent_list.size();i--;) + { + temp_entity = ref_ent_list.get_and_step(); + if (temp_entity) + get_gqe()->delete_solid_model_entities( (Surface*)temp_entity); + } + return CUBIT_FAILURE; + } + + BodySM *cutting_tool_ptr = newBodies.get(); + + stat = + this->webcut(blank_bodies, cutting_tool_ptr, results_list, imprint ) ; + + // Delete the BodySM that was created to be used as a tool + get_gqe()->delete_solid_model_entities(cutting_tool_ptr) ; + + return stat; +} + +CubitStatus GeometryModifyEngine::webcut_with_sweep_surfaces( + DLIList<BodySM*> &blank_bodies, + DLIList<Surface*> &surfaces, + const CubitVector& sweep_vector, + bool sweep_perp, + bool through_all, + bool outward, + bool up_to_next, + Surface *stop_surf, + Curve *curve_to_sweep_along, + DLIList<BodySM*> &results_list, + CubitBoolean imprint ) +{ + if(surfaces.size() == 0 ) + return CUBIT_FAILURE; + + CubitVector tmp_sweep_vector = sweep_vector; + + //get model bbox info...will scale sweep vector by its diagonal + //so that we go far enough + if( through_all || stop_surf || up_to_next) + { + CubitBox bounding_box = GeometryQueryTool::instance()->model_bounding_box(); + tmp_sweep_vector.normalize(); + tmp_sweep_vector*=(2*bounding_box.diagonal().length()); + } + + if( sweep_perp == true ) + { + if( through_all || stop_surf ) + { + CubitBox bounding_box = GeometryQueryTool::instance()->model_bounding_box(); + tmp_sweep_vector.set(1,0,0); + tmp_sweep_vector = 2*(bounding_box.diagonal()); + } + } + + BodySM* to_body = NULL; + CubitStatus stat = CUBIT_SUCCESS; + if(up_to_next && blank_bodies.size() > 1) //unite all bland_bodies + { + DLIList<BodySM*> newBodies; + DLIList<BodySM*> copied_bodies; + for(int i = 0; i < blank_bodies.size(); i++) + copied_bodies.append(copy_body(blank_bodies.get_and_step())); + + stat = unite(copied_bodies, newBodies); + if(stat == CUBIT_FAILURE) + { + PRINT_ERROR("Cannot use 'up_to_next' option with specified geometry\n"); + PRINT_INFO("Try the 'stop surface <id>' option instead\n"); + return stat; + } + to_body = newBodies.get(); + } + + else if(up_to_next && blank_bodies.size() == 1) + to_body = copy_body(blank_bodies.get()); + + DLIList<GeometryEntity*> ref_ent_list; + Surface * temp_face = NULL; + for(int i = 0; i < surfaces.size(); i++) + { + //copy the faces before sweep + temp_face = make_Surface(surfaces.get_and_step()); + if (temp_face) + ref_ent_list.append((GeometryEntity*)temp_face); + } + + //Sweep surfaces + DLIList<BodySM*> swept_bodies; + + //see if we're sweeping along a specified curve + if( curve_to_sweep_along ) + { + DLIList<Curve*> curves_to_sweep_along; + curves_to_sweep_along.append(curve_to_sweep_along); + stat = sweep_along_curve(ref_ent_list, swept_bodies, + curves_to_sweep_along, 0.0,0,false,stop_surf, + to_body); + } + + else if (sweep_perp ) + stat = sweep_perpendicular(ref_ent_list, swept_bodies, + tmp_sweep_vector.length(),0.0,0,outward,false, + stop_surf, to_body); + else + stat = sweep_translational(ref_ent_list, swept_bodies, + tmp_sweep_vector,0.0,0, false, false, stop_surf, + to_body); + + + if (stat == CUBIT_FAILURE && swept_bodies.size() == 0) + { + //delete copied faces + GeometryEntity * temp_entity = NULL; + for(int i = ref_ent_list.size();i--;) + { + temp_entity = ref_ent_list.get_and_step(); + if (temp_entity) + get_gqe()->delete_solid_model_entities( (Surface*)temp_entity); + } + return stat; + } + + //if there are more than 1, unite them all + DLIList<BodySM*> newBodies; + if (swept_bodies.size() > 1) + stat = unite(swept_bodies, newBodies); + else + newBodies = swept_bodies; + + if(stat == CUBIT_FAILURE || newBodies.size()!= 1) + { + PRINT_ERROR("the webcut tool body is not created from acis.\n"); + //delete the swept_bodies + BodySM* tmp_body = NULL; + for (int i = swept_bodies.size(); i--;) + { + tmp_body= swept_bodies.get_and_step(); + if (tmp_body) + get_gqe()->delete_solid_model_entities(tmp_body); + } + //delete copied faces + GeometryEntity * temp_entity = NULL; + for(int i = ref_ent_list.size();i--;) + { + temp_entity = ref_ent_list.get_and_step(); + if (temp_entity) + get_gqe()->delete_solid_model_entities( (Surface*)temp_entity); + } + + return CUBIT_FAILURE; + } + + BodySM *cutting_tool_ptr = newBodies.get(); + + stat = + this->webcut(blank_bodies, cutting_tool_ptr, results_list, imprint ) ; + + // Delete the BodySM that was created to be used as a tool + get_gqe()->delete_solid_model_entities(cutting_tool_ptr) ; + + return stat; +} Modified: cgm/trunk/geom/GeometryModifyEngine.hpp =================================================================== --- cgm/trunk/geom/GeometryModifyEngine.hpp 2007-08-24 20:05:52 UTC (rev 1252) +++ cgm/trunk/geom/GeometryModifyEngine.hpp 2007-08-24 20:43:22 UTC (rev 1253) @@ -150,6 +150,15 @@ //- specific modeling engine. For example, if the engine is //- AcisGeometryEngine, then a SurfaceACIS is created. + virtual CubitStatus stitch_surfs( + DLIList<BodySM*> &surf_bodies, + BodySM *& stitched_Body )const= 0; + //I List of surface_bodys you want stitched together + //IO If stitching of FACEs is successful, stitched_Body is resultant BodySM. + // Means that all surfaces could be stitched together, forming a single BODY, + // but not a single FACE. + //returns CUBIT_SUCCESS if stitching was successful, other return FAILURE + virtual Lump* make_Lump( DLIList<Surface*>& surface_list ) const = 0; //R Lump* //R- Pointer to a newly created Lump object. @@ -244,7 +253,7 @@ //- Returns the ID of the new Body or CUBIT_FAILURE virtual BodySM* cylinder( double hi, double r1, double r2, - double r3 ) const = 0 ; + double r3) const = 0; //- Creates an ACIS frustum and assigns it to a Body $ //- {hi} input height $ //- {r1} input radius in x-direction at base $ @@ -458,7 +467,9 @@ double draft_angle, int draft_type, bool switchside, - bool rigid) const = 0; + bool rigid, + Surface* stop_surf = NULL, + BodySM* stop_body = NULL) const = 0; virtual CubitStatus sweep_perpendicular( DLIList<GeometryEntity*>& ref_ent_list, @@ -467,7 +478,9 @@ double draft_angle, int draft_type, bool switchside, - bool rigid) const = 0; + bool rigid, + Surface* stop_surf = NULL, + BodySM* stop_body = NULL ) const = 0; virtual CubitStatus sweep_rotational( DLIList<GeometryEntity*>& ref_ent_list, @@ -480,7 +493,9 @@ int draft_type = 0, bool switchside = false, bool make_solid = false, - bool rigid = false ) const = 0; + bool rigid = false, + Surface *stop_surf = NULL, + BodySM* stop_body = NULL ) const = 0; virtual CubitStatus sweep_along_curve( DLIList<GeometryEntity*>& ref_ent_list, @@ -488,18 +503,22 @@ DLIList<Curve*>& ref_edge_list, double draft_angle = 0.0, int draft_type = 0, - bool rigid = false ) const= 0; + bool rigid = false, + Surface *stop_surf = NULL, + BodySM* stop_body = NULL ) const= 0; virtual CubitStatus scale( BodySM *&body, const CubitVector& factors ) = 0; //HEADER- Webcut-related functions - virtual CubitStatus webcut( DLIList<BodySM*>& webcut_body_list, - const CubitVector &v1, - const CubitVector &v2, - const CubitVector &v3, - DLIList<BodySM*>& results_list, - bool imprint = false ) const = 0; + virtual CubitStatus webcut( + DLIList<BodySM*>& webcut_body_list, + const CubitVector &v1, + const CubitVector &v2, + const CubitVector &v3, + DLIList<BodySM*>& results_list, + bool imprint = false + ) const = 0; //R int //R- Number of bodies that were webcut ( >= 0 ) //I webcut_body_list @@ -516,10 +535,12 @@ //- The newly created bodies are merged and imprinted depeding on //- the respective flags. - virtual CubitStatus webcut(DLIList<BodySM*>& webcut_body_list, - BodySM const* tool_body, - DLIList<BodySM*>& results_list, - bool imprint = false ) const = 0 ; + virtual CubitStatus webcut( + DLIList<BodySM*>& webcut_body_list, + BodySM const* tool_body, + DLIList<BodySM*>& results_list, + bool imprint = false + ) const = 0 ; //R int //R- Number of bodies that were webcut ( >= 0 ) //I webcut_body_list @@ -548,10 +569,12 @@ //- I- Bodies to be webcut, plane to define cuts, and imprint merge flags. //- This is an experimental function, hooked to the GUI for making //- bodies one to one sweeps. + /* virtual CubitStatus webcut_with_sheet(DLIList<BodySM*>& webcut_body_list, BodySM *sheet_body, DLIList<BodySM*> &new_bodies, bool imprint = false) = 0; + */ //- webcuts a body using a sheet body. //- It splits the sheet into two single sided bodies. //- it then subtracts this with the webcut body. @@ -564,7 +587,7 @@ Surface *extend_from, DLIList<BodySM*> &new_bodies, int &num_cut, - bool imprint = false ) = 0; + bool imprint = false ); //- creates a surface by extending one from the given surface then //- webcuts using the this sheet.(see webcut_with_sheet. @@ -579,7 +602,7 @@ Surface *stop_surf, Curve *curve_to_sweep_along, DLIList<BodySM*> &results_list, - CubitBoolean imprint = false) = 0; + CubitBoolean imprint = false); virtual CubitStatus webcut_with_sweep_curves( DLIList<BodySM*> &blank_bodies, @@ -589,7 +612,7 @@ Surface *stop_surf, Curve *curve_to_sweep_along, DLIList<BodySM*> &results_list, - CubitBoolean imprint = false) = 0; + CubitBoolean imprint = false) ; virtual CubitStatus webcut_with_sweep_curves_rotated( DLIList<BodySM*> &blank_bodies, @@ -599,7 +622,7 @@ double angle, Surface *stop_surf, DLIList<BodySM*> &results_list, - CubitBoolean imprint = false) = 0; + CubitBoolean imprint = false) ; virtual CubitStatus webcut_with_sweep_surfaces_rotated( DLIList<BodySM*> &blank_bodies, @@ -610,24 +633,24 @@ Surface *stop_surf, bool up_to_next, DLIList<BodySM*> &results_list, - CubitBoolean imprint = false) = 0; + CubitBoolean imprint = false); virtual CubitStatus webcut_with_cylinder( - DLIList<BodySM*> &webcut_body_list, + DLIList<BodySM*> &webcut_body_list, double radius, const CubitVector &axis, const CubitVector ¢er, DLIList<BodySM*>& results_list, - bool imprint = false) = 0; + bool imprint = false) ; //- webcuts a body using a cylinder give the input parameters. - virtual CubitStatus webcut_with_brick( + CubitStatus webcut_with_brick( DLIList<BodySM*>& webcut_body_list, const CubitVector ¢er, const CubitVector axes[3], const CubitVector &extension, DLIList<BodySM*> &results_list, - bool imprint = false ) = 0; + bool imprint = false ); /**< Webcuts the bodies in the list with a cutting brick. * The brick is created by the given parameters - center of * brick, xyz axes, and extension. Extension is 1/2 width, @@ -638,12 +661,12 @@ */ virtual CubitStatus webcut_with_planar_sheet( - DLIList<BodySM*>& webcut_body_list, + DLIList<BodySM*>& webcut_body_list, const CubitVector ¢er, const CubitVector axes[2], double width, double height, DLIList<BodySM*> &results_list, - bool imprint = false ) = 0; + bool imprint = false ); /**< Webcuts the bodies in the list with a cutting planar sheet. * The sheet is created by the given parameters - center of * sheet, xy axes, and width and height. Sheet creation is done @@ -654,7 +677,7 @@ DLIList<BodySM*> &webcut_body_list, DLIList<Curve*> &ref_edge_list, DLIList<BodySM*>& results_list, - bool imprint = false) = 0; + bool imprint = false) ; //- webcuts a body list using a temp sheet body created from the curve loop Modified: cgm/trunk/geom/GeometryModifyTool.cpp =================================================================== --- cgm/trunk/geom/GeometryModifyTool.cpp 2007-08-24 20:05:52 UTC (rev 1252) +++ cgm/trunk/geom/GeometryModifyTool.cpp 2007-08-24 20:43:22 UTC (rev 1253) @@ -5032,7 +5032,7 @@ push_vg_attributes_before_modify(body_sm_list); - CubitStatus stat = gme->webcut_with_sheet ( + CubitStatus stat = gme->webcut ( body_sm_list, tool_sm, new_sms, imprint ); restore_vg_after_modify(new_sms, original_body_list); Modified: cgm/trunk/geom/facet/FacetModifyEngine.cpp =================================================================== --- cgm/trunk/geom/facet/FacetModifyEngine.cpp 2007-08-24 20:05:52 UTC (rev 1252) +++ cgm/trunk/geom/facet/FacetModifyEngine.cpp 2007-08-24 20:43:22 UTC (rev 1253) @@ -1286,6 +1286,13 @@ return (BodySM*) NULL; } +CubitStatus FacetModifyEngine::stitch_surfs( + DLIList<BodySM*>& surf_bodies, + BodySM*& stitched_body) const +{ + PRINT_ERROR("Option not supported for mesh based geometry.\n"); + return CUBIT_SUCCESS; +} //=============================================================================== // Function : subtract // Member Type: PUBLIC @@ -1775,7 +1782,9 @@ double /*draft_angle*/, int /*draft_type*/, bool /*switchside*/, - bool /*rigid*/) const + bool /*rigid*/, + Surface * /*stop_face*/, + BodySM *stop_body )const { PRINT_ERROR("Option not supported for mesh based geometry.\n"); return CUBIT_FAILURE; @@ -1795,7 +1804,9 @@ double /*draft_angle*/, int /*draft_type*/, bool /*switchside*/, - bool /*rigid*/) const + bool /*rigid*/, + Surface* stop_surf, + BodySM *stop_body ) const { PRINT_ERROR("Option not supported for mesh based geometry.\n"); return CUBIT_FAILURE; @@ -1819,7 +1830,9 @@ int /*draft_type*/, bool /*switchside*/, bool /*make_solid*/, - bool /*rigid*/) const + bool /*rigid*/, + Surface * /*stop_face*/, + BodySM *stop_body) const { PRINT_ERROR("Option not supported for mesh based geometry.\n"); return CUBIT_FAILURE; @@ -1838,7 +1851,9 @@ DLIList<Curve*>& /*ref_edge_list*/, double /*draft_angle*/, int /*draft_type*/, - bool /*rigid*/) const + bool /*rigid*/, + Surface * /*stop_face*/, + BodySM *stop_body ) const { PRINT_ERROR("Option not supported for mesh based geometry.\n"); return CUBIT_FAILURE; @@ -1858,7 +1873,8 @@ const CubitVector &v2, const CubitVector &v3, DLIList<BodySM*>& results_list, - bool imprint ) const + bool imprint + ) const { MODIFY_CHECK_RETURN_FAILURE; @@ -1978,10 +1994,11 @@ // Author : John Fowler // Date : 10/02 //=============================================================================== -CubitStatus FacetModifyEngine::webcut(DLIList<BodySM*>& /*webcut_body_list*/, - BodySM const* /*tool_body*/, - DLIList<BodySM*>& /*results_list*/, - bool /*imprint*/ ) const +CubitStatus FacetModifyEngine::webcut( + DLIList<BodySM*>& /*webcut_body_list*/, + BodySM const* /*tool_body*/, + DLIList<BodySM*>& /*results_list*/, + bool /*imprint*/ )const { PRINT_ERROR("Option not supported for mesh based geometry.\n"); return CUBIT_FAILURE; @@ -2131,18 +2148,19 @@ // Author : John Fowler // Date : 10/02 //=============================================================================== -CubitStatus FacetModifyEngine::webcut_with_brick( - DLIList<BodySM*>& /*webcut_body_list*/, - const CubitVector &/*center*/, - const CubitVector* /*axes[3]*/, - const CubitVector &/*extension*/, - DLIList<BodySM*> &/*results_list*/, - bool /*imprint*/ ) -{ - PRINT_ERROR("Option not supported for mesh based geometry.\n"); - return CUBIT_FAILURE; -} +//CubitStatus FacetModifyEngine::webcut_with_brick( +// DLIList<BodySM*>& /*webcut_body_list*/, +// const CubitVector &/*center*/, +// const CubitVector* /*axes[3]*/, +// const CubitVector &/*extension*/, +// DLIList<BodySM*> &/*results_list*/, +// bool /*imprint*/ ) +//{ +// PRINT_ERROR("Option not supported for mesh based geometry.\n"); +// return CUBIT_FAILURE; +//} + //=============================================================================== // Function : webcut_with_planar_sheet // Member Type: PUBLIC Modified: cgm/trunk/geom/facet/FacetModifyEngine.hpp =================================================================== --- cgm/trunk/geom/facet/FacetModifyEngine.hpp 2007-08-24 20:05:52 UTC (rev 1252) +++ cgm/trunk/geom/facet/FacetModifyEngine.hpp 2007-08-24 20:43:22 UTC (rev 1253) @@ -139,6 +139,10 @@ virtual BodySM* copy_body ( BodySM* bodyPtr) const ; + virtual CubitStatus stitch_surfs( + DLIList<BodySM*>& surf_bodies, + BodySM*& stitched_body)const; + virtual CubitStatus subtract(DLIList<BodySM*> &tool_body_list, DLIList<BodySM*> &from_bodies, DLIList<BodySM*> &new_bodies, @@ -225,7 +229,9 @@ double draft_angle, int draft_type, bool switchside, - bool rigid) const; + bool rigid, + Surface *stop_surf = NULL, + BodySM *stop_body = NULL) const; virtual CubitStatus sweep_perpendicular( DLIList<GeometryEntity*>& ref_ent_list, @@ -234,7 +240,9 @@ double draft_angle, int draft_type, bool switchside, - bool rigid) const; + bool rigid, + Surface* stop_surf = NULL, + BodySM *stop_body = NULL ) const; virtual CubitStatus sweep_rotational( DLIList<GeometryEntity*>& ref_ent_list, @@ -247,7 +255,9 @@ int draft_type = 0, bool switchside = CUBIT_FALSE, bool make_solid = CUBIT_FALSE, - bool rigid = CUBIT_FALSE ) const; + bool rigid = CUBIT_FALSE , + Surface *stop_surf = NULL, + BodySM *stop_body = NULL) const; virtual CubitStatus sweep_along_curve( DLIList<GeometryEntity*>& ref_ent_list, @@ -255,9 +265,10 @@ DLIList<Curve*>& ref_edge_list, double draft_angle = 0.0, int draft_type = 0, - bool rigid = CUBIT_FALSE ) const; + bool rigid = CUBIT_FALSE, + Surface *stop_surf = NULL, + BodySM *stop_body = NULL ) const; - virtual CubitStatus webcut_with_sweep_surfaces( DLIList<BodySM*> &blank_bodies, DLIList<Surface*> &surfaces, @@ -308,12 +319,13 @@ const CubitVector &v2, const CubitVector &v3, DLIList<BodySM*>& results_list, - bool imprint = false ) const; + bool imprint = false + ) const; virtual CubitStatus webcut(DLIList<BodySM*>& webcut_body_list, BodySM const* tool_body, DLIList<BodySM*>& results_list, - bool imprint = false ) const; + bool imprint = false)const; virtual CubitStatus webcut_across_translate( DLIList<BodySM*>& body_list, Surface* plane_surf1, @@ -340,12 +352,13 @@ DLIList<BodySM*>& results_list, bool imprint = false ); - virtual CubitStatus webcut_with_brick( DLIList<BodySM*>& webcut_body_list, +/* virtual CubitStatus webcut_with_brick( DLIList<BodySM*>& webcut_body_list, const CubitVector ¢er, const CubitVector axes[3], const CubitVector &extension, DLIList<BodySM*> &results_list, bool imprint = false ); +*/ virtual CubitStatus webcut_with_planar_sheet( DLIList<BodySM*>& webcut_body_list, const CubitVector ¢er,
participants (1)
kraftche@mcs.anl.gov
