Author: janehu Date: 2008-01-28 15:30:01 -0600 (Mon, 28 Jan 2008) New Revision: 1565 Modified: cgm/trunk/geom/OCC/OCCCurve.cpp Log: Finished the project_curve function. Modified: cgm/trunk/geom/OCC/OCCCurve.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCCurve.cpp 2008-01-25 20:04:27 UTC (rev 1564) +++ cgm/trunk/geom/OCC/OCCCurve.cpp 2008-01-28 21:30:01 UTC (rev 1565) @@ -48,7 +48,12 @@ #include <BRepLProp_CLProps.hxx> #include <BRep_Tool.hxx> #include <TopoDS.hxx> +#include "BRepBuilderAPI_MakeEdge.hxx" +#include "Geom_BezierCurve.hxx" #include "GeomAPI_ProjectPointOnCurve.hxx" +#include "TColgp_Array1OfPnt.hxx" +#include "GeomAdaptor_Curve.hxx" +#include "GCPnts_QuasiUniformAbscissa.hxx" #include "TopTools_ListOfShape.hxx" #include "BRepAlgo_NormalProjection.hxx" #include "TopExp_Explorer.hxx" @@ -968,18 +973,24 @@ else if (num_projection == 2) { + double d; + double first, last; + TopoDS_Shape shape1 = projections.First(); + TopoDS_Edge edge1 = TopoDS::Edge(shape1); + + TopoDS_Shape shape2 = projections.Last(); + TopoDS_Edge edge2 = TopoDS::Edge(shape2); + + Handle(Geom_Curve) myCurve1 = + BRep_Tool::Curve(edge1,first,last); + + Handle(Geom_Curve) myCurve2= BRep_Tool::Curve(edge2, first, last); //If the surface is periodic, so it has 2 projections, we just need to //find the segment to which the third_point is closer. if(closed == CUBIT_FALSE && third_point != NULL) { - double d; - double first, last; - TopoDS_Shape shape = projections.First(); - TopoDS_Edge edge = TopoDS::Edge(shape); - Handle(Geom_Curve) myCurve = - BRep_Tool::Curve(edge,first,last); gp_Pnt P (third_point->x(), third_point->y(), third_point->z()); - GeomAPI_ProjectPointOnCurve projOncurve(P, myCurve); + GeomAPI_ProjectPointOnCurve projOncurve(P, myCurve1); if (projOncurve.NbPoints() == 0) { PRINT_ERROR("Cannot project the curve to the surface.\n" @@ -989,10 +1000,7 @@ d = projOncurve.LowerDistance(); //Compare with the second solution - shape = projections.Last(); - edge = TopoDS::Edge(shape); - myCurve = BRep_Tool::Curve(edge, first, last); - GeomAPI_ProjectPointOnCurve projOncurve2(P, myCurve); + GeomAPI_ProjectPointOnCurve projOncurve2(P, myCurve2); if (projOncurve2.NbPoints() == 0) { PRINT_ERROR("Cannot project the curve to the surface.\n" @@ -1010,8 +1018,34 @@ else if (closed == CUBIT_TRUE) { - //connect the two segment into a closed shape. + //connect the two segment into a closed shape. Assume both segment + // has the same curve type, create Bezier closed curve. + GeomAdaptor_Curve acurve1(myCurve1); + GeomAdaptor_Curve acurve2(myCurve2); + //get 10 points of each curve, combine them to make one Bezier curve + int NbPoints = 10; + GCPnts_QuasiUniformAbscissa distribution1(acurve1, NbPoints); + GCPnts_QuasiUniformAbscissa distribution2(acurve2, NbPoints); + TColgp_Array1OfPnt points(1, 2*NbPoints-1); + int i = 1; + for (i; i <= NbPoints; i++) + { + double u = distribution1.Parameter(i); + gp_Pnt P = myCurve1->Value(u); + points.SetValue(i, P); + } + for (int j = NbPoints-1; j >= 1; j--) + { + double u = distribution2.Parameter(j); + gp_Pnt P = myCurve2->Value(u); + points.SetValue(++i,P); + } + + Geom_BezierCurve BezierCurve(points); + Handle(Geom_Curve) curve_ptr(&BezierCurve); + TopoDS_Edge new_edge = BRepBuilderAPI_MakeEdge(curve_ptr); + return OCCQueryEngine::instance()->populate_topology_bridge(new_edge); } } }
participants (1)
janehu@mcs.anl.gov
