r6082 - in cgm/branches/merge-cubit14.0: . compat compat/new geom itaps test
Author: janehu Date: 2013-11-01 12:45:08 -0500 (Fri, 01 Nov 2013) New Revision: 6082 Added: cgm/branches/merge-cubit14.0/compat/ cgm/branches/merge-cubit14.0/compat/Makefile.am cgm/branches/merge-cubit14.0/compat/new/ cgm/branches/merge-cubit14.0/compat/new/new.h cgm/branches/merge-cubit14.0/geom/CubitCompat.cpp cgm/branches/merge-cubit14.0/geom/CubitCompat.h.in cgm/branches/merge-cubit14.0/geom/CubitCompat.hpp cgm/branches/merge-cubit14.0/test/cylinders.cpp cgm/branches/merge-cubit14.0/test/s5.sat cgm/branches/merge-cubit14.0/test/s5.stp cgm/branches/merge-cubit14.0/test/spheres.cpp Modified: cgm/branches/merge-cubit14.0/itaps/Makefile.am cgm/branches/merge-cubit14.0/itaps/iGeom_CGMA.cc cgm/branches/merge-cubit14.0/test/Makefile.am cgm/branches/merge-cubit14.0/test/r_w.cpp cgm/branches/merge-cubit14.0/test/subtract.cpp Log: Added missing files; Removed some of the warnings; Passed make check for cubit shared, occ static and shared builds. Ready to move to bitbucket. Added: cgm/branches/merge-cubit14.0/compat/Makefile.am =================================================================== --- cgm/branches/merge-cubit14.0/compat/Makefile.am (rev 0) +++ cgm/branches/merge-cubit14.0/compat/Makefile.am 2013-11-01 17:45:08 UTC (rev 6082) @@ -0,0 +1 @@ +EXTRA_DIST = new/new.h Added: cgm/branches/merge-cubit14.0/compat/new/new.h =================================================================== --- cgm/branches/merge-cubit14.0/compat/new/new.h (rev 0) +++ cgm/branches/merge-cubit14.0/compat/new/new.h 2013-11-01 17:45:08 UTC (rev 6082) @@ -0,0 +1,11 @@ +#include <new> + +// According to section 18.4 of the 2005-10-19 working draft +// of the C++ Standard (Doc no: N1905=05-0165), these are the +// symbols defined in the <new> header. + +using std::bad_alloc; +using std::nothrow_t; +using std::nothrow; +using std::new_handler; +using std::set_new_handler; Added: cgm/branches/merge-cubit14.0/geom/CubitCompat.cpp =================================================================== --- cgm/branches/merge-cubit14.0/geom/CubitCompat.cpp (rev 0) +++ cgm/branches/merge-cubit14.0/geom/CubitCompat.cpp 2013-11-01 17:45:08 UTC (rev 6082) @@ -0,0 +1,93 @@ +#include "CubitCompat.h" +#include "CubitCompat.hpp" +#include "GeometryQueryTool.hpp" +#include <string.h> + +#define CUBIT_COMPAT_FT_ELIF(TYPE) \ + else if (!strcmp(file_type,#TYPE)) \ + return TYPE ## _TYPE + +static Model_File_Type +CubitCompat_file_type( const char* file_type ) +{ + if (!file_type) + return MFT_NOT_DEFINED; + CUBIT_COMPAT_FT_ELIF(ACIS); + CUBIT_COMPAT_FT_ELIF(ACIS_SAT); + CUBIT_COMPAT_FT_ELIF(ACIS_SAB); + CUBIT_COMPAT_FT_ELIF(ACIS_DEBUG); + CUBIT_COMPAT_FT_ELIF(IGES); + CUBIT_COMPAT_FT_ELIF(CATIA); + CUBIT_COMPAT_FT_ELIF(STEP); + CUBIT_COMPAT_FT_ELIF(PROE);
participants (1)
janehu@mcs.anl.gov
