Author: janehu Date: 2008-03-06 13:58:48 -0600 (Thu, 06 Mar 2008) New Revision: 1637 Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp Log: Added copy body, prism for 4 sided case and pyramid for wedge case. Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp =================================================================== --- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-03-05 20:12:56 UTC (rev 1636) +++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-03-06 19:58:48 UTC (rev 1637) @@ -55,6 +55,7 @@ #include "BRepAlgoAPI_Fuse.hxx" #include "BRepPrimAPI_MakeSphere.hxx" #include "BRepPrimAPI_MakeBox.hxx" +#include "BRepPrimAPI_MakeWedge.hxx" #include "Handle_Geom_TrimmedCurve.hxx" #include "Handle_Geom_RectangularTrimmedSurface.hxx" #include "TopExp_Explorer.hxx" @@ -1192,8 +1193,14 @@ BodySM* OCCModifyEngine::prism( double height, int sides, double major, double minor) const { - PRINT_ERROR("Option not supported for OCC based geometry.\n"); - return (BodySM*) NULL; + //currently OCC only support 4 sided prism + if (sides != 4) + { + PRINT_ERROR("Option not supported for OCC based geometry.\n"); + return (BodySM*) NULL; + } + + return brick(2 * major, 2 * minor, height); } //=============================================================================== @@ -1206,8 +1213,23 @@ BodySM* OCCModifyEngine::pyramid( double height, int sides, double major, double minor, double top) const { - PRINT_ERROR("Option not supported for OCC based geometry.\n"); - return (BodySM*) NULL; + //currently OCC only support 4 sided pyramid + if (sides != 4) + { + PRINT_ERROR("Option not supported for OCC based geometry.\n"); + return (BodySM*) NULL; + } + + TopoDS_Solid S = BRepPrimAPI_MakeWedge( 2 * major, 2* minor, height, + 2 * top); + + Lump* lump = OCCQueryEngine::instance()->populate_topology_bridge(S, + CUBIT_TRUE); + if (lump == NULL) + return (BodySM*)NULL; + + return CAST_TO(lump, OCCLump)->body(); + } //=============================================================================== @@ -1339,14 +1361,55 @@ //=============================================================================== // Function : copy_body // Member Type: PUBLIC -// Description: copy a facet-based body -// Author : John Fowler -// Date : 10/02 +// Description: copy an OCC-based body +// Author : Jane Hu +// Date : 03/08 //=============================================================================== -BodySM* OCCModifyEngine::copy_body ( BodySM* /*bodyPtr*/) const +BodySM* OCCModifyEngine::copy_body ( BodySM* bodyPtr ) const { - PRINT_ERROR("Option not supported for mesh based geometry.\n"); - return (BodySM*) NULL; + OCCBody* occ_body = CAST_TO(bodyPtr, OCCBody); + if (!occ_body) + { + PRINT_ERROR("Cannot create an OCC bodySM from the given bodySM.\n" + "Possible incompatible geometry engines.\n"); + return (BodySM *)NULL; + } + + TopoDS_CompSolid *theCS = occ_body->get_TopoDS_Shape(); + + if (theCS == NULL) //sheet body + { + Surface* surface = make_Surface(occ_body->my_sheet_surface()); + if (surface == NULL) + { + PRINT_ERROR("Cannot create an OCC sheet bodySM from the given bodySM.\n"); + return (BodySM *)NULL; + } + + return CAST_TO(surface,OCCSurface)->my_body(); + } + + if(OCCQueryEngine::instance()->OCCMap->IsBound(*theCS)) + { + BRepBuilderAPI_Copy api_copy(*theCS); + + TopoDS_Shape newShape = api_copy.ModifiedShape(*theCS); + + TopoDS_CompSolid newCS = TopoDS::CompSolid(newShape); + + return OCCQueryEngine::instance()->populate_topology_bridge(newCS); + } + + //single lump body + Lump *lump = occ_body->lumps().get(); + TopoDS_Solid solid = *(CAST_TO(lump, OCCLump)->get_TopoDS_Solid()); + BRepBuilderAPI_Copy api_copy(solid); + TopoDS_Shape newShape = api_copy.ModifiedShape(solid); + TopoDS_Solid newSolid = TopoDS::Solid(newShape); + lump = OCCQueryEngine::instance()->populate_topology_bridge(newSolid, + CUBIT_TRUE); + + return CAST_TO(lump, OCCLump)->body(); } CubitStatus OCCModifyEngine::stitch_surfs(
participants (1)
janehu@mcs.anl.gov
