Author: kraftche Date: 2008-10-29 14:44:57 -0500 (Wed, 29 Oct 2008) New Revision: 2183 Modified: cgm/trunk/Makefile.am cgm/trunk/configure.in cgm/trunk/itaps/Makefile.am Log: fix test build issues Modified: cgm/trunk/Makefile.am =================================================================== --- cgm/trunk/Makefile.am 2008-10-29 19:22:27 UTC (rev 2182) +++ cgm/trunk/Makefile.am 2008-10-29 19:44:57 UTC (rev 2183) @@ -1,5 +1,5 @@ AUTOMAKE_OPTIONS = foreign -SUBDIRS = util geom init itaps . test cgm_apps +SUBDIRS = util geom init . itaps test cgm_apps # Don't loose the autoconf include path ACLOCAL_AMFLAGS = -I m4 @@ -59,7 +59,6 @@ libcgm_la_LIBADD = init/libcgma_init.la \ - itaps/libiGeom.la \ $(CORE_CGM_LIBS) \ $(EXT_LINK_FLAGS) \ $(EXT_LIBS) Modified: cgm/trunk/configure.in =================================================================== --- cgm/trunk/configure.in 2008-10-29 19:22:27 UTC (rev 2182) +++ cgm/trunk/configure.in 2008-10-29 19:44:57 UTC (rev 2183) @@ -125,7 +125,7 @@ fi CGM_LIBS_LINK='$(CUBIT_LDFLAGS) $(CUBIT_LIBS)' CGM_LIBS_FILES='$(CUBIT_FILE)' - CGM_LIBS_LTFLAGS='$(CUBIT_LTFLAGS)' + CGM_LIBS_LTFLAGS="$CGM_LIBS_LTFLAGS $CUBIT_LTFLAGS" CUBIT_CGM="-DCUBIT_CGM" dnl AC_DEFINE( HAVE_ACIS, "Have CGM ACIS Implementation" ) HAVE_ACIS_DEF=-DHAVE_ACIS @@ -199,6 +199,8 @@ ACIS_LINK_FLAGS='-L$(ACIS_LIB_DIR)' ACIS_HEALER="-DACIS_HEALER" ACIS_INCLUDES="-I$ACIS_DIR/include" + ACIS_LTFLAGS="-R$ACIC_LIB_DIR" + CGM_LIBS_LTFLAGS="$CGM_LIBS_LTFLAGS $ACIS_LTFLAGS" if test "x$GXX" = "xyes"; then CPPFLAGS="$CPPFLAGS -isystem $ACIS_DIR/include" fi Modified: cgm/trunk/itaps/Makefile.am =================================================================== --- cgm/trunk/itaps/Makefile.am 2008-10-29 19:22:27 UTC (rev 2182) +++ cgm/trunk/itaps/Makefile.am 2008-10-29 19:44:57 UTC (rev 2183) @@ -10,14 +10,8 @@ SUBDIRS = . $(SIDL_DIR) -noinst_LTLIBRARIES = libiGeom.la +lib_LTLIBRARIES = libiGeom.la -if build_ACIS - TEST_ACISPATH = -R$(ACIS_LIB_DIR) -else - TEST_ACISPATH = -endif - libiGeom_la_includedir = $(includedir) libiGeom_la_LIBADD = ../libcgm.la @@ -49,9 +43,9 @@ check_PROGRAMS = $(TESTS) testgeom_SOURCES = testgeom.cc -testgeom_LDADD = ../libcgm.la +testgeom_LDADD = libiGeom.la testgeom_CPPFLAGS = $(CPPFLAGS) -DSRCDIR=$(srcdir) -testgeom_LDFLAGS = $(TEST_ACISPATH) +testgeom_LDFLAGS = $(CGM_LIBS_LTFLAGS) # Automake doesn't seem to have a directory defined for # platform-dependent data (or include) files. So put
participants (1)
kraftche@mcs.anl.gov
