Author: janehu Date: 2008-12-24 12:30:44 -0600 (Wed, 24 Dec 2008) New Revision: 2500 Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp Log: Since multiple solutions are possible for create_arc_three with 3 curves, it needs to verify that the 3 bisection lines are intersecting at the same point, if multipul solutions exist, find the first reasonable solution, otherwise gives error messages. Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-12-23 20:15:23 UTC (rev 2499) +++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-12-24 18:30:44 UTC (rev 2500) @@ -30,6 +30,7 @@ #include "BRepBuilderAPI_MakeWire.hxx" #include "BRepPrimAPI_MakeHalfSpace.hxx" #include "BRepBndLib.hxx" +#include "IntersectionTool.hpp" #include "TopoDS_Shape.hxx" #include "TopAbs_Orientation.hxx" #include "TColgp_Array1OfPnt.hxx" @@ -5042,68 +5043,211 @@ CubitVector p32 = vt3 + t_curve32; //3. find the intersection of each of the bisection curve with the third curve - CubitVector int_pt1, int_pt2, int_pt3; + //Error out if there's multiple solutions,urge user to shorten the curves to + //make the intention clear. + + CubitVector int_pt11, int_pt12, int_pt21, int_pt22, int_pt31, int_pt32; intscts.clean_out(); OCCQueryEngine::instance()->get_intersections(curve3, vt1, p11, intscts,none,none); CubitVector int_pt = *intscts.pop(); u = occ_crv3->u_from_position (int_pt); + CubitBoolean found[6] = {CUBIT_FALSE, CUBIT_FALSE, CUBIT_FALSE, CUBIT_FALSE, + CUBIT_FALSE, CUBIT_FALSE}; + if(u >= u31-tol && u <= u32+tol) //found intersection point - int_pt1 = int_pt; - else { - OCCQueryEngine::instance()->get_intersections(curve3, vt1, p12, intscts,none,none); - int_pt = *intscts.pop(); - u = occ_crv3->u_from_position (int_pt); - if(u >= u31-tol && u <= u32+tol) - int_pt1 = int_pt; + int_pt11 = int_pt; + found[0] = CUBIT_TRUE; + } + + OCCQueryEngine::instance()->get_intersections(curve3, vt1, p12, intscts,none,none); + int_pt = *intscts.pop(); + u = occ_crv3->u_from_position (int_pt); + if(u >= u31-tol && u <= u32+tol) + { + if(found[0]) + { + found[1] = CUBIT_TRUE; + int_pt12 = int_pt; + } else { - PRINT_ERROR("Can't find the intesection point to create circle.\n"); - return (Curve*) NULL; + int_pt11 = int_pt; + found[0] = CUBIT_TRUE; } } + if(!found[0] ) + { + PRINT_ERROR("Can't find the intesection point to create circle.\n"); + return (Curve*) NULL; + } OCCQueryEngine::instance()->get_intersections(curve1, vt2, p21, intscts,none,none); int_pt = *intscts.pop(); u = occ_crv1->u_from_position (int_pt); if(u >= u11-tol && u <= u12+tol) //found intersection point - int_pt2 = int_pt; - else { - OCCQueryEngine::instance()->get_intersections(curve1, vt2, p22, intscts,none,none); - int_pt = *intscts.pop(); - u = occ_crv1->u_from_position (int_pt); - if(u >= u11-tol && u <= u12+tol) - int_pt2 = int_pt; + found[2] = CUBIT_TRUE; + int_pt21 = int_pt; + } + + OCCQueryEngine::instance()->get_intersections(curve1, vt2, p22, intscts,none,none); + int_pt = *intscts.pop(); + u = occ_crv1->u_from_position (int_pt); + if(u >= u11-tol && u <= u12+tol) + { + if(found[2]) + { + int_pt22 = int_pt; + found[3] = CUBIT_TRUE; + } else { - PRINT_ERROR("Can't find the intesection point to create circle.\n"); - return (Curve*) NULL; + found[2] = CUBIT_TRUE; + int_pt21 = int_pt; } } + if(!found[2] ) + { + PRINT_ERROR("Can't find the intesection point to create circle.\n"); + return (Curve*) NULL; + } OCCQueryEngine::instance()->get_intersections(curve2, vt3, p31, intscts,none,none); int_pt = *intscts.pop(); u = occ_crv2->u_from_position (int_pt); if(u >= u21-tol && u <= u22+tol) //found intersection point - int_pt3 = int_pt; - else { - OCCQueryEngine::instance()->get_intersections(curve2, vt3, p32, intscts,none,none); - int_pt = *intscts.pop(); - u = occ_crv2->u_from_position (int_pt); - if(u >= u21-tol && u <= u22+tol) - int_pt3 = int_pt; + found[4] = CUBIT_TRUE; + int_pt31 = int_pt; + } + + OCCQueryEngine::instance()->get_intersections(curve2, vt3, p32, intscts,none,none); + int_pt = *intscts.pop(); + u = occ_crv2->u_from_position (int_pt); + if(u >= u21-tol && u <= u22+tol) + { + if(found[4]) + { + int_pt32 = int_pt; + found[5] = CUBIT_TRUE; + } else { - PRINT_ERROR("Can't find the intesection point to create circle.\n"); - return (Curve*) NULL; + found[4] = CUBIT_TRUE; + int_pt31 = int_pt; } } + if(!found[4] ) + { + PRINT_ERROR("Can't find the intesection point to create circle.\n"); + return (Curve*) NULL; + } + + //find the three intersection points which when connected with the vertices, + //intersect at same point. + CubitVector c_p11, c_p12, c_p21, c_p22, c_p31, c_p32, c_p; + double sc, tc; + CubitVector int_pt1, int_pt2, int_pt3; + CubitBoolean find = CUBIT_FALSE; + + IntersectionTool int_tool; + for(int i = 0; i < 8 ; i++) + { + int_tool.closest_points_on_segments(vt1, int_pt11, vt2, int_pt21, c_p11, c_p12, sc, tc); + if(c_p11.distance_between(c_p12) < tol) //intersect + c_p = c_p11; + else + assert(0); + + int_tool.closest_points_on_segments(vt1, int_pt11, vt3, int_pt31, c_p11, c_p12, sc, tc); + if(c_p11.distance_between(c_p12) < tol && sc < 1.0 && tc < 1.0) //intersect + { + if(c_p.distance_between(c_p12) < tol) //three line intersects at same point + { + find = CUBIT_TRUE; + break; + } + } + else //not interscting at same points or parallel + { + if(i == 0) + { + if(found[1]) + { + int_pt1 = int_pt11; + int_pt11 = int_pt12; + } + else + continue; + } + if(i == 1) + { + if(found[1]) + int_pt11 = int_pt1; + if(found[3]) + { + int_pt2 = int_pt21; + int_pt21 = int_pt22; + } + else + continue; + } + if(i == 2) + { + if(found[1] && found[3]) + int_pt11 = int_pt12; + else + continue; + } + if(i == 3) + { + if(found[1]) + int_pt11 = int_pt1; + if(found[3]) + int_pt21 = int_pt2; + if(found[5]) + { + int_pt3 = int_pt31; + int_pt31 = int_pt32; + } + else + continue; + } + if(i == 4) + { + if(found[1] && found[5]) + int_pt11 = int_pt12; + else + continue; + } + if(i == 5) + { + if(found[1]) + int_pt11 = int_pt1; + if(found[3] && found[5]) + int_pt21 = int_pt22; + else + continue; + } + if(i == 6) + { + if(found[1] && found[3] && found[5]) + int_pt11 = int_pt12; + else + continue; + } + } + } + if(!find) + { + PRINT_ERROR("Can't find the intesection point to create circle.\n"); + return (Curve*) NULL; + } //4. use the 3 intersection points to find the arc or circle. - OCCPoint occ_p1(int_pt1); - OCCPoint occ_p2(int_pt2); - OCCPoint occ_p3(int_pt3); + OCCPoint occ_p1(int_pt11); + OCCPoint occ_p2(int_pt21); + OCCPoint occ_p3(int_pt31); return create_arc_three(&occ_p1, &occ_p2, &occ_p3, full); }
participants (1)
janehu@mcs.anl.gov
