Author: kraftche Date: 2008-10-20 15:22:33 -0500 (Mon, 20 Oct 2008) New Revision: 2160 Modified: cgm/trunk/geom/OCC/OCCShapeAttributeSet.cpp Log: fix buffer overflows, memory leaks, non-portable code, assumption that attributes will never contain more than 10 numerical values, and other nastiness in parsing routine Modified: cgm/trunk/geom/OCC/OCCShapeAttributeSet.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCShapeAttributeSet.cpp 2008-10-20 20:01:05 UTC (rev 2159) +++ cgm/trunk/geom/OCC/OCCShapeAttributeSet.cpp 2008-10-20 20:22:33 UTC (rev 2160) @@ -416,91 +416,57 @@ Standard_IStream& IS, TDF_Label& l_attr) { - char buffer[255]; + std::string buffer, type, stringdata; DLIList<CubitString*> strings; DLIList<double> doubles; DLIList<int> ints; do { IS >> buffer; - int i = 0; - while(buffer[i] != '*') - i++; - strings.clean_out(); - char type[i]; - - i = 0; - while(buffer[i] != '*') - { - type[i] = buffer[i]; - i++; - } - CubitString string(type); - string = string.substr(0, i ); - CubitString* string_prt = new CubitString(string); + std::string::size_type i = buffer.find_first_of("*"); + type = buffer.substr( 0, i ); + + CubitString* string_prt = new CubitString(type.c_str()); strings.append(string_prt); IS >> buffer; //consider there's only one string in the stringdata field - i = 0; - while(buffer[i] != '*') - i++; - char* stringdata = NULL; + i = buffer.find_first_of("*"); if(i > 0) { - stringdata = new char[i]; - i = 0; - while(buffer[i] != '*') - { - stringdata[i] = buffer[i]; - i++; - } - CubitString string2(stringdata); - string2 = string2.substr(0, i ); - CubitString* string_prt2 = new CubitString(string2); + stringdata = buffer.substr( 0, i ); + CubitString* string_prt2 = new CubitString(stringdata.c_str()); strings.append(string_prt2); } IS.get(); //' ' - int ints_[10]; - double doubles_[10]; + int tmp_int; + double tmp_dbl; doubles.clean_out(); ints.clean_out(); char s; IS.get(s); //either '*' or 'number' - i = 0; while (s != '\n') { while(s != '*') // integer attributes { IS.unget(); - IS >> ints_[i]; - i++; + IS >> tmp_int; + ints.append( tmp_int ); IS.get(); //' ' IS.get(s); //either '*' or 'number' } - if(i > 0) - { - for(int j = 0; j < i; j++) - ints.append( ints_[j] ); - } - i = 0; IS.get(); //' ' IS.get(s); //either '*' or 'number' while(s != '*') // double attributes { IS.unget(); - IS >> doubles_[i]; - i++; + IS >> tmp_dbl; + doubles.append( tmp_dbl ); IS.get(); //' ' IS.get(s); //either '*' or 'number' } - if(i > 0) - { - for(int j = 0; j < i; j++) - doubles.append(doubles_[j]); - } IS.get(s); //'\n' }
participants (1)
kraftche@mcs.anl.gov
